    4. simple-api v.2.3.3 'common' of null
    UNSOLVED simple-api v.2.3.3 'common' of null
      Ich habe seit einigen Tagen immer zur gleichen Zeit folgende Fehlermeldung.
      Scripte kamen keine neuen dazu, zumindest keine, die irgend etwas mit dem Adapter/Fehlermeldung zu tun haben könnten.
      Leider komme ich nicht dahinter, was der Fehler sein könnte, vllt hat jemand eine Idee?
      Ansonsten läuft alles auf latest.... aktuellster Stand
      host.IoBroker	2020-03-20 00:04:04.580	error	Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
      host.IoBroker	2020-03-20 00:04:04.580	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      host.IoBroker	2020-03-20 00:04:04.580	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      host.IoBroker	2020-03-20 00:04:04.580	error	Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
      host.IoBroker	2020-03-20 00:04:04.579	error	Caught by controller[0]: TypeError: Cannot read property 'common' of null
      simple-api.0	2020-03-20 00:04:04.006	info	(2569) Terminated (NO_ERROR): Without reason
      simple-api.0	2020-03-20 00:04:04.005	info	(2569) terminating
      simple-api.0	2020-03-20 00:04:03.993	info	(2569) terminating http server on port 8087
      simple-api.0	2020-03-20 00:04:03.992	error	at process._tickCallback (internal/process/next_tick.js:68:7)
      simple-api.0	2020-03-20 00:04:03.992	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      simple-api.0	2020-03-20 00:04:03.992	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      simple-api.0	2020-03-20 00:04:03.992	error	at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
      simple-api.0	2020-03-20 00:04:03.992	error	(2569) TypeError: Cannot read property 'common' of null
      simple-api.0	2020-03-20 00:04:03.984	error	(2569) uncaught exception: Cannot read property 'common' of null
      Adapter config
      • Glasfaser
        Glasfaser @crunchip last edited by
        @crunchip
        Kann ich bestätigen ... bin auch im latest ...
        Bei mir ist es sporalisch aufgetreten und jetzt nicht mehr .
        Habe noch nichts gefunden woher es kommen könnte
        2020-03-18 00:35:12.725 - info: simple-api.0 (8818) terminating http server on port 8087
        2020-03-18 00:35:12.730 - info: simple-api.0 (8818) terminating
        2020-03-18 00:35:12.731 - info: simple-api.0 (8818) Terminated (NO_ERROR): Without reason
        2020-03-18 00:35:13.301 - error: host.iobrokerv4 Caught by controller[0]: TypeError: Cannot read property 'common' of null
        2020-03-18 00:35:13.301 - error: host.iobrokerv4 Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
        2020-03-18 00:35:13.302 - error: host.iobrokerv4 Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        2020-03-18 00:35:13.302 - error: host.iobrokerv4 Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        2020-03-18 00:35:13.302 - error: host.iobrokerv4 Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
        2020-03-18 00:35:13.302 - info: host.iobrokerv4 instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
        2020-03-18 00:35:13.302 - info: host.iobrokerv4 Restart adapter system.adapter.simple-api.0 because enabled
        2020-03-18 00:35:43.371 - info: host.iobrokerv4 instance system.adapter.simple-api.0 started with pid 31153
        2020-03-18 00:35:45.029 - info: simple-api.0 (31153) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
        2020-03-18 00:35:45.076 - info: simple-api.0 (31153) simpleAPI server listening on port 8087
        2020-03-18 00:35:45.077 - info: simple-api.0 (31153) Allow states only when user is owner: false
        2020-03-18 00:35:45.081 - info: simple-api.0 (31153) http server listening on port 8087
        2020-03-18 00:36:13.104 - error: simple-api.0 (31153) uncaught exception: Cannot read property 'common' of null
        2020-03-18 00:36:13.105 - error: simple-api.0 (31153) TypeError: Cannot read property 'common' of null
        2020-03-18 00:36:13.106 - info: simple-api.0 (31153) terminating http server on port 8087
