    4. Test Coronavirus Statistics for ioBroker
      crunchip Forum Testing Most Active last edited by crunchip
      Dashboard Erweiterung
      kleines update für die Täglichen Werte im Vergleich
      JSON wer will im Spoiler
       "datasource": "InfluxDB-corona",
       "aliasColors": {
         "Genesen": "dark-green",
         "Kritisch": "dark-purple",
         "Sterbefälle": "dark-red",
         "aktiv": "dark-orange",
         "infiziert": "dark-blue"
       "bars": true,
       "dashLength": 10,
       "dashes": false,
       "fill": 1,
       "fillGradient": 0,
       "gridPos": {
         "h": 6,
         "w": 11,
         "x": 13,
         "y": 25
       "hiddenSeries": false,
       "id": 27,
       "legend": {
         "avg": false,
         "current": false,
         "hideEmpty": false,
         "hideZero": false,
         "max": true,
         "min": false,
         "show": true,
         "total": false,
         "values": true
       "lines": false,
       "linewidth": 1,
       "nullPointMode": "null",
       "options": {
         "dataLinks": []
       "percentage": false,
       "pointradius": 2,
       "points": false,
       "renderer": "flot",
       "seriesOverrides": [
           "alias": "Sterbefälle",
           "zindex": 1
           "alias": "Kritisch",
           "zindex": 2
           "alias": "aktiv"
           "alias": "Genesen"
           "alias": "infiziert"
       "spaceLength": 10,
       "stack": false,
       "steppedLine": false,
       "targets": [
           "alias": "infiziert",
           "groupBy": [
               "params": [
                 "$__interval"
               "type": "time"
               "params": [
                 "null"
               "type": "fill"
           "orderByTime": "ASC",
           "policy": "default",
           "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.cases\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
           "rawQuery": true,
           "refId": "A",
           "resultFormat": "time_series",
           "select": [
                 "params": [
                   "value"
                 "type": "field"
                 "params": [],
                 "type": "mean"
           "tags": []
           "alias": "aktiv",
           "groupBy": [
               "params": [
                 "$__interval"
               "type": "time"
               "params": [
                 "null"
               "type": "fill"
           "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.active\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
           "rawQuery": true,
           "refId": "B",
           "select": [
                 "params": [
                   "value"
                 "type": "field"
                 "params": [],
                 "type": "mean"
           "tags": []
           "groupBy": [
               "params": [
                 "$__interval"
               "type": "time"
               "params": [
                 "null"
               "type": "fill"
           "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.critical\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
           "rawQuery": true,
           "refId": "D",
           "select": [
                 "params": [
                   "value"
                 "type": "field"
                 "params": [],
                 "type": "mean"
           "tags": []
           "groupBy": [
               "params": [
                 "$__interval"
               "type": "time"
               "params": [
                 "null"
               "type": "fill"
           "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.deaths\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
           "rawQuery": true,
           "refId": "C",
           "select": [
                 "params": [
                   "value"
                 "type": "field"
                 "params": [],
                 "type": "mean"
           "tags": []
           "alias": "Genesen",
           "groupBy": [
               "params": [
                 "$__interval"
               "type": "time"
               "params": [
                 "null"
               "type": "fill"
           "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.recovered\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
           "rawQuery": true,
           "refId": "E",
           "select": [
                 "params": [
                   "value"
                 "type": "field"
                 "params": [],
                 "type": "mean"
           "tags": []
       "thresholds": [],
       "timeFrom": "7d",
       "timeRegions": [],
       "timeShift": null,
       "title": "Tageswerte Global",
       "tooltip": {
         "shared": true,
         "sort": 0,
         "value_type": "individual"
       "transparent": true,
       "type": "graph",
       "xaxis": {
         "buckets": null,
         "mode": "time",
         "name": null,
         "show": true,
         "values": []
       "yaxes": [
           "format": "short",
           "label": null,
           "logBase": 2,
           "max": null,
           "min": null,
           "show": true
           "format": "short",
           "label": null,
           "logBase": 1,
           "max": null,
           "min": null,
           "show": true
       "yaxis": {
         "align": false,
         "alignLevel": null
        sigi234 Forum Testing Most Active @Dutchman last edited by
        @Dutchman
        Hallo , kannst du den DP von der flag USA noch korrigieren?
          MartyBr @sigi234 last edited by
          @sigi234
          Hallo sigi234 kannst du den view oder das Widget teilen? Es wirklich übersichtlich und informativ.
            sigi234 Forum Testing Most Active @MartyBr last edited by sigi234
            @MartyBr sagte in Test Coronavirus Statistics for ioBroker:
            @sigi234
            Arbeite noch daran, kommt bald
            [View_Corona_Top5_Sigi234.txt
            Uli977 M 2 Replies Last reply Reply Quote 1
            • Uli977
              Uli977 @sigi234 last edited by
              @sigi234 Infiziert heute ist aber noch etwas hoch, oder?
