    4. TV Fernbedienungs View - Vorlage ??
      sigi234 Forum Testing Most Active @TG70 last edited by sigi234
      @TG70 sagte in TV Fernbedienungs View - Vorlage ??:
      was nutzt du eigentlich zur Online Abfrage
      tr-064
      https://forum.iobroker.net/topic/30812/material-design-widets-netzwerk-status
      TG70 1 Reply Last reply Reply Quote 0
      • TG70
        TG70 Forum Testing @sigi234 last edited by
        @sigi234 ......OK.. DANKE ist das zuverlässiger wie RADAR/PING
          Ja
          • TG70
            TG70 Forum Testing @sigi234 last edited by TG70
            @sigi234 .. leider startet der Adaper nicht .... hab auf der FB einen extra user angelegt. Das ist im Log.
            Adapter habe ich schon mal neu installiert. Hast du eine Idee:
            host.IOBROKER-CT	2020-03-20 11:10:13.014	error	instance system.adapter.tr-064.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
            host.IOBROKER-CT	2020-03-20 11:10:13.014	error	Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
            host.IOBROKER-CT	2020-03-20 11:10:13.014	error	Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
            host.IOBROKER-CT	2020-03-20 11:10:13.014	error	Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
            host.IOBROKER-CT	2020-03-20 11:10:13.014	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
            host.IOBROKER-CT	2020-03-20 11:10:13.013	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
            host.IOBROKER-CT	2020-03-20 11:10:13.013	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
            host.IOBROKER-CT	2020-03-20 11:10:13.013	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
            host.IOBROKER-CT	2020-03-20 11:10:13.013	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
            host.IOBROKER-CT	2020-03-20 11:10:13.013	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:15:20)
            host.IOBROKER-CT	2020-03-20 11:10:13.013	error	Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
            host.IOBROKER-CT	2020-03-20 11:10:13.013	error	Caught by controller[0]: TypeError: fns.adapter is not a function
            host.IOBROKER-CT	2020-03-20 11:10:13.013	error	Caught by controller[0]: ^
            host.IOBROKER-CT	2020-03-20 11:10:13.012	error	Caught by controller[0]: fns.adapter = fns.adapter(options);
            host.IOBROKER-CT	2020-03-20 11:10:13.012	error	Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
              @TG70
              https://forum.iobroker.net/topic/29456/tr-064-v3-1-x-latest-repo-diskussion
              • TG70
                @sigi234 ... ok hast du im Kopf was das letztendliche Problem ist... hab da die duzenden Posts mal überflogen... finde da auf die schnelle
                kein Ergebniss 😳
                ab MORGEN 00:01 haben wir eine Ausgangssperre in Bayern << wg. Corona
                  kein Ergebniss 😳
                  Welche Version hast du?
                  • TG70
                    @sigi234
                      @sigi234
                      Dann hast du noch den alten drinnen, sollte so aussehen:
                      TG70 1 Reply Last reply Reply Quote 1
                      • TG70
                        @sigi234 Jaa du hattest Recht... jetzt ist er grün ... Die IP- und Mac-Adressen muss ich händisch eintragen?? Oder gibts
                        eine Möglichkeit die direkt von der FB zu bekommen ?
                          Nein, suche nach Geräten!
                          • TG70
                            Ich habe gerade ein "banales" Problem. Ich importiere deinen View und finde diese dann nicht unter dem
                            angegeben Namen. Heute morgen hat das ohne Probleme funktioniert. Auch wenn ich einen View kopiere finde ich diesen nicht.
                            Probiere ich es nochmal, "der Name ist schon vergeben".
                            Bei einem kleinen View mit wenig Inhalt funktioniert das kopieren aber.
                            • I
                              io2345 last edited by io2345
                              Einfache VIS-2 Vorlage ohne Schnickschnack, für eine VU+ Fernbedienung (Zero).
                              Komplett mit "Gestylt"-Widgets umgesetzt.
