    4. Test Adapter mihome-vacuum v2.0.x
      blackeagle998 @dirkhe last edited by
      @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
      2.0.9-RC02 ist im git:
      unötiges conect/reconnect sollte gefixt sein
      in info.queue sollten dann jetzt auch die Raumnamen auftauchen
      @dirkhe
      Seit dieser Version verbindet sich der Adapter mit dem Staubi nicht mehr, vorher lief das reibungslos:
      mihome-vacuum.0	2020-03-05 17:52:37.375	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:52:18.688	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:52:18.687	warn	(9892) Time difference between Mihome Vacuum and ioBroker: 1 sec
      mihome-vacuum.0	2020-03-05 17:51:57.535	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:51:37.371	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:51:17.368	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:50:57.370	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:50:37.367	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:50:17.367	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:49:57.367	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:49:37.366	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:49:17.366	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:48:57.363	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:48:37.362	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:48:17.361	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:47:57.361	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:47:37.360	info	(9892) connecting, this can take up to 5 minutes ...
      mihome-vacuum.0	2020-03-05 17:47:17.362	info	(9892) connecting, this can take up to 5 minutes ...
      • haselchen
        haselchen Most Active @Kueppert last edited by
        @Kueppert
        Karte und Token auslesen ist der Hammer. Stimmt.
        Hat gleich eine neue View in der VIS bekommen 🙂 🙂
        • haselchen
          haselchen Most Active @blackeagle998 last edited by
          @blackeagle998
          MIHOME App öffnen , dann geht es
          B E 2 Replies Last reply Reply Quote 0
            blackeagle998 @haselchen last edited by
            @haselchen
            Danke, aber den Zusammenhang verstehe ich nicht, ging doch vorher auch ohne 🤷‍♂️
            • haselchen
              @blackeagle998
              Ich weiß, denke das @dirkhe das zeitnah fixen wird.
              App öffnen behebt das Problem erstmal.
              • Diginix
                Diginix last edited by Diginix
                @dirkhe Direkt ein Fehler mit Instanz Absturz erhalten mit 2 Räumen im queue:
                2020-03-05 17:57:15.959  - info: mihome-vacuum.0 (13815) trigger cleaning segment 21
                2020-03-05 17:57:37.942  - info: mihome-vacuum.0 (13815) should trigger cleaning segment 17, but is currently active. Add to queue
                2020-03-05 17:57:59.311  - info: mihome-vacuum.0 (13815) should trigger cleaning segment 19, but is currently active. Add to queue
                2020-03-05 17:58:06.326  - info: mihome-vacuum.0 (13815) trigger cleaning segment 17
                2020-03-05 17:58:41.436  - error: mihome-vacuum.0 (13815) uncaught exception: Cannot read property 'body' of undefined
                2020-03-05 17:58:41.439  - error: mihome-vacuum.0 (13815) TypeError: Cannot read property 'body' of undefined
                    at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:565:44)
                    at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                    at Request.emit (events.js:198:13)
                    at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
                    at ClientRequest.emit (events.js:198:13)
                    at TLSSocket.socketErrorListener (_http_client.js:401:9)
                    at TLSSocket.emit (events.js:198:13)
                    at emitErrorNT (internal/streams/destroy.js:91:8)
                    at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
                    at process._tickCallback (internal/process/next_tick.js:63:19)
                2020-03-05 17:58:41.452  - info: mihome-vacuum.0 (13815) terminating
                2020-03-05 17:58:41.453  - info: mihome-vacuum.0 (13815) Terminated (NO_ERROR): Without reason
                2020-03-05 17:58:41.989  - error: host.BT3-PRO Caught by controller[0]: TypeError: Cannot read property 'body' of undefined
                2020-03-05 17:58:41.990  - error: host.BT3-PRO Caught by controller[0]:     at Request._callback (/opt/iobroker/node_modules/iobroker.mihome-vacuum/lib/maphelper.js:565:44)
                2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
                2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at Request.emit (events.js:198:13)
                2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:881:8)
                2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at ClientRequest.emit (events.js:198:13)
                2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at TLSSocket.socketErrorListener (_http_client.js:401:9)
                2020-03-05 17:58:41.991  - error: host.BT3-PRO Caught by controller[0]:     at TLSSocket.emit (events.js:198:13)
                2020-03-05 17:58:41.992  - error: host.BT3-PRO Caught by controller[0]:     at emitErrorNT (internal/streams/destroy.js:91:8)
                2020-03-05 17:58:41.992  - error: host.BT3-PRO Caught by controller[0]:     at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
                2020-03-05 17:58:41.992  - error: host.BT3-PRO Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:63:19)
                2020-03-05 17:59:15.368  - info: mihome-vacuum.0 (15878) starting. Version 2.0.9-RC02 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                • JB_Sullivan
                  JB_Sullivan @haselchen last edited by
                  @haselchen sagte in Test Adapter mihome-vacuum v2.0.x:
                  @Kueppert
                  Mit was (Widget) hast du das gemacht? Hast diesen ultra langen Link genommen? Bei mir bricht dann alles (ioB & VIS Editor) zusammen wenn ich den Map64 Link verwende.
                    dirkhe Developer @Diginix last edited by
                    @Diginix also das muss ich mir genauer ansehen nachher, dürfte eigentlich nichts mit den letzten Veränderungen zu tun haben, da es in der maphelper auftrit.
                    Dass man sich erst mit der App verbinden muss, ist mir neu. Dass er manchmal ne Minute oder länger braucht, das kann bei Adapter start schon Mal vorkomm, daher schreibe ich das ja extra ins Log.
