    3. Entwicklung
    4. lgtv Adapter zur Steuerung von LG WebOS SmartTVs
      Seraphis @dirkhe last edited by
      @dirkhe Klappt bei mir jetzt beides einwandfrei. Vielen Dank fürs anpassen 🙂
      Wechsel/Schließen der App:
      2020-03-10 21:44:12.390  - debug: lgtv.0 (20145) check TV connection: ok
      2020-03-10 21:44:25.534  - debug: lgtv.0 (20145) DEBUGGING getForegroundAppInfo: {"subscribed":true,"appId":"com.webos.app.hdmi1","returnValue":true,"windowId":"","processId":""}
      2020-03-10 21:44:25.535  - debug: lgtv.0 (20145) cur app is com.webos.app.hdmi1
      2020-03-10 21:44:35.654  - debug: lgtv.0 (20145) DEBUGGING getForegroundAppInfo: {"subscribed":true,"appId":"amazon","returnValue":true,"windowId":"","processId":""}
      2020-03-10 21:44:35.654  - debug: lgtv.0 (20145) cur app is amazon
      2020-03-10 21:44:50.922  - debug: lgtv.0 (20145) DEBUGGING getForegroundAppInfo: {"subscribed":true,"appId":"","returnValue":true,"windowId":"","processId":""}
      2020-03-10 21:44:51.958  - debug: lgtv.0 (20145) DEBUGGING getForegroundAppInfo: {"subscribed":true,"appId":"com.webos.app.hdmi1","returnValue":true,"windowId":"","processId":""}
      2020-03-10 21:44:51.958  - debug: lgtv.0 (20145) cur app is com.webos.app.hdmi1
      2020-03-10 21:45:12.368  - debug: lgtv.0 (20145) check TV connection: ok
      Verhalten beim Ausschalten des TVs:
      2020-03-12 18:38:47.101  - debug: lgtv.0 (20145) check TV connection: ok
      2020-03-12 18:39:47.093  - debug: lgtv.0 (20145) check TV connection: ok
      2020-03-12 18:41:02.051  - debug: lgtv.0 (20145) ERROR! Response from TV: Error: timeout
      2020-03-12 18:41:02.052  - debug: lgtv.0 (20145) check TV connection: Error: timeout
      2020-03-12 18:41:02.052  - debug: lgtv.0 (20145) TV is off
      2020-03-12 18:42:02.051  - debug: lgtv.0 (20145) ERROR! Response from TV: Error: timeout
      2020-03-12 18:42:02.052  - debug: lgtv.0 (20145) check TV connection: Error: timeout
      2020-03-12 18:42:02.052  - debug: lgtv.0 (20145) TV is off
      2020-03-12 18:53:02.056  - debug: lgtv.0 (20145) ERROR! Response from TV: Error: timeout
      2020-03-12 18:53:02.056  - debug: lgtv.0 (20145) check TV connection: Error: timeout
      2020-03-12 18:53:02.056  - debug: lgtv.0 (20145) TV is off
      2020-03-12 18:56:02.057  - debug: lgtv.0 (20145) ERROR! Response from TV: Error: timeout
      2020-03-12 18:56:02.058  - debug: lgtv.0 (20145) check TV connection: Error: timeout
      2020-03-12 18:56:02.058  - debug: lgtv.0 (20145) TV is off
      2020-03-12 18:56:14.428  - debug: lgtv.0 (20145) Error on connecting or sending command to WebOS TV: Error: read EHOSTUNREACH
      2020-03-12 18:56:14.428  - debug: lgtv.0 (20145) Connection closed: 1006
      2020-03-12 18:56:19.428  - debug: lgtv.0 (20145) Connecting to WebOS TV: ws://192.168.178.106:3000
      2020-03-12 18:56:22.434  - debug: lgtv.0 (20145) Error on connecting or sending command to WebOS TV: Error: connect EHOSTUNREACH 192.168.178.106:3000
      2020-03-12 18:56:24.428  - debug: lgtv.0 (20145) TV is off
      2020-03-12 18:56:27.434  - debug: lgtv.0 (20145) Connecting to WebOS TV: ws://192.168.178.106:3000
      2020-03-12 18:56:29.428  - debug: lgtv.0 (20145) TV is off
      2020-03-12 18:56:35.441  - debug: lgtv.0 (20145) Connecting to WebOS TV: ws://192.168.178.106:3000
      2020-03-12 18:56:37.436  - debug: lgtv.0 (20145) TV is off
      Zwischen dem ersten timeout-error und dem host unreachable lagen auch gestern ca. 15 Minuten.
