    4. Adapter: DasWetter
    Adapter: DasWetter
    • mrFenyx
      mrFenyx last edited by mrFenyx
      Ok, hier ist ein Beispiel. Als erstes muss man für den iconURL state auch das Schreiben erlauben.
      Dann habe ich einen Blockly Script erstellt das bei änderung des Wertes die IP Adresse hinzufügt.
      BlocklyJavascriptTypeScript
      Log outputs
      Export selected blocks
       <variables>
         <variable type="" id="!5F*af~{t.q/O?P():U|">localIP</variable>
         <variable type="" id="@)$iDw;1=[qxXb+|Xu7}">isFixed</variable>
       </variables>
       <block type="variables_set" id="yIBeUGNn8ER-f--bh-Zr" x="38" y="-87">
         <field name="VAR" id="!5F*af~{t.q/O?P():U|" variabletype="">localIP</field>
           <block type="text" id="7XEh:*!Ql-*`%DZ.KYX(">
             <field name="TEXT">http://192.168.1.121:8082</field>
           <block type="on_ext" id="-,Rx]xbnQwOZ3NxFy7[^">
             <value name="OID0">
               <shadow type="field_oid" id="Ff^`^RWaZF4WG2H11k;P">
                 <field name="oid">daswetter.0.NextHours.Location_1.Day_1.current.iconURL</field>
               <block type="variables_set" id="Po%2QdMcg3jzdDH@MR?O">
                 <field name="VAR" id="@)$iDw;1=[qxXb+|Xu7}" variabletype="">isFixed</field>
                   <block type="text_indexOf" id="}bw#~NUR]/dD,@AlmZkt">
                     <field name="END">FIRST</field>
                       <block type="on_source" id="p+0K5`acwl^g2O~ux2ig">
                     <value name="FIND">
                       <shadow type="text" id="/*0*Yr+U9I?R#S*e6AQV">
                         <field name="TEXT">abc</field>
                       <block type="variables_get" id="2)6,@T~Jjv:pQt4R9d14">
                   <block type="debug" id="lo+2TNOdm[w;:1b|+GcZ">
                     <value name="TEXT">
                       <shadow type="text" id="r~{Xwnn]u%UqO(z3,SGg">
                       <block type="variables_get" id="5+gW{2.bG|X`7}.2=4tb">
                       <block type="controls_if" id="E@j6XB4IoceHpwl-Wr09">
                           <block type="logic_compare" id="v$@;97:TU17Imp[xBrxo">
                             <field name="OP">EQ</field>
                               <block type="variables_get" id="guY$RY]R#G+)M7Jb0]=j">
                               <block type="math_number" id="/0%AnKOb.7-t[![,s31h">
                                 <field name="NUM">0</field>
                           <block type="control_ex" id="ZGx0HzjDaq7^PYXE}1+i">
                             <field name="TYPE">true</field>
                             <value name="OID">
                               <shadow type="field_oid">
                                 <field name="oid">daswetter.0.NextHours.Location_1.Day_1.current.iconFullURL</field>
                               <block type="on_source" id="?h_-Jg`rf-G;_Hl3eaPl">
                                 <field name="ATTR">id</field>
                               <shadow type="logic_boolean">
                               <block type="text_join" id="i)ET{w!2L6G#08Tr|O:N">
                                 <value name="ADD0">
                                   <block type="variables_get" id="pbK.i5/%5YweuF4/Snrm">
                                 <value name="ADD1">
                                   <block type="on_source" id="EY:AQ_OHaCM=3mn~5OV,">
                             <value name="DELAY_MS">
                               <shadow type="math_number" id="rsNxCV=ZPeq`LM)hRY^Y">
       <variables>
       </variables>
             <field name="TEXT">http://192.168.2.21:8082</field>
             <value name="OID0">
                     <value name="FIND">
                     <value name="TEXT">
                             <value name="OID">
                                 <value name="ADD0">
                                 <value name="ADD1">
      Wenn du den Script importierst musst du auch die IP Adresse ändern. Viel Glück!
        Bluelightcrew @mrFenyx last edited by Bluelightcrew
        @mrFenyx
        Cool danke für den Tipp!
        So in der Art hatte ich mir das gedacht nur ist es am umsetzen gescheitert 😂
        Hast du das Script so in Benutzung? Ich hab es importiert und die IP geändert aber es reagiert nicht auf Veränderung des icon URL datenpunktes. Hab auch mal testweise den trigger von Veränderung auf aktualisierung geändert, hat aber auch nix bewirkt.
        Ich nehme alles zurück! Kaum war es nach 24uhr läuft es auf einmal, ich weiß nicht wieso aber es läuft, danke.
        mrFenyx 1 Reply Last reply Reply Quote 0
        • mrFenyx
          mrFenyx @Bluelightcrew last edited by
          @Bluelightcrew Cool, freut mich. Und ja, ich hab's auch so in Betrieb und es läuft seit dem ich es gepostet habe ohne Probleme 😉
          • Glasfaser
            Glasfaser @Rene_HM last edited by Glasfaser
            @Rene_HM
            Mir ist letztens aufgefallen , das sich meine Wetterdaten nicht aktualisieren ,
            es ist im Log dazu eine Meldung gekommen .
            2020-03-12 23:18:02.378 - error: daswetter.0 (17366) force terminate, objects still in list: 107
            2020-03-12 23:18:02.380 - warn: daswetter.0 (17366) Terminated (15): Without reason
            2020-03-12 23:18:02.890 - error: host.iobrokerv4 instance system.adapter.daswetter.0 terminated with code 15 (15)
            ok .. dachte mir nach einem Forumseintrag den "Zeitlimit für Herunterladen und Parsen"
            die Zeit höher zu setzten was auch nicht half.
            Dann bei weiteren versuchen , bin ich auf den Fehler gestoßen ,ab wann der ( Adapter ) Probleme macht.
            Alle Datenpunkte von daswetter.0.NextHours.............
            Also tritt es nur bei "Pfad 3: XML-Datei mit Wettervorhersage für die nächsten 5 Tage und stündliche Informationen auf , wo der Fehler kommt und genau das sind alle Datenpunkte die ich zu 90% nutze .
            Habe dann die Adapterversionen rauf und runter installiert , andere Orte für Pfad 3, aber keine Änderung .
