    4. Test Coronavirus Statistics for ioBroker
    • Uli977
      Uli977 last edited by
      Wie ändere ich denn dies hier von World auf Deutschland
        sigi234 Forum Testing Most Active @Scrounger last edited by sigi234
        @Scrounger
        javascript.0	2020-03-19 10:39:28.302	warn	(11884) getState "coronavirus-statistics.0.Togo.todayDeathsPerOneMillion" not found (3)
        javascript.0	2020-03-19 10:39:28.302	warn	(11884) at Timer.processTimers (timers.js:223:10)
        javascript.0	2020-03-19 10:39:28.302	warn	(11884) at listOnTimeout (timers.js:263:5)
        javascript.0	2020-03-19 10:39:28.302	warn	(11884) at tryOnTimeout (timers.js:300:5)
        javascript.0	2020-03-19 10:39:28.302	warn	(11884) at ontimeout (timers.js:438:13)
        javascript.0	2020-03-19 10:39:28.302	warn	(11884) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:2077:34)
        javascript.0	2020-03-19 10:39:28.302	warn	(11884) at Object.<anonymous> (script.js.Sigi.Corona_Kontinent:78:17)
        javascript.0	2020-03-19 10:39:28.302	warn	(11884) at calcStats (script.js.Sigi.Corona_Kontinent:110:97)
        javascript.0	2020-03-19 10:39:28.301	warn	(11884) getState "coronavirus-statistics.0.Togo.todayCasesPerOneMillion" not found (3)
        javascript.0	2020-03-19 10:39:28.301	warn	(11884) at Timer.processTimers (timers.js:223:10)
        javascript.0	2020-03-19 10:39:28.301	warn	(11884) at listOnTimeout (timers.js:263:5)
        javascript.0	2020-03-19 10:39:28.301	warn	(11884) at tryOnTimeout (timers.js:300:5)
        javascript.0	2020-03-19 10:39:28.301	warn	(11884) at ontimeout (timers.js:438:13)
        javascript.0	2020-03-19 10:39:28.301	warn	(11884) at Timeout._onTimeout (C:\Program Files\iobroker\Test\node_modules\iobroker.javascript\lib\sandbox.js:2077:34)
        javascript.0	2020-03-19 10:39:28.301	warn	(11884) at Object.<anonymous> (script.js.Sigi.Corona_Kontinent:78:17)
        javascript.0	2020-03-19 10:39:28.301	warn	(11884) at calcStats (script.js.Sigi.Corona_Kontinent:109:93)
        javascript.0	2020-03-19 10:39:28.301	warn	(11884) getState "coronavirus-statistics.0.Togo.criticalPerOneMillion" not found (3)
        • Scrounger
          Scrounger Developer @sigi234 last edited by
          @sigi234
          Fehlermeldung kommt wegen dem neuen Wert. Muss ich das Skript anpassen.
          @Dutchman sagte in Test Coronavirus Statistics for ioBroker:
          solved in 0.2.3
          @sigi234 sagte in Test Coronavirus Statistics for ioBroker:
          das funktioniert auch nicht out of the box!
          Ihr müsst für die Graphen Eure eigenen History Instanzen und Datenpunkte eintragen
            @Scrounger sagte in Test Coronavirus Statistics for ioBroker:
            Habe ich
              Brati @MyzerAT last edited by
              @MyzerAT Einfach im Admin aus GitHub installieren, dann zieht er auch die 0.2.3.
              Brati
                sigi234 Forum Testing Most Active @sigi234 last edited by sigi234
                Habe ich
                Es gehen keine meiner Charts mehr , dreht ständig im Kreis
                Vis-materialdesign-Chart-Line-History
                Edit:
                Mit Update erledigt.
