    4. IOBroker Anbindung an einen Kostal Plenticore
    • Diginix
      Diginix last edited by
      Hab jetzt von GIT (2.1.0.6, Dateien von 08:23 Uhr) aktualisiert und die fcast.json + pwrgen.json gelöscht.
      Sonst alles aktiv im Adapter.
      Adapter stürzt direkt nach Start ab und bleibt rot:
      2020-03-20 08:37:22.886 - info: plenticore.0 (807) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.plenticore, node: v10.19.0
      2020-03-20 08:37:22.950 - info: plenticore.0 (807) [START] Starting adapter plenticore v2.1.0.6
      2020-03-20 08:37:22.994 - debug: plenticore.0 (807) Panel tilt: 23°
      2020-03-20 08:37:22.996 - debug: plenticore.0 (807) Panel direction: 180°
      2020-03-20 08:37:22.997 - debug: plenticore.0 (807) Panel efficiency: 19.3%
      2020-03-20 08:37:22.997 - debug: plenticore.0 (807) Panel surface: 39m²
      2020-03-20 08:37:24.431 - info: plenticore.0 (807) got weather data from met.no with 229 elements.
      2020-03-20 08:38:44.965 - error: host.BT3-PRO Caught by controller[0]: FATAL ERROR: invalid array length Allocation failed - JavaScript heap out of memory
      2020-03-20 08:38:44.966 - error: host.BT3-PRO Caught by controller[1]: 1: 0x8fa090 node::Abort() [io.plenticore.0]
      2020-03-20 08:38:44.966 - error: host.BT3-PRO Caught by controller[2]: 2: 0x8fa0dc [io.plenticore.0]
      2020-03-20 08:38:44.967 - error: host.BT3-PRO Caught by controller[3]: 3: 0xb0052e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.plenticore.0]
      2020-03-20 08:38:44.967 - error: host.BT3-PRO Caught by controller[4]: 4: 0xb00764 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.plenticore.0]
      2020-03-20 08:38:44.967 - error: host.BT3-PRO Caught by controller[5]: 5: 0xef4c72 [io.plenticore.0]
      2020-03-20 08:38:44.967 - error: host.BT3-PRO Caught by controller[6]: 6: 0xecc7b9 [io.plenticore.0]
      2020-03-20 08:38:44.968 - error: host.BT3-PRO Caught by controller[7]: 7: 0xece53d v8::internal::Factory::NewFixedDoubleArray(int, v8::internal::PretenureFlag) [io.plenticore.0]
      2020-03-20 08:38:44.968 - error: host.BT3-PRO Caught by controller[8]: 8: 0xe7c8ff [io.plenticore.0]
      2020-03-20 08:38:44.968 - error: host.BT3-PRO Caught by controller[9]: 9: 0x1127ded v8::internal::Runtime_GrowArrayElements(int, v8::internal::Object**, v8::internal::Isolate*) [io.plenticore.0]
      2020-03-20 08:38:44.968 - error: host.BT3-PRO Caught by controller[9]: 10: 0x1c3d1905be1d
      2020-03-20 08:38:44.968 - warn: host.BT3-PRO instance system.adapter.plenticore.0 terminated due to SIGABRT
      StrathCole 1 Reply Last reply Reply Quote 0
      • StrathCole
        StrathCole @Diginix last edited by
        @Diginix sagte in IOBroker Anbindung an einen Kostal Plenticore:
        Könntest du noch einmal vom git aktualisieren? Irgendwie muss ich nach und nach Logmeldungen einfügen 😕
        • Diginix
          Diginix @StrathCole last edited by
          @StrathCole 2.0.1.7 stürzt ebenso ab:
          2020-03-20 09:00:19.268 - info: plenticore.0 (4530) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.plenticore, node: v10.19.0
          2020-03-20 09:00:19.317 - info: plenticore.0 (4530) [START] Starting adapter plenticore v2.1.0.7
          2020-03-20 09:00:19.335 - debug: plenticore.0 (4530) Panel tilt: 23°
          2020-03-20 09:00:19.335 - debug: plenticore.0 (4530) Panel direction: 180°
          2020-03-20 09:00:19.336 - debug: plenticore.0 (4530) Panel efficiency: 19.3%
          2020-03-20 09:00:19.336 - debug: plenticore.0 (4530) Panel surface: 39m²
          2020-03-20 09:00:22.368 - info: plenticore.0 (4530) got weather data from met.no with 229 elements.
