    2. Русский
    3. ioBroker
    4. Скрипты
    5. ioBroker скрипты
    6. Вопросы по написанию скриптов
      spectrekr last edited by
      Так и написано
      ! connection.query('SELECT max(id) AS id FROM inbox', function(err, res_id, fields) { if (err) throw err; setState('sms.id', res_id[0].id); log(getState('sms.id').val); }); ! on({id: 'javascript.0.sms.id', change: 'any'}, function (obj) { if (obj.oldState.val < obj.newState.val){ count = obj.newState.val - obj.oldState.val; } log(count); if (count > 1){ connection.query('SELECT UDH FROM inbox WHERE ID = ?', [getState('sms.id').val], function(err, res_udh, fields) { if (err) throw err; log(res_udh[0].UDH); if(res_udh[0].UDH !== ''){ setState('sms.udh', res_udh[0].UDH.substring(0, res[0].UDH.length - 1)); log(getState('sms.udh').val); } }); } }); !
      Первый запрос выполняется и внем все прекрасно получает, потом производит подписку и внутри уже выдает ошибку.
      ! Error: Cannot enqueue Query after invoking quit. at Protocol._validateEnqueue (/opt/iobroker/node_modules/iobroker.javascript/node_modules/mysql/lib/protocol/Protocol.js:202:16) at Protocol._enqueue (/opt/iobroker/node_modules/iobroker.javascript/node_modules/mysql/lib/protocol/Protocol.js:135:13) at Connection.query (/opt/iobroker/node_modules/iobroker.javascript/node_modules/mysql/lib/Connection.js:201:25) at Object. (script.js.SMS:41:20) at Object.subs.callback (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1206:48) at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:541:48 at getObjectEnums (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2430:17) at checkPatterns (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:537:17) at Object.utils.adapter.stateChange (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:215:17) at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1969:80) at Socket.StatesInMemClient.client.on.connectionTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30) at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:263:10) at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:221:12) at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8) at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20) at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12) at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:323:16) at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:441:14) at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:258:10) at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:143:8) at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:135:8) at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:132:10) at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:418:14) at WebSocket.emit (events.js:98:17) at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:816:10) at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:477:18 at Receiver.applyExtensions (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:364:5) at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:466:14 at Receiver.flush (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:340:3) at Receiver.opcodes.1.finish (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:482:12) at Receiver. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:457:31) at Receiver.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:95:24) at Socket.realHandler (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:800:20) at Socket.emit (events.js:95:17) at Socket. (stream_readable.js:765:14) at Socket.emit (events.js:92:17) at emitReadable (_stream_readable.js:427:10) at emitReadable (_stream_readable.js:423:5) at readableAddChunk (_stream_readable.js:166:9) at Socket.Readable.push (_stream_readable.js:128:10) at TCP.onread (net.js:529:21)
      На драйвер пока знаний не хватает, пытаюсь написать скрипт, а потом уже буду пытаться преобразовать все в драйвер.
      UPD: Разобрался, он закрывал соединение не зависимо от подписки.
      • I
        instalator last edited by
        есть переменная
        var menu = [
                ['Заказываем как обычно?', 'да', 'нет', [0,0,2]],
                ['На какой день?', 'сегодня', 'завтра'],
                ['На какое время?', 'утро', 'обед', 'вечер'],
                ['Я делаю заказ'],
                ['Какое количество?'],
        Пытаюсь узнать длину массива menu[0][0]
        log('menu[0][0].length' + menu[0][0].length);
        Выдает 14, целый час бился. Перезапускал даже IoB.
        Но после того как узнал длину следующего элемента, все встало на свои места
        23:25:39.178 [info] javascript.0 Start javascript script.js.МЕНЮ
        23:25:39.185 [info] javascript.0 script.js.МЕНЮ: menu[0][0].length-14
        23:25:39.185 [info] javascript.0 script.js.МЕНЮ: registered 1 subscription and 0 schedules
        23:25:58.064 [info] javascript.0 Stop script script.js.МЕНЮ
        23:25:58.243 [info] javascript.0 Start javascript script.js.МЕНЮ
        23:25:58.250 [info] javascript.0 script.js.МЕНЮ: menu[1][0].length3
        23:25:58.250 [info] javascript.0 script.js.МЕНЮ: registered 1 subscription and 0 schedules
        23:26:14.320 [info] javascript.0 Stop script script.js.МЕНЮ
        23:26:14.512 [info] javascript.0 Start javascript script.js.МЕНЮ
        23:26:14.525 [info] javascript.0 script.js.МЕНЮ: menu[0][1].length3
        23:26:14.525 [info] javascript.0 script.js.МЕНЮ: registered 1 subscription and 0 schedules
        23:26:24.575 [info] javascript.0 Stop script script.js.МЕНЮ
        23:26:24.828 [info] javascript.0 Start javascript script.js.МЕНЮ
        23:26:24.835 [info] javascript.0 script.js.МЕНЮ: menu[0][0].length4
        23:26:24.835 [info] javascript.0 script.js.МЕНЮ: registered 1 subscription and 0 schedules
        Это из-за чего такие глюки происходят в js?
