    4. ioBroker startet nicht
    SOLVED ioBroker startet nicht
    • N
      Nier last edited by Negalein
      @haselchen said in ioBroker startet nicht:
      cd iobroker
      Also ich habe das so gemacht und es geht leider immer noch nicht
      root@NiermannSmartHome:/opt# cd iobroker
      root@NiermannSmartHome:/opt/iobroker# iobroker upgrade self
      Objects 127.0.0.1:42080 (Init=false) Redis error:Error: Invalid Chunk: parse failed
      Objects 127.0.0.1:42082 (Init=false) Redis error:Error: Invalid Chunk: parse failed
      Objects 127.0.0.1:42084 (Init=false) Redis error:Error: Invalid Chunk: parse failed
      Objects 127.0.0.1:42086 (Init=false) Redis error:Error: Invalid Chunk: parse failed
      Objects 127.0.0.1:42088 (Init=false) Redis error:Error: Invalid Chunk: parse failed
      Objects 127.0.0.1:42090 (Init=false) Redis error:Error: Invalid Chunk: parse failed
      Objects 127.0.0.1:42092 (Init=false) Redis error:Error: Invalid Chunk: parse failed
      Objects 127.0.0.1:42094 (Init=false) Redis error:Error: Invalid Chunk: parse failed
      Objects 127.0.0.1:42096 (Init=false) Redis error:Error: Invalid Chunk: parse failed
      Host    "NiermannSmartHome" is up to date.
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
      • N
        Das kommt wenn ich es veruche zu instalieren
        root@NiermannSmartHome:/opt/iobroker# sudo -H -u iobroker npm install iobroker.js-controller
        npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
        > iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
        > node lib/preinstallCheck.js
        NPM version: 6.14.2
        > iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
        > node iobroker.js setup first
        npm WARN notsup Unsupported engine for rsa-compat@2.0.8: wanted: {"node":">=10.12"} (current: {"node":"8.17.0","npm":"6.14.2"})
        npm WARN notsup Not compatible with your version of node/npm: rsa-compat@2.0.8
        npm WARN notsup Unsupported engine for rsa-compat@1.9.4: wanted: {"node":">=10.12"} (current: {"node":"8.17.0","npm":"6.14.2"})
        npm WARN notsup Not compatible with your version of node/npm: rsa-compat@1.9.4
        npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
        npm WARN winston-daily-rotate-file@4.4.2 requires a peer of winston@^3 but none is installed. You must install peer dependencies yourself.
        npm WARN winston-syslog@2.4.0 requires a peer of winston@^3.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        + iobroker.js-controller@2.2.9
        updated 1 package and audited 4642 packages in 59.771s
        2 packages are looking for funding
          run `npm fund` for details
        found 50 vulnerabilities (32 low, 18 high)
          run `npm audit fix` to fix them, or `npm audit` for details
        • haselchen
          haselchen Most Active @Nier last edited by
          @Nier
          Am besten du machst erstmal ein
          apt-get update
          danach
          apt-get upgrade
          • N
            @haselchen hab ich gemacht kommt immer noch die meldung im browser
            This adapter cannot be installed directly from github.
            You must install it from npm.
            Write for that "npm install iobroker.admin" in according directory.
            root@NiermannSmartHome:/opt/iobroker# apt-get update
            OK:1 http://security.debian.org/debian-security stretch/updates InRelease
            Ign:2 http://ftp.de.debian.org/debian stretch InRelease
            OK:3 http://ftp.de.debian.org/debian stretch-updates InRelease
            OK:4 http://ftp.de.debian.org/debian stretch Release
            OK:5 https://deb.nodesource.com/node_8.x stretch InRelease
            root@NiermannSmartHome:/opt/iobroker# apt-get upgrade
            Paketaktualisierung (Upgrade) wird berechnet... Fertig
            Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
             gimp-data gir1.2-gdata-0.0 gir1.2-gepub-0.4 gir1.2-zpj-0.0 libabw-0.1-1
             libamd2 libbabl-0.1-0 libcamd2 libccolamd2 libcholmod3 libe-book-0.1-1
             libgc1c2 libgegl-0.3-0 libgepub0 libgimp2.0 libgtkmm-2.4-1v5 libgtkspell0
             libimage-magick-perl libimage-magick-q16-perl libmagick++-6.q16-7 libmetis5
             libmng1 libpotrace0 libsdl1.2debian libumfpack5 python-bs4 python-cairo
             python-gobject-2 python-gtk2 python-html5lib python-lxml python-numpy
             python-scour python-webencodings unoconv
            Verwenden Sie »apt autoremove«, um sie zu entfernen.
            Die folgenden Pakete sind zurückgehalten worden:
             default-jre default-jre-headless icedtea-netx libfreerdp-cache1.1
             libfreerdp-core1.1 libfreerdp-gdi1.1 linux-image-amd64
            0 aktualisiert, 0 neu installiert, 0 zu entfernen und 7 nicht aktualisiert.