                                "name": "RemoteControl",
                                "parentId": null,
                                "settings": {
                                  "style": {
                                    "background_class": "",
                                    "background": "#021E2D"
                                  "useBackground": true,
                                  "navigation": true,
                                  "navigationTitle": "RC VU+",
                                  "navigationOrientation": "horizontal",
                                  "navigationIcon": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xNSA3LjVWMkg5djUuNWwzIDNsMy0zek03LjUgOUgydjZoNS41bDMtM2wtMy0zek05IDE2LjVWMjJoNnYtNS41bC0zLTNsLTMgM3pNMTYuNSA5bC0zIDNsMyAzSDIyVjloLTUuNXoiLz48L3N2Zz4=",
                                  "sizex": "700",
                                  "sizey": "880"
                                "widgets": {
                                  "w000275": {
                                    "tpl": "tplJquiBool",
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "oid": "enigma2.0.command.MUTE_TOGGLE",
                                      "text_false": "Mute",
                                      "g_text": true,
                                      "text_true": "Mute",
                                      "padding": 5,
                                      "g_style": true,
                                      "variant": "contained",
                                      "orientation": "horizontal",
                                      "color_false": "white",
                                      "color_true": "red",
                                      "src_false": null,
                                      "icon_false": "data:image/svg+xml;base64,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",
                                      "icon_color_false": "white",
                                      "invert_icon_false": false,
                                      "imageHeight_false": 30,
                                      "g_icon_false": true,
                                      "src_true": null,
                                      "icon_true": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xNCA4LjgzdjYuMzRMMTEuODMgMTNIOXYtMmgyLjgzTDE0IDguODNNMTYgNGwtNSA1SDd2Nmg0bDUgNVY0eiIvPjwvc3ZnPg==",
                                      "icon_color_true": "red",
                                      "invert_icon_true": null,
                                      "imageHeight_true": 30,
                                      "g_icon_true": true,
                                      "g_css_border": true,
                                      "g_css_shadow_padding": true,
                                      "lc-oid": null,
                                      "lc-type": "last-change",
                                      "lc-is-interval": true,
                                      "lc-is-moment": null,
                                      "lc-format": null,
                                      "lc-position-vert": "top",
                                      "lc-position-horz": "right",
                                      "lc-offset-vert": null,
                                      "lc-offset-horz": null,
                                      "lc-font-size": "12px",
                                      "lc-font-family": null,
                                      "lc-font-style": null,
                                      "lc-bkg-color": null,
                                      "lc-color": null,
                                      "lc-border-width": "0",
                                      "lc-border-style": null,
                                      "lc-border-color": null,
                                      "lc-border-radius": 10,
                                      "lc-padding": 3,
                                      "lc-zindex": null,
                                      "g_last_change": true
                                    "style": {
                                      "bindings": [],
                                      "left": "48.984375px",
                                      "top": 58,
                                      "background-color": "rgba(5,61,103,1)",
                                      "border-width": "1px",
                                      "border-style": "solid",
                                      "border-color": "#e0e0e0",
                                      "border-radius": "5px",
                                      "box-shadow": "2px 2px 3px rgba(20,20,20,50)",
                                      "width": 135.46875
                                    "widgetSet": "jqui"
                                  "w000276": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "oid": "enigma2.0.command.STANDBY_TOGGLE",
                                      "text_false": "Standby",
                                      "g_text": true,
                                      "text_true": "Power",
                                      "padding": 5,
                                      "g_style": true,
                                      "color_false": "red",
                                      "color_true": "white",
                                      "src_false": null,
                                      "icon_false": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xNyA2SDdjLTMuMzEgMC02IDIuNjktNiA2czIuNjkgNiA2IDZoMTBjMy4zMSAwIDYtMi42OSA2LTZzLTIuNjktNi02LTZ6bTAgMTBIN2MtMi4yMSAwLTQtMS43OS00LTRzMS43OS00IDQtNGgxMGMyLjIxIDAgNCAxLjc5IDQgNHMtMS43OSA0LTQgNHptMC03Yy0xLjY2IDAtMyAxLjM0LTMgM3MxLjM0IDMgMyAzczMtMS4zNCAzLTNzLTEuMzQtMy0zLTN6Ii8+PC9zdmc+",
                                      "src_true": null,
                                      "icon_true": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xNyA2SDdjLTMuMzEgMC02IDIuNjktNiA2czIuNjkgNiA2IDZoMTBjMy4zMSAwIDYtMi42OSA2LTZzLTIuNjktNi02LTZ6bTAgMTBIN2MtMi4yMSAwLTQtMS43OS00LTRzMS43OS00IDQtNGgxMGMyLjIxIDAgNCAxLjc5IDQgNHMtMS43OSA0LTQgNHpNNyA5Yy0xLjY2IDAtMyAxLjM0LTMgM3MxLjM0IDMgMyAzczMtMS4zNCAzLTNzLTEuMzQtMy0zLTN6Ii8+PC9zdmc+",
                                      "lc-oid": null,
                                      "lc-format": null,
                                      "lc-color": null,
