      crunchip Forum Testing Most Active last edited by crunchip
      @SBorg also nochmal von vorn
      • VM neu gestartet
        *Ausgabe grep
      root@IoBroker:~# ps -aux | grep wetterstation.sh
      root       695  0.4  0.0  11548  3344 ?        S    13:53   0:00 /bin/bash /home/iobroker/wetterstation.sh
      root      2297  0.0  0.0  11548  2092 ?        S    13:55   0:00 /bin/bash /home/iobroker/wetterstation.sh
      root      2302  0.0  0.0  12780  1016 pts/0    S+   13:55   0:00 grep wetterstation.sh
      Werte für javascript.0.Wetterstation._Kommunikationsfehler (mein Abfrageintervall ist 30 sec)
      false 	true 	simple-api.0 	2020-03-14 13:52:26.944
      true 	true 	simple-api.0 	2020-03-14 13:52:32.131
      nur so am Rande gefragt, im log hab ich gerade gesehen(durch den Neustart)
      host.IoBroker	2020-03-14 13:57:18.088	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
      host.IoBroker	2020-03-14 13:57:18.087	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      host.IoBroker	2020-03-14 13:57:18.087	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      host.IoBroker	2020-03-14 13:57:18.087	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
      host.IoBroker	2020-03-14 13:57:18.086	error	Caught by controller[0]: TypeError: Cannot read property 'common' of null
      simple-api.0	2020-03-14 13:57:17.534	info	(3520) Terminated (NO_ERROR): Without reason
      simple-api.0	2020-03-14 13:57:17.533	info	(3520) terminating
      simple-api.0	2020-03-14 13:57:17.510	info	(3520) terminating http server on port 8087
      simple-api.0	2020-03-14 13:57:17.508	error	at process._tickCallback (internal/process/next_tick.js:68:7)
      simple-api.0	2020-03-14 13:57:17.508	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      simple-api.0	2020-03-14 13:57:17.508	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      simple-api.0	2020-03-14 13:57:17.508	error	at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
      simple-api.0	2020-03-14 13:57:17.508	error	(3520) TypeError: Cannot read property 'common' of null
      simple-api.0	2020-03-14 13:57:17.506	error	(3520) uncaught exception: Cannot read property 'common' of null
      • SBorg
        SBorg Forum Testing Most Active @crunchip last edited by
        @crunchip sagte in [Linux Shell-Skript] WLAN-Wetterstation:
        Jepp, Skript läuft doppelt. Daher bekommst du gelegentlich Werte, Direkttests funktionieren deswegen auch nicht (der Port ist durch die 1. Instanz bereits belegt)
        Die "13:53 Uhr" dürfte der Autostart vom Reboot sein, aber wo die "13:55 Uhr" herkommt? Oder hattest du da zwischenzeitlich das Skript manuell gestartet? Oder hast du es ev. doppelt in der crontab stehen?
        Das erklärt dann natürlich auch warum der "Kommunikationsfehler" so schnell kommt. Da werkelt die eine Instanz noch, wird von der 2. blockiert und meckert dann natürlich zu Recht 😉
        und wenn dann sich noch mit
        der Simple-API verabschiedet geht sowieso auch im ioB nüscht mehr.
        crunchip Glasfaser 2 Replies Last reply Reply Quote 0
          crunchip Forum Testing Most Active @SBorg last edited by crunchip
          @SBorg wie kann bitte das script doppelt laufen?
          es war lediglich ein Neustart der VM,(kein manuelles starten des scripts)
          anschliessend habe ich ps -aux | grep wetterstation.sh aufgerufen,
          mit dem Ergebnis von oben.
          ein crontab ist nur einmal eingetragen
          @reboot /home/iobroker/wetterstation.sh &
          2 0 * * * pkill -9 wetterstation.* && /home/iobroker/wetterstation.sh &
          @SBorg sagte in [Linux Shell-Skript] WLAN-Wetterstation:
          die Uhrzeit ändert sich, wenn ich den Befehl erneut ausführe, also immer die aktuelle Uhrzeit beim Befehlsaufruf
          ? 2 Replies Last reply Reply Quote 0
            A Former User @crunchip last edited by
            @crunchip bei welchem User hast du den Cron eingetragen? Jeder user hat seinen eigenen Cron.. nicht vergessen.. da hab ich mir auch schon ein paar Eigentore geschossen, weil ein Cron beim falschen user drin war...
            crunchip 2 Replies Last reply Reply Quote 0
              @crunchip also zum nachvollziehen, ein "sudo crontab -e " ist eine andere also einfach nur crontab -e 🙂
                crunchip Forum Testing Most Active @Guest last edited by
                @ilovegym ich bin mit root drauf
                  @ilovegym aber danke für den Hinweis, hab mal mit sudo eingegeben
                  ist ein anderes temp/crontab.xxxxx
                  also bewusst hatte ich kein sudo eingegeben, ist dann wohl scheinbar zu Anfangszeiten durch copy and past passiert, das nochmal ein zweiter crontab gesetzt wurde.