        2020-03-18 00:36:13.116 - info: simple-api.0 (31153) terminating
        2020-03-18 00:36:13.117 - info: simple-api.0 (31153) Terminated (NO_ERROR): Without reason
        2020-03-18 00:36:13.665 - error: host.iobrokerv4 Caught by controller[0]: TypeError: Cannot read property 'common' of null
        2020-03-18 00:36:13.666 - error: host.iobrokerv4 Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
        2020-03-18 00:36:13.666 - error: host.iobrokerv4 Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        2020-03-18 00:36:13.666 - error: host.iobrokerv4 Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        2020-03-18 00:36:13.666 - error: host.iobrokerv4 Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
        2020-03-18 00:36:13.667 - info: host.iobrokerv4 instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
        2020-03-18 00:36:13.667 - info: host.iobrokerv4 Restart adapter system.adapter.simple-api.0 because enabled
        2020-03-18 19:48:42.427 - error: simple-api.0 (2501) uncaught exception: Cannot read property 'common' of null
        2020-03-18 19:48:42.429 - error: simple-api.0 (2501) TypeError: Cannot read property 'common' of null
        2020-03-18 19:48:42.430 - info: simple-api.0 (2501) terminating http server on port 8087
        2020-03-18 19:48:42.515 - info: simple-api.0 (2501) terminating
        2020-03-18 19:48:42.516 - info: simple-api.0 (2501) Terminated (NO_ERROR): Without reason
        2020-03-18 19:48:43.086 - error: host.iobrokerv4 Caught by controller[0]: TypeError: Cannot read property 'common' of null
        2020-03-18 19:48:43.087 - error: host.iobrokerv4 Caught by controller[0]: at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
        2020-03-18 19:48:43.087 - error: host.iobrokerv4 Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        2020-03-18 19:48:43.087 - error: host.iobrokerv4 Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        2020-03-18 19:48:43.087 - error: host.iobrokerv4 Caught by controller[0]: at process._tickCallback (internal/process/next_tick.js:68:7)
        2020-03-18 19:48:43.087 - info: host.iobrokerv4 instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
        2020-03-18 19:48:43.087 - info: host.iobrokerv4 Restart adapter system.adapter.simple-api.0 because enabled
        2020-03-18 19:48:43.218 - info: sql.0 (17756) disabled logging of daswetter.0.NextHours.Location_1.Day_1.tempmax_value
        2020-03-18 19:49:13.171 - info: host.iobrokerv4 instance system.adapter.simple-api.0 started with pid 3946
        2020-03-18 19:49:14.766 - info: simple-api.0 (3946) starting. Version 2.3.2 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
        2020-03-18 19:49:14.809 - info: simple-api.0 (3946) simpleAPI server listening on port 8087
        2020-03-18 19:49:14.810 - info: simple-api.0 (3946) Allow states only when user is owner: false
        2020-03-18 19:49:14.814 - info: simple-api.0 (3946) http server listening on port 8087
          crunchip Forum Testing Most Active @Glasfaser last edited by crunchip
          @Glasfaser bekomme die oben genannte Meldung auch, wenn IoBroker neu gestartet wurde
          desweiteren habe ich auch gelegentlich die Meldung
          web.0	2020-03-21 14:44:34.274	warn	(3060) Empty pattern!
          wenn ich im web Adapter socketio integriert auf socketio stelle, bekomme ich das Empty pattern! dann beim socketio Adapter
          • Glasfaser
            Glasfaser @crunchip last edited by Glasfaser
            @crunchip
            Die Meldung habe ich seit Tagen bemerkt und versucht es rauszufinden .
            Aber nur jetzt kommen Sie nicht mehr , habe auch nicht´s geändert 🤔
            Die Meldungen kamen aber nicht bei einem Neustart.
            Habe so meine Einstellungen ... aber wie gesagt alles Top ...
            Den Adapter ( Instanz) socket.io habe ich nicht an .
              @Glasfaser bei mir ist eine Datenbank angegeben und alle Datenpunkte auflisten haken gesetzt, da man dadurch siehe hier auch Daten direkt holen kann.
