    4. Adapter: DasWetter
    Adapter: DasWetter
    • Glasfaser
      Glasfaser @Rene_HM last edited by
      @Rene_HM
      Kein Problem ... sage mir dann Bescheid 👍
      • Rene_HM
        Rene_HM Developer @Glasfaser last edited by
        @Glasfaser 2.8.2 liegt im github.
        neues log sollte so aussehen (wenn nur Pfad 3 abgeholt wird):
        2020-03-19 21:09:03.943 - info: daswetter.0 (3255) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
        2020-03-19 21:09:03.995 - debug: daswetter.0 (3255) set timeout to 240 sec
        2020-03-19 21:09:03.997 - debug: daswetter.0 (3255) using new data structure
        2020-03-19 21:09:04.005 - debug: daswetter.0 (3255) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
        2020-03-19 21:09:04.298 - debug: daswetter.0 (3255) got response
        2020-03-19 21:09:04.299 - debug: daswetter.0 (3255) got data without error, now parsing
        2020-03-19 21:09:04.578 - debug: daswetter.0 (3255) number of locations 1
        2020-03-19 21:09:04.583 - debug: daswetter.0 (3255) number of days 5
        2020-03-19 21:09:04.591 - debug: daswetter.0 (3255) number of hours 24
        2020-03-19 21:09:04.641 - debug: daswetter.0 (3255) number of hours 24
        2020-03-19 21:09:04.664 - debug: daswetter.0 (3255) number of hours 8
        2020-03-19 21:09:04.673 - debug: daswetter.0 (3255) number of hours 8
        2020-03-19 21:09:04.683 - debug: daswetter.0 (3255) number of hours 8
        2020-03-19 21:09:04.691 - debug: daswetter.0 (3255) hourly forecast done, objects in list 1640
        2020-03-19 21:09:04.696 - debug: daswetter.0 (3255) objects in list: 1640
        2020-03-19 21:09:05.630 - debug: daswetter.0 (3255) objects in list: 1539
        2020-03-19 21:09:06.433 - debug: daswetter.0 (3255) objects in list: 1438
        2020-03-19 21:09:07.091 - debug: daswetter.0 (3255) objects in list: 1337
        2020-03-19 21:09:07.706 - debug: daswetter.0 (3255) objects in list: 1236
        2020-03-19 21:09:08.345 - debug: daswetter.0 (3255) objects in list: 1135
        2020-03-19 21:09:10.746 - debug: daswetter.0 (3255) objects in list: 1034
        2020-03-19 21:09:11.346 - debug: daswetter.0 (3255) objects in list: 933
        2020-03-19 21:09:11.873 - debug: daswetter.0 (3255) objects in list: 832
        2020-03-19 21:09:12.450 - debug: daswetter.0 (3255) objects in list: 731
        2020-03-19 21:09:12.989 - debug: daswetter.0 (3255) objects in list: 630
        2020-03-19 21:09:13.531 - debug: daswetter.0 (3255) objects in list: 529
        2020-03-19 21:09:14.024 - debug: daswetter.0 (3255) objects in list: 428
        2020-03-19 21:09:14.541 - debug: daswetter.0 (3255) objects in list: 327
        2020-03-19 21:09:15.057 - debug: daswetter.0 (3255) objects in list: 226
        2020-03-19 21:09:15.561 - debug: daswetter.0 (3255) objects in list: 125
        2020-03-19 21:09:16.077 - debug: daswetter.0 (3255) objects in list: 24
        2020-03-19 21:09:16.256 - debug: daswetter.0 (3255) nothing to do
        2020-03-19 21:09:16.257 - debug: daswetter.0 (3255) exit, all done
        • Glasfaser
          @Rene_HM
          Hier ist das Ergebnis 😞
          host.iobrokerv4	2020-03-19 22:40:02.680	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
          daswetter.0	2020-03-19 22:40:02.169	warn	(6775) Terminated (15): Without reason
          daswetter.0	2020-03-19 22:40:02.168	error	(6775) force terminate, objects still in list: 0
          daswetter.0	2020-03-19 22:36:02.170	debug	(6775) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
          daswetter.0	2020-03-19 22:36:02.167	debug	(6775) using new data structure
          daswetter.0	2020-03-19 22:36:02.166	debug	(6775) set timeout to 240 sec
          daswetter.0	2020-03-19 22:36:02.144	info	(6775) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
          host.iobrokerv4	2020-03-19 22:36:00.072	info	instance system.adapter.daswetter.0 started with pid 6775
