    4. Adapter: DasWetter
    Adapter: DasWetter
    • Glasfaser
      Glasfaser @Rene_HM last edited by
      @Rene_HM
      Hier ist das Ergebnis 😞
      host.iobrokerv4	2020-03-19 22:40:02.680	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
      daswetter.0	2020-03-19 22:40:02.169	warn	(6775) Terminated (15): Without reason
      daswetter.0	2020-03-19 22:40:02.168	error	(6775) force terminate, objects still in list: 0
      daswetter.0	2020-03-19 22:36:02.170	debug	(6775) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
      daswetter.0	2020-03-19 22:36:02.167	debug	(6775) using new data structure
      daswetter.0	2020-03-19 22:36:02.166	debug	(6775) set timeout to 240 sec
      daswetter.0	2020-03-19 22:36:02.144	info	(6775) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
      host.iobrokerv4	2020-03-19 22:36:00.072	info	instance system.adapter.daswetter.0 started with pid 6775
      host.iobrokerv4	2020-03-19 22:34:02.756	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
      daswetter.0	2020-03-19 22:34:02.244	warn	(3023) Terminated (15): Without reason
      daswetter.0	2020-03-19 22:34:02.243	error	(3023) force terminate, objects still in list: 0
      daswetter.0	2020-03-19 22:30:02.246	debug	(3023) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
      daswetter.0	2020-03-19 22:30:02.243	debug	(3023) using new data structure
      daswetter.0	2020-03-19 22:30:02.242	debug	(3023) set timeout to 240 sec
      daswetter.0	2020-03-19 22:30:02.217	info	(3023) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
      host.iobrokerv4	2020-03-19 22:30:00.069	info	instance system.adapter.daswetter.0 started with pid 3023
      host.iobrokerv4	2020-03-19 22:28:02.784	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
      daswetter.0	2020-03-19 22:24:02.275	debug	(31701) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
      daswetter.0	2020-03-19 22:24:02.272	debug	(31701) using new data structure
      daswetter.0	2020-03-19 22:24:02.271	debug	(31701) set timeout to 240 sec
      daswetter.0	2020-03-19 22:24:02.250	info	(31701) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
      host.iobrokerv4	2020-03-19 22:24:00.078	info	instance system.adapter.daswetter.0 started with pid 31701
      • harrym
        harrym last edited by
        ich hab damit noch nie Probleme gehabt ....?
        • Rene_HM
          Rene_HM Developer @Glasfaser last edited by
          @Glasfaser der Adapter bekommt keine Antwort vom Server, deshalb der timeout.
          Glasfaser 2 Replies Last reply Reply Quote 0
          • Glasfaser
            @Rene_HM
            Ok ... sehr mehrkwürdig !
            Die URL ist über den Browser sofort erreichbar,
            nur halt bei Pfad3 im Adapter wo der Link anders aufgebaut ist ( 2.0&h=1 ) funktioniert es nicht , bzw. der Server ist nicht erreichbar !?
            Kann man da was eingrenzen herrausfinden woran das liegt !?
            DANKE für deine Mühe !!!
            • Glasfaser
              Glasfaser @Rene_HM last edited by Glasfaser
              @Rene_HM
              Habe einen zweiten iobroker im Docker installiert .(Neuinstallation)
              Gerade mal die Grundinstallation vorhanden und dort geht es auch nicht .
              Ich verstehe es nicht !
              root@iobrokerv3:/opt/iobroker# node -v
              v10.19.0
              root@iobrokerv3:/opt/iobroker# nodejs -v
              v10.19.0
              root@iobrokerv3:/opt/iobroker# npm -v
              sudo: Hostname iobrokerv3 kann nicht aufgelöst werden
              6.13.4
              root@iobrokerv3:/opt/iobroker# iobroker -v
              2.2.9
              root@iobrokerv3:/opt/iobroker# iobroker list adapters
              system.adapter.admin                   : admin          - v3.7.8
              system.adapter.daswetter               : daswetter      - v2.8.2
              system.adapter.discovery               : discovery      - v1.3.0
              system.adapter.info                    : info           - v1.5.6
              root@iobrokerv3:/opt/iobroker# iobroker list instances
              + system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.daswetter.0             : daswetter             -  enabled
              + system.adapter.discovery.0             : discovery             -  enabled
              + system.adapter.info.0                  : info                  -  enabled
              + instance is alive
              root@iobrokerv3:/opt/iobroker# ping 104.18.197.72
              PING 104.18.197.72 (104.18.197.72) 56(84) bytes of data.