            Andere Pfade 1 / 2 werden ohne Probleme angelegt und auch aktualisiert.
            hier der DEBUG Auszug :
            2020-03-17 16:45:01.329 - debug: daswetter.0 (2311) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2020-03-17 16:45:01.378 - debug: daswetter.0 (2311) Objects client ready ... initialize now
            2020-03-17 16:45:01.382 - debug: daswetter.0 (2311) Objects create System PubSub Client
            2020-03-17 16:45:01.383 - debug: daswetter.0 (2311) Objects create User PubSub Client
            2020-03-17 16:45:01.383 - debug: daswetter.0 (2311) Objects client initialize lua scripts
            2020-03-17 16:45:01.425 - debug: daswetter.0 (2311) Objects connected to redis: 127.0.0.1:9001
            2020-03-17 16:45:01.431 - debug: daswetter.0 (2311) objectDB connected
            2020-03-17 16:45:01.433 - debug: daswetter.0 (2311) Redis States: Use Redis connection: 127.0.0.1:9000
            2020-03-17 16:45:01.444 - debug: daswetter.0 (2311) States create User PubSub Client
            2020-03-17 16:45:01.446 - debug: daswetter.0 (2311) States create System PubSub Client
            2020-03-17 16:45:01.466 - debug: daswetter.0 (2311) States connected to redis: 127.0.0.1:9000
            2020-03-17 16:45:01.466 - debug: daswetter.0 (2311) statesDB connected
            2020-03-17 16:45:02.300 - info: daswetter.0 (2311) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
            2020-03-17 16:45:02.324 - debug: daswetter.0 (2311) set timeout to 60 sec
            2020-03-17 16:45:02.325 - debug: daswetter.0 (2311) using new data structure
            2020-03-17 16:45:02.329 - debug: daswetter.0 (2311) objects in list: 0
            2020-03-17 16:45:02.330 - debug: daswetter.0 (2311) nothing to do
            2020-03-17 16:45:02.330 - debug: daswetter.0 (2311) exit, all done
            2020-03-17 16:45:02.331 - info: daswetter.0 (2311) Terminated (NO_ERROR): Without reason
            2020-03-17 16:45:03.236 - info: host.iobrokerv4 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
            2020-03-17 16:49:50.230 - info: host.iobrokerv4 stopInstance system.adapter.daswetter.0 (force=false, process=false)
            2020-03-17 16:49:50.231 - info: host.iobrokerv4 stopInstance canceled schedule system.adapter.daswetter.0
            2020-03-17 16:49:52.738 - info: host.iobrokerv4 instance scheduled system.adapter.daswetter.0 */15 * * * *
            2020-03-17 16:50:07.587 - info: calendar.0 (2065) Updated calendar "Müllkalender"
            2020-03-17 16:52:15.102 - info: info.0 (774) Popup news was read...
            2020-03-17 16:57:57.061 - info: javascript.0 (16079) script.js.Kalender_Zeit.Astro_Tageszeit_Neu: neue Tagezeit: Abend
            2020-03-17 16:57:57.062 - info: javascript.0 (16079) script.js.Kalender_Zeit.Astro_Tageszeit_Neu: nächte kommende Tagezeit: Sonnenuntergang
            2020-03-17 17:00:00.067 - info: host.iobrokerv4 instance system.adapter.daswetter.0 started with pid 11315
            2020-03-17 17:00:00.451 - info: calendar.0 (2065) Updated calendar "Müllkalender"
            2020-03-17 17:00:01.358 - debug: daswetter.0 (11315) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2020-03-17 17:00:01.400 - debug: daswetter.0 (11315) Objects client ready ... initialize now
            2020-03-17 17:00:01.404 - debug: daswetter.0 (11315) Objects create System PubSub Client
            2020-03-17 17:00:01.405 - debug: daswetter.0 (11315) Objects create User PubSub Client
            2020-03-17 17:00:01.406 - debug: daswetter.0 (11315) Objects client initialize lua scripts
            2020-03-17 17:00:01.441 - debug: daswetter.0 (11315) Objects connected to redis: 127.0.0.1:9001
            2020-03-17 17:00:01.446 - debug: daswetter.0 (11315) objectDB connected
            2020-03-17 17:00:01.448 - debug: daswetter.0 (11315) Redis States: Use Redis connection: 127.0.0.1:9000
            2020-03-17 17:00:01.460 - debug: daswetter.0 (11315) States create User PubSub Client
            2020-03-17 17:00:01.462 - debug: daswetter.0 (11315) States create System PubSub Client
            2020-03-17 17:00:01.481 - debug: daswetter.0 (11315) States connected to redis: 127.0.0.1:9000
            2020-03-17 17:00:01.482 - debug: daswetter.0 (11315) statesDB connected
            2020-03-17 17:00:02.051 - info: daswetter.0 (11315) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
            2020-03-17 17:00:02.077 - debug: daswetter.0 (11315) set timeout to 60 sec
            2020-03-17 17:00:02.077 - debug: daswetter.0 (11315) using new data structure
            2020-03-17 17:00:02.078 - debug: daswetter.0 (11315) calling forecast 7 days: http://api.daswetter.com/index.php?api_lang=at&localidad=100950&affiliate_id=myx7k637fzzv
            2020-03-17 17:00:02.368 - debug: daswetter.0 (11315) 7 days forecast done, objects in list 107
            2020-03-17 17:00:02.370 - debug: daswetter.0 (11315) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=at&localidad=100950&affiliate_id=myx7k637fzzv&v=2.0&h=1
            2020-03-17 17:01:02.078 - error: daswetter.0 (11315) force terminate, objects still in list: 107
            2020-03-17 17:01:02.079 - warn: daswetter.0 (11315) Terminated (15): Without reason
            2020-03-17 17:01:02.590 - error: host.iobrokerv4 instance system.adapter.daswetter.0 terminated with code 15 (15)
            2020-03-17 17:03:04.107 - info: javascript.0 (16079) script.js.Wetter.UWZ: AREA: UWZDE47249
            2020-03-17 17:03:04.108 - info: javascript.0 (16079) script.js.Wetter.UWZ: UWZ Body: {"results":[],"generator":"PHPjf"}
            2020-03-17 17:03:04.108 - info: javascript.0 (16079) script.js.Wetter.UWZ: []
            2020-03-17 17:05:25.192 - info: host.iobrokerv4 stopInstance system.adapter.daswetter.0 (force=false, process=false)
            2020-03-17 17:05:25.193 - info: host.iobrokerv4 stopInstance canceled schedule system.adapter.daswetter.0
            2020-03-17 17:05:27.699 - info: host.iobrokerv4 instance scheduled system.adapter.daswetter.0 */15 * * * *
            2020-03-17 17:06:30.572 - info: host.iobrokerv4 stopInstance system.adapter.daswetter.0 (force=false, process=false)
            2020-03-17 17:06:30.573 - info: host.iobrokerv4 stopInstance canceled schedule system.adapter.daswetter.0
            2020-03-17 17:06:33.106 - info: host.iobrokerv4 instance scheduled system.adapter.daswetter.0 */5 * * * *
