    4. Test Adapter mihome-vacuum v2.0.x
      Jaschkopf last edited by
      Hab gerade auf 2.0.9 über github geupdated und jetzt stürzen die Instanzen permanent ab. Hier ein Log:
      mihome-vacuum.0	2020-03-13 17:25:19.053	info	(17352) set nächster Timer: Nicht verfügbar
      mihome-vacuum.0	2020-03-13 17:25:18.606	info	(17352) connecting, this can take up to 10 minutes ...
      mihome-vacuum.0	2020-03-13 17:25:18.577	info	(17352) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
      mihome-vacuum.0	2020-03-13 17:25:18.576	info	(17352) extend state mop for State control.fan_power
      mihome-vacuum.0	2020-03-13 17:25:18.574	info	(17352) change states from State control.fan_power
      mihome-vacuum.0	2020-03-13 17:25:18.500	info	(17352) Cloud control disabled
      mihome-vacuum.0	2020-03-13 17:25:18.498	info	(17352) Expert mode disabled, states deleted
      mihome-vacuum.0	2020-03-13 17:25:18.401	info	(17352) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
      mihome-vacuum.1	2020-03-13 17:25:16.432	info	(17232) set nächster Timer: Nicht verfügbar
      mihome-vacuum.1	2020-03-13 17:25:15.979	info	(17232) connecting, this can take up to 10 minutes ...
      mihome-vacuum.1	2020-03-13 17:25:15.927	info	(17232) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
      mihome-vacuum.1	2020-03-13 17:25:15.925	info	(17232) extend state mop for State control.fan_power
      mihome-vacuum.1	2020-03-13 17:25:15.924	info	(17232) change states from State control.fan_power
      mihome-vacuum.1	2020-03-13 17:25:15.894	info	(17232) Cloud control disabled
      mihome-vacuum.1	2020-03-13 17:25:15.891	info	(17232) Expert mode disabled, states deleted
      mihome-vacuum.1	2020-03-13 17:25:15.847	info	(17232) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
      host.raspberrypi	2020-03-13 17:25:15.566	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
      host.raspberrypi	2020-03-13 17:25:15.565	error	instance system.adapter.mihome-vacuum.0 terminated with code 156 (156)
      mihome-vacuum.0	2020-03-13 17:25:15.043	warn	(15936) Got terminate signal. Checking desired PID: 17352 vs own PID 15936
      mihome-vacuum.0	2020-03-13 17:25:15.040	info	(15936) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      mihome-vacuum.0	2020-03-13 17:25:15.039	info	(15936) terminating
      mihome-vacuum.0	2020-03-13 17:25:15.036	warn	(15936) Got terminate signal. Checking desired PID: 0 vs own PID 15936
      host.raspberrypi	2020-03-13 17:25:15.031	info	instance system.adapter.mihome-vacuum.0 started with pid 17352
      host.raspberrypi	2020-03-13 17:25:13.415	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
      host.raspberrypi	2020-03-13 17:25:13.414	error	instance system.adapter.mihome-vacuum.1 terminated with code 156 (156)
      mihome-vacuum.1	2020-03-13 17:25:12.888	warn	(15746) Got terminate signal. Checking desired PID: 17232 vs own PID 15746
      mihome-vacuum.1	2020-03-13 17:25:12.883	info	(15746) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      mihome-vacuum.1	2020-03-13 17:25:12.881	info	(15746) terminating
      mihome-vacuum.1	2020-03-13 17:25:12.877	warn	(15746) Got terminate signal. Checking desired PID: 0 vs own PID 15746
      host.raspberrypi	2020-03-13 17:25:12.870	info	instance system.adapter.mihome-vacuum.1 started with pid 17232
      mihome-vacuum.0	2020-03-13 17:25:07.880	info	(15936) connecting, this can take up to 10 minutes ...
      mihome-vacuum.0	2020-03-13 17:25:07.880	warn	(15936) Time difference between Mihome Vacuum and ioBroker: 1 sec
      mihome-vacuum.1	2020-03-13 17:25:05.913	info	(15746) connecting, this can take up to 10 minutes ...
