    4. JavaScript
    5. Script fürTabelle der Batterie Zustände
      sigi234 Forum Testing Most Active @liv-in-sky last edited by
      @liv-in-sky
      Wie muss ich die json importieren und welches Widget genau hast du genommen?
        liv-in-sky @sigi234 last edited by
        @sigi234
        import - alles drin
        [{"tpl":"tplVis-materialdesign-Table","data":{"oid":"","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","countCols":"3","tableLayout":"standard","showHeader":"true","headerTextSize":"headline6","showColumn0":"true","colType0":"text","textAlign0":"left","showColumn1":"true","colType1":"text","textAlign1":"center","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"showColumn2":"true","colType2":"text","textAlign2":"center","showColumn3":"true","colType3":"image","textAlign3":"center","dataJson":"[{\"Device\": \"magnet\",\"Wert\": \"60.6 %\",\"Status\": \"✅\",\"Hersteller\":\"/vis.0/armin/img/marken/xiaomki.png\" },{\"Device\": \"magnet\",\"Wert\": \"62.4 %\",\"Status\": \"✅\",\"Hersteller\":\"/vis.0/armin/img/marken/xiaomki.png\" },{\"Device\": \"magnet\",\"Wert\": \"64.2 %\",\"Status\": \"✅\",\"Hersteller\":\"/vis.0/armin/img/marken/xiaomki.png\" },{\"Device\": \"magnet\",\"Wert\": \"60.6 %\",\"Status\": \"✅\",\"Hersteller\":\"/vis.0/armin/img/marken/xiaomki.png\" },{\"Device\": \"motion 2\",\"Wert\": \"66.1 %\",\"Status\": \"✅\",\"Hersteller\":\"/vis.0/armin/img/marken/xiaomki.png\" },{\"Device\": \"motion 1\",\"Wert\": \"69.7 %\",\"Status\": \"✅\",\"Hersteller\":\"/vis.0/armin/img/marken/xiaomki.png\" },{\"Device\": \"sensor_motion.aq2\",\"Wert\": \"60.6 %\",\"Status\": \"✅\",\"Hersteller\":\"/vis.0/armin/img/marken/xiaomki.png\" },{\"Device\": \"switch\",\"Wert\": \"69.2 %\",\"Status\": \"✅\",\"Hersteller\":\"/vis.0/armin/img/marken/xiaomki.png\" },{\"Device\": \"switch\",\"Wert\": \"71 %\",\"Status\": \"✅\",\"Hersteller\":\"/vis.0/armin/img/marken/xiaomki.png\" },{\"Device\": \"vibration\",\"Wert\": \"64.2 %\",\"Status\": \"✅\",\"Hersteller\":\"/vis.0/armin/img/marken/xiaomki.png\" },{\"Device\": \"vibration\",\"Wert\": \"64.2 %\",\"Status\": \"✅\",\"Hersteller\":\"/vis.0/armin/img/marken/xiaomki.png\" },{\"Device\": \"Fenster Küche\",\"Wert\": \"64.2 %\",\"Status\": \"✅\",\"Hersteller\":\"/vis.0/armin/img/marken/deconzk.png\" },{\"Device\": \"Wasser Küche\",\"Wert\": \"33 %\",\"Status\": \"✅\",\"Hersteller\":\"/vis.0/armin/img/marken/deconzk.png\" }]","colTextSize0":"headline4","label1":"Wert","label0":"Name","label2":"Status","sortKey0":"name","fontFamily0":"Jura-DemiBold","padding_left0":"10","colTextColor0":"#beb7b7","colorBackground":"#ffffff","colorHeaderRowBackground":"#000000","colorHeaderRowText":"#17ee36","borderColor":"#000000","fontFamily1":"Jura-DemiBold","colTextColor1":"#beb7b7","rowHeight":"19","label3":"Hersteller","imageSize3":"20","padding_right3":"-5"},"style":{"left":"11px","top":"472px","z-index":"900","width":"499px","height":"525px","overflow-y":"hidden"},"widgetSet":"materialdesign"}]
          A Former User @liv-in-sky last edited by
          @liv-in-sky sagte in Script fürTabelle der Batterie Zustände:
          @Elirion
          probiere mal das script im ersten post - deconz sollte funktionieren
          @liv-in-sky Leider immer noch doppelte Einträge:
            liv-in-sky @Guest last edited by
            @Elirion kann es sein, dass du noch eine alte instanz mit diesen werten hast - ich denke- etwas in deinem system ist doppelt
              @liv-in-sky nein ist gelöscht und neue datenpunkte 😉
                @Elirion verstehe ich nicht - ich habe ja deine werte eingespielt und bei mir funktioniert es
                es gibt also keinen deconz.1 oder deconz.2
                das script hat eigentlich keinen grund 2 mal über das selbe zu laufen - es ist ja eine kopie - dann müßten alle namen unter allen kategorien doppelt sein - ist aber nicht der fall
                  @liv-in-sky Nein es gibt nur deconz.0 dort aber für ein Gerät 2 IDs (wegen Luftfeuchte, Temperatur und Luftdruck)
                    @Elirion aber diese id's haben keinen datenpunkt mit ...battery
                    deconz.0.Sensors.10.battery - ist ein sensor - der wird gefunden - wenn der nicht da ist, wird qauch nix gefunden und angezeigt - unter
                    gibt es nur ein battery
                    ds ist ein gerät
                    hast du mal iobroker neugestartet, nicht das der javascript cache ärger macht
                      @Elirion oder zumindest die javascript instanz beendet und wieder gestartet
                        ds ist ein gerät
                        Hierbei geht es allerdings nicht um ID10 sondern um 3,4,5
                        Und diese werden angelegt und haben auch einen battery-Status der dann mit null quittiert ist:
                        Und ja Cache ist geleert und iobroker neugestartet. Macht aber ja wegen dem Bild oben kein Unterschied.
