    4. [Vorstellung] Meine dritte VIS
      Kuddel @hofmannha last edited by
      @hofmannha
      Abfrage ioBroker Verisonen (JS-Controller, NPM, Node) mit Blockly
      <block xmlns="http://www.w3.org/1999/xhtml" type="schedule" id="8G-t1R$2*5D,dzJ+=Z/)" x="-412" y="13">
       <field name="SCHEDULE">* * * * *</field>
         <block type="comment" id="dZ|/xy)sNM[lRRw-OxBJ">
           <field name="COMMENT">ioBroker</field>
             <block type="controls_if" id="#yy4FbzX*XlFSwqJFt#F">
                 <block type="logic_compare" id="`;vF1Fwn46;py!YL!|D|">
                   <field name="OP">EQ</field>
                     <block type="get_value" id="?$NRbrzmN!UU3n`|L_Lp">
                       <field name="OID">system.host.ioBroker-MASTER.alive</field>
                     <block type="logic_boolean" id="iD*m^,*WXE?GM=l/{h9p">
                 <block type="comment" id="Sl#pk4ynUi?qtGg$cE[g">
                   <field name="COMMENT">ioBroker Version</field>
                     <block type="exec" id="!R8mB:{en(uJ^pcv:[x-">
                       <mutation with_statement="true"></mutation>
                       <field name="WITH_STATEMENT">TRUE</field>
                       <field name="LOG"></field>
                       <value name="COMMAND">
                         <shadow type="text" id="v]l$N@4P}O26I3a-q-h?">
                           <field name="TEXT">iobroker version</field>
                         <block type="control" id="][GYoQ$TpSK^1z+Y1)io">
                           <field name="OID">javascript.0.Versionen.ioBroker.JS-Controller</field>
                             <block type="variables_get" id="^mDY7*B6ucov9?$`tyWW">
                               <field name="VAR" id="7(zFM`@Yx-M/c5uU@N^j" variabletype="">result</field>
                         <block type="comment" id="H%;3a-me1U9t}!fx~0y~">
                           <field name="COMMENT">Node Version</field>
                             <block type="exec" id="*{Wr/}G!6rw|w(ts:Ubr">
                                 <shadow type="text" id="1e4e9U(dN%k7nOplwh/t">
                                   <field name="TEXT">node -v</field>
                                 <block type="control" id="`vkk(uG/q|f.RsbQJ6-F">
                                   <field name="OID">javascript.0.Versionen.ioBroker.Node</field>
                                     <block type="variables_get" id=",@I94/CPiw]|fzeEmZIN">
                                 <block type="comment" id=":rYml-k#oiHgEwv`2(YH">
                                   <field name="COMMENT">NPM Version</field>
                                     <block type="exec" id="NsFDRm/4E?3a;yAjP2~M">
                                         <shadow type="text" id="Pq@ZNpd%kQM$SihLxwc%">
                                           <field name="TEXT">npm -v</field>
                                         <block type="control" id="Z;/822T:KaNxR6lSS-HN">
                                           <field name="OID">javascript.0.Versionen.ioBroker.NPM</field>
                                             <block type="variables_get" id="Ur~}G^ol^zYpeaK0SPS0">
        hofmannha @Kuddel last edited by
        @Kuddel
        Vielen vielen Dank!!
          hofmannha @sigi234 last edited by
          @sigi234
          Hallo sigi234,
          ich stelle mal hier die Frage obwohl sie hier nicht hingehört.
          Ich habe den Adapter Tr-064 Version 3.1.4 installiert. Er zeigt auch grün, aber er ist in den Objekten nicht zu sehen.
          Was kann ich denn tun?
            sigi234 Forum Testing Most Active @hofmannha last edited by
            @hofmannha sagte in [Vorstellung] Meine dritte VIS:
            @sigi234
            Hallo sigi234,
            Callmonitor aktiviert und mal selbst angerufen?
              @sigi234
              habe ich gemacht, aber trotzdem nichts.