              Glasfaser 2 Replies Last reply Reply Quote 0
              • Glasfaser
                @crunchip
                Danke für den Tip ... schau ich mir an 👍
                  crunchip Forum Testing Most Active last edited by crunchip
                  nachdem ich heute mal mein Tablet neugestartet habe, kamen wieder die Fehlermeldung in mehrfacher Ausführung,
                  also gehe ich davon aus, ...wenn Gerät nicht erreichbar...,
                  bleibt die Frage, warum häufig aber nicht immer, genau um 0:04Uhr,
                  zumal in Vorgängerversionen eine solche Meldung nicht kam, wenn das Tablet neu gestartet/nicht erreichbar war,
                  zumindest fiel es mir nicht bewusst auf
                  auch die Fehlermeldungen ziehen sich von 15:38 - 16:04 kann also auch nicht allein am Neustart des Tablets liegen
                  2020-03-25 15:38:51.385  - error: simple-api.0 (6321) uncaught exception: Cannot read property 'common' of null
                  2020-03-25 15:38:51.387  - error: simple-api.0 (6321) TypeError: Cannot read property 'common' of null
                  2020-03-25 15:38:51.389  - info: simple-api.0 (6321) terminating http server on port 8087
                  2020-03-25 15:38:51.413  - info: simple-api.0 (6321) terminating
                  2020-03-25 15:38:51.416  - info: simple-api.0 (6321) Terminated (NO_ERROR): Without reason
                  2020-03-25 15:38:52.100  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
                  2020-03-25 15:38:52.102  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
                  2020-03-25 15:38:52.102  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                  2020-03-25 15:38:52.103  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                  2020-03-25 15:38:52.103  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
                  2020-03-25 15:38:52.103  - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
                  2020-03-25 15:38:52.103  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
                  2020-03-25 15:39:00.127  - info: host.IoBroker instance system.adapter.daswetter.0 started with pid 15993
                  2020-03-25 15:39:22.159  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 16017
                  2020-03-25 15:39:25.254  - info: simple-api.0 (16017) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
                  2020-03-25 15:39:25.329  - info: simple-api.0 (16017) simpleAPI server listening on port 8087
                  2020-03-25 15:39:25.330  - info: simple-api.0 (16017) Allow states only when user is owner: false
                  2020-03-25 15:39:25.337  - info: simple-api.0 (16017) http server listening on port 8087
                  2020-03-25 15:39:34.492  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Büro: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 379, >= Schwelle von 20
                  2020-03-25 15:39:36.829  - error: simple-api.0 (16017) uncaught exception: Cannot read property 'common' of null
                  2020-03-25 15:39:36.830  - error: simple-api.0 (16017) TypeError: Cannot read property 'common' of null
                  2020-03-25 15:39:36.832  - info: simple-api.0 (16017) terminating http server on port 8087
                  2020-03-25 15:39:37.835  - warn: simple-api.0 (16017) Terminated (UNCAUGHT_EXCEPTION): Without reason
                  2020-03-25 15:39:39.458  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
                  2020-03-25 15:39:39.459  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
                  2020-03-25 15:39:39.460  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                  2020-03-25 15:39:39.460  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                  2020-03-25 15:39:39.460  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
                  2020-03-25 15:39:39.461  - error: host.IoBroker instance system.adapter.simple-api.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                  2020-03-25 15:39:39.462  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
                  2020-03-25 15:40:00.103  - info: host.IoBroker instance system.adapter.weatherunderground.0 started with pid 16202
                  2020-03-25 15:40:00.551  - info: javascript.0 (1649) script.js.Visualisierung.Lebensmittel-RRS: RSS-Feed https://www.lebensmittelwarnung.de/bvl-lmw-de/opensaga/feed/alle/bayern.rss eingelesen
                  2020-03-25 15:40:00.573  - info: javascript.0 (1649) script.js.Visualisierung.Newsfeed_Bild: RSS-Feed http://www.bild.de/rssfeeds/vw-news/vw-news-16726644,sort=1,view=rss2.bild.xml eingelesen
                  2020-03-25 15:40:06.707  - error: daswetter.0 (15993) force terminate, objects still in list: 84
                  2020-03-25 15:40:06.710  - warn: daswetter.0 (15993) Terminated (15): Without reason
                  2020-03-25 15:40:07.249  - error: host.IoBroker instance system.adapter.daswetter.0 terminated with code 15 (15)