      Macht es eigentlich Sinn die Parameter für timeout und den neuen für das Abfrageintervall in der Adapter-konfig noch in irgend einer Form anzupassen? Verwende momentan die Standard-Werte 15.000 bzw. 60.000ms
        dirkhe Developer @Seraphis last edited by
        @Seraphis das freut mich, dann werde ich das mal zusammenpacken und ein Problem stellen.
        Die Zeiten muss jeder für sich selber wissen. Das hängt halt damit zusammen, was du für Aktionen hinter tv an/aus hast und wie schnell die reagieren sollen
        sigi234 S 2 Replies Last reply Reply Quote 0
          sigi234 Forum Testing Most Active @dirkhe last edited by
          @dirkhe
          Bekomme nur die V 1.1.5 via Git?
            dirkhe Developer last edited by
            Aktuell nur über meinen Account https://github.com/dirkhe/ioBroker.lgtv
            Muss erst ein Pull request stellen
              @dirkhe sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
              $ ./iobroker url "https://github.com/dirkhe/ioBroker.lgtv.git"
              install https://github.com/dirkhe/ioBroker.lgtv/tarball/044ccbd852bd5ea5280c59a17eb20fe3c75ccce7
              NPM version: 6.9.0
              npm install https://github.com/dirkhe/ioBroker.lgtv/tarball/044ccbd852bd5ea5280c59a17eb20fe3c75ccce7 --loglevel error (System call)
              gyp
              ERR!
               build error
              gyp
              ERR!
               stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1gyp
              ERR!
              stack
                   at ChildProcess.onExit (C:\Program Files\iobroker\Test\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)gyp
              ERR!
              stack
                   at ChildProcess.emit (events.js:198:13)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
              gyp
              ERR!
               System Windows_NT 10.0.18363
              gyp
               ERR!
              command
               "C:\\Program Files\\iobroker\\Test\\nodejs\\node.exe" "C:\\Program Files\\iobroker\\Test\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\Program Files\iobroker\Test\node_modules\authenticate-pamgyp ERR! node -v v10.16.3gyp ERR!
               node-gyp -v
               v3.8.0gyp
              ERR! not ok
              gyp
               ERR! build error
              gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1gyp ERR!
              stack
              gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack
              gyp
               ERR! System Windows_NT 10.0.18363gyp ERR! command "C:\\Program Files\\iobroker\\Test\\nodejs\\node.exe" "C:\\Program Files\\iobroker\\Test\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\Program Files\iobroker\Test\node_modules\bufferutilgyp ERR! node -v v10.16.3
              gyp ERR! node-gyp -v v3.8.0gyp
              ERR!
              not ok
              gyp
               ERR!
              build error
              gyp
              ERR! stack
              gyp ERR!
              stack     at ChildProcess.onExit (C:\Program Files\iobroker\Test\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
              gyp ERR!
               stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
              gyp
              ERR! System
               ERR!
