    4. Test Adapter mihome-vacuum v2.0.x
    • bahnuhr
      Eben hat er gesaugt.
      Und es kamen permanent die error Meldung:
      mihome-vacuum.0	2020-03-21 10:15:22.251	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:15:19.024	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:15:15.802	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:15:12.197	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:15:08.640	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:15:05.098	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:15:01.858	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:58.604	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:54.963	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:51.429	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:47.885	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:44.682	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:41.460	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:38.271	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:35.063	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:31.502	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:27.942	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:24.363	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:21.162	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:17.895	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:14.316	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:10.747	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:07.163	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:03.637	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:14:00.429	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:13:56.861	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:13:53.625	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:13:50.109	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:13:46.908	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:13:43.684	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:13:40.167	error	(5124) Error: IndexSizeError: The source width is 0.
      mihome-vacuum.0	2020-03-21 10:13:36.598	error	(5124) Error: IndexSizeError: The source width is 0.
      Kann doch nicht normal sein ?
      Oder?
      • bahnuhr
        Habe den Adapter mal neu von git gezogen.
        Und dann upload.
        Nun scheint der fehler nicht mehr zu kommen.
        Aber trotzdem scheint doch da etwas nicht zu stimmen.
        • bahnuhr
          Eben robo wieder gestartet.
          Und prompt kommt wieder der error im log.
          mihome-vacuum.0	2020-03-22 09:10:15.856	error	(1664) Error: IndexSizeError: The source width is 0.
          Bitte berichtigen.
          Danke.
          • bahnuhr
            Und wieder error:
            mihome-vacuum.0	2020-03-23 10:25:19.941	warn	(1664) Get Error when receiving mapurl:Error: connect ETIMEDOUT 120.92.65.5:443
            mihome-vacuum.0	2020-03-23 10:21:59.575	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 09:21:59 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"44cd6101-8d14-3e
            mihome-vacuum.0	2020-03-23 10:21:56.023	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 09:21:55 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"abe08064-b7e0-a3
            mihome-vacuum.0	2020-03-23 10:21:52.815	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 09:21:52 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"97cf4e84-ba26-35
            mihome-vacuum.0	2020-03-23 10:21:49.254	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 09:21:49 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"89473937-08c5-d7
            mihome-vacuum.0	2020-03-23 10:21:38.481	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 09:21:38 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"d02b56d8-6ee7-65
            mihome-vacuum.0	2020-03-23 09:51:07.176	warn	(1664) Could not receive Mappointer, giving up
            mihome-vacuum.0	2020-03-23 09:15:34.681	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 08:15:34 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"735c175f-f585-a8
            mihome-vacuum.0	2020-03-23 09:15:31.144	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 08:15:30 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"75dc4a9c-20c0-e5
            mihome-vacuum.0	2020-03-23 09:15:27.966	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 08:15:27 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"28a443a4-2154-83
            mihome-vacuum.0	2020-03-23 09:15:24.363	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 08:15:24 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"7946ac99-4478-f6
            mihome-vacuum.0	2020-03-23 09:14:33.289	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 08:14:33 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"0e4f6f1a-cd07-c3
            mihome-vacuum.0	2020-03-23 09:14:29.750	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 08:14:29 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"4d63f765-d970-11
            mihome-vacuum.0	2020-03-23 09:14:26.177	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 08:14:25 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"28a54ef9-0573-90
            mihome-vacuum.0	2020-03-23 09:14:22.315	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 08:14:22 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"fbfd3cd2-2781-3b
            mihome-vacuum.0	2020-03-23 09:14:18.809	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 08:14:18 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"9197679b-d823-ca
            mihome-vacuum.0	2020-03-23 09:14:15.549	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 08:14:15 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"235ad5f6-c257-38
            mihome-vacuum.0	2020-03-23 09:14:12.346	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 08:14:12 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"89f4b6c7-460b-af
            mihome-vacuum.0	2020-03-23 09:14:09.049	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 08:14:08 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"ffe7e6c1-4ab0-22
            mihome-vacuum.0	2020-03-23 09:14:05.520	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 08:14:05 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"13c40c7c-f84d-e9
            mihome-vacuum.0	2020-03-23 09:14:05.012	warn	(1664) Could not receive Mappointer, giving up
            mihome-vacuum.0	2020-03-23 09:14:01.994	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 08:14:01 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2269b91f-d394-ed
            mihome-vacuum.0	2020-03-23 09:13:58.787	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 08:13:58 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8aa4042f-bbc5-fc
            mihome-vacuum.0	2020-03-23 08:42:33.299	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 07:42:33 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"d55440bb-e2d0-0a
            mihome-vacuum.0	2020-03-23 08:42:30.085	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 07:42:29 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"b5319b2e-3017-80
            mihome-vacuum.0	2020-03-23 08:42:26.880	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 07:42:26 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"7cbe049b-4e43-76
            mihome-vacuum.0	2020-03-23 08:42:23.263	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 07:42:23 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"4bc6dd89-8312-4b
            mihome-vacuum.0	2020-03-23 08:42:20.033	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 07:42:19 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"399d833c-cac0-10
            mihome-vacuum.0	2020-03-23 08:42:16.465	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 07:42:16 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"d4496fc0-61e2-98
            mihome-vacuum.0	2020-03-23 08:42:13.242	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 07:42:13 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2c0bd143-04fc-4f
            mihome-vacuum.0	2020-03-23 08:42:10.018	error	(1664) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Mon, 23 Mar 2020 07:42:09 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"ffe64eec-36c6-42
            mihome-vacuum.0	2020-03-23 08:11:32.853	info	(1664) trigger cleaning all
            Muss oder kann ich was tun?
