    4. [Vorlage] Vis für Adapter HeatingControl
      Pittini Developer @Bastelritius last edited by
      @Bastelritius sagte in [Vorlage] Vis für Adapter HeatingControl:
      Was mache ich hier falsch?
      Nachtrag:
      Du hast auch einen nicht konfigurierten Raum mit ohne Namen, siehe hier:
      21.3.2020, 22:17:52.966 [info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: 0 Büro
      21.3.2020, 22:17:52.966 [info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: 1 Gaeste_WC
      21.3.2020, 22:17:52.966 [info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: 2
      • O
        Oli @Pittini last edited by
        @Pittini
        ich bekomme ebenfalls viele Warnmeldungen.
        javascript.0	2020-03-23 09:50:24.559	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.559	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.559	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.559	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.559	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.559	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.558	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.558	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:323:5)
        javascript.0	2020-03-23 09:50:24.558	warn	(774) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
        javascript.0	2020-03-23 09:50:24.557	warn	(774) You are assigning a object to the state "javascript.0.vis.HeatingControl.RoomValues.CurrentTimePeriod" which expects a number. Please fix your code to use a number or change the state type to o
        javascript.0	2020-03-23 09:50:24.557	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.556	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.556	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.556	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.556	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.556	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.555	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.555	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:323:61)
        javascript.0	2020-03-23 09:50:24.554	warn	(774) getState "heatingcontrol.0.Rooms.Wohnzimmer.ActiveTimeSlot" not found (3) states[id]=null
        javascript.0	2020-03-23 09:50:24.552	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.552	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.552	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.552	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.552	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.551	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.551	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.550	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:296:17)
        javascript.0	2020-03-23 09:50:24.550	warn	(774) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
        javascript.0	2020-03-23 09:50:24.549	warn	(774) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Fri.Periods.4.time" which expects a string. Please fix your code to use a string or change the state type t
        javascript.0	2020-03-23 09:50:24.549	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.549	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.549	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.549	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.549	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.548	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.548	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.548	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:296:79)
        javascript.0	2020-03-23 09:50:24.547	warn	(774) getState "heatingcontrol.0.Profiles.0.Wohnzimmer.Fri.4.time" not found (3)
        javascript.0	2020-03-23 09:50:24.547	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.546	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.546	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.546	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.546	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.546	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.546	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.546	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:294:17)
        javascript.0	2020-03-23 09:50:24.545	warn	(774) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
        javascript.0	2020-03-23 09:50:24.545	warn	(774) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Thu.Periods.4.time" which expects a string. Please fix your code to use a string or change the state type t
        javascript.0	2020-03-23 09:50:24.544	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.544	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.544	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.543	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.543	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.543	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.543	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.542	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:294:79)
        javascript.0	2020-03-23 09:50:24.541	warn	(774) getState "heatingcontrol.0.Profiles.0.Wohnzimmer.Thu.4.time" not found (3)
        javascript.0	2020-03-23 09:50:24.536	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.535	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.535	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.534	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.534	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.534	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.534	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.533	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:296:17)
        javascript.0	2020-03-23 09:50:24.533	warn	(774) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
        javascript.0	2020-03-23 09:50:24.532	warn	(774) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Fri.Periods.3.time" which expects a string. Please fix your code to use a string or change the state type t
        javascript.0	2020-03-23 09:50:24.532	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.532	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.532	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.531	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.531	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.531	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.531	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.530	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:296:79)
        javascript.0	2020-03-23 09:50:24.530	warn	(774) getState "heatingcontrol.0.Profiles.0.Wohnzimmer.Fri.3.time" not found (3)
        javascript.0	2020-03-23 09:50:24.529	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.529	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.529	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.529	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.528	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.528	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.528	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.528	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:294:17)
        javascript.0	2020-03-23 09:50:24.528	warn	(774) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
        javascript.0	2020-03-23 09:50:24.527	warn	(774) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Thu.Periods.3.time" which expects a string. Please fix your code to use a string or change the state type t
        javascript.0	2020-03-23 09:50:24.527	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.527	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.527	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.526	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.526	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.526	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.526	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.526	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:294:79)