            2020-03-17 17:07:01.226 - info: host.iobrokerv4 stopInstance system.adapter.daswetter.0 (force=false, process=false)
            2020-03-17 17:07:01.227 - info: host.iobrokerv4 stopInstance canceled schedule system.adapter.daswetter.0
            2020-03-17 17:07:03.742 - info: host.iobrokerv4 instance scheduled system.adapter.daswetter.0 */5 * * * *
            2020-03-17 17:10:00.062 - info: host.iobrokerv4 instance system.adapter.daswetter.0 started with pid 17242
            2020-03-17 17:10:00.453 - info: calendar.0 (2065) Updated calendar "Müllkalender"
            2020-03-17 17:10:01.252 - debug: daswetter.0 (17242) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2020-03-17 17:10:01.295 - debug: daswetter.0 (17242) Objects client ready ... initialize now
            2020-03-17 17:10:01.299 - debug: daswetter.0 (17242) Objects create System PubSub Client
            2020-03-17 17:10:01.300 - debug: daswetter.0 (17242) Objects create User PubSub Client
            2020-03-17 17:10:01.301 - debug: daswetter.0 (17242) Objects client initialize lua scripts
            2020-03-17 17:10:01.335 - debug: daswetter.0 (17242) Objects connected to redis: 127.0.0.1:9001
            2020-03-17 17:10:01.341 - debug: daswetter.0 (17242) objectDB connected
            2020-03-17 17:10:01.343 - debug: daswetter.0 (17242) Redis States: Use Redis connection: 127.0.0.1:9000
            2020-03-17 17:10:01.355 - debug: daswetter.0 (17242) States create User PubSub Client
            2020-03-17 17:10:01.357 - debug: daswetter.0 (17242) States create System PubSub Client
            2020-03-17 17:10:01.375 - debug: daswetter.0 (17242) States connected to redis: 127.0.0.1:9000
            2020-03-17 17:10:01.376 - debug: daswetter.0 (17242) statesDB connected
            2020-03-17 17:10:02.183 - info: daswetter.0 (17242) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
            2020-03-17 17:10:02.206 - debug: daswetter.0 (17242) set timeout to 240 sec
            2020-03-17 17:10:02.206 - debug: daswetter.0 (17242) using new data structure
            2020-03-17 17:10:02.207 - debug: daswetter.0 (17242) calling forecast 7 days: http://api.daswetter.com/index.php?api_lang=at&localidad=100950&affiliate_id=myx7k637fzzv
            2020-03-17 17:10:02.343 - debug: daswetter.0 (17242) 7 days forecast done, objects in list 107
            2020-03-17 17:10:02.345 - debug: daswetter.0 (17242) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=at&localidad=100950&affiliate_id=myx7k637fzzv&v=2.0&h=1
            2020-03-17 17:12:00.064 - info: host.iobrokerv4 instance system.adapter.weatherunderground.0 started with pid 18450
            2020-03-17 17:12:01.945 - info: weatherunderground.0 (18450) starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v10.19.0
            2020-03-17 17:12:09.289 - info: weatherunderground.0 (18450) Terminated (NO_ERROR): Without reason
            2020-03-17 17:12:10.107 - info: host.iobrokerv4 instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
            2020-03-17 17:12:49.006 - debug: daswetter.0 (17242) system.adapter.admin.0: logging false
            2020-03-17 17:12:57.782 - debug: daswetter.0 (17242) system.adapter.admin.0: logging true
            2020-03-17 17:14:02.207 - error: daswetter.0 (17242) force terminate, objects still in list: 107
            2020-03-17 17:14:02.209 - warn: daswetter.0 (17242) Terminated (15): Without reason
            2020-03-17 17:14:02.727 - error: host.iobrokerv4 instance system.adapter.daswetter.0 terminated with code 15 (15)
            2020-03-17 17:15:00.068 - info: host.iobrokerv4 instance system.adapter.daswetter.0 started with pid 20212
            2020-03-17 17:15:01.324 - debug: daswetter.0 (20212) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2020-03-17 17:15:01.369 - debug: daswetter.0 (20212) Objects client ready ... initialize now
            2020-03-17 17:15:01.373 - debug: daswetter.0 (20212) Objects create System PubSub Client
            2020-03-17 17:15:01.374 - debug: daswetter.0 (20212) Objects create User PubSub Client
            2020-03-17 17:15:01.375 - debug: daswetter.0 (20212) Objects client initialize lua scripts
            2020-03-17 17:15:01.410 - debug: daswetter.0 (20212) Objects connected to redis: 127.0.0.1:9001
            2020-03-17 17:15:01.416 - debug: daswetter.0 (20212) objectDB connected
            2020-03-17 17:15:01.418 - debug: daswetter.0 (20212) Redis States: Use Redis connection: 127.0.0.1:9000
            2020-03-17 17:15:01.430 - debug: daswetter.0 (20212) States create User PubSub Client
            2020-03-17 17:15:01.432 - debug: daswetter.0 (20212) States create System PubSub Client
            2020-03-17 17:15:01.454 - debug: daswetter.0 (20212) States connected to redis: 127.0.0.1:9000
            2020-03-17 17:15:01.455 - debug: daswetter.0 (20212) statesDB connected
            2020-03-17 17:15:02.196 - info: daswetter.0 (20212) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
            2020-03-17 17:15:02.220 - debug: daswetter.0 (20212) set timeout to 240 sec
            2020-03-17 17:15:02.221 - debug: daswetter.0 (20212) using new data structure
            2020-03-17 17:15:02.222 - debug: daswetter.0 (20212) calling forecast 7 days: http://api.daswetter.com/index.php?api_lang=at&localidad=100950&affiliate_id=myx7k637fzzv
            2020-03-17 17:15:02.496 - debug: daswetter.0 (20212) 7 days forecast done, objects in list 107
            2020-03-17 17:15:02.498 - debug: daswetter.0 (20212) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=at&localidad=100950&affiliate_id=myx7k637fzzv&v=2.0&h=1
            2020-03-17 17:19:02.221 - error: daswetter.0 (20212) force terminate, objects still in list: 107
            2020-03-17 17:19:02.223 - warn: daswetter.0 (20212) Terminated (15): Without reason
            2020-03-17 17:19:02.737 - error: host.iobrokerv4 instance system.adapter.daswetter.0 terminated with code 15 (15)
            2020-03-17 21:30:01.447 - debug: daswetter.0 (12153) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2020-03-17 21:30:01.491 - debug: daswetter.0 (12153) Objects client ready ... initialize now
            2020-03-17 21:30:01.524 - debug: daswetter.0 (12153) Objects create System PubSub Client
            2020-03-17 21:30:01.525 - debug: daswetter.0 (12153) Objects create User PubSub Client