              • Sky66766
                Sky66766 last edited by
                Hallo Kuddel
                wo finde ich dann die ganzen Scripte
                bin neu und anfänger zb.
                javascript.0.sonstige.weihnachtszeit
                javascript.0.muell.gelbersack
                javascript.0.sonstige.arbeitsstatus
                javascript.0.haushalt.waschmaschine
                javascript.0.Anwesenheit
                unw.
                ich wäre für ein bißchen Hilfe dankbar
                und auch wie das mit dem Fusball geht
                  Kuddel @Sky66766 last edited by
                  @Sky66766 meine Skripte findest du in der zweiten Version von meiner VIS:
                  https://forum.iobroker.net/topic/19611/vorstellung-meine-zweite-visualisierung/1152
                  Das mit Fußball mach ich mit dem Adapter OpenLigaDB
                  https://forum.iobroker.net/topic/29506/test-adapter-openligadb-v0-0-x
                  Sky66766 1 Reply Last reply Reply Quote 0
                  • Sky66766
                    Sky66766 @Kuddel last edited by
                    @Kuddel
                    Hallo Kuddel erst mal möchte ich mich für die tolle arbeit und die, die mit daran mitgewirkt haben. echt spitze 👍
                    arbeite mich langsam vor
                    kurze frage
                    (objekte.txt) was mach ich damit und wo füge ich das ein ?
                    die scripte habe ich eingefügt
                    meine neugier wird immer größer zur deiner vis
                    • Sternmiere
                      Sternmiere last edited by
                      Hi @Kuddel ,
                      sag mal, wie schaut denn Dein Skript zur Berechnung von javascript.0.uptime.raw.vu_wohnzimmer_raw aus? Im Skript vu_wohnzimmer lauschst Du auf die Änderung von diesem DP. Nur finde ich in Deinen Skripten (habe ich mir aus Deiner 2. VIS geladen) nirgends den Eintrag zum Schreiben der RAW-Werte.
                        @Sky66766 in der objekte.txt sind alle meine Objekte, die ich in meinen ganzen Skripten so verwende.
                        Einfach in ein JHavscript kopierne und einmal starten. Dann werden die Objekte erstellt und meine Skripte funktionieren.
                          Kuddel @Sternmiere last edited by
                          @Sternmiere ich werde nächste Woch noch einmal einen aktuellen Export meine Skripte hochladen.
                          Hier die Uptime vom VU Receiver:
                           <variables>
                             <variable type="" id="v$!LyS/GX8DB4?ZU!y(c">raw</variable>
                             <variable type="" id="jwfovQ})xZ_O0_3zF:zc">result</variable>
                             <variable type="" id="`}L_Lzn|vt?3/!cZ_t7s">stelle_tage</variable>
                             <variable type="" id="pDC.c)qS~5!qlBgX]:))">stelle_doppelpunkt</variable>
                             <variable type="" id="c1et;Qzgy.J^m$Y7XD(}">stelle_komma</variable>
                             <variable type="" id="pg,790%C~4/;_rPA62F6">stelle_komma2</variable>
                             <variable type="" id="h$?S,?!0%|B-+x54)DPA">stelle_min</variable>
                             <variable type="" id="CES/yGu==C)k`@r*?INd">tage</variable>
                             <variable type="" id="IU`:e7ibMCJ2mQ@5scC!">stunden</variable>
                             <variable type="" id="VsSZA^_:X[8cAWG4-[LJ">minuten</variable>
                           </variables>
                           <block type="schedule" id="{Ho#tB7Ic-7TP@?y-Ugt" x="-569" y="-16">
                               <block type="exec" id="fBzN-E0vC5cgDObjc-3f">
                                   <shadow type="text" id="V2qy=mZ/JcC|VD?gQ}5p">
                                     <field name="TEXT">ssh root@192.168.4.24 uptime | awk '{print $3_$4_$5}'</field>
