    4. Test Adapter mihome-vacuum v2.0.x
      dehein2 last edited by
      Hallo nochmal,
      ich habe nun Valetudo installiert und das webinterface funktioniert. Leider klappt die Bedienung über iobroker nicht. Es hat kurz funktioniert nun aber wieder nicht. Weder reagiert der Roboter zuverflässig auf Tastendrücke noch bekomme ich eine Karte angezeigt. Hier einmal ein Log:
      mihome-vacuum.0	2020-03-03 21:32:51.728	debug	(9962) requesting params every: 60 Sec
      mihome-vacuum.0	2020-03-03 21:32:43.764	info	(9962) should trigger cleaning all null, but is currently active. Add to queue
      mihome-vacuum.0	2020-03-03 21:32:43.759	debug	(9962) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      mihome-vacuum.0	2020-03-03 21:32:43.758	debug	(9962) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1583267563751,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581065963877}
      mihome-vacuum.0	2020-03-03 21:32:42.738	debug	(9962) stateChange mihome-vacuum.0.control.resumeRoomClean {"val":true,"ack":false,"ts":1583267562734,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1582918439862}
      mihome-vacuum.0	2020-03-03 21:32:39.365	debug	(9962) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1583267559362,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066074377}
      mihome-vacuum.0	2020-03-03 21:32:33.774	debug	(9962) no answer for get_consumable(id:19) received, giving up
      mihome-vacuum.0	2020-03-03 21:32:33.575	warn	(9962) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
      mihome-vacuum.0	2020-03-03 21:32:33.574	debug	(9962) no answer for miIO.info(id:18) received, giving up
      mihome-vacuum.0	2020-03-03 21:32:33.572	debug	(9962) no answer for get_status(id:17) received, giving up
      mihome-vacuum.0	2020-03-03 21:32:30.061	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267550058,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
      mihome-vacuum.0	2020-03-03 21:32:29.391	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267549384,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
      mihome-vacuum.0	2020-03-03 21:32:28.387	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267548380,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
      mihome-vacuum.0	2020-03-03 21:32:24.506	debug	(9962) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583267544500,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581066090653}
      mihome-vacuum.0	2020-03-03 21:32:23.564	debug	(9962) no answer for get_status(id:16) received, giving up
      mihome-vacuum.0	2020-03-03 21:32:22.574	debug	(9962) stateChange mihome-vacuum.0.control.resumeRoomClean {"val":true,"ack":false,"ts":1583267542571,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1582918439862}
      mihome-vacuum.0	2020-03-03 21:32:18.567	debug	(9962) requesting params every: 60 Sec
      mihome-vacuum.0	2020-03-03 21:32:18.565	info	(9962) Connected
      mihome-vacuum.0	2020-03-03 21:32:18.561	info	(9962) Disconnect
      mihome-vacuum.0	2020-03-03 21:32:16.356	debug	(9962) no answer for get_status(id:15) received, giving up
      mihome-vacuum.0	2020-03-03 21:32:14.354	debug	(9962) no answer for undefined(id:14) received, giving up
      mihome-vacuum.0	2020-03-03 21:32:09.741	debug	(9962) no answer for get_room_mapping(id:13) received, giving up
      mihome-vacuum.0	2020-03-03 21:32:09.730	debug	(9962) no answer for get_carpet_mode(id:12) received, giving up
      mihome-vacuum.0	2020-03-03 21:32:09.679	debug	(9962) system.adapter.admin.0: logging true
      mihome-vacuum.0	2020-03-03 21:32:08.412	debug	(9962) CLEAN_LOGGING[{"Datum":"3.3","Start":"21:30","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"3.3","Start":"21:16","Saugzeit":"3 min","Fläche":"4.38 m²","Error":0,"Ende":fa
      mihome-vacuum.0	2020-03-03 21:32:08.210	debug	(9962) no answer for get_clean_record(id:11) received, giving up
      mihome-vacuum.0	2020-03-03 21:32:06.558	info	(9962) should trigger cleaning all null, but is currently active. Add to queue
      mihome-vacuum.0	2020-03-03 21:32:06.555	debug	(9962) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
      mihome-vacuum.0	2020-03-03 21:32:06.554	debug	(9962) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1583267526551,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1581065963877}
      mihome-vacuum.0	2020-03-03 21:32:03.410	debug	(9962) CLEAN_LOGGING[{"Datum":"3.3","Start":"21:30","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"3.3","Start":"21:16","Saugzeit":"3 min","Fläche":"4.38 m²","Error":0,"Ende":fa
      mihome-vacuum.0	2020-03-03 21:31:59.347	info	(9962) trigger cleaning all null
      VG
        root_ last edited by root_
        Hab seit dem update auf die neusste Version auch so 1-2 Probleme.
