    3. Entwicklung
    4. lgtv Adapter zur Steuerung von LG WebOS SmartTVs
      sigi234 Forum Testing Most Active @dirkhe last edited by
      @dirkhe sagte in lgtv Adapter zur Steuerung von LG WebOS SmartTVs:
      Aktuell nur über meinen Account https://github.com/dirkhe/ioBroker.lgtv
      Muss erst ein Pull request stellen
      $ ./iobroker url "https://github.com/dirkhe/ioBroker.lgtv.git"
      install https://github.com/dirkhe/ioBroker.lgtv/tarball/044ccbd852bd5ea5280c59a17eb20fe3c75ccce7
      NPM version: 6.9.0
      npm install https://github.com/dirkhe/ioBroker.lgtv/tarball/044ccbd852bd5ea5280c59a17eb20fe3c75ccce7 --loglevel error (System call)
      gyp
      ERR!
       build error
      gyp
      ERR!
       stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1gyp
      ERR!
      stack
           at ChildProcess.onExit (C:\Program Files\iobroker\Test\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)gyp
      ERR!
      stack
           at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp
      ERR!
       System Windows_NT 10.0.18363
      gyp
       ERR!
      command
       "C:\\Program Files\\iobroker\\Test\\nodejs\\node.exe" "C:\\Program Files\\iobroker\\Test\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\Program Files\iobroker\Test\node_modules\authenticate-pamgyp ERR! node -v v10.16.3gyp ERR!
       node-gyp -v
       v3.8.0gyp
      ERR! not ok
      gyp
       ERR! build error
      gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1gyp ERR!
      stack
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack
      gyp
       ERR! System Windows_NT 10.0.18363gyp ERR! command "C:\\Program Files\\iobroker\\Test\\nodejs\\node.exe" "C:\\Program Files\\iobroker\\Test\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\Program Files\iobroker\Test\node_modules\bufferutilgyp ERR! node -v v10.16.3
      gyp ERR! node-gyp -v v3.8.0gyp
      ERR!
      not ok
      gyp
       ERR!
      build error
      gyp
      ERR! stack
      gyp ERR!
      stack     at ChildProcess.onExit (C:\Program Files\iobroker\Test\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
      gyp ERR!
       stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp
      ERR! System
       ERR!
       ERR!
      cwd C:\Program Files\iobroker\Test\node_modules\unix-dgram
      gyp ERR!
       node -v
       v10.16.3gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      gyp
      ERR!
      build error
      gyp
       ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1gyp ERR! stack     at ChildProcess.onExit (C:\Program Files\iobroker\Test\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)gyp
      gyp ERR! cwd C:\Program Files\iobroker\Test\node_modules\utf-8-validategyp ERR! node -v v10.16.3
      gyp ERR!
      node-gyp -v v3.8.0
      gyp
      ERR! not ok
      upload [3] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/words.js words.js application/javascript
      upload [2] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/lgtv.png lgtv.png image/png
      upload [1] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/index_m.html index_m.html text/html
      upload [0] lgtv.admin C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv/admin/index.html index.html text/html
      process exited with code 0
        dirkhe Developer last edited by
        Ich weiss nicht, ob das was mit dem adapter zu tun hat, vlt kannst du mal den originalen nochmal installieren, ob das klappt. Wenn du den adapter aber mal startest, was steht denn dann im Log als Version?
          sigi234 Forum Testing Most Active @dirkhe last edited by sigi234
          Interessant:
          lgtv.0	2020-03-12 21:18:40.973	info	(13820) Ready. Configured WebOS TV IP: 192.168.178.41
          lgtv.0	2020-03-12 21:18:40.956	info	(13820) starting. Version 1.1.6-RC01 in C:/Program Files/iobroker/Test/node_modules/iobroker.lgtv, node: v10.16.3
          host.Medion(Test)	2020-03-12 21:18:39.150	info	instance system.adapter.lgtv.0 started with pid 13820
            Dann hast du die richtige Version, was da in der Info steht ist bei Entwicklung unwichtig.
              Seraphis @dirkhe last edited by
              @dirkhe Wäre es nicht gut, dann auch noch das Intervall, in dem versucht wird die Verbindung zum TV herzustellen, anpassbar zu machen? Das liegt aktuell ja bei 8s:
              lgtv.0	2020-03-14 08:24:35.344	debug	(27131) Connecting to WebOS TV: ws://192.168.178.106:3000
              lgtv.0	2020-03-14 08:24:37.337	debug	(27131) TV is off
              lgtv.0	2020-03-14 08:24:43.353	debug	(27131) Connecting to WebOS TV: ws://192.168.178.106:3000
              lgtv.0	2020-03-14 08:24:45.345	debug	(27131) TV is off
                @SchuetzeSchulz die reconnect time ist aktuell hart auf 5 sec eingestellt. Das ist auch die Default Zeit von hobyquackers lib. Macht es Sinn die einstellbar zu machen, hattet ihr da in der Vergangenheit mal getestet?