                                   <block type="comment" id="e`@QX}n-~J*w55w*Njrd">
                                     <field name="COMMENT">Impor der RAW-Daten</field>
                                       <block type="variables_set" id="InRE;D))7IjO~@[u9o-2">
                                         <field name="VAR" id="v$!LyS/GX8DB4?ZU!y(c" variabletype="">raw</field>
                                           <block type="variables_get" id="m#;!R3;^9P98fbe)}Z]N">
                                             <field name="VAR" id="jwfovQ})xZ_O0_3zF:zc" variabletype="">result</field>
                                           <block type="comment" id="aenR|!64[;M/5pwS*e2{">
                                             <field name="COMMENT">Stellen in Variable</field>
                                               <block type="variables_set" id="O.WlhmF(p~kCu]MfSc|9">
                                                 <field name="VAR" id="`}L_Lzn|vt?3/!cZ_t7s" variabletype="">stelle_tage</field>
                                                   <block type="text_indexOf" id=")+n_2r}A=}1nHA|3$t7U">
                                                     <field name="END">FIRST</field>
                                                       <block type="variables_get" id="/w_?2!Io?Pr_Y}Zj~`@[">
                                                     <value name="FIND">
                                                       <shadow type="text" id="sRBC.qA4R_]Pf@@bf*HP">
                                                         <field name="TEXT">day</field>
                                                   <block type="variables_set" id="OK+U-dp*,wRUxQF=}hB8">
                                                     <field name="VAR" id="pDC.c)qS~5!qlBgX]:))" variabletype="">stelle_doppelpunkt</field>
                                                       <block type="text_indexOf" id="Qr(RyE_9QWPzwZO19`Er">
                                                           <block type="variables_get" id="a+qh%P63+ux8*NU@Q4Rx">
                                                         <value name="FIND">
                                                           <shadow type="text" id="nk50l7paDSbxsH{jRF^+">
                                                             <field name="TEXT">:</field>
                                                       <block type="variables_set" id="ShFN@RY1iRSN9w9km4`,">
                                                         <field name="VAR" id="c1et;Qzgy.J^m$Y7XD(}" variabletype="">stelle_komma</field>
                                                           <block type="text_indexOf" id="C;(Rd_];.nae4WA}a}KB">
                                                               <block type="variables_get" id="cUCv.oh29ln|I@1t`M:S">
                                                             <value name="FIND">
                                                               <shadow type="text" id="uNfKR$(kp@-Vc^@m+_Az">
        <field name="TEXT">,</field>
                                                           <block type="variables_set" id="7VB$FrJqq?,;]dG+CCGi">
                                                             <field name="VAR" id="pg,790%C~4/;_rPA62F6" variabletype="">stelle_komma2</field>
                                                               <block type="text_indexOf" id=")-js#nY/(!e]Uqe/Os!Q">
        <field name="END">LAST</field>
        <block type="variables_get" id="~/UkbC;7~LUuEA2}#nB7">
        <value name="FIND">
        <shadow type="text" id="5T0NCYIwT$$,*L{DU_GB">
                                                               <block type="variables_set" id="X{YN3tf7qz]+Lu(`_O,.">
        <field name="VAR" id="h$?S,?!0%|B-+x54)DPA" variabletype="">stelle_min</field>