                                      "lc-padding": 3,
                                      "lc-zindex": null,
                                      "g_last_change": true,
                                      "pushMode": false,
                                      "equal_text_length": true
                                    "style": {
                                      "bindings": [],
                                      "left": "561.515625px",
                                      "top": 58,
                                      "width": 135.46875
                                    "widgetSet": "jqui"
                                  "w000277": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "oid": "enigma2.0.command.EPG",
                                      "text_false": "EPG",
                                      "g_text": true,
                                      "text_true": "EPG",
                                      "padding": 5,
                                      "g_style": true,
                                      "src_false": null,
                                      "icon_false": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xMSA3aDJ2MmgtMnptMCA0aDJ2NmgtMnptMS05QzYuNDggMiAyIDYuNDggMiAxMnM0LjQ4IDEwIDEwIDEwczEwLTQuNDggMTAtMTBTMTcuNTIgMiAxMiAyem0wIDE4Yy00LjQxIDAtOC0zLjU5LTgtOHMzLjU5LTggOC04czggMy41OSA4IDhzLTMuNTkgOC04IDh6Ii8+PC9zdmc+",
                                      "src_true": null,
                                      "icon_true": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xMSA3aDJ2MmgtMnptMCA0aDJ2NmgtMnptMS05QzYuNDggMiAyIDYuNDggMiAxMnM0LjQ4IDEwIDEwIDEwczEwLTQuNDggMTAtMTBTMTcuNTIgMiAxMiAyem0wIDE4Yy00LjQxIDAtOC0zLjU5LTgtOHMzLjU5LTggOC04czggMy41OSA4IDhzLTMuNTkgOC04IDh6Ii8+PC9zdmc+",
                                      "lc-oid": null,
                                      "lc-format": null,
                                      "lc-color": null,
                                      "lc-padding": 3,
                                      "lc-zindex": null,
                                    "style": {
                                      "bindings": [],
                                      "left": "390.671875px",
                                      "top": 58,
                                      "width": 135.46875,
                                      "height": "55.9844px"
                                    "widgetSet": "jqui"
                                  "w000294": {
                                    "data": {
                                      "bindings": [],
                                      "type": "round-button",
                                      "g_common": true,
                                      "oid": "enigma2.0.command.OK",
                                      "text_false": "OK",
                                      "g_text": true,
                                      "text_true": "An",
                                      "padding": 5,
                                      "g_style": true,
                                      "g_css_background": true,
                                      "color_false": "rgba(5,61,103,1)",
                                      "color_true": "rgba(5,61,103,1)",
                                      "g_css_font_text": true,
                                      "pushMode": true
                                    "style": {
                                      "bindings": [],
                                      "left": 240,
                                      "top": 426,
                                      "width": "250px",
                                      "height": "250px",
                                      "background": null,
                                      "background-color": "",
                                      "background-image": null,
                                      "background-repeat": null,
                                      "background-attachment": null,
                                      "background-position": null,
                                      "background-size": null,
                                      "background-clip": null,
                                      "background-origin": null,
                                      "z-index": 1,
                                      "border-width": "",
                                      "border-style": "",
                                      "border-color": "rgba(5,61,103,1)",
                                      "border-radius": null,
                                      "color": null,
                                      "text-align": null,
                                      "text-shadow": null,
                                      "font-family": null,
                                      "font-style": null,
                                      "font-variant": null,
                                      "font-weight": "bold",
                                      "font-size": "xx-large",
                                      "line-height": null,
                                      "letter-spacing": null,
                                      "word-spacing": null
                                    "widgetSet": "jqui"
                                  "w000295": {
                                    "data": {
                                      "bindings": [],
                                      "g_common": true,
                                      "oid": "enigma2.0.command.UP",
                                      "text_false": "",
                                      "g_text": true,
                                      "text_true": "An",
                                      "padding": 5,
                                      "g_style": true,
                                      "src_false": null,
                                      "icon_false": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik04LjEyIDE0LjcxTDEyIDEwLjgzbDMuODggMy44OGEuOTk2Ljk5NiAwIDEgMCAxLjQxLTEuNDFMMTIuNyA4LjcxYS45OTYuOTk2IDAgMCAwLTEuNDEgMEw2LjcgMTMuM2EuOTk2Ljk5NiAwIDAgMCAwIDEuNDFjLjM5LjM4IDEuMDMuMzkgMS40MiAweiIvPjwvc3ZnPg==",
                                      "icon_color_false": null,
                                      "invert_icon_false": null,
                                      "imageHeight_false": null,
                                      "pushMode": false,
