    4. [Vorlage] Vis für Adapter HeatingControl
    • O
      Oli @Pittini last edited by
      @Pittini
      ich habe das Script und den Adapter neu installiert, nun bekomme folgende Fehlermeldung:
      heatingcontrol.0	2020-03-11 18:22:02.139	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.138	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.137	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.136	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.135	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.134	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.133	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.132	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.131	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.130	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.129	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.128	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.127	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.126	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.125	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.124	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.123	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.122	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:22:02.121	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
      heatingcontrol.0	2020-03-11 18:21:59.099	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.098	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.097	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.096	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.095	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.094	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.093	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.092	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.091	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.090	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.089	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.088	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.087	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.086	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.085	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.084	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.083	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.082	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.081	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:59.069	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
      heatingcontrol.0	2020-03-11 18:21:58.841	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.840	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.839	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.838	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.837	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.836	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.835	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.834	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.833	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.832	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.831	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.830	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.829	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.828	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.827	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.826	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.825	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.810	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
      heatingcontrol.0	2020-03-11 18:21:58.614	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
      heatingcontrol.0	2020-03-11 18:21:58.613	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
      heatingcontrol.0	2020-03-11 18:21:58.612	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
      heatingcontrol.0	2020-03-11 18:21:58.611	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
      heatingcontrol.0	2020-03-11 18:21:58.610	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
      heatingcontrol.0	2020-03-11 18:21:58.609	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
      heatingcontrol.0	2020-03-11 18:21:58.608	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
      heatingcontrol.0	2020-03-11 18:21:58.607	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
      heatingcontrol.0	2020-03-11 18:21:58.606	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
      heatingcontrol.0	2020-03-11 18:21:58.605	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
      heatingcontrol.0	2020-03-11 18:21:58.604	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
      heatingcontrol.0	2020-03-11 18:21:58.603	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
      heatingcontrol.0	2020-03-11 18:21:58.602	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
      heatingcontrol.0	2020-03-11 18:21:58.601	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
      • Uhula
        Uhula @Pittini last edited by
        @Pittini Bisher war es so, wenn die Schaltflächen zum Öffnen der linken/rechten Nav im MD CSS v2 nicht funktionieren, dass dann der 2-Jahre alte Material Design Adapter installiert ist. Der stört, da in diesem die MD CSS v1.8 enthalten ist. Dann kämpfen beide um die klick-Events.
          Pittini Developer @Oli last edited by
          @Oli sagte in [Vorlage] Vis für Adapter HeatingControl:
          Der Fehler kommt vom HeatingControl, da bitte an @Rene_HM wenden, Das Skript sollte erst gestartet werden wenn der Adapter auch sauber läuft, nicht dass es da iwelche Interferenzen gibt.
          • O
            @Pittini
            im Script kommen aber auch viele Warnungen
            18:42:48.132	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:288:79)
            18:42:48.132	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.132	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.134	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:288:17)
            18:42:48.135	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.135	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.137	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:290:79)
            18:42:48.137	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.138	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.139	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:290:17)
            18:42:48.140	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.140	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.143	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:288:79)
            18:42:48.143	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.144	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.147	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:288:17)