                  2020-03-25 15:40:09.749  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 16357
                  2020-03-25 15:40:13.706  - info: host.IoBroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                  2020-03-25 15:40:16.467  - info: simple-api.0 (16357) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
                  2020-03-25 15:40:16.603  - info: simple-api.0 (16357) simpleAPI server listening on port 8087
                  2020-03-25 15:40:16.604  - info: simple-api.0 (16357) Allow states only when user is owner: false
                  2020-03-25 15:40:16.610  - info: simple-api.0 (16357) http server listening on port 8087
                  2020-03-25 15:40:39.603  - error: simple-api.0 (16357) uncaught exception: Cannot read property 'common' of null
                  2020-03-25 15:40:39.605  - error: simple-api.0 (16357) TypeError: Cannot read property 'common' of null
                  2020-03-25 15:40:39.606  - info: simple-api.0 (16357) terminating http server on port 8087
                  2020-03-25 15:40:40.481  - info: simple-api.0 (16357) terminating
                  2020-03-25 15:40:40.483  - info: simple-api.0 (16357) Terminated (NO_ERROR): Without reason
                  2020-03-25 15:40:40.560  - info: simple-api.0 (16357) terminating
                  2020-03-25 15:40:40.878  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Büro: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 378, >= Schwelle von 20
                  2020-03-25 15:40:41.051  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
                  2020-03-25 15:40:41.052  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
                  2020-03-25 15:40:41.052  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                  2020-03-25 15:40:41.052  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                  2020-03-25 15:40:41.053  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
                  2020-03-25 15:40:41.053  - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
                  2020-03-25 15:40:41.053  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
                  2020-03-25 15:41:11.100  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 16688
                  2020-03-25 15:41:14.158  - info: simple-api.0 (16688) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
                  2020-03-25 15:41:14.277  - info: simple-api.0 (16688) simpleAPI server listening on port 8087
                  2020-03-25 15:41:14.278  - info: simple-api.0 (16688) Allow states only when user is owner: false
                  2020-03-25 15:41:14.284  - info: simple-api.0 (16688) http server listening on port 8087
                  2020-03-25 15:41:39.560  - error: simple-api.0 (16688) uncaught exception: Cannot read property 'common' of null
                  2020-03-25 15:41:39.561  - error: simple-api.0 (16688) TypeError: Cannot read property 'common' of null
                  2020-03-25 15:41:39.563  - info: simple-api.0 (16688) terminating http server on port 8087
                  2020-03-25 15:41:40.374  - info: simple-api.0 (16688) terminating
                  2020-03-25 15:41:40.376  - info: simple-api.0 (16688) Terminated (NO_ERROR): Without reason
                  2020-03-25 15:41:40.382  - info: simple-api.0 (16688) terminating
                  2020-03-25 15:41:41.120  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
                  2020-03-25 15:41:41.121  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
                  2020-03-25 15:41:41.121  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                  2020-03-25 15:41:41.122  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                  2020-03-25 15:41:41.122  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
                  2020-03-25 15:41:41.122  - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
                  2020-03-25 15:41:41.122  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
                  2020-03-25 15:41:58.275  - info: coronavirus-statistics.0 (15208) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2020-03-25 15:41:58.818  - info: host.IoBroker instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2020-03-25 15:42:11.077  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Esstisch: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 111, >= Schwelle von 20
                  2020-03-25 15:42:11.181  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 17019
                  2020-03-25 15:42:13.696  - info: simple-api.0 (17019) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
                  2020-03-25 15:42:13.809  - info: simple-api.0 (17019) simpleAPI server listening on port 8087
                  2020-03-25 15:42:13.810  - info: simple-api.0 (17019) Allow states only when user is owner: false
                  2020-03-25 15:42:13.818  - info: simple-api.0 (17019) http server listening on port 8087