        javascript.0	2020-03-23 09:50:24.525	warn	(774) getState "heatingcontrol.0.Profiles.0.Wohnzimmer.Thu.3.time" not found (3)
        javascript.0	2020-03-23 09:50:24.523	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.523	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.523	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.523	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.523	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.523	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.522	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.522	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:296:17)
        javascript.0	2020-03-23 09:50:24.522	warn	(774) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
        javascript.0	2020-03-23 09:50:24.521	warn	(774) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Fri.Periods.2.time" which expects a string. Please fix your code to use a string or change the state type t
        javascript.0	2020-03-23 09:50:24.521	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.521	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.521	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.521	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.521	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.520	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.520	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.520	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:296:79)
        javascript.0	2020-03-23 09:50:24.519	warn	(774) getState "heatingcontrol.0.Profiles.0.Wohnzimmer.Fri.2.time" not found (3)
        javascript.0	2020-03-23 09:50:24.519	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.519	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.518	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.518	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.518	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.518	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.518	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.518	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:294:17)
        javascript.0	2020-03-23 09:50:24.517	warn	(774) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
        javascript.0	2020-03-23 09:50:24.517	warn	(774) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Thu.Periods.2.time" which expects a string. Please fix your code to use a string or change the state type t
        javascript.0	2020-03-23 09:50:24.517	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.517	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.516	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.516	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.516	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.516	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.516	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.515	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:294:79)
        javascript.0	2020-03-23 09:50:24.513	warn	(774) getState "heatingcontrol.0.Profiles.0.Wohnzimmer.Thu.2.time" not found (3)
        javascript.0	2020-03-23 09:50:24.512	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.512	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.512	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.511	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.511	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.511	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.511	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.511	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:296:17)
        javascript.0	2020-03-23 09:50:24.511	warn	(774) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
        javascript.0	2020-03-23 09:50:24.510	warn	(774) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Fri.Periods.1.time" which expects a string. Please fix your code to use a string or change the state type t
        javascript.0	2020-03-23 09:50:24.510	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.510	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.510	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.509	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.509	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.509	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.509	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.509	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:296:79)
        javascript.0	2020-03-23 09:50:24.508	warn	(774) getState "heatingcontrol.0.Profiles.0.Wohnzimmer.Fri.1.time" not found (3)
        javascript.0	2020-03-23 09:50:24.507	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.507	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.507	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.507	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.507	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.507	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.506	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.506	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:294:17)
        javascript.0	2020-03-23 09:50:24.506	warn	(774) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
        javascript.0	2020-03-23 09:50:24.505	warn	(774) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Thu.Periods.1.time" which expects a string. Please fix your code to use a string or change the state type t
        javascript.0	2020-03-23 09:50:24.505	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.505	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.505	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.505	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.505	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.504	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.504	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.504	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:294:79)
        javascript.0	2020-03-23 09:50:24.503	warn	(774) getState "heatingcontrol.0.Profiles.0.Wohnzimmer.Thu.1.time" not found (3)
        javascript.0	2020-03-23 09:50:24.502	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.501	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.501	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.501	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.501	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.501	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.501	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.501	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:296:17)
        javascript.0	2020-03-23 09:50:24.500	warn	(774) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
        javascript.0	2020-03-23 09:50:24.500	warn	(774) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Fri.Periods.0.time" which expects a string. Please fix your code to use a string or change the state type t
        javascript.0	2020-03-23 09:50:24.500	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.499	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.499	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        javascript.0	2020-03-23 09:50:24.499	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
        javascript.0	2020-03-23 09:50:24.499	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
        javascript.0	2020-03-23 09:50:24.499	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
        javascript.0	2020-03-23 09:50:24.499	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
        javascript.0	2020-03-23 09:50:24.498	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:296:79)
        javascript.0	2020-03-23 09:50:24.497	warn	(774) getState "heatingcontrol.0.Profiles.0.Wohnzimmer.Fri.0.time" not found (3)
        javascript.0	2020-03-23 09:50:24.497	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
        javascript.0	2020-03-23 09:50:24.493	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
        javascript.0	2020-03-23 09:50:24.492	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
        Angeblich werden States am Donnerstag und Freitag nicht gefunden, die allerdings vorhanden sind.
