    4. Test Adapter mihome-vacuum v2.0.x
      blackeagle998 @dirkhe last edited by
      @dirkhe
      Ich bin blind, sorry, danke für die Info 😁
      Eine Sache ist mir noch aufgefallen:
      Wenn ich per Skript eine Zone reinigen lasse, bekomme ich eine Fehlermeldung im LOG, er saugt aber trotzdem alles wie gewünscht. Hier ein DEBUG Auszug dazu:
      mihome-vacuum.0	2020-03-05 08:50:14.806	debug	(30297) 26364
      mihome-vacuum.0	2020-03-05 08:50:13.942	debug	(30297) update_Map got new time:1583394613
      mihome-vacuum.0	2020-03-05 08:50:13.941	debug	(30297) update_Map got new expires:1583396413
      mihome-vacuum.0	2020-03-05 08:50:13.941	debug	(30297) update_Map got new url:https://awsde0.fds.api.xiaomi.com/robomap/robomap/74488275/9?Expires=1583396413000&GalaxyAccessKeyId=5271733786445&Signature=XPXWZI9RtAA9rB8Wn1fQQj+x6u4=
      mihome-vacuum.0	2020-03-05 08:50:13.841	debug	(30297) update_Map need new mapurl
      mihome-vacuum.0	2020-03-05 08:50:13.840	debug	(30297) update_Map Mimap enabled
      mihome-vacuum.0	2020-03-05 08:50:13.839	debug	(30297) get rooms from map
      mihome-vacuum.0	2020-03-05 08:50:13.839	debug	(30297) Empty array try to get from Map
      mihome-vacuum.0	2020-03-05 08:50:13.838	debug	(30297) Receive <<< {"result":[],"id":33}
      mihome-vacuum.0	2020-03-05 08:50:13.832	debug	(30297) sendMsg[1] >>> {"id":33,"method":"get_room_mapping"}
      mihome-vacuum.0	2020-03-05 08:50:06.292	info	(30297) create states for water box filter
      mihome-vacuum.0	2020-03-05 08:50:06.290	debug	(30297) Receive <<< {"result":[{"msg_ver":3,"msg_seq":1139,"state":10,"battery":76,"clean_time":335,"clean_area":5200000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":1,"in_fresh_state
      mihome-vacuum.0	2020-03-05 08:50:06.281	debug	(30297) sendMsg[1] >>> {"id":32,"method":"get_status"}
      mihome-vacuum.0	2020-03-05 08:50:05.076	debug	(30297) Receive <<< {"result":["ok"],"id":31}
      mihome-vacuum.0	2020-03-05 08:50:05.075	debug	(30297) Receive <<< {"result":["ok"],"id":30}
      mihome-vacuum.0	2020-03-05 08:50:05.074	debug	(30297) Receive <<< {"result":["ok"],"id":29}
      mihome-vacuum.0	2020-03-05 08:50:04.281	debug	(30297) sendMsg[1] >>> {"id":31,"method":"app_zoned_clean","params":[[27189,28275,29439,30425,1]]}
      mihome-vacuum.0	2020-03-05 08:50:04.280	info	(30297) trigger cleaning zone [27189,28275,29439,30425,1]
      mihome-vacuum.0	2020-03-05 08:50:04.279	error	(30297) [27189,28275,29439,30425,1] ->
      mihome-vacuum.0	2020-03-05 08:50:04.176	debug	(30297) sendTo "cleanZone" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0: [27189,28275,29439,30425,1]
      mihome-vacuum.0	2020-03-05 08:50:04.175	debug	(30297) stateChange mihome-vacuum.0.control.zoneClean {"val":"[27189,28275,29439,30425,1]","ack":false,"ts":1583394604157,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":158
      mihome-vacuum.0	2020-03-05 08:50:04.172	debug	(30297) sendMsg[1] >>> {"id":30,"method":"set_carpet_mode","params":[{"enable":1}]}
      mihome-vacuum.0	2020-03-05 08:50:04.171	debug	(30297) stateChange mihome-vacuum.0.control.carpet_mode {"val":true,"ack":false,"ts":1583394604157,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582558085122}
      mihome-vacuum.0	2020-03-05 08:50:04.166	debug	(30297) sendMsg[1] >>> {"id":29,"method":"set_custom_mode","params":[104]}
      mihome-vacuum.0	2020-03-05 08:50:04.164	debug	(30297) stateChange mihome-vacuum.0.control.fan_power {"val":104,"ack":false,"ts":1583394604157,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582557715499}
        dirkhe Developer @Adnim last edited by
        @Adnim Einen Button könnte man sicherlich einbauen, sonst sollte das über
        sendTo("mihome-vacuum.0", "getMap") gehen
          dirkhe Developer @blackeagle998 last edited by dirkhe
          @blackeagle998 sorry, ist noch eine Testausgabe von von mir
          Aber gut,habe da gerade noch eine potentielle Fehlerquelle entdeckt....