      mihome-vacuum.0	2020-03-13 17:24:48.390	info	(15936) set nächster Timer: Nicht verfügbar
      mihome-vacuum.0	2020-03-13 17:24:47.963	info	(15936) connecting, this can take up to 10 minutes ...
      mihome-vacuum.0	2020-03-13 17:24:47.962	warn	(15936) Time difference between Mihome Vacuum and ioBroker: 1 sec
      mihome-vacuum.0	2020-03-13 17:24:47.932	info	(15936) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
      mihome-vacuum.0	2020-03-13 17:24:47.930	info	(15936) extend state mop for State control.fan_power
      mihome-vacuum.0	2020-03-13 17:24:47.929	info	(15936) change states from State control.fan_power
      mihome-vacuum.0	2020-03-13 17:24:47.863	info	(15936) Cloud control disabled
      mihome-vacuum.0	2020-03-13 17:24:47.862	info	(15936) Expert mode disabled, states deleted
      mihome-vacuum.0	2020-03-13 17:24:47.703	info	(15936) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
      mihome-vacuum.1	2020-03-13 17:24:46.424	info	(15746) set nächster Timer: Nicht verfügbar
      mihome-vacuum.1	2020-03-13 17:24:45.995	info	(15746) connecting, this can take up to 10 minutes ...
      mihome-vacuum.1	2020-03-13 17:24:45.933	info	(15746) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
      mihome-vacuum.1	2020-03-13 17:24:45.931	info	(15746) extend state mop for State control.fan_power
      mihome-vacuum.1	2020-03-13 17:24:45.930	info	(15746) change states from State control.fan_power
      mihome-vacuum.1	2020-03-13 17:24:45.894	info	(15746) Cloud control disabled
      mihome-vacuum.1	2020-03-13 17:24:45.891	info	(15746) Expert mode disabled, states deleted
      mihome-vacuum.1	2020-03-13 17:24:45.839	info	(15746) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
      host.raspberrypi	2020-03-13 17:24:45.009	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
      host.raspberrypi	2020-03-13 17:24:45.009	error	instance system.adapter.mihome-vacuum.0 terminated with code 156 (156)
      mihome-vacuum.0	2020-03-13 17:24:44.487	warn	(14925) Got terminate signal. Checking desired PID: 15936 vs own PID 14925
      mihome-vacuum.0	2020-03-13 17:24:44.479	info	(14925) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      mihome-vacuum.0	2020-03-13 17:24:44.476	info	(14925) terminating
      mihome-vacuum.0	2020-03-13 17:24:44.469	warn	(14925) Got terminate signal. Checking desired PID: 0 vs own PID 14925
      host.raspberrypi	2020-03-13 17:24:44.463	info	instance system.adapter.mihome-vacuum.0 started with pid 15936
      host.raspberrypi	2020-03-13 17:24:42.832	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
      host.raspberrypi	2020-03-13 17:24:42.831	error	instance system.adapter.mihome-vacuum.1 terminated with code 156 (156)
      mihome-vacuum.1	2020-03-13 17:24:42.291	warn	(14897) Got terminate signal. Checking desired PID: 15746 vs own PID 14897
      mihome-vacuum.1	2020-03-13 17:24:42.287	info	(14897) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      mihome-vacuum.1	2020-03-13 17:24:42.286	info	(14897) terminating
      mihome-vacuum.1	2020-03-13 17:24:42.284	warn	(14897) Got terminate signal. Checking desired PID: 0 vs own PID 14897
      host.raspberrypi	2020-03-13 17:24:42.273	info	instance system.adapter.mihome-vacuum.1 started with pid 15746
      mihome-vacuum.0	2020-03-13 17:24:37.726	info	(14925) connecting, this can take up to 10 minutes ...
      mihome-vacuum.1	2020-03-13 17:24:36.488	info	(14897) connecting, this can take up to 10 minutes ...
      mihome-vacuum.0	2020-03-13 17:24:18.880	info	(14925) connecting, this can take up to 10 minutes ...