        1de7404b-c384-4663-baa8-01c12704c1b6-image.png ![alt text](image url)
          Pittini Developer @Oli last edited by Pittini
          @Oli sagte in [Vorlage] Vis für Adapter HeatingControl:
          Bestätigt. Bug. Behoben. Neue Version des Skriptes 1.0.5 is auf Git.
          • O
            @Pittini
            super Danke für die schnelle Bearbeitung, leider bekomme ich immer noch Warnmeldungen
            javascript.0	2020-03-23 11:09:13.895	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
            javascript.0	2020-03-23 11:09:13.895	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
            javascript.0	2020-03-23 11:09:13.895	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            javascript.0	2020-03-23 11:09:13.895	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
            javascript.0	2020-03-23 11:09:13.894	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
            javascript.0	2020-03-23 11:09:13.894	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
            javascript.0	2020-03-23 11:09:13.894	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
            javascript.0	2020-03-23 11:09:13.893	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:324:5)
            javascript.0	2020-03-23 11:09:13.893	warn	(774) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
            javascript.0	2020-03-23 11:09:13.892	warn	(774) You are assigning a object to the state "javascript.0.vis.HeatingControl.RoomValues.CurrentTimePeriod" which expects a number. Please fix your code to use a number or change the state type to o
            javascript.0	2020-03-23 11:09:13.892	warn	(774) at process._tickCallback (internal/process/next_tick.js:68:7)
            javascript.0	2020-03-23 11:09:13.892	warn	(774) at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
            javascript.0	2020-03-23 11:09:13.891	warn	(774) at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
            javascript.0	2020-03-23 11:09:13.891	warn	(774) at (anonymous function).(anonymous function) (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:17:71697)
            javascript.0	2020-03-23 11:09:13.891	warn	(774) at /opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1916:42
            javascript.0	2020-03-23 11:09:13.891	warn	(774) at Object.<anonymous> (script.js.Gewerke.Heizpläne:160:13)
            javascript.0	2020-03-23 11:09:13.890	warn	(774) at main (script.js.Gewerke.Heizpläne:174:5)
            javascript.0	2020-03-23 11:09:13.890	warn	(774) at SetVis (script.js.Gewerke.Heizpläne:324:61)
            javascript.0	2020-03-23 11:09:13.889	warn	(774) getState "heatingcontrol.0.Rooms.Wohnzimmer.ActiveTimeSlot" not found (3) states[id]=null
              Mach mir mal bitte nen Screen vom aufgeklappten heatingcontrol.0.Rooms.Wohnzimmer
              • O
                @Pittini
                hier der gewünschte Screen
                  Danke. Dacht ichs mir doch, für den Bug kann ich nix, da musste Dich an Rene wenden bzw. ein Issue aufmachen. Wenn der Adapter das Feld nicht füllt kanns mein Skript logischerweise nicht auslesen.
                  • O
                    @Pittini
                    alles klar, danke
                    • Stephan Schleich
                      Stephan Schleich last edited by Stephan Schleich
                      @Pittini: Ich bekomm mit dem Script folgende Warnmeldungen beim start
                        Pittini Developer @Stephan Schleich last edited by Pittini
                        @Stephan-Schleich sagte in [Vorlage] Vis für Adapter HeatingControl:
                        Adapterversion? Skriptversion? Welchen View (das Projekt oder den SimpleView)?
