    4. JavaScript
    5. Energieanzeige (kWh) über HTML Tabelle - vis
      liv-in-sky @PatrickFro last edited by
      @PatrickFro kannst du mal bitte den inhalt des datenpunktes für das materialdesign table widget posten ?
      • O
        Oli @liv-in-sky last edited by Oli
        @liv-in-sky
        ich habe vielleicht auch noch eine interessante Variante für deine Sammlung
        [{"tpl":"tplVis-materialdesign-Icon-List","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","wrapItems":true,"listItemDataMethod":"jsonStringObject","countListItems":"1","vibrateOnMobilDevices":"50","listLayout":"card","itemLayout":"vertical","listType0":"text","showValueLabel0":"true","listType1":"text","showValueLabel1":"true","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"json_string_oid":"javascript.0.Energieverbrauch.Strom.EnergyMaterialWidge","maxItemsperRow":"7","iconItemMinWidth":"280","iconHeight":"60","buttonHeight":"","labelFontSize":"16","subLabelFontSize":"14","subLabelFontColor":"#8f8f8f","labelFontFamily":"Arial, Helvetica, sans-serif","subLabelFontFamily":"Arial, Helvetica, sans-serif","horizontalIconContainerWidth":"","listImage0":"","autoLockAfter":"10","lockIconTop":"5","lockIconLeft":"5","lockFilterGrayscale":"30","lockApplyOnlyOnImage":"true","verticalIconContainerHeight":"80","buttonLayout":"full","itemBackgroundColor":"#2e2e2e","labelFontColor":"#d7cec1"},"style":{"left":"23px","top":"308px","width":"calc(100% - 40px)","height":"calc(100% - 120px)","overflow-x":"","overflow-y":"auto","z-index":"1","color":"#8f8f8f"},"widgetSet":"materialdesign"}]
        Subtextänderungen im Script ab Zeile 1530
        mysubText =     `<div>Strom: ${vax3} A</div>
                              <div>Spannung: ${vax4} V</div>
                              <div>Leistung: ${vax5} W</div>
                              <div>Heute: ${vax7} kWh</div>
                              <div>Monat: ${vax8} kWh</div>
                              <div>Heute: ${vax9} €</div>
                              <div>Monat: ${vax10} €</div>`
        liv-in-sky 1 Reply Last reply Reply Quote 1
        • O
          @liv-in-sky said in Energieanzeige (kWh) über HTML Tabelle - vis:
          wie has du eigentlich die marke in die 2te spalte bekommen ?
          das funktioniert, wenn du in deinem Script bei der Json Bildung die Marke als zweites einfügst und anschließend im Widget die Spalten neu konfigurierst.
            liv-in-sky @Oli last edited by
            @Oli danke, dass weiß ich - ich wollte eigentlich wissen, ob @PatrickFro das script verändert hat 🙂 - wegen den bildern
              liv-in-sky @Oli last edited by liv-in-sky
              @Oli das sieht gut aus - ich wollte nur nicht so viel platz verschwenden , wenn man mehr von den geräten hat, wird es sonst zu lange
              poste doch deine "subtext"einstellung , damit andere das auch haben
                PatrickFro @Oli last edited by
                @Oli Schreibweise ist bei beiden die selbe, nur erster Buchstabe groß.
                @liv-in-sky Das Widget aus dem ersten Post passte nicht, die Daten waren an anderer Stelle. Somit habe ich weitere Spalten hinzugefügt, aber nichts an sich geändert.
                let braucheMaterialDesignWidgetTable=false; , daher habe ich kein Table. Wenn ich es aktiviere kommt folgendes:
                [{"Device":"<font color='#00BFFF'>alle Geräte</font>","Status":"🔹","Strom":" - ","Spannung":" - ","Power":" - ","Schalter":" - ","kWhNow":"0 ","kWhMonat":"0","PreisNow":"0.00","PreisMonat":"0.00","marke":"/vis.0/Icons/infok.png"}]
                  @PatrickFro was kommt nach ein oder 2 minuten ? bleibt der inhalt gleich
                  • O
                    habe ich in meinem Poste hinzugefügt.
                    Andere Frage kann ich im Subtext Leerzeilen einfügen und wenn ja wie?