                  2020-03-25 15:42:34.081  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Esstisch: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 143, >= Schwelle von 20
                  2020-03-25 15:42:47.862  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Esstisch: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 144, >= Schwelle von 20
                  2020-03-25 15:43:07.370  - info: iogo.0 (1615) device update received: {"alive":false,"batteryCharging":false,"batteryLevel":70,"name":"S10+","token":"f4Oce5GiBFM:APA91bHU9SFepK3mvxNHFO_dqfGUzIBv0AIpDnOzaMKPUlmzlJg8VwzLHYkKlypOkIwkwHVHfX9Gqn22FFs4286QcifPhj1tuWnj4GIf1HTyRZtFbrb_5CmgJ8xxE-C9OqLUrChq7l5c","ts":1585147384429}
                  2020-03-25 15:43:07.590  - info: iogo.0 (1615) user Mario changed
                  2020-03-25 15:45:00.061  - info: host.IoBroker instance system.adapter.coronavirus-statistics.0 started with pid 17840
                  2020-03-25 15:45:05.300  - info: coronavirus-statistics.0 (17840) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v10.19.0
                  2020-03-25 15:47:37.030  - info: coronavirus-statistics.0 (17840) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2020-03-25 15:47:37.551  - info: host.IoBroker instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2020-03-25 15:47:45.329  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Büro: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 364, >= Schwelle von 20
                  2020-03-25 15:48:00.111  - info: host.IoBroker instance system.adapter.dwd.0 started with pid 18773
                  2020-03-25 15:48:08.719  - info: host.IoBroker instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                  2020-03-25 15:50:00.108  - info: host.IoBroker instance system.adapter.weatherunderground.0 started with pid 19556
                  2020-03-25 15:50:00.527  - info: javascript.0 (1649) script.js.Visualisierung.Newsfeed_Bild: RSS-Feed http://www.bild.de/rssfeeds/vw-news/vw-news-16726644,sort=1,view=rss2.bild.xml eingelesen
                  2020-03-25 15:50:00.536  - info: javascript.0 (1649) script.js.Visualisierung.Lebensmittel-RRS: RSS-Feed https://www.lebensmittelwarnung.de/bvl-lmw-de/opensaga/feed/alle/bayern.rss eingelesen
                  2020-03-25 15:50:09.998  - info: host.IoBroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                  2020-03-25 15:51:22.850  - info: host.IoBroker stopInstance system.adapter.coronavirus-statistics.0 (force=false, process=false)
                  2020-03-25 15:51:22.852  - info: host.IoBroker stopInstance canceled schedule system.adapter.coronavirus-statistics.0
                  2020-03-25 15:51:25.358  - info: host.IoBroker instance scheduled system.adapter.coronavirus-statistics.0 */15 * * * *
                  2020-03-25 15:51:25.408  - info: host.IoBroker instance system.adapter.coronavirus-statistics.0 started with pid 19896
                  2020-03-25 15:51:30.352  - info: coronavirus-statistics.0 (19896) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v10.19.0
                  2020-03-25 15:52:00.115  - info: host.IoBroker instance system.adapter.daswetter.0 started with pid 20079
                  2020-03-25 15:52:52.571  - info: host.IoBroker instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                  2020-03-25 15:54:04.236  - info: info.0 (1596) Popup news was read...
                  2020-03-25 15:54:11.452  - info: coronavirus-statistics.0 (19896) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2020-03-25 15:54:11.995  - info: host.IoBroker instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2020-03-25 15:58:24.393  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Büro: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 364, >= Schwelle von 20
                  2020-03-25 15:59:39.021  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Büro: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 344, >= Schwelle von 20
                  2020-03-25 16:00:00.060  - info: host.IoBroker instance system.adapter.daswetter.0 started with pid 22591
                  2020-03-25 16:00:00.785  - info: javascript.0 (1649) script.js.Visualisierung.Lebensmittel-RRS: RSS-Feed https://www.lebensmittelwarnung.de/bvl-lmw-de/opensaga/feed/alle/bayern.rss eingelesen
                  2020-03-25 16:00:00.798  - info: javascript.0 (1649) script.js.Visualisierung.Newsfeed_Bild: RSS-Feed http://www.bild.de/rssfeeds/vw-news/vw-news-16726644,sort=1,view=rss2.bild.xml eingelesen
                  2020-03-25 16:00:04.205  - info: host.IoBroker instance system.adapter.coronavirus-statistics.0 started with pid 22736
                  2020-03-25 16:00:07.811  - warn: daswetter.0 (22591) no connection to objects DB
                  2020-03-25 16:00:08.459  - info: host.IoBroker instance system.adapter.weatherunderground.0 started with pid 22754
                  2020-03-25 16:00:10.106  - warn: daswetter.0 (22591) no connection to states DB
                  2020-03-25 16:00:10.086  - warn: coronavirus-statistics.0 (22736) no connection to states DB