                        Sieht aus als wenn händisch ne Temperatur mit °C eingegeben wurde obwohl nur ne Zahl erlaubt ist oder ne Zahl mit Komma statt Punkt? Solltest Du sowas gemacht haben, ist das der Fehler, ansonsten, bitte Screen mit aufgeklappten Datenpunkten von:
                        heatingcontrol.0.Profiles.0.Wohnzimmer.Sun.Periods.0
                        und
                        heatingcontrol.0.Profiles.0.Wohnzimmer.Thu.Periods
                        und
                        Stephan Schleich 1 Reply Last reply Reply Quote 0
                        • Stephan Schleich
                          Stephan Schleich @Pittini last edited by Stephan Schleich
                          @Pittini: Adapter: 0.3.18, Script: von heute, SimpleView
                          Die Werte stehen als Zahl drinnen
                          Javascript:
                          HeatingControl:
                            Adapter: 0.3.18
                            Bitte 0.3.19 einspielen, da wurden etlicher solcher Probleme gelöst, dann nochmal Feedback bitte.
                            • Bastelritius
                              Bastelritius @Beliar_666 last edited by
                              ich hoffe ich beantworte jetzt alle Fragen und übersehe nichts.
                              @Beliar_666: Ich hatte den Adapter mal testweise installiert, aber wieder gelöscht. Jedoch erscheinen noch die Widgets im VIS-Editor:
                              Zumal ich auch meine Vis Seite mit dem aktuellen MD-Desing von uhlah laufen habe. Dort funtioniert das Auf und zuklappen auch. Auch der input mit Datetime klappt.
                              @Pittini
                              • Update habe ich gemacht, habe jetzt die Version 0.3.19
                              • Widget "jqui - ctrl - Input Datetime" sollte ich haben
                              1. Liste Deiner installierten Adapter, vorallem mit Vis zusammenhängende.
                              2. die Objektliste von "javascript.0.vis.HeatingControl" mit aufgeklappten Channels
                              3. die Objektliste von "heatingcontrol.0" mit aufgeklappten Channel "Info"
                              4. Haupt- und Profil- Einstellungen aus dem HeatingControl Adapter.
                              Ich hoffe ich habe nichts vergessen.
                                Pittini Developer @Bastelritius last edited by Pittini
                                Schaut eigentlich soweit ok aus. Leider hast das wichtigste vergessen, nämlich die Auskunft obs jetzt funktioniert oder nicht und wenn nein, was nicht geht, bzw. ob das update keinerlei Effekt hatte. Am besten nochmal n Log. Tritt der Fehler bei Start auf oder wenn Du was änderst im Vis?
                                Bastelritius 1 Reply Last reply Reply Quote 0
                                • Bastelritius
                                  Bastelritius @Pittini last edited by
                                  @Pittini , Hallo.
                                  Also beim Start vom Script erscheinen folgende Warnmeldungen:
                                  24.3.2020, 13:31:22.096	[info ]: javascript.0 (1038) Stop script script.js.common.HeatingControlMapper
                                  24.3.2020, 13:31:22.208	[info ]: javascript.0 (1038) Start javascript script.js.common.HeatingControlMapper
                                  24.3.2020, 13:31:22.221	[info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: registered 0 subscriptions and 0 schedules
                                  24.3.2020, 13:31:22.271	[info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: CreateStates fertig!
