    • Nashra
      Da baut der das Teil erstmal auseinander. @SBorg du bist mir einer 😂
      • Nashra
        Nashra Most Active Forum Testing @crunchip last edited by
        @crunchip sagte in [Linux Shell-Skript] WLAN-Wetterstation:
        @Nashra hier mal das einzelne json nur für Regenmenge
        "datasource": null,
        "gridPos": {
        "h": 4,
        "w": 6,
        "x": 9,
        "y": 8
        "hideTimeOverride": true,
        "id": 5,
        "options": {
        "displayMode": "lcd",
        "orientation": "horizontal",
        "fieldOptions": {
        "values": false,
        "calcs": [
        "lastNotNull"
        "defaults": {
        "min": 0,
        "max": 1200,
        "thresholds": [
        "color": "rgb(15, 31, 171)",
        "value": null
        "mappings": [],
        "unit": "lengthmm"
        "override": {}
        "pluginVersion": "6.5.2",
        "targets": [
        "alias": "Jahr",
        "groupBy": [
        "params": [
        "$__interval"
        "type": "time"
        "params": [
        "null"
        "type": "fill"
        "measurement": "javascript.0.Wetterstation.Regen_Jahr_kumuliert",
        "orderByTime": "ASC",
        "policy": "default",
        "refId": "A",
        "resultFormat": "time_series",
        "select": [
        "params": [
        "value"
        "type": "field"
        "params": [],
        "type": "mean"
        "tags": []
        "alias": "Monat",
        "groupBy": [
        "params": [
        "$__interval"
        "type": "time"
        "params": [
        "null"
        "type": "fill"
        "measurement": "javascript.0.Wetterstation.Regen_Monat",
        "refId": "D",
        "select": [
        "params": [
        "value"
        "type": "field"
        "params": [],
        "type": "mean"
        "tags": []
        "alias": "Woche",
        "groupBy": [
        "params": [
        "$__interval"
        "type": "time"
        "params": [
        "null"
        "type": "fill"
        "measurement": "javascript.0.Wetterstation.Regen_Woche",
        "refId": "B",
        "select": [
        "params": [
        "value"
        "type": "field"
        "params": [],
        "type": "mean"
        "tags": []
        "alias": "Tag",
        "groupBy": [
        "params": [
        "$__interval"
        "type": "time"
        "params": [
        "null"
        "type": "fill"
        "measurement": "javascript.0.Wetterstation.Regen_Tag",
        "refId": "C",
        "select": [
        "params": [
        "value"
        "type": "field"
        "params": [],
        "type": "mean"
        "tags": []
        "timeFrom": "1d",
        "timeShift": null,
        "title": "Regenmenge",
        "transparent": true,
        "type": "bargauge"
        aktuelle view und json ist oben im Beitrag
        Irgendwie stehe ich heute auf dem Schlauch, wie bekomme ich das ausgetauscht?
        Glasfaser crunchip 2 Replies Last reply Reply Quote 0
        • Glasfaser
          Glasfaser @Nashra last edited by Glasfaser
          @Nashra
          Das Dashboard Json von crunchip klappte auf anhieb , brauchte nur die influxdb anwählen wo ich es Importiert habe .
          No Date würde bei dir heißen , das nichts in Influx geloggt ist bei den Datenpunkten .
          Hier der Screenshot von der Regenmenge :
          @crunchip kannst du es als Textdatei hinterlegen
            crunchip Forum Testing Most Active @Glasfaser last edited by crunchip
            @Glasfaser @Nashra hier als Textdatei. Datenpunkte sind alle Original gelassen, wie auch im Script, also javascript.0.Wetterstation.xyz
            Regenmenge.txt
              crunchip Forum Testing Most Active @Nashra last edited by
              @Nashra willst du die ganze View oder nur Regen austauschen?
              Glasfaser Nashra 2 Replies Last reply Reply Quote 0
              • Glasfaser
                Glasfaser @crunchip last edited by
                @crunchip
                Bei mir passt es .... war nur für @Nashra
                • Nashra
                  Bitte die ganze View, habe mir gerade alles zerschossen 🙄
                    crunchip Forum Testing Most Active @Nashra last edited by crunchip
                    @Nashra allerdings sind in dieser View zusätzliche plugins, die benötigt werden
                    • Boom Theme (Oben rechts im Dashboard)...ist für Hindergrund
                    • Bar Gauge
                    • Windrose
                    • Table
                    • Singlestat
                    • Graph
                    Wetterstation mit Hintergrund.txt
                    Glasfaser S Nashra 3 Replies Last reply Reply Quote 5
                    • Glasfaser
                      Glasfaser @crunchip last edited by Glasfaser
                      @crunchip
                      Das sieht mal Geil aus 😎
                      Wie schaltet man den Hintergrund ein , habe gerade einen neuen Import von "Wetterstation mit Hintergrund " der Hintergrund ist schwarz
                        @Glasfaser https://grafana.com/grafana/plugins/yesoreyeram-boomtheme-panel
                        sieht dann so aus, Neues Thema "Wetterstation" hinzugefügt, custom Style vom Night Theme hinein kopiert.
