    4. Test Adapter mihome-vacuum v2.0.x
      dirkhe Developer last edited by
      Was habt ihr denn als IntervallZeiten eingestellt?
      Disconnect schreibt er immer, wenn die letzte Antwort vom robbi länger als die Intervallzeit ist
      • Diginix
        Diginix @dirkhe last edited by Diginix
        @dirkhe Status alle 10s / WLAN alle 60s (sollte default sein).
        Hier mal das Log als es heute Nacht anfing. So ging/geht das über Stunden. Sehe es nun durch warn Loglevel nicht mehr. Sind immer alle 20 Sek, also keines der beiden gesetzten Intervalle.
        2020-03-05 03:40:49.500  - info: mihome-vacuum.0 (4187) Disconnect
        2020-03-05 03:40:54.535  - warn: mihome-vacuum.0 (4187) no answer received after after 3 times -> pause miIO.info try again in one hour
        2020-03-05 03:41:09.531  - info: mihome-vacuum.0 (4187) Disconnect
        2020-03-05 03:41:29.533  - info: mihome-vacuum.0 (4187) Disconnect
        2020-03-05 03:41:49.534  - info: mihome-vacuum.0 (4187) Disconnect
        2020-03-05 03:42:09.536  - info: mihome-vacuum.0 (4187) Disconnect
        2020-03-05 03:42:09.542  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
        2020-03-05 03:42:09.562  - info: mihome-vacuum.0 (4187) Connected
        2020-03-05 03:42:29.537  - info: mihome-vacuum.0 (4187) Disconnect
        2020-03-05 03:42:29.545  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
        2020-03-05 03:42:29.594  - info: mihome-vacuum.0 (4187) Connected
        2020-03-05 03:42:49.539  - info: mihome-vacuum.0 (4187) Disconnect
        2020-03-05 03:42:49.547  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
        2020-03-05 03:42:49.580  - info: mihome-vacuum.0 (4187) Connected
        2020-03-05 03:43:09.542  - info: mihome-vacuum.0 (4187) Disconnect
        2020-03-05 03:43:09.549  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
        2020-03-05 03:43:09.701  - info: mihome-vacuum.0 (4187) Connected
        2020-03-05 03:43:29.543  - info: mihome-vacuum.0 (4187) Disconnect
        2020-03-05 03:43:29.551  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
        2020-03-05 03:43:29.575  - info: mihome-vacuum.0 (4187) Connected
        2020-03-05 03:43:49.544  - info: mihome-vacuum.0 (4187) Disconnect
        2020-03-05 03:43:49.551  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
        2020-03-05 03:43:49.573  - info: mihome-vacuum.0 (4187) Connected
        2020-03-05 03:44:09.545  - info: mihome-vacuum.0 (4187) Disconnect
        2020-03-05 03:44:09.552  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
        2020-03-05 03:44:09.575  - info: mihome-vacuum.0 (4187) Connected
        2020-03-05 03:44:29.547  - info: mihome-vacuum.0 (4187) Disconnect
        2020-03-05 03:44:29.552  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
        2020-03-05 03:44:29.576  - info: mihome-vacuum.0 (4187) Connected
        2020-03-05 03:44:49.549  - info: mihome-vacuum.0 (4187) Disconnect
        2020-03-05 03:44:49.555  - info: mihome-vacuum.0 (4187) connecting, This can take up to 5 minutes ...
        2020-03-05 03:44:49.580  - info: mihome-vacuum.0 (4187) Connected
        Token, IP usw. sind korrekt und ohne System/Instanz Neustart konnte ich den Sauger gestern Abend problemlos steuern inkl. Kartenabruf. Wenn es also nur Netzwerkprobleme sind, dann nehme ich es so hin. Falls mehr dahinter steckt, musst du sagen was du bräuchtest. Debuglog mit Interaktion vom Sauger kann ich erst später liefern.
