    4. ioBroker startet nicht
    SOLVED ioBroker startet nicht
    • haselchen
      haselchen Most Active @Nier last edited by
      @Nier
      Ich meinte wenn du den Befehl dort eingibst:
      npm install iobroker.admin - update
      • N
        Nier @haselchen last edited by Negalein
        @haselchen oh sry
        root@NiermannSmartHome:/opt/iobroker# npm install iobroker.admin - update
        npm ERR! code E404
        npm ERR! 404 Not Found - GET https://registry.npmjs.org/- - Not found
        npm ERR! 404
        npm ERR! 404  '-@latest' is not in the npm registry.
        npm ERR! 404 You should bug the author to publish it (or use the name yourself!)
        npm ERR! 404
        npm ERR! 404 Note that you can also install from a
        npm ERR! 404 tarball, folder, http url, or git url.
        npm ERR!     /home/iobroker/.npm/_logs/2020-03-05T13_32_10_443Z-debug.log
        Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
        Hier gehts zur Hilfe.
        • haselchen
          @Nier
          Liegt vermutlich an deinem Verwahrungsort .
          npm install iobroker.admin@3.7.8
          • N
            @haselchen said in ioBroker startet nicht:
            Wieso was könnte da falsch sein?
            Leider funktionierte das auch nicht. Folgendes kommt:
            root@NiermannSmartHome:/opt/iobroker# npm install iobroker.admin@3.7.8
            npm WARN ajv-keywords@2.1.1 requires a peer of ajv@^5.0.0 but none is installed. You must install peer dependencies yourself.
            npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
            npm WARN winston-daily-rotate-file@4.4.2 requires a peer of winston@^3 but none is installed. You must install peer dependencies yourself.
            npm WARN winston-syslog@2.4.0 requires a peer of winston@^3.0.0 but none is installed. You must install peer dependencies yourself.
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/fsevents):
            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
            + iobroker.admin@3.7.8
            removed 23 packages and updated 1 package in 31.927s
            7 packages are looking for funding
              run `npm fund` for details
            • haselchen
              @Nier
              Das sind alles nur Warnungen.
              Kommst du denn jetzt auf die Oberfläche?
              • AlCalzone
                AlCalzone Developer @Nier last edited by AlCalzone
                @Nier sagte in ioBroker startet nicht:
                iobroker.js-controller@2.2.9
                updated 1 package
                Geht doch!
                Und hierzu:
                This adapter cannot be installed directly from github.
                You must install it from npm.
                Write for that "npm install iobroker.admin" in according directory.
                Du hast den Admin zuvor über Github installiert.
                Les dir bitte https://www.iobroker.net/#de/documentation/tutorial/adapter.md?dieinstallationvongithub und mach es dann nie wieder. Außer du wirst explizit dazu aufgefordert.
                • N
                  Nier @AlCalzone last edited by
                  @AlCalzone Kann man das noch irgendwie fixieren? Denn mit npm install iobroker.admin geht es ja leider auch nicht....
                  werde es auf jeden fall nie wieder tun 😞
                  haselchen AlCalzone 2 Replies Last reply Reply Quote 0
                  • haselchen
                    @Nier
                    Was geht denn nicht ?
                    • AlCalzone
                      @Nier
                      cd /opt/iobroker
                      iobroker upload admin
                      iobroker start admin.0
                      • N
                        @haselchen Wenn ich den iobroker öffne kommt nur:
                        ich komm leider gar nicht auf die oberfläche und kann halt nichts machen
                        • AlCalzone
                          @Nier Das sind Befehle für die Konsole!
                          • N
                            @AlCalzone DANKE!!! Es hat geklappt. Ich kann dir grade gar nicht genug danken. Auch an @haselchen !
                            haselchen 1 Reply Last reply Reply Quote 1
                            • haselchen
                              @Nier
                              Das Kind ist geboren . Halleluja 😎
                              In der Oberfläche im Admin den Verwahrungsort auf Latest stellen und auf der Oberfläche den Admin auf 4.0.5 updaten.
                              • N
                                @haselchen alles klar danke 🙂
                                  Homoran Global Moderator Administrators @Nier last edited by
                                  Leider gehts immer noch nicht
                                  Spoiler
                                  wo ist das Problem?
                                  WARN: skipping OPTIONAL dependencies
                                  Also kein Fehler nur eine Warnung - ist ok!
                                  funktioniertnicht
                                  4260