          host.iobrokerv4	2020-03-19 22:34:02.756	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
          daswetter.0	2020-03-19 22:34:02.244	warn	(3023) Terminated (15): Without reason
          daswetter.0	2020-03-19 22:34:02.243	error	(3023) force terminate, objects still in list: 0
          daswetter.0	2020-03-19 22:30:02.246	debug	(3023) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
          daswetter.0	2020-03-19 22:30:02.243	debug	(3023) using new data structure
          daswetter.0	2020-03-19 22:30:02.242	debug	(3023) set timeout to 240 sec
          daswetter.0	2020-03-19 22:30:02.217	info	(3023) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
          host.iobrokerv4	2020-03-19 22:30:00.069	info	instance system.adapter.daswetter.0 started with pid 3023
          host.iobrokerv4	2020-03-19 22:28:02.784	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
          daswetter.0	2020-03-19 22:24:02.275	debug	(31701) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
          daswetter.0	2020-03-19 22:24:02.272	debug	(31701) using new data structure
          daswetter.0	2020-03-19 22:24:02.271	debug	(31701) set timeout to 240 sec
          daswetter.0	2020-03-19 22:24:02.250	info	(31701) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
          host.iobrokerv4	2020-03-19 22:24:00.078	info	instance system.adapter.daswetter.0 started with pid 31701
          • harrym
            harrym last edited by
            ich hab damit noch nie Probleme gehabt ....?
            • Rene_HM
              @Glasfaser der Adapter bekommt keine Antwort vom Server, deshalb der timeout.
              Glasfaser 2 Replies Last reply Reply Quote 0
              • Glasfaser
                @Rene_HM
                Ok ... sehr mehrkwürdig !
                Die URL ist über den Browser sofort erreichbar,
                nur halt bei Pfad3 im Adapter wo der Link anders aufgebaut ist ( 2.0&h=1 ) funktioniert es nicht , bzw. der Server ist nicht erreichbar !?
                Kann man da was eingrenzen herrausfinden woran das liegt !?
                DANKE für deine Mühe !!!
                • Glasfaser
                  Glasfaser @Rene_HM last edited by Glasfaser
                  @Rene_HM
                  Habe einen zweiten iobroker im Docker installiert .(Neuinstallation)
                  Gerade mal die Grundinstallation vorhanden und dort geht es auch nicht .
                  Ich verstehe es nicht !
                  root@iobrokerv3:/opt/iobroker# node -v
                  v10.19.0
                  root@iobrokerv3:/opt/iobroker# nodejs -v
                  v10.19.0
                  root@iobrokerv3:/opt/iobroker# npm -v
                  sudo: Hostname iobrokerv3 kann nicht aufgelöst werden
                  6.13.4
                  root@iobrokerv3:/opt/iobroker# iobroker -v
                  2.2.9
                  root@iobrokerv3:/opt/iobroker# iobroker list adapters
                  system.adapter.admin                   : admin          - v3.7.8
                  system.adapter.daswetter               : daswetter      - v2.8.2
                  system.adapter.discovery               : discovery      - v1.3.0
                  system.adapter.info                    : info           - v1.5.6
                  root@iobrokerv3:/opt/iobroker# iobroker list instances
                  + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  + system.adapter.daswetter.0             : daswetter             -  enabled
                  + system.adapter.discovery.0             : discovery             -  enabled
                  + system.adapter.info.0                  : info                  -  enabled
                  + instance is alive
                  root@iobrokerv3:/opt/iobroker# ping 104.18.197.72
                  PING 104.18.197.72 (104.18.197.72) 56(84) bytes of data.