            2020-03-17 21:30:01.526 - debug: daswetter.0 (12153) Objects client initialize lua scripts
            2020-03-17 21:30:01.570 - debug: daswetter.0 (12153) Objects connected to redis: 127.0.0.1:9001
            2020-03-17 21:30:01.576 - debug: daswetter.0 (12153) objectDB connected
            2020-03-17 21:30:01.579 - debug: daswetter.0 (12153) Redis States: Use Redis connection: 127.0.0.1:9000
            2020-03-17 21:30:01.590 - debug: daswetter.0 (12153) States create User PubSub Client
            2020-03-17 21:30:01.592 - debug: daswetter.0 (12153) States create System PubSub Client
            2020-03-17 21:30:01.613 - debug: daswetter.0 (12153) States connected to redis: 127.0.0.1:9000
            2020-03-17 21:30:01.614 - debug: daswetter.0 (12153) statesDB connected
            2020-03-17 21:30:02.351 - info: daswetter.0 (12153) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
            2020-03-17 21:30:02.373 - debug: daswetter.0 (12153) set timeout to 70 sec
            2020-03-17 21:30:02.374 - debug: daswetter.0 (12153) using old data structure
            2020-03-17 21:30:02.380 - debug: daswetter.0 (12153) calling forecast: http://api.daswetter.com/index.php?api_lang=de&localidad=26469&affiliate_id=myx7k637fzzv&v=2.0&h=1
            2020-03-17 21:31:12.375 - error: daswetter.0 (12153) force terminate, objects still in list: 899
            2020-03-17 21:31:12.376 - warn: daswetter.0 (12153) Terminated (15): Without reason
            2020-03-17 21:31:12.895 - error: host.iobrokerv4 instance system.adapter.daswetter.0 terminated with code 15 (15)
            2020-03-17 21:33:00.087 - info: host.iobrokerv4 instance system.adapter.daswetter.0 started with pid 13931
            2020-03-17 21:33:01.293 - debug: daswetter.0 (13931) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2020-03-17 21:33:01.336 - debug: daswetter.0 (13931) Objects client ready ... initialize now
            2020-03-17 21:33:01.340 - debug: daswetter.0 (13931) Objects create System PubSub Client
            2020-03-17 21:33:01.341 - debug: daswetter.0 (13931) Objects create User PubSub Client
            2020-03-17 21:33:01.341 - debug: daswetter.0 (13931) Objects client initialize lua scripts
            2020-03-17 21:33:01.377 - debug: daswetter.0 (13931) Objects connected to redis: 127.0.0.1:9001
            2020-03-17 21:33:01.383 - debug: daswetter.0 (13931) objectDB connected
            2020-03-17 21:33:01.385 - debug: daswetter.0 (13931) Redis States: Use Redis connection: 127.0.0.1:9000
            2020-03-17 21:33:01.396 - debug: daswetter.0 (13931) States create User PubSub Client
            2020-03-17 21:33:01.398 - debug: daswetter.0 (13931) States create System PubSub Client
            2020-03-17 21:33:01.417 - debug: daswetter.0 (13931) States connected to redis: 127.0.0.1:9000
            2020-03-17 21:33:01.418 - debug: daswetter.0 (13931) statesDB connected
            2020-03-17 21:33:02.191 - info: daswetter.0 (13931) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
            2020-03-17 21:33:02.217 - debug: daswetter.0 (13931) set timeout to 70 sec
            2020-03-17 21:33:02.217 - debug: daswetter.0 (13931) using old data structure
            2020-03-17 21:33:02.223 - debug: daswetter.0 (13931) calling forecast: http://api.daswetter.com/index.php?api_lang=de&localidad=26469&affiliate_id=myx7k637fzzv&v=2.0&h=1
            2020-03-17 21:33:23.844 - debug: daswetter.0 (13931) system.adapter.admin.0: logging true
            2020-03-17 21:33:52.270 - debug: daswetter.0 (13931) system.adapter.admin.0: logging false
            2020-03-17 21:34:08.089 - debug: daswetter.0 (13931) system.adapter.admin.0: logging true
            2020-03-17 21:34:12.218 - error: daswetter.0 (13931) force terminate, objects still in list: 899
            2020-03-17 21:34:12.219 - warn: daswetter.0 (13931) Terminated (15): Without reason
            2020-03-17 21:34:12.740 - error: host.iobrokerv4 instance system.adapter.daswetter.0 terminated with code 15 (15)
            Meine Systemdaten:
            nodejs : v10.19.0
            node   : v10.19.0
            npm    : 6.14.1
            js-controller : 2.2.9
            system.adapter.admin                   : admin          - v4.0.5
            system.adapter.alexa                   : alexa          - v0.0.36
            system.adapter.alexa2                  : alexa2         - v3.0.7
            system.adapter.asterisk                : asterisk       - v1.0.6
            system.adapter.b-control-em            : b-control-em   - v0.2.1
            system.adapter.backitup                : backitup       - v1.4.1
            system.adapter.broadlink2              : broadlink2     - v2.0.2
            system.adapter.bsblan                  : bsblan         - v0.0.6
            system.adapter.calendar                : calendar       - v1.0.1
            system.adapter.chromecast              : chromecast     - v2.3.1
            system.adapter.cloud                   : cloud          - v3.0.2
            system.adapter.contactid               : contactid      - v1.0.0
            system.adapter.daswetter               : daswetter      - v2.8.1
            system.adapter.deconz                  : deconz         - v1.3.1
            system.adapter.discovery               : discovery      - v2.2.2
            system.adapter.dwd                     : dwd            - v2.4.6
            system.adapter.email                   : email          - v1.0.6
            system.adapter.enigma2                 : enigma2        - v1.2.5
            system.adapter.feiertage               : feiertage      - v1.0.17
            system.adapter.flot                    : flot           - v1.9.2
            system.adapter.fontui                  : fontui         - v0.1.0
            system.adapter.fritzbox                : fritzbox       - v0.3.1
            system.adapter.fritzdect               : fritzdect      - v0.2.4
            system.adapter.history                 : history        - v1.8.6
            system.adapter.hm-rega                 : hm-rega        - v2.5.5
            system.adapter.hm-rpc                  : hm-rpc         - v1.12.8
            system.adapter.hmip                    : hmip           - v0.0.11
            system.adapter.hue                     : hue            - v3.2.3
