    4. Vorstellung meiner VIS
      saeft_2003 Most Active @Glasfaser last edited by
      @Glasfaser
      hier das widget das du haben wolltest:
      [{"tpl":"tplFrame","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":true,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","title":"","title_color":"#ffffff","title_top":"20","title_left":"500","header_height":"0","header_color":"#5c5757","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"title_back":"#000000"},"style":{"left":"525px","top":"8px","width":"199px","height":"334px","border-color":"#76767f","border-style":"groove","border-width":"7px","border-radius":"30px","background-color":"#171616","z-index":"1"},"widgetSet":"basic"}]
        Knusterus last edited by
        @saeft_2003
        Erst mal herzlichen Glückwunsch zu Deiner Vis. Das hat bestimmt viel Arbeit gemacht,das sieht wirklich SUPER aus.
        Besonders gefällt mir Dein Proxmox View.
        Ich habe es versucht nachzustellen, aber leider ohne Erfolg. Im Iobroker läuft der Proxmoxadapter ,der influxDB adapter.
        Alle funktionieren auch. Jetzt habe ich mit Grafana ein neues Dashboard erstellt und dort die "Panele".
        Das hat auch alles funktioniert.
        In der Iobroker Vis habe ich dann das i-Frame Widget ausgewählt und die Shareadresse des Panels eingetragen.
        Aber ich sehe in der Vis kein Bild es kommt aber auch keine Fehlermeldung. Wenn ich die Adresse in den Browser eingebe sehe ich das Bild.
        Was mache ich falsch??
        Vielen Dank schon mal für deine Hilfe
        Knuster
          saeft_2003 Most Active @Knusterus last edited by saeft_2003
          @Knusterus
          Ich glaub ich weiß an was das liegt du musst in grafana erst noch einstellen das ein chart in einem iframe eingezeigt werden darf.
          Am besten mal googeln, ich glaube es war auch schon hier im Forum ein Thema, ich schaue später auch noch mal.
          Ich hab meinen thread gefunden der sollte dir weiter helfen, weil am anfang hatte ich auch Probleme. Ich glaube du musst in der grafana.ini den anonymus Zugang aktivieren.
          Aber less dir am besten mal alles durch:
          https://forum.iobroker.net/topic/23270/gelöst-grafana-diagramm-in-vis-einfügen
            Knusterus @saeft_2003 last edited by
            @saeft_2003
            Danke für Deine schnelle Hilfe
            Das
            Bei Grafana selber gibt es eine Setting "allow_embedding" in der grafana.ini, welche auf true gestellt werden muss.
            Das habe ich bereits gelesen und geändert ,aber leider ohne Erfolg.
            Aus Deinem Link bin ich leider nicht so richtig schlau geworden. Woher weis ich den Namen der Organisation??
            Knusterus
              crunchip Forum Testing Most Active @Knusterus last edited by crunchip
              @Knusterus sagte in Vorstellung meiner VIS:
              Die musst du selbst festlegen und entsprechend eintragen, also
              in der grafana.ini hinterlegen, und dann in Grafana unter Configuration>Preferences den Namen eintragen
                Knusterus @crunchip last edited by
                @crunchip
                Ok ich habe jetzt meine grafana.ini auch so geändert.
                [auth.anonymous]
                enabled = true
                # Organization name that should be used for unauthenticated users
                org_name = Main Org.
                # Role for unauthenticated users, other valid values are `Editor` and `Admin`
                org_role = Viewer
                Aber wo muß der Name der Organisation noch hin?
                K crunchip 2 Replies Last reply Reply Quote 0
                  Knusterus @Knusterus last edited by
                  @Knusterus said in Vorstellung meiner VIS:
                  @crunchip
                  #################################### Anonymous Auth ######################
                  [auth.anonymous]
                  # enable anonymous access
                  enabled = true
                  # specify organization name that should be used for unauthenticated users
                  # specify role for unauthenticated users
                  org_role = Viewer
                    @Knusterus das Main Org. löscht du raus und schreibst da irgendwas rein, nach belieben, z.b. iobroker
                    und wie gerade geschrieben, in grafana auch eintragen
                      Knusterus @crunchip last edited by Knusterus
                      @crunchip
                      So habe ich gemacht ,aber leider trotzdem kein Bild.
                      Was kann ich noch tun??
                      Ich habe noch einen Nachtrag ,das Ganze läuft bei mir unter Proxmox, iobroker in einer VM
                      und Grafana mit InfluxDB in einer anderen VM.
                      Vielleicht liegt dort der Fehler.
                      Vielleicht installiere ich die Grafana VM am Wochenende nochmal neu.
                      Vielleicht geht es ja dann.
                        So alles nochmal neu installiert,aber immer noch kein Bild.
                        Knusterus
                        • Glasfaser
                          Glasfaser @Knusterus last edited by Glasfaser
                          @Knusterus
                          Schau dir mal das Video an ! Link Text
                            Knusterus @Glasfaser last edited by Knusterus
                            @Glasfaser
                            Vielen Dank für den Tipp, in der grafana.ini muß der Wert noch so geändert werden
                            # set to true if you want to allow browsers to render Grafana in a <frame>, <iframe>, <embed> or <object>. default is false.