                                  24.3.2020, 13:31:22.274	[info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: <div class="mdui-listitem mdui-center-v" style="height:48px;"> <img height=40px src="/vis.0/HeatingControl/images/fts_window_1w.svg"&nbsp</img> <div class="mdui-label">Büro<div class="mdui-subtitle">seit 24.03.2020 08:14:38</div></div></div><div class="mdui-listitem mdui-center-v" style="height:48px;"> <img height=40px src="/vis.0/HeatingControl/images/fts_window_1w.svg"&nbsp</img> <div class="mdui-label">Gaeste_WC<div class="mdui-subtitle">seit 11.03.2020 20:45:01</div></div></div>
                                  24.3.2020, 13:31:22.276	[info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: reaching CreateCurrentTimePeriodTrigger - Oldroom= none ChoosenRoom= Büro
                                  24.3.2020, 13:31:22.278	[info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: 0 Büro
                                  24.3.2020, 13:31:22.279	[info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: 1 Gaeste_WC
                                  24.3.2020, 13:31:22.282	[info ]: javascript.0 (1038) script.js.common.HeatingControlMapper: Reaching SetVis
                                  24.3.2020, 13:31:22.284	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:296:79)
                                  24.3.2020, 13:31:22.284	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                                  24.3.2020, 13:31:22.286	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                                  24.3.2020, 13:31:22.290	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:296:17)
                                  24.3.2020, 13:31:22.290	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                                  24.3.2020, 13:31:22.290	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                                  24.3.2020, 13:31:22.299	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:298:79)
                                  24.3.2020, 13:31:22.300	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                                  24.3.2020, 13:31:22.300	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                                  24.3.2020, 13:31:22.304	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:298:17)
                                  24.3.2020, 13:31:22.304	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                                  24.3.2020, 13:31:22.304	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                                  24.3.2020, 13:31:22.309	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:296:79)
                                  24.3.2020, 13:31:22.310	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                                  24.3.2020, 13:31:22.310	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                                  24.3.2020, 13:31:22.315	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:296:17)
                                  24.3.2020, 13:31:22.316	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                                  24.3.2020, 13:31:22.316	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                                  24.3.2020, 13:31:22.321	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:298:79)
                                  24.3.2020, 13:31:22.322	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                                  24.3.2020, 13:31:22.322	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                                  24.3.2020, 13:31:22.327	[warn ]: javascript.0 (1038)     at SetVis (script.js.common.HeatingControlMapper:298:17)
                                  24.3.2020, 13:31:22.328	[warn ]: javascript.0 (1038)     at main (script.js.common.HeatingControlMapper:174:5)
                                  24.3.2020, 13:31:22.328	[warn ]: javascript.0 (1038)     at Object.<anonymous> (script.js.common.HeatingControlMapper:160:13)
                                  Bei Änderungen am Profil im Vis erscheint folgendes:
                                  heatingcontrol.0	2020-03-24 13:33:29.651	warn	(11016) more then 100 cron jobs existing for this adapter, this might be a configuration error!
                                  heatingcontrol.0	2020-03-24 13:33:24.713	warn	(11016) more then 100 cron jobs existing for this adapter, this might be a configuration error!
                                  heatingcontrol.0	2020-03-24 13:33:13.058	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                                  heatingcontrol.0	2020-03-24 13:33:13.057	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                                  heatingcontrol.0	2020-03-24 13:33:13.047	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                                  heatingcontrol.0	2020-03-24 13:33:13.046	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                                  heatingcontrol.0	2020-03-24 13:33:13.045	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                                  heatingcontrol.0	2020-03-24 13:33:13.035	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                                  heatingcontrol.0	2020-03-24 13:33:13.034	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                                  heatingcontrol.0	2020-03-24 13:33:13.033	warn	(11016) wrong order of periods: 1:0 is smaller then 3:0. Please reorder periods
                                  javascript.0	2020-03-24 13:33:28.079	info	(1038) script.js.Rollos.Rolladen_automatik: getState(id=0_userdata.0.rolladensteuerung.rolladen_runter_helligkeit, timerId=undefined) => {"val":"110","ack":false,"ts":1584725455483,"q":0,"from":"syste
                                  javascript.0	2020-03-24 13:33:28.078	info	(1038) script.js.Rollos.Rolladen_automatik: getState(id=hm-rpc.0.NEQ0118858.1.BRIGHTNESS, timerId=undefined) => {"val":219,"ack":true,"ts":1585053208075,"q":0,"from":"system.adapter.hm-rpc.0","user":"
                                  javascript.0	2020-03-24 13:33:28.078	info	(1038) script.js.Rollos.Rolladen_automatik: setForeignState(id=0_userdata.0.rolladensteuerung.rolladen_steuerung, state={"val":0,"ack":true})
                                  javascript.0	2020-03-24 13:33:28.077	info	(1038) script.js.Rollos.Rolladen_automatik: getState(id=0_userdata.0.rolladensteuerung.rolladen_runter_helligkeit, timerId=undefined) => {"val":"110","ack":false,"ts":1584725455483,"q":0,"from":"syste
                                  javascript.0	2020-03-24 13:33:28.076	info	(1038) script.js.Rollos.Rolladen_automatik: getState(id=hm-rpc.0.NEQ0118858.1.BRIGHTNESS, timerId=undefined) => {"val":219,"ack":true,"ts":1585053208075,"q":0,"from":"system.adapter.hm-rpc.0","user":"
                                  javascript.0	2020-03-24 13:33:22.172	info	(1038) script.js.common.HeatingControlMapper: MinimumTemp=Null, skipping entry and showing 0
