    4. Test Adapter HeatingControl v2.12.x
    • Rene_HM
      Rene_HM Developer @Oli last edited by
      @Oli kannst du mal auf debug schalten und das log nochmal posten (bitte als text und nicht als Bild)?
      • O
        Oli @Rene_HM last edited by Oli
        @Rene_HM
        ja kommt sofort, es kamen noch mehrere Fehler hinterher
        heatingcontrol.0	2020-03-11 18:22:02.139	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.138	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.137	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.136	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.135	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.134	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.133	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.132	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.131	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.130	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.129	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.128	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.127	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.126	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.125	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.124	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.123	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.122	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:22:02.121	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Thu.Periods.0.time
        heatingcontrol.0	2020-03-11 18:21:59.099	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.098	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.097	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.096	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.095	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.094	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.093	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.092	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.091	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.090	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.089	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.088	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.087	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.086	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.085	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.084	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.083	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.082	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.081	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:59.069	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.4.time
        heatingcontrol.0	2020-03-11 18:21:58.841	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.840	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.839	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.838	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.837	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.836	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.835	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.834	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.833	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.832	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.831	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.830	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.829	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.828	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.827	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.826	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.825	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.810	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.3.time
        heatingcontrol.0	2020-03-11 18:21:58.614	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
        heatingcontrol.0	2020-03-11 18:21:58.613	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
        heatingcontrol.0	2020-03-11 18:21:58.612	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
        heatingcontrol.0	2020-03-11 18:21:58.611	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
        heatingcontrol.0	2020-03-11 18:21:58.610	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
        heatingcontrol.0	2020-03-11 18:21:58.609	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
        heatingcontrol.0	2020-03-11 18:21:58.608	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
        heatingcontrol.0	2020-03-11 18:21:58.607	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
        heatingcontrol.0	2020-03-11 18:21:58.606	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
        heatingcontrol.0	2020-03-11 18:21:58.605	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
        heatingcontrol.0	2020-03-11 18:21:58.604	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
        heatingcontrol.0	2020-03-11 18:21:58.603	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
        heatingcontrol.0	2020-03-11 18:21:58.602	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
        heatingcontrol.0	2020-03-11 18:21:58.601	error	(29320) nextTime.val should be a string but is object for Profiles.2.Wohnzimmer.Fri.Periods.2.time