          So, ich glaube ich habe die Ursache gefunden. HIntergrund ist, dass ich den Traffic generell verringern wollte. Bei mir ist Status zb. auch auf 1 Minute eingestellt. Wenn aus dem Adapter irgendwelche statusrelevanten Aktionen angestossen werden, wie zb. ein Saugvrogang, Stop,Pause usw. wird der Status unabhängig davon 2s später abgefragt. Solange er saugt, wird der Interval automatisch auf 10sec eingestellt und hinterher wieder auf eure Zeit aus der config.
          Ich denke, dass es bei 10sec da ggf. zu Problemen führt, vlt. sollte ich ein Neuverbinden, bzw. ein connection lost erst nach min. 1.Minute nicht mehr annehmen. Also ich werde das mal so machen, dass ich 1 Minte oder einen ggf. grösser eingetelles Intervall annehme.
            jayfizzle last edited by jayfizzle
            nutze nun seit einigen Tagen euren Adapter und muss euch für die geleistete Arbeit Danken, super Leistung, Hut ab.
            Nun aber zu meinem Problem, welches ggf. nicht hier hin gehört.
            Über den Adapter kann ich meinen Roborock S5 problemlos steuern, jedoch habe ich heute morgen folgende Meldungen im Log erhalten:
            mihome-vacuum.0 2020-03-05 09:30:54.070 error (24164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Thu, 05 Mar 2020 08:30:54 GMT","content-length":"123","connection":"close","x-xiaomi-request-id":"514567be-5f65-
            mihome-vacuum.0 2020-03-05 09:29:57.664 error (24164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Thu, 05 Mar 2020 08:29:57 GMT","content-length":"123","connection":"close","x-xiaomi-request-id":"11264492-1329-
            mihome-vacuum.0 2020-03-05 09:29:55.598 error (24164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Thu, 05 Mar 2020 08:29:55 GMT","content-length":"123","connection":"close","x-xiaomi-request-id":"46e6454a-5302-
            mihome-vacuum.0 2020-03-05 09:29:20.919 error (24164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Thu, 05 Mar 2020 08:29:20 GMT","content-length":"123","connection":"close","x-xiaomi-request-id":"9ahzh5e9-61ef-
            mihome-vacuum.0 2020-03-05 09:18:44.112 warn (24164) Could not receive Mappointer, giving up
            Die im Objekt mihome-vacuum.0.map.map64 hinterlegte Karte kann aufgerufen werden.
            ebenfalls wird mir die Karte nicht in der Mi Home App angezeigt, es steht lediglich "Karte wird geladen..." und es tut sich nichts.
            Hat jmd. von euch ähnliche Probleme?
            Hoffe das mir da ggf. jmd. weiterhelfen kann, auch wenn dies wahrscheinlich nichts mit dem Adapter zu tun hat.
              Adnim @dirkhe last edited by
              @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
              @Adnim Einen Button könnte man sicherlich einbauen, sonst sollte das über
              sendTo("mihome-vacuum.0", "getMap") gehen
              danke für die Antwort, blicke Sie aber nicht 🙂
              Also ich kann eine gespeicherte Karte in Valetudo durch den Adapter laden?
              wo müsste der name der map den stehen, "getMap" verweist ja auf keine gespeicherte Karte oder wie ist das zu verstehen?
                dirkhe Developer @Adnim last edited by
                @Adnim Soweit ich weiß, wird der Roboter gefragt, welche Karte aktuell ist und dann wird die Url der Karte geholt
                  ok verstehe, nun möchte ich eine andere Map aus dem Valetudo speicher vor jeder Reinigung laden, eine in der die Türen halt auf sind...
                  Das geht dann aber bislang nur via Valetudo Interface?
                    @Adnim Sorry, da kenne ich nicht nicht mit aus
                      2.0.9-RC02 ist im git:
                      unötiges conect/reconnect sollte gefixt sein
                      in info.queue sollten dann jetzt auch die Raumnamen auftauchen
                      haselchen B B 3 Replies Last reply Reply Quote 0
                      • haselchen
                        haselchen Most Active @dirkhe last edited by haselchen
                        @dirkhe
                        Von diesem Link installieren?