                                      "readOnly": false,
                                      "color_true": ""
                                    "style": {
                                      "bindings": [],
                                      "left": 336,
                                      "top": 435,
                                      "width": "70px",
                                      "height": "70px",
                                      "font-size": "x-large",
                                      "z-index": 10,
                                      "background-color": "rgba(255,255,255,0.94)"
                                    "widgetSet": "jqui"
                                  "w000296": {
                                    "data": {
                                      "bindings": [],
                                      "g_common": true,
                                      "oid": "enigma2.0.command.LEFT",
                                      "text_false": "",
                                      "g_text": true,
                                      "text_true": "An",
                                      "padding": 5,
                                      "g_style": true,
                                      "src_false": null,
                                      "icon_false": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xNC43MSAxNS44OEwxMC44MyAxMmwzLjg4LTMuODhhLjk5Ni45OTYgMCAxIDAtMS40MS0xLjQxTDguNzEgMTEuM2EuOTk2Ljk5NiAwIDAgMCAwIDEuNDFsNC41OSA0LjU5Yy4zOS4zOSAxLjAyLjM5IDEuNDEgMGMuMzgtLjM5LjM5LTEuMDMgMC0xLjQyeiIvPjwvc3ZnPg==",
                                      "icon_color_false": "",
                                      "pushMode": false,
                                      "readOnly": false,
                                      "color_true": "",
                                    "style": {
                                      "bindings": [],
                                      "left": 248,
                                      "top": 519,
                                      "width": "70px",
                                      "height": "70px",
                                      "z-index": 10,
                                    "widgetSet": "jqui"
                                  "w000297": {
                                    "data": {
                                      "bindings": [],
                                      "g_common": true,
                                      "oid": "enigma2.0.command.RIGHT",
                                      "text_false": "",
                                      "g_text": true,
                                      "text_true": "An",
                                      "padding": 5,
                                      "g_style": true,
                                      "src_false": null,
                                      "icon_false": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik05LjI5IDE1Ljg4TDEzLjE3IDEyTDkuMjkgOC4xMmEuOTk2Ljk5NiAwIDEgMSAxLjQxLTEuNDFsNC41OSA0LjU5Yy4zOS4zOS4zOSAxLjAyIDAgMS40MUwxMC43IDE3LjNhLjk5Ni45OTYgMCAwIDEtMS40MSAwYy0uMzgtLjM5LS4zOS0xLjAzIDAtMS40MnoiLz48L3N2Zz4=",
                                      "pushMode": false,
                                      "readOnly": false,
                                      "color_true": ""
                                    "style": {
                                      "bindings": [],
                                      "left": 415,
                                      "top": 518,
                                      "width": "70px",
                                      "height": "70px",
                                      "z-index": 10,
                                    "widgetSet": "jqui"
                                  "w000298": {
                                    "data": {
                                      "bindings": [],
                                      "g_common": true,
                                      "oid": "enigma2.0.command.DOWN",
                                      "text_false": "",
                                      "g_text": true,
                                      "text_true": "An",
                                      "padding": 5,
                                      "g_style": true,
                                      "src_false": null,
                                      "icon_false": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik04LjEyIDkuMjlMMTIgMTMuMTdsMy44OC0zLjg4YS45OTYuOTk2IDAgMSAxIDEuNDEgMS40MWwtNC41OSA0LjU5YS45OTYuOTk2IDAgMCAxLTEuNDEgMEw2LjcgMTAuN2EuOTk2Ljk5NiAwIDAgMSAwLTEuNDFjLjM5LS4zOCAxLjAzLS4zOSAxLjQyIDB6Ii8+PC9zdmc+",
                                      "pushMode": false,
                                      "color_true": "",
                                      "readOnly": false
                                    "style": {
                                      "bindings": [],
                                      "left": 330,
                                      "top": 599,
                                      "width": "70px",
                                      "height": "70px",
                                      "z-index": 10,
                                    "widgetSet": "jqui"
                                  "w000299": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "oid": "enigma2.0.command.VOLUME_UP",
                                      "text_false": "",
                                      "g_text": true,
                                      "text_true": "",
                                      "padding": 5,
                                      "g_style": true,
                                      "src_false": null,
                                      "icon_false": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0zIDl2Nmg0bDUgNVY0TDcgOUgzem03LS4xN3Y2LjM0TDcuODMgMTNINXYtMmgyLjgzTDEwIDguODN6TTE2LjUgMTJBNC41IDQuNSAwIDAgMCAxNCA3Ljk3djguMDVjMS40OC0uNzMgMi41LTIuMjUgMi41LTQuMDJ6TTE0IDMuMjN2Mi4wNmMyLjg5Ljg2IDUgMy41NCA1IDYuNzFzLTIuMTEgNS44NS01IDYuNzF2Mi4wNmM0LjAxLS45MSA3LTQuNDkgNy04Ljc3YzAtNC4yOC0yLjk5LTcuODYtNy04Ljc3eiIvPjwvc3ZnPg==",
                                      "icon_color_false": "red",
                                      "src_true": null,