        <block type="text_indexOf" id="euW+z!_V{MJ.]`UNFdz]">
        <block type="variables_get" id="pNm.t17Kc6^CM(8@emrJ">
        <value name="FIND">
        <shadow type="text" id="_@rX51i|3q5{?ydDBE!%">
        <field name="TEXT">min</field>
        <block type="comment" id="{qxgDqA8s;]nW=DSaLV3">
        <field name="COMMENT">Herausfiltern des Tages</field>
        <block type="controls_if" id="y+lQ+n+N4Ym8VJ4pa[W?">
        <block type="logic_compare" id="%R{2rkCyfF#6A}xdjq]U">
        <field name="OP">GT</field>
        <block type="variables_get" id="C?E.y6;%UiNF4,ylc-Ob">
        <block type="math_number" id="35@A;B|SeX^kkTMK]yJ]">
        <field name="NUM">0</field>
        <block type="variables_set" id="=`~z}BBHWN8?!a^DPFq@">
        <field name="VAR" id="CES/yGu==C)k`@r*?INd" variabletype="">tage</field>
        <block type="text_getSubstring" id="yd;0z.Lg]{CKF(+-uR*o">
        <mutation at1="true" at2="true"></mutation>
        <field name="WHERE1">FROM_START</field>
        <field name="WHERE2">FROM_START</field>
        <value name="STRING">
        <block type="variables_get" id="},+8Ap:kd19X0h6$s6Px">
        <value name="AT1">
        <block type="math_number" id="A!jJdPz9Z~;:*uslJ$Iu">
        <field name="NUM">1</field>
        <value name="AT2">
        <block type="math_arithmetic" id="`v#U2{Vop)19-2IRzb0`">
        <shadow type="math_number" id="Di+z,.G~gfWJhNSx_T5I">
        <block type="variables_get" id="Sr_lETrDQ~?u4;%(R!/4">
        <shadow type="math_number" id="iFO14pOVbK=*d#/4$;.p">
        <statement name="ELSE">
        <block type="variables_set" id="v2r8la@?]TP(PuUgSg]N">
        <block type="math_number" id="IaI+u`taEV33D];(YQ,:">
        <block type="comment" id="$4NqG;IfUHWztc^lLtf-">
        <field name="COMMENT">Herausfiltern der Stunde</field>
        <block type="controls_if" id="e;]15X*b)eLpc:!c_%pb">
        <block type="logic_compare" id="$8,t]9]/%^tD?|#,7cE$">
        <block type="variables_get" id="n;a,R?FD*iak!/n*,+}d">
        <block type="math_number" id="QZ!uKr7.GA(_XD#?+ADe">
        <block type="controls_if" id=",I7?Oox[96,-0hfdgJ[4">
        <block type="logic_compare" id="rd02-;@y=MK)HRZ|]`FP">
        <block type="variables_get" id="s|(^$(-(j@Pd}S_?!;;k">
        <block type="math_number" id="nAs=%4Ti#f!azzh/hQ5m">
        <block type="variables_set" id="@~DE]P?Nk,TUYyW:gMz:">
        <field name="VAR" id="IU`:e7ibMCJ2mQ@5scC!" variabletype="">stunden</field>
        <block type="text_getSubstring" id="XLDrJ5.LU}/djC7+W3ZY">
        <block type="variables_get" id="yNf`9`Y[U5#:#9Q.z%Si">
        <value name="AT1">
        <block type="math_arithmetic" id="hvgJo,4H-H_HO7j]/8+t">
        <field name="OP">ADD</field>
        <shadow type="math_number" id="]jKiX[w!KbV0E.`nRgg,">
        <block type="variables_get" id=")Q_UAg/a0RCJ,%pv9lTy">
        <shadow type="math_number" id="I(Vw2rIJ?e2HR[h(bOU=">
        <value name="AT2">
        <block type="math_arithmetic" id="ODs^g%lU}Oen%GOoAI)z">
        <block type="variables_get" id="r%7m_ho9V6V!d2{-9pLg">
        <shadow type="math_number" id=";WY%Jgm2z9Y.bGG)kq{y">
        <block type="variables_set" id="RYMIeMDUOoP@)Wv6Sq)i">
        <block type="text_getSubstring" id=")F#YeOhkJN6`$=Mq9R@=">
        <block type="variables_get" id="4|1a9!DRz6]*5Y.9T8t9">
        <value name="AT1">
        <block type="math_arithmetic" id="4$6#/-d#j3@uZRU:fJFh">
        <block type="variables_get" id="vCcw]jmbSPI+A{,7,Pdw">
        <shadow type="math_number" id="k`+{4kXy)@7DEcCs,ykz">
        <value name="AT2">
        <block type="math_arithmetic" id="QGJs)+i;!t%lIlA$tKKg">
        <block type="variables_get" id="Sl1;!B/,MwjUy/nMm`c^">
        <shadow type="math_number" id="XxSo9B|;A]9Y](oTy`f~">
        <block type="variables_set" id="qZ9J)#hq5je/ep-r+PUD">
        <block type="text" id="@:^pB9GCU;6I6|lZ%9T#">