        Zusätliche Meldungen kommen auch im debug nicht
        • Rene_HM
          @Oli dann zeig bitte mal das debug log, wenn der Adapter startet...
          • O
            @Rene_HM
            ich glaube ich mach da was falsch, wie lasse ich mir das debug anzeigen?
            • Rene_HM
              • O
                @Rene_HM
                jetzt aber,
                heatingcontrol.0	2020-03-11 21:02:51.739	debug	(6832) #subscribtion finished
                heatingcontrol.0	2020-03-11 21:02:51.738	info	(6832) subscribe Bad linkeddevices.0.Fenster.Bad.OpenClose
                heatingcontrol.0	2020-03-11 21:02:51.738	info	(6832) subscribe Toilette linkeddevices.0.Fenster.GästeWC.OpenClose
                heatingcontrol.0	2020-03-11 21:02:51.737	info	(6832) subscribe Büro linkeddevices.0.Fenster.BüroRechts.OpenClose
                heatingcontrol.0	2020-03-11 21:02:51.736	info	(6832) subscribe Büro linkeddevices.0.Fenster.BüroLinks.OpenClose
                heatingcontrol.0	2020-03-11 21:02:51.735	info	(6832) subscribe Wohnzimmer linkeddevices.0.Fenster.Esszimmer.OpenClose
                heatingcontrol.0	2020-03-11 21:02:51.734	info	(6832) subscribe Wohnzimmer linkeddevices.0.Fenster.Wohnzimmer.OpenClose
                heatingcontrol.0	2020-03-11 21:02:51.733	debug	(6832) no subscribe Path2PartyNowDP
                heatingcontrol.0	2020-03-11 21:02:51.733	debug	(6832) no subscribe Path2GuestsPresentDP
                heatingcontrol.0	2020-03-11 21:02:51.733	debug	(6832) no subscribe Path2HolidayPresentDP
                heatingcontrol.0	2020-03-11 21:02:51.732	debug	(6832) no subscribe Path2VacationDP
                heatingcontrol.0	2020-03-11 21:02:51.732	debug	(6832) no subscribe Path2PresentDP
                heatingcontrol.0	2020-03-11 21:02:51.732	info	(6832) subscribe feiertage.0.heute.boolean
                heatingcontrol.0	2020-03-11 21:02:51.727	debug	(6832) #start subscribtion
                heatingcontrol.0	2020-03-11 21:02:51.726	debug	(6832) [INFO] status = true next event: 14 Mar 2020 23:20:00
                heatingcontrol.0	2020-03-11 21:02:51.719	debug	(6832) [INFO] status = true next event: 14 Mar 2020 15:00:00
                heatingcontrol.0	2020-03-11 21:02:51.716	debug	(6832) [INFO] status = true next event: 14 Mar 2020 14:00:00
                heatingcontrol.0	2020-03-11 21:02:51.712	debug	(6832) [INFO] status = true next event: 14 Mar 2020 08:00:00
                heatingcontrol.0	2020-03-11 21:02:51.710	debug	(6832) [INFO] status = true next event: 14 Mar 2020 01:00:00
                heatingcontrol.0	2020-03-11 21:02:51.708	debug	(6832) [INFO] status = true next event: 11 Mar 2020 23:20:00
                heatingcontrol.0	2020-03-11 21:02:51.705	debug	(6832) [INFO] status = true next event: 11 Mar 2020 22:00:00
                heatingcontrol.0	2020-03-11 21:02:51.704	debug	(6832) [INFO] status = true next event: 18 Mar 2020 15:00:00
                heatingcontrol.0	2020-03-11 21:02:51.701	debug	(6832) [INFO] status = true next event: 18 Mar 2020 06:00:00
                heatingcontrol.0	2020-03-11 21:02:51.698	debug	(6832) [INFO] status = true next event: 18 Mar 2020 01:00:00
                heatingcontrol.0	2020-03-11 21:02:51.696	debug	(6832) [INFO] status = true next event: 17 Mar 2020 23:20:00
                heatingcontrol.0	2020-03-11 21:02:51.689	debug	(6832) [INFO] status = true next event: 17 Mar 2020 22:00:00
                heatingcontrol.0	2020-03-11 21:02:51.684	debug	(6832) [INFO] status = true next event: 17 Mar 2020 15:00:00
                heatingcontrol.0	2020-03-11 21:02:51.680	debug	(6832) [INFO] status = true next event: 17 Mar 2020 06:00:00
                heatingcontrol.0	2020-03-11 21:02:51.678	debug	(6832) [INFO] status = true next event: 17 Mar 2020 01:00:00
                heatingcontrol.0	2020-03-11 21:02:51.674	debug	(6832) [INFO] status = true next event: 16 Mar 2020 23:20:00
                heatingcontrol.0	2020-03-11 21:02:51.667	debug	(6832) [INFO] status = true next event: 16 Mar 2020 22:00:00
                heatingcontrol.0	2020-03-11 21:02:51.663	debug	(6832) [INFO] status = true next event: 16 Mar 2020 15:00:00
                heatingcontrol.0	2020-03-11 21:02:51.659	debug	(6832) [INFO] status = true next event: 16 Mar 2020 06:00:00
                heatingcontrol.0	2020-03-11 21:02:51.657	debug	(6832) [INFO] status = true next event: 16 Mar 2020 01:00:00
                heatingcontrol.0	2020-03-11 21:02:51.606	debug	(6832) do not set target if no heating for room Bad
                heatingcontrol.0	2020-03-11 21:02:51.560	debug	(6832) do not set target if no heating for room Toilette
                heatingcontrol.0	2020-03-11 21:02:51.516	debug	(6832) do not set target if no heating for room Büro
                heatingcontrol.0	2020-03-11 21:02:51.470	debug	(6832) do not set target if no heating for room Wohnzimmer
                heatingcontrol.0	2020-03-11 21:02:51.468	debug	(6832) nothing to do: no heating period
                heatingcontrol.0	2020-03-11 21:02:51.465	debug	(6832) calculating new target temperatures
                heatingcontrol.0	2020-03-11 21:02:51.461	info	(6832) external states checked, done