            18:42:48.147	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.147	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.150	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:290:79)
            18:42:48.150	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.150	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.153	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:290:17)
            18:42:48.153	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.153	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.157	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:288:79)
            18:42:48.157	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.157	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.163	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:288:17)
            18:42:48.163	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.163	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.166	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:290:79)
            18:42:48.166	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.166	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.169	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:290:17)
            18:42:48.169	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.169	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.172	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:288:79)
            18:42:48.173	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.173	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.175	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:288:17)
            18:42:48.175	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.176	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.178	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:290:79)
            18:42:48.178	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.179	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.181	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:290:17)
            18:42:48.181	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.181	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.184	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:288:79)
            18:42:48.185	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.185	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.187	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:288:17)
            18:42:48.187	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.188	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.190	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:290:79)
            18:42:48.190	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.190	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.192	warn	javascript.0 (5570) at SetVis (script.js.Gewerke.Heizpläne_Test:290:17)
            18:42:48.192	warn	javascript.0 (5570) at main (script.js.Gewerke.Heizpläne_Test:172:5)
            18:42:48.197	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:158:13)
            18:42:48.468	info	javascript.0 (5570) script.js.Gewerke.Heizpläne_Test: Reaching SetTimeTempValue
            18:42:48.468	info	javascript.0 (5570) script.js.Gewerke.Heizpläne_Test: SetTimeTempValue: heatingcontrol.0.Profiles.2.Wohnzimmer.Tue.Periods.4time - 23:20
            18:42:48.470	warn	javascript.0 (5570) at SetTimeTempValue (script.js.Gewerke.Heizpläne_Test:235:9)
            18:42:48.491	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:476:49)
            18:42:48.501	info	javascript.0 (5570) script.js.Gewerke.Heizpläne_Test: Reaching SetTimeTempValue
            18:42:48.502	info	javascript.0 (5570) script.js.Gewerke.Heizpläne_Test: SetTimeTempValue: heatingcontrol.0.Profiles.2.Wohnzimmer.Wed.Periods.4time - 23:20
            18:42:48.503	warn	javascript.0 (5570) at SetTimeTempValue (script.js.Gewerke.Heizpläne_Test:235:9)
            18:42:48.503	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:482:49)
            18:42:48.546	info	javascript.0 (5570) script.js.Gewerke.Heizpläne_Test: Reaching SetTimeTempValue
            18:42:48.547	info	javascript.0 (5570) script.js.Gewerke.Heizpläne_Test: SetTimeTempValue: heatingcontrol.0.Profiles.2.Wohnzimmer.Sat.Periods.4time - 23:20
            18:42:48.551	warn	javascript.0 (5570) at SetTimeTempValue (script.js.Gewerke.Heizpläne_Test:235:9)
            18:42:48.551	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:500:49)
            18:42:48.568	info	javascript.0 (5570) script.js.Gewerke.Heizpläne_Test: Reaching SetTimeTempValue
            18:42:48.569	info	javascript.0 (5570) script.js.Gewerke.Heizpläne_Test: SetTimeTempValue: heatingcontrol.0.Profiles.2.Wohnzimmer.Sun.Periods.4time - 23:20
            18:42:48.572	warn	javascript.0 (5570) at SetTimeTempValue (script.js.Gewerke.Heizpläne_Test:235:9)
            18:42:48.572	warn	javascript.0 (5570) at Object.<anonymous> (script.js.Gewerke.Heizpläne_Test:506:49)
              Naja, solang der Adapter nicht sauber läuft und evtl. nicht alle DAtenpunkte da sind lass das Skript aus. Nen paar Warnungen wären ok (da bin ich schon dran) aber das da oben deutet drauf hin dass da ne komplette Struktur nicht gefunden wird.
              Beliar_666 1 Reply Last reply Reply Quote 0
              • Beliar_666
                Beliar_666 @Pittini last edited by
                @Pittini @Uhula Wie genau heisst denn der Adapter der nicht da sein darf?
                • Beliar_666
                  Beliar_666 @Beliar_666 last edited by Beliar_666
                  @Pittini @Uhula Fehler gefunden. Nicht nur der Material Designadapter von vor 2 Jahren macht ärger, auch der Material Design Widgets Adapter von @Scrounger macht hier ärger. Nun Frag ich mich allerdings wessen Materialdesign nun das richtige ist. Denn Scrounger schreibt in seinem Adapter das er nach den Google's material design guidelines basiert. Nachdem ich den nun eliminiert habe läuft die View. Zum Glück habe ich von dem Adapter nur 2 Slider verwendet.
                  O Uhula 2 Replies Last reply Reply Quote 0
                  • O
                    Oli @Beliar_666 last edited by
                    @Beliar_666
                    ist aber ein cooler Adapter, ich verwende den oft.
                    @Pittini
                    irgendwie werden im Fensterstatus bei mir keine Bilder angezeigt, woran könnte das denn liegen?
                      Falscher Pfad.
                      Du hast das Projekt vermutlich nicht HeatingControl (in genau dieser Schreibweise) genannt wie in der Anleitung gefordert. Da der Projektname auch gleichzeitig der Pfadname zum Projekt ist und die Bilder sowie der MaterialFont dort im Unterordner Images liegen findet er das dann nicht mehr.
                      Lösung1 - das Projekt HeatingControl nennen.
                      Lösung2 - Im Skript Zeile 8 und 9 die Pfade anpassen und im CSS Zeile 21 + 24 +25 die Pfade anpassen.
