    4. ioBroker startet nicht
    SOLVED ioBroker startet nicht
    • N
      Nier @haselchen last edited by Negalein
      @haselchen said in ioBroker startet nicht:
      npm i iobroker.js-controller
      Leider gehts immer noch nicht
      root@NiermannSmartHome:/opt/iobroker# npm i iobroker.js-controller
      npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
      > iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/preinstallCheck.js
      NPM version: 6.13.4
      > iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
      npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
      npm WARN winston-daily-rotate-file@4.4.2 requires a peer of winston@^3 but none is installed. You must install peer dependencies yourself.
      npm WARN winston-syslog@2.4.0 requires a peer of winston@^3.0.0 but none is installed. You must install peer dependencies yourself.
      npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
      + iobroker.js-controller@2.2.9
      updated 1 package and audited 4642 packages in 50.317s
      2 packages are looking for funding
       run `npm fund` for details
      found 50 vulnerabilities (32 low, 18 high)
       run `npm audit fix` to fix them, or `npm audit` for details
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
      haselchen AlCalzone Homoran 3 Replies Last reply Reply Quote 0
      • haselchen
        haselchen Most Active @Nier last edited by
        @Nier
        Hilft wohl nur noch der Fixer
        curl -sL https://iobroker.net/fix.sh | bash -
        • N
          @haselchen
          was kann ich dagegen tin?
          root@NiermannSmartHome:/opt/iobroker# iobroker stop
          root@NiermannSmartHome:/opt/iobroker# curl -sL https://iobroker.net/fix.sh | bash -
          library: loaded
          Library version=2020-01-30
          ioBroker or some processes are still running:
           io.cloud.0
           io.yahka.0
           io.ring.0
           io.broadlink2.0
           io.alexa2.0
           io.mihome.0
           io.text2command.0
           io.email.0
           io.web.0
           io.tado.0
           io.meross.0
          Please stop them first and try again!
          • haselchen
            @Nier
            Versuch mal
            pkill iobroker
            • N
              @haselchen Leider nein 😞 Danke dir aber für diene Zeit
              root@NiermannSmartHome:/opt/iobroker# pkill iobroker
              library: loaded
               io.cloud.0
               io.yahka.0
               io.ring.0
               io.broadlink2.0
               io.alexa2.0
               io.mihome.0
               io.text2command.0
               io.email.0
               io.web.0
               io.tado.0
               io.meross.0
              • haselchen
                @Nier
                Und ein iobroker stop
                Eventuell mit sudo davor
                • N
                  • haselchen
                    @Nier
                    Kannst natürlich jeden Adapter einzeln stoppen
                    iobroker stop adapterName
                    • N
                      @haselchen Wenigstens etwas was geklappt hat 😛 Aber leider kommt immer noch die gleiche meldung wie vorher
                      This adapter cannot be installed directly from github.
                      You must install it from npm.
                      Write for that "npm install iobroker.admin" in according directory.
                      root@NiermannSmartHome:~# curl -sL https://iobroker.net/fix.sh | bash -#
                      bash: -#: Ungültige Option
                      Aufruf: bash [Lange GNU Option] [Option] ...
                                      bash [Lange GNU Option] [Option] Script-Datei ...
                      Lange GNU Optionen:
                              --debug
                              --debugger
                              --dump-po-strings
                              --dump-strings
                              --help
                              --init-file
                              --login
                              --noediting
                              --noprofile
                              --norc
                              --posix
                              --rcfile
                              --restricted
                              --verbose
                              --version
                      Shell-Optionen:
                              -ilrsD oder -c Kommando oder -O shopt_option            (Nur Aufruf)
                              -abefhkmnptuvxBCHP oder Option -o
                      library: loaded
                          Welcome to the ioBroker installation fixer!
                          Script version: 2020-01-25
                          Installing prerequisites (1/3)
                      OK:1 http://security.debian.org/debian-security stretch/updates InRelease
                      Ign:2 http://ftp.de.debian.org/debian stretch InRelease
                      OK:3 http://ftp.de.debian.org/debian stretch-updates InRelease
                      OK:4 http://ftp.de.debian.org/debian stretch Release
                      OK:5 https://deb.nodesource.com/node_10.x stretch InRelease
                      Installed gcc-c++
                      Installed python-dev
                          Checking ioBroker user and directory permissions (2/3)
                      Created /etc/sudoers.d/iobroker
                      Fixing directory permissions...
                          Checking autostart (3/3)
                      Enabling autostart...
                      Autostart enabled!
                          Your installation was fixed successfully
                          Run iobroker start to start ioBroker again!