        Добавлено.
        В скрипте так и продолжает выдавать 14.
        есть еще массив с одним элементом выдает длину 23:34:38.188 [info] javascript.0 script.js.МЕНЮ: result.length-11
          Haus last edited by
          Всем привет, нужна помощь это кусочек скрипта работает нормально, где то на третьем вычислении circ_temp_water + temp_corr получаю Дом: Повышаем расчетную температуру подачи на 0.1: 32.300000000000004 должно быть "32.3"
          function startt() {
               var room   = 'Heat_control';
               var ctwid  = getIdByName(room + '.circ_temp_water');
               var circ_temp_water = getState(ctwid).val;
               var temp_corr;
               if ( circ_temp_water_real < circ_temp_water - 1 )
               log(circ_title + ': Фактическая температура подачи значительно отличается от расчетной. Ждем, когда t достигнет нормы.');
               else if ( temp_trend == '+' )
               log(circ_title + ': Температура в помещении повышается (' + past_temp + ' -> ' + cur_temp + '). Наблюдаем');
               else
                     temp_corr = 0.1;
                     circ_temp_water = circ_temp_water + temp_corr;
                     setState(ctwid, circ_temp_water);
                     log(circ_title + ': Повышаем расчетную температуру подачи на ' + temp_corr + ': ' + circ_temp_water);
          setInterval(function() {
              startt();
          },30000);
          • Bluefox
            Bluefox last edited by
            @Haus:
            function startt() {
                 var temp_corr;
                 else
                       temp_corr = 0.1;
                startt();
            },30000);
            circ_temp_water = Math.round((circ_temp_water + temp_corr) * 10)) / 10;
              Haus last edited by
              Как сделать выполнение скрипта через пять минут после его завершения. В этом варианте circ_flap_duration2 одна или две секунды , но есть в скрипте и 35; 140 секунд. То Есть чтобы код подождал пока выполнится setTimeout действие.
              function startt() {
                              if ( circ_temp_water_real > circ_temp_water + 3 )
              	        circ_flap_duration = circ_mix_step * 2;
              	        else
              	        circ_flap_duration = circ_mix_step;
                              circ_flap_duration2 = circ_flap_duration * 1000;
              	        setState(cmuid, 0);
              	        setState(cmdid, 1);
              	        setTimeout(function () {setState(cmdid, 0);}, circ_flap_duration2);
              	        circ_flap = circ_flap - circ_flap_duration;
                              setState(cfid, circ_flap);
                  startt();
              },300000);
              • Bluefox
                @Haus:
                function startt() {
                	        else
                	        setState(cmuid, 0);
                	        setState(cmdid, 1);
                    startt();
                },300000);
                Код не может подождать. Надо снова вызывать setTimeout. В каком месте надо подождать?
                function startt(cb) {
                	        else
                	        setState(cmuid, 0);
                	        setState(cmdid, 1);
                	        setTimeout(function () {setState(cmdid, 0); cb && cb();}, circ_flap_duration2);
                    startt(function () {
                        log('едем дальше');
                },300000);
                  Haus last edited by
                  @Bluefox:
                  @Haus:
                  function startt() {
                  	        else
                  	        setState(cmuid, 0);
                  	        setState(cmdid, 1);
                      startt();
                  },300000);
                  	        else
                  	        setState(cmuid, 0);
                  	        setState(cmdid, 1);
                          log('едем дальше');
                  },300000);
                  setState(cmdid, 1);
                  setTimeout(function () {setState(cmdid, 0); cb && cb();}, 140000);
                  чтобы код идущий дальше выполнялся по завершению этого действия, просто дальше по коду есть условия if (circ_flap < 10) сделай то и то …
                  В PHP из которого я переделал это выглядит так
                  key_sw($circ_mix_up, 0);
                  key_sw($circ_mix_down, 1);
                  sleep(120);
                  key_sw($circ_mix_down, 0);
                  и по логу видно как время смищается
                  • Bluefox
                    @Haus:
                    @Bluefox:
                    @Haus:
                    function startt() {
                    	        else
                    	        setState(cmuid, 0);
                    	        setState(cmdid, 1);
                        startt();
                    },300000);
                    	        else
                    	        setState(cmuid, 0);
                    	        setState(cmdid, 1);
                            log('едем дальше');
                    },300000);
                    setState(cmdid, 1);
                    sleep(120);
                    и по логу видно как время смищается `
                    Я же показал код. Посмотри там где написано 'едем дальше'
                    А твой PHP вот так бы выглядел в JS:
                    }, 120);
                    • I
                      А по моей проблемам какие идеи?
                        А как можно вывести все поля объекта? Когда подписываюсь на изменения объекта, например чтоб не только по полю val проверять, а например, и по времени изменения?
                        • I
                          @spectrekr:
                          А как можно вывести все поля объекта? Когда подписываюсь на изменения объекта, например чтоб не только по полю val проверять, а например, и по времени изменения? `
                          Вместо val напиши ts. Описание на дравйвер смотри на гите
                            В чем ошибка?