        <field name="TEXT">0</field>
        <block type="comment" id="Zrvt]^6znCt9~HW}b-d0">
        <field name="COMMENT">0 hinzufügen wenn Stunden &lt; 10</field>
        <block type="controls_if" id="9NrEpjYS|Zqf|7?:IEAc">
        <block type="logic_compare" id="[5;Yo-v+#yFx#3RDce81">
        <field name="OP">LT</field>
        <block type="variables_get" id="[Tm2G:`=@[vb2%s;[jWm">
        <block type="math_number" id="SUY5i%D8%$O/FBT3,Vsi">
        <field name="NUM">10</field>
        <block type="variables_set" id="uN~%%nZ2Z2i2}u.E]{(J">
        <block type="text_join" id="%Pi6UMXvQ:n`%G+_K#9S">
        <value name="ADD0">
        <block type="text" id="Ld@]3(:G=X[#U_hrZH~9">
        <value name="ADD1">
        <block type="variables_get" id="DpObVyFw`Hs`F~}n+I(=">
        <block type="comment" id="*vbiZc;LSnStohLBW+eM">
        <field name="COMMENT">Herausfiltern der Minuten</field>
        <block type="controls_if" id="rHK(CD85;td/]/4Z`ciX">
        <block type="logic_compare" id="idfiI4B79KJf.[v1UeZe">
        <block type="variables_get" id="E}F{?(CC{1Q:0wE=I{jw">
        <block type="math_number" id="HX6O~jKbv^.5pa*g$rbF">
        <block type="controls_if" id="E6w,`x4U]NP?+;JZT%+}">
        <block type="logic_compare" id="vdp8}.C8koE5Ak#.*w|j">
        <block type="variables_get" id="Jh.A_~*Q_bxdI.GFY8ko">
        <block type="math_number" id="wXD6xF9QM|eF-%I..6x|">
        <block type="variables_set" id="8Ip/%l~s5NW)G4hYWDKZ">
        <field name="VAR" id="VsSZA^_:X[8cAWG4-[LJ" variabletype="">minuten</field>
        <block type="text_getSubstring" id="53eB7q[k`;%roydR}gb?">
        <block type="variables_get" id="+z5[*V~ls(6/|Zg;IoQx">
        <value name="AT1">
        <block type="math_arithmetic" id="YJ;iG+J!c+aN74rg?;8|">
        <block type="variables_get" id="T{p?pUH5O+jo`5Y/Hl^e">
        <shadow type="math_number" id="C#|4mQDH2[dtm={D~)8?">
        <value name="AT2">
        <block type="math_arithmetic" id=";j*[u!Jrp8|y$*{`+W8R">
        <block type="variables_get" id="?n$|K/vBCODtyvDx2O}a">
        <shadow type="math_number" id="}YRtnl/9W=El,[%QS[cI">
        <block type="variables_set" id="_?[w.VXc{xrAORAS0qsa">
        <block type="text_getSubstring" id="USYd$MPqj3Xk)fR+s_.w">
        <block type="variables_get" id="A,q.{ukNM{9C3/QT;Z3S">
        <value name="AT1">
        <block type="math_arithmetic" id="xlQLWP75{}BiDhwY@a|^">
        <block type="variables_get" id="0YZr~G@_D4j~*.BOGfs|">
        <shadow type="math_number" id="]$tx[~yzW16-c-A3o(iD">
        <value name="AT2">
        <block type="math_arithmetic" id="If7.?.0^5A2n*32KivS5">
        <block type="variables_get" id="y4f._)MJi8:;NnVq1`5]">
        <shadow type="math_number" id="hwQ;pi?~z18Nbl^wJ9Hm">
        <block type="variables_set" id="lf?IYZiqd)u.9fi=[Ynb">
        <block type="text" id="W(uLknRJg7G7[C=(3QiQ">
        <field name="TEXT">00</field>
        <block type="controls_if" id="n@!qp`;kdQ2`=?Pni.(;">
        <block type="logic_compare" id="SPFD]u(Ao[suW?Z%e3si">
        <block type="variables_get" id="Y[kceV$$8!a1IacavII0">
        <block type="math_number" id="jMRct@)k]8b_d0=HNHtu">
        <block type="variables_set" id="U7^Zn=RZr77K+J?$ckH@">
        <block type="text_getSubstring" id="J,FF?/Y#{=oIaS.;UEy!">
        <mutation at1="false" at2="true"></mutation>
        <field name="WHERE1">FIRST</field>
        <block type="variables_get" id="Wv1*waDBKz+pGsz?Wk+m">
        <value name="AT2">
        <block type="math_arithmetic" id="q+JrL#9w[vx_6(iaN7e#">
        <shadow type="math_number" id="Ah/:WZ~P=Mk{?gyN*XQ;">
        <block type="variables_get" id="8[F`BR|:Aj+p@d}=2c%4">
        <shadow type="math_number" id="8.QEvI2#SVot3=/W9AcO">
        <block type="variables_set" id="bE9[UPY8#q1@L!LZ[*fM">
        <block type="convert_tonumber" id="@cT1[lg(IlghOD#0a4oo">