               ERR!
              cwd C:\Program Files\iobroker\Test\node_modules\unix-dgram
              gyp ERR!
               node -v
               v10.16.3gyp ERR! node-gyp -v v3.8.0
              gyp ERR! not ok
              gyp
              ERR!
              build error
              gyp
               ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1gyp ERR! stack     at ChildProcess.onExit (C:\Program Files\iobroker\Test\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
              gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp
              gyp ERR! cwd C:\Program Files\iobroker\Test\node_modules\utf-8-validategyp ERR! node -v v10.16.3
              gyp ERR!
              node-gyp -v v3.8.0
              gyp
              ERR! not ok
              upload [3] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/words.js words.js application/javascript
              upload [2] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/lgtv.png lgtv.png image/png
              upload [1] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/index_m.html index_m.html text/html
              upload [0] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/index.html index.html text/html
              process exited with code 0
                Ich weiss nicht, ob das was mit dem adapter zu tun hat, vlt kannst du mal den originalen nochmal installieren, ob das klappt. Wenn du den adapter aber mal startest, was steht denn dann im Log als Version?
                  sigi234 Forum Testing Most Active @dirkhe last edited by sigi234
                  Interessant:
                  lgtv.0	2020-03-12 21:18:40.973	info	(13820) Ready. Configured WebOS TV IP: 192.168.178.41
                  lgtv.0	2020-03-12 21:18:40.956	info	(13820) starting. Version 1.1.6-RC01 in C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv, node: v10.16.3
                  host.Medion(Test)	2020-03-12 21:18:39.150	info	instance system.adapter.lgtv.0 started with pid 13820
                    Dann hast du die richtige Version, was da in der Info steht ist bei Entwicklung unwichtig.
                      @dirkhe Wäre es nicht gut, dann auch noch das Intervall, in dem versucht wird die Verbindung zum TV herzustellen, anpassbar zu machen? Das liegt aktuell ja bei 8s:
                      lgtv.0	2020-03-14 08:24:35.344	debug	(27131) Connecting to WebOS TV: ws://192.168.178.106:3000
                      lgtv.0	2020-03-14 08:24:37.337	debug	(27131) TV is off
                      lgtv.0	2020-03-14 08:24:43.353	debug	(27131) Connecting to WebOS TV: ws://192.168.178.106:3000
                      lgtv.0	2020-03-14 08:24:45.345	debug	(27131) TV is off
                        @SchuetzeSchulz die reconnect time ist aktuell hart auf 5 sec eingestellt. Das ist auch die Default Zeit von hobyquackers lib. Macht es Sinn die einstellbar zu machen, hattet ihr da in der Vergangenheit mal getestet?
                          SchuetzeSchulz @dirkhe last edited by
                          Hatten wir nicht getestet. Mir ist nur damals aufgefallen alles unter 5 Sekunden führt zu Problemen.
                            OK, ich habe die reconnect time jetzt mal konfigurierbar gemacht. https://github.com/dirkhe/ioBroker.lgtv
                            Könnt ihr ja mal testen. Wenn das soweit passt, würde ich einen Merge Request stellen
                              FloW da FunK @rh1212 last edited by FloW da FunK
                              @rh1212
                              Hallo rh1212 und Community!
                              Ich bin ein kompletter Neuling was ioBroker betrifft und habe es mittels der Anleitung von rh1212 soweit geschafft, dass ich über die "launch app" des LG TV Adapter, unter Erstellung der Objekte und Verwendung von Blockly, gewisse "Apps" auf meinem LG TV zum starten bringe. Wenn ich bei den erstellten Objekten in ioBroker den Button dahinter anklicke, startet auch auf meinem TV jede App die ich anklicke. In Blockly habe ich im Baustein TEXT immer den Wert eingetragen, welchen mir das Objekt Launch App als Wert angezeigt hat (z.B. für HDMI-1 -> com.webos.app.hdmi1) eingetragen.
                              Ich binde dann diese Objekte in dem iot.0 Adapter unter "Alexa-Geräte" ein. Jedoch sagt mir der Adapter, dass er manche Objekte nicht einbinden möchte (siehe Screenshot). Warum macht der Adapter das??? Gibt es da vielleicht eine andere Lösung?
                              Auch im Log kann ich keine Fehlermeldung finden.
                              Danke im Voraus für eure Hilfe 😉
                              EDIT: Ich versuche die ganzen Befehle natürlich mittels Echo-dot umzusetzen.
                                Hast du den smartname korrekt gesetzt? Passt Role und Type ?
                                  FloW da FunK @dirkhe last edited by FloW da FunK
                                  @dirkhe
                                  Ich habe das alles so wie im Screenshot rechts oben eingegeben. Rolle ist bei allen state und Type bei allen button.