                  64 bytes from 104.18.197.72: icmp_seq=1 ttl=56 time=15.6 ms
                  64 bytes from 104.18.197.72: icmp_seq=2 ttl=56 time=17.9 ms
                  64 bytes from 104.18.197.72: icmp_seq=3 ttl=56 time=16.1 ms
                  64 bytes from 104.18.197.72: icmp_seq=4 ttl=56 time=12.3 ms
                  64 bytes from 104.18.197.72: icmp_seq=5 ttl=56 time=17.7 ms
                  64 bytes from 104.18.197.72: icmp_seq=6 ttl=56 time=19.9 ms
                  64 bytes from 104.18.197.72: icmp_seq=7 ttl=56 time=14.8 ms
                  64 bytes from 104.18.197.72: icmp_seq=8 ttl=56 time=12.8 ms
                  64 bytes from 104.18.197.72: icmp_seq=9 ttl=56 time=20.5 ms
                  64 bytes from 104.18.197.72: icmp_seq=10 ttl=56 time=13.0 ms
                  ^C
                  --- 104.18.197.72 ping statistics ---
                  10 packets transmitted, 10 received, 0% packet loss, time 9013ms
                  rtt min/avg/max/mdev = 12.389/16.106/20.512/2.755 ms
                  root@iobrokerv3:/opt/iobroker# ^C
                  LOG :
                  host.iobrokerv3	2020-03-20 23:10:01.692	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
                  daswetter.0	2020-03-20 23:10:01.181	warn	(1072) Terminated (15): Without reason
                  daswetter.0	2020-03-20 23:10:01.180	error	(1072) force terminate, objects still in list: 0
                  daswetter.0	2020-03-20 23:06:01.183	debug	(1072) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
                  daswetter.0	2020-03-20 23:06:01.180	debug	(1072) using new data structure
                  daswetter.0	2020-03-20 23:06:01.179	debug	(1072) set timeout to 240 sec
                  daswetter.0	2020-03-20 23:06:01.157	info	(1072) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
                  daswetter.0	2020-03-20 23:06:01.065	debug	(1072) statesDB connected
                  daswetter.0	2020-03-20 23:06:01.064	debug	(1072) States connected to redis: 127.0.0.1:9000
                  daswetter.0	2020-03-20 23:06:01.059	debug	(1072) States create System PubSub Client
                  daswetter.0	2020-03-20 23:06:01.056	debug	(1072) States create User PubSub Client
                  daswetter.0	2020-03-20 23:06:01.052	debug	(1072) Redis States: Use Redis connection: 127.0.0.1:9000
                  daswetter.0	2020-03-20 23:06:01.049	debug	(1072) objectDB connected
                  daswetter.0	2020-03-20 23:06:01.044	debug	(1072) Objects connected to redis: 127.0.0.1:9001
                  daswetter.0	2020-03-20 23:06:01.034	debug	(1072) Objects client initialize lua scripts
                  daswetter.0	2020-03-20 23:06:01.034	debug	(1072) Objects create User PubSub Client
                  daswetter.0	2020-03-20 23:06:01.033	debug	(1072) Objects create System PubSub Client
                  daswetter.0	2020-03-20 23:06:01.029	debug	(1072) Objects client ready ... initialize now
                  daswetter.0	2020-03-20 23:06:00.996	debug	(1072) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  host.iobrokerv3	2020-03-20 23:06:00.017	info	instance system.adapter.daswetter.0 started with pid 1072
                  host.iobrokerv3	2020-03-20 23:04:02.142	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
                  daswetter.0	2020-03-20 23:04:01.630	warn	(1000) Terminated (15): Without reason
                  daswetter.0	2020-03-20 23:04:01.629	error	(1000) force terminate, objects still in list: 0
                  daswetter.0	2020-03-20 23:00:01.632	debug	(1000) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
                  daswetter.0	2020-03-20 23:00:01.629	debug	(1000) using new data structure
                  daswetter.0	2020-03-20 23:00:01.628	debug	(1000) set timeout to 240 sec
                  daswetter.0	2020-03-20 23:00:01.606	info	(1000) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