                  SchuetzeSchulz @dirkhe last edited by
                  Hatten wir nicht getestet. Mir ist nur damals aufgefallen alles unter 5 Sekunden führt zu Problemen.
                    OK, ich habe die reconnect time jetzt mal konfigurierbar gemacht. https://github.com/dirkhe/ioBroker.lgtv
                    Könnt ihr ja mal testen. Wenn das soweit passt, würde ich einen Merge Request stellen
                      FloW da FunK @rh1212 last edited by FloW da FunK
                      @rh1212
                      Hallo rh1212 und Community!
                      Ich bin ein kompletter Neuling was ioBroker betrifft und habe es mittels der Anleitung von rh1212 soweit geschafft, dass ich über die "launch app" des LG TV Adapter, unter Erstellung der Objekte und Verwendung von Blockly, gewisse "Apps" auf meinem LG TV zum starten bringe. Wenn ich bei den erstellten Objekten in ioBroker den Button dahinter anklicke, startet auch auf meinem TV jede App die ich anklicke. In Blockly habe ich im Baustein TEXT immer den Wert eingetragen, welchen mir das Objekt Launch App als Wert angezeigt hat (z.B. für HDMI-1 -> com.webos.app.hdmi1) eingetragen.
                      Ich binde dann diese Objekte in dem iot.0 Adapter unter "Alexa-Geräte" ein. Jedoch sagt mir der Adapter, dass er manche Objekte nicht einbinden möchte (siehe Screenshot). Warum macht der Adapter das??? Gibt es da vielleicht eine andere Lösung?
                      Auch im Log kann ich keine Fehlermeldung finden.
                      Danke im Voraus für eure Hilfe 😉
                      EDIT: Ich versuche die ganzen Befehle natürlich mittels Echo-dot umzusetzen.
                        Hast du den smartname korrekt gesetzt? Passt Role und Type ?
                          FloW da FunK @dirkhe last edited by FloW da FunK
                          @dirkhe
                          Ich habe das alles so wie im Screenshot rechts oben eingegeben. Rolle ist bei allen state und Type bei allen button.
                          Was verstehst du unter Smartname? Die ID oder den Namen... entschuldige ich bin wirklich ein Noob gg versuche aber dazu zu lernen. 😉
                          Also wie beschrieben funktionieren auch alle button in ioBroker ohne Probleme, jedoch bekomme ich bei der Einbindung in iot.0 Adapter bei mehreren "App's" die im oben angeführten Screenshot angezeigte Botschaft.
                          "Gerät lgtv.0.Extras_Ordner.Netflix wurde nicht hinzugefügt.
                          EDIT: Habe jetzt ein 'Wake on lan' Script eingebaut und versucht dieses im iot.0 Adapter unter Alexa-Geräte einzubinden. Auch da bekam ich die "Botschaft", dass es nicht hinzugefügt wurde. Es liegt also glaube ich nicht am lgtv.0 Adapter, denn auch die "Wake on Lan" Funktion startet in ioBroker ganz normal. Es wird wohl am iot.0 Adapter liegen.....
                          Danke für deine Hilfe
                          Lg
                            Geh mal in der Object Ansicht auf den Bleistift. Dann unter RAW, da siehst du den smartname
                              "_id": "lgtv.0.states.power",
                              "type": "state",
                              "common": {
                                "name": "Switch TV power",
                                "role": "switch",
                                "type": "boolean",
                                "read": true,
                                "write": true,
                                "smartName": {
                                  "de": "Tv,Fernseher"
                              "native": {},
                              "acl": {
                                "object": 1636,
                                "state": 1636,
                                "owner": "system.user.admin",
                              "user": "system.user.admin",
                              "ts": 1584040988961
                              "smartName": { "de": "Tv,Fernseher" }
                              Hallo dirkhe!
                              Beim durchstöbern des Forum habe ich bemerkt, dass mehrere User seit Anfang März probleme mit der Einbindung von Geräten in iot.0 Adapter haben.
                              Siehe Link: https://forum.iobroker.net/topic/11288/cloud-adapter-smart-gerät-hinzufügen-geht-nicht/26
                              Es liegt also definitiv nicht am lgtv.0 adapter.
                                "ts": 1584970466099,
                                "common": {
                                  "name": "Amazon Prime Video",
                                  "role": "button",
                                  "type": "object",
                                  "desc": "Manuell erzeugt",
                                  "read": true,
                                  "write": true
                                  "smartName": "Amazon"
                                "native": {},
                                "acl": {
                                  "object": 1636,
                                  "state": 1636
                                "_id": "lgtv.0.Extras_Ordner.Amazon_Prime_Video",
                                "type": "state"
                              Wenn ich den Smartname im RAW zu ändern versuche und das Ganze speichere, zeigt er mir sofort eine Fehlermeldung an.Fehler beim Parsen.jpg
                              Ich werde die ganzen Einbindungen in iot.0 Adapter mit dem kleinen Workaround machen müssen, wie sie im anderen Thread beschrieben sind.