        <block type="variables_get" id=":sbStjd3C;#:$z++1K+B">
        <block type="comment" id="u`!^^e/:_n}]_%@B??/G">
        <field name="COMMENT">0 hinzufügen wenn Minuten &lt; 10</field>
        <block type="controls_if" id="bRx|^^=9wj7d7h{BIV@M">
        <block type="logic_compare" id=".Fc/u.e=rPo8Y|0y]ehT">
        <block type="variables_get" id="9qUZaLy=!Pcmq_Da:u8;">
        <block type="math_number" id="jXtyuXh[%Tjj:7=,i,Fk">
        <block type="variables_set" id="Q4?V/8|]L/2=89`#7ufG">
        <block type="text_join" id="q-u(6Ye-97I|a^9$[n%$">
        <value name="ADD0">
        <block type="text" id="tj!c.W5DmAH_E!LVFvvV">
        <value name="ADD1">
        <block type="variables_get" id="yMarDZ?b?7D~You(TjPe">
        <block type="comment" id="}%%=SQ(aFr1w_n-:6:yZ">
        <field name="COMMENT">Laufzeit in Objekt schreiben</field>
        <block type="comment" id="):-U?%/oWDq`@l+U~h~M">
        <field name="COMMENT">Tage</field>
        <block type="controls_if" id="F/M8{rV.rCGwX[CnL=vx">
        <block type="logic_operation" id="M25wfZcLGFb4GJg)a)MG">
        <field name="OP">OR</field>
        <block type="logic_compare" id="J_pdrRGNb6yo1OC(.R4z">
        <block type="variables_get" id="!@%0:k.AXFP?l2Mb6X:~">
        <block type="math_number" id="dK!@s)PXi!~:C6]:;o,6">
        <block type="logic_compare" id="~m%XZI?j^=2S)hs/US6t">
        <block type="variables_get" id="+-K51lRY=Z`U?5q%is+M">
        <block type="math_number" id="=M3y0jXD}=d32cj!f#~J">
        <block type="variables_set" id="*7vtw(1@ei#;V1ST:/;P">
        <block type="text_join" id="bG@dj4MU`?[@i{{9`hbA">
        <value name="ADD0">
        <block type="variables_get" id="{B2tTLXru]=F.s0keEZ0">
        <value name="ADD1">
        <block type="text" id="zBtE08]C($B|P6c{A|SP">
        <field name="TEXT"> Tage, </field>
        <block type="variables_set" id="T5ZhNz%T5w]NtKSEpAW=">
        <block type="text_join" id="0j,drO`$d?F{4{Jl{?9K">
        <value name="ADD0">
        <block type="variables_get" id="bk:]FR@|!xB:AGJt^cET">
        <value name="ADD1">
        <block type="text" id="KdzmndZ^B5OtsGDP~DM]">
        <field name="TEXT"> Tag, </field>
        <block type="comment" id="KoTE`D^uscfc|miPAMbX">
        <field name="COMMENT">Stunden</field>
        <block type="variables_set" id=".p[^4YkDvI5SU5zK)^8{">
        <block type="text_join" id="f=iL!In2ccd(;QaPZHPv">
        <value name="ADD0">
        <block type="variables_get" id="yZojJwenZcz3[{5nj?ns">
        <value name="ADD1">
        <block type="text" id="#fo[S~5I}^2zWq74)?@i">
        <field name="TEXT"> Std, </field>
        <block type="comment" id="DZ3)bNceInk(8|fPC2qs">
        <field name="COMMENT">Minuten</field>
        <block type="variables_set" id="%Gt9FZ]ndKF2;h+v{hx-">
        <block type="text_join" id="E?P.o?ZDJ2?iX,Z}uJYI">
        <value name="ADD0">
        <block type="variables_get" id="^e/:??IsKLf-iJl|xnuM">
        <value name="ADD1">
        <block type="text" id="?{a~GlML45b#e3-!)Vri">
        <field name="TEXT"> Min</field>
        <block type="control" id="qM=Pf[UGSE}.MH{OP+V]">
        <field name="OID">javascript.0.uptime.vu_wohnzimmer</field>
        <block type="text_join" id="#@(=V`T9`,60hJI.HNKH">
        <value name="ADD0">
        <block type="text_join" id="Y;aC``m})PM;@ACEthGa">
        <value name="ADD0">
        <block type="variables_get" id="E^`3c!JpZT}s}a.ptFuI">
        <value name="ADD1">
        <block type="variables_get" id="!zj_8xPgS3IS:nl}o/:S">
        <value name="ADD1">
        <block type="variables_get" id="?0I}_P,)TBA%vCqvOT|W">
                          • Sky66766
                            @Kuddel
                            Hallo Kuddel,
                            ahaa ok Danke also einmal starten und danach kann ich dieses script wieder löschen oder soll ich das so drinn lassen.