                heatingcontrol.0	2020-03-11 21:02:51.459	debug	(6832) checking Path2HolidayPresentDP
                heatingcontrol.0	2020-03-11 21:02:51.456	debug	(6832) checking Path2PartyNowDP
                heatingcontrol.0	2020-03-11 21:02:51.454	debug	(6832) checking Path2GuestsPresentDP
                heatingcontrol.0	2020-03-11 21:02:51.451	debug	(6832) checking Path2VacationDP
                heatingcontrol.0	2020-03-11 21:02:51.448	debug	(6832) checking Path2PresentDP
                heatingcontrol.0	2020-03-11 21:02:51.403	info	(6832) setting PublicHolidyToday to false
                heatingcontrol.0	2020-03-11 21:02:51.401	debug	(6832) checking Path2FeiertagAdapter
                heatingcontrol.0	2020-03-11 21:02:51.400	info	(6832) checking all external states
                heatingcontrol.0	2020-03-11 21:02:51.355	debug	(6832) Bad window open is false
                heatingcontrol.0	2020-03-11 21:02:51.354	debug	(6832) got sensor state {"val":0,"ack":true,"ts":1583790576414,"q":0,"from":"system.adapter.linkeddevices.0","user":"system.user.admin","lc":1582147164575} from linkeddevices.0.Fenster.Bad.OpenClose
                heatingcontrol.0	2020-03-11 21:02:51.352	debug	(6832) Check sensors for Bad
                heatingcontrol.0	2020-03-11 21:02:51.310	debug	(6832) Toilette window open is false
                heatingcontrol.0	2020-03-11 21:02:51.309	debug	(6832) got sensor state {"val":0,"ack":true,"ts":1583790576413,"q":0,"from":"system.adapter.linkeddevices.0","user":"system.user.admin","lc":1583053495650} from linkeddevices.0.Fenster.GästeWC.OpenCl
                heatingcontrol.0	2020-03-11 21:02:51.307	debug	(6832) Check sensors for Toilette
                heatingcontrol.0	2020-03-11 21:02:51.264	debug	(6832) Büro window open is false
                heatingcontrol.0	2020-03-11 21:02:51.264	debug	(6832) got sensor state {"val":0,"ack":true,"ts":1583790576413,"q":0,"from":"system.adapter.linkeddevices.0","user":"system.user.admin","lc":1582895501347} from linkeddevices.0.Fenster.BüroRechts.Ope
                heatingcontrol.0	2020-03-11 21:02:51.262	debug	(6832) got sensor state {"val":0,"ack":true,"ts":1583790576413,"q":0,"from":"system.adapter.linkeddevices.0","user":"system.user.admin","lc":1582147249343} from linkeddevices.0.Fenster.BüroLinks.Open
                heatingcontrol.0	2020-03-11 21:02:51.259	debug	(6832) Check sensors for Büro
                heatingcontrol.0	2020-03-11 21:02:51.216	debug	(6832) Wohnzimmer window open is false
                heatingcontrol.0	2020-03-11 21:02:51.215	debug	(6832) got sensor state {"val":0,"ack":true,"ts":1583955554029,"q":0,"from":"system.adapter.linkeddevices.0","user":"system.user.admin","lc":1583955553955} from linkeddevices.0.Fenster.Esszimmer.Open
                heatingcontrol.0	2020-03-11 21:02:51.165	debug	(6832) got sensor state {"val":0,"ack":true,"ts":1583790576414,"q":0,"from":"system.adapter.linkeddevices.0","user":"system.user.admin","lc":1582147044151} from linkeddevices.0.Fenster.Wohnzimmer.Ope
                heatingcontrol.0	2020-03-11 21:02:51.159	debug	(6832) Check sensors for Wohnzimmer
                heatingcontrol.0	2020-03-11 21:02:51.157	error	(6832) exception in CalculateNextTime[Error: Field (7) value is out of range]
                heatingcontrol.0	2020-03-11 21:02:51.156	debug	(6832) create cron job #20 at 1:0 string: 0 0 1 * * 7 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.147	debug	(6832) create cron job #19 at 23:20 string: 0 20 23 * * 6 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.143	debug	(6832) create cron job #18 at 15:0 string: 0 0 15 * * 6 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.138	debug	(6832) create cron job #17 at 14:0 string: 0 0 14 * * 6 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.134	debug	(6832) create cron job #16 at 8:0 string: 0 0 8 * * 6 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.131	debug	(6832) create cron job #15 at 1:0 string: 0 0 1 * * 6 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.126	debug	(6832) create cron job #14 at 23:20 string: 0 20 23 * * 3 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.123	debug	(6832) create cron job #13 at 22:0 string: 0 0 22 * * 3 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.116	debug	(6832) create cron job #12 at 15:0 string: 0 0 15 * * 3 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.111	debug	(6832) create cron job #11 at 6:0 string: 0 0 6 * * 3 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.106	debug	(6832) create cron job #10 at 1:0 string: 0 0 1 * * 3 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.093	debug	(6832) create cron job #9 at 23:20 string: 0 20 23 * * 2 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.087	debug	(6832) create cron job #8 at 22:0 string: 0 0 22 * * 2 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.081	debug	(6832) create cron job #7 at 15:0 string: 0 0 15 * * 2 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.076	debug	(6832) create cron job #6 at 6:0 string: 0 0 6 * * 2 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.071	debug	(6832) create cron job #5 at 1:0 string: 0 0 1 * * 2 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.061	debug	(6832) create cron job #4 at 23:20 string: 0 20 23 * * 1 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.053	debug	(6832) create cron job #3 at 22:0 string: 0 0 22 * * 1 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.041	debug	(6832) create cron job #2 at 15:0 string: 0 0 15 * * 1 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:51.031	debug	(6832) create cron job #1 at 6:0 string: 0 0 6 * * 1 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:50.999	debug	(6832) create cron job #0 at 1:0 string: 0 0 1 * * 1 Europe/Berlin