        Bei mir startet der Sauger über ein js. das hat heut nicht mehr funktioniert.
        9Uhr sollte er loslegen:
        mihome-vacuum.0	2020-03-04 09:00:00.029	info	(13716) trigger cleaning all null
        Das js löst den mihome-vacuum.0.control.start button aus.
        Jetzt hab ich den Button per hand ausgelöst und da ging es dann.
        Zum anderen bekomme ich diese Meldungen:
        mihome-vacuum.0	2020-03-04 09:37:13.736	error	(13716) Error: IndexSizeError: The source width is 0.
        mihome-vacuum.0	2020-03-04 09:35:53.774	error	(13716) Error: IndexSizeError: The source width is 0.
        mihome-vacuum.0	2020-03-04 09:34:27.812	error	(13716) Error: IndexSizeError: The source width is 0.
        mihome-vacuum.0	2020-03-04 09:34:24.708	error	(13716) Error: IndexSizeError: The source width is 0.
        mihome-vacuum.0	2020-03-04 09:34:20.458	error	(13716) Error: IndexSizeError: The source width is 0.
        mihome-vacuum.0	2020-03-04 09:34:17.147	error	(13716) Error: IndexSizeError: The source width is 0.
        mihome-vacuum.0	2020-03-04 09:34:13.814	error	(13716) Error: IndexSizeError: The source width is 0.
        mihome-vacuum.0	2020-03-04 09:34:10.498	error	(13716) Error: IndexSizeError: The source width is 0.
        mihome-vacuum.0	2020-03-04 09:34:07.335	error	(13716) Error: IndexSizeError: The source width is 0.
        Es handelt sich um einen Gen1 mit Xiaomi FW und Cloudanbindung im Adapter.
          dirkhe Developer @root_ last edited by
          @root_ bitte Mal loglevel auf debug setzen.
          Wie triggerst du denn per ja?
            dirkhe Developer @dehein2 last edited by
            @dehein2 der Roboter spricht nicht mit dem Adapter. IP und token richtig?
              root_ @dirkhe last edited by root_
              @dirkhe
              Genau, per true. Ging bis jetzt 1a.
              Ob es notwendig ist bei einem Button weiss ich nicht aber ich setze ihn nach 1000ms wieder auf false.
              • Diginix
                Diginix last edited by Diginix
                @dirkhe @Meistertr
                Mein 1S reagiert mit 2.0.7 und 2.0.8 auf "Home" nicht.
                Zwischen "Pause" und "Find Me" habe ich immer wieder den "Home" Button im Admin betätigt. Der Sauger stand pausiert im Raum rum, also nicht im Dock. In der MiHome App hat der "Dock" Button dann sofort funktioniert.