                            allow_embedding = true
                            Vielen Dank, jetzt funktioniert es.
                            Knusterus
                              @saeft_2003
                              eine Frage habe ich noch ,wie hast Du die Betriebzeit in Tagen hinbekommen. Bei mir kommen aus dem Proxmoxadapter nur Sekunden.
                              Wie hast Du das gelöst??
                              Knusterus
                                @Knusterus
                                Das rechnet ein blockly skript für mich um...
                                  @saeft_2003
                                  Würdest Du mir es bitte zur Verfügung stellen.
                                  Da hast du ja wirklich was ausgetüftelt, Hut ab...👍 👍
                                  Vielen Dank
                                  Knusterus
                                  S Kalle Blomquist 2 Replies Last reply Reply Quote 0
                                    @Knusterus
                                    Hier bitte, aber das nachbauen wäre doch jetzt auch kein ding gewesen...
                                    <block xmlns="http://www.w3.org/1999/xhtml" type="on" id="VqJ%~W+WNHMjJja./5lo" x="688" y="638">
                                      <field name="OID">synology.0.DiskStationManager.info.uptime</field>
                                        <block type="variables_set" id="F5(vdm$0YlSf)JEhaui{">
                                          <field name="VAR" id="PtI/@;j1mCgZ=}!^nvXX" variabletype="">uptime diskstation</field>
                                            <block type="math_arithmetic" id="eUHp*rwNCD;P0n4;^22/">
                                              <field name="OP">DIVIDE</field>
                                                <shadow type="math_number" id="FNIYlKgjc//XONw5eSe}">
                                                  <field name="NUM">1</field>
                                                <block type="get_value" id="/:xeRTnSX25b6/|p]CSj">
                                                <shadow type="math_number" id="Qy9Y[oLQs0:;%{_ygF}x">
                                                  <field name="NUM">86400</field>
                                            <block type="variables_set" id="n6;?0rx9D.9whcc?aF6D">
                                              <field name="VAR" id="(PhRGpL]gjR4z=$:@wy}" variabletype="">uptime diskstation runde</field>
                                                <block type="math_round" id="AEyWM/7)ZOZk{Qa(JE7q">
                                                  <field name="OP">ROUND</field>
                                                  <value name="NUM">
                                                    <shadow type="math_number" id="FZzx,BFTWr_VuDg4@VR#">
                                                      <field name="NUM">3.1</field>
                                                    <block type="variables_get" id="XaaxFG;DH7@71e!AS)7W">
                                                <block type="timeouts_settimeout" id="RT%YBk=cqd+2b:E7-;rg">
                                                  <field name="NAME">timeout4</field>
                                                  <field name="DELAY">1000</field>
                                                  <field name="UNIT">ms</field>
                                                    <block type="control" id="l]IBhU44KX^hdEhF$D3i">
                                                      <field name="OID">synology.0.DiskStationManager.info.uptime_tage</field>
                                                        <block type="variables_get" id="_hNJ^i-4%_%6CK]C+hwS">
                                    • Glasfaser
                                      Glasfaser @saeft_2003 last edited by
                                      @saeft_2003
                                      Ok ... das ist der Style " groove " bei CSS Ränder , da ist der Effekt/Fehler schon immer gewesen.
                                      Ich denke mal auf " solide " willst du dann nicht ändern , sieht ( fast ) gleich aus :
                                        @Glasfaser
                                        ich hatte groove gewählt, weil es meiner Meinung nach so einen kleinen 3D Effekt hat
                                          @saeft_2003
                                          Prima Danke ,für den Code. Für mich wäre das selber bauen schon ein Problem, so fit bin ich noch nicht. Der Code funktioniert auch super.
                                          Jetzt habe ich aber ein neues Problem, wenn ich die Seite über den FullyBrowser aurufe ,dauert es fast 2 min bis sich die Seite komplett aufgebaut hat.
                                          Die anderen Seiten sind sofort da. Wie hast Du das gelöst??
                                          Gibt es vielleicht die Möglichkeit ,das sich die Seite im Hintergrund immer aktuallisiert?
                                          Im i-Frame Widget habe ich die Aktuallisierung schon mal auf 1 min gestellt,hat aber nix gebracht.
                                          Knusterus
                                            @Knusterus
                                            Auf was läuft der FullyBrowser? Ich denke dein Backend hat zu wenig Leistung. Ich hatte erst ein beelink bt3 pro, da hat das laden vom proxmox view auch ca 2 min gedauert.
                                            Deswegen habe ich mir ein NUC8i3 geholt, da waren es dann unter 20 Sekunden mit Edge und nachdem ich noch umgestiegen bin auf chrome sind es jetzt noch ca. 10 Sekunden. Damit kann ich jetzt leben...
                                            Die update Zeit vom iframe steht bei mir auf 0. Weil je nachdem was du in grafana eingestellt hast, wird der chart aktualisiert (zu erkennen an dem kleinen drehenden Kreis rechts oben).
                                            vis
                                            45
                                            339
                                            85817