                heatingcontrol.0	2020-03-11 21:02:50.997	debug	(6832) ---found time for Bad at {"val":"23:20:00","ack":false,"ts":1583262904244,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582141860528} 23:20:00
                heatingcontrol.0	2020-03-11 21:02:50.994	debug	(6832) push to list = 22,00,00
                heatingcontrol.0	2020-03-11 21:02:50.994	debug	(6832) ---found time for Bad at {"val":"22:00:00","ack":false,"ts":1583262904198,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582141850778} 22:00:00
                heatingcontrol.0	2020-03-11 21:02:50.992	debug	(6832) push to list = 10,00,00
                heatingcontrol.0	2020-03-11 21:02:50.992	debug	(6832) ---found time for Bad at {"val":"10:00:00","ack":false,"ts":1583262904198,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582141814645} 10:00:00
                heatingcontrol.0	2020-03-11 21:02:50.989	debug	(6832) ---found time for Bad at {"val":"08:00:00","ack":false,"ts":1583262904198,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583262734757} 08:00:00
                heatingcontrol.0	2020-03-11 21:02:50.946	debug	(6832) ---found time for Bad at {"val":"01:00:00","ack":false,"ts":1583262904198,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582141800831} 01:00:00
                heatingcontrol.0	2020-03-11 21:02:50.944	debug	(6832) setting Sun
                heatingcontrol.0	2020-03-11 21:02:50.944	debug	(6832) push to list = 23,00,00
                heatingcontrol.0	2020-03-11 21:02:50.944	debug	(6832) ---found time for Bad at {"val":"23:00:00","ack":false,"ts":1583262720541,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582141780988} 23:00:00
                heatingcontrol.0	2020-03-11 21:02:50.901	debug	(6832) push to list = 22,00,00
                heatingcontrol.0	2020-03-11 21:02:50.901	debug	(6832) ---found time for Bad at {"val":"22:00:00","ack":false,"ts":1583262720540,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582924163847} 22:00:00
                heatingcontrol.0	2020-03-11 21:02:50.899	debug	(6832) push to list = 10,00,00
                heatingcontrol.0	2020-03-11 21:02:50.899	debug	(6832) ---found time for Bad at {"val":"10:00:00","ack":false,"ts":1583262720540,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582141730535} 10:00:00
                heatingcontrol.0	2020-03-11 21:02:50.892	debug	(6832) ---found time for Bad at {"val":"08:00:00","ack":false,"ts":1583262725508,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583262724390} 08:00:00
                heatingcontrol.0	2020-03-11 21:02:50.850	debug	(6832) ---found time for Bad at {"val":"01:00:00","ack":false,"ts":1583262720540,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582141705192} 01:00:00
                heatingcontrol.0	2020-03-11 21:02:50.848	debug	(6832) setting Sat
                heatingcontrol.0	2020-03-11 21:02:50.847	debug	(6832) push to list = 23,00,00
                heatingcontrol.0	2020-03-11 21:02:50.846	debug	(6832) ---found time for Bad at {"val":"23:00:00","ack":false,"ts":1583262901191,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583262714296} 23:00:00
                heatingcontrol.0	2020-03-11 21:02:50.843	debug	(6832) push to list = 22,00,00
                heatingcontrol.0	2020-03-11 21:02:50.843	debug	(6832) ---found time for Bad at {"val":"22:00:00","ack":false,"ts":1583262901191,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583262707764} 22:00:00
                heatingcontrol.0	2020-03-11 21:02:50.841	debug	(6832) push to list = 07,30,00
                heatingcontrol.0	2020-03-11 21:02:50.840	debug	(6832) ---found time for Bad at {"val":"07:30:00","ack":false,"ts":1583262901191,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583262702340} 07:30:00
                heatingcontrol.0	2020-03-11 21:02:50.838	debug	(6832) push to list = 05,00,00
                heatingcontrol.0	2020-03-11 21:02:50.838	debug	(6832) ---found time for Bad at {"val":"05:00:00","ack":false,"ts":1583262901191,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583262694350} 05:00:00
                heatingcontrol.0	2020-03-11 21:02:50.835	debug	(6832) ---found time for Bad at {"val":"01:00:00","ack":false,"ts":1583262901191,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583262690654} 01:00:00
                heatingcontrol.0	2020-03-11 21:02:50.794	debug	(6832) setting Fri
                heatingcontrol.0	2020-03-11 21:02:50.793	debug	(6832) ---found time for Bad at {"val":"23:00:00","ack":false,"ts":1583272594319,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272594203} 23:00:00
                heatingcontrol.0	2020-03-11 21:02:50.792	debug	(6832) push to list = 23,00,00