                Hier das Debug Log dazu:
                2020-03-04 19:13:03.749  - info: mihome-vacuum.0 (20921) starting. Version 2.0.8 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                2020-03-04 19:13:03.846  - debug: mihome-vacuum.0 (20921) load Map creator... true
                2020-03-04 19:13:03.850  - debug: mihome-vacuum.0 (20921) Xiaomi Cloud: Logging in
                2020-03-04 19:13:03.868  - info: mihome-vacuum.0 (20921) Expert mode enabled, states created
                2020-03-04 19:13:03.870  - info: mihome-vacuum.0 (20921) Create state clean_home for controlling by cloud adapter
                2020-03-04 19:13:03.884  - info: mihome-vacuum.0 (20921) Disconnect
                2020-03-04 19:13:03.896  - debug: mihome-vacuum.0 (20921) server started on 0.0.0.0:53422
                2020-03-04 19:13:03.968  - info: mihome-vacuum.0 (20921) change states from State control.fan_power
                2020-03-04 19:13:03.971  - info: mihome-vacuum.0 (20921) New generation or new fw(3.5.4,0948) detected, create new states goto and zoneclean
                2020-03-04 19:13:04.428  - info: mihome-vacuum.0 (20921) set nächster Timer: Nicht verfügbar
                2020-03-04 19:13:06.831  - debug: mihome-vacuum.0 (20921) Xiaomi Cloud: Login successful
                2020-03-04 19:13:13.677  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.find {"val":true,"ack":false,"ts":1583345593672,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1573675095947}
                2020-03-04 19:13:13.684  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":1,"method":"find_me"}
                2020-03-04 19:13:18.687  - debug: mihome-vacuum.0 (20921) sendMsg[2] >>> {"id":1,"method":"find_me"}
                2020-03-04 19:13:23.690  - debug: mihome-vacuum.0 (20921) sendMsg[3] >>> {"id":1,"method":"find_me"}
                2020-03-04 19:13:23.887  - info: mihome-vacuum.0 (20921) Disconnect
                2020-03-04 19:13:23.892  - debug: mihome-vacuum.0 (20921) Receive <<< Helo <<< 21310020000000000f92f23c5e5fefc3ffffffffffffffffffffffffffffffff
                2020-03-04 19:13:23.894  - info: mihome-vacuum.0 (20921) connecting, This can take up to 5 minutes ...
                2020-03-04 19:13:23.896  - debug: mihome-vacuum.0 (20921) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                2020-03-04 19:13:23.904  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":2,"method":"get_status"}
                2020-03-04 19:13:23.915  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[{"msg_ver":1,"msg_seq":5745,"state":3,"battery":81,"clean_time":531,"clean_area":9650000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":2}
                2020-03-04 19:13:23.918  - debug: mihome-vacuum.0 (20921) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                2020-03-04 19:13:23.922  - info: mihome-vacuum.0 (20921) Connected
                2020-03-04 19:13:24.125  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":3,"method":"miIO.info"}
                2020-03-04 19:13:24.133  - debug: mihome-vacuum.0 (20921) Next WiFi check: 04.03 19:14
                2020-03-04 19:13:24.136  - debug: mihome-vacuum.0 (20921) Receive <<< {"partner_id":"","id":3,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.4_0948","ap":{"ssid":"sparky","bssid":"CC:CE:1E:C2:11:17","rssi":-45},"netif":{"localIp":"192.168.2.122","mask":"255.255.255.0","gw":"192.168.2.4"},"model":"roborock.vacuum.m1s","mac":"50:EC:50:12:37:15","token":"59414c416c4246694b3048764435577a","life":55952}}
                2020-03-04 19:13:24.323  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":4,"method":"get_sound_volume"}
                2020-03-04 19:13:24.332  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[100],"id":4}
                2020-03-04 19:13:24.525  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":5,"method":"get_consumable"}
                2020-03-04 19:13:24.534  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[{"main_brush_work_time":75966,"side_brush_work_time":75966,"filter_work_time":75966,"sensor_dirty_time":74777}],"id":5}
                2020-03-04 19:13:24.724  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":6,"method":"get_clean_summary"}
                2020-03-04 19:13:24.733  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[74777,1474542500,91,[1583340758,1583339903,1583225954,1583180962,1583180261,1582735711,1582735619,1582735055,1582617128,1582571726,1582570856,1582570281,1582566875,1581790042,1581761962,1581629504,1581322645,1581244828,1581244266,1580840290]],"id":6}
                2020-03-04 19:13:24.737  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":7,"method":"get_clean_record","params":[1583340758]}
                2020-03-04 19:13:24.749  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1583340758,1583341334,531,9650000,0,1,2,3]],"id":7}