              64 bytes from 104.18.197.72: icmp_seq=1 ttl=56 time=15.6 ms
              64 bytes from 104.18.197.72: icmp_seq=2 ttl=56 time=17.9 ms
              64 bytes from 104.18.197.72: icmp_seq=3 ttl=56 time=16.1 ms
              64 bytes from 104.18.197.72: icmp_seq=4 ttl=56 time=12.3 ms
              64 bytes from 104.18.197.72: icmp_seq=5 ttl=56 time=17.7 ms
              64 bytes from 104.18.197.72: icmp_seq=6 ttl=56 time=19.9 ms
              64 bytes from 104.18.197.72: icmp_seq=7 ttl=56 time=14.8 ms
              64 bytes from 104.18.197.72: icmp_seq=8 ttl=56 time=12.8 ms
              64 bytes from 104.18.197.72: icmp_seq=9 ttl=56 time=20.5 ms
              64 bytes from 104.18.197.72: icmp_seq=10 ttl=56 time=13.0 ms
              ^C
              --- 104.18.197.72 ping statistics ---
              10 packets transmitted, 10 received, 0% packet loss, time 9013ms
              rtt min/avg/max/mdev = 12.389/16.106/20.512/2.755 ms
              root@iobrokerv3:/opt/iobroker# ^C
              LOG :
              host.iobrokerv3	2020-03-20 23:10:01.692	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
              daswetter.0	2020-03-20 23:10:01.181	warn	(1072) Terminated (15): Without reason
              daswetter.0	2020-03-20 23:10:01.180	error	(1072) force terminate, objects still in list: 0
              daswetter.0	2020-03-20 23:06:01.183	debug	(1072) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
              daswetter.0	2020-03-20 23:06:01.180	debug	(1072) using new data structure
              daswetter.0	2020-03-20 23:06:01.179	debug	(1072) set timeout to 240 sec
              daswetter.0	2020-03-20 23:06:01.157	info	(1072) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
              daswetter.0	2020-03-20 23:06:01.065	debug	(1072) statesDB connected
              daswetter.0	2020-03-20 23:06:01.064	debug	(1072) States connected to redis: 127.0.0.1:9000
              daswetter.0	2020-03-20 23:06:01.059	debug	(1072) States create System PubSub Client
              daswetter.0	2020-03-20 23:06:01.056	debug	(1072) States create User PubSub Client
              daswetter.0	2020-03-20 23:06:01.052	debug	(1072) Redis States: Use Redis connection: 127.0.0.1:9000
              daswetter.0	2020-03-20 23:06:01.049	debug	(1072) objectDB connected
              daswetter.0	2020-03-20 23:06:01.044	debug	(1072) Objects connected to redis: 127.0.0.1:9001
              daswetter.0	2020-03-20 23:06:01.034	debug	(1072) Objects client initialize lua scripts
              daswetter.0	2020-03-20 23:06:01.034	debug	(1072) Objects create User PubSub Client
              daswetter.0	2020-03-20 23:06:01.033	debug	(1072) Objects create System PubSub Client
              daswetter.0	2020-03-20 23:06:01.029	debug	(1072) Objects client ready ... initialize now
              daswetter.0	2020-03-20 23:06:00.996	debug	(1072) Redis Objects: Use Redis connection: 127.0.0.1:9001
              host.iobrokerv3	2020-03-20 23:06:00.017	info	instance system.adapter.daswetter.0 started with pid 1072
              host.iobrokerv3	2020-03-20 23:04:02.142	error	instance system.adapter.daswetter.0 terminated with code 15 (15)
              daswetter.0	2020-03-20 23:04:01.630	warn	(1000) Terminated (15): Without reason
              daswetter.0	2020-03-20 23:04:01.629	error	(1000) force terminate, objects still in list: 0
              daswetter.0	2020-03-20 23:00:01.632	debug	(1000) calling forecast hourly: http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1
              daswetter.0	2020-03-20 23:00:01.629	debug	(1000) using new data structure
              daswetter.0	2020-03-20 23:00:01.628	debug	(1000) set timeout to 240 sec
              daswetter.0	2020-03-20 23:00:01.606	info	(1000) starting. Version 2.8.2 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.19.0
              daswetter.0	2020-03-20 23:00:01.069	debug	(1000) statesDB connected
              daswetter.0	2020-03-20 23:00:01.068	debug	(1000) States connected to redis: 127.0.0.1:9000
              daswetter.0	2020-03-20 23:00:01.062	debug	(1000) States create System PubSub Client