      mihome-vacuum.0	2020-03-13 17:24:18.880	warn	(14925) Time difference between Mihome Vacuum and ioBroker: 1 sec
      mihome-vacuum.0	2020-03-13 17:24:18.864	info	(14925) set nächster Timer: Nicht verfügbar
      mihome-vacuum.0	2020-03-13 17:24:17.776	info	(14925) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
      mihome-vacuum.0	2020-03-13 17:24:17.775	info	(14925) extend state mop for State control.fan_power
      mihome-vacuum.0	2020-03-13 17:24:17.774	info	(14925) change states from State control.fan_power
      mihome-vacuum.0	2020-03-13 17:24:17.705	info	(14925) Cloud control disabled
      mihome-vacuum.0	2020-03-13 17:24:17.703	info	(14925) Expert mode disabled, states deleted
      mihome-vacuum.0	2020-03-13 17:24:17.608	info	(14925) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
      mihome-vacuum.1	2020-03-13 17:24:15.944	info	(14897) set nächster Timer: Nicht verfügbar
      mihome-vacuum.1	2020-03-13 17:24:15.484	info	(14897) connecting, this can take up to 10 minutes ...
      mihome-vacuum.1	2020-03-13 17:24:15.451	info	(14897) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
      mihome-vacuum.1	2020-03-13 17:24:15.449	info	(14897) extend state mop for State control.fan_power
      mihome-vacuum.1	2020-03-13 17:24:15.448	info	(14897) change states from State control.fan_power
      mihome-vacuum.1	2020-03-13 17:24:15.412	info	(14897) Cloud control disabled
      mihome-vacuum.1	2020-03-13 17:24:15.409	info	(14897) Expert mode disabled, states deleted
      mihome-vacuum.1	2020-03-13 17:24:15.365	info	(14897) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
      host.raspberrypi	2020-03-13 17:24:14.429	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
      host.raspberrypi	2020-03-13 17:24:14.429	error	instance system.adapter.mihome-vacuum.0 terminated with code 156 (156)
      mihome-vacuum.0	2020-03-13 17:24:13.903	warn	(13853) Got terminate signal. Checking desired PID: 14925 vs own PID 13853
      mihome-vacuum.0	2020-03-13 17:24:13.900	info	(13853) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      mihome-vacuum.0	2020-03-13 17:24:13.899	info	(13853) terminating
      mihome-vacuum.0	2020-03-13 17:24:13.897	warn	(13853) Got terminate signal. Checking desired PID: 0 vs own PID 13853
      host.raspberrypi	2020-03-13 17:24:13.894	info	instance system.adapter.mihome-vacuum.0 started with pid 14925
      host.raspberrypi	2020-03-13 17:24:12.252	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
      host.raspberrypi	2020-03-13 17:24:12.250	error	instance system.adapter.mihome-vacuum.1 terminated with code 156 (156)
      mihome-vacuum.1	2020-03-13 17:24:11.728	warn	(13825) Got terminate signal. Checking desired PID: 14897 vs own PID 13825
      mihome-vacuum.1	2020-03-13 17:24:11.724	info	(13825) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      mihome-vacuum.1	2020-03-13 17:24:11.722	info	(13825) terminating
      mihome-vacuum.1	2020-03-13 17:24:11.718	warn	(13825) Got terminate signal. Checking desired PID: 0 vs own PID 13825
      host.raspberrypi	2020-03-13 17:24:11.712	info	instance system.adapter.mihome-vacuum.1 started with pid 14897
      mihome-vacuum.0	2020-03-13 17:24:06.409	info	(13853) connecting, this can take up to 10 minutes ...
      mihome-vacuum.1	2020-03-13 17:24:04.362	info	(13825) connecting, this can take up to 10 minutes ...
      mihome-vacuum.0	2020-03-13 17:23:46.924	info	(13853) set nächster Timer: Nicht verfügbar
      mihome-vacuum.0	2020-03-13 17:23:46.546	info	(13853) connecting, this can take up to 10 minutes ...