          • JB_Sullivan
            JB_Sullivan last edited by
            MOin zusammen -
            ich habe mich nun auch mal getraut meinen Adapter upzudaten. Habe den Sauger der ersten Generation und war bislang auf Version 1.1.5 des Adapters.
            Nun bin ich gleich auf 2.0.9 gegangen, da ich permanente Connected / Disconnect Ausgaben habe.
            2020-03-05 00:02:00.035  - info: mihome-vacuum.0 (8) Disconnect
            2020-03-05 00:02:00.057  - info: mihome-vacuum.0 (8) Connected
            2020-03-05 00:03:20.087  - info: mihome-vacuum.0 (8) Disconnect
            2020-03-05 00:03:20.092  - info: mihome-vacuum.0 (8) Connected
            2020-03-05 00:05:20.118  - info: mihome-vacuum.0 (8) Disconnect
            2020-03-05 00:05:20.126  - info: mihome-vacuum.0 (8) Connected
            Ein Debug könnte ich auch liefern, aber da sind so viele Account und Zugangsdaten drin - da bin ich mir nicht sicher was ich alles Raus-Xèn müsste, damit der Robbi nicht mehr identifizierbar wäre.
            Der nächste Punkt betrifft die erzeugte Karte. Wenn ich die URL ins VIS Widget einbaue, bricht mein ganzes ioB System Performance mäßig komplett zusammen ( Intel i3 mit 8 GB Ram). Ich hole mir die Karte allerdings von der xiaomi cloud.
            Diginix D 2 Replies Last reply Reply Quote 0
            • Diginix
              Diginix @JB_Sullivan last edited by Diginix
              @JB_Sullivan Die Connect/Disconnect Logeinträge habe ich mit @dirkhe 2.0.8 auch heute im Log seit 03:40 Uhr. Hab den Loglevel dann 9 Uhr vorerst auf warn gestellt, damit ich wirklich wichtiges im Log noch wahrnehmen kann. Ob das immer noch im Hintergrund fliegt sehe ich nun nicht mehr. Funktioniert hat gestern alles was ich getestet habe. Da waren diese Einträge aber auch nur nach Instanz Neustart. Wieso das diese Nacht dann derart massiv angefangen hat, kann ich nur auf Netzwerk Probleme zurückführen.
                dirkhe Developer @JB_Sullivan last edited by dirkhe
                @JB_Sullivan ohne debug können wir dir leider nicht helfen
                  dirkhe Developer last edited by
                  Was habt ihr denn als IntervallZeiten eingestellt?
                  Disconnect schreibt er immer, wenn die letzte Antwort vom robbi länger als die Intervallzeit ist
                  • Diginix
                    Diginix @dirkhe last edited by Diginix
                    @dirkhe Status alle 10s / WLAN alle 60s (sollte default sein).
                    Hier mal das Log als es heute Nacht anfing. So ging/geht das über Stunden. Sehe es nun durch warn Loglevel nicht mehr. Sind immer alle 20 Sek, also keines der beiden gesetzten Intervalle.