                              Vielen DANK für deine Bemühungen!!!!
                                @dirkhe
                                Problem gelöst!!!
                                Ich hab einfach den Typ von Button auf Switch geändert und siehe da! Es lässt sich in iot.0 Adapter integrieren und der Sprachbefehl via ALEXA funktioniert auch!!!
                                Nochmals DANKE für deine Bemühungen und gesund bleiben! 😉
                                  kniwweli @knx last edited by
                                  @knx hast du es hinbekommen mit netflix?
                                    killroy2 last edited by
                                    ich verwende Version 1.1.6.
                                    Wenn ich Wert false auf
                                    lgtv.0.states.power
                                    schreibe geht der Fernseher aus, soweit okay.
                                    Schreibe ich nochmal false, geht der Fernseher an. Ist das plausibel oder ein Fehler?
                                    Vielen Dank
                                      Lt Code dürfte das nicht passieren. Kannst du mal auf debug stellen und das dann hier Posten? Hast du den Haken bei schalte als Fernbedienung gesetzt?
                                        bei mir geht der garnicht an
                                          killroy2 @dirkhe last edited by
                                          @dirkhe Nein. Wenn ich "Schalten Sie den Fernseher als Ferbedienungstaste aus" aktiviere so geht turnOff und power nicht mehr. Was macht die Einstellung?
                                          Das ist das Log.
                                          Erst mache ich aus - ok - "appId":""
                                          dann nochmal aus - State change "states.power" - VALUE: false -> Sending turn OFF command to WebOS TV
                                          dann geht die Kiste an - "appId":"com.webos.app.livetv"
                                          lgtv.0	2020-06-07 10:44:22.109	debug	(14278) tv/getCurrentChannel: {"channelId":"7_22_6_6_1089_12060_1","dualChannel":{"dualChannelId":null,"dualChannelTypeName":null,"dualChannelTypeId":null,"dualChannelNumber":null},"isScrambled":false
                                          lgtv.0	2020-06-07 10:44:21.294	debug	(14278) tv/getCurrentChannel: {"channelId":"7_22_6_6_1089_12060_1","dualChannel":{"dualChannelId":null,"dualChannelTypeName":null,"dualChannelTypeId":null,"dualChannelNumber":null},"isScrambled":false
                                          lgtv.0	2020-06-07 10:44:20.692	debug	(14278) renew connection in one minute for stable subscriptions...
                                          lgtv.0	2020-06-07 10:44:20.671	debug	(14278) cur app is com.webos.app.livetv
                                          lgtv.0	2020-06-07 10:44:20.670	debug	(14278) DEBUGGING getForegroundAppInfo: {"subscribed":true,"appId":"com.webos.app.livetv","returnValue":true,"windowId":"","processId":""}
                                          lgtv.0	2020-06-07 10:44:20.066	debug	(14278) Sending turn OFF command to WebOS TV: 192.168.0.14
                                          lgtv.0	2020-06-07 10:44:20.065	debug	(14278) State change "states.power" - VALUE: false
                                          lgtv.0	2020-06-07 10:44:15.680	debug	(14278) TV is off
                                          lgtv.0	2020-06-07 10:44:14.177	debug	(14278) DEBUGGING getForegroundAppInfo: {"subscribed":true,"appId":"","returnValue":true,"windowId":"","processId":""}
                                          lgtv.0	2020-06-07 10:44:13.988	debug	(14278) Sending turn OFF command to WebOS TV: 192.168.0.14
                                          lgtv.0	2020-06-07 10:44:13.988	debug	(14278) State change "states.power" - VALUE: false
                                            Ich habe jetzt gerade mal in den code geschaut:
        case 'states.power':
        if (!state.val){
        adapter.log.debug('Sending turn OFF command to WebOS TV: ' + adapter.config.ip);
        if (adapter.config.power){
        sendCommand('button', {name: 'power'}, (err, val) => {
        if (!err) adapter.setState('states.power', state.val, true);
        } else {
        sendCommand('ssap://system/turnOff', {message: state.val}, (err, val) => {
                                            Also so wie ich den code verstehe, wird bei angehakter checkbox ein key-command zum TV geschickt, also quasi, als wenn du auf die Fernbedienung clickst. Sonst wird halt expliziet das Ausschaltkommando geschickt
                                            Was mich wundert ist, wie du den state setzt? Der reagiert nämlich nur, wenn du den ack nicht setzt. Und zumindest über die admin konsole bekomme ich das erbeute setzten, wenn der bereits auf false ist, gar nicht hin. Also ich bekomme deine Zeile 7 gar nicht reproduziert. Ich denke, es macht auch kein Sinn, abzufragen ob der TV aus ist, denn vlt. ist aus irgendeinem Grund ein Schiefstand im System, dann hätte man die Möglichkeit, darüber nochmal extra zu schalten.
                                            1.0k
                                            lgtv
                                            113
                                            861
                                            313856
