    4. Test Adapter rtspStream v0.0.x GitHub
      Kuddel @el_malto last edited by
      @el_malto magst du von deinem Widget mal einen xport zur Verfügung stellen ?
        el_malto @Kuddel last edited by
        @Kuddel wie gesagt, ist das standard "basic - image" Widget.
        [{"tpl":"tplImage","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"http://192.168.0.20:8080/mjpegfeed?oid=1&size=1280x720"},"style":{"left":"609px","top":"0px","width":"415px","height":"233px"},"widgetSet":"basic"}]
          @el_malto also der Link, den du im Widget verwendest funktioniert.
          Das Widget selber zeigt leider nichts an.
            @Kuddel der Link? Das ist der Link von meiner Cam bzw. der Link von iSpy. Wäre ja Zufall wenn du auch iSpy und die gleiche IP benutzt...🤷‍♂️
              @el_malto ich habe die IP und den Port auf die Adresse vom RTSP Adapter geändert
                @Kuddel achso. Dann liegt es wohl auch daran welches Programm den Stream erzeugt.
                  Hat schon jemand eine Lösung, wie man den Stream vernünftig ohne Scroll-Balken einbinden kann ?
                  Stream = http://192.168.4.31:8086/
                    daniel_iobroker last edited by
                    Hab mir heute auch den Adapter installiert. Zuerst natürlich noch das "ffmpeg"
                    Das ganze am Raspi 4.
                    Habe dann meinen rtsp link eingetragen (inkl. Username / Passwort). Der Adapter gibt auch keinen Fehler aus.
                    Wenn ich aber dann meinen Stream mit der IoBroker IP + Port aufrufen will, kommt nur ein Seiten-Ladefehler
                    Hab ich hier noch was falsch eingestellt? Der rtsp Link funktioniert zumindest im VLC Player ohne Probleme
                    Hier die Einstellungen vom Adapter:
                    Hier das log, nach einem Neustart vom Adapter:
                      skokarl @daniel_iobroker last edited by
                      @daniel_iobroker
                      Du kannst keinen RTSP Stream mit User/Pass im Browser ausgeben, lässt der Browser nicht zu.
                      VLC ist ja ein Programm, da sieht das anders aus.
                      Der RTSP Stream muss umgewandelt werden, z.b. mit MotionEye
                      D werner2000x 2 Replies Last reply Reply Quote 0
                        daniel_iobroker @skokarl last edited by
                        @skokarl
                        Das war mir bewusst, dass der Browser User/Pass nicht mehr unterstützt. Ich dachte aber, dass genau dafür der Adapter da ist? Das der Adapter quasi den Stream mit User/Pass von der CAM abholt und dann ohne Authentifizierung weitergibt.
                        Den umgewandelten Stream kann ich ja sowieso in der VIS nutzen. Geht bei mir zumindest ohne Probleme. Egal ob mit MotionEye oder Zoneminder.
                        dbweb 1 Reply Last reply Reply Quote 0
                        • dbweb
                          dbweb @daniel_iobroker last edited by
                          @daniel_iobroker Wie hast du dies dann im Browser aufgerufen?
                          Du musst die Adresse mit Port 8087 aufrufen, also z.B.
                          http://192.168.1.1:8087/
                            daniel_iobroker @dbweb last edited by
                            @dbweb
                            Richtig. Genau so habe ich die Adresse im Browser aufgerufen. Natürlich mit meiner IP und meinem eingestellten Port
                              Balu0127 last edited by
                              Hallo
                              Kann man den Adpater rtsp auch installieren wenn man Windows nutzt?
                              • JackDaniel
                                JackDaniel last edited by
                                wie bekomme ich diesen adapter nun wieder sauber deinstalliert?
                                • dbweb
                                  dbweb @Balu0127 last edited by
                                  @Balu0127 Leider nicht, ffmpeg kann da nicht so benutzt werden.
                                  @JackDaniel Das schaut für mich nicht aus, als ob diese Meldung wegen dem Adapter kommt, ich würde ioBroker mal sauber neu starten und dann nochmals probieren.
                                  • JackDaniel
                                    JackDaniel last edited by JackDaniel
                                    hmm ja das war auch mein erster gedanke, brachte nur nichts 😞
                                    auch ein sudo rm -r /opt/iobroker/node_modules/iobroker.rtspStream bringt nicht wirklich etwas, da nach einem restart alles wieder da ist!
                                    Bin für jede Hilfe dankbar wie ich das wieder los werde.
                                    • Endurance
                                      Endurance last edited by
                                      @dbweb
                                      Hab nun auch ein bisschen rumgetestet, inkl. reinstall ffmpeg usw.
                                      Mehr bring ich aktuell, egal mit welchen Settings auch nicht hin:
                                      Noch irgendwelche Ideen / Ansätze?
                                        Steffengr last edited by
                                        Hallo in die Runde,
                                        ich konnte den Adapter installieren und meine Kamera anbinden. Nach einem Tastendruck auf "startStream" wird auch ein Stream erzeugt, welcher im Browser unter der entsprechenden Adresse aufgerufen werden kann.