                    2020-03-05 03:40:49.500  - info: mihome-vacuum.0 (4187) Disconnect
                    2020-03-05 03:40:54.535  - warn: mihome-vacuum.0 (4187) no answer received after after 3 times -> pause miIO.info try again in one hour
                    2020-03-05 03:41:09.531  - info: mihome-vacuum.0 (4187) Disconnect
                    2020-03-05 03:41:29.533  - info: mihome-vacuum.0 (4187) Disconnect
                    2020-03-05 03:41:49.534  - info: mihome-vacuum.0 (4187) Disconnect
                    2020-03-05 03:42:09.536  - info: mihome-vacuum.0 (4187) Disconnect
                    2020-03-05 03:42:09.542  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
                    2020-03-05 03:42:09.562  - info: mihome-vacuum.0 (4187) Connected
                    2020-03-05 03:42:29.537  - info: mihome-vacuum.0 (4187) Disconnect
                    2020-03-05 03:42:29.545  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
                    2020-03-05 03:42:29.594  - info: mihome-vacuum.0 (4187) Connected
                    2020-03-05 03:42:49.539  - info: mihome-vacuum.0 (4187) Disconnect
                    2020-03-05 03:42:49.547  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
                    2020-03-05 03:42:49.580  - info: mihome-vacuum.0 (4187) Connected
                    2020-03-05 03:43:09.542  - info: mihome-vacuum.0 (4187) Disconnect
                    2020-03-05 03:43:09.549  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
                    2020-03-05 03:43:09.701  - info: mihome-vacuum.0 (4187) Connected
                    2020-03-05 03:43:29.543  - info: mihome-vacuum.0 (4187) Disconnect
                    2020-03-05 03:43:29.551  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
                    2020-03-05 03:43:29.575  - info: mihome-vacuum.0 (4187) Connected
                    2020-03-05 03:43:49.544  - info: mihome-vacuum.0 (4187) Disconnect
                    2020-03-05 03:43:49.551  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
                    2020-03-05 03:43:49.573  - info: mihome-vacuum.0 (4187) Connected
                    2020-03-05 03:44:09.545  - info: mihome-vacuum.0 (4187) Disconnect
                    2020-03-05 03:44:09.552  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
                    2020-03-05 03:44:09.575  - info: mihome-vacuum.0 (4187) Connected
                    2020-03-05 03:44:29.547  - info: mihome-vacuum.0 (4187) Disconnect
                    2020-03-05 03:44:29.552  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
                    2020-03-05 03:44:29.576  - info: mihome-vacuum.0 (4187) Connected
                    2020-03-05 03:44:49.549  - info: mihome-vacuum.0 (4187) Disconnect
                    2020-03-05 03:44:49.555  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
                    2020-03-05 03:44:49.580  - info: mihome-vacuum.0 (4187) Connected
                    Token, IP usw. sind korrekt und ohne System/Instanz Neustart konnte ich den Sauger gestern Abend problemlos steuern inkl. Kartenabruf. Wenn es also nur Netzwerkprobleme sind, dann nehme ich es so hin. Falls mehr dahinter steckt, musst du sagen was du bräuchtest. Debuglog mit Interaktion vom Sauger kann ich erst später liefern.
                      So, ich glaube ich habe die Ursache gefunden. HIntergrund ist, dass ich den Traffic generell verringern wollte. Bei mir ist Status zb. auch auf 1 Minute eingestellt. Wenn aus dem Adapter irgendwelche statusrelevanten Aktionen angestossen werden, wie zb. ein Saugvrogang, Stop,Pause usw. wird der Status unabhängig davon 2s später abgefragt. Solange er saugt, wird der Interval automatisch auf 10sec eingestellt und hinterher wieder auf eure Zeit aus der config.
                      Ich denke, dass es bei 10sec da ggf. zu Problemen führt, vlt. sollte ich ein Neuverbinden, bzw. ein connection lost erst nach min. 1.Minute nicht mehr annehmen. Also ich werde das mal so machen, dass ich 1 Minte oder einen ggf. grösser eingetelles Intervall annehme.
                        jayfizzle last edited by jayfizzle
                        nutze nun seit einigen Tagen euren Adapter und muss euch für die geleistete Arbeit Danken, super Leistung, Hut ab.
                        Nun aber zu meinem Problem, welches ggf. nicht hier hin gehört.