              daswetter.0	2020-03-20 23:00:01.060	debug	(1000) States create User PubSub Client
              daswetter.0	2020-03-20 23:00:01.055	debug	(1000) Redis States: Use Redis connection: 127.0.0.1:9000
              daswetter.0	2020-03-20 23:00:01.053	debug	(1000) objectDB connected
              daswetter.0	2020-03-20 23:00:01.048	debug	(1000) Objects connected to redis: 127.0.0.1:9001
              daswetter.0	2020-03-20 23:00:01.036	debug	(1000) Objects client initialize lua scripts
              daswetter.0	2020-03-20 23:00:01.036	debug	(1000) Objects create User PubSub Client
              daswetter.0	2020-03-20 23:00:01.035	debug	(1000) Objects create System PubSub Client
              daswetter.0	2020-03-20 23:00:01.030	debug	(1000) Objects client ready ... initialize now
              daswetter.0	2020-03-20 23:00:00.997	debug	(1000) Redis Objects: Use Redis connection: 127.0.0.1:9001
              host.iobrokerv3	2020-03-20 23:00:00.011	info	instance system.adapter.daswetter.0 started with pid 1000
              Negalein Rene_HM 2 Replies Last reply Reply Quote 0
              • Negalein
                Negalein Global Moderator @Glasfaser last edited by
                @Glasfaser sagte in Adapter: DasWetter:
                Ich hatte das bei mir auch mal. Zwar nicht ioBroker, oder ein Adapter davon.
                Alles ging, nur 1 Adresse konnte ich nie öffnen.
                Nach sehr sehr viel Sucherei und Testerei lag es an der Syno und Fritz.
                Update der Fritz dürfte an der Syno etwas aktiviert haben, so dass diese Adresse immer blockiert wurde.
                Leider schien dies in keinem Log auf.
                Wir haben im Endeffekt die Fritz komplett zurückgesetzt und an der Syno alles in der Firewall komplett neu erstellt.
                • Glasfaser
                  Glasfaser @Negalein last edited by Glasfaser
                  @Negalein
                  Fritzbox / Synology und I-Net kann ich ausschließen .
                  Die Daten wurden schon im letzten Monat nicht aktualisiert laut altem Log ist mir halt nicht aufgefallen und seit dem 28.02.2020 habe ich eine neue Fritzbox 6591 mit 1000Mbit/s Anschluss und auch dort das gleiche.
                  Es ist halt nur bei Pfad3 ,das er nicht parsen kann .
                    wasi last edited by
                    wie habt ihr das mit der Registrierungsvereinbarung für die API gemacht?
                      Bluelightcrew @mrFenyx last edited by
                      @mrFenyx sagte in Adapter: DasWetter:
                      @Bluelightcrew Cool, freut mich. Und ja, ich hab's auch so in Betrieb und es läuft seit dem ich es gepostet habe ohne Probleme 😉
                      Ich hab das Problem bei mir jetzt gefunden! Irgendwann ist mir aufgefallen das im netztwerk zuhause die Bilder funktionieren und unterwegs nicht. Kurz nachgedacht,naja mit der ip adresse kann das natürlich nicht Funktionieren.
                      • Rene_HM
                        @Glasfaser ich verstehe es auch nicht wrklich. Das sind drei Zeilen Code:
                        adapter.log.debug("calling forecast hourly: " + url);
                                request(url, (error, response, body) => {
                                    adapter.log.debug("got response");
                        das erste log sehen wir, das zweite nicht. Request kommt aus einer Bibliothek, welches http Requests behandelt, eigenlich sehr zuverlässig...
                        Normalerweise würde ich jetzt sagen, wir müssen die Pakete auf dem Netzwerk mit wireshark mitschneiden... Ich weiß nicht, ob du soweit gehen kannst und willst...
                        Aber ich vermute auch, dass irgendeine firewall die Pakete blockt. Ich kann aber auch nicht sagen, ob die Pakete gar nicht zum Server raus gehen oder ob nur die Antwort nicht richtig weitergeleitet wird...
                        Du hattest ja gezeigt, dass die URL vom Rechner aus richtige Daten liefert. Hängt dein iobroker-docker im gleichen Netz wie dein Rechner?