                            on({id: 'javascript.0.sms.in.time', change: 'any'}, function (obj) {
                                log(obj.oldState.ts);
                                log(getObject('javascript.0.sms.in.time').oldState.ts);
                            Вроде бы должно в обоих случаях вывести одинаковое число, а по факту первый лог выводит, а второй дает ошибку что ts не существует.
                            • I
                              @spectrekr:
                              В чем ошибка?
                              Вроде бы должно в обоих случаях вывести одинаковое число, а по факту первый лог выводит, а второй дает ошибку что ts не существует. `
                              getState (id)
                              Returns state of id in form {val: value, ack: true/false, ts: timestamp, lc: lastchanged, from: origin}
                              Отсюда следует что колбек getState возвращает только текущее состояние. А вот on возвращает много чего.
                              • I
                                Имеем массив с данными
                                data-product="{"id":2104,"price":250,"discountPrice":240,"isBottle":true,"type":"product","count":1}",
                                data-product="{"id":1204,"price":190,"discountPrice":180,"isBottle":true,"type":"product","count":1}",
                                data-product="{"id":1041,"price":170,"discountPrice":160,"isBottle":true,"type":"product","count":1}",
                                data-product="{"id":3,"price":160,"discountPrice":150,"isBottle":true,"type":"product","count":1}",
                                data-product="{"id":1203,"price":120,"discountPrice":120,"isBottle":true,"type":"product","count":1}"
                                log(JSON.parse(itm)) выдает данные как строку а не как объект, это особенность JSON.parse для массивов?
                                `m.forEach(function(itm, i, arr) {
                                                    result[i] = JSON.stringify((itm.replace('data-product="', '').replace(/"/g, '"').slice(0, -1)));
                                                    if (i >= arr.length - 1){
                                                        result.forEach(function(itm, i, arr) {
                                                        log(JSON.parse(itm));
                                                });` [/i]
                                • Bluefox
                                  @instalator:
                                  Ты не даешь полной информации. Как конкретно выглядит m?[/i]
                                  • I
                                    @Bluefox:
                                    @instalator:
                                    Так и выглядит. Только вместо кавычек quote лог автоматом преобразовывет
                                    `~~[code]~~var m = body.match(/data-product="(.*)"/g);[/code]`
                                    `~~[code]~~{"id":1204,"price":190,"discountPrice":180,"isBottle":true,"type":"product","count":1}[/code]`[/i]
                                    • Bluefox
                                      @instalator:
                                      @Bluefox:
                                      @instalator:
                                      один stringify лишний
                                      `~~[code]~~result[i] = itm.replace('data-product="', '').replace(/"/g, '"').slice(0, -1);` [/i][/code][/i]
                                      • I
                                        @Bluefox:
                                        @instalator:
                                        @Bluefox:
                                        Ты не даешь полной информации. Как конкретно выглядит m? `
                                        `result[i] = itm.replace('data-product="', '').replace(/"/g, '"').slice(0, -1);`
                                         :) Решил перестраховаться, а он оказывается может напортачить[/i]
                                          Haus last edited by
                                          Народ помогайте, маленький кусочек скрипта. Проблема, сделал пока костыль на PHP чтобы дёргать из базы средние значения температур за определённый период времени. Таких request штук 10 в скрипте все прописаны в начале скрипта, так вот в временном log('Текущая ' + body), log('Средняя ' + body) инфа актуальная но она как бы запаздывает и лог log(circ_title + ': Расчет: ' + temp_base + ', Сред: ' + temp_in + ', Тек: ' + cur_temp) отображает прошлый request из переменных temp_in и cur_temp. Что можно сделать?
                                          var tbid    = getIdByName(room + '.temp_base');
                                          var shaid  = getIdByName(room + '.temp_in_stair_hall_avr_30min');
                                          var ctid    = getIdByName(room + '.cur_temp');
                                          function startt() {
                                              var request       = require('request');
                                              var circ_title    = 'Дом';
                                              var temp_base  = getState(tbid).val;
                                              var temp_in      = getState(shaid).val;
                                              var cur_temp    = getState(ctid).val;
                                              request('http://192.168.1.11/cur_temp.php', function (error, response, body) {
                                          	if (!error && response.statusCode == 200) {
                                                       setState(ctid, body);
                                                       log('Текущая ' + body);
                                              // Средняя температура в помещении за 30 минут
                                              request('http://192.168.1.11/avr_temp_in_stair_hall.php', function (error, response, body) {
                                                       setState(shaid, body);
                                                       log('Средняя ' + body);
                                              // Отладка. Выводим информацию по температурам
                                              log(circ_title + ': Расчет: ' + temp_base + ', Сред: ' + temp_in + ', Тек: ' + cur_temp);
                                              startt();
                                          },30000);
                                          • Bluefox
                                            function printDebug() {
                                            function startt() {
                                            	var count = 0;
                                            	count++;
                                            		count--;
                                            		if (!count) printDebug();
                                            	count++;
                                            		count--;
                                                startt();
                                            },30000);
                                            А надо ли вызывать скрипт каждые 30 секунд?
                                            358
                                            92363