                                  javascript.0	2020-03-24 13:33:22.169	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:22.169	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:22.169	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:22.169	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:22.169	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:22.169	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:22.169	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                                  javascript.0	2020-03-24 13:33:22.168	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:17)
                                  javascript.0	2020-03-24 13:33:22.168	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                                  javascript.0	2020-03-24 13:33:22.167	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Fri.Periods.1.time" which expects a string. Please fix your code to use a string or change the state type t
                                  javascript.0	2020-03-24 13:33:22.167	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:22.167	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:22.167	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:22.167	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:22.167	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:22.166	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:22.166	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                                  javascript.0	2020-03-24 13:33:22.166	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:79)
                                  javascript.0	2020-03-24 13:33:22.165	warn	(1038) getState "heatingcontrol.0.Profiles.1.Gaeste_WC.Fri.1.time" not found (3)
                                  javascript.0	2020-03-24 13:33:22.165	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:22.164	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:22.164	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:22.164	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:22.164	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:22.164	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:22.164	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                                  javascript.0	2020-03-24 13:33:22.164	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:17)
                                  javascript.0	2020-03-24 13:33:22.163	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                                  javascript.0	2020-03-24 13:33:22.163	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Thu.Periods.1.time" which expects a string. Please fix your code to use a string or change the state type t
                                  javascript.0	2020-03-24 13:33:22.162	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:22.162	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:22.162	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:22.160	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:22.160	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:22.159	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:22.159	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                                  javascript.0	2020-03-24 13:33:22.159	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:79)
                                  javascript.0	2020-03-24 13:33:22.157	warn	(1038) getState "heatingcontrol.0.Profiles.1.Gaeste_WC.Thu.1.time" not found (3)
                                  javascript.0	2020-03-24 13:33:22.154	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:22.154	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:22.154	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:22.154	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:22.154	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:22.154	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:22.153	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                                  javascript.0	2020-03-24 13:33:22.153	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:17)
                                  javascript.0	2020-03-24 13:33:22.153	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                                  javascript.0	2020-03-24 13:33:22.152	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Fri.Periods.0.time" which expects a string. Please fix your code to use a string or change the state type t
                                  javascript.0	2020-03-24 13:33:22.152	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:22.152	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:22.152	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:22.152	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:22.152	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:22.151	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:22.151	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                                  javascript.0	2020-03-24 13:33:22.151	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:79)
                                  javascript.0	2020-03-24 13:33:22.150	warn	(1038) getState "heatingcontrol.0.Profiles.1.Gaeste_WC.Fri.0.time" not found (3)
                                  javascript.0	2020-03-24 13:33:22.150	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:22.149	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:22.149	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:22.149	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:22.149	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:22.149	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:22.149	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                                  javascript.0	2020-03-24 13:33:22.148	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:17)
                                  javascript.0	2020-03-24 13:33:22.148	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                                  javascript.0	2020-03-24 13:33:22.148	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Thu.Periods.0.time" which expects a string. Please fix your code to use a string or change the state type t
                                  javascript.0	2020-03-24 13:33:22.147	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:22.147	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:22.147	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:22.147	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:22.147	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:22.147	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:22.146	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:403:9)
                                  javascript.0	2020-03-24 13:33:22.146	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:79)
                                  javascript.0	2020-03-24 13:33:22.145	warn	(1038) getState "heatingcontrol.0.Profiles.1.Gaeste_WC.Thu.0.time" not found (3)
                                  javascript.0	2020-03-24 13:33:22.143	info	(1038) script.js.common.HeatingControlMapper: Reaching SetVis
                                  javascript.0	2020-03-24 13:33:20.672	info	(1038) script.js.common.HeatingControlMapper: Trigger für Raum Büro gelöscht, und für Raum Gaeste_WC gesetzt.