                  • Glasfaser
                    Glasfaser @SBorg last edited by
                    @SBorg
                    Ist ja richtig was los hier 🙂
                    Die Version V1.0.0 funktioniert sehr gut ... Danke ....
                    SBorg 1 Reply Last reply Reply Quote 1
                    • Nashra
                      Donnerwetter bei mir lief wetterstation.sh auch zweimal, obwohl es nur in einer cron drin war/ist.
                      Aber ich habe ein größeres Problem bei Regen_Monat und Regen_Woche.
                      Ich kann einstellen in der History/Influxdb was ich will, es werden keine Daten geschrieben, alle anderen Daten sind vorhanden. Weiß einfach nicht mehr weiter 😞
                      History:
                      67.1 	false 		2020-03-14 16:30:39.121
                      67.1 	false 		2020-03-14 16:30:12.899
                      67.1 	false 		2020-03-14 16:29:46.670
                      Influxdb:
                      null 	false 	influxdb.0 	2020-03-14 17:10:17.628
                      null 	false 	influxdb.0 	2020-03-14 17:10:36.632
                      null 	false 	influxdb.0 	2020-03-14 17:10:36.644
                      • Glasfaser
                        Glasfaser @Nashra last edited by Glasfaser
                        @Nashra
                        Wird denn der Datenpunkt aktualisiert !?
                        Zeige mal die Debug Ausgabe in Putty was dann kommt !
                        ./wetterstation.sh --debug
                        • Nashra
                          Nashra Most Active Forum Testing @Glasfaser last edited by
                          @Glasfaser sagte in [Linux Shell-Skript] WLAN-Wetterstation:
                          @Nashra
                          • Glasfaser
                            @Nashra
                            Laut Gesamtansicht sind die Werte da .
                            Da fehlt aber der Abschnitt mit den Datenpunkten ,da kannst du es auch erkennen das sie gesendet werden bzw. welcher Wert gesendet wird ...
                            • Nashra
                              @Nashra
                              Werte kommen alle rein und stehen auch im io in den DP. Im History.0 sind sie ja auch drin,
                              nur eben die Werte von Regen_Monat und Regen_Woche stehen nicht in Influxdb.0 drin.
                              Alle anderen Werte/Daten sind in Influxdb vorhanden.
                                @SBorg kann es möglich sein, das mit der neuen version wieder das Problem besteht, was ich ganz am Anfang hatte, wegen Proxmox VM, falls du dich erinnern kannst (im Thread ganz am Anfang).
                                da musst ich ja das -p einfügen in dieser Zeile
                                DATA=$(timeout ${WARTE} nc -lv -p ${WS_PORT}|sed '3 p')
                                in v1.0 sieht die Zeile so aus
                                DATA=$(timeout ${WARTE} nc -lvw 1 -p ${WS_PORT}|sed -n '1 p')
                                da scheinbar bei mir ja vorhin irgendwas doppelt lief, hab ichs nochmal neu gemacht.
                                Jedoch bekomm ich mit v1.0 keine Werte rein
                                root@IoBroker:/home/iobroker# ./wetterstation.sh --debug
                                listening on [any] 55555 ...