                        Über den Adapter kann ich meinen Roborock S5 problemlos steuern, jedoch habe ich heute morgen folgende Meldungen im Log erhalten:
                        mihome-vacuum.0 2020-03-05 09:30:54.070 error (24164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Thu, 05 Mar 2020 08:30:54 GMT","content-length":"123","connection":"close","x-xiaomi-request-id":"514567be-5f65-
                        mihome-vacuum.0 2020-03-05 09:29:57.664 error (24164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Thu, 05 Mar 2020 08:29:57 GMT","content-length":"123","connection":"close","x-xiaomi-request-id":"11264492-1329-
                        mihome-vacuum.0 2020-03-05 09:29:55.598 error (24164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Thu, 05 Mar 2020 08:29:55 GMT","content-length":"123","connection":"close","x-xiaomi-request-id":"46e6454a-5302-
                        mihome-vacuum.0 2020-03-05 09:29:20.919 error (24164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Thu, 05 Mar 2020 08:29:20 GMT","content-length":"123","connection":"close","x-xiaomi-request-id":"9ahzh5e9-61ef-
                        mihome-vacuum.0 2020-03-05 09:18:44.112 warn (24164) Could not receive Mappointer, giving up
                        Die im Objekt mihome-vacuum.0.map.map64 hinterlegte Karte kann aufgerufen werden.
                        ebenfalls wird mir die Karte nicht in der Mi Home App angezeigt, es steht lediglich "Karte wird geladen..." und es tut sich nichts.
                        Hat jmd. von euch ähnliche Probleme?
                        Hoffe das mir da ggf. jmd. weiterhelfen kann, auch wenn dies wahrscheinlich nichts mit dem Adapter zu tun hat.
                          Adnim @dirkhe last edited by
                          @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
                          danke für die Antwort, blicke Sie aber nicht 🙂
                          Also ich kann eine gespeicherte Karte in Valetudo durch den Adapter laden?
                          wo müsste der name der map den stehen, "getMap" verweist ja auf keine gespeicherte Karte oder wie ist das zu verstehen?
                            @Adnim Soweit ich weiß, wird der Roboter gefragt, welche Karte aktuell ist und dann wird die Url der Karte geholt
                              ok verstehe, nun möchte ich eine andere Map aus dem Valetudo speicher vor jeder Reinigung laden, eine in der die Türen halt auf sind...
                              Das geht dann aber bislang nur via Valetudo Interface?
                                @Adnim Sorry, da kenne ich nicht nicht mit aus
                                  2.0.9-RC02 ist im git:
                                  unötiges conect/reconnect sollte gefixt sein
                                  in info.queue sollten dann jetzt auch die Raumnamen auftauchen
                                  haselchen B B 3 Replies Last reply Reply Quote 0
                                  • haselchen
                                    haselchen Most Active @dirkhe last edited by haselchen
                                    @dirkhe
                                    Von diesem Link installieren?
                                    https://github.com/dirkhe/ioBroker.mihome-vacuum
                                    Wenn ja habe ich es getan. Es kam die Nachricht im Log, dass das Verbinden 5min braucht.
                                    Es kam aber permanent disconnected.
                                    Erst als ich die MiHome App geöffnet habe, hat er sich verbunden.
                                    • Diginix
                                      Diginix @haselchen last edited by
                                      @haselchen Nein offizielles Repo. https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum
                                      Im Log siehst du auch welche Version gestartet wird.
                                      • haselchen
                                        haselchen Most Active @Diginix last edited by
                                        @Diginix
                                        Deswegen hatte ich letztens um Vereinheitlichung gebeten.
                                        Also veröffentlicht @dirkhe seine Versionen jetzt unter dem früheren Link (Deinem)?
                                        • Diginix
                                          Diginix @haselchen last edited by Diginix
                                          @haselchen Nicht meinem, sondern dem offiziellen, indirekt dem von Meistertr und je nach dem wie umfangreich die Änderungen sind, wird das sicher auch mal wieder in @dirkhe Fork sein (müssen). Wer nicht jede Neuerung braucht, muss sich damit ja auch nicht befassen. Bisher ist alles maximal latestet, eher beta auch wenn es stabil ist. Wenn du durcheinander kommst, dann bleib auf den offiziellen Repos (stable oder latest). Ansonsten einfach bei GIT schauen wo die "jüngeren" Dateien liegen bzw. was als Commit eingecheckt wurde.
                                          • haselchen
                                            haselchen Most Active @Diginix last edited by haselchen
                                            @Diginix
                                            Ich verfolge das hier ja auch permanent.
                                            In dieser Version ist es tatsächlich so, dass er sich erst verbindet wenn ich die App öffne.
                                            Vielleicht hilfreich für @dirkhe
                                            Ein Log habe ich leider nicht, da es nach dem Update auftritt. Wenn er einmal connected ist, bleibt es so.
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            492448
