    4. Test Adapter fb-checkpresence v0.2.x
    • Santos
      Santos @sigi234 last edited by
      @sigi234 said in Test Adapter fb-checkpresence v0.2.x:
      @afuerhoff
      Adapter ab und zu Gelb:
      2020-02-18 10:35:46.011 - error: fb-checkpresence.0 (6740) getActive: soapAction GetSpecificHostEntry -> {"statusCode":500,"body":"\n\n\n\ns:Client\nUPnPError\n\n\n401\nInvalid Action\n\n\n\n\n","headers":{"date":"Tue, 18 Feb 2020 09:35:44 GMT","server":"FRITZ!Box 6590 Cable UPnP/1.0 AVM FRITZ!Box 6590 Cable 148.07.12","connection":"close","content-length":"429","content-type":"text/xml; charset=\"utf-8\""},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"192.168.178.1:49443","port":"49443","hostname":"192.168.178.1","hash":null,"search":null,"query":null,"pathname":"/upnp/control/hosts","path":"/upnp/control/hosts","href":"https://192.168.178.1:49443/upnp/control/hosts"},"method":"POST","headers":{"SoapAction":"urn:dslforum-org:service:Hosts:1#GetSpecificHostEntry","Content-Type":"text/xml","charset":"utf-8","content-length":588}}}
      Ich habe mich zu früh gefreut, es kommt der gleicher Fehler auf, der Adapter ist auch gelb.
      fb-checkpresence.0	2020-03-09 11:04:40.244	debug	(4463) checkPresence first run
      fb-checkpresence.0	2020-03-09 11:04:40.239	error	(4463) getActive: soapAction GetSpecificHostEntry -> {"statusCode":500,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schem
      fb-checkpresence.0	2020-03-09 11:04:40.164	debug	(4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schema
      fb-checkpresence.0	2020-03-09 11:04:40.155	debug	(4463) getActive [{"Name":"Bendito","Active":"true","Kommt":"2020.03.08 21:40:10","Geht":"2020.03.08 21:40:14"},{"Name":"Galaxy-J6","Active":"false","Kommt":"2020.03.08 21:40:09","Geht":"2020.03.09 01
      fb-checkpresence.0	2020-03-09 11:04:40.085	debug	(4463) getActive MI6-Xiaomi 1
      fb-checkpresence.0	2020-03-09 11:04:40.082	debug	(4463) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\n
      fb-checkpresence.0	2020-03-09 11:04:40.041	debug	(4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schema
      fb-checkpresence.0	2020-03-09 11:04:39.990	debug	(4463) getActive [{"Name":"Bendito","Active":"true","Kommt":"2020.03.08 21:40:10","Geht":"2020.03.08 21:40:14"},{"Name":"Galaxy-J6","Active":"false","Kommt":"2020.03.08 21:40:09","Geht":"2020.03.09 01
      fb-checkpresence.0	2020-03-09 11:04:39.642	debug	(4463) getActive Galaxy-J6 0
      fb-checkpresence.0	2020-03-09 11:04:39.638	debug	(4463) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\
      fb-checkpresence.0	2020-03-09 11:04:39.599	debug	(4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem
      fb-checkpresence.0	2020-03-09 11:04:39.464	debug	(4463) getActive [{"Name":"Bendito","Active":"true","Kommt":"2020.03.08 21:40:10","Geht":"2020.03.08 21:40:14"},
      fb-checkpresence.0	2020-03-09 11:04:37.575	debug	(4463) getActive Bendito 1
      fb-checkpresence.0	2020-03-09 11:04:37.572	debug	(4463) response: 0 {"statusCode":200,"body":"<?xml version=\"1.0\"?>\n<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\" s:encodingStyle=\"http://schemas.xmlsoap.org/soap/encoding/\">\
      fb-checkpresence.0	2020-03-09 11:04:37.542	debug	(4463) request url https://fritz.box:49443/upnp/control/hosts body: <?xml version="1.0" encoding="utf-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schem
      fb-checkpresence.0	2020-03-09 11:04:37.537	debug	(4463) getDeviceInfo blCnt: 50
      fb-checkpresence.0	2020-03-09 11:04:37.536	debug	(4463) getDeviceInfo activeCnt: 34
      fb-checkpresence.0	2020-03-09 11:04:37.460	debug	(4463) getDeviceList: [{"Index":"1","IPAddress":"192.168.1.250","MACAddress":"24:5E:BE:1E:C3:9A","Active":"1","HostName":"Bendito","InterfaceType":"Ethernet","X_AVM-DE_Port":"3","X_AVM-DE_Speed":"100
      afuerhoff 1 Reply Last reply Reply Quote 0
      • afuerhoff
        afuerhoff Developer @Santos last edited by
        @Santos sagte in Test Adapter fb-checkpresence v0.2.x:
        Hallo, wie oft kommt der Fehler denn vor? Der Fehler sagt aus, das Server seitig ein Fehler aufgetreten ist. Evtl. muss ich hier die Fehlerausgabe mal überdenken.