                        https://github.com/dirkhe/ioBroker.mihome-vacuum
                        Wenn ja habe ich es getan. Es kam die Nachricht im Log, dass das Verbinden 5min braucht.
                        Es kam aber permanent disconnected.
                        Erst als ich die MiHome App geöffnet habe, hat er sich verbunden.
                        • Diginix
                          Diginix @haselchen last edited by
                          @haselchen Nein offizielles Repo. https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum
                          Im Log siehst du auch welche Version gestartet wird.
                          • haselchen
                            haselchen Most Active @Diginix last edited by
                            @Diginix
                            Deswegen hatte ich letztens um Vereinheitlichung gebeten.
                            Also veröffentlicht @dirkhe seine Versionen jetzt unter dem früheren Link (Deinem)?
                            • Diginix
                              Diginix @haselchen last edited by Diginix
                              @haselchen Nicht meinem, sondern dem offiziellen, indirekt dem von Meistertr und je nach dem wie umfangreich die Änderungen sind, wird das sicher auch mal wieder in @dirkhe Fork sein (müssen). Wer nicht jede Neuerung braucht, muss sich damit ja auch nicht befassen. Bisher ist alles maximal latestet, eher beta auch wenn es stabil ist. Wenn du durcheinander kommst, dann bleib auf den offiziellen Repos (stable oder latest). Ansonsten einfach bei GIT schauen wo die "jüngeren" Dateien liegen bzw. was als Commit eingecheckt wurde.
                              • haselchen
                                haselchen Most Active @Diginix last edited by haselchen
                                @Diginix
                                Ich verfolge das hier ja auch permanent.
                                In dieser Version ist es tatsächlich so, dass er sich erst verbindet wenn ich die App öffne.
                                Vielleicht hilfreich für @dirkhe
                                Ein Log habe ich leider nicht, da es nach dem Update auftritt. Wenn er einmal connected ist, bleibt es so.
                                  Kueppert @haselchen last edited by
                                  @haselchen das hatte ich bei meiner Version auch. Hab ich hier auch schon - meine ich - mal erwähnt. Aber läuft klasse. Besonders das mit der Karte finde ich geil via Cloud. Hab auf meinem Vacuum leider die neuste FW druff, so dass das Draufkloppen von der Software die hier genannt wird, bei mir nicht mehr klappt.
                                    blackeagle998 @dirkhe last edited by
                                    @dirkhe
                                    Seit dieser Version verbindet sich der Adapter mit dem Staubi nicht mehr, vorher lief das reibungslos:
                                    mihome-vacuum.0	2020-03-05 17:52:37.375	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:52:18.688	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:52:18.687	warn	(9892) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                    mihome-vacuum.0	2020-03-05 17:51:57.535	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:51:37.371	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:51:17.368	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:50:57.370	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:50:37.367	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:50:17.367	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:49:57.367	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:49:37.366	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:49:17.366	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:48:57.363	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:48:37.362	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:48:17.361	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:47:57.361	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:47:37.360	info	(9892) connecting, this can take up to 5 minutes ...
                                    mihome-vacuum.0	2020-03-05 17:47:17.362	info	(9892) connecting, this can take up to 5 minutes ...
                                    • haselchen
                                      haselchen Most Active @Kueppert last edited by
                                      @Kueppert
                                      Karte und Token auslesen ist der Hammer. Stimmt.
                                      Hat gleich eine neue View in der VIS bekommen 🙂 🙂
                                      • haselchen
                                        haselchen Most Active @blackeagle998 last edited by
                                        @blackeagle998
                                        MIHOME App öffnen , dann geht es
                                        B E 2 Replies Last reply Reply Quote 0
                                          blackeagle998 @haselchen last edited by
                                          @haselchen
                                          Danke, aber den Zusammenhang verstehe ich nicht, ging doch vorher auch ohne 🤷‍♂️
                                          • haselchen
                                            @blackeagle998
                                            Ich weiß, denke das @dirkhe das zeitnah fixen wird.
                                            App öffnen behebt das Problem erstmal.
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            493851