      mihome-vacuum.0	2020-03-13 17:23:46.501	info	(13853) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
      mihome-vacuum.0	2020-03-13 17:23:46.498	info	(13853) extend state mop for State control.fan_power
      mihome-vacuum.0	2020-03-13 17:23:46.496	info	(13853) change states from State control.fan_power
      mihome-vacuum.0	2020-03-13 17:23:46.392	info	(13853) Cloud control disabled
      mihome-vacuum.0	2020-03-13 17:23:46.391	info	(13853) Expert mode disabled, states deleted
      mihome-vacuum.0	2020-03-13 17:23:46.292	info	(13853) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
      mihome-vacuum.1	2020-03-13 17:23:44.873	info	(13825) set nächster Timer: Nicht verfügbar
      mihome-vacuum.1	2020-03-13 17:23:44.486	info	(13825) connecting, this can take up to 10 minutes ...
      mihome-vacuum.1	2020-03-13 17:23:44.404	info	(13825) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
      mihome-vacuum.1	2020-03-13 17:23:44.387	info	(13825) extend state mop for State control.fan_power
      mihome-vacuum.1	2020-03-13 17:23:44.384	info	(13825) change states from State control.fan_power
      mihome-vacuum.1	2020-03-13 17:23:44.340	info	(13825) Cloud control disabled
      mihome-vacuum.1	2020-03-13 17:23:44.338	info	(13825) Expert mode disabled, states deleted
      mihome-vacuum.1	2020-03-13 17:23:44.294	info	(13825) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
      host.raspberrypi	2020-03-13 17:23:43.876	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
      host.raspberrypi	2020-03-13 17:23:43.876	error	instance system.adapter.mihome-vacuum.0 terminated with code 156 (156)
      mihome-vacuum.0	2020-03-13 17:23:43.354	warn	(12840) Got terminate signal. Checking desired PID: 13853 vs own PID 12840
      mihome-vacuum.0	2020-03-13 17:23:43.344	info	(12840) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      mihome-vacuum.0	2020-03-13 17:23:43.343	info	(12840) terminating
      mihome-vacuum.0	2020-03-13 17:23:43.341	warn	(12840) Got terminate signal. Checking desired PID: 0 vs own PID 12840
      host.raspberrypi	2020-03-13 17:23:43.338	info	instance system.adapter.mihome-vacuum.0 started with pid 13853
      host.raspberrypi	2020-03-13 17:23:41.674	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
      host.raspberrypi	2020-03-13 17:23:41.673	error	instance system.adapter.mihome-vacuum.1 terminated with code 156 (156)
      mihome-vacuum.1	2020-03-13 17:23:41.155	warn	(12812) Got terminate signal. Checking desired PID: 13825 vs own PID 12812
      mihome-vacuum.1	2020-03-13 17:23:41.149	info	(12812) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      mihome-vacuum.1	2020-03-13 17:23:41.147	info	(12812) terminating
      mihome-vacuum.1	2020-03-13 17:23:41.143	warn	(12812) Got terminate signal. Checking desired PID: 0 vs own PID 12812
      host.raspberrypi	2020-03-13 17:23:41.137	info	instance system.adapter.mihome-vacuum.1 started with pid 13825
      mihome-vacuum.0	2020-03-13 17:23:36.598	info	(12840) connecting, this can take up to 10 minutes ...
      mihome-vacuum.1	2020-03-13 17:23:33.629	info	(12812) connecting, this can take up to 10 minutes ...
      mihome-vacuum.0	2020-03-13 17:23:16.466	info	(12840) set nächster Timer: Nicht verfügbar
      mihome-vacuum.0	2020-03-13 17:23:16.029	info	(12840) connecting, this can take up to 10 minutes ...
      mihome-vacuum.0	2020-03-13 17:23:15.997	info	(12840) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
      mihome-vacuum.0	2020-03-13 17:23:15.994	info	(12840) extend state mop for State control.fan_power
      mihome-vacuum.0	2020-03-13 17:23:15.992	info	(12840) change states from State control.fan_power
      mihome-vacuum.0	2020-03-13 17:23:15.917	info	(12840) Cloud control disabled
      mihome-vacuum.0	2020-03-13 17:23:15.915	info	(12840) Expert mode disabled, states deleted
      mihome-vacuum.0	2020-03-13 17:23:15.817	info	(12840) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
      mihome-vacuum.1	2020-03-13 17:23:14.146	info	(12812) set nächster Timer: Nicht verfügbar
      mihome-vacuum.1	2020-03-13 17:23:13.722	info	(12812) connecting, this can take up to 10 minutes ...
