    • Nashra
      Nashra Most Active Forum Testing @crunchip last edited by
      @crunchip sagte in [Linux Shell-Skript] WLAN-Wetterstation:
      @Rushmed für die Windrichtung logge ich übrigens noch den Datenpunkt weatherunderground.0.forecast.current.windDirection
      Hey @crunchip , wie hast Du das hinbekommen mit der Regenmenge. Du hattest mir ja mal die Json
      zukommen lassen, aber ich bekomme das wie gesagt nicht mit der Regenmenge hin bzw. geändert.
      Auch will er nicht beim UV Index
        crunchip Forum Testing Most Active @Nashra last edited by crunchip
        @Nashra hier mal das einzelne json nur für Regenmenge
        "datasource": null,
        "gridPos": {
        "h": 4,
        "w": 6,
        "x": 9,
        "y": 8
        "hideTimeOverride": true,
        "id": 5,
        "options": {
        "displayMode": "lcd",
        "orientation": "horizontal",
        "fieldOptions": {
        "values": false,
        "calcs": [
        "lastNotNull"
        "defaults": {
        "min": 0,
        "max": 1200,
        "thresholds": [
        "color": "rgb(15, 31, 171)",
        "value": null
        "mappings": [],
        "unit": "lengthmm"
        "override": {}
        "pluginVersion": "6.5.2",
        "targets": [
        "alias": "Jahr",
        "groupBy": [
        "params": [
        "$__interval"
        "type": "time"
        "params": [
        "null"
        "type": "fill"
        "measurement": "javascript.0.Wetterstation.Regen_Jahr_kumuliert",
        "orderByTime": "ASC",
        "policy": "default",
        "refId": "A",
        "resultFormat": "time_series",
        "select": [
        "params": [
        "value"
        "type": "field"
        "params": [],
        "type": "mean"
        "tags": []
        "alias": "Monat",
        "groupBy": [
        "params": [
        "$__interval"
        "type": "time"
        "params": [
        "null"
        "type": "fill"
        "measurement": "javascript.0.Wetterstation.Regen_Monat",
        "refId": "D",
        "select": [
        "params": [
        "value"
        "type": "field"
        "params": [],
        "type": "mean"
        "tags": []
        "alias": "Woche",
        "groupBy": [
        "params": [
        "$__interval"
        "type": "time"
        "params": [
        "null"
        "type": "fill"
        "measurement": "javascript.0.Wetterstation.Regen_Woche",
        "refId": "B",
        "select": [
        "params": [
        "value"
        "type": "field"
        "params": [],
        "type": "mean"
        "tags": []
        "alias": "Tag",
        "groupBy": [
        "params": [
        "$__interval"
        "type": "time"
        "params": [
        "null"
        "type": "fill"
        "measurement": "javascript.0.Wetterstation.Regen_Tag",
        "refId": "C",
        "select": [
        "params": [
        "value"
        "type": "field"
        "params": [],
        "type": "mean"
        "tags": []
        "timeFrom": "1d",
        "timeShift": null,
        "title": "Regenmenge",
        "transparent": true,
        "type": "bargauge"
        aktuelle view und json ist oben im Beitrag
        Nashra 1 Reply Last reply Reply Quote 1
        • Nashra
          Nashra Most Active Forum Testing @SBorg last edited by
          @SBorg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
          @Nashra 😀 Ich teste erst mal nur Indoor. Muss mir zuerst noch einen "Mast" suchen. Das beiliegende 20cm Rohr ist zwar nett, aber damit komme ich nicht sehr weit.
          Ich habe mir noch ne Halterung für eine Sat-Schüssel geholt Link Text
          und die dann am Hühnerstall montiert 😄
            Meine hab ich an der Terrassenüberdachung mit nem Fahnenmastrohr das übrig war, befestigt
              skokarl @SBorg last edited by
              @SBorg
              Ganz ehrlich, ...... eigentlich ist es schon ein Hammer, dass jemand der keine Wetterstation hat, ein Script dafür schreibt, oder überhaupt schreiben kann. Auf sowas verrücktes muss man erstmal kommen.....😀 😀
              Von daher hast Du sie Dir mehr als verdient. 👍
              ? 1 Reply Last reply Reply Quote 1
                A Former User @skokarl last edited by A Former User
                @skokarl sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                @SBorg
                Genau das sehe ich auch so! Super vielen Dank für den Einsatz!
                Update: So ist sie bei mir installiert, war ne Regen-Aktion diese Woche, musste schnell gehen.. 😉
                crunchip 1 Reply Last reply Reply Quote 2
                • SBorg
                  Hmm, dass macht Lust auf mehr... Interessant was sich im Inneren verbirgt:
                  1: ja, es ist ein ESP 😀
                  2: ja, es ist eine FTDI-Schnittstelle (Brücken für den Flash-Modus sind auch vorhanden)
                  3: (leider) 864 MHz Funkmodul
                  zu 3. (leider): es gibt keine WLAN-Antenne, was eigentlich auch nicht weiter verwunderlich ist. Selbst mit der GoldCap/Solar-Unterstützung wäre bei einem WLAN-Betrieb einfach die Batterielaufzeit zu kurz.