                      PatrickFro @liv-in-sky last edited by
                      @liv-in-sky jetzt ist es:
                      [{"Device":"Couchlicht","Status":"🔹","Strom":" - ","Spannung":" - ","Power":"0","Schalter":" <font color=\"#58ACFA\"> OFF","kWhNow":"2.940 ","kWhMonat":"7.521","PreisNow":"1","PreisMonat":"2.56","marke":"/vis.0/Icons/virtualpowermeterk.png"},{"Device":"Fernseher Gästezimmer","Status":"🔹","Strom":" - ","Spannung":" - ","Power":"0","Schalter":" <font color=\"#58ACFA\"> OFF","kWhNow":"0 ","kWhMonat":"0","PreisNow":"0","PreisMonat":"0","marke":"/vis.0/Icons/virtualpowermeterk.png"},{"Device":"Vitrine","Status":"🔹","Strom":" - ","Spannung":" - ","Power":"0","Schalter":" <font color=\"#58ACFA\"> OFF","kWhNow":"0 ","kWhMonat":"0.021","PreisNow":"0","PreisMonat":"0.01","marke":"/vis.0/Icons/virtualpowermeterk.png"},{"Device":"Großes Bad","Status":"🔹","Strom":"0","Spannung":"0","Power":"0","Schalter":" <font color=\"#0080FF\"> OFF","kWhNow":"0.002 ","kWhMonat":"0.100","PreisNow":"0","PreisMonat":"0.03","marke":"/vis.0/Icons/shellyk.png"},{"Device":"Großes Bad(2)","Status":"🔹","Strom":"0","Spannung":"0","Power":"0","Schalter":" <font color=\"#0080FF\"> OFF","kWhNow":"0.001 ","kWhMonat":"0.053","PreisNow":"0","PreisMonat":"0.02","marke":"/vis.0/Icons/shellyk.png"},{"Device":"Gästezimmer","Status":"🔹","Strom":"0","Spannung":"0","Power":"0","Schalter":" <font color=\"#0080FF\"> OFF","kWhNow":"0 ","kWhMonat":"0.051","PreisNow":"0","PreisMonat":"0.02","marke":"/vis.0/Icons/shellyk.png"},{"Device":"Gästezimmer(2)","Status":"🔹","Strom":"0","Spannung":"0","Power":"0","Schalter":" <font color=\"#0080FF\"> OFF","kWhNow":"0 ","kWhMonat":"0.148","PreisNow":"0","PreisMonat":"0.05","marke":"/vis.0/Icons/shellyk.png"},{"Device":"Küche und Vitrine","Status":"🔹","Strom":"0","Spannung":"0","Power":"0","Schalter":" <font color=\"#0080FF\"> ON","kWhNow":"0 ","kWhMonat":"0.042","PreisNow":"0","PreisMonat":"0.01","marke":"/vis.0/Icons/shellyk.png"},{"Device":"Küche und Vitrine(2)","Status":"🔹","Strom":"0","Spannung":"0","Power":"0","Schalter":" <font color=\"#0080FF\"> OFF","kWhNow":"0 ","kWhMonat":"0","PreisNow":"0","PreisMonat":"0","marke":"/vis.0/Icons/shellyk.png"},{"Device":"Hauswirtschaftsraum","Status":"🔹","Strom":"0","Spannung":"0","Power":"0","Schalter":" <font color=\"#0080FF\"> OFF","kWhNow":"0 ","kWhMonat":"0.013","PreisNow":"0","PreisMonat":"0","marke":"/vis.0/Icons/shellyk.png"},{"Device":"Hauswirtschaftsraum(2)","Status":"🔹","Strom":"0","Spannung":"0","Power":"0","Schalter":" <font color=\"#0080FF\"> OFF","kWhNow":"0 ","kWhMonat":"0","PreisNow":"0","PreisMonat":"0","marke":"/vis.0/Icons/shellyk.png"},{"Device":"Schlafzimmer","Status":"🔹","Strom":"0","Spannung":"0","Power":"0","Schalter":" <font color=\"#0080FF\"> OFF","kWhNow":"0 ","kWhMonat":"0.014","PreisNow":"0","PreisMonat":"0","marke":"/vis.0/Icons/shellyk.png"},{"Device":"Schlafzimmer(2)","Status":"🔹","Strom":"0","Spannung":"0","Power":"0","Schalter":" <font color=\"#0080FF\"> OFF","kWhNow":"0 ","kWhMonat":"0","PreisNow":"0","PreisMonat":"0","marke":"/vis.0/Icons/shellyk.png"},{"Device":"Wohnzimmer","Status":"🔹","Strom":"0","Spannung":"0","Power":"0","Schalter":" <font color=\"#0080FF\"> OFF","kWhNow":"0 ","kWhMonat":"0.022","PreisNow":"0","PreisMonat":"0.01","marke":"/vis.0/Icons/shellyk.png"},{"Device":"Wohnzimmer(2)","Status":"🔹","Strom":"0","Spannung":"0","Power":"0","Schalter":" <font color=\"#0080FF\"> OFF","kWhNow":"0 ","kWhMonat":"0","PreisNow":"0","PreisMonat":"0","marke":"/vis.0/Icons/shellyk.png"},{"Device":"Steckdose TV Wohnzimmer","Status":"🔹","Strom":"0.021","Spannung":"234","Power":"0","Schalter":" <font color=\"#58ACFA\"> OFF","kWhNow":"0.093 ","kWhMonat":"4.196","PreisNow":"0.03","PreisMonat":"1.43","marke":"/vis.0/Icons/tplinkk.png"},{"Device":"Steckdose Spülmaschine","Status":"🔹","Strom":"0.032","Spannung":"233","Power":"0","Schalter":" <font color=\"#0080FF\"> ON","kWhNow":"0.755 ","kWhMonat":"9.872","PreisNow":"0.26","PreisMonat":"3.36","marke":"/vis.0/Icons/tplinkk.png"},{"Device":"Steckdose Waschmaschine","Status":"🔹","Strom":"0.033","Spannung":"236","Power":"0.38","Schalter":" <font color=\"#0080FF\"> ON","kWhNow":"0 ","kWhMonat":"8.921","PreisNow":"0","PreisMonat":"3.03","marke":"/vis.0/Icons/tplinkk.png"},{"Device":"Playstation","Status":"🔹","Strom":"0.017","Spannung":"235","Power":"0","Schalter":" <font color=\"#58ACFA\"> OFF","kWhNow":"0 ","kWhMonat":"0.422","PreisNow":"0","PreisMonat":"0.14","marke":"/vis.0/Icons/tplinkk.png"},{"Device":"Schreibtisch Gästezimmer","Status":"🔹","Strom":"0.014","Spannung":"233","Power":"0","Schalter":" <font color=\"#58ACFA\"> OFF","kWhNow":"0 ","kWhMonat":"2.182","PreisNow":"0","PreisMonat":"0.74","marke":"/vis.0/Icons/tplinkk.png"},{"Device":"Ladegeräte Wohnzimmer","Status":"🔹","Strom":"0.011","Spannung":"235","Power":"0","Schalter":" <font color=\"#58ACFA\"> OFF","kWhNow":"0.002 ","kWhMonat":"0.433","PreisNow":"0","PreisMonat":"0.15","marke":"/vis.0/Icons/tplinkk.png"},{"Device":"Technik HWR","Status":"🔹","Strom":"0.173","Spannung":"236","Power":"18.2","Schalter":" <font color=\"#0080FF\"> ON","kWhNow":"0.189 ","kWhMonat":"4.995","PreisNow":"0.06","PreisMonat":"1.7","marke":"/vis.0/Icons/tplinkk.png"},{"Device":"<font color='#00BFFF'>alle Geräte</font>","Status":"🔹","Strom":" - ","Spannung":" - ","Power":" - ","Schalter":" - ","kWhNow":"3.981 ","kWhMonat":"39.006","PreisNow":"1.35","PreisMonat":"13.26","marke":"/vis.0/Icons/infok.png"}]
                        @Oli ich mache gerade eine neue version - können wir warten bis die fertig ist - sonst mußt du es nochmal ändern
                        aber so sollte funktioniert es
                          @PatrickFro wegen den bildern - ichb in da was auf der spur - bitte warte auf das nächste update
                            @liv-in-sky Ok, vielen Dank!
                              wieder ein update - erster post - für die material design widget user !
                              • die farbe für "alle geräte" widget ist im setting einstellbar - für materialdesign(MD)
                              • bugfix bei anwendung der bilder - kam nur bei besonderen daten zum vorschein
                              • schalter (ON OFF) sind nun sichtbar im material design - farbe war und ist einstellbar (const farbeSchalterON)
                              • die farbe für die EINSPEISUNG ist auch einstellbar für MD
                              • im setting sind die MD widgets auf false - bitte auf true setzen ( wenn ihr die html tabelle nicht benötigt, kann braucheEinVISWidget=false eingestellt werden)
                              @PatrickFro bitte teste das script ohne änderungen und sieh nach en bildern und den werten
                              @oli - mit dem schalten der buttons habe ich mich noch nicht beschäftigt - im material design widget
                              O P 2 Replies Last reply Reply Quote 0
                              • O
                                @liv-in-sky
                                hast du den Gesamtverbrauch auch wieder mit eingearbeitet?
                                  @Oli der war nie weg - alle geräte sind der gesamtverbrauch
                                  • O
                                    @liv-in-sky
                                    ich meine die rot markierten Werte
                                      @Oli let mitMonatBeforeAnzeige=false; auf true, dann ist der Vormonat wieder dabei
                                        @liv-in-sky leider keine Änderung, Bilder fehlen weiterhin.
                                        • O
                                          Oli @PatrickFro last edited by
                                          @PatrickFro
                                          danke, habe ich bei den ganzen Einstellungsmöglichkeiten total übersehen
                                            liv-in-sky @PatrickFro last edited by liv-in-sky
                                            @PatrickFro bei mir gehen die auch im /vis.0/Icons ordner (gerade getestet) - starte mal die vis instanz neu (oder iobroker)- vielleicht cache thema
                                            javascript template
                                            37
                                            696
                                            130680