            D Meistertr 2 Replies Last reply Reply Quote 0
              csamaggi last edited by
              Erstmal danke an dieser Stelle für die Überarbeitung des Adapters.
              Endlich kann mann so den Mi1S auch per Sprachen eine Raumreinigung veranlassen und auch sich die Karte anzeigen lassen.
              Bisher muss ich sagen sind mir keine Fehler aufgefallen es läuft wie es soll.
              Version 2.0.7.
              MFG Maggi
                dirkhe Developer @bahnuhr last edited by dirkhe
                @bahnuhr sag mal, hast du den haken bei enable map from xiamoi cloud aktiviert? Du darfst immer nur einen aktivieren, das wird aktuell noch nicht abgefangen
                • bahnuhr
                  bahnuhr Forum Testing Most Active @dirkhe last edited by
                  @dirkhe sagte in Test Adapter mihome-vacuum v2.0.x:
                  Na klar hab ich den aktiviert. Da kommt die map doch auch her, oder ?
                  • Meistertr
                    Meistertr Developer @bahnuhr last edited by
                    @bahnuhr kannst du mal einen debug log posten mit dem fehler am besten von adapterstart an
                    • bahnuhr
                      bahnuhr Forum Testing Most Active @Meistertr last edited by bahnuhr
                      @Meistertr sagte in Test Adapter mihome-vacuum v2.0.x:
                      Wie erwartet 😉 ; jetzt kam nur ein kleiner Fehler.
                      mihome-vacuum.0	2020-03-23 12:56:35.711	debug	(25108) 27094
                      mihome-vacuum.0	2020-03-23 12:56:34.139	debug	(25108) update_Map got new time:1584964593
                      mihome-vacuum.0	2020-03-23 12:56:34.139	debug	(25108) update_Map got new expires:1584966399
                      mihome-vacuum.0	2020-03-23 12:56:34.139	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/17?Expires=1584966399000&GalaxyAccessKeyId=5271733786445&Signature=t2EP7FNPlPmKgnc2jlc407uJZ2E=
                      mihome-vacuum.0	2020-03-23 12:56:33.196	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:56:33.196	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F18"],"id":67}
                      mihome-vacuum.0	2020-03-23 12:56:33.190	debug	(25108) update_Map need new mapurl
                      mihome-vacuum.0	2020-03-23 12:56:33.190	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:56:33.190	debug	(25108) sendMsg[1] >>> {"id":67,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:56:31.113	debug	(25108) 26149
                      mihome-vacuum.0	2020-03-23 12:56:29.566	debug	(25108) update_Map got new time:1584964588
                      mihome-vacuum.0	2020-03-23 12:56:29.566	debug	(25108) update_Map got new expires:1584966395
                      mihome-vacuum.0	2020-03-23 12:56:29.565	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/16?Expires=1584966395000&GalaxyAccessKeyId=5271733786445&Signature=3Iqpx2YmoEn9MA3bqASRW9cgPf4=
                      mihome-vacuum.0	2020-03-23 12:56:28.803	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:56:28.803	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F17"],"id":66}
                      mihome-vacuum.0	2020-03-23 12:56:28.797	debug	(25108) update_Map need new mapurl
                      mihome-vacuum.0	2020-03-23 12:56:28.796	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:56:28.796	debug	(25108) sendMsg[1] >>> {"id":66,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:56:26.696	debug	(25108) 25622
                      mihome-vacuum.0	2020-03-23 12:56:25.466	debug	(25108) update_Map got new time:1584964584
                      mihome-vacuum.0	2020-03-23 12:56:25.466	debug	(25108) update_Map got new expires:1584966391
                      mihome-vacuum.0	2020-03-23 12:56:25.465	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/15?Expires=1584966391000&GalaxyAccessKeyId=5271733786445&Signature=XFvjvvLFtcF6P8DirOSWl2yOZnY=
                      mihome-vacuum.0	2020-03-23 12:56:24.756	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:56:24.755	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F16"],"id":65}
                      mihome-vacuum.0	2020-03-23 12:56:24.746	debug	(25108) update_Map need new mapurl