          2020-03-20 09:02:58.471 - error: host.BT3-PRO Caught by controller[0]: FATAL ERROR: invalid array length Allocation failed - JavaScript heap out of memory
          2020-03-20 09:02:58.472 - error: host.BT3-PRO Caught by controller[0]: 1: 0x8fa090 node::Abort() [io.plenticore.0]
          2020-03-20 09:02:58.473 - error: host.BT3-PRO Caught by controller[0]: 2: 0x8fa0dc [io.plenticore.0]
          2020-03-20 09:02:58.473 - error: host.BT3-PRO Caught by controller[1]: 3: 0xb0052e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.plenticore.0]
          2020-03-20 09:02:58.473 - error: host.BT3-PRO Caught by controller[2]: 4: 0xb00764 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.plenticore.0]
          2020-03-20 09:02:58.473 - error: host.BT3-PRO Caught by controller[3]: 5: 0xef4c72 [io.plenticore.0]
          2020-03-20 09:02:58.473 - error: host.BT3-PRO Caught by controller[4]: 6: 0xecc7b9 [io.plenticore.0]
          2020-03-20 09:02:58.474 - error: host.BT3-PRO Caught by controller[5]: 7: 0xece53d v8::internal::Factory::NewFixedDoubleArray(int, v8::internal::PretenureFlag) [io.plenticore.0]
          2020-03-20 09:02:58.474 - error: host.BT3-PRO Caught by controller[6]: 8: 0xe7c8ff [io.plenticore.0]
          2020-03-20 09:02:58.474 - error: host.BT3-PRO Caught by controller[6]: 9: 0x1127ded v8::internal::Runtime_GrowArrayElements(int, v8::internal::Object**, v8::internal::Isolate*) [io.plenticore.0]
          2020-03-20 09:02:58.474 - error: host.BT3-PRO Caught by controller[6]: 10: 0x33b7e975be1d
          2020-03-20 09:02:58.474 - warn: host.BT3-PRO instance system.adapter.plenticore.0 terminated due to SIGABRT
          • StrathCole
            @Diginix ich versuche gerade herauszufinden, an welcher Stelle genau er abstürzt. Mich irritiert, dass nach dem "met.no" keine weiteren Meldungen kommen. Eigentlich müssten da im Debug-Modus viel mehr kommen. Ich teste ein paar Dinge und gebe Bescheid, wenn du noch mal aktualisieren kannst.
            • Diginix
              Diginix last edited by Diginix
              Stehe in den Startlöchern, aber kein Stress! 😉
              Loglevel Debug ist dauerhaft aktiv für deinen Adapter.
              • StrathCole
                @Diginix so. Bitte einmal aus dem git laden. Ich habe mal met.no auskommentiert. Wird jetzt sicher Warnungen oder Fehler werfen, aber so sehe ich, ob es ggf. daran liegt.
                • Diginix
                  @StrathCole Läuft wieder!
                  • StrathCole
                    @Diginix Nicht gut.
                      tp1de last edited by
                      @StrathCole bei mir auch
                        @StrathCole
                        habe jetzt aber folgende Meldungen:
                        plenticore.0	2020-03-20 09:24:09.969	warn	(14408) Could not read weatherunderground.0.forecastHourly.4h.sky. It returned null state.
                        plenticore.0	2020-03-20 09:24:09.968	warn	(14408) Could not read weatherunderground.0.forecastHourly.3h.sky. It returned null state.
                        plenticore.0	2020-03-20 09:24:09.922	warn	(14408) Could not read weatherunderground.0.forecastHourly.2h.sky. It returned null state.
                        plenticore.0	2020-03-20 09:24:09.919	warn	(14408) Could not read weatherunderground.0.forecastHourly.1h.sky. It returned null state.
                        • StrathCole
                          StrathCole @tp1de last edited by
                          @tom57 Danach schaue ich dann, wenn ich den anderen Fehler gefunden habe. Das ist echt ein seltsames Phänomen.
                          • StrathCole
                            So, hab eine neue Version im Git. Ich hoffe, damit geht es auch trotz metno.
                              tp1de @StrathCole last edited by
                              @StrathCole sagte in IOBroker Anbindung an einen Kostal Plenticore:
                              Ja scheint zu funktionieren ... auch die WU-Meldungen sind weg. Werde ich jetzt mal beobachten.
                              • StrathCole
                                @tom57 Ähm … auch keine [warn] Meldung?
                                • Diginix
                                  Ich bekomme mit 2.0.1.9 zumindest diese bzgl met.no
                                  2020-03-20 09:57:56.350	warn	(11834) Met.no got more than 10 entries in from/to entry. This is bad. Stopping.
                                  • StrathCole
                                    @Diginix Danke, genau das habe ich erwartet. Kannst du mir die debug Meldungen, die davor und danach kommen, noch mitteilen? Das scheint nämlich genau der Punkt zu sein, an dem der Adapter bei euch abgestürzt ist und bei mir nicht.
                                    • Diginix
                                      @StrathCole
                                      Da musst du dich mal durchkämpfen:
                                      Ach hab das vor 3 Stunden schon gepostet aber das Log war zu lang und der Post wurde gar nicht gesendet.
                                      Also hier mal das Log in meiner Dropbox:
                                      https://www.dropbox.com/s/w8wouypxj3hi20b/2020-03-19_plenticore.log?dl=0
                                      • StrathCole
                                        @Diginix Danke sehr. Das genügt mir schon. So etwas hatte ich mir gedacht. Du kannst das Log wieder löschen. Ich denke, mit der neuesten Version ist das Problem behoben.
                                        • Diginix
                                          Diginix @StrathCole last edited by Diginix
                                          @StrathCole Ok, hab die neue von GIT installiert.
                                            @Diginix @StrathCole
                                            Bei mir kommt auch mit der neuen Version noch die Meldung:
                                            plenticore.0	2020-03-20 14:30:31.114	warn	(19507) Met.no got more than 10 entries in from/to entry. This is bad. Stopping.
                                            1302
                                            447007