            system.adapter.ical                    : ical           - v1.6.6
            system.adapter.icons-addictive-flavour-png: icons-addictive-flavour-png - v0.1.1
            system.adapter.icons-icons8            : icons-icons8   - v0.0.1
            system.adapter.icons-mfd-png           : icons-mfd-png  - v1.0.2
            system.adapter.icons-mfd-svg           : icons-mfd-svg  - v1.0.2
            system.adapter.icons-open-icon-library-png: icons-open-icon-library-png - v0.1.3
            system.adapter.icons-ultimate-png      : icons-ultimate-png - v1.0.1
            system.adapter.influxdb                : influxdb       - v1.7.0
            system.adapter.info                    : info           - v1.5.7
            system.adapter.iot                     : iot            - v1.3.2
            system.adapter.javascript              : javascript     - v4.4.2
            system.adapter.knx                     : knx            - v1.0.37
            system.adapter.lupusec                 : lupusec        - v1.2.3
            system.adapter.milight                 : milight        - v0.3.6
            system.adapter.milight-smart-light     : milight-smart-light - v0.2.7
            system.adapter.mobile                  : mobile         - v0.5.0
            system.adapter.motion                  : motion         - v0.0.1
            system.adapter.mqtt                    : mqtt           - v2.0.4
            system.adapter.nina                    : nina           - v0.0.21
            system.adapter.node-red                : node-red       - v1.13.0
            system.adapter.nut                     : nut            - v1.1.3
            system.adapter.openweathermap          : openweathermap - v0.1.0
            system.adapter.ping                    : ping           - v1.3.2
            system.adapter.pushover                : pushover       - v1.2.3
            system.adapter.rickshaw                : rickshaw       - v1.0.0
            system.adapter.samsung2016             : samsung2016    - v0.0.2
            system.adapter.sayit                   : sayit          - v1.8.2
            system.adapter.scenes                  : scenes         - v1.1.0
            system.adapter.sia                     : sia            - v1.0.4
            system.adapter.simple-api              : simple-api     - v2.3.2
            system.adapter.snmp                    : snmp           - v0.5.0
            system.adapter.socketio                : socketio       - v3.0.1
            system.adapter.sonoff                  : sonoff         - v2.3.3
            system.adapter.sourceanalytix          : sourceanalytix - v0.3.0
            system.adapter.sql                     : sql            - v1.9.5
            system.adapter.synology                : synology       - v0.0.4
            system.adapter.systeminfo              : systeminfo     - v0.3.1
            system.adapter.telegram                : telegram       - v1.5.4
            system.adapter.terminal                : terminal       - v0.1.2
            system.adapter.text2command            : text2command   - v1.3.0
            system.adapter.tr-064                  : tr-064         - v3.1.4
            system.adapter.tr-064-community        : tr-064-community - v1.0.0
            system.adapter.tvspielfilm             : tvspielfilm    - v1.0.4
            system.adapter.upnp                    : upnp           - v1.0.15
            system.adapter.vis                     : vis            - v1.2.4
            system.adapter.vis-colorpicker         : vis-colorpicker - v1.1.1
            system.adapter.vis-history             : vis-history    - v1.0.0
            system.adapter.vis-justgage            : vis-justgage   - v1.0.2
            system.adapter.vis-material            : vis-material   - v0.1.5
            system.adapter.vis-materialdesign      : vis-materialdesign - v0.2.66
            system.adapter.vis-plumb               : vis-plumb      - v1.0.2
            system.adapter.vis-weather             : vis-weather    - v2.5.2
            system.adapter.vuplus                  : vuplus         - v0.1.0
            system.adapter.weatherunderground      : weatherunderground - v3.2.0
            system.adapter.web                     : web            - v3.0.1
            system.adapter.web-speedy              : web-speedy     - v0.2.0
            system.adapter.wifilight               : wifilight      - v0.2.0
            system.adapter.zigbee                  : zigbee         - v1.0.4
            __________________________-
            EDIT :
            Zur Info !
            Ich habe im Pfad 3 das Ende für die Stündliche Information
            http://api.daswetter.com.........=2.0&h=1
            auf
            Informationen für alle 3 Stunden was eigentlich für Pfad 2 ist geändert
            und dort werden dann die Datenpunkte für daswetter.0.NextHours............. gefüllt und aktualisiert.
            Nur dadurch fehlen andere Datenpunkte wie zb.
            daswetter.0.NextHours.Location_1.Day_1.current.snowline_value
            daswetter.0.NextHours.Location_1.Day_1.current.humidity_value
            daswetter.0.NextHours.Location_1.Day_1.current.wind_value
            usw ....................
            • Rene_HM
              Rene_HM Developer @Glasfaser last edited by
              @Glasfaser hast du probiert, ob die URL auch wirklich Daten liefert (z.Bsp. in einem normalen Browser)? Laut log bekommst du meiner Meinung nach keine oder eine falsche Antwort vom Server...
              Ich verstehe auch nicht, warum du alte und neue Datenstruktur umschaltest. Das Umschalten dauert sehr lange, da dort alte Einträge u.U. gelöscht werden und die neuen neu angelegt werden müssen.
              Das ändern der URL manuell nützt nichts, da ich ja nur die Daten parse, die laut Doku geliefert werden sollten. Wenn andere Daten als laut Doku kommen, werden die ignoriert...
              • Glasfaser
                @Rene_HM sagte in Adapter: DasWetter:
                Die URL die ich von dasWetter bekomme funktionieren alle im Browser , habe auch mehere Orte versucht .
                Deswegen habe ich ganz zum Schluss nochmal den Test mit der URL für Pfad 2 dann in Pfad 3 eingesetz und dort werden dann die Datenpunkte gefüllt ( unvollständig)
                Kann sein das ich den Log von den verschienden Versionen ausgepickt habe , wo ich alles mögliche getestete habe .
