    2. English
    3. ioBroker general
    4. How to lower disk writes (for extending life of an sd card)
      paul53 @apollon77 last edited by
      @apollon77 sagte:
      this will be likely hard when you do not only use device values, but also logical values.
      A reboot / killing of ioBroker immediately writes the states from RAM to the file. Only in case of a system crash (power failure) such a long time is problematic.
        apollon77 @paul53 last edited by
        @paul53 ... or a process crash (yes there is come code that tries to write it also when crashing) ... but 🙂 (e.g. a SIGTERM because of OOM might also not write values).
        It is all about "knowing what one is doing"
        • Tomasz Nowak
          Tomasz Nowak last edited by Tomasz Nowak
          @paul53 , @apollon77
          Thanks for your hints, guys. For now I'm just handling Ecovacs Deebot vacuuming robot (and Daikin aircon soon, probably) over MQTT with no logic within ioBroker. So I hope I don't risk any house disaster with that setting
          @paul53, I've created an issue, thanks.
          • Dutchman
            just as suggestion, to avoid load read/write loads on storage and move the to Memory isn't Redis providing more efficient state handling here ?
            • Tomasz Nowak
              I thought about it but AFAIK Redis also needs to write to disk / sd card. I have relatively small number of states so I believe creating yet another docker instance for Redis would be kind of overkill in my case.
              Mic 1 Reply Last reply Reply Quote 0
              • Mic
                Mic Developer @Tomasz Nowak last edited by Mic
                @Tomasz-Nowak
                I am using Redis successfully for several months. I have installed it on the same system (Debian) on which ioBroker is installed - but no Raspberry experience (I am using a Zotac barebone with Proxmox), though.
                See: https://github.com/ioBroker/ioBroker.js-controller#state-and-objects-databases-and-files
                Also, see: https://redis.io/topics/persistence
                You may want to look into it again, but not sure how the performance is gonna be on a Raspberry.
                Tomasz Nowak 1 Reply Last reply Reply Quote 0
                • Tomasz Nowak
                  Tomasz Nowak @Mic last edited by
                  @Mic
                  I've read that before. They say good for many objects such has 10000 for performance reasons. I have like 50 objects 🙂
                  And I don't want make it more complex (you don't install another services in docker instance, you need another docker)
                  • Dutchman
                    Dutchman Developer Most Active Administrators last edited by Dutchman
                    guys wait ...., don't ix performance and io topics please 🙂
                    we are discussing write access to storage, Redis works in memory so less write on disk/card was my hypothese 🙂
                      paul53 @Dutchman last edited by
                      @Dutchman sagte:
                      Per default Redis writes every 5 minutes to disk/card.
                      • Dutchman
                        Dutchman Developer Most Active Administrators @paul53 last edited by
                        @paul53 sagte in How to lower disk writes (for extending life of an sd card):
                        @Dutchman sagte:
                        Better than every 30 seconds 🤷‍♂️
                        • Mic
                          Mic Developer @Dutchman last edited by
                          @Dutchman sagte in How to lower disk writes (for extending life of an sd card):
                          Exactly, and the default value can certainly be increased to whatever is needed. I would give Redis a try.
                          Also,
                          @Tomasz-Nowak sagte in How to lower disk writes (for extending life of an sd card):
                          I would assume this statement in the documentation was just made for the ease of use of ioBroker in general: Without like Redis, typically ioBroker's performance is good if you have way less than 10000+ objects. You are having a different use case (limited disc r/w per period). Not sure how the performance (like CPU and memory usage) of Redis is on a Raspberry, but I guess pretty low.
                          states.json write interval
                          1478