                • Chaot
                  Chaot @Dutchman last edited by
                  @Dutchman Nur mal in den Raum geworfen:
                  Hast du auch mal an die Möglichkeit gedacht ein Quarantäne Countdown einzubauen? 🤕
                  • Dutchman
                    version 0.2.4 ist raus mit grossen dank an @Scrounger der seine Lösung der continente implementiert hat !
                    naaste baustelle : filter per land das man nicht die ganze wel rein bekommt 🙂
                    • Dutchman
                      Dutchman Developer Most Active Administrators @Chaot last edited by
                      @Chaot sagte in Test Coronavirus Statistics for ioBroker:
                      hehe, euh .... mach mir ein git issue und ich nimmt beim niesten release mit so schwer ist das garnicht 😊
                      • Chaot
                        @Dutchman
                        Habe ich gemacht. Alternativ habe ich mir das Ding hier mal angeschaut:
                        https://forum.iobroker.net/topic/22077/neuer-adapter-countdown/42?page=3
                        Würde auch taugen. Ist zwar bischen blöd einzustellen, aber machbar.
                        Dutchman crunchip 2 Replies Last reply Reply Quote 0
                        • Dutchman
                          ich dachte eher daran nen Datenpunkt mit datum ein zu tragen der dan runter zählt.
                          mal schauen
                          • Chaot
                            @Dutchman
                            Ich gehe davon aus das wir in den nächsten Tagen die Anordnung "Quarantäne bis xx.xx.xxxx " bekommen werden.
                            Dafür taugt dann der Countdown.
                            Bei uns ist seit heute sogar nachts die Straßenbeleuchtung aus aber die Leute sind immer noch unterwegs.
                            Da hilft dann vermutlich wirklich nur noch die Keule.
                              crunchip Forum Testing Most Active @Chaot last edited by
                              Strom sparen, damit das Smarthome weiter laufen kann🙂
                                @Chaot sowas wie Einfacher Countdown
                                allerdings habe ich gesehen, dass du selbst in dem Thread aktiv warst.
                                  SaiBot1981 last edited by SaiBot1981
                                  Ich habe mich ein wenig hin gesetzt und eine view in 800*600 speziel für ältere Tablets erstellt (habe mich an einer view hier aus dem Tread bedient... danke für die Vorlage)
                                  kann in iqontrol als PopUp genutzt werden
                                  Falls jemand interesse hat...
                                  Dazu ein Button für zB iqontrol:
                                  hier die View einfach zum einfügen: Corona View.txt
                                  Die icons: Icons.rar
                                  Hier noch die Flaggen: Flaggen.rar
                                  Getestet mit iPad2 und Huawei MediaTab T3
                                  edit: hatte die Icons vergessen
                                  sigi234 Chaot 2 Replies Last reply Reply Quote 1
                                    sigi234 Forum Testing Most Active @SaiBot1981 last edited by
                                    @TiboTake sagte in Test Coronavirus Statistics for ioBroker:
                                    Bitte sehr. 😀
                                    • Chaot
                                      Chaot @SaiBot1981 last edited by
                                      @TiboTake Danke schön.
                                      Bei mir fehlen ein paar Sachen:
                                      Das Bild "Asien"
                                      Die Bilder
                                      Die Überschriften der Bilder
                                        SaiBot1981 @Chaot last edited by SaiBot1981
                                        @Chaot said in Test Coronavirus Statistics for ioBroker:
                                        Das Bild "Asien"
                                        Die Bilder
                                        Lad dir die Icons und Flagge nochmal runter...
                                        Hatte bei den Flaggen asien vergessen und die Icons komplett....
                                        Da ich die oberen Texte mit den Icons gruppiert habe wird es wohl daran liegen
                                        Die Icons ins selbe Verzeichnis wie die Flaggen laden
                                        • Chaot
                                          @TiboTake
                                          Danke. Die Icons scheinen jetzt vorhanden.
                                          Aber vermutlich ist beim Export iorgendwas scheifgegangen.
                                          Die Gruppe scheint leer zu sein.
                                          Ich hab das mal zerlegt:
                                            @Chaot dann zerlege ich eben die gruppen und lade es gleich nach testen neu hoch...
                                            habs getestet. die icons hatte ich zwar noch drinne aber läuft
                                            adapter installation adapterentwicklung testen
                                            120
                                            1177
                                            332967