      mihome-vacuum.1	2020-03-13 17:23:13.653	info	(12812) New generation or new fw(3.5.7,002008) detected, create new states goto and zoneclean
      mihome-vacuum.1	2020-03-13 17:23:13.651	info	(12812) extend state mop for State control.fan_power
      mihome-vacuum.1	2020-03-13 17:23:13.650	info	(12812) change states from State control.fan_power
      mihome-vacuum.1	2020-03-13 17:23:13.605	info	(12812) Cloud control disabled
      mihome-vacuum.1	2020-03-13 17:23:13.603	info	(12812) Expert mode disabled, states deleted
      mihome-vacuum.1	2020-03-13 17:23:13.557	info	(12812) starting. Version 2.0.9-RC03 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
      host.raspberrypi	2020-03-13 17:23:13.322	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
      host.raspberrypi	2020-03-13 17:23:13.321	error	instance system.adapter.mihome-vacuum.0 terminated with code 156 (156)
      mihome-vacuum.0	2020-03-13 17:23:12.798	warn	(11748) Got terminate signal. Checking desired PID: 12840 vs own PID 11748
      mihome-vacuum.0	2020-03-13 17:23:12.794	info	(11748) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      mihome-vacuum.0	2020-03-13 17:23:12.792	info	(11748) terminating
      mihome-vacuum.0	2020-03-13 17:23:12.789	warn	(11748) Got terminate signal. Checking desired PID: 0 vs own PID 11748
      host.raspberrypi	2020-03-13 17:23:12.786	info	instance system.adapter.mihome-vacuum.0 started with pid 12840
      host.raspberrypi	2020-03-13 17:23:11.104	info	Restart adapter system.adapter.mihome-vacuum.1 because enabled
      host.raspberrypi	2020-03-13 17:23:11.104	error	instance system.adapter.mihome-vacuum.1 terminated with code 156 (156)
      mihome-vacuum.1	2020-03-13 17:23:10.571	warn	(11714) Got terminate signal. Checking desired PID: 12812 vs own PID 11714
      Diginix J 2 Replies Last reply Reply Quote 0
      • Diginix
        Diginix @Jaschkopf last edited by
        @Jaschkopf
        Raumzuweisung geht nicht per Skript, schon gar nicht mit eingeschränktem Blockly. War hier auch schon Thema.
        Dein Absturz kommt durch mind ein Zombieprozess. Entweder killst du die PID in der Kommandozeile oder startest alles komplett neu durch.
          dirkhe Developer @Jaschkopf last edited by
          @Jaschkopf dafür gibt es zoneclean oder x_sendcommand oder du machst es per Timer, habe ich auch schon mehrfach beschrieben
            dirkhe Developer @Diginix last edited by dirkhe
            @Diginix Fix ist im Git 2.0.9-RC05.
            Übrigens so sieht meine Vis aus, wenn de State eines Raumchannels gefüllt ist:
            X 1 Reply Last reply Reply Quote 5
            • 0
              0018 @0018 last edited by
              @0018 sagte in Test Adapter mihome-vacuum v2.0.x:
              kann mir jemand erklären wie ich von meinem Gen1 mit ValetudoRE 0.8.1 / Firmware 3.3.9 - 3468 die bereits in Valetudo angelegten Zonen in ioBroker importieren und ansteuern kann?
              Jemand ne Auskunft für mich? Ist das mit Gen1 möglich oder wird dieser nicht in dem Adapter integriert?
              • haselchen
                haselchen Most Active @0018 last edited by
                @dirkhe
                RC06 ist online...changelog?
                  Kludi last edited by
                  Hallo
                  Ich wollte von Version 1.1.5 stable auf die 2.07 last Version updaten.