        Santos 1 Reply Last reply Reply Quote 0
        • afuerhoff
          afuerhoff Developer @e-s last edited by
          @e-s sagte in Test Adapter fb-checkpresence v0.2.x:
          ist es möglich in der Auswahlliste anzuzeigen welche schon in der Liste sind.
          Hallo, das ist möglich. Ich plane das mal für das nächste Release ein.
          Wäre es alternativ auch möglich statt mac oder ip adresse, beide gleichzeitig in der Familienliste anzeigen zu lassen.
          Das wäre schon möglich. Es könnte aber sein, dass sich die IP-Adresse je nach Einstellung in der Fritzbox ändert. Eindeutig ist die Mac-Adresse. Die Möglichkeit mit der IP-Adresse macht nur Sinn, wenn sie in der Fritzbox festgeschrieben ist.
          ? E 2 Replies Last reply Reply Quote 0
            A Former User @afuerhoff last edited by
            Das ist eines der Dinge die ich an deinem Adapter mag. Warum auch immer sich eine IP ändern kann dem Adapter ist es egal 👍
              e-s @afuerhoff last edited by
              @afuerhoff
              Könnte aber zumindest die aktuelle IP angezeigt werden und trotzdem nach Mac gesucht werden?
              Schön wäre es natürlich wenn bei der Auswahl nur die angezeigt werden, die noch nicht in der Liste sind.
              • Santos
                Santos @afuerhoff last edited by
                @afuerhoff said in Test Adapter fb-checkpresence v0.2.x:
                Das kann ich jetzt nicht sagen, heute war der Adapter grün. Ich versuche zu beobachten, unter welchen Bedienungen er sich ändert.
                • afuerhoff
                  afuerhoff Developer last edited by
                  @Bluefox
                  Hallo, ich habe ein Problem mit meinem Adapter. Obwohl er vor ein paar Tagen ins stable Repository aufgenommen worden ist, wird er bei mir nicht als stable in der Adapterliste angezeigt. Er erscheint weiterhin in der gelben Farbe als Beta. Kann das jemand der Tester so bestätigen?
                  Wenn ich unter npm schaue, wird als stable Version die 0.3.0 dort angezeigt. Was auch korrekt ist.
                  Was habe ich hier falsch gemacht?
                  sigi234 H 2 Replies Last reply Reply Quote 0
                    sigi234 Forum Testing Most Active @afuerhoff last edited by
                    @afuerhoff sagte in Test Adapter fb-checkpresence v0.2.x:
                    kann das jemand der Tester so bestätigen?
                    Ja
                      Headhunter70 @afuerhoff last edited by
                      @afuerhoff habe gerade versucht zu installieren, bekomme aber Fehlermeldung, liegt es an meinem System ?
                      • afuerhoff
                        afuerhoff Developer @Headhunter70 last edited by
                        @Headhunter70
                        Hallo, ich verwende einen RaspberryPI und ein TinkerBoard. Wie hast du denn installiert?
                          @afuerhoff Habe auch Tinkerboard, installation versucht ganz normal über Iobroker adapter view
                          E afuerhoff 2 Replies Last reply Reply Quote 0
                            e-s @Headhunter70 last edited by
                            @Headhunter70
                            drück doch da mal auf mehr und zeig dann einen neuen screenshot
                            • afuerhoff
                              @Headhunter70
                              Ich hab gerade eine neue Instanz installiert. Hat bei mir ohne Probleme geklappt. Gibt es im Log irgendwelche Hinweise?
                                @afuerhoff mehmmm das ist ja echt komisch, habe einen anderen adapter installiert und das ging ohne Probleme.
                                Hier noch mal ein screenshot
                                  @afuerhoff wenn ich das aus dem Info Adtaper heraus installiere, sagt er mir der Adapter is schon installiert...
                                    @Headhunter70
                                    welche Versionen hat dein System, also npm, node.js usw
                                      Headhunter70 @e-s last edited by
                                      • afuerhoff
                                        afuerhoff Developer @Headhunter70 last edited by afuerhoff
                                        @Headhunter70
                                        Schau dir mal die io-package.json an und vergleiche den Inhalt mal mit der auf Github. Stimmen die Berechtigungen in deinem System?
                                        Du könntest auch den Adapter über die Admin Experten Ansicht löschen und neu installieren.
                                          Headhunter70 @afuerhoff last edited by Headhunter70
                                          @afuerhoff habe das alles mal probiert, war aber nix, habe jetzt das Tinkerboard platt gemacht und alles neu aufgesetzt, jetzt ging die Installation problemlos durch
                                          • afuerhoff
                                            @Headhunter70
                                            Dann viel Spaß mit dem Adapter.
                                            31.7k
                                            79.8k
                                            avm fb-checkpresence fritzbox soap tr-064
                                            26
                                            259
                                            27688