                      • N
                        Nier last edited by Negalein
                        root@NiermannSmartHome:~# install iobroker.admin
                        install: Fehlender Zieldatei‐Operand hinter 'iobroker.admin'
                        „install --help“ liefert weitere Informationen.
                        root@NiermannSmartHome:~# npm install iobroker.admin
                        npm WARN saveError ENOENT: no such file or directory, open '/root/package.json'
                        npm WARN enoent ENOENT: no such file or directory, open '/root/package.json'
                        npm WARN root No description
                        npm WARN root No repository field.
                        npm WARN root No README data
                        npm WARN root No license field.
                        + iobroker.admin@4.0.5
                        updated 1 package and audited 1050 packages in 5.777s
                        found 0 vulnerabilities
                        • haselchen
                          @Nier
                          Da steht erfolgreich?
                          Reboot gemacht ?
                          • N
                            @haselchen Ja habe ich , aber leider immer noch die gleiche meldung 😞
                            • haselchen
                              @Nier
                              Was ergibt
                              Iobroker -v
                              Und
                              ./iobroker update
                              • N
                                ./iobroker update
                                root@NiermannSmartHome:/opt/iobroker# Iobroker -v
                                -bash: Iobroker: Kommando nicht gefunden.
                                root@NiermannSmartHome:/opt/iobroker# ./iobroker update
                                Used repository: default
                                hash unchanged, use cached sources
                                update done
                                Adapter    "admin"         : 3.7.8    , installed 4.0.5
                                Adapter    "alexa2"        : 3.0.5    , installed 3.0.7
                                Adapter    "alpha2"        : 1.0.0
                                Adapter    "amazon-dash"   : 0.3.1
                                Adapter    "artnet"        : 1.0.0
                                Adapter    "asterisk"      : 1.0.6
                                Adapter    "asuswrt"       : 1.0.1
                                Adapter    "b-control-em"  : 0.2.1
                                Adapter    "backitup"      : 1.3.6
                                Adapter    "beckhoff"      : 1.2.0
                                Adapter    "benq"          : 0.2.0
                                Adapter    "ble"           : 0.10.1
                                Adapter    "bmw"           : 1.3.3
                                Adapter    "bosesoundtouch": 0.2.4
                                Adapter    "botvac"        : 1.0.0
                                Adapter    "bring"         : 1.7.1
                                Adapter    "broadlink2"    : 2.0.2    , installed 2.0.2
                                Adapter    "bsblan"        : 0.0.6
                                Adapter    "bshb"          : 0.1.4
                                Adapter    "chromecast"    : 2.3.1
                                Adapter    "cloud"         : 2.6.2    , installed 2.7.1
                                Adapter    "comfoair"      : 0.3.2
                                Adapter    "contactid"     : 1.0.0
                                Adapter    "countdown"     : 1.0.4
                                Adapter    "cul"           : 0.4.0
                                Adapter    "daikin"        : 1.0.5
                                Adapter    "daswetter"     : 2.8.1
                                Adapter    "deconz"        : 1.1.2
                                Adapter    "denon"         : 1.7.2
                                Adapter    "digitalstrom"  : 0.5.5
                                Adapter    "discovergy"    : 0.5.0
                                Adapter    "discovery"     : 1.3.0
                                Adapter    "ds18b20"       : 1.1.4
                                Adapter    "dwd"           : 2.4.3
                                Adapter    "ebus"          : 1.0.0
                                Adapter    "egigeozone"    : 0.1.2
                                Adapter    "ekey"          : 1.1.0
                                Adapter    "email"         : 1.0.5    , installed 1.0.5
                                Adapter    "emby"          : 1.0.2
                                Adapter    "energymanager" : 1.2.2
                                Adapter    "enet"          : 1.0.1
                                Adapter    "epson_stylus_px830": 0.2.1
                                Adapter    "fakeroku"      : 0.2.1
                                Adapter    "feiertage"     : 1.0.17
                                Adapter    "fhem"          : 1.3.0
                                Adapter    "find-my-iphone": 0.2.15
                                Adapter    "firetv"        : 0.0.27
                                Adapter    "flot"          : 1.9.2
                                Adapter    "foobar2000"    : 1.0.0
                                Adapter    "fritzbox"      : 0.2.1
                                Adapter    "fritzdect"     : 0.1.4
                                Adapter    "fronius"       : 1.0.5
                                Adapter    "fullcalendar"  : 0.2.4
                                Adapter    "fullybrowser"  : 1.0.0
                                Adapter    "g-homa"        : 0.5.1