                                no connection : Connection timed out
                                Messwerteblock:
                                Temperatur Innen : °C
                                Temperatur Aussen : °C
                                Taupunkt : °C
                                Chill-Faktor : °C
                                Luftfeuchte Innen : %
                                Luftfeuchte Aussen : %
                                Windgeschwindkeit : km/h
                                max. Windgeschwindkeit : km/h
                                Windrichtung : °
                                Windrichtung :
                                Luftdruck absolut : hPa
                                Luftdruck relativ : hPa
                                Regenrate : mm/h
                                Regen Tag : mm
                                Regen Woche : mm
                                Regen Monat : mm
                                Regen Jahr : mm
                                Sonnenstrahlung : W/m²
                                UV-Index :
                                Zeitstempel :
                                Datenstring für ioBroker:
                                DATA von Wetterstation:
                                Debug VAR:
                                Installationsverzeichnis: /home/iobroker
                                IPP: 10.1.1.10:8087 WS_PORT: 55555 WS_POLL: 30 PRE_DP: javascript.0.Wetterstation
                                Script-Version: V1.0.0 Config-Version: V1.0.0 Sub-Version: V1.0.0
                                bin zurück auf die 0.1.4 und läuft wieder
                                Messwerteblock: 72.5 45.0 36.1 45.0 39 71 0.9 1.1 58 29.238 29.968 0.000 0.000 0.681 1.449 0 0.00 0 2020-03-14 %2017:25:31
                                Temperatur Innen : 22.50 °C
                                Temperatur Aussen : 7.22 °C
                                Taupunkt : 2.27 °C
                                Chill-Faktor : 7.22 °C
                                Luftfeuchte Innen : 39 %
                                Luftfeuchte Aussen : 71 %
                                Windgeschwindkeit : 1.44 km/h
                                max. Windgeschwindkeit : 1.77 km/h
                                Windrichtung : 58 °
                                Luftdruck absolut : 990.11 hPa
                                Luftdruck relativ : 1014.83 hPa
                                Regen aktuell : 0 mm
                                Regen Tag : 0 mm
                                Regen Woche : 17.2 mm
                                Regen Monat : 36.8 mm
                                Regen Jahr : 0 mm
                                Sonnenstrahlung : 0.00 W/m²
                                UV-Index : 0
                                Zeitstempel : 14.03.2020 18:25:31
                                javascript.0.Wetterstation.Innentemperatur=22.50&javascript.0.Wetterstation.Aussentemperatur=7.22&javascript.0 .Wetterstation.Taupunkt=2.27&javascript.0.Wetterstation.Chillfaktor=7.22&javascript.0.Wetterstation.Innenfeuch tigkeit=39&javascript.0.Wetterstation.Aussenfeuchtigkeit=71&javascript.0.Wetterstation.Wind=1.44&javascript.0. Wetterstation.Wind_max=1.77&javascript.0.Wetterstation.Windrichtung=58&javascript.0.Wetterstation.Druck_absolu t=990.11&javascript.0.Wetterstation.Druck_relativ=1014.83&javascript.0.Wetterstation.Regen_aktuell=0&javascrip t.0.Wetterstation.Regen_Tag=0&javascript.0.Wetterstation.Regen_Woche=17.2&javascript.0.Wetterstation.Regen_Mon at=36.8&javascript.0.Wetterstation.Regen_Jahr=0&javascript.0.Wetterstation.Sonnenstrahlung=0.00&javascript.0.W etterstation.UV_Index=0&javascript.0.Wetterstation.Zeitstempel=14.03.2020 18:25:31
                                GET /weatherstation/updateweatherstation.php?ID=&PASSWORD=&indoortempf=72.5&tempf=45.0&dewptf=36.1&w indchillf=45.0&indoorhumidity=39&humidity=71&windspeedmph=0.9&windgustmph=1.1&winddir=58&absbaromin=29.238&bar omin=29.968&rainin=0.000&dailyrainin=0.000&weeklyrainin=0.681&monthlyrainin=1.449&yearlyrainin=0&solarradiatio n=0.00&UV=0&dateutc=2020-03-14%2017:25:31&softwaretype=EasyWeatherV1.4.7&action=updateraw&realtime=1&rtfreq=5 Connection: Close
                                Debug VAR:
                                Script-Version: V0.1.4 Config-Version: V0.1.4
                                • Glasfaser
                                  @Nashra
                                  Zeige mal die Einstellungen von Influx ( Datenpunkt )
                                  • Nashra
                                    @Nashra
                                    • Glasfaser
                                      @Nashra
                                      Stelle mal so ein ....
                                      • Nashra
                                        Nashra Most Active Forum Testing @Glasfaser last edited by Nashra
                                        @Glasfaser habs geändert. Ergebnis nach Neustart des Adapters
                                        Sorry, aber ich kapiere das nicht das keine Daten geschrieben werden 😵
                                        • Glasfaser
                                          @Nashra
                                          Hast du mal Testweise einen neuen Datenpunkt mit influx geloggt , bzw. jetzt mal neu angelegt ob es auch dort kommt das " null" geschrieben wird !?
                                          • Nashra
                                            @Nashra
                                            Jap, mal eben die Wattzahl der USV geloggt, 1a alle Daten da d.h. Verbrauch schwankt zwar aber wird geloggt.
                                            152
                                            5661
                                            3769636