                heatingcontrol.0	2020-03-11 21:02:50.791	debug	(6832) ---found time for Bad at {"val":"23:00:00","ack":false,"ts":1583272594319,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272594203} 23:00:00
                heatingcontrol.0	2020-03-11 21:02:50.789	debug	(6832) push to list = 07,30,00
                heatingcontrol.0	2020-03-11 21:02:50.788	debug	(6832) ---found time for Bad at {"val":"07:30:00","ack":false,"ts":1583272594319,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272594203} 07:30:00
                heatingcontrol.0	2020-03-11 21:02:50.786	debug	(6832) push to list = 05,00,00
                heatingcontrol.0	2020-03-11 21:02:50.786	debug	(6832) ---found time for Bad at {"val":"05:00:00","ack":false,"ts":1583272594319,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272594203} 05:00:00
                heatingcontrol.0	2020-03-11 21:02:50.784	debug	(6832) ---found time for Bad at {"val":"01:00:00","ack":false,"ts":1583272594319,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272594203} 01:00:00
                heatingcontrol.0	2020-03-11 21:02:50.782	debug	(6832) setting Thu
                heatingcontrol.0	2020-03-11 21:02:50.781	debug	(6832) ---found time for Bad at {"val":"23:00:00","ack":false,"ts":1583272853234,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272592026} 23:00:00
                heatingcontrol.0	2020-03-11 21:02:50.739	debug	(6832) push to list = 23,00,00
                heatingcontrol.0	2020-03-11 21:02:50.739	debug	(6832) ---found time for Bad at {"val":"23:00:00","ack":false,"ts":1583272853234,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272592006} 23:00:00
                heatingcontrol.0	2020-03-11 21:02:50.737	debug	(6832) push to list = 07,30,00
                heatingcontrol.0	2020-03-11 21:02:50.737	debug	(6832) ---found time for Bad at {"val":"07:30:00","ack":false,"ts":1583272853234,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272592006} 07:30:00
                heatingcontrol.0	2020-03-11 21:02:50.734	debug	(6832) push to list = 05,00,00
                heatingcontrol.0	2020-03-11 21:02:50.733	debug	(6832) ---found time for Bad at {"val":"05:00:00","ack":false,"ts":1583272853234,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272592006} 05:00:00
                heatingcontrol.0	2020-03-11 21:02:50.691	debug	(6832) ---found time for Bad at {"val":"01:00:00","ack":false,"ts":1583274077610,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272592006} 01:00:00
                heatingcontrol.0	2020-03-11 21:02:50.689	debug	(6832) setting Wed
                heatingcontrol.0	2020-03-11 21:02:50.688	debug	(6832) ---found time for Bad at {"val":"23:00:00","ack":false,"ts":1583272850461,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272590436} 23:00:00
                heatingcontrol.0	2020-03-11 21:02:50.687	debug	(6832) push to list = 23,00,00
                heatingcontrol.0	2020-03-11 21:02:50.686	debug	(6832) ---found time for Bad at {"val":"23:00:00","ack":false,"ts":1583272850461,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272590414} 23:00:00
                heatingcontrol.0	2020-03-11 21:02:50.684	debug	(6832) push to list = 07,30,00
                heatingcontrol.0	2020-03-11 21:02:50.683	debug	(6832) ---found time for Bad at {"val":"07:30:00","ack":false,"ts":1583272850460,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272590414} 07:30:00
                heatingcontrol.0	2020-03-11 21:02:50.681	debug	(6832) push to list = 05,00,00
                heatingcontrol.0	2020-03-11 21:02:50.680	debug	(6832) ---found time for Bad at {"val":"05:00:00","ack":false,"ts":1583272850460,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272590414} 05:00:00
                heatingcontrol.0	2020-03-11 21:02:50.637	debug	(6832) ---found time for Bad at {"val":"01:00:00","ack":false,"ts":1583272850460,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272590413} 01:00:00
                heatingcontrol.0	2020-03-11 21:02:50.636	debug	(6832) setting Tue
                heatingcontrol.0	2020-03-11 21:02:50.635	debug	(6832) ---found time for Bad at {"val":"23:00:00","ack":false,"ts":1583272846985,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272580251} 23:00:00
                heatingcontrol.0	2020-03-11 21:02:50.633	debug	(6832) push to list = 23,00,00
                heatingcontrol.0	2020-03-11 21:02:50.632	debug	(6832) ---found time for Bad at {"val":"23:00:00","ack":false,"ts":1583272846978,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272572251} 23:00:00
                heatingcontrol.0	2020-03-11 21:02:50.590	debug	(6832) push to list = 07,30,00
                heatingcontrol.0	2020-03-11 21:02:50.589	debug	(6832) ---found time for Bad at {"val":"07:30:00","ack":false,"ts":1583272846978,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272553684} 07:30:00
                heatingcontrol.0	2020-03-11 21:02:50.587	debug	(6832) push to list = 05,00,00
                heatingcontrol.0	2020-03-11 21:02:50.586	debug	(6832) ---found time for Bad at {"val":"05:00:00","ack":false,"ts":1583272846978,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272539796} 05:00:00