                        Pfad der Bilder(die müssen selbst ausgesucht und reinkopiert werden), siehe
                        bild der View
                        hier noch ein paar andere
                        bilder-wetterstation.zip
                        Glasfaser 1 Reply Last reply Reply Quote 3
                          skokarl @crunchip last edited by
                          @crunchip
                          super geil
                          • Glasfaser
                            😭 Nächste Baustelle
                            Das Problem ist ... Grafana ist im Synology Docker da habe ich kein Zugriff auf den Ordner 🤔
                            Aber ist nicht so wichtig ... ´werde es nach Zeiten herrausfinden
                              @Glasfaser der Pfad sollte ja keine Rolle spielen, kannst du auch woanders ablegen. Genauso geht ja auch z.b. ein http Link, den du einbinden kannst. Gibt ja mehrere Möglichkeiten
                              Glasfaser 1 Reply Last reply Reply Quote 1
                              • Glasfaser
                                Danke trotzdem ,rennt nicht weg 😉
                                  A Former User @crunchip last edited by
                                  @ilovegym Der Ostwind geht dir dann aber flöten?
                                  Ja, noch, war ne schnelle Kabelbinder Montage bei Regenwetter 🙈🙈🤣🤣
                                  Die bleibt da nicht.
                                  • SBorg
                                    SBorg Forum Testing Most Active @Glasfaser last edited by
                                    @Glasfaser sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                    @SBorg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                    Wäre toll, da mir für mein "Pimp up your weatherstation"
                                    Dann würde ich aber einen neuen Thread dafür aufmachen 😂
                                    Hehehe...+ klick 😂
                                    @Nashra sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                                    Besser als wenn sie schon montiert ist 😇 😁
                                      rollerfreak2 last edited by
                                      Hi zusammen, ich bin der Anleitung gefolgt und soweit funktioniert auch alles, bis auf den cronjob. Mein IoBroker läuft in einem Docker Container auf meinem Synology DS218+. Das mit dem cronjob läuft aber irgendwie nicht. Kann es sein das dass @reboot im Docker nicht funktioniert? So sieht mein cronjob aus (crontab -l)
                                      @reboot /opt/iobroker/wetterstation.sh &
                                      2 0 * * * pkill -9 wetterstation.* && /opt/iobroker/wetterstation.sh &
                                      Wenn ich das hier in der Console setze klappt die Übertragung. Ich schaffe es aber nicht das als cronjob zu konfiguieren.
                                      setsid /opt/iobroker/wetterstation.sh > /dev/null 2>&1 < /dev/null
                                      Hat jemand eine Idee was ich falsch mache? Hinweis ich musste vorher im docker auch erst crontab installieren (apt install cron), das fand ich etwas komisch, ist das nicht immer mit dabei? Als Container verwende ich "buanet/iobroker:latest"
                                      SBorg Glasfaser 2 Replies Last reply Reply Quote 0
                                      • SBorg
                                        SBorg Forum Testing Most Active @rollerfreak2 last edited by
                                        @rollerfreak2 Hi, so wie ich das lese, musst du noch den User bei der Synology hinzufügen:
                                        @reboot root /opt/iobroker/wetterstation.sh &
                                        2 0 * * * root pkill -9 wetterstation.* && /opt/iobroker/wetterstation.sh &
                                        Quelle
                                        "reboot" kennt sie auch 🙂
                                        • Nashra
                                          Nashra Most Active Forum Testing @crunchip last edited by Nashra
                                          • Bar Gauge
                                          • Windrose
                                          • Table
                                          • Singlestat
                                          • Graph
                                          Hallo @crunchip erstmal Danke für View.
                                          Habe es soweit alles hinbekommen aber einige Sachen wollen einfach nicht
                                          d.h. ich kann einstellen was ich will, es werden keine Daten (rot) angezeigt.
                                          Vllt weißt Du ja woran es liegen könnte, mir fällt im Moment nichts ein 😞
                                            rollerfreak2 @SBorg last edited by
                                            @SBorg geht leider auch nicht.
                                            152
                                            5661
                                            3771884