                    Wenn ich nachher zu Hause bin, muss ich noch Mal schauen.
                    • haselchen
                      haselchen Most Active @JB_Sullivan last edited by haselchen
                      @JB_Sullivan
                      Lach. Wollte dir die Infos von der View zukommen lassen und hab sie ausversehen gelöscht.
                      Dumm und Dümmer in einer Person -> Thats me 🙂
                      Das HTML Widget und in das HTML Feld rechts {mihome-vacuum.0.map.map64}
                      reinschreiben.
                      Die Karte wird nur in der Runtime angezeigt.
                      • JB_Sullivan
                        JB_Sullivan @haselchen last edited by JB_Sullivan
                        Super - Vielen Dank, aber ..........
                        ..... bekommt man das auch irgendwie größer? Innerhalb des Fensters wird ja nur ein Mini Kärtchen angezeigt.
                        PS: Die blaue Karte gehört zum Mi-Sauger - die rote ist vom roomba
                        • haselchen
                          @JB_Sullivan
                          Du musst rechts anstatt px % angeben.
                          Und dann das Widget so hinziehen das es vernünftig aussieht.
                            dirkhe Developer @Diginix last edited by dirkhe
                            @Diginix Also den Fehler habe ich jetzt mal abgefangen, hat aber nichts mit den Räumen zu tun oder ähnliches. Das muß einen anderen Hintergrund haben, ich hoffe, dass der eigentliche Fehler jetzt ausgegeben wird.
                            2.0.9-RC03 ist im Git
                            Ich habe bei mir jetzt den Robi mal wieder mit dem Internet verbunden. Ich habe habe 8 Minuten gebraucht, bis er sich connected hat. Daher habe ich den Info Text von 5 auf 10 Minuten geändert.
                            Da kann ich aber leider nichts gegen machen.
                            • JB_Sullivan
                              @JB_Sullivan
                              OK, vielen Dank - hat funktioniert.
                              @dirkhe
                              Also mit 2.0.9-RC02 habe ich keine Connection Probleme mehr - und er verbindet sich sofort.
                              mihome-vacuum.0	2020-03-05 19:51:19.741	info	(9768) create state for carpet_mode
                              mihome-vacuum.0	2020-03-05 19:51:19.098	info	(9768) set nächster Timer: Nicht verfügbar
                              mihome-vacuum.0	2020-03-05 19:51:18.720	info	(9768) Connected
                              mihome-vacuum.0	2020-03-05 19:51:18.658	info	(9768) connecting, this can take up to 5 minutes ...
                              mihome-vacuum.0	2020-03-05 19:51:18.625	info	(9768) New generation or new fw(3.3.9,003468) detected, create new states goto and zoneclean
                              mihome-vacuum.0	2020-03-05 19:51:18.570	info	(9768) Create state clean_home for controlling by cloud adapter
                              mihome-vacuum.0	2020-03-05 19:51:18.569	info	(9768) Expert mode disabled, states deleted
                              mihome-vacuum.0	2020-03-05 19:51:18.477	info	(9768) starting. Version 2.0.9-RC02 in C:/iobroker/GLT/node_modules/iobroker.mihome-vacuum, node: v10.17.0
                                dirkhe Developer @JB_Sullivan last edited by
                                @JB_Sullivan ähhh, die RC02 war doch genau die Version, die diese Probleme verursacht. Die RC03, hat was das betrifft nur eine Textänderung von 5 Minuten auf 10 Minuten
                                • JB_Sullivan
                                  JB_Sullivan @dirkhe last edited by
                                  Bei mir hat "nur " die 2.0.9 die Probleme verursacht - mit der RC02 waren sie weg
                                    dirkhe Developer last edited by dirkhe
                                    Kann es sein, dass der Chinaserver da gerade irgendwelche Zicken macht und das mit unserem Adapter gar nichts zu tun hat? Es ist nämlich so, dass ich grossartig nichts geändert habe. Das war nur eher sachen, dass er nicht unnötig was geschickt hat, denn der Adapter lief ja, war also eher Optimierung..
                                    Bin jetzt auch nochmal in die App gegangen und da wollte er eine Firmware Aktualisierung machen
                                      2.0.9-RC04
                                      add Button loadMap
                                      load map automaticly 2 sec after charging
                                      Ich habe jetzt die neue Firmware drauf und ich denke, China <> App <> Robbi sind wieder im Sync. Jetzt geht mein Adapter Start auch wieder schnell
                                      B haselchen 2 Replies Last reply Reply Quote 0
                                      • Diginix
                                        Diginix @dirkhe last edited by
                                        @dirkhe RC03 lief mit dem gleichen Testmuster eben fehlerfrei. Auch gab es nach Instanzstart sofort ein Connected.
                                        Die 8 min die du gewartet hast, wären sicher auch kürzer ausgefallen wenn du parallel die MiHome App öffnest.
                                        Das hat wie bei anderen hier bei mir heute bei der RC02 auch sofort zum Connected geführt. K.a. was da für ein Event beim Sauger getriggert wird, dass er williger auf Anfragen reagiert.
                                          @dirkhe
                                          RC03 (nicht RC04) funktioniert wieder super schnell, danke!
                                          • haselchen
                                            haselchen Most Active @dirkhe last edited by
                                            @dirkhe
                                            RC03 läuft, kann ich bestätigen.
                                            Connect kommt sofort.
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            493556