                        Du könntest auch mal in der Linux Konsole per wget versuchen, die Daten zu holen:
                        wget -q -o log.txt "http://api.daswetter.com/index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1"
                        Das sollte dannn eine Datei mit dem Namen
                        'index.php?api_lang=de&localidad=26301&affiliate_id=myx7k637fzzv&v=2.0&h=1'
                        ablegen.
                        Vielleicht kommen wir so weiter...
                        • Glasfaser
                          @Rene_HM
                          ioBroker ist im gleichen Netzwerk .
                          Den Befehl in der Konsole ausfgeführt und auch die Datei wird erstellt .
                          Alles funktioniert ,ist auch über ping oder per wget ausführbar.
                          hier der Inhalt der Datei :
                          und hier als Test ohne " &h=1 " ( für Pfad2)
                          • Rene_HM
                            Rene_HM Developer last edited by
                            @Glasfaser Das Ergebnis spricht gegen die Theorie, dass Pakete geblockt werden...
                            Ich habe jetzt mal meinen aktuellen Entwicklungszweig in den master im github gemerged. Dort hatte ich begonnen, request durch bent zu ersetzen, weil request nicht weiterentwickelt wird. Vielleicht kannst du die version 3.0.0 mal probieren?
                            Glasfaser 1 Reply Last reply Reply Quote 1
                            • Glasfaser
                              @Rene_HM sagte in Adapter: DasWetter:
                              Es klappt alles mit dieser Version .... 👍 😳 DANKE !!!
                              die Daten werden abgeholt ....
                              verarbeitet .. und auch die Datenpunkte werden geschieben .
                              Lag es vielleicht an der alten Option die du jetzt rausgenommen hast !?
                              "breaking change: old data structure is not supported anymore"
                              Hier der LOG :
                              Meldungen.txt
                              • Rene_HM
                                @Glasfaser Ursache kann nur das Paket "request" gewesen sein. Das habe ich ja ersetzt. Bishar war das sehr zuverlässig... naja, muss ich jetzt schauen, dass ich die 3.0 fertig bekomme, damit ich sie auch releasen kann...
                                • Glasfaser
                                  @Rene_HM
                                  OK ... nochmal Danke 😳
                                  ... war schon am verzweifel , das ein größeres Problem bei mir vorliegt !
                                    Coffeelover last edited by
                                    mein Adapter aktualisiert nicht mehr. Im Log finde ich keine Einträge, aber das Verlaufsdiagramm zeigt noch immer die Werte ab 22.04. (auch der Datenpunkt "daswetter.0.NextDaysDetailed.Location_1.Day_1.day_value" zeigt den 22. Adapter Neustart und Installieren einer neue Instanz haben nicht geholfen. Die neue Instanz wurde einfach nicht angelegt. Als nächstes werde ich den Adapter komplett neu installieren.
                                    Habt ihr das auch?
                                    sigi234 Glasfaser C 3 Replies Last reply Reply Quote 0
                                      sigi234 Forum Testing Most Active @Coffeelover last edited by
                                      @Coffeelover sagte in Adapter: DasWetter:
                                      Habt ihr das auch?
                                      Nein
                                      • Glasfaser
                                        Glasfaser @Coffeelover last edited by Glasfaser
                                        Habt ihr das auch?
                                        Nur das Thema über dein Thread mit Pfad3.
                                        Wurde aber in der Version 3.0.0 behoben und funktioniert seit dem Top.