                  Leider bekomme ich immer die Fehlermeldung "Fertig mit Fehler: host.tinkerboard Cannot install iobroker.mihome-vacuum@2.0.7: 1"
                  $ ./iobroker upgrade mihome-vacuum
                  Update mihome-vacuum from @1.1.5 to @2.0.7
                  NPM version: 6.13.4
                  npm install iobroker.mihome-vacuum@2.0.7 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
                  Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
                  gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
                  gyp
                   ERR! configure error gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR!
                   stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp ERR! System Linux 4.19.69-rockchipgyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=5" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v10.19.0gyp ERR!
                  node-gyp -v v5.0.5gyp ERR! not ok
                  node-pre-gyp
                   ERR! build error
                  node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=5 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)node-pre-gyp
                   ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/canvas/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)node-pre-gyp ERR! stack
                       at maybeClose (internal/child_process.js:982:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
                  node-pre-gyp ERR! System Linux 4.19.69-rockchipnode-pre-gyp ERR!
                   command "/usr/bin/node" "/opt/iobroker/node_modules/canvas/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v
                   v10.19.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
                  npm
                   ERR! code ELIFECYCLEnpm ERR! errno 1
                  npm ERR! canvas@2.6.1 install: `node-pre-gyp install --fallback-to-build`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the canvas@2.6.1 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2020-03-15T16_15_09_710Z-debug.log
                  ERROR: host.tinkerboard Cannot install iobroker.mihome-vacuum@2.0.7: 1
                  ERROR: process exited with code 25
                  Was mach ich falsch?
                  MFG Kludi
                    dirkhe Developer @haselchen last edited by
                    @haselchen https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/commits/master
                      dirkhe Developer @Kludi last edited by
                      @Kludi Bitte readme lesen, ganz im Anfang. Das Problem ist die canvas
                      • X
                        xADDRx @dirkhe last edited by
                        @dirkhe deine Vis sieht echt gut aus. Teilen du mit uns :D?
                          jayfizzle @Jaschkopf last edited by
                          @Jaschkopf Habe ein ähnliches Problem, konntest du deins lösen? Ein Neustart des raspi, Neuinstallation brachte keinen Erfolg. Bin nun auf die 2.0.7 gegangen, diese läft ohne die Connection Probleme.
                            dirkhe Developer @xADDRx last edited by
                            @xADDRx Na klar, Grundlage sind die materialdesign widgets
                            Hier sind die 4 Views:
                            staubi-vis-views.json
                            Ich weiss nicht, ob man die direkt so einlesen kannst, sonst eben einzeln importieren
                              mameier1234 @dirkhe last edited by
                              @dirkhe
                              Danke fürs teilen... Aber so krieg ich das leider nicht rein.. Da kommt immer ein JSON Fehler.. auch wenn ich die einzelnen Views importieren will...
                              Hat das sonst jemand geschafft ??? Sind nämlich echt schön....
                                dirkhe Developer last edited by
                                @mameier1234 Hier sind mal die 3 einzeln:
                                staubi-wartung-vis-views.json
                                staubi-history-vis-views.json
                                staubi-steuerung-vis-views.json
                                • I
                                  iphone333 last edited by
                                  dieser Wert kann doch nicht stimmen, dürfte doch nur bis 100% gehen oder? Ist ein Roborock S5 Max.
                                  • Diginix
                                    Diginix @iphone333 last edited by
                                    @iphone333 Das sind keine Prozentwerte. Ist ja auch keine Einheit dahinter.
                                    Es sind einfach numerische Werte für die einzelnen Saugstärken und die liegen alle über 100. Nur die alten Sauger bzw. mit alter Firmware gab es das in Prozent (0-100%). Daher wurden die neuen Saugstärken (min, max, turbo usw.) von Xiaomi/Roborock evtl. auch oberhalb 100 festgelegt.
                                    • I
                                      iphone333 @Diginix last edited by
                                      @Diginix
                                      Es wird aber kein Wert wie mix, max, übernommen
                                      • Diginix
                                        Diginix @iphone333 last edited by Diginix
                                        @iphone333 Dann passt was nicht. Sollte eigentlich so im RAW von fan_power aussehen:
                                        Welche Adapter Version nutzt du?
                                        I L 2 Replies Last reply Reply Quote 0
                                        • I
                                          @Diginix
                                          Die aktuellste
                                          • Diginix
                                            @iphone333 Die Aussage hilft nicht wirklich. Offizielles Repo oder ein Fork? Per GIT installiert oder per manueller URL?
                                            Aber an den Saugstärken dürfte schon lange nichts geändert worden sein. Also ist die VersionsNr. nur bedingt von Bedeutung.
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            493658