                                  Was verstehst du unter Smartname? Die ID oder den Namen... entschuldige ich bin wirklich ein Noob gg versuche aber dazu zu lernen. 😉
                                  Also wie beschrieben funktionieren auch alle button in ioBroker ohne Probleme, jedoch bekomme ich bei der Einbindung in iot.0 Adapter bei mehreren "App's" die im oben angeführten Screenshot angezeigte Botschaft.
                                  "Gerät lgtv.0.Extras_Ordner.Netflix wurde nicht hinzugefügt.
                                  EDIT: Habe jetzt ein 'Wake on lan' Script eingebaut und versucht dieses im iot.0 Adapter unter Alexa-Geräte einzubinden. Auch da bekam ich die "Botschaft", dass es nicht hinzugefügt wurde. Es liegt also glaube ich nicht am lgtv.0 Adapter, denn auch die "Wake on Lan" Funktion startet in ioBroker ganz normal. Es wird wohl am iot.0 Adapter liegen.....
                                  Danke für deine Hilfe
                                  Lg
                                    Geh mal in der Object Ansicht auf den Bleistift. Dann unter RAW, da siehst du den smartname
                                      "_id": "lgtv.0.states.power",
                                      "type": "state",
                                      "common": {
                                        "name": "Switch TV power",
                                        "role": "switch",
                                        "type": "boolean",
                                        "read": true,
                                        "write": true,
                                        "smartName": {
                                          "de": "Tv,Fernseher"
                                      "native": {},
                                      "acl": {
                                        "object": 1636,
                                        "state": 1636,
                                        "owner": "system.user.admin",
                                      "user": "system.user.admin",
                                      "ts": 1584040988961
                                      "smartName": { "de": "Tv,Fernseher" }
                                      Hallo dirkhe!
                                      Beim durchstöbern des Forum habe ich bemerkt, dass mehrere User seit Anfang März probleme mit der Einbindung von Geräten in iot.0 Adapter haben.
                                      Siehe Link: https://forum.iobroker.net/topic/11288/cloud-adapter-smart-gerät-hinzufügen-geht-nicht/26
                                      Es liegt also definitiv nicht am lgtv.0 adapter.
                                        "ts": 1584970466099,
                                        "common": {
                                          "name": "Amazon Prime Video",
                                          "role": "button",
                                          "type": "object",
                                          "desc": "Manuell erzeugt",
                                          "read": true,
                                          "write": true
                                          "smartName": "Amazon"
                                        "native": {},
                                        "acl": {
                                          "object": 1636,
                                          "state": 1636
                                        "_id": "lgtv.0.Extras_Ordner.Amazon_Prime_Video",
                                        "type": "state"
                                      Wenn ich den Smartname im RAW zu ändern versuche und das Ganze speichere, zeigt er mir sofort eine Fehlermeldung an.Fehler beim Parsen.jpg
                                      Ich werde die ganzen Einbindungen in iot.0 Adapter mit dem kleinen Workaround machen müssen, wie sie im anderen Thread beschrieben sind.
                                      Vielen DANK für deine Bemühungen!!!!
                                        @dirkhe
                                        Problem gelöst!!!
                                        Ich hab einfach den Typ von Button auf Switch geändert und siehe da! Es lässt sich in iot.0 Adapter integrieren und der Sprachbefehl via ALEXA funktioniert auch!!!
                                        Nochmals DANKE für deine Bemühungen und gesund bleiben! 😉
                                          kniwweli @knx last edited by
                                          @knx hast du es hinbekommen mit netflix?
                                            killroy2 last edited by
                                            ich verwende Version 1.1.6.
                                            Wenn ich Wert false auf
                                            lgtv.0.states.power
                                            schreibe geht der Fernseher aus, soweit okay.
                                            Schreibe ich nochmal false, geht der Fernseher an. Ist das plausibel oder ein Fehler?
                                            Vielen Dank
                                            lgtv
                                            113
                                            861
                                            312402