                2020-03-04 19:13:24.924  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":8,"method":"get_carpet_mode"}
                2020-03-04 19:13:24.925  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":9,"method":"get_room_mapping"}
                2020-03-04 19:13:24.934  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":8}
                2020-03-04 19:13:24.936  - info: mihome-vacuum.0 (20921) create state for carpet_mode
                2020-03-04 19:13:24.939  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[16,"277001004452"],[17,"277001004448"],[18,"277001004451"],[19,"277001004453"],[20,"277001118019"],[21,"277001004449"]],"id":9}
                2020-03-04 19:13:24.943  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":10,"method":"get_clean_record","params":[1583339903]}
                2020-03-04 19:13:24.953  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1583339903,1583340754,829,17177500,0,1,2,3]],"id":10}
                2020-03-04 19:13:25.124  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":11,"method":"get_map_v1"}
                2020-03-04 19:13:25.132  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["retry"],"id":11}
                2020-03-04 19:13:25.146  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1583225954]}
                2020-03-04 19:13:25.155  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1583225954,1583227596,1642,34910000,0,1,2,3]],"id":12}
                2020-03-04 19:13:25.349  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1583180962]}
                2020-03-04 19:13:25.357  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1583180962,1583181066,104,1735000,0,1,2,3]],"id":13}
                2020-03-04 19:13:25.551  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":14,"method":"get_clean_record","params":[1583180261]}
                2020-03-04 19:13:25.562  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1583180261,1583180956,695,14795000,0,1,2,3]],"id":14}
                2020-03-04 19:13:25.636  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":15,"method":"get_map_v1"}
                2020-03-04 19:13:25.636  - debug: mihome-vacuum.0 (20921) 0. Mappointer_nomap___retry
                2020-03-04 19:13:25.669  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["retry"],"id":15}
                2020-03-04 19:13:25.755  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1582735711]}
                2020-03-04 19:13:25.766  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582735711,1582736153,442,9622500,0,1,2,3]],"id":16}
                2020-03-04 19:13:25.957  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":17,"method":"get_clean_record","params":[1582735619]}
                2020-03-04 19:13:25.966  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582735619,1582735640,18,0,0,0,2,1]],"id":17}
                2020-03-04 19:13:26.159  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1582735055]}
                2020-03-04 19:13:26.168  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582735055,1582735619,504,9577500,0,0,2,3]],"id":18}
                2020-03-04 19:13:26.171  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":19,"method":"get_map_v1"}
                2020-03-04 19:13:26.172  - debug: mihome-vacuum.0 (20921) 1. Mappointer_nomap___retry
                2020-03-04 19:13:26.193  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["ruby2%2F261288508%2F17"],"id":19}
                2020-03-04 19:13:26.195  - debug: mihome-vacuum.0 (20921) Mappointer_updated
                2020-03-04 19:13:26.197  - debug: mihome-vacuum.0 (20921) update_Map Mimap enabled
                2020-03-04 19:13:26.198  - debug: mihome-vacuum.0 (20921) update_Map need new mapurl
                2020-03-04 19:13:26.362  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1582617128]}
                2020-03-04 19:13:26.370  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582617128,1582618883,1755,35097500,0,1,2,3]],"id":20}
                2020-03-04 19:13:26.563  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":21,"method":"get_clean_record","params":[1582571726]}
                2020-03-04 19:13:26.571  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582571726,1582571734,6,0,0,0,2,1]],"id":21}
                2020-03-04 19:13:26.766  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1582570856]}
                2020-03-04 19:13:26.773  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582570856,1582571680,802,16392500,0,1,2,3]],"id":22}
                2020-03-04 19:13:26.968  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1582570281]}
                2020-03-04 19:13:26.975  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582570281,1582570721,13,240000,0,0,2,3]],"id":23}