                  daswetter.0	2020-03-20 23:00:01.069	debug	(1000) statesDB connected
                  daswetter.0	2020-03-20 23:00:01.068	debug	(1000) States connected to redis: 127.0.0.1:9000
                  daswetter.0	2020-03-20 23:00:01.062	debug	(1000) States create System PubSub Client
                  daswetter.0	2020-03-20 23:00:01.060	debug	(1000) States create User PubSub Client
                  daswetter.0	2020-03-20 23:00:01.055	debug	(1000) Redis States: Use Redis connection: 127.0.0.1:9000
                  daswetter.0	2020-03-20 23:00:01.053	debug	(1000) objectDB connected
                  daswetter.0	2020-03-20 23:00:01.048	debug	(1000) Objects connected to redis: 127.0.0.1:9001
                  daswetter.0	2020-03-20 23:00:01.036	debug	(1000) Objects client initialize lua scripts
                  daswetter.0	2020-03-20 23:00:01.036	debug	(1000) Objects create User PubSub Client
                  daswetter.0	2020-03-20 23:00:01.035	debug	(1000) Objects create System PubSub Client
                  daswetter.0	2020-03-20 23:00:01.030	debug	(1000) Objects client ready ... initialize now
                  daswetter.0	2020-03-20 23:00:00.997	debug	(1000) Redis Objects: Use Redis connection: 127.0.0.1:9001
                  host.iobrokerv3	2020-03-20 23:00:00.011	info	instance system.adapter.daswetter.0 started with pid 1000
                  Negalein Rene_HM 2 Replies Last reply Reply Quote 0
                  • Negalein
                    Negalein Global Moderator @Glasfaser last edited by
                    @Glasfaser sagte in Adapter: DasWetter:
                    Ich hatte das bei mir auch mal. Zwar nicht ioBroker, oder ein Adapter davon.
                    Alles ging, nur 1 Adresse konnte ich nie öffnen.
                    Nach sehr sehr viel Sucherei und Testerei lag es an der Syno und Fritz.
                    Update der Fritz dürfte an der Syno etwas aktiviert haben, so dass diese Adresse immer blockiert wurde.
                    Leider schien dies in keinem Log auf.
                    Wir haben im Endeffekt die Fritz komplett zurückgesetzt und an der Syno alles in der Firewall komplett neu erstellt.
                    • Glasfaser
                      Glasfaser @Negalein last edited by Glasfaser
                      @Negalein
                      Fritzbox / Synology und I-Net kann ich ausschließen .
                      Die Daten wurden schon im letzten Monat nicht aktualisiert laut altem Log ist mir halt nicht aufgefallen und seit dem 28.02.2020 habe ich eine neue Fritzbox 6591 mit 1000Mbit/s Anschluss und auch dort das gleiche.
                      Es ist halt nur bei Pfad3 ,das er nicht parsen kann .
                        wasi last edited by
                        wie habt ihr das mit der Registrierungsvereinbarung für die API gemacht?
                          Bluelightcrew @mrFenyx last edited by
                          @mrFenyx sagte in Adapter: DasWetter:
                          @Bluelightcrew Cool, freut mich. Und ja, ich hab's auch so in Betrieb und es läuft seit dem ich es gepostet habe ohne Probleme 😉
                          Ich hab das Problem bei mir jetzt gefunden! Irgendwann ist mir aufgefallen das im netztwerk zuhause die Bilder funktionieren und unterwegs nicht. Kurz nachgedacht,naja mit der ip adresse kann das natürlich nicht Funktionieren.
                          • Rene_HM
                            @Glasfaser ich verstehe es auch nicht wrklich. Das sind drei Zeilen Code:
                            adapter.log.debug("calling forecast hourly: " + url);
                                    request(url, (error, response, body) => {
                                        adapter.log.debug("got response");
                            das erste log sehen wir, das zweite nicht. Request kommt aus einer Bibliothek, welches http Requests behandelt, eigenlich sehr zuverlässig...