                heatingcontrol.0	2020-03-11 21:02:50.544	debug	(6832) ---found time for Bad at {"val":"01:00:00","ack":false,"ts":1583272846974,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272531034} 01:00:00
                heatingcontrol.0	2020-03-11 21:02:50.542	debug	(6832) setting Mon
                heatingcontrol.0	2020-03-11 21:02:50.542	debug	(6832) ---found time for Toilette at {"val":"23:20:00","ack":false,"ts":1583262433988,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582142603791} 23:20:00
                heatingcontrol.0	2020-03-11 21:02:50.531	debug	(6832) ---found time for Toilette at {"val":"15:00:00","ack":false,"ts":1583262433981,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582142599088} 15:00:00
                heatingcontrol.0	2020-03-11 21:02:50.528	debug	(6832) ---found time for Toilette at {"val":"14:00:00","ack":false,"ts":1583262433975,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582928340416} 14:00:00
                heatingcontrol.0	2020-03-11 21:02:50.485	debug	(6832) ---found time for Toilette at {"val":"08:00:00","ack":false,"ts":1583262440507,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583262439290} 08:00:00
                heatingcontrol.0	2020-03-11 21:02:50.483	debug	(6832) ---found time for Toilette at {"val":"01:00:00","ack":false,"ts":1583262433975,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582142579614} 01:00:00
                heatingcontrol.0	2020-03-11 21:02:50.464	debug	(6832) setting Sun
                heatingcontrol.0	2020-03-11 21:02:50.463	debug	(6832) ---found time for Toilette at {"val":"23:20:00","ack":false,"ts":1583262420392,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582142567036} 23:20:00
                heatingcontrol.0	2020-03-11 21:02:50.460	debug	(6832) ---found time for Toilette at {"val":"15:00:00","ack":false,"ts":1583262420328,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582142561897} 15:00:00
                heatingcontrol.0	2020-03-11 21:02:50.456	debug	(6832) ---found time for Toilette at {"val":"14:00:00","ack":false,"ts":1583262420328,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582928308080} 14:00:00
                heatingcontrol.0	2020-03-11 21:02:50.454	debug	(6832) ---found time for Toilette at {"val":"08:00:00","ack":false,"ts":1583262426445,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583262425573} 08:00:00
                heatingcontrol.0	2020-03-11 21:02:50.412	debug	(6832) ---found time for Toilette at {"val":"01:00:00","ack":false,"ts":1583262420328,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1582142543157} 01:00:00
                heatingcontrol.0	2020-03-11 21:02:50.410	debug	(6832) setting Sat
                heatingcontrol.0	2020-03-11 21:02:50.410	debug	(6832) ---found time for Toilette at {"val":"23:20:00","ack":false,"ts":1583262417516,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583262416373} 23:20:00
                heatingcontrol.0	2020-03-11 21:02:50.407	debug	(6832) ---found time for Toilette at {"val":"15:00:00","ack":false,"ts":1583262414420,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583262413767} 15:00:00
                heatingcontrol.0	2020-03-11 21:02:50.404	debug	(6832) ---found time for Toilette at {"val":"14:00:00","ack":false,"ts":1583262408211,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583262407575} 14:00:00
                heatingcontrol.0	2020-03-11 21:02:50.402	debug	(6832) ---found time for Toilette at {"val":"06:00:00","ack":false,"ts":1583262403476,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583262402318} 06:00:00
                heatingcontrol.0	2020-03-11 21:02:50.394	debug	(6832) ---found time for Toilette at {"val":"01:00:00","ack":false,"ts":1583262399187,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583262398406} 01:00:00
                heatingcontrol.0	2020-03-11 21:02:50.363	debug	(6832) setting Fri
                heatingcontrol.0	2020-03-11 21:02:50.363	debug	(6832) ---found time for Toilette at {"val":"23:20:00","ack":false,"ts":1583272284666,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272062910} 23:20:00
                heatingcontrol.0	2020-03-11 21:02:50.359	debug	(6832) ---found time for Toilette at {"val":"15:00:00","ack":false,"ts":1583272284624,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272062881} 15:00:00
                heatingcontrol.0	2020-03-11 21:02:50.356	debug	(6832) ---found time for Toilette at {"val":"14:00:00","ack":false,"ts":1583272284623,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272062881} 14:00:00
                heatingcontrol.0	2020-03-11 21:02:50.354	debug	(6832) ---found time for Toilette at {"val":"06:00:00","ack":false,"ts":1583272284623,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272062880} 06:00:00
                heatingcontrol.0	2020-03-11 21:02:50.312	debug	(6832) ---found time for Toilette at {"val":"01:00:00","ack":false,"ts":1583272284622,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272062880} 01:00:00
                heatingcontrol.0	2020-03-11 21:02:50.310	debug	(6832) setting Thu
                heatingcontrol.0	2020-03-11 21:02:50.309	debug	(6832) ---found time for Toilette at {"val":"23:20:00","ack":false,"ts":1583272058584,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272058441} 23:20:00