                Habe alle Datenpunkte gelöscht inkl. dem Adapter und alles neu installiert und es kommt immer dieser Fehler in Pfad 3 mit der richtigen URL die auch erreichbar ist im Browser
                ______________________________----
                EDIT : hier aktuell als TEST und nochmals alles gelöscht und installiert
                http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
                host.iobrokerv4	2020-03-18 19:53:23.800	info	"system.adapter.daswetter.0" disabled
                host.iobrokerv4	2020-03-18 19:53:02.722	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
                daswetter.0	2020-03-18 19:53:02.196	warn	(5048) Terminated (15): Without reason
                daswetter.0	2020-03-18 19:53:02.194	error	(5048) force terminate, objects still in list: 0
                daswetter.0	2020-03-18 19:51:02.197	debug	(5048) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
                daswetter.0	2020-03-18 19:51:02.195	debug	(5048) using new data structure
                daswetter.0	2020-03-18 19:51:02.194	debug	(5048) set timeout to 120 sec
                daswetter.0	2020-03-18 19:51:02.170	info	(5048) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
                daswetter.0	2020-03-18 19:51:01.393	debug	(5048) statesDB connected
                daswetter.0	2020-03-18 19:51:01.391	debug	(5048) States connected to redis: 127.0.0.1:9000
                daswetter.0	2020-03-18 19:51:01.316	debug	(5048) States create System PubSub Client
                daswetter.0	2020-03-18 19:51:01.314	debug	(5048) States create User PubSub Client
                daswetter.0	2020-03-18 19:51:01.302	debug	(5048) Redis States: Use Redis connection: 127.0.0.1:9000
                daswetter.0	2020-03-18 19:51:01.300	debug	(5048) objectDB connected
                daswetter.0	2020-03-18 19:51:01.294	debug	(5048) Objects connected to redis: 127.0.0.1:9001
                daswetter.0	2020-03-18 19:51:01.266	debug	(5048) Objects client initialize lua scripts
                daswetter.0	2020-03-18 19:51:01.265	debug	(5048) Objects create User PubSub Client
                daswetter.0	2020-03-18 19:51:01.264	debug	(5048) Objects create System PubSub Client
                daswetter.0	2020-03-18 19:51:01.260	debug	(5048) Objects client ready ... initialize now
                daswetter.0	2020-03-18 19:51:01.220	debug	(5048) Redis Objects: Use Redis connection: 127.0.0.1:9001
                host.iobrokerv4	2020-03-18 19:51:00.061	info	instance system.adapter.daswetter.0 started with pid 5048
                host.iobrokerv4	2020-03-18 19:49:52.586	info	instance scheduled system.adapter.daswetter.0 */3 * * * *
                • Rene_HM
                  @Glasfaser sagte in Adapter: DasWetter:
                  gib die URL mal in einem browser ein...
                  • Glasfaser
                    @Rene_HM
                    Und dann !???
                    Das ist die URL von das Wetter :
                    • Rene_HM
                      @Glasfaser ich hätte so etwas erwartet:
                      aber bei dir sieht es gut aus...
                      Trotzdem bekommt der Adapter irgendwie keine Antwort:
                      Hier sieht man, dass auf die erste Abfrage eine Antwort kommt, es werden 107 Datenpunkte gelesen, auf die zweite Abfrage kommt keine Antwort. Im log müsste erscheinen, wieviele Datenpunkt dort erhalten wurden. Das fehlt und der Adapter wartet...
                      • Glasfaser
                        @Rene_HM
                        Wie schon erwähnt ... ist es bei jeder Stadt die ich getestet habe ... nur das merkwürdige bei Pfad 3 funktioniert es halt nicht .
                        Und jetzt ? wie kann ich weiter den Fehler eingrenzen ... obwohl ich schon alles versucht habe.
                        "Zeitlimit für Herunterladen und Parsen" schon rauf und runter .
                        Auch schon auf 10 Minuten gestellt , alle Varianten ......
                        Rene_HM 2 Replies Last reply Reply Quote 0
                        • Rene_HM
                          @Glasfaser habs eben bei mir mit deiner URL probiert, es geht:
                          020-03-18 21:17:02.688 - info: daswetter.0 (28513) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
                          2020-03-18 21:17:02.737 - debug: daswetter.0 (28513) set timeout to 240 sec
                          2020-03-18 21:17:02.739 - debug: daswetter.0 (28513) using new data structure
                          2020-03-18 21:17:02.744 - debug: daswetter.0 (28513) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
                          2020-03-18 21:17:03.363 - debug: daswetter.0 (28513) hourly forecast done, objects in list 1640
                          2020-03-18 21:17:03.367 - debug: daswetter.0 (28513) objects in list: 1640
                          2020-03-18 21:17:13.875 - debug: daswetter.0 (28513) nothing to do
                          2020-03-18 21:17:13.876 - debug: daswetter.0 (28513) exit, all done
                          2020-03-18 21:17:13.878 - info: daswetter.0 (28513) Terminated (NO_ERROR): Without reason
                          • Rene_HM
                            Und jetzt ?
                            Ich kann dir eine Version auf github legen, die noch ein paar mehr logs schreibt. Vielleicht hilft uns das. Das wird aber erst am Wochenende...
                            Glasfaser 1 Reply Last reply Reply Quote 1
                            • Glasfaser
                              @Rene_HM
                              Kein Problem ... sage mir dann Bescheid 👍
                              • Rene_HM
                                @Glasfaser 2.8.2 liegt im github.