                                      "icon_true": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0zIDl2Nmg0bDUgNVY0TDcgOUgzem03LS4xN3Y2LjM0TDcuODMgMTNINXYtMmgyLjgzTDEwIDguODN6TTE2LjUgMTJBNC41IDQuNSAwIDAgMCAxNCA3Ljk3djguMDVjMS40OC0uNzMgMi41LTIuMjUgMi41LTQuMDJ6TTE0IDMuMjN2Mi4wNmMyLjg5Ljg2IDUgMy41NCA1IDYuNzFzLTIuMTEgNS44NS01IDYuNzF2Mi4wNmM0LjAxLS45MSA3LTQuNDkgNy04Ljc3YzAtNC4yOC0yLjk5LTcuODYtNy04Ljc3eiIvPjwvc3ZnPg==",
                                      "icon_color_true": "white",
                                      "lc-oid": null,
                                      "lc-format": null,
                                      "lc-color": null,
                                      "lc-padding": 3,
                                      "lc-zindex": null,
                                    "style": {
                                      "bindings": [],
                                      "top": 437,
                                      "height": "100"
                                    "widgetSet": "jqui"
                                  "w000300": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "oid": "enigma2.0.command.VOLUME_DOWN",
                                      "text_false": "",
                                      "g_text": true,
                                      "text_true": "",
                                      "padding": 5,
                                      "g_style": true,
                                      "src_false": null,
                                      "icon_false": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xNiA3Ljk3djguMDVjMS40OC0uNzMgMi41LTIuMjUgMi41LTQuMDJBNC41IDQuNSAwIDAgMCAxNiA3Ljk3ek01IDl2Nmg0bDUgNVY0TDkgOUg1em03LS4xN3Y2LjM0TDkuODMgMTNIN3YtMmgyLjgzTDEyIDguODN6Ii8+PC9zdmc+",
                                      "src_true": null,
                                      "lc-oid": null,
                                      "lc-format": null,
                                      "lc-color": null,
                                      "lc-padding": 3,
                                      "lc-zindex": null,
                                    "style": {
                                      "bindings": [],
                                      "top": 568,
                                      "height": "100"
                                    "widgetSet": "jqui"
                                  "w000301": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "oid": "enigma2.0.command.CHANNEL_DOWN",
                                      "text_false": "",
                                      "g_text": true,
                                      "text_true": "",
                                      "padding": 5,
                                      "g_style": true,
                                      "src_false": null,
                                      "icon_false": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xOSAxMi45OThINXYtMmgxNHoiLz48L3N2Zz4=",
                                      "src_true": null,
                                      "lc-oid": null,
                                      "lc-format": null,
                                      "lc-color": null,
                                      "lc-padding": 3,
                                      "lc-zindex": null,
                                    "style": {
                                      "bindings": [],
                                      "left": "619.03125px",
                                      "top": 572,
                                      "height": "100"
                                    "widgetSet": "jqui"
                                  "w000302": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "oid": "enigma2.0.command.CHANNEL_UP",
                                      "text_false": "",
                                      "g_text": true,
                                      "text_true": "",
                                      "padding": 5,
                                      "g_style": true,
                                      "src_false": null,
                                      "icon_false": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xOSAxMi45OThoLTZ2NmgtMnYtNkg1di0yaDZ2LTZoMnY2aDZ6Ii8+PC9zdmc+",
                                      "src_true": null,
                                      "icon_true": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xOSAxMi45OThoLTZ2NmgtMnYtNkg1di0yaDZ2LTZoMnY2aDZ6Ii8+PC9zdmc+",
                                      "lc-oid": null,
                                      "lc-format": null,
                                      "lc-color": null,
                                      "lc-padding": 3,
                                      "lc-zindex": null,
                                    "style": {
                                      "bindings": [],
                                      "top": 441,
                                      "height": "100"
                                    "widgetSet": "jqui"
                                  "w000303": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "oid": "enigma2.0.command.MENU",
                                      "text_false": "MENU",
                                      "g_text": true,
                                      "text_true": "MENU",
                                      "padding": 5,
                                      "g_style": true,
                                      "src_false": null,
                                      "icon_false": "",
                                      "src_true": null,
                                      "icon_true": "",
                                      "lc-oid": null,
                                      "lc-format": null,
                                      "lc-color": null,
                                      "lc-padding": 3,
                                      "lc-zindex": null,
                                    "style": {
                                      "bindings": [],
                                      "top": 727,
                                      "width": "109.797px",
                                      "height": "60"
                                    "widgetSet": "jqui"
                                  "w000304": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "oid": "enigma2.0.command.EXIT",
                                      "text_false": "Exit",
                                      "g_text": true,