                      • Uhula
                        Uhula @Beliar_666 last edited by
                        @Beliar_666 Eine richtige und falsche Material Design Darstellung gibt es nicht. Beide haben aber vollkommen andere Absätze. Während es sich beim MD Adapter um eigene Widgets handelt, werden beim MD CSS nur die Basiswidgets verwendet und zeichnen sich lediglich im MD Design Jeder muss für sich entscheiden, was er benötigt und womit er besser klar kommt. Ich werde dazu keine Bewertung abgeben, da ich den MD Adapter nicht kenne.
                          Pittini Developer last edited by
                          Für alle welche Probleme mit dem großen Projekt haben bzw. das ganze in Ihr eigenes Projekt einfügen möchten:
                          ZusatzView:
                          Vis-Simple-HeatingControl.txt enthält alle relevanten Elemente um die Funktionalität in eigene Projekte integrieren zu können. Es entfällt dadurch jedoch Responsive Design, Farbeinstellungen, klappbare Cards, etc.
                          Die einzelnen Element-Blöcke sind gruppiert und haben die gleiche Funktionalität wie das große Projekt, es wurden jedoch alle Verweise auf MaterialDesign und relativen Größenangaben entfernt. Um die Optik müßt Ihr Euch hier selber kümmern. Die Textdatei ist via "Widgets Importieren" einzufügen. Wer das große Projekt verwendet braucht diese Datei NICHT.
                          O 1 Reply Last reply Reply Quote 2
                          • O
                            @Pittini
                            hast du die Vis vergessen mit dran zu hängen, oder wo finde ich die?
                              sigi234 Forum Testing Most Active @Oli last edited by
                              @Pittini
                              Auf Github
                              • O
                                Oli @sigi234 last edited by
                                @sigi234
                                • Beliar_666
                                  Also ich hab es als komplettes bei mir integriert. Und mittlerweile passt es auch alles und funktioniert soweit auch Fehlerfrei. Da meine neue Vis eh auf dem Inventwo aufbaut, kann ich bestens auf die Material Adapter verzichten.
                                  Einzig die Textgrösse haut so nicht ganz so hin...
                                  P Uhula 2 Replies Last reply Reply Quote 0
                                    Pittini Developer @Beliar_666 last edited by Pittini
                                    @Beliar_666 sagte in [Vorlage] Vis für Adapter HeatingControl:
                                    Betrifft wie ich das sehe ja vorallem den Profilparam Bereich weil Du das Fenster kleiner gemacht hast als in der Vorlage. Sollte aber bei diesen Beschreibungstexten kein Problem sein einfach bei Fontsize z.B. 14px einzugeben (geht, habs grad probiert). Nur die Gruppen nicht auflösen dazu, sondern mit doppelklick in den Gruppen editmode. Texte markieren, Fontsize 14px und gut is. Aber Achtung, da liegen zwei Gruppen übereinander, einmal mit den Texten für relative und einmal die Texte für absolute, mußt natürlich die richtige oder beide ändern. Alternativ kannste natürlich auch die Definition in der CSS für mdui-label verändern, dann nehmen das alle Labels mit.
                                    • Uhula
                                      @Beliar_666 Info: Früher (v1.8) war die "font-size:0.8em;" für "mdui-label" im MDCSS. Die habe ich auf "1em" angepasst, damit bessere Bündigkeiten mit valies/selects/buttons usw. erreicht werden. Wenn @Pittini noch für "0.8em" entworfen hat, sind sie nun u.U. zu "groß".
                                      Beliar_666 1 Reply Last reply Reply Quote 1
                                      • Beliar_666
                                        Beliar_666 @Uhula last edited by Beliar_666
                                        @Uhula @Pittini ist das dann die Stelle wo ich ändern muss?
                                        .mdui-label {
                                          z-index:2;
                                          color:var(--design-font-color);
                                          font-weight:normal !important;
                                          font-size:1em;
                                          text-shadow:none !important;
                                          letter-spacing: 0px !important;
                                          width:auto;
                                          height:auto;
                                          opacity:0.87;
                                        • Beliar_666
                                          Ok, der Wert alleine nützt nichts. Siehe Screen. Hatte jetzt mal auf 0.8em geändert.
                                          jetzt habe ich es. mdui-label, mdui-select und mdui-title auf Werte unter 1 und es passt bei mir.