                2020-03-04 19:13:27.171  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":24,"method":"get_clean_record","params":[1582566875]}
                2020-03-04 19:13:27.180  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1582566875,1582567670,795,16565000,0,1,2,3]],"id":24}
                2020-03-04 19:13:27.375  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1581790042]}
                2020-03-04 19:13:27.384  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581790042,1581790663,621,9707500,0,1,2,3]],"id":25}
                2020-03-04 19:13:27.579  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1581761962]}
                2020-03-04 19:13:27.588  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581761962,1581765162,3200,68240000,0,1,2,3]],"id":26}
                2020-03-04 19:13:27.783  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1581629504]}
                2020-03-04 19:13:27.792  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581629504,1581629795,291,9602500,0,0,2,3]],"id":27}
                2020-03-04 19:13:27.986  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":28,"method":"get_clean_record","params":[1581322645]}
                2020-03-04 19:13:27.993  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581322645,1581323442,797,17057500,0,1,2,3]],"id":28}
                2020-03-04 19:13:28.189  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1581244828]}
                2020-03-04 19:13:28.199  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581244828,1581247475,2647,51210000,0,1,2,3]],"id":29}
                2020-03-04 19:13:28.395  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1581244266]}
                2020-03-04 19:13:28.404  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1581244266,1581244810,544,9777500,0,1,2,3]],"id":30}
                2020-03-04 19:13:28.599  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":31,"method":"get_clean_record","params":[1580840290]}
                2020-03-04 19:13:28.606  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[[1580840290,1580840773,483,9737500,0,1,2,3]],"id":31}
                2020-03-04 19:13:28.690  - debug: mihome-vacuum.0 (20921) no answer for find_me(id:1) received, giving up
                2020-03-04 19:13:28.801  - debug: mihome-vacuum.0 (20921) CLEAN_LOGGING[{"Datum":"4.3","Start":"17:52","Saugzeit":"9 min","Fläche":"9.65 m²","Error":0,"Ende":true},{"Datum":"4.3","Start":"17:38","Saugzeit":"14 min","Fläche":"17.18 m²","Error":0,"Ende":true},{"Datum":"3.3","Start":"09:59","Saugzeit":"27 min","Fläche":"34.91 m²","Error":0,"Ende":true},{"Datum":"2.3","Start":"21:29","Saugzeit":"2 min","Fläche":"1.74 m²","Error":0,"Ende":true},{"Datum":"2.3","Start":"21:17","Saugzeit":"12 min","Fläche":"14.8 m²","Error":0,"Ende":true},{"Datum":"26.2","Start":"17:48","Saugzeit":"7 min","Fläche":"9.62 m²","Error":0,"Ende":true},{"Datum":"26.2","Start":"17:46","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"26.2","Start":"17:37","Saugzeit":"8 min","Fläche":"9.58 m²","Error":0,"Ende":false},{"Datum":"25.2","Start":"08:52","Saugzeit":"29 min","Fläche":"35.1 m²","Error":0,"Ende":true},{"Datum":"24.2","Start":"20:15","Saugzeit":"0 min","Fläche":"0 m²","Error":0,"Ende":false},{"Datum":"24.2","Start":"20:00","Saugzeit":"13 min","Fläche":"16.39 m²","Error":0,"Ende":true},{"Datum":"24.2","Start":"19:51","Saugzeit":"0 min","Fläche":"0.24 m²","Error":0,"Ende":false},{"Datum":"24.2","Start":"18:54","Saugzeit":"13 min","Fläche":"16.57 m²","Error":0,"Ende":true},{"Datum":"15.2","Start":"19:07","Saugzeit":"10 min","Fläche":"9.71 m²","Error":0,"Ende":true},{"Datum":"15.2","Start":"11:19","Saugzeit":"53 min","Fläche":"68.24 m²","Error":0,"Ende":true},{"Datum":"13.2","Start":"22:31","Saugzeit":"5 min","Fläche":"9.6 m²","Error":0,"Ende":false},{"Datum":"10.2","Start":"09:17","Saugzeit":"13 min","Fläche":"17.06 m²","Error":0,"Ende":true},{"Datum":"9.2","Start":"11:40","Saugzeit":"44 min","Fläche":"51.21 m²","Error":0,"Ende":true},{"Datum":"9.2","Start":"11:31","Saugzeit":"9 min","Fläche":"9.78 m²","Error":0,"Ende":true},{"Datum":"4.2","Start":"19:18","Saugzeit":"8 min","Fläche":"9.74 m²","Error":0,"Ende":true}]
                2020-03-04 19:13:30.421  - debug: mihome-vacuum.0 (20921) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/ruby2/261288508/17?Expires=1583347410000&GalaxyAccessKeyId=5271733786445&Signature=rnfZhuZbNi6QHn/Vkf7tvjbAqQE=
                2020-03-04 19:13:30.422  - debug: mihome-vacuum.0 (20921) update_Map got new expires:1583347410
                2020-03-04 19:13:30.422  - debug: mihome-vacuum.0 (20921) update_Map got new time:1583345606
                2020-03-04 19:13:32.381  - debug: mihome-vacuum.0 (20921) 25653
                2020-03-04 19:13:35.515  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.find {"val":true,"ack":false,"ts":1583345615511,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1573675095947}