                  2020-03-25 16:00:12.569  - info: host.IoBroker instance system.adapter.dwd.0 started with pid 22792
                  2020-03-25 16:00:13.810  - info: coronavirus-statistics.0 (22736) starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v10.19.0
                  2020-03-25 16:00:17.360  - info: host.IoBroker instance system.adapter.ical.0 started with pid 22816
                  2020-03-25 16:00:21.224  - info: host.IoBroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                  2020-03-25 16:00:25.892  - info: host.IoBroker instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
                  2020-03-25 16:00:34.573  - info: host.IoBroker instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                  2020-03-25 16:01:10.973  - error: simple-api.0 (17019) uncaught exception: Cannot read property 'common' of null
                  2020-03-25 16:01:10.975  - error: simple-api.0 (17019) TypeError: Cannot read property 'common' of null
                  2020-03-25 16:01:10.977  - info: simple-api.0 (17019) terminating http server on port 8087
                  2020-03-25 16:01:11.662  - info: simple-api.0 (17019) terminating
                  2020-03-25 16:01:11.663  - info: simple-api.0 (17019) Terminated (NO_ERROR): Without reason
                  2020-03-25 16:01:11.667  - info: simple-api.0 (17019) terminating
                  2020-03-25 16:01:12.248  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
                  2020-03-25 16:01:12.249  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
                  2020-03-25 16:01:12.250  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                  2020-03-25 16:01:12.250  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                  2020-03-25 16:01:12.250  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
                  2020-03-25 16:01:12.250  - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
                  2020-03-25 16:01:12.251  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
                  2020-03-25 16:01:13.333  - error: daswetter.0 (22591) force terminate, objects still in list: 314
                  2020-03-25 16:01:13.338  - warn: daswetter.0 (22591) Terminated (15): Without reason
                  2020-03-25 16:01:13.874  - error: host.IoBroker instance system.adapter.daswetter.0 terminated with code 15 (15)
                  2020-03-25 16:01:42.304  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 23305
                  2020-03-25 16:01:45.882  - info: simple-api.0 (23305) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
                  2020-03-25 16:01:46.005  - info: simple-api.0 (23305) simpleAPI server listening on port 8087
                  2020-03-25 16:01:46.007  - info: simple-api.0 (23305) Allow states only when user is owner: false
                  2020-03-25 16:01:46.015  - info: simple-api.0 (23305) http server listening on port 8087
                  2020-03-25 16:01:57.788  - error: simple-api.0 (23305) uncaught exception: Cannot read property 'common' of null
                  2020-03-25 16:01:57.789  - error: simple-api.0 (23305) TypeError: Cannot read property 'common' of null
                  2020-03-25 16:01:57.791  - info: simple-api.0 (23305) terminating http server on port 8087
                  2020-03-25 16:01:57.808  - info: simple-api.0 (23305) terminating
                  2020-03-25 16:01:57.810  - info: simple-api.0 (23305) Terminated (NO_ERROR): Without reason
                  2020-03-25 16:01:58.382  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
                  2020-03-25 16:01:58.383  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
                  2020-03-25 16:01:58.383  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                  2020-03-25 16:01:58.383  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                  2020-03-25 16:01:58.383  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
                  2020-03-25 16:01:58.383  - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
                  2020-03-25 16:01:58.383  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
                  2020-03-25 16:02:11.022  - info: javascript.0 (1649) script.js.Beleuchtung.BWM-Lichtsteuerung1: Bewegungsmelder Büro: Ausgelöst, aber es wird nicht geschaltet, Grund: Gemessene Lux = 335, >= Schwelle von 20
                  2020-03-25 16:02:28.430  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 23644
                  2020-03-25 16:02:32.062  - info: simple-api.0 (23644) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
                  2020-03-25 16:02:32.143  - info: simple-api.0 (23644) simpleAPI server listening on port 8087
                  2020-03-25 16:02:32.145  - info: simple-api.0 (23644) Allow states only when user is owner: false
                  2020-03-25 16:02:32.151  - info: simple-api.0 (23644) http server listening on port 8087
                  2020-03-25 16:03:01.254  - info: javascript.0 (1649) script.js.Visualisierung.Lebensmittelwarnung: Daten aktualisiert...