                                          Rückmeldung zur Gesamtfunktionalität:
                                          Die Vis funktioniert einwandfrei. Fehler treten nur auf wenn eben die 2 erwähnten Material Design Adapter installiert sind. Perfekte funktionelle ergänzung zum Heating Control Adapter!
                                          • Stephan Schleich
                                            Stephan Schleich last edited by
                                            Weiß jemand was das zu bedeuten hat?
                                            17:14:21.176	warn	javascript.0 (3622) at SetVis (script.js.common.HeatingControlMapper:291:79)
                                            17:14:21.176	warn	javascript.0 (3622) at main (script.js.common.HeatingControlMapper:176:5)
                                            17:14:21.177	warn	javascript.0 (3622) at Object.<anonymous> (script.js.common.HeatingControlMapper:162:13)
                                            17:14:21.178	warn	javascript.0 (3622) at SetVis (script.js.common.HeatingControlMapper:291:17)
                                            17:14:21.179	warn	javascript.0 (3622) at main (script.js.common.HeatingControlMapper:176:5)
                                            17:14:21.179	warn	javascript.0 (3622) at Object.<anonymous> (script.js.common.HeatingControlMapper:162:13)
                                            17:14:21.181	warn	javascript.0 (3622) at SetVis (script.js.common.HeatingControlMapper:293:79)
                                            17:14:21.181	warn	javascript.0 (3622) at main (script.js.common.HeatingControlMapper:176:5)
                                            17:14:21.181	warn	javascript.0 (3622) at Object.<anonymous> (script.js.common.HeatingControlMapper:162:13)
                                            17:14:21.186	warn	javascript.0 (3622) at SetVis (script.js.common.HeatingControlMapper:293:17)
                                            17:14:21.187	warn	javascript.0 (3622) at main (script.js.common.HeatingControlMapper:176:5)
                                            17:14:21.187	warn	javascript.0 (3622) at Object.<anonymous> (script.js.common.HeatingControlMapper:162:13)
                                            17:14:21.190	warn	javascript.0 (3622) at SetVis (script.js.common.HeatingControlMapper:291:79)
                                            17:14:21.190	warn	javascript.0 (3622) at main (script.js.common.HeatingControlMapper:176:5)
                                            17:14:21.190	warn	javascript.0 (3622) at Object.<anonymous> (script.js.common.HeatingControlMapper:162:13)
                                            17:14:21.192	warn	javascript.0 (3622) at SetVis (script.js.common.HeatingControlMapper:291:17)
                                            17:14:21.192	warn	javascript.0 (3622) at main (script.js.common.HeatingControlMapper:176:5)
                                            17:14:21.192	warn	javascript.0 (3622) at Object.<anonymous> (script.js.common.HeatingControlMapper:162:13)
                                            17:14:21.194	warn	javascript.0 (3622) at SetVis (script.js.common.HeatingControlMapper:293:79)
                                            17:14:21.195	warn	javascript.0 (3622) at main (script.js.common.HeatingControlMapper:176:5)
                                            17:14:21.195	warn	javascript.0 (3622) at Object.<anonymous> (script.js.common.HeatingControlMapper:162:13)
                                            17:14:21.197	warn	javascript.0 (3622) at SetVis (script.js.common.HeatingControlMapper:293:17)
                                            17:14:21.197	warn	javascript.0 (3622) at main (script.js.common.HeatingControlMapper:176:5)
                                            17:14:21.197	warn	javascript.0 (3622) at Object.<anonymous> (script.js.common.HeatingControlMapper:162:13)
                                            17:14:21.200	warn	javascript.0 (3622) at SetVis (script.js.common.HeatingControlMapper:319:56)
                                            17:14:21.200	warn	javascript.0 (3622) at main (script.js.common.HeatingControlMapper:176:5)
                                            17:14:21.200	warn	javascript.0 (3622) at Object.<anonymous> (script.js.common.HeatingControlMapper:162:13)
                                            17:14:21.202	warn	javascript.0 (3622) at SetVis (script.js.common.HeatingControlMapper:319:5)
                                            17:14:21.203	warn	javascript.0 (3622) at main (script.js.common.HeatingControlMapper:176:5)
                                            17:14:21.203	warn	javascript.0 (3622) at Object.<anonymous> (script.js.common.HeatingControlMapper:162:13)
                                            template vis
                                            52
                                            443
                                            89600