                2020-03-04 19:13:35.517  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":32,"method":"find_me"}
                2020-03-04 19:13:35.581  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["ok"],"id":32}
                2020-03-04 19:13:38.489  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345618484,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                2020-03-04 19:13:43.894  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":33,"method":"get_status"}
                2020-03-04 19:13:43.907  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":[{"msg_ver":1,"msg_seq":5746,"state":3,"battery":81,"clean_time":531,"clean_area":9650000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"fan_power":104,"dnd_enabled":0,"map_status":3,"lock_status":0}],"id":33}
                2020-03-04 19:13:44.860  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.pause {"val":true,"ack":false,"ts":1583345624788,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1573587802676}
                2020-03-04 19:13:44.862  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":34,"method":"app_pause"}
                2020-03-04 19:13:44.868  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["ok"],"id":34}
                2020-03-04 19:13:47.722  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345627719,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                2020-03-04 19:13:49.408  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.find {"val":true,"ack":false,"ts":1583345629404,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1573675095947}
                2020-03-04 19:13:49.409  - debug: mihome-vacuum.0 (20921) sendMsg[1] >>> {"id":35,"method":"find_me"}
                2020-03-04 19:13:49.415  - debug: mihome-vacuum.0 (20921) Receive <<< {"result":["ok"],"id":35}
                2020-03-04 19:13:51.438  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345631434,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                2020-03-04 19:13:52.192  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345632186,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                2020-03-04 19:13:53.210  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345633204,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                2020-03-04 19:13:53.664  - debug: mihome-vacuum.0 (20921) stateChange mihome-vacuum.0.control.home {"val":true,"ack":false,"ts":1583345633658,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1575408936787}
                2020-03-04 19:14:00.173  - info: mihome-vacuum.0 (20921) Got terminate signal TERMINATE_YOURSELF
                Hier die History für den Button "Home":
                true	true	mihome-vacuum.0	2020-03-04 19:13:53.665
                true	false	admin.0	2020-03-04 19:13:53.658
                true	true	mihome-vacuum.0	2020-03-04 19:13:53.213
                true	false	admin.0	2020-03-04 19:13:53.204
                true	true	mihome-vacuum.0	2020-03-04 19:13:52.194
                true	false	admin.0	2020-03-04 19:13:52.186
                true	true	mihome-vacuum.0	2020-03-04 19:13:51.440
                true	false	admin.0	2020-03-04 19:13:51.434
                true	true	mihome-vacuum.0	2020-03-04 19:13:47.726
                true	false	admin.0	2020-03-04 19:13:47.719
                true	true	mihome-vacuum.0	2020-03-04 19:13:38.491
                true	false	admin.0	2020-03-04 19:13:38.484
                  dirkhe Developer @Diginix last edited by
                  @Diginix Alles klar, Fehler gefunden. Ich löse bei home nur aus, wnn er gerade aktiv am Reinigen ist. Flasche Annahme, nehme ich gleich raus und melde mich
                    @root_ Also ich habe jetzt mal geschaut. Einen Button per true zu triggern funktioniert. ich habe dieselbe funktion hinter start und clean_home gepackt und damit akzeptierte start auch ein false, mit dem Ergebniss, dass sofort wieder angehalten wurde. Ist gefixt und wird gleich hochgeladen. Für den IndexSizeError brauche ich ein debug log
                      dirkhe Developer last edited by
                      So für meine Version gibt es jetzt die 2.0.8-RC2
                      Meistertr 1 Reply Last reply Reply Quote 0
                      • Meistertr
                        Meistertr Developer @dirkhe last edited by
                        @dirkhe machs doch direkt alles in der hauptversion
                        haselchen D 2 Replies Last reply Reply Quote 0
                        • haselchen
                          haselchen Most Active @Meistertr last edited by
                          @Meistertr @dirkhe
                          Das wäre auch meine Bitte.
                          1 Version, die man im Admin oder auf Github bekommt.
                          Man steigt schon leider nicht mehr durch, wer von euch beiden was macht und woher man es beziehen kann.