                heatingcontrol.0	2020-03-11 21:02:50.307	debug	(6832) ---found time for Toilette at {"val":"15:00:00","ack":false,"ts":1583272058543,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272058419} 15:00:00
                heatingcontrol.0	2020-03-11 21:02:50.304	debug	(6832) ---found time for Toilette at {"val":"14:00:00","ack":false,"ts":1583272058542,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272058419} 14:00:00
                heatingcontrol.0	2020-03-11 21:02:50.302	debug	(6832) ---found time for Toilette at {"val":"06:00:00","ack":false,"ts":1583272058542,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272058419} 06:00:00
                heatingcontrol.0	2020-03-11 21:02:50.261	debug	(6832) ---found time for Toilette at {"val":"01:00:00","ack":false,"ts":1583272058536,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272058419} 01:00:00
                heatingcontrol.0	2020-03-11 21:02:50.258	debug	(6832) setting Wed
                heatingcontrol.0	2020-03-11 21:02:50.257	debug	(6832) ---found time for Toilette at {"val":"23:20:00","ack":false,"ts":1583272055057,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272054956} 23:20:00
                heatingcontrol.0	2020-03-11 21:02:50.214	debug	(6832) ---found time for Toilette at {"val":"15:00:00","ack":false,"ts":1583272055057,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272054934} 15:00:00
                heatingcontrol.0	2020-03-11 21:02:50.213	debug	(6832) ---found time for Toilette at {"val":"14:00:00","ack":false,"ts":1583272055057,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272054934} 14:00:00
                heatingcontrol.0	2020-03-11 21:02:50.210	debug	(6832) ---found time for Toilette at {"val":"06:00:00","ack":false,"ts":1583272055057,"q":0,"from":"system.adapter.javascript.0","user":"system.user.admin","lc":1583272054934} 06:00:00
                • Rene_HM
                  @Oli ich sehe zwar das Problem, kann aber noch nicht sagen, wo der Fehler liegt. Nimm mal in der Zwischenzeit eines der anderen beiden Profiltypen (entweder Mo -So oder Mo-Fr + Sa - So). Der Type "jeden Tag separat" macht hier beim erstellen der Zeittabelle ein Problem... Ich schau mir das aber weiter hin...
                  • O
                    @Rene_HM
                    alles klar, hat aber schon mal funktioniert
                    • Bastelritius
                      Bastelritius last edited by
                      ich bräuchte etwas Hilfe bei der Einrichtung des Adapters.
                      Ich habe folgendes Setup.
                      • Fußbodenheizung mit Stellmotoren (nur ein/aus, keine PWM)
                      • Die Stellmotoren steuere ich über zwei 8ch Realisboards an, welches ich wiederum über einen MCP23017 ansteuere. Ich habe also kein Thermostat, sondern steuere die Stellmotoren direkt an.
                      • Die Temperatur pro Raum bekomme ich über einen HM Temperatursenor
                      • In jedem Raum habe ich einen HM-Fensterdrehgriffkontakt.
                      Da ich eine Fussbodenheizung habe machen für mich mehrere Heizzeiten pro Tag keinen Sinn, da die FBH eh zu träge reagiert. Das sieht dann so aus, richtig?
                      Jetzt kommt aber der Teil den ich nicht ganz so verstehe. Wie setze ich den Aktor und mein Temperatursensor?
                      Den Temperatursensor definiere ich unter Thermostat als OID aktueller Wert und lasse den Zielwert leer, oder muss ich das unter Sensoren machen?
                      Meinen MCP23017 Ausgang setzte ich unter Aktoren?
                      Desweiteren verstehe ich die gelb markierten angelegten Datenpunkte nicht:
                      Kann mir die jemand erklären. Was wird dort wie definiert?
                      Dann noch eine nicht ganz so wichtige Frage. Im ersten Post steht etwas von einem Kaminmodus. Gibt es den wirklich. Ich habe dazu nichts gefunden?
                      G P Rene_HM 3 Replies Last reply Reply Quote 0
                        guergen @Bastelritius last edited by
                        @Bastelritius Kamin-Modus steht unter "wünsch dir was"...
                          Pittini Developer @Bastelritius last edited by
                          @Bastelritius sagte in Test Adapter HeatingControl v0.3.x:
                          time - Zu welcher Zeit die darüber stehende Temperatur aktiv wird
                          CurrentTimePeriod + CurrentTimePeriodFull - Welche Zeit/Temperatur gerade aktiv ist
                          TemperaturOverride und TemperaturOverrideTime - Hier kannste die Grundeinstellungen für ne bestimmte Zeit überschreiben. z.B. Bad hat normalerweise 22°C. Zum Vollbaden willste aber 30° für ne Stunde. Dafür ist das der richtige Punkt und Du brauchst nicht Dein normales Profil ändern.
                          Viel interessanter @Rene_HM finde ich den CurrentTimeSlot mit -1, wie kommt denn das Zustande?
                          Bastelritius 1 Reply Last reply Reply Quote 0
                          • Bastelritius
                            Bastelritius @Pittini last edited by
                            @Pittini , danke erst mal für Deine Antworten.