                                        • wendy2702
                                          wendy2702 @Zippolighter last edited by wendy2702
                                          @Zippolighter sagte in Adapter: DasWetter:
                                          @CyberMicha:
                                          Huhu,
                                          hast du schon wegen dem Datum schauen können? Bei mir wird es als 20190113 dargestellt 😕
                                          LG Micha `
                                          Datumscript
                                          //   Datum für Wetter Widget in der richtigen Reihenfolge anzeigen
                                          createState("javascript.0.Manuell.Systemvariable.Wetter.Datum_ 1Tag", {name: 'Datum_ 1Tag', common: 'string'}, function () {});
                                          createState("javascript.0.Manuell.Systemvariable.Wetter.Datum_ 2Tag", {name: 'Datum_ 2Tag', common: 'string'}, function () {});
                                          createState("javascript.0.Manuell.Systemvariable.Wetter.Datum_ 3Tag", {name: 'Datum_ 3Tag', common: 'string'}, function () {});
                                          createState("javascript.0.Manuell.Systemvariable.Wetter.Datum_ 4Tag", {name: 'Datum_ 4Tag', common: 'string'}, function () {});
                                          createState("javascript.0.Manuell.Systemvariable.Wetter.Datum_ 5Tag", {name: 'Datum_ 5Tag', common: 'string'}, function () {});
                                          function berechneDatum() {
                                          // Berechnung des aktuellen Monats
                                              var d = new Date();
                                              var dm = d.getMonth() +1;
                                              var dd = d.getDate();
                                              var dJ = d.getFullYear();
                                              var Monat;
                                              log('Monat ' + dm);
                                              log('Tag ' + dd);
                                          log('Datum neu berechnet');
                                              var Tag1 = "javascript.0.Manuell.Systemvariable.Wetter.Datum_ 1Tag";
                                              var Tag2 = "javascript.0.Manuell.Systemvariable.Wetter.Datum_ 2Tag";
                                              var Tag3 = "javascript.0.Manuell.Systemvariable.Wetter.Datum_ 3Tag";
                                              var Tag4 = "javascript.0.Manuell.Systemvariable.Wetter.Datum_ 4Tag";
                                              var Tag5 = "javascript.0.Manuell.Systemvariable.Wetter.Datum_ 5Tag";
                                              var dD1 = dd + 0;
                                              if (dD1 < 10) {
                                                  dD1 = ('0' + dd);
                                          //        log('Tag zweistellig ' + dD1);
                                              var dD2 = dd + 1;
                                              if (dD2 < 10) {
                                                  dD2 = ('0' + (dd + 1));
                                          //        log('Tag zweistellig ' + dD2);
                                              var dD3 = dd + 2;
                                              if (dD3 < 10) {
                                                  dD3 = ('0' + (dd + 2));
                                          //        log('Tag zweistellig ' + dD3);
                                          //    log(dD3);
                                              var dD4 = dd + 3;
                                              if (dD4 < 10) {
                                                  dD4 = ('0' + (dd + 3));
                                          //        log('Tag zweistellig ' + dD4);
                                              var dD5 = dd + 4;
                                              if (dD5 < 10) {
                                                  dD5 = ('0' + (dd + 4));
                                          //        log('Tag zweistellig ' + dD5);
                                              dM = dm;
                                              if (dm < 10) {
                                                  var dM = ('0' + dm);
                                          //        log('Monat zweistellig ' + dM);
                                          //VorMonat als Namen
                                          Date.prototype.getFullMonth = function () {
                                            return (["Januar", "Februar", "März", "April", "Mai", "Juni", "Juli", "August", "September", "Oktober", "November", "Dezember"])[this.getMonth()];
                                              var VdM = d.getFullMonth();
                                              setState(Tag1, (dD1 + ' ' + VdM + ' ' + dJ));
                                              log(dD1 + ' ' + VdM + ' ' + dJ);
                                              setState(Tag2, (dD2 + ' ' + VdM + ' ' + dJ));
                                          //    log(dD2 + ' ' + VdM + ' ' + dJ);
                                              setState(Tag3, (dD3 + ' ' + VdM + ' ' + dJ));
                                          //    log(dD3 + ' ' + VdM + ' ' + dJ);
                                              setState(Tag4, (dD4 + ' ' + VdM + ' ' + dJ));
                                          //    log(dD4 + ' ' + VdM + ' ' + dJ);
                                              setState(Tag5, (dD5 + ' ' + VdM + ' ' + dJ));
                                          //    log(dD5 + ' ' + VdM + ' ' + dJ);
                                          berechneDatum(); // Skriptstart
                                          schedule("25 0 0 * * *", berechneDatum);
                                          Dann im Widget die Objekt-ID für das Datum auf javascript.0.Manuell.Systemvariable.Wetter.Datum_ 1Tag usw bis Datum_5Tag ändern
                                          @Glasfaser und ich sind dank @Nashra gerade darauf aufmerksam gemacht worden das mit diesem Script der April ein paar Tage mehr hat:
                                          Ist das schon jemandem aufgefallen und hat es eventuell schon jemand korrigiert ?
                                          EDIT: geht hier weiter: https://forum.iobroker.net/topic/18720/erledigt-hilfe-datumsscript/16
                                            Coffeelover @Coffeelover last edited by
                                            Ich habe nun gerade die 3.0.0 installiert, nachdem ich alle Instanzen gelöscht und den bisherigen Adapter deinstalliert habe.
                                            Die aktuellen Werte passen. Leider hat mir der Adapter aber die beiden "Detailed" Sichten nicht angelegt. Irgendwie funktioniert das gerade bei mir nicht sauber.
                                            1208
                                            411023