            • haselchen
              haselchen Most Active @Nier last edited by Negalein
              @Nier
              curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
              sudo apt-get install -y nodejs
              • N
                @haselchen leider kommt immer noch die gleiche meldung 😞
                Hab die zwei schritte gemacht:
                root@NiermannSmartHome:/opt/iobroker# curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
                ## Installing the NodeSource Node.js 10.x repo...
                ## Populating apt-get cache...
                + apt-get update
                OK:5 https://deb.nodesource.com/node_10.x stretch InRelease
                ## Confirming "stretch" is supported...
                + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_10.x/dists/stretch/Release'
                ## Adding the NodeSource signing key to your keyring...
                + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add -
                OK
                ## Creating apt sources list file for the NodeSource Node.js 10.x repo...
                + echo 'deb https://deb.nodesource.com/node_10.x stretch main' > /etc/apt/sources.list.d/nodesource.list
                + echo 'deb-src https://deb.nodesource.com/node_10.x stretch main' >> /etc/apt/sources.list.d/nodesource.list
                ## Running `apt-get update` for you...
                + apt-get update
                ## Run `sudo apt-get install -y nodejs` to install Node.js 10.x and npm
                ## You may also need development tools to build native addons:
                    sudo apt-get install gcc g++ make
                ## To install the Yarn package manager, run:
                    curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add -
                    echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
                    sudo apt-get update && sudo apt-get install yarn
                root@NiermannSmartHome:/opt/iobroker# sudo apt-get install -y nodejs
                nodejs ist schon die neueste Version (10.19.0-1nodesource1).
                Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
                • haselchen
                  @Nier
                  Was ergibt
                  npm -v
                  nodejs -v
                  • N
                    Nier @haselchen last edited by Negalein
                    @haselchen
                    root@NiermannSmartHome:/opt/iobroker# npm -v
                    6.13.4
                    root@NiermannSmartHome:/opt/iobroker# nodejs -v
                    v10.19.0
                    • haselchen
                      @Nier
                      dann jetzt
                      npm i iobroker.js-controller
                      • N
                        Leider gehts immer noch nicht
                        root@NiermannSmartHome:/opt/iobroker# npm i iobroker.js-controller
                        NPM version: 6.13.4
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                        updated 1 package and audited 4642 packages in 50.317s
                        haselchen AlCalzone Homoran 3 Replies Last reply Reply Quote 0
                        • haselchen
                          @Nier
                          Hilft wohl nur noch der Fixer
                          curl -sL https://iobroker.net/fix.sh | bash -
                          • N
                            @haselchen
                            was kann ich dagegen tin?
                            root@NiermannSmartHome:/opt/iobroker# iobroker stop
                            root@NiermannSmartHome:/opt/iobroker# curl -sL https://iobroker.net/fix.sh | bash -
                            library: loaded
                            Library version=2020-01-30
                            ioBroker or some processes are still running:
                             io.cloud.0
                             io.yahka.0
                             io.ring.0
                             io.broadlink2.0
                             io.alexa2.0
                             io.mihome.0
                             io.text2command.0
                             io.email.0
                             io.web.0
                             io.tado.0
                             io.meross.0
                            Please stop them first and try again!
                            • haselchen
                              @Nier
                              Versuch mal
                              pkill iobroker
                              • N
                                @haselchen Leider nein 😞 Danke dir aber für diene Zeit
                                root@NiermannSmartHome:/opt/iobroker# pkill iobroker
                                library: loaded
                                 io.cloud.0
                                 io.yahka.0
                                 io.ring.0
                                 io.broadlink2.0
                                 io.alexa2.0
                                 io.mihome.0
                                 io.text2command.0
                                 io.email.0
                                 io.web.0
                                 io.tado.0
                                 io.meross.0
                                • haselchen
                                  @Nier
                                  Und ein iobroker stop
                                  Eventuell mit sudo davor
                                  • N
                                    • haselchen
                                      @Nier
                                      Kannst natürlich jeden Adapter einzeln stoppen
                                      iobroker stop adapterName
                                      • N
                                        @haselchen Wenigstens etwas was geklappt hat 😛 Aber leider kommt immer noch die gleiche meldung wie vorher
                                        root@NiermannSmartHome:~# curl -sL https://iobroker.net/fix.sh | bash -#
                                        bash: -#: Ungültige Option
                                        Aufruf: bash [Lange GNU Option] [Option] ...
                                                        bash [Lange GNU Option] [Option] Script-Datei ...
                                        Lange GNU Optionen:
                                                --debug
                                                --debugger
                                                --dump-po-strings
                                                --dump-strings
                                                --help
                                                --init-file
                                                --login
                                                --noediting
                                                --noprofile
                                                --norc
                                                --posix
                                                --rcfile
                                                --restricted
                                                --verbose
                                                --version
                                        Shell-Optionen:
                                                -ilrsD oder -c Kommando oder -O shopt_option            (Nur Aufruf)
                                                -abefhkmnptuvxBCHP oder Option -o
                                        library: loaded
                                            Welcome to the ioBroker installation fixer!
                                            Script version: 2020-01-25
                                            Installing prerequisites (1/3)
                                        Installed gcc-c++
                                        Installed python-dev
                                            Checking ioBroker user and directory permissions (2/3)
                                        Created /etc/sudoers.d/iobroker
                                        Fixing directory permissions...
                                            Checking autostart (3/3)
                                        Enabling autostart...
                                        Autostart enabled!
                                            Your installation was fixed successfully
                                            Run iobroker start to start ioBroker again!
                                        • N
                                          root@NiermannSmartHome:~# install iobroker.admin
                                          install: Fehlender Zieldatei‐Operand hinter 'iobroker.admin'
                                          „install --help“ liefert weitere Informationen.
                                          root@NiermannSmartHome:~# npm install iobroker.admin
                                          npm WARN saveError ENOENT: no such file or directory, open '/root/package.json'
                                          npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
                                          npm WARN root No description
                                          npm WARN root No repository field.
                                          npm WARN root No README data
                                          npm WARN root No license field.
                                          + iobroker.admin@4.0.5
                                          updated 1 package and audited 1050 packages in 5.777s
                                          found 0 vulnerabilities
                                          • haselchen
                                            @Nier
                                            Da steht erfolgreich?
                                            Reboot gemacht ?
                                            funktioniertnicht
                                            4259