                                Adapter    "geofency"      : 0.3.2
                                Adapter    "gruenbeck"     : 0.0.18
                                Adapter    "habpanel"      : 0.3.4
                                Adapter    "haier"         : 1.0.2
                                Adapter    "ham"           : 1.1.2
                                Adapter    "ham-wemo"      : 1.0.1
                                Adapter    "harmony"       : 1.2.2
                                Adapter    "heytech"       : 0.2.0
                                Adapter    "hid"           : 0.1.17
                                Adapter    "history"       : 1.8.6
                                Adapter    "hm-rega"       : 2.5.4
                                Adapter    "hm-rpc"        : 1.12.6
                                Adapter    "hmip"          : 0.0.11
                                Adapter    "homeconnect"   : 0.0.26
                                Adapter    "homee"         : 0.3.1
                                Adapter    "homepilot"     : 1.0.3
                                Adapter    "hp-ilo"        : 1.0.5
                                Adapter    "hs100"         : 1.0.10
                                Adapter    "hue"           : 3.2.3    , installed 3.2.1 [Updateable]
                                Adapter    "hue-extended"  : 1.2.1    , installed 1.2.2
                                Adapter    "ical"          : 1.7.0    , installed 1.7.1
                                Adapter    "icons-addictive-flavour-png": 0.1.0
                                Adapter    "icons-fatcow-hosting": 0.1.0
                                Adapter    "icons-icons8"  : 0.0.1
                                Adapter    "icons-material-png": 0.1.0
                                Adapter    "icons-material-svg": 0.1.0
                                Adapter    "icons-mfd-png" : 1.0.2
                                Adapter    "icons-mfd-svg" : 1.0.2
                                Adapter    "icons-open-icon-library-png": 0.1.2
                                Adapter    "icons-ultimate-png": 1.0.1
                                Adapter    "influxdb"      : 1.6.3
                                Adapter    "info"          : 1.5.6
                                Adapter    "innogy-smarthome": 0.3.3
                                Adapter    "iogo"          : 0.4.17
                                Adapter    "iot"           : 1.1.8
                                Adapter    "iqontrol"      : 0.2.16
                                Adapter    "javascript"    : 4.3.4    , installed 4.4.2
                                Adapter    "jeelink"       : 0.1.0
                                Controller "js-controller" : 2.2.9    , installed 2.2.9
                                Adapter    "kecontact"     : 0.1.0
                                Adapter    "klf200"        : 0.9.5
                                Adapter    "km200"         : 1.1.6
                                Adapter    "knx"           : 0.8.6
                                Adapter    "kodi"          : 1.0.0
                                Adapter    "kress"         : 2.5.5
                                Adapter    "lametric"      : 0.0.7
                                Adapter    "landroid"      : 1.0.3
                                Adapter    "lcn"           : 0.3.2
                                Adapter    "lgtv"          : 1.1.5
                                Adapter    "lgtv-rs"       : 0.0.4
                                Adapter    "lgtv11"        : 1.0.5
                                Adapter    "lifx"          : 0.0.5
                                Adapter    "lightify"      : 0.2.16
                                Adapter    "link"          : 0.4.4
                                Adapter    "linkeddevices" : 1.1.1
                                Adapter    "lovelace"      : 0.2.3
                                Adapter    "loxone"        : 1.0.0
                                Adapter    "luftdaten"     : 0.0.11
                                Adapter    "lupusec"       : 1.2.3
                                Adapter    "luxtronik1"    : 0.1.0
                                Adapter    "material"      : 0.12.1
                                Adapter    "maxcube"       : 0.1.2
                                Adapter    "maxcul"        : 1.1.1
                                Adapter    "mbus"          : 2.1.3
                                Adapter    "megad"         : 1.2.1
                                Adapter    "megadd"        : 0.2.0
                                Adapter    "megaesp"       : 0.1.0
                                Adapter    "mercedesme"    : 0.0.20
                                Adapter    "meross"        : 1.3.11   , installed 1.3.11
                                Adapter    "meteoalarm"    : 1.0.9
                                Adapter    "miele"         : 0.1.5
                                Adapter    "mihome"        : 1.2.5    , installed 1.2.8
                                Adapter    "mihome-lamp"   : 1.1.0
                                Adapter    "mihome-plug"   : 0.2.0
                                Adapter    "mihome-vacuum" : 1.1.5
                                Adapter    "mikrotik"      : 1.0.4
                                Adapter    "milight"       : 0.3.6
                                Adapter    "milight-smart-light": 0.2.7
                                Adapter    "mobile"        : 0.5.0
                                Adapter    "modbus"        : 2.0.9
                                Adapter    "moma"          : 1.2.3
                                Adapter    "mpd"           : 1.0.0