                                      "text_true": "Exit",
                                      "padding": 5,
                                      "g_style": true,
                                      "src_false": null,
                                      "icon_false": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xNC41OSA4TDEyIDEwLjU5TDkuNDEgOEw4IDkuNDFMMTAuNTkgMTJMOCAxNC41OUw5LjQxIDE2TDEyIDEzLjQxTDE0LjU5IDE2TDE2IDE0LjU5TDEzLjQxIDEyTDE2IDkuNDFMMTQuNTkgOHpNMTIgMkM2LjQ3IDIgMiA2LjQ3IDIgMTJzNC40NyAxMCAxMCAxMHMxMC00LjQ3IDEwLTEwUzE3LjUzIDIgMTIgMnptMCAxOGMtNC40MSAwLTgtMy41OS04LThzMy41OS04IDgtOHM4IDMuNTkgOCA4cy0zLjU5IDgtOCA4eiIvPjwvc3ZnPg==",
                                      "src_true": null,
                                      "lc-oid": null,
                                      "lc-format": null,
                                      "lc-color": null,
                                      "lc-padding": 3,
                                      "lc-zindex": null,
                                      "pushMode": true
                                    "style": {
                                      "bindings": [],
                                      "left": 315,
                                      "top": 726,
                                      "height": "60"
                                    "widgetSet": "jqui"
                                  "w000305": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "oid": "enigma2.0.command.REC",
                                      "text_false": "Rec",
                                      "g_text": true,
                                      "text_true": "Rec",
                                      "padding": 5,
                                      "g_style": true,
                                      "src_false": null,
                                      "icon_false": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xMiAyQzYuNDggMiAyIDYuNDggMiAxMnM0LjQ4IDEwIDEwIDEwczEwLTQuNDggMTAtMTBTMTcuNTIgMiAxMiAyem0wIDE4Yy00LjQyIDAtOC0zLjU4LTgtOHMzLjU4LTggOC04czggMy41OCA4IDhzLTMuNTggOC04IDh6Ii8+PGNpcmNsZSBmaWxsPSJjdXJyZW50Q29sb3IiIGN4PSIxMiIgY3k9IjEyIiByPSI1Ii8+PC9zdmc+",
                                      "src_true": null,
                                      "lc-oid": null,
                                      "lc-format": null,
                                      "lc-color": null,
                                      "lc-padding": 3,
                                      "lc-zindex": null,
                                      "pushMode": true
                                    "style": {
                                      "bindings": [],
                                      "left": 453,
                                      "top": 812,
                                      "height": "60"
                                    "widgetSet": "jqui"
                                  "w000306": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "oid": "enigma2.0.command.PLAY_PAUSE",
                                      "text_false": "",
                                      "g_text": true,
                                      "text_true": "",
                                      "padding": 5,
                                      "g_style": true,
                                      "src_false": null,
                                      "icon_false": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xMCA4LjY0TDE1LjI3IDEyTDEwIDE1LjM2VjguNjRNOCA1djE0bDExLTdMOCA1eiIvPjwvc3ZnPg==",
                                      "icon_color_false": "green",
                                      "src_true": null,
                                      "icon_true": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik05IDE2aDJWOEg5djh6bTMtMTRDNi40OCAyIDIgNi40OCAyIDEyczQuNDggMTAgMTAgMTBzMTAtNC40OCAxMC0xMFMxNy41MiAyIDEyIDJ6bTAgMThjLTQuNDEgMC04LTMuNTktOC04czMuNTktOCA4LThzOCAzLjU5IDggOHMtMy41OSA4LTggOHptMS00aDJWOGgtMnY4eiIvPjwvc3ZnPg==",
                                      "lc-oid": null,
                                      "lc-format": null,
                                      "lc-color": null,
                                      "lc-padding": 3,
                                      "lc-zindex": null,
                                    "style": {
                                      "bindings": [],
                                      "left": 188,
                                      "top": 817,
                                      "height": "60"
                                    "widgetSet": "jqui"
                                  "w000309": {
                                    "tpl": "tplJquiButtonState",
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "oid": "enigma2.0.command.REMOTE-CONTROL",
                                      "count": 1,
                                      "value1": "2",
                                      "test1": null,
                                      "onlyIcon1": null,
                                      "text1": "1",
                                      "color1": "white",
                                      "activeColor1": null,
                                      "image1": null,
                                      "icon1": null,
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "top": "141px",
                                      "width": "81.9844px",
                                      "height": "52.9688px",
                                      "position": "absolute",
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000310": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "3",
                                      "test1": null,
                                      "onlyIcon1": null,
                                      "text1": "2",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": null,
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "left": "190.4765625px",
                                      "top": 141,
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000311": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "4",
                                      "test1": null,
                                      "onlyIcon1": null,
                                      "text1": "3",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": null,
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "left": "331.9921875px",