                              @Sky66766 ich hab es gestoppt und trage da dann immer alle neuen DPs ein, die ich so benutze
                              • Sky66766
                                Sky66766 @Kuddel last edited by Sky66766
                                @Kuddel
                                ok danke
                                wollte gerade türklinkel starten kommt aber die meldung ( Cannot extract Blockly code )
                                ich habe gerade mal durchgestestet bei Blockly
                                hier bei bekomme ich die fehler meldung
                                geschirrspueler_v0_1
                                trockner_v0_1
                                waschmaschine_v0_1
                                start_stop_esxp
                                wake_on_lan_v0_2
                                rolladen_verdunkelung_v0_1
                                benachrichtigungen_v0_1
                                bewaesserung
                                briefkasten_tuerklingel_v0_1
                                staubsauger_v0_2
                                tablet
                                tuerklingel
                                kamera
                                reboot_skript
                                usv_shutdown
                                wlan_failover
                                  @Sky66766 hab mal einen neuen Export gemacht:
                                  2020-03-17-scripts.zip
                                  • tobasium
                                    tobasium @Kuddel last edited by
                                    @Kuddel kannst du ein bisschen mehr zu deinem Echo Seiten sagen? Find das eine Super arbeit und mich würde interessieren was die Datenpunkte auslöst und wie ich das eventuell in meiner VIS einsetzen kann:
                                    javascript.0.echo.wohnzimmer_status
                                    hast du hier ein skript für?
                                    Danke schon mal vorab.
                                      Kuddel @tobasium last edited by
                                      @Tobias-Armbruster im Beitrag vor dir sind alle meine Skripte, auch das für die Echos.
                                      Das Skript wertet aus, was der jeweilige Echo gerade macht ( Stopped, Radio, Spotify und Amazon Music).
                                      Das wird dann in den jeweiligen DP geschrieben.
                                      Über den DP wird dann dann in meiner VIS der jeweilige Player angezeigt
                                      tobasium 1 Reply Last reply Reply Quote 0
                                      • tobasium
                                        @Kuddel Danke irgendwie sehe ich den Beitrag erst jetzt. obwohl ich dachte ich bin alles durch. Dan schau ich mal ob ich das skript finde.
                                        Danke Dir auf jedenfall schonmal
                                        • Sky66766
                                          @Kuddel
                                          Hallo Kuddel,
                                          also habe jetzt zwei mal versucht aber die fehler bei den besagten Blockly bestehen weiter
                                          trockner_v0_1
                                          waschmaschine_v0_1
                                          start_stop_esxp
                                          wake_on_lan_v0_2
                                          bewaesserung
                                          staubsauger_v0_2
                                          tablet
                                          tuerklingel
                                          kamera
                                          reboot_skript
                                          usv_shutdown
                                          wlan_failover
                                          habe beim ersten mal alles überschrieben ohne erfolg
                                          beim zweiten versuch habe ich alle scripte einzel´n gelöscht ,
                                          javascript adapter gelöscht und neu intalliert den DP gesetzt und deine neuen scripte wieder importiert
                                            @Sky66766 ich habe mir eben meinen Export heruntegeladen und ohne Probleme in meiner Testinstanz importiert.
                                            Welche Version vom JS-Adapter verwendet du ?
                                            Ich nutze 4.4.2
                                            vis vis projekte
                                            83
                                            640
                                            172233