                                neues log sollte so aussehen (wenn nur Pfad 3 abgeholt wird):
                                2020-03-19 21:09:03.943 - info: daswetter.0 (3255) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
                                2020-03-19 21:09:03.995 - debug: daswetter.0 (3255) set timeout to 240 sec
                                2020-03-19 21:09:03.997 - debug: daswetter.0 (3255) using new data structure
                                2020-03-19 21:09:04.005 - debug: daswetter.0 (3255) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
                                2020-03-19 21:09:04.298 - debug: daswetter.0 (3255) got response
                                2020-03-19 21:09:04.299 - debug: daswetter.0 (3255) got data without error, now parsing
                                2020-03-19 21:09:04.578 - debug: daswetter.0 (3255) number of locations 1
                                2020-03-19 21:09:04.583 - debug: daswetter.0 (3255) number of days 5
                                2020-03-19 21:09:04.591 - debug: daswetter.0 (3255) number of hours 24
                                2020-03-19 21:09:04.641 - debug: daswetter.0 (3255) number of hours 24
                                2020-03-19 21:09:04.664 - debug: daswetter.0 (3255) number of hours 8
                                2020-03-19 21:09:04.673 - debug: daswetter.0 (3255) number of hours 8
                                2020-03-19 21:09:04.683 - debug: daswetter.0 (3255) number of hours 8
                                2020-03-19 21:09:04.691 - debug: daswetter.0 (3255) hourly forecast done, objects in list 1640
                                2020-03-19 21:09:04.696 - debug: daswetter.0 (3255) objects in list: 1640
                                2020-03-19 21:09:05.630 - debug: daswetter.0 (3255) objects in list: 1539
                                2020-03-19 21:09:06.433 - debug: daswetter.0 (3255) objects in list: 1438
                                2020-03-19 21:09:07.091 - debug: daswetter.0 (3255) objects in list: 1337
                                2020-03-19 21:09:07.706 - debug: daswetter.0 (3255) objects in list: 1236
                                2020-03-19 21:09:08.345 - debug: daswetter.0 (3255) objects in list: 1135
                                2020-03-19 21:09:10.746 - debug: daswetter.0 (3255) objects in list: 1034
                                2020-03-19 21:09:11.346 - debug: daswetter.0 (3255) objects in list: 933
                                2020-03-19 21:09:11.873 - debug: daswetter.0 (3255) objects in list: 832
                                2020-03-19 21:09:12.450 - debug: daswetter.0 (3255) objects in list: 731
                                2020-03-19 21:09:12.989 - debug: daswetter.0 (3255) objects in list: 630
                                2020-03-19 21:09:13.531 - debug: daswetter.0 (3255) objects in list: 529
                                2020-03-19 21:09:14.024 - debug: daswetter.0 (3255) objects in list: 428
                                2020-03-19 21:09:14.541 - debug: daswetter.0 (3255) objects in list: 327
                                2020-03-19 21:09:15.057 - debug: daswetter.0 (3255) objects in list: 226
                                2020-03-19 21:09:15.561 - debug: daswetter.0 (3255) objects in list: 125
                                2020-03-19 21:09:16.077 - debug: daswetter.0 (3255) objects in list: 24
                                2020-03-19 21:09:16.256 - debug: daswetter.0 (3255) nothing to do
                                2020-03-19 21:09:16.257 - debug: daswetter.0 (3255) exit, all done
                                • Glasfaser
                                  @Rene_HM
                                  Hier ist das Ergebnis 😞
                                  host.iobrokerv4	2020-03-19 22:40:02.680	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
                                  daswetter.0	2020-03-19 22:40:02.169	warn	(6775) Terminated (15): Without reason
                                  daswetter.0	2020-03-19 22:40:02.168	error	(6775) force terminate, objects still in list: 0
                                  daswetter.0	2020-03-19 22:36:02.170	debug	(6775) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
                                  daswetter.0	2020-03-19 22:36:02.167	debug	(6775) using new data structure
                                  daswetter.0	2020-03-19 22:36:02.166	debug	(6775) set timeout to 240 sec
                                  daswetter.0	2020-03-19 22:36:02.144	info	(6775) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
                                  host.iobrokerv4	2020-03-19 22:36:00.072	info	instance system.adapter.daswetter.0 started with pid 6775
                                  host.iobrokerv4	2020-03-19 22:34:02.756	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
                                  daswetter.0	2020-03-19 22:34:02.244	warn	(3023) Terminated (15): Without reason
                                  daswetter.0	2020-03-19 22:34:02.243	error	(3023) force terminate, objects still in list: 0
                                  daswetter.0	2020-03-19 22:30:02.246	debug	(3023) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
                                  daswetter.0	2020-03-19 22:30:02.243	debug	(3023) using new data structure
                                  daswetter.0	2020-03-19 22:30:02.242	debug	(3023) set timeout to 240 sec
                                  daswetter.0	2020-03-19 22:30:02.217	info	(3023) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
                                  host.iobrokerv4	2020-03-19 22:30:00.069	info	instance system.adapter.daswetter.0 started with pid 3023
                                  host.iobrokerv4	2020-03-19 22:28:02.784	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
                                  daswetter.0	2020-03-19 22:24:02.275	debug	(31701) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
                                  daswetter.0	2020-03-19 22:24:02.272	debug	(31701) using new data structure
                                  daswetter.0	2020-03-19 22:24:02.271	debug	(31701) set timeout to 240 sec
                                  daswetter.0	2020-03-19 22:24:02.250	info	(31701) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
                                  host.iobrokerv4	2020-03-19 22:24:00.078	info	instance system.adapter.daswetter.0 started with pid 31701
                                  • harrym
                                    harrym last edited by
                                    ich hab damit noch nie Probleme gehabt ....?
                                    • Rene_HM
                                      @Glasfaser der Adapter bekommt keine Antwort vom Server, deshalb der timeout.
                                      Glasfaser 2 Replies Last reply Reply Quote 0
                                      • Glasfaser
                                        @Rene_HM
                                        Ok ... sehr mehrkwürdig !
                                        Die URL ist über den Browser sofort erreichbar,
                                        nur halt bei Pfad3 im Adapter wo der Link anders aufgebaut ist ( 2.0&h=1 ) funktioniert es nicht , bzw. der Server ist nicht erreichbar !?
                                        Kann man da was eingrenzen herrausfinden woran das liegt !?
                                        DANKE für deine Mühe !!!
                                        • Glasfaser
                                          @Rene_HM
                                          Habe einen zweiten iobroker im Docker installiert .(Neuinstallation)
                                          Gerade mal die Grundinstallation vorhanden und dort geht es auch nicht .
                                          Ich verstehe es nicht !
                                          root@iobrokerv3:/opt/iobroker# node -v
                                          v10.19.0
                                          root@iobrokerv3:/opt/iobroker# nodejs -v
                                          v10.19.0
                                          root@iobrokerv3:/opt/iobroker# npm -v
                                          sudo: Hostname iobrokerv3 kann nicht aufgelöst werden
                                          6.13.4
                                          root@iobrokerv3:/opt/iobroker# iobroker -v
                                          2.2.9
                                          root@iobrokerv3:/opt/iobroker# iobroker list adapters
                                          system.adapter.admin                   : admin          - v3.7.8
                                          system.adapter.daswetter               : daswetter      - v2.8.2
                                          system.adapter.discovery               : discovery      - v1.3.0
                                          system.adapter.info                    : info           - v1.5.6
                                          root@iobrokerv3:/opt/iobroker# iobroker list instances
                                          + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          + system.adapter.daswetter.0             : daswetter             -  enabled
                                          + system.adapter.discovery.0             : discovery             -  enabled
                                          + system.adapter.info.0                  : info                  -  enabled
                                          + instance is alive
                                          root@iobrokerv3:/opt/iobroker# ping 104.18.197.72
                                          PING 104.18.197.72 (104.18.197.72) 56(84) bytes of data.