                          darkiop Most Active @liv-in-sky last edited by
                          wie ich die batteriewerte farbig bekomme - kann ich das im json angeben?
                          wie wird das widget aktualisiert
                          warum kann ich keine schrifart wählen
                          Alle 3 sind doch in der Tabelle von @Scrounger Einstellbar? D.h. das json liefert nur die Daten dafür.
                            @Elirion oh man - wieder so ein super adapter - ich habe die unteren datenpunkte gelöscht und dadurch übersehen - sonst bekomme ich zuviele datenpunkte - sorry
                            das ist ein größeres problem - doppelte werte - d.h ich muss die gefundenen datenpunkte speichern und überprüfen ob ich den schon habe - warum schreibt der adapter einen datenpunkt, den er nicht besetzt - da sollte man mal bein adapterhersteller nachfragen - wenn da nix drinsteht, vielleicht kann er ihn dann garnicht schreiben - hast du mal lust, ihn das zu fragen - du kannst ihn auch gerne hierher verweisen - vielleicht gibt es ja eine erklärung dafür, die ich nicht überschaue
                              A Former User @liv-in-sky last edited by A Former User
                              @liv-in-sky Die Antwort kann ich dir bereits geben. Der Deconz-Adapter funktioniert etwas anders als die Zigbee-Adapter. Deconz erstellt für jede "Funktion" je eine ID. Da es bei dem Temperaturmesser 3 Funktionen sind = 3 IDs.
                              Daran bin ich nämlich auch gescheitert. Deconz an sich anlegen hat geklappt aber aus der Tabelle entfernen nicht...
                                liv-in-sky @darkiop last edited by
                                @darkiop sagte in Script fürTabelle der Batterie Zustände:
                                punkt 3 ist gelöst
                                punkt 2 - das widget zeigt nur neue sachen an, wenn ich es im browser refreshe - nicht wenn das script etwas in den datenpunkt schreibt
                                punkt ein - nicht die schriftfarbe soll für alle eingestellt werden sondern wenn im script ein wert bestimmte werte hat sind die rot,grün oder gelb - das muss ich übergeben - aber vielleicht finde ich das in dem adapter script -- da ändert sich ja auch einiges
                                  @Elirion dann musss ich wohl mein script anpassen - ich komme wieder auf dich zurück
                                    @liv-in-sky gern 😉
                                      Ich hab das gerade mal mit dem Log Skript von @Mic getestet - hier aktualisiert sich die Materialdesign-Tabelle nachdem das json aktualisiert wurde. Vielleicht kann @Mic ja helfen.
                                        @Elirion
                                        @Jey-Cee
                                        hallo @Jey-Cee - ich wollte im script deinen adapter einbinden und habe das problem, dass ein sensor durch 2 oder 3 ID's einen battery wert hat (den frage ich ab). es würde also 2 oder 3 mal der selbe sensor auftauchen - dies könnte ich abfangen indem ich im script kontrolliere , ob er schon existiert (common.name) - mein problem ist, dass die battery-werte nur einmal einen state haben und 2 mal keinen - z.b hier zu sehen https://forum.iobroker.net/post/389281
                                        ich generiere aber dadurch eine menge warnings, weil die datenpunkte keinen states haben - ich frage auch reachable ab und da sind alle werte geschrieben - wäre es möglich, die battery werte auch in jede id zu schreiben?
                                          wegen material design - was für ein widget wäre euch den am liebsten ? man muss ja für jedes widget ein eigenes json erzeugen - oder sehe ich das falsch
                                          ich denke, dass icon list widget ist mehr euer ding ?
                                          sigi234 O D 3 Replies Last reply Reply Quote 0
                                            Jupp
                                            javascript monitoring template
                                            67
                                            1379
                                            486900