              Dutchman sigi234 2 Replies Last reply Reply Quote 0
              • Dutchman
                Dutchman Developer Most Active Administrators @Uli977 last edited by
                @Uli977 sagte in Test Coronavirus Statistics for ioBroker:
                eventuell muss man dads noch in der API abfangen das wen die werte noch von gestern sind es 0 bleibt bis die daten von. heute bekannt gemacht. wurden
                Uli977 1 Reply Last reply Reply Quote 0
                • Uli977
                  Uli977 @Dutchman last edited by Uli977
                  @Dutchman Wurden nicht heute schon 1025 gemeldet?
                  ich denke die Zuordnung passt noch nicht. Aber ist ja auch noch in arbeit.
                  • S0NIC
                    S0NIC last edited by S0NIC
                    Anhand der Zahlen und öffentlichen Informationen kann auch berechnet werden, wann in Deutschland die Beatmungsgeräte (schätzungsweise) zu 100% ausgelastet sind:
                    -> 28.000 Intensivplätze, davon 20.000 mit Beatmung
                    -> Grundauslastung der Geräte 80%
                    -> 10% der Erkrankten sind beatmungspflichtig
                    Quellen:
                    -> https://app.handelsblatt.com/politik/deutschland/coronakrise-deutsche-krankenhausgesellschaft-wir-sind-besser-vorbereitet-als-italien/25651268.html?ticket=ST-1120379-oOJuDLcMvrbi0rjdLEV0-ap5
                    -> https://www.heise.de/tp/features/Coronavirus-Warum-Herr-Wodarg-Unrecht-hat-4685718.html
                    -> https://www.aerzteblatt.de/nachrichten/111029/Ueberlastung-deutscher-Krankenhaeuser-durch-COVID-19-laut-Experten-unwahrscheinlich
                    Da die Beatmung mit einem ECMO Gerät eine sehr viel höhere Überlebenschance schafft, hat mich diese Zahl auch interessiert. Aber diese gilt leider als klassifizierte Information. Zumindest kann man sich hier selbst einen Überblick über die grundsätzliche Verfügbarkeit verschaffen: https://www.divi.de/register/intensivregister
                    Ergänzung: https://forum.iobroker.net/topic/31245/test-coronavirus-statistics-for-iobroker/378
                      sigi234 Forum Testing Most Active @Uli977 last edited by
                      Ja, Fehler korrigiert.
                      • Dutchman
                        Ich kann nur in Datenpunkte schreiben was die API hergibt, da ich keine Glaskugel hab weis ich auch nicht wie der stand ist wen die API noch nicht die neuen werte hat 🙂
                        was meinste damit ?
                        • Dutchman
                          so leute, die Bundesländer sind drin in 0.4.2 !
                          Zwar mit tage verzögert, aber ich habe noch keine bessere API gefunden
                          sigi234 B harrym 3 Replies Last reply Reply Quote 2
                            sigi234 Forum Testing Most Active @Dutchman last edited by sigi234
                            @Dutchman sagte in Test Coronavirus Statistics for ioBroker:
                            Kann man diese auch ausblenden?
                            Gibt es das auch für Austria?
                            • Dutchman
                              Dutchman Developer Most Active Administrators @sigi234 last edited by
                              @sigi234 sagte in Test Coronavirus Statistics for ioBroker:
                              siehe erweiterte Einstellungen
                              • jackblackson
                                jackblackson last edited by
                                Hab grad auf die latest aktualisiert, meine Länder (z.b. Österreich) ausgewählt, und "delete unused states" gemacht - und dann auch den Adapter neu gestartet. Nun schaut es so aus: 43625d56-1e35-4f23-a92c-72a6a6cc7068-grafik.png
                                Ist das so gewollt, das die Länder die man nicht ausgewählt hat stehen bleiben? z.B: Andora.
                                  Brati @Dutchman last edited by
                                  @Dutchman läuft, das RKI ist auch nicht schneller.
                                  Bisher sieht es ja so aus, als wenn die Neuanfälle seit Freitag nicht mehr so hoch hätte gestern (nach dem WE) deutlich mehr erwartet.
                                  Grüße Brati
                                  • Uli977
                                    Uli977 @sigi234 last edited by Uli977
                                    @sigi234
                                    Das passt auch noch nicht von der Zuordnung....
                                    1094 sind die infizierten heute
                                    130 sind Todesfälle heute.
                                    • harrym
                                      harrym @Dutchman last edited by harrym
                                      @Dutchman
                                      ist nur ein 520er Error .... eventuell "abfangen" im script?
                                        crunchip Forum Testing Most Active @jackblackson last edited by
                                        @jackblackson country info sind die Überbleibsel durch die Api Änderung von gestern, was mit dem Update behoben wurde. Jedoch bereits bestehende states bleiben blöderweise dadurch erhalten und müssen manuell gelöscht werden.
                                        Hoffe ich habs richtig erklärt @Dutchman 😊
                                        harrym Dutchman 2 Replies Last reply Reply Quote 1
                                        • harrym
                                          harrym @crunchip last edited by
                                          @crunchip haste richtig erklärt 😉
                                            @sigi234 Vielen Dank, ist eine tolle VIS.
                                            adapter installation adapterentwicklung testen
                                            120
                                            1177
                                            333753