                                  javascript.0	2020-03-24 13:33:20.672	info	(1038) script.js.common.HeatingControlMapper: reaching CreateCurrentTimePeriodTrigger - Oldroom= Büro ChoosenRoom= Gaeste_WC
                                  javascript.0	2020-03-24 13:33:20.670	info	(1038) script.js.common.HeatingControlMapper: MinimumTemp=Null, skipping entry and showing 0
                                  javascript.0	2020-03-24 13:33:20.665	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:20.665	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:20.665	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:20.665	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:20.665	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:20.664	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:20.664	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                                  javascript.0	2020-03-24 13:33:20.664	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:17)
                                  javascript.0	2020-03-24 13:33:20.664	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                                  javascript.0	2020-03-24 13:33:20.663	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Fri.Periods.1.time" which expects a string. Please fix your code to use a string or change the state type t
                                  javascript.0	2020-03-24 13:33:20.663	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:20.663	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:20.662	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:20.662	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:20.662	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:20.662	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:20.662	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                                  javascript.0	2020-03-24 13:33:20.661	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:79)
                                  javascript.0	2020-03-24 13:33:20.660	warn	(1038) getState "heatingcontrol.0.Profiles.0.Gaeste_WC.Fri.1.time" not found (3)
                                  javascript.0	2020-03-24 13:33:20.660	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:20.660	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:20.659	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:20.659	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:20.659	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:20.659	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:20.657	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                                  javascript.0	2020-03-24 13:33:20.657	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:17)
                                  javascript.0	2020-03-24 13:33:20.657	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                                  javascript.0	2020-03-24 13:33:20.656	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Thu.Periods.1.time" which expects a string. Please fix your code to use a string or change the state type t
                                  javascript.0	2020-03-24 13:33:20.656	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:20.655	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:20.655	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:20.655	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:20.655	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:20.655	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:20.654	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                                  javascript.0	2020-03-24 13:33:20.654	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:79)
                                  javascript.0	2020-03-24 13:33:20.653	warn	(1038) getState "heatingcontrol.0.Profiles.0.Gaeste_WC.Thu.1.time" not found (3)
                                  javascript.0	2020-03-24 13:33:20.651	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:20.651	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:20.651	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:20.651	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:20.650	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:20.650	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:20.650	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                                  javascript.0	2020-03-24 13:33:20.650	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:17)
                                  javascript.0	2020-03-24 13:33:20.650	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                                  javascript.0	2020-03-24 13:33:20.649	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Fri.Periods.0.time" which expects a string. Please fix your code to use a string or change the state type t
                                  javascript.0	2020-03-24 13:33:20.649	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:20.649	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:20.649	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:20.648	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:20.648	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:20.648	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:20.648	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                                  javascript.0	2020-03-24 13:33:20.648	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:298:79)