                            dirkhe Developer @Meistertr last edited by
                            @Meistertr Ich hatte ja gedacht, du wolltest die erstmal für dich testen, weil ich ich ja doch einiges umgebaut habe. Jetzt bin ich davon ausgegangen, dass du gerade keine Zeit hast und da wollte ich dich auch nicht drängen...
                            Jetzt haben aber schon Leute hier ohne Aufforderung getestet (was ich gut finde) und es scheint ja zu funktionieren. Wenn es aber doch noch zu Problemen geführt hätte, könnten wir vlt. nicht so schnell zurück.
                            Aber ich kann meine Version gerne mergen, bin gerade dabei, den aktuellen Raum-channel einen Status zu geben, ob gerade gereinigt oder in Queue..
                            • Diginix
                              Meine Frage nach einem finalen verzögerten Kartenupdate nachdem der Sauger im Dock parkt, blieb bisher ja unbeantwortet.
                              Vllt kann das ja noch in das Update einfließen.
                                @dirkhe said in Test Adapter mihome-vacuum v2.0.x:
                                Klasse. Das log mach ich morgen.
                                  So,Version 2.0.9 ist im offiziellen community git.
                                  Status info für Räume hinzugefügt und queue info von anzahl zu JSON verändert
                                  Es gibt jetzt für jeden Raum ein zusätzlichen state info, indem steht, ob der Raum gerade gesaugt wird oder an welcher Stelle in der Warteliste er steht.
                                  Unter info.queue steht jetzt nicht mehr die Anzahl, sondern ein komplettes JSON Array, wobei die Liste Rückwarts sortiert ist
                                  So,dann mal frohes Testen
                                  A B 2 Replies Last reply Reply Quote 0
                                    Adnim @dirkhe last edited by
                                    Hi!
                                    das problem mit den geschlossenen Türen konnte ich über speichern einer Karte in ValetudoRE lösen, nun muss ich die aber manuell vor jeder Reinigung laden.
                                    Gibt es die möglichkeit karten zu laden über den Adapter?`
                                    Danke für eine Antwort!
                                      blackeagle998 @dirkhe last edited by
                                      @dirkhe
                                      erstes Testergebnis:
                                      Zwei Räume per Button getriggert, Raum 1 wird gesaugt, dann geht er in den Status "Back to home" (nur ganz kurz) und saugt dann den zweiten weiter, funktioniert also, super!
                                      Trotzdem ein paar kleine Sachen:
                                      1. Beim zweiten Raum wird der Datenpunkt "state" befüllt mit "Warteposition:: 0" (ein Doppelpunkt kann raus)
                                      2. der Datenpunkt Queue wird befüllt mit ["segment "], da fehlt irgendwie die Nummer des Raums
                                        --> bei drei Räumen sieht das so aus: ["segment ","segment room23","segment room20"]
                                        --> immer bei dem aktuell ausgewählten Raum (wird vorn angefügt, richtig?), fehlt die Nummer.
                                      3. Ich hätte gerne immer noch einen Button um die Queue zu leeren
                                        --> wenn ich einen Raum starte und danach noch weitere Räume auswähle, kann es passieren, dass ich einen falschen anwähle. Dann möchte ich die Queue leeren und die Auswahl neu treffen können, ohne dass das saugen des aktuellen Raumes beeinflusst wird.
                                        --> ist doch machbar oder?
                                      Danke für eure Mühen!!!
                                        dirkhe Developer @blackeagle998 last edited by
                                        @blackeagle998 Danke für deine Rückmeldung:
                                        1 und 2 schaue ich mir an, da sollte eigentlich sowas wie segment namedeschannels stehen, heist dein Raum channel so?
