    2. English
    3. ioBroker general
    4. get zigbee data automatically
    • erfan shaigani
      erfan shaigani last edited by
      hi everyone , I have a zigbee xiaomi tempreture sensor , I can manually get data by IOBROKER SIMPLE API by "get": "http://ipaddress:8087/get/stateID/?prettyPrint",
      in a json formatted file , but as I said it is manually !!
      I want to receive data automatically whenever the tempreture changes
      i have a rpi4 , and sqlite database on it
      thanks in advance
      • Jey Cee
        Jey Cee Developer @erfan shaigani last edited by
        @erfan-shaigani more details please. What zigbee gateway do you use?
        erfan shaigani 1 Reply Last reply Reply Quote 0
        • erfan shaigani
          erfan shaigani @Jey Cee last edited by
          @Jey-Cee i use a raspberry pi as my gateway
          • mickym
            I don't see the problem.
            When the value changes, you will get a trigger in your favorite logic machine and do what you want. 😉 - So you can create json strings, files or do start any other action.
            I use Node-Red as logic machine - but you can use Javascript / Blockly as well.
              paul53 @erfan shaigani last edited by
              @erfan-shaigani sagte:
              Which Zigbee modem ?
              • erfan shaigani
                erfan shaigani @mickym last edited by
                @mickym
                thnaks a lot , can you explain more ? I am not familliar enough with logic machine.
                or if u are ok , i can give u my email or whatsapp id
                • mickym
                  mickym Most Active @erfan shaigani last edited by
                  @erfan-shaigani
                  A logic machine - is for example your JavaScript Adapter and you can use Blockly.
                  I am not so familiar with Blockly. I prefer the Node-RED adapter.
                  You have an iobroker node - where you can select den data - point where the your zigbee Adapter stores the temperature of your sensor.
                  I have also the xiaomi sensor as well - and if you look to the screen shot. If the value changes - a message will be automatically created and you can do with this value - what you want. I just display it on the node-RED dashboard, but you can format a json-string as well and send it whereever you want.
                  • erfan shaigani
                    @mickym thanks a lot !!! "You have an iobroker node" you said ,
                    how can I find this node ? I mean how did you connect iobroker to this node in youe node red ?
                    in your picture I can see Node "93a14......"
                    where does it come form
                    again thanks a lot for your help
                    • mickym
                      Have you installed the node-red Adapter in iobroker?
                      • erfan shaigani
                        @mickym hello again , yes I installed it ,
                        now what should I do ?
                        my final goal is to send the data to an external server whenever the data changes
                        or at least I want to be notified about the changes in the data to send a query and save the data on my rpi
                        • mickym
                          @erfan-shaigani
                          I can not write a Node-Red tutorial here - but there are a lot of videos.
                          I can recommend this site - to get familiar with Node-RED this page: http://www.steves-internet-guide.com/node-red-overview/
                          and his starter video: https://www.youtube.com/watch?v=y05vQUIMIxs&feature=youtu.be
                          instead of the mqtt-in node - you can use the "iobroker in" node.
                          So if you have open your node red - drag an "iobroker in" node into the flow area. Configure this node by opening this node - and select your datapoint of your temperature sensor - as you can see in my screen-shot.
                          Then wire for the first time a debug node to the "iobroker in" node and have the debug window open in node-red.
                          Everytime your temperature will change generates a new message, which you can see in the debug window.
                          With this message - containing the temperature you can do what you want. Create your json string, you can use to put it in an other data object, write to a file, a database, put in an http-request and even use the simple api.
                          rpi raspi 4 simple api adapter xiaomi zigbee zigbee cc2531 cc2530
                          925