                                  javascript.0	2020-03-24 13:33:20.647	warn	(1038) getState "heatingcontrol.0.Profiles.0.Gaeste_WC.Fri.0.time" not found (3)
                                  javascript.0	2020-03-24 13:33:20.646	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:20.646	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:20.646	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:20.646	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:20.646	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:20.645	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:20.645	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                                  javascript.0	2020-03-24 13:33:20.645	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:17)
                                  javascript.0	2020-03-24 13:33:20.645	warn	(1038) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1404:20)
                                  javascript.0	2020-03-24 13:33:20.644	warn	(1038) You are assigning a object to the state "javascript.0.vis.HeatingControl.ProfileTypes.Thu.Periods.0.time" which expects a string. Please fix your code to use a string or change the state type t
                                  javascript.0	2020-03-24 13:33:20.644	warn	(1038) at processImmediate (timers.js:658:5)
                                  javascript.0	2020-03-24 13:33:20.644	warn	(1038) at tryOnImmediate (timers.js:676:5)
                                  javascript.0	2020-03-24 13:33:20.644	warn	(1038) at runCallback (timers.js:705:18)
                                  javascript.0	2020-03-24 13:33:20.644	warn	(1038) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
                                  javascript.0	2020-03-24 13:33:20.643	warn	(1038) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
                                  javascript.0	2020-03-24 13:33:20.643	warn	(1038) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
                                  javascript.0	2020-03-24 13:33:20.643	warn	(1038) at Object.<anonymous> (script.js.common.HeatingControlMapper:410:9)
                                  javascript.0	2020-03-24 13:33:20.643	warn	(1038) at SetVis (script.js.common.HeatingControlMapper:296:79)
                                  javascript.0	2020-03-24 13:33:20.642	warn	(1038) getState "heatingcontrol.0.Profiles.0.Gaeste_WC.Thu.0.time" not found (3)
                                  javascript.0	2020-03-24 13:33:20.640	info	(1038) script.js.common.HeatingControlMapper: Reaching SetVis
                                  javascript.0	2020-03-24 13:33:17.208	info	(1038) script.js.common.HeatingControlMapper: SetTimeTempValue: heatingcontrol.0.Profiles.0.Büro.Thu.Periods.0.time set to 07:27
                                  javascript.0	2020-03-24 13:33:17.208	info	(1038) script.js.common.HeatingControlMapper: Reaching SetTimeTempValue
                                  javascript.0	2020-03-24 13:33:17.207	info	(1038) script.js.common.HeatingControlMapper: string
                                  Das Auf- und zuklappen der Cards geht auch nicht.
                                    Die Änderung auf 0.3.19 vom HeatingControl hat ja schon was geholfen, Fehler sind weniger geworden. Was übrig ist, kommt mir bekannt vor und sollte eigentlich gefixt sein, welche Version vom meinem Skript verwendest Du? Wenns nicht die 1.0.5 ist, bitte updaten und erneutes Feedback bzw. Logs.
                                    Der Fehler mit den nicht klappbaren cards, da scheinst Du nicht alleine zu sein, siehe hier und ich kann da wenig machen, das hängt mit dem MD zusammen. Vieleicht kann @Uhula da was zu sagen oder es eingrenzen, bei den meisten funktionierts ja, also müssen Du und @chhe irgendwas gemeinsam haben, evtl. is das ja auch ne Hilfestellung für @Uhula. Sollte er das hier nicht mitkriegen, schildere das Problem einfach im oben verlinkten Thread.
                                      chhe last edited by
                                      Hi @Bastelritius
                                      ich habe für den Fehler mit den nicht klappbaren Cards einen neuen Thread anglegt. Das Thema scheint etwas komplexer zu sein, dort können wir die Informationen gut bündeln.
                                      Vielleicht schilderst du dort deine Situation nochmal... Und wir hoffen dass @Uhula sich dort meldet.
                                      • Bastelritius
                                        @Pittini, so ich hatte die version 1.0.4. Mit der 1.0.5 kommen keine Warnmeldungen mehr. Super, danke für die Hilfe.
                                        Jetzt bekomme ich nur noch folgende Meldung vonm heatingcontrol in meinem Log:
                                        heatingcontrol.0	2020-03-24 14:53:51.003	warn	(11016) more then 100 cron jobs existing for this adapter, this might be a configuration error!
                                        @CHHE Ich hänge mich an deinen Thread.
                                          Ist bekannt, dazu gibts bereits ein Issue bei Git, siehe hier und ne Meldung im Thread, siehe da.
                                          • Stephan Schleich
                                            Kann es ein das der Javascript Punkt HolidayPresent für die Temperatur fehlt?
                                            1.0k
                                            template vis
                                            52
                                            443
                                            89662