                            Normalerweise würde ich jetzt sagen, wir müssen die Pakete auf dem Netzwerk mit wireshark mitschneiden... Ich weiß nicht, ob du soweit gehen kannst und willst...
                            Aber ich vermute auch, dass irgendeine firewall die Pakete blockt. Ich kann aber auch nicht sagen, ob die Pakete gar nicht zum Server raus gehen oder ob nur die Antwort nicht richtig weitergeleitet wird...
                            Du hattest ja gezeigt, dass die URL vom Rechner aus richtige Daten liefert. Hängt dein iobroker-docker im gleichen Netz wie dein Rechner?
                            Du könntest auch mal in der Linux Konsole per wget versuchen, die Daten zu holen:
                            wget -q -o log.txt "http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1"
                            Das sollte dannn eine Datei mit dem Namen
                            'index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1'
                            ablegen.
                            Vielleicht kommen wir so weiter...
                            • Glasfaser
                              @Rene_HM
                              ioBroker ist im gleichen Netzwerk .
                              Den Befehl in der Konsole ausfgeführt und auch die Datei wird erstellt .
                              Alles funktioniert ,ist auch über ping oder per wget ausführbar.
                              hier der Inhalt der Datei :
                              und hier als Test ohne " &h=1 " ( für Pfad2)
                              • Rene_HM
                                Rene_HM Developer last edited by
                                @Glasfaser Das Ergebnis spricht gegen die Theorie, dass Pakete geblockt werden...
                                Ich habe jetzt mal meinen aktuellen Entwicklungszweig in den master im github gemerged. Dort hatte ich begonnen, request durch bent zu ersetzen, weil request nicht weiterentwickelt wird. Vielleicht kannst du die version 3.0.0 mal probieren?
                                Glasfaser 1 Reply Last reply Reply Quote 1
                                • Glasfaser
                                  @Rene_HM sagte in Adapter: DasWetter:
                                  Es klappt alles mit dieser Version .... 👍 😳 DANKE !!!
                                  die Daten werden abgeholt ....
                                  verarbeitet .. und auch die Datenpunkte werden geschieben .
                                  Lag es vielleicht an der alten Option die du jetzt rausgenommen hast !?
                                  "breaking change: old data structure is not supported anymore"
                                  Hier der LOG :
                                  Meldungen.txt
                                  • Rene_HM
                                    @Glasfaser Ursache kann nur das Paket "request" gewesen sein. Das habe ich ja ersetzt. Bishar war das sehr zuverlässig... naja, muss ich jetzt schauen, dass ich die 3.0 fertig bekomme, damit ich sie auch releasen kann...
                                    • Glasfaser
                                      @Rene_HM
                                      OK ... nochmal Danke 😳
                                      ... war schon am verzweifel , das ein größeres Problem bei mir vorliegt !
                                        Coffeelover last edited by
                                        mein Adapter aktualisiert nicht mehr. Im Log finde ich keine Einträge, aber das Verlaufsdiagramm zeigt noch immer die Werte ab 22.04. (auch der Datenpunkt "daswetter.0.NextDaysDetailed.Location_1.Day_1.day_value" zeigt den 22. Adapter Neustart und Installieren einer neue Instanz haben nicht geholfen. Die neue Instanz wurde einfach nicht angelegt. Als nächstes werde ich den Adapter komplett neu installieren.
                                        Habt ihr das auch?
                                        sigi234 Glasfaser C 3 Replies Last reply Reply Quote 0
                                          sigi234 Forum Testing Most Active @Coffeelover last edited by
                                          @Coffeelover sagte in Adapter: DasWetter:
                                          Habt ihr das auch?
                                          Nein
                                          • Glasfaser
                                            Glasfaser @Coffeelover last edited by Glasfaser
                                            Habt ihr das auch?
                                            Nur das Thema über dein Thread mit Pfad3.
                                            Wurde aber in der Version 3.0.0 behoben und funktioniert seit dem Top.
                                            1208
                                            410972
