    4. [neuer Adapter] smartgarden adapter for Gardena smart system
    • dslraser
      dslraser Forum Testing Most Active @jpgorganizer last edited by
      @jpgorganizer
      prima, da habe ich drauf gewartet, wird auf jeden Fall getestet.
      • dslraser
        @jpgorganizer
        ich bekomme den Adapter nicht gestartet.
        host.iobroker	2020-03-20 21:45:56.654	info	Restart adapter system.adapter.smartgarden.0 because enabled
        host.iobroker	2020-03-20 21:45:56.654	info	instance system.adapter.smartgarden.0 terminated with code 0 (NO_ERROR)
        host.iobroker	2020-03-20 21:45:56.653	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:63:19)
        host.iobroker	2020-03-20 21:45:56.653	error	Caught by controller[0]: at endReadableNT (_stream_readable.js:1145:12)
        host.iobroker	2020-03-20 21:45:56.653	error	Caught by controller[0]: at IncomingMessage.emit (events.js:203:15)
        host.iobroker	2020-03-20 21:45:56.653	error	Caught by controller[0]: at Object.onceWrapper (events.js:286:20)
        host.iobroker	2020-03-20 21:45:56.653	error	Caught by controller[0]: at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/request/request.js:1083:12)
        host.iobroker	2020-03-20 21:45:56.653	error	Caught by controller[0]: at Request.emit (events.js:198:13)
        host.iobroker	2020-03-20 21:45:56.653	error	Caught by controller[0]: at Request.<anonymous> (/opt/iobroker/node_modules/request/request.js:1161:10)
        host.iobroker	2020-03-20 21:45:56.653	error	Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:185:22)
        host.iobroker	2020-03-20 21:45:56.652	error	Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.smartgarden/lib/api.js:1102:43)
        host.iobroker	2020-03-20 21:45:56.652	error	Caught by controller[0]: TypeError: Cannot read property '0' of undefined
        smartgarden.0	2020-03-20 21:45:56.113	info	(5608) Terminated (NO_ERROR): Without reason
        smartgarden.0	2020-03-20 21:45:56.112	info	(5608) terminating
        smartgarden.0	2020-03-20 21:45:56.068	info	(5608) cleaned everything up...
        jpgorganizer 1 Reply Last reply Reply Quote 0
        • jpgorganizer
          jpgorganizer @dslraser last edited by
          @dslraser
          er kann die Location nicht auflösen. Schau mal im Log, das müsste der letzte Response des Servers drinstehen. Kannst du mir den mal zeigen. Evtl. die Buchstaben und Zahlen gerne verfremden ... aber bitte keine Punkte rausnehmen - oder per PN
          jpgorganizer
          • jpgorganizer
            jpgorganizer @JohGre last edited by jpgorganizer
            @JohGre
            dachte ich mir, dass es an einer DNS Auflösung liegt 🙂
            Aber gut dass es geht.
            jpgorganizer
            • dslraser
              @jpgorganizer
              pn kommt gleich
              • jpgorganizer
                @dslraser
                da steht ein
                2020-03-20 21:54:56.085 - info: smartgarden.0 (5879) Response: Forbidden
                hast du auch irgendeine Art Pi-Hole laufen?
                jpgorganizer
                • dslraser
                  @jpgorganizer
                  nein, aber ioBroker im Docker Container, aber mi eigener IP über mac vlan
                  • dslraser
                    dslraser Forum Testing Most Active @jpgorganizer last edited by dslraser
                    @jpgorganizer
                    ich habe nochmal alles gelöscht und neu installiert, nun ist der Adapter grün. Frage mich nicht warum, ich habe nichts anderes gemacht...?
                    Testen kann ich dann erst wenn ich meine Ventile wieder an geklemmt habe.(vielleicht noch an diesem WE)
                    • jpgorganizer
                      @dslraser
                      hmm, ich muss mal überlegen woran das liegen mag. Der Server verweigert deinen Zugriff. Er bekommt in der Anfrage das Ergebnis aus dem vorgehenden Call. Das sollte wohl passen.
                      Hast du python3 auf deiner VM? Ich hab ein kleines python3 script, damit könnte man das ohne Overhead mal testen.
                      jpgorganizer
                      • dslraser
                        @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                        Das ist keine VM, das ist ein Synology NAS mit Docker. Aber der Adapter läuft ja jetzt.
                        • jpgorganizer
                          @dslraser
                          und warum läuft der jetzt? Du machst mir Angst .... Selbstheilung wäre mir neu
                          jpgorganizer
                          • dslraser
                            @dslraser
                            jpgorganizer
                            hast Du vielleicht einen Beitrag oben überlesen ?