                  Falls die Messdaten ebenfalls an (2) anstehen, könnte man mittels eines ESP-01 die Station direkt WLAN fähig bekommen, ohne einen größeren Umbau durchführen zu müssen. Wäre toll, da mir für mein "Pimp up your weatherstation" sowieso noch Solar und mindestens Luftgüte vorschwebt.
                    @SBorg
                    Du sollst das Ding nicht gleich umprogrammieren ...... 😁
                    einfach nur anschliessen ...... 😀 😀
                    • Glasfaser
                      Glasfaser @skokarl last edited by
                      Dann würde ich aber einen neuen Thread dafür aufmachen 😂
                      SBorg 1 Reply Last reply Reply Quote 1
                      • Glasfaser
                        hat mal jemand ne View
                        Siehe Anfang vom Thread
                          crunchip Forum Testing Most Active @Guest last edited by
                          @ilovegym Der Ostwind geht dir dann aber flöten?
                          Glasfaser ? 2 Replies Last reply Reply Quote 0
                          • Glasfaser
                            Glasfaser @crunchip last edited by
                            Der Mast ist bei ihm Variabel , der fährt dann Nachts aus , damit der Flugbetrieb nicht gestört wird 😎
                            • Nashra
                              Da baut der das Teil erstmal auseinander. @SBorg du bist mir einer 😂
                              • Nashra
                                "datasource": null,
                                "gridPos": {
                                "h": 4,
                                "w": 6,
                                "x": 9,
                                "y": 8
                                "id": 5,
                                "options": {
                                "fieldOptions": {
                                "values": false,
                                "calcs": [
                                "lastNotNull"
                                "defaults": {
                                "min": 0,
                                "max": 1200,
                                "thresholds": [
                                "value": null
                                "mappings": [],
                                "unit": "lengthmm"
                                "override": {}
                                "targets": [
                                "alias": "Jahr",
                                "groupBy": [
                                "params": [
                                "$__interval"
                                "type": "time"
                                "params": [
                                "null"
                                "type": "fill"
                                "refId": "A",
                                "select": [
                                "params": [
                                "value"
                                "type": "field"
                                "params": [],
                                "type": "mean"
                                "tags": []
                                "alias": "Monat",
                                "groupBy": [
                                "params": [
                                "$__interval"
                                "type": "time"
                                "params": [
                                "null"
                                "type": "fill"
                                "refId": "D",
                                "select": [
                                "params": [
                                "value"
                                "type": "field"
                                "params": [],
                                "type": "mean"
                                "tags": []
                                "alias": "Woche",
                                "groupBy": [
                                "params": [
                                "$__interval"
                                "type": "time"
                                "params": [
                                "null"
                                "type": "fill"
                                "refId": "B",
                                "select": [
                                "params": [
                                "value"
                                "type": "field"
                                "params": [],
                                "type": "mean"
                                "tags": []
                                "alias": "Tag",
                                "groupBy": [
                                "params": [
                                "$__interval"
                                "type": "time"
                                "params": [
                                "null"
                                "type": "fill"
                                "refId": "C",
                                "select": [
                                "params": [
                                "value"
                                "type": "field"
                                "params": [],
                                "type": "mean"
                                "tags": []
                                "timeFrom": "1d",
                                "timeShift": null,
                                "type": "bargauge"
                                Irgendwie stehe ich heute auf dem Schlauch, wie bekomme ich das ausgetauscht?
                                Glasfaser crunchip 2 Replies Last reply Reply Quote 0
                                • Glasfaser
                                  Glasfaser @Nashra last edited by Glasfaser
                                  @Nashra
                                  Das Dashboard Json von crunchip klappte auf anhieb , brauchte nur die influxdb anwählen wo ich es Importiert habe .
                                  No Date würde bei dir heißen , das nichts in Influx geloggt ist bei den Datenpunkten .
                                  Hier der Screenshot von der Regenmenge :
                                  @crunchip kannst du es als Textdatei hinterlegen
                                    crunchip Forum Testing Most Active @Glasfaser last edited by crunchip
                                    @Glasfaser @Nashra hier als Textdatei. Datenpunkte sind alle Original gelassen, wie auch im Script, also javascript.0.Wetterstation.xyz
                                    Regenmenge.txt
                                      @Nashra willst du die ganze View oder nur Regen austauschen?
                                      Glasfaser Nashra 2 Replies Last reply Reply Quote 0
                                      • Glasfaser
                                        @crunchip
                                        Bei mir passt es .... war nur für @Nashra
                                        • Nashra
                                          Bitte die ganze View, habe mir gerade alles zerschossen 🙄
                                            @Nashra allerdings sind in dieser View zusätzliche plugins, die benötigt werden
                                            • Boom Theme (Oben rechts im Dashboard)...ist für Hindergrund
                                            • Bar Gauge
                                            • Windrose
                                            • Table
                                            • Singlestat
                                            • Graph
                                            Wetterstation mit Hintergrund.txt
                                            Glasfaser S Nashra 3 Replies Last reply Reply Quote 5
                                            150
                                            5650
                                            3547506