                            Soweit verstehe ich das dann, glaube ich zumindest. D.h.. da ich nur 1 Profil habe, kann ich bei Time eintragen was ich möchte. Es wird in diesem Beispiel jetzt immer von 05:00 bis am nächsten Tag 05:00 geheizt?
                            Kannst Du noch etwas zur Definition meines Temperaturfühlers sagen. Meine Vorgehensweise scheint nicht richtig zu sein. Wenn ich es so mache wie oben beschreiben kommt im LOG ein Fehler und danach ein Haufen Warnmeldung in Endlosschleife.
                            P 2 Replies Last reply Reply Quote 0
                              Ich sag nur was wenn ich nen Plan hab und von Fußbodenheizungen und deren Konfig hab ich 0 Plan, also sorry nein.
                              • Bastelritius
                                Da geht es doch aber eher darum wie ich das setup im Adapter mache wenn ich keine Thermostate verwende, sondern einen Temperaturfühler und Aktor den ich direkt ansteuern will unabhängig davon ob es eine FBH ist oder nicht.
                                Aber wenn du da nicht weiter helfen kannst, ist das ok
                                  Jaein. Es kommt natürlich auch noch drauf an wieviele Perioden Du verwendest. Bei einem Profil mit einer Periode ist es so wie Du meinst. Sind mehrere Perioden gesetzt - nicht.
                                  • Rene_HM
                                    @Oli Mit der 0.3.19 sollte das jetzt richtig funktionieren. Das Anlegen der cron-Tabelle für Sonntag im Profil-Type "jeden Tag" war noch fehlerhaft...
                                    • O
                                      @Rene_HM
                                      alles klar, werde ich testen, danke!!
                                      • Rene_HM
                                        Rene_HM Developer @Bastelritius last edited by
                                        Das ist richtig. Temperatursensor gehört in die Thermostat-Konfiguration als aktueller Wert.
                                        Die Warnungen zeigen nicht wirklich die Ursache. Das Problem bei solchen Warnungen ist ein Fehlkonfiguration von OID's. Ich denke die OID unter Aktoren ist nicht richtig.
                                          tazdevil20 last edited by tazdevil20
                                          ich wollte mir heute mal anschauen warum ich immer wieder Warnungen und einen Fehler bekomme. Leider komme ich nicht dahinter was in meiner Konfiguration falsch sein könnte:
                                          Hier der Fehler:
                                          2020-03-19 12:42:47.358 - debug: heatingcontrol.0 (668) FindNextPeriod for 2020-3-19 12:42:47 PM in Büro
                                          2020-03-19 12:42:47.359 - debug: heatingcontrol.0 (668) ### set ActiveTimeSlot to 0
                                          2020-03-19 12:42:47.359 - debug: heatingcontrol.0 (668) check ID Profiles.0.Büro.Mo-Fr.Periods.0.time period 0
                                          2020-03-19 12:42:47.360 - debug: heatingcontrol.0 (668) check time for Büro Profiles.0.Büro.Mo-Fr.Periods.0.time 19
                                          2020-03-19 12:42:47.360 - debug: heatingcontrol.0 (668) check ID Profiles.0.Büro.Mo-Fr.Periods.1.time period 1
                                          2020-03-19 12:42:47.362 - warn: heatingcontrol.0 (668) try to convert 20 to a number
                                          2020-03-19 12:42:47.362 - debug: heatingcontrol.0 (668) check time for Büro Profiles.0.Büro.Mo-Fr.Periods.1.time 20
                                          2020-03-19 12:42:47.362 - debug: heatingcontrol.0 (668) check ID Profiles.0.Büro.Mo-Fr.Periods.2.time period 2
                                          2020-03-19 12:42:47.363 - debug: heatingcontrol.0 (668) ### set ActiveTimeSlot to 1 period 1
                                          2020-03-19 12:42:47.364 - debug: heatingcontrol.0 (668) Büro found period 1 with 20 on 08,00
                                          2020-03-19 12:42:47.364 - debug: heatingcontrol.0 (668) ### current > 1 1 1
                                          2020-03-19 12:42:47.364 - debug: heatingcontrol.0 (668) ### new target temp 20 0 0 0 0 3
                                          2020-03-19 12:42:47.364 - debug: heatingcontrol.0 (668) room Büro setting new target 17
                                          Die Datenpunkte sehen wie folgt aus:
                                          Temperatur ist auch als Zahl definiert.
                                          Warum kommt immer wieder die Warnung, dass der Wert in eine Zahl konvertiert werden muss?
                                          Irgendjemand eine Idee?
                                          • Stephan Schleich
                                            Stephan Schleich last edited by
                                            Wenn ich das Simple Vis importiere funktioniert unter "Allgemeines" lediglich der Punkt Party, alle anderen Punkte werden bei mir nicht angewandt.
                                            heating
                                            236
                                            3158
                                            1949984