                                      "top": 143,
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000312": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "5",
                                      "test1": null,
                                      "onlyIcon1": null,
                                      "text1": "4",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": null,
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "left": "477px",
                                      "top": 143,
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000313": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "6",
                                      "test1": null,
                                      "onlyIcon1": null,
                                      "text1": "5",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": null,
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "left": "615px",
                                      "top": 145,
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000314": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "7",
                                      "test1": null,
                                      "onlyIcon1": null,
                                      "text1": "6",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": null,
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "top": 222,
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000315": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "8",
                                      "test1": null,
                                      "onlyIcon1": null,
                                      "text1": "7",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": null,
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "top": 222,
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000316": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "9",
                                      "test1": null,
                                      "onlyIcon1": null,
                                      "text1": "8",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": null,
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "top": 224,
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000317": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "10",
                                      "test1": null,
                                      "onlyIcon1": null,
                                      "text1": "9",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": null,
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "left": "477px",
                                      "top": 224,
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000318": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "11",
                                      "test1": null,
                                      "onlyIcon1": null,
                                      "text1": "0",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": null,
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "left": "615px",
                                      "top": 226,
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000319": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "412",
                                      "test1": null,
                                      "onlyIcon1": true,
                                      "text1": "",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0yMCAxMUg3LjgzbDUuNTktNS41OUwxMiA0bC04IDhsOCA4bDEuNDEtMS40MUw3LjgzIDEzSDIwdi0yeiIvPjwvc3ZnPg==",
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "top": 303,
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000320": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "398",
                                      "test1": null,
                                      "onlyIcon1": true,
                                      "text1": "7",
                                      "color1": "red",
                                      "image1": null,
                                      "icon1": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xMiAyQzYuNDcgMiAyIDYuNDcgMiAxMnM0LjQ3IDEwIDEwIDEwczEwLTQuNDcgMTAtMTBTMTcuNTMgMiAxMiAyem0wIDE4Yy00LjQyIDAtOC0zLjU4LTgtOHMzLjU4LTggOC04czggMy41OCA4IDhzLTMuNTggOC04IDh6Ii8+PC9zdmc+",
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "top": 303,
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000321": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "399",
                                      "test1": null,
                                      "onlyIcon1": true,
                                      "text1": "8",
                                      "color1": "green",
                                      "image1": null,
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "left": 289,
                                      "top": 304,
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000322": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "401",
                                      "test1": null,
                                      "onlyIcon1": true,
                                      "text1": "9",
                                      "color1": "blue",
                                      "image1": null,
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "left": "477px",
                                      "top": 305,
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000323": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "407",
                                      "test1": null,
                                      "onlyIcon1": true,
                                      "text1": "0",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xMiA0bC0xLjQxIDEuNDFMMTYuMTcgMTFINHYyaDEyLjE3bC01LjU4IDUuNTlMMTIgMjBsOC04bC04LTh6Ii8+PC9zdmc+",
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "left": "615px",
                                      "top": 307,
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000324": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "400",
                                      "test1": null,
                                      "onlyIcon1": true,
                                      "text1": "8",
                                      "color1": "yellow",
                                      "image1": null,
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "left": 383,