                            https://forum.iobroker.net/post/397087
                            • jpgorganizer
                              @dslraser
                              yes, den Beitrag, dass du neu installiert hast, habe ich überlesen.
                              Na dann, einfach melden, wenn du Support brauchst. Abends bin ich i.d.R. erreichbar.
                              jpgorganizer
                              • dslraser
                                die erstellten Datenpunkte sind alle read only bzw. alle als Rolle text ? Mit welchen Datenpunkten könnte ich eine Bewässerung starten bzw.steuern ? In dem "alten" Adapter musste man die Duration einstellen und von idle auf manual umstellen und den trigger betätigen.
                                Vielleicht liegt es auch daran, das die Ventile nicht angeklemmt sind ? In der App sind die ja dann auch ausgegraut...
                                • jpgorganizer
                                  jpgorganizer @dslraser last edited by jpgorganizer
                                  @dslraser
                                  welche Datenpunkte du schreiben kannst steht hier https://github.com/jpgorganizer/ioBroker.smartgarden
                                  Wenn keine Ventile angeklemmt sind, dann wird Gardena auch nichts zeigen können. Wie sollten die das auch machen, ist ja nichts da
                                  Sowas gibt es in diesem Adapter nicht. Das sind unterschiedliche Konzepte. im anderen Adapter wird gepolllt, dh. zyklisch nachgesehen (nachgefragt), hier wird auf eine Mitteilung gewartet. Somit resourcenschonender
                                  jpgorganizer
                                  jpgorganizer 1 Reply Last reply Reply Quote 1
                                  • jpgorganizer
                                    jpgorganizer @jpgorganizer last edited by
                                    @dslraser
                                    du hast eine smart irrigation control? Wenn ja, dann sind wir schon zu zweit 🙂
                                    jpgorganizer
                                    • dslraser
                                      ja, dann sind wir zu zweit.
                                      • jpgorganizer
                                        jpgorganizer last edited by jpgorganizer
                                        Neue Version 0.2.0 soeben hochgeladen nach github.
                                        Bitte beachtet die folgenden Hinweise
                                        • IMPORTANT : datapoint for MOWER control (command) changed from duration_value to activity_control_i
                                        • rework leftovertimer
                                        • improved error handling
                                        • improved logging (see loglevel in adapter configurations)
                                        Die Änderung des Datenpunktes für die Mower control war erforderlich, da es sonst zu Missverständnis mit dem Datenpunkt gleichen Namens in anderen Services (z.B. bei den Valve's) gekommen wäre.
                                        Ich habe lange mit mir gerungen, den Namen zu ändern. Aber lieber jetzt ändern wie ewig mitschleppen. Danke für euer Verständnis.
                                        Bitte testen. Danke.
                                        jpgorganizer
                                        • dslraser
                                          @jpgorganizer
                                          Ich habe nun meine Ventile angeklemmt, aber ich kann keinen Datenpunkt setzen bzw. beschreiben. Ich kann sie nur "ansehen". Wenn ich in der App starte, dann ändern sich die Datenpunkte in den Objekten entsprechend, aber schalten kann ich keinen, weder starten noch stoppen.
                                          Was mache ich falsch ?
                                          Das habe ich gelesen, geht bei mir aber nicht.
                                          For VALVE Controlling To control the device use datapoint duration_value Change this datapoint to start the valve. To start for a defined time set the value to the value in seconds (please use multiples of 60) to cancel the current watering and continue with the schedule use string STOP_UNTIL_NEXT_TASK to skip automatic operation until specified time, the currently active operation might or might not be cancelled (depends on device model) use string PAUSE to restore automatic operation if it was paused use string UNPAUSE
                                          Wenn Du willst, kann ich Dir auch gern eine Teamviewer Session auf meinem Rechner anbieten.
                                          • jpgorganizer
                                            @dslraser
                                            @dslraser sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                                            Wie muss ich mir das vorstellen? Warum solltest du einen Datenpunkt nicht schreiben können? Mach doch mal einen Versuch. Gehe in die Datenpunktansicht (da wo du den Screenshot gemacht hast) und schreibe in den Datenpunkt duration_value mal z.B. 60 per Hand rein. Dann sollte das entsprechende Ventil für 60 sec aufgehen.
                                            Die Werte die in deinem Screenshot drinstehen, wurden durch Eingabe in der Gardena App erzeugt, richtig? Du hast das Ventil in diesem Beispiel für 20 min (1200 sec) geöffnet?
                                            Was nutzt du in ioBroker als App? VIS?
                                            jpgorganizer
                                            gardena smart system smartgarden
                                            108
                                            1080
                                            281753