                                Adapter    "mqtt"          : 2.0.4
                                Adapter    "mqtt-client"   : 1.1.1
                                Adapter    "musiccast"     : 0.0.8
                                Adapter    "mysensors"     : 1.2.2
                                Adapter    "nanoleaf-lightpanels": 0.8.1
                                Adapter    "nello"         : 2.0.6
                                Adapter    "netatmo"       : 1.3.1
                                Adapter    "nibeuplink"    : 0.3.0
                                Adapter    "nina"          : 0.0.15
                                Adapter    "node-red"      : 1.13.0
                                Adapter    "nuki"          : 1.1.2
                                Adapter    "nuki-extended" : 2.2.0    , installed 2.2.0
                                Adapter    "nut"           : 1.1.3
                                Adapter    "odl"           : 1.0.5
                                Adapter    "oilfox"        : 0.0.5
                                Adapter    "onkyo"         : 2.0.2
                                Adapter    "onvif"         : 0.0.2
                                Adapter    "openhab"       : 1.1.0
                                Adapter    "openweathermap": 0.1.0
                                Adapter    "opi"           : 0.1.1
                                Adapter    "oppoplayer"    : 0.2.1
                                Adapter    "owfs"          : 0.6.1
                                Adapter    "owntracks"     : 0.6.2
                                Adapter    "panasonic-viera": 1.0.2
                                Adapter    "parser"        : 1.0.7
                                Adapter    "paw"           : 0.0.7
                                Adapter    "phantomjs"     : 1.0.1
                                Adapter    "pi-hole"       : 1.2.3
                                Adapter    "piface"        : 1.0.0
                                Adapter    "pimatic"       : 0.1.5
                                Adapter    "ping"          : 1.3.2
                                Adapter    "places"        : 0.7.0
                                Adapter    "plex"          : 0.8.9
                                Adapter    "plexconnect"   : 0.0.7
                                Adapter    "pollenflug"    : 1.0.4
                                Adapter    "proxmox"       : 0.3.2
                                Adapter    "proxy"         : 1.1.1
                                Adapter    "pushbullet"    : 0.0.11
                                Adapter    "pushover"      : 1.1.1
                                Adapter    "pushsafer"     : 0.1.8
                                Adapter    "radar2"        : 1.0.9
                                Adapter    "radiohead"     : 1.0.4
                                Adapter    "rflink"        : 1.2.0
                                Adapter    "rickshaw"      : 1.0.0
                                Adapter    "ring"          : 1.0.5    , installed 1.0.5
                                Adapter    "roomba"        : 1.1.1
                                Adapter    "rpi2"          : 1.1.1
                                Adapter    "s7"            : 1.1.4
                                Adapter    "samsung"       : 0.2.9
                                Adapter    "sayit"         : 1.7.0
                                Adapter    "sbfspot"       : 2.4.0
                                Adapter    "scenes"        : 1.1.0
                                Adapter    "schoolfree"    : 0.3.1
                                Adapter    "shelly"        : 3.1.6
                                Adapter    "shuttercontrol": 0.4.3
                                Adapter    "sia"           : 1.0.3
                                Adapter    "siegenia"      : 1.0.0
                                Adapter    "simple-api"    : 2.3.2    , installed 2.3.2
                                Adapter    "smappee"       : 0.2.2
                                Adapter    "smartmeter"    : 3.0.10
                                Adapter    "snips"         : 1.5.0
                                Adapter    "snmp"          : 0.5.0
                                Adapter    "socketio"      : 2.1.2    , installed 2.1.2
                                Adapter    "solarlog"      : 1.2.1
                                Adapter    "solarwetter"   : 1.0.0
                                Adapter    "sonnen"        : 1.3.0
                                Adapter    "sonoff"        : 2.2.2
                                Adapter    "sonos"         : 2.0.1
                                Adapter    "sony-bravia"   : 1.0.1
                                Adapter    "spotify-premium": 1.0.0
                                Adapter    "sql"           : 1.9.4
                                Adapter    "squeezebox"    : 1.0.0
                                Adapter    "starline"      : 1.0.0
                                Adapter    "statistics"    : 0.2.0
                                Adapter    "stiebel-isg"   : 1.4.11
                                Adapter    "swiss-weather-api": 0.1.6
                                Adapter    "systeminfo"    : 0.3.1
                                Adapter    "tahoma"        : 0.3.2
                                Adapter    "tankerkoenig"  : 2.0.5
                                Adapter    "telegram"      : 1.4.3
                                Adapter    "terminal"      : 0.1.2
                                Adapter    "text2command"  : 1.2.5    , installed 1.2.5
                                Adapter    "tr-064"        : 0.4.14   , installed 0.4.18
                                Adapter    "tradfri"       : 2.5.2