                                        3 den gibt es doch unter control.clearQueue
                                          @dirkhe
                                          Ich bin blind, sorry, danke für die Info 😁
                                          Eine Sache ist mir noch aufgefallen:
                                          Wenn ich per Skript eine Zone reinigen lasse, bekomme ich eine Fehlermeldung im LOG, er saugt aber trotzdem alles wie gewünscht. Hier ein DEBUG Auszug dazu:
                                          mihome-vacuum.0	2020-03-05 08:50:14.806	debug	(30297) 26364
                                          mihome-vacuum.0	2020-03-05 08:50:13.942	debug	(30297) update_Map got new time:1583394613
                                          mihome-vacuum.0	2020-03-05 08:50:13.941	debug	(30297) update_Map got new expires:1583396413
                                          mihome-vacuum.0	2020-03-05 08:50:13.941	debug	(30297) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/9?Expires=1583396413000&GalaxyAccessKeyId=5271733786445&Signature=XPXWZI9RtAA9rB8Wn1fQQj+x6u4=
                                          mihome-vacuum.0	2020-03-05 08:50:13.841	debug	(30297) update_Map need new mapurl
                                          mihome-vacuum.0	2020-03-05 08:50:13.840	debug	(30297) update_Map Mimap enabled
                                          mihome-vacuum.0	2020-03-05 08:50:13.839	debug	(30297) get rooms from map
                                          mihome-vacuum.0	2020-03-05 08:50:13.839	debug	(30297) Empty array try to get from Map
                                          mihome-vacuum.0	2020-03-05 08:50:13.838	debug	(30297) Receive <<< {"result":[],"id":33}
                                          mihome-vacuum.0	2020-03-05 08:50:13.832	debug	(30297) sendMsg[1] >>> {"id":33,"method":"get_room_mapping"}
                                          mihome-vacuum.0	2020-03-05 08:50:06.292	info	(30297) create states for water box filter
                                          mihome-vacuum.0	2020-03-05 08:50:06.290	debug	(30297) Receive <<< {"result":[{"msg_ver":3,"msg_seq":1139,"state":10,"battery":76,"clean_time":335,"clean_area":5200000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":1,"in_fresh_state
                                          mihome-vacuum.0	2020-03-05 08:50:06.281	debug	(30297) sendMsg[1] >>> {"id":32,"method":"get_status"}
                                          mihome-vacuum.0	2020-03-05 08:50:05.076	debug	(30297) Receive <<< {"result":["ok"],"id":31}
                                          mihome-vacuum.0	2020-03-05 08:50:05.075	debug	(30297) Receive <<< {"result":["ok"],"id":30}
                                          mihome-vacuum.0	2020-03-05 08:50:05.074	debug	(30297) Receive <<< {"result":["ok"],"id":29}
                                          mihome-vacuum.0	2020-03-05 08:50:04.281	debug	(30297) sendMsg[1] >>> {"id":31,"method":"app_zoned_clean","params":[[27189,28275,29439,30425,1]]}
                                          mihome-vacuum.0	2020-03-05 08:50:04.280	info	(30297) trigger cleaning zone [27189,28275,29439,30425,1]
                                          mihome-vacuum.0	2020-03-05 08:50:04.279	error	(30297) [27189,28275,29439,30425,1] ->
                                          mihome-vacuum.0	2020-03-05 08:50:04.176	debug	(30297) sendTo "cleanZone" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: [27189,28275,29439,30425,1]
                                          mihome-vacuum.0	2020-03-05 08:50:04.175	debug	(30297) stateChange mihome-vacuum.0.control.zoneClean {"val":"[27189,28275,29439,30425,1]","ack":false,"ts":1583394604157,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":158
                                          mihome-vacuum.0	2020-03-05 08:50:04.172	debug	(30297) sendMsg[1] >>> {"id":30,"method":"set_carpet_mode","params":[{"enable":1}]}
                                          mihome-vacuum.0	2020-03-05 08:50:04.171	debug	(30297) stateChange mihome-vacuum.0.control.carpet_mode {"val":true,"ack":false,"ts":1583394604157,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582558085122}
                                          mihome-vacuum.0	2020-03-05 08:50:04.166	debug	(30297) sendMsg[1] >>> {"id":29,"method":"set_custom_mode","params":[104]}
                                          mihome-vacuum.0	2020-03-05 08:50:04.164	debug	(30297) stateChange mihome-vacuum.0.control.fan_power {"val":104,"ack":false,"ts":1583394604157,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582557715499}
                                            dirkhe Developer @Adnim last edited by
                                            @Adnim Einen Button könnte man sicherlich einbauen, sonst sollte das über
                                            sendTo("mihome-vacuum.0", "getMap") gehen
                                            1.2k
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            491815