                                      "top": 305,
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000325": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "393",
                                      "test1": null,
                                      "onlyIcon1": true,
                                      "text1": "0",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": "data:image/svg+xml;base64,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",
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "left": "187px",
                                      "top": "728px",
                                      "width": "98.9844px",
                                      "height": "60",
                                      "position": "",
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000326": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "oid": "enigma2.0.command.STOP",
                                      "text_false": "",
                                      "g_text": true,
                                      "text_true": "",
                                      "padding": 5,
                                      "g_style": true,
                                      "src_false": null,
                                      "icon_false": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xNiA4djhIOFY4aDhtMi0ySDZ2MTJoMTJWNnoiLz48L3N2Zz4=",
                                      "src_true": null,
                                      "lc-oid": null,
                                      "lc-format": null,
                                      "lc-color": null,
                                      "lc-padding": 3,
                                      "lc-zindex": null,
                                    "style": {
                                      "bindings": [],
                                      "left": 314,
                                      "top": 818,
                                      "height": "60"
                                    "widgetSet": "jqui"
                                  "w000327": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "168",
                                      "test1": null,
                                      "onlyIcon1": true,
                                      "text1": "0",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xOCA5Ljg2djQuMjhMMTQuOTcgMTJMMTggOS44Nm0tOSAwdjQuMjhMNS45NyAxMkw5IDkuODZNMjAgNmwtOC41IDZsOC41IDZWNnptLTkgMGwtOC41IDZsOC41IDZWNnoiLz48L3N2Zz4=",
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "top": 814,
                                      "height": "60",
                                      "position": "",
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000328": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "208",
                                      "test1": null,
                                      "onlyIcon1": true,
                                      "text1": "0",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xNSA5Ljg2TDE4LjAzIDEyTDE1IDE0LjE0VjkuODZtLTkgMEw5LjAzIDEyTDYgMTQuMTRWOS44Nk0xMyA2djEybDguNS02TDEzIDZ6TTQgNnYxMmw4LjUtNkw0IDZ6Ii8+PC9zdmc+",
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "left": "598.0078125px",
                                      "top": 816,
                                      "height": "60",
                                      "position": "",
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000329": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "388",
                                      "test1": null,
                                      "onlyIcon1": true,
                                      "text1": "0",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": "data:image/svg+xml;base64,PHN2ZyB4bWxucz0iaHR0cDovL3d3dy53My5vcmcvMjAwMC9zdmciIHdpZHRoPSIyNCIgaGVpZ2h0PSIyNCIgdmlld0JveD0iMCAwIDI0IDI0Ij48cGF0aCBmaWxsPSJjdXJyZW50Q29sb3IiIGQ9Ik0xOSA1djE0SDVWNWgxNG0wLTJINWMtMS4xIDAtMiAuOS0yIDJ2MTRjMCAxLjEuOSAyIDIgMmgxNGMxLjEgMCAyLS45IDItMlY1YzAtMS4xLS45LTItMi0yeiIvPjxwYXRoIGZpbGw9ImN1cnJlbnRDb2xvciIgZD0iTTE0IDE3SDd2LTJoN3Yyem0zLTRIN3YtMmgxMHYyem0wLTRIN1Y3aDEwdjJ6Ii8+PC9zdmc+",
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "left": "219.828125px",
                                      "top": 58,
                                      "width": 135.46875,
                                      "height": "60",
                                      "position": "",
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000330": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "370",
                                      "test1": null,
                                      "onlyIcon1": false,
                                      "text1": "Untertitel",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": "",
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "left": 457,
                                      "top": 726,
                                      "height": "60",
                                      "position": "",
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                  "w000331": {
                                    "data": {
                                      "bindings": [],
                                      "type": "button",
                                      "g_common": true,
                                      "count": 1,
                                      "value1": "39",
                                      "test1": null,
                                      "onlyIcon1": false,
                                      "text1": "Audio",
                                      "color1": "white",
                                      "image1": null,
                                      "icon1": "",
                                      "tooltip1": null,
                                      "g_states-1": true,
                                    "style": {
                                      "bindings": [],
                                      "top": 727,
                                      "height": "60",
                                      "position": "",
                                      "z-index": 11,
                                      "newLine": false
                                    "widgetSet": "jqui"
                                "activeWidgets": {}
                              vis
                              2208