                                Adapter    "tunnelbroker-endpoint-updater": 0.0.1
                                Adapter    "tuya"          : 3.2.0
                                Adapter    "tvspielfilm"   : 1.0.4
                                Adapter    "unifi"         : 0.3.1
                                Adapter    "upnp"          : 1.0.11
                                Adapter    "valloxmv"      : 1.0.3
                                Adapter    "vcard"         : 0.0.9
                                Adapter    "velux"         : 0.0.2
                                Adapter    "viessmann"     : 1.2.4
                                Adapter    "virtualpowermeter": 1.0.0
                                Adapter    "vis"           : 1.2.3
                                Adapter    "vis-bars"      : 0.1.4
                                Adapter    "vis-canvas-gauges": 0.1.5
                                Adapter    "vis-colorpicker": 1.1.1
                                Adapter    "vis-fancyswitch": 1.1.0
                                Adapter    "vis-google-fonts": 0.1.0
                                Adapter    "vis-history"   : 1.0.0
                                Adapter    "vis-hqwidgets" : 1.1.3
                                Adapter    "vis-jqui-mfd"  : 1.0.12
                                Adapter    "vis-justgage"  : 1.0.2
                                Adapter    "vis-keyboard"  : 0.0.2
                                Adapter    "vis-lcars"     : 1.0.4
                                Adapter    "vis-map"       : 1.0.2
                                Adapter    "vis-metro"     : 1.1.2
                                Adapter    "vis-players"   : 0.1.5
                                Adapter    "vis-plumb"     : 1.0.1
                                Adapter    "vis-rgraph"    : 0.0.2
                                Adapter    "vis-timeandweather": 1.1.7
                                Adapter    "vis-weather"   : 2.5.2
                                Adapter    "vr200"         : 1.0.0
                                Adapter    "weatherunderground": 3.1.6
                                Adapter    "web"           : 2.4.10   , installed 2.4.10
                                Adapter    "weishaupt-wem" : 0.0.8
                                Adapter    "wetty"         : 0.1.1
                                Adapter    "wiffi-wz"      : 2.1.4
                                Adapter    "wifilight"     : 0.2.0
                                Adapter    "wm-bus"        : 0.1.12
                                Adapter    "wolf"          : 0.9.2
                                Adapter    "worx"          : 1.0.0
                                Adapter    "xbox"          : 0.5.8
                                Adapter    "xs1"           : 1.0.2
                                Adapter    "yahka"         : 0.9.2    , installed 0.9.2
                                Adapter    "yamaha"        : 0.3.19
                                Adapter    "yeelight-2"    : 1.0.3
                                Adapter    "youtube"       : 0.0.6
                                Adapter    "yr"            : 2.0.3
                                Adapter    "zigbee"        : 1.0.2
                                Adapter    "zont"          : 0.5.3
                                Adapter    "zwave"         : 1.6.3
                                • haselchen
                                  @Nier
                                  Ist doch alles tutti.
                                  iobroker restart
                                  Oder
                                  iobroker start admin.0 oder ohne .0 probieren
                                  • N
                                    iobroker restart
                                    alles drei eingegeben und es kommt immer noch:
                                    • haselchen
                                      @Nier
                                      Was passiert denn wenn du diesen Befehl in
                                      opt/iobroker eingibst?
                                      • N
                                        @haselchen dauert wein wenig und dann nichts
                                        root@NiermannSmartHome:/opt/iobroker# iobroker restart
                                        root@NiermannSmartHome:/opt/iobroker# iobroker start admin.0
                                        • haselchen
                                          @Nier
                                          Ich meinte wenn du den Befehl dort eingibst:
                                          npm install iobroker.admin - update
                                          • N
                                            @haselchen oh sry
                                            root@NiermannSmartHome:/opt/iobroker# npm install iobroker.admin - update
                                            npm ERR! code E404
                                            npm ERR! 404 Not Found - GET https://registry.npmjs.org/- - Not found
                                            npm ERR! 404
                                            npm ERR! 404  '-@latest' is not in the npm registry.
                                            npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
                                            npm ERR! 404
                                            npm ERR! 404 Note that you can also install from a
                                            npm ERR! 404 tarball, folder, http url, or git url.
                                            npm ERR!     /home/iobroker/.npm/_logs/2020-03-05T13_32_10_443Z-debug.log
                                            funktioniertnicht
                                            4261