                  2020-03-25 16:03:03.436  - error: simple-api.0 (23644) uncaught exception: Cannot read property 'common' of null
                  2020-03-25 16:03:03.437  - error: simple-api.0 (23644) TypeError: Cannot read property 'common' of null
                  2020-03-25 16:03:03.439  - info: simple-api.0 (23644) terminating http server on port 8087
                  2020-03-25 16:03:03.569  - info: simple-api.0 (23644) terminating
                  2020-03-25 16:03:03.577  - info: simple-api.0 (23644) Terminated (NO_ERROR): Without reason
                  2020-03-25 16:03:04.163  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
                  2020-03-25 16:03:04.164  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
                  2020-03-25 16:03:04.165  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                  2020-03-25 16:03:04.165  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                  2020-03-25 16:03:04.165  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
                  2020-03-25 16:03:04.165  - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
                  2020-03-25 16:03:04.165  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
                  2020-03-25 16:03:12.191  - info: coronavirus-statistics.0 (22736) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                  2020-03-25 16:03:12.844  - info: host.IoBroker instance system.adapter.coronavirus-statistics.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                  2020-03-25 16:03:34.237  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 23974
                  2020-03-25 16:03:37.002  - info: simple-api.0 (23974) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
                  2020-03-25 16:03:37.093  - info: simple-api.0 (23974) simpleAPI server listening on port 8087
                  2020-03-25 16:03:37.094  - info: simple-api.0 (23974) Allow states only when user is owner: false
                  2020-03-25 16:03:37.100  - info: simple-api.0 (23974) http server listening on port 8087
                  2020-03-25 16:04:06.373  - error: simple-api.0 (23974) uncaught exception: Cannot read property 'common' of null
                  2020-03-25 16:04:06.384  - error: simple-api.0 (23974) TypeError: Cannot read property 'common' of null
                  2020-03-25 16:04:06.386  - info: simple-api.0 (23974) terminating http server on port 8087
                  2020-03-25 16:04:06.647  - info: simple-api.0 (23974) terminating
                  2020-03-25 16:04:06.648  - info: simple-api.0 (23974) Terminated (NO_ERROR): Without reason
                  2020-03-25 16:04:07.231  - error: host.IoBroker Caught by controller[0]: TypeError: Cannot read property 'common' of null
                  2020-03-25 16:04:07.233  - error: host.IoBroker Caught by controller[0]:     at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:107068)
                  2020-03-25 16:04:07.233  - error: host.IoBroker Caught by controller[0]:     at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
                  2020-03-25 16:04:07.233  - error: host.IoBroker Caught by controller[0]:     at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
                  2020-03-25 16:04:07.234  - error: host.IoBroker Caught by controller[0]:     at process._tickCallback (internal/process/next_tick.js:68:7)
                  2020-03-25 16:04:07.234  - info: host.IoBroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
                  2020-03-25 16:04:07.234  - info: host.IoBroker Restart adapter system.adapter.simple-api.0 because enabled
                  2020-03-25 16:04:37.284  - info: host.IoBroker instance system.adapter.simple-api.0 started with pid 24305
                  2020-03-25 16:04:40.791  - info: simple-api.0 (24305) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.simple-api, node: v10.19.0
                  2020-03-25 16:04:40.869  - info: simple-api.0 (24305) simpleAPI server listening on port 8087
                  2020-03-25 16:04:40.871  - info: simple-api.0 (24305) Allow states only when user is owner: false
                  2020-03-25 16:04:40.876  - info: simple-api.0 (24305) http server listening on port 8087
                  • Glasfaser
                    @crunchip sagte in simple-api v.2.3.3 'common' of null:
                    Ich habe ja die Einstellungen (noch) nicht geändert , da ja zur Zeit alles läuft und keine Fehlermeldung mehr kommen ...
                    Hast du es mal so getestet wie ich die Einstellungen habe , ob der Fehler dann noch kommt .
                    Es sieht so aus als würde der simple-api Adapter immer zusammenbrechen ( zu viele Ereignisse)
                      @Glasfaser du meinst den externen simple ausschalten und den internen im Web Adapter verwenden?
                      kann ich mal testen
                      • Glasfaser
                        @crunchip
                        Jipp ... alle Einstellungen wie ich oben alle im Screenshot habe .
                        Simple und Web Adapter
                          @Glasfaser also trotzdem den Simple-api Adapter an?
                          • Glasfaser
                            @crunchip
                            Ja ..
                            ich habe nur die Adapter Simple-Api und Web an , den socketio Adapter habe ich aus.
                              @Glasfaser dann hast ja den simple doppelt, extern und intigriert?
                              • Glasfaser
                                @crunchip
                                Die Einstellungen habe ich schon immer so .
                                common of null error simple api
                                858