                                          64 bytes from 104.18.197.72: icmp_seq=1 ttl=56 time=15.6 ms
                                          64 bytes from 104.18.197.72: icmp_seq=2 ttl=56 time=17.9 ms
                                          64 bytes from 104.18.197.72: icmp_seq=3 ttl=56 time=16.1 ms
                                          64 bytes from 104.18.197.72: icmp_seq=4 ttl=56 time=12.3 ms
                                          64 bytes from 104.18.197.72: icmp_seq=5 ttl=56 time=17.7 ms
                                          64 bytes from 104.18.197.72: icmp_seq=6 ttl=56 time=19.9 ms
                                          64 bytes from 104.18.197.72: icmp_seq=7 ttl=56 time=14.8 ms
                                          64 bytes from 104.18.197.72: icmp_seq=8 ttl=56 time=12.8 ms
                                          64 bytes from 104.18.197.72: icmp_seq=9 ttl=56 time=20.5 ms
                                          64 bytes from 104.18.197.72: icmp_seq=10 ttl=56 time=13.0 ms
                                          ^C
                                          --- 104.18.197.72 ping statistics ---
                                          10 packets transmitted, 10 received, 0% packet loss, time 9013ms
                                          rtt min/avg/max/mdev = 12.389/16.106/20.512/2.755 ms
                                          root@iobrokerv3:/opt/iobroker# ^C
                                          LOG :
                                          host.iobrokerv3	2020-03-20 23:10:01.692	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
                                          daswetter.0	2020-03-20 23:10:01.181	warn	(1072) Terminated (15): Without reason
                                          daswetter.0	2020-03-20 23:10:01.180	error	(1072) force terminate, objects still in list: 0
                                          daswetter.0	2020-03-20 23:06:01.183	debug	(1072) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
                                          daswetter.0	2020-03-20 23:06:01.180	debug	(1072) using new data structure
                                          daswetter.0	2020-03-20 23:06:01.179	debug	(1072) set timeout to 240 sec
                                          daswetter.0	2020-03-20 23:06:01.157	info	(1072) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
                                          daswetter.0	2020-03-20 23:06:01.065	debug	(1072) statesDB connected
                                          daswetter.0	2020-03-20 23:06:01.064	debug	(1072) States connected to redis: 127.0.0.1:9000
                                          daswetter.0	2020-03-20 23:06:01.059	debug	(1072) States create System PubSub Client
                                          daswetter.0	2020-03-20 23:06:01.056	debug	(1072) States create User PubSub Client
                                          daswetter.0	2020-03-20 23:06:01.052	debug	(1072) Redis States: Use Redis connection: 127.0.0.1:9000
                                          daswetter.0	2020-03-20 23:06:01.049	debug	(1072) objectDB connected
                                          daswetter.0	2020-03-20 23:06:01.044	debug	(1072) Objects connected to redis: 127.0.0.1:9001
                                          daswetter.0	2020-03-20 23:06:01.034	debug	(1072) Objects client initialize lua scripts
                                          daswetter.0	2020-03-20 23:06:01.034	debug	(1072) Objects create User PubSub Client
                                          daswetter.0	2020-03-20 23:06:01.033	debug	(1072) Objects create System PubSub Client
                                          daswetter.0	2020-03-20 23:06:01.029	debug	(1072) Objects client ready ... initialize now
                                          daswetter.0	2020-03-20 23:06:00.996	debug	(1072) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          host.iobrokerv3	2020-03-20 23:06:00.017	info	instance system.adapter.daswetter.0 started with pid 1072
                                          host.iobrokerv3	2020-03-20 23:04:02.142	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
                                          daswetter.0	2020-03-20 23:04:01.630	warn	(1000) Terminated (15): Without reason
                                          daswetter.0	2020-03-20 23:04:01.629	error	(1000) force terminate, objects still in list: 0
                                          daswetter.0	2020-03-20 23:00:01.632	debug	(1000) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
                                          daswetter.0	2020-03-20 23:00:01.629	debug	(1000) using new data structure
                                          daswetter.0	2020-03-20 23:00:01.628	debug	(1000) set timeout to 240 sec
                                          daswetter.0	2020-03-20 23:00:01.606	info	(1000) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
                                          daswetter.0	2020-03-20 23:00:01.069	debug	(1000) statesDB connected
                                          daswetter.0	2020-03-20 23:00:01.068	debug	(1000) States connected to redis: 127.0.0.1:9000
                                          daswetter.0	2020-03-20 23:00:01.062	debug	(1000) States create System PubSub Client
                                          daswetter.0	2020-03-20 23:00:01.060	debug	(1000) States create User PubSub Client
                                          daswetter.0	2020-03-20 23:00:01.055	debug	(1000) Redis States: Use Redis connection: 127.0.0.1:9000
                                          daswetter.0	2020-03-20 23:00:01.053	debug	(1000) objectDB connected
                                          daswetter.0	2020-03-20 23:00:01.048	debug	(1000) Objects connected to redis: 127.0.0.1:9001
                                          daswetter.0	2020-03-20 23:00:01.036	debug	(1000) Objects client initialize lua scripts
                                          daswetter.0	2020-03-20 23:00:01.036	debug	(1000) Objects create User PubSub Client
                                          daswetter.0	2020-03-20 23:00:01.035	debug	(1000) Objects create System PubSub Client
                                          daswetter.0	2020-03-20 23:00:01.030	debug	(1000) Objects client ready ... initialize now
                                          daswetter.0	2020-03-20 23:00:00.997	debug	(1000) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          host.iobrokerv3	2020-03-20 23:00:00.011	info	instance system.adapter.daswetter.0 started with pid 1000
                                          Negalein Rene_HM 2 Replies Last reply Reply Quote 0
                                          • Negalein
                                            Negalein Global Moderator @Glasfaser last edited by
                                            Ich hatte das bei mir auch mal. Zwar nicht ioBroker, oder ein Adapter davon.
                                            Alles ging, nur 1 Adresse konnte ich nie öffnen.
                                            Nach sehr sehr viel Sucherei und Testerei lag es an der Syno und Fritz.
                                            Update der Fritz dürfte an der Syno etwas aktiviert haben, so dass diese Adresse immer blockiert wurde.
                                            Leider schien dies in keinem Log auf.
                                            Wir haben im Endeffekt die Fritz komplett zurückgesetzt und an der Syno alles in der Firewall komplett neu erstellt.
                                            1208
                                            410977