                                        Was mir noch unklar ist, bzw. was aus meiner Sicht noch angepasst werden müsste:
                                        1. Der Datenpunkt "startStream" direkt unter dem Adapter steht immer auf "false". Man kann also den Stream nicht stoppen. Eintragungen haben keine Auswirkungen.
                                        2. In der Adapterkonfiguration kann man die eingebundenen Kameras nicht editieren. Man muss die Kamera löschen und neu konfigurieren.
                                        Viele Grüße
                                        Steffen
                                          Noch eine Frage:
                                          Wie kann ich den Stream in VIS vernüftig einbinden? Ich nutze die Vorlage von Kudel. Dort gibt es in der Übersicht ein Vorschaubild und wenn man darauf klickt geht ein Fenster auf mit dem Stream. Das läuft nicht. Ich kann nur ein Iframe nehmen wo der Stream läuft. Habt Ihr Vorschläge?
                                          Danke und Gruß
                                          Steffen
                                            bob der 1. @JackDaniel last edited by bob der 1.
                                            @JackDaniel
                                            Das gleiche bei mir....auf dem Test syst.
                                            ich mach da nie lange rum....Backup drüber und fertig....ist ja eh ein Alpha Adapter...
                                            und das sollte jeder gelesen haben ....
                                            Post 1
                                            Achtung: Das ist wirklich "pre-Alpha", kann z.B. euer System stark auslasten, sollte es aber nicht gleich zerstören... ich übernehme aber keine Haftung
                                            Fertig mit Fehler: Commands:iobroker setup [--objects ] [--states ] [custom]iobroker start - starts the js-controlleriobroker stop - stops the js-controlleriobroker start [.instance] - starts a specified adapter instanceiobroker stop .[instance] - stops a specified adapter instanceiobroker start all - starts js-controller and all adaptersiobroker restart - restarts the js-controlleriobroker restart [.instance] - restarts a specified adapteriobroker debug [--ip=] [--port=] [--wait] - Starts a Node.js debugging session for the adapter --wait stops the execution until the debugger is attached. --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.iobroker info - shows the host infoiobroker logs [adapter] [--watch] [--lines=1000]iobroker add [desiredNumber] [--enabled] [--host ] [--port ]iobroker install - installs a specified adapteriobroker rebuild |self [--install]iobroker url [] - install adapter from specified url, e.g. GitHubiobroker del - remove adapter from systemiobroker del . - remove adapter instanceiobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash checkiobroker upgrade [repository url]iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository urliobroker upgrade [repository url] - upgrade specified adapter, optionally you can specify the repository urliobroker upload iobroker upload all - upload all adapter files to make them available for instancesiobroker upload - upload specified adapter files to make them available for instancesiobroker object get - get object specified by idiobroker object set - set object with the given id by providing a new json objectiobroker object set propertyname= - update part of the object by providing a new value or partial objectiobroker object extend - extend object with the given id by providing a new json objectiobroker object del [--yes]iobroker object chmod [state-mode] iobroker object chown iobroker object list iobroker state get - get state, specified by idiobroker state getplain [--pretty]iobroker state getvalue iobroker state set [ack]iobroker state del iobroker message [.instance] []iobroker list [filter]iobroker chmod iobroker chown iobroker touch iobroker rm iobroker file read []iobroker file write iobroker file rm iobroker file synciobroker user add [--ingroup group] [--password pass]iobroker user del iobroker user passwd [--password pass]iobroker user enable iobroker user disable iobroker user get iobroker user check [--password pass]iobroker group add iobroker group del iobroker group list iobroker group enable iobroker group disable iobroker group get iobroker group adduser iobroker group deluser iobroker host thisiobroker host iobroker host set iobroker host remove iobroker set . [--port port] [--ip address] [--ssl true|false]iobroker license iobroker cert createiobroker cert view []iobroker cleaniobroker backupiobroker restore - restore a specified backupiobroker validate - validate a specified backupiobroker --timeout 5000iobroker status [all|.]iobroker repo [name]iobroker repo add iobroker repo set iobroker repo del iobroker uuidiobroker unsetupiobroker fix - execute the installation fixer script, this updates your ioBroker installationiobroker multihost [--secure true|false]iobroker multihost browseiobroker multihost connectiobroker compact status - show if compact mode is enabled in generaliobroker compact - enable or disable compact mode in generaliobroker compact . status - show if compact mode is enabled for a specific instanceiobroker compact . group - define compact group of a specific adapteriobroker compact . - enable or disable compact mode for specified adapter instanceiobroker compact . [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionallyiobroker plugin enable [--host ] - enables a plugin for the specified host. If no host is specified, the current one is usediobroker plugin disable [--host ] - disables a plugin for the specified host. If no host is specified, the current one is usediobroker plugin status [--host ] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is usediobroker plugin enable --instance [.] - enables a plugin for the specified adapter instance (defaults to instance 0)iobroker plugin disable --instance [.] - disables a plugin for the specified adapter instance (defaults to instance 0)iobroker plugin status --instance [.] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)iobroker version [adapter] - show version of js-controller or specified adapteriobroker [adapter] -v - show version of js-controller or specified adapterOptions: --help Show help [boolean] --version Show version number [boolean]
                                            31.7k
                                            79.8k
                                            rtsp stream
                                            36
                                            157
                                            18651