                      mihome-vacuum.0	2020-03-23 12:56:24.746	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:56:24.746	debug	(25108) sendMsg[1] >>> {"id":65,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:56:24.357	debug	(25108) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1821,"state":5,"battery":90,"clean_time":52,"clean_area":1650000,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":60,"dnd_enabled":0}],"
                      mihome-vacuum.0	2020-03-23 12:56:24.349	debug	(25108) sendMsg[1] >>> {"id":64,"method":"get_status"}
                      mihome-vacuum.0	2020-03-23 12:56:22.504	debug	(25108) 25287
                      mihome-vacuum.0	2020-03-23 12:56:21.257	debug	(25108) update_Map got new time:1584964580
                      mihome-vacuum.0	2020-03-23 12:56:21.257	debug	(25108) update_Map got new expires:1584966386
                      mihome-vacuum.0	2020-03-23 12:56:21.257	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/14?Expires=1584966386000&GalaxyAccessKeyId=5271733786445&Signature=EUwOC9FaM2PA7UdbOxIlrSFMtgM=
                      mihome-vacuum.0	2020-03-23 12:56:20.541	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:56:20.540	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F15"],"id":63}
                      mihome-vacuum.0	2020-03-23 12:56:20.523	debug	(25108) update_Map need new mapurl
                      mihome-vacuum.0	2020-03-23 12:56:20.523	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:56:20.522	debug	(25108) sendMsg[1] >>> {"id":63,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:56:18.480	debug	(25108) 25298
                      mihome-vacuum.0	2020-03-23 12:56:17.232	debug	(25108) update_Map got new time:1584964576
                      mihome-vacuum.0	2020-03-23 12:56:17.232	debug	(25108) update_Map got new expires:1584966382
                      mihome-vacuum.0	2020-03-23 12:56:17.232	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/13?Expires=1584966382000&GalaxyAccessKeyId=5271733786445&Signature=rU6CEL9ad98+soIz8aj1vIHtNI0=
                      mihome-vacuum.0	2020-03-23 12:56:16.779	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:56:16.779	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F14"],"id":62}
                      mihome-vacuum.0	2020-03-23 12:56:16.349	debug	(25108) update_Map need new mapurl
                      mihome-vacuum.0	2020-03-23 12:56:16.349	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:56:16.349	debug	(25108) sendMsg[1] >>> {"id":62,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:56:14.253	debug	(25108) 25384
                      mihome-vacuum.0	2020-03-23 12:56:12.979	debug	(25108) update_Map got new time:1584964571
                      mihome-vacuum.0	2020-03-23 12:56:12.978	debug	(25108) update_Map got new expires:1584966378
                      mihome-vacuum.0	2020-03-23 12:56:12.978	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/12?Expires=1584966378000&GalaxyAccessKeyId=5271733786445&Signature=1Dwo2TkxTrZzxbzxQZi8JcS8wLU=
                      mihome-vacuum.0	2020-03-23 12:56:11.625	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:56:11.625	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F13"],"id":61}
                      mihome-vacuum.0	2020-03-23 12:56:11.618	debug	(25108) update_Map need new mapurl
                      mihome-vacuum.0	2020-03-23 12:56:11.618	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:56:11.618	debug	(25108) sendMsg[1] >>> {"id":61,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:56:09.575	debug	(25108) 25476
                      mihome-vacuum.0	2020-03-23 12:56:08.315	debug	(25108) update_Map got new time:1584964567
                      mihome-vacuum.0	2020-03-23 12:56:08.314	debug	(25108) update_Map got new expires:1584966373
                      mihome-vacuum.0	2020-03-23 12:56:08.314	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/11?Expires=1584966373000&GalaxyAccessKeyId=5271733786445&Signature=tjYniLMErl39ZV7YoJCllXEXKzk=
                      mihome-vacuum.0	2020-03-23 12:56:07.581	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:56:07.580	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F12"],"id":60}
                      mihome-vacuum.0	2020-03-23 12:56:07.567	debug	(25108) update_Map need new mapurl
                      mihome-vacuum.0	2020-03-23 12:56:07.567	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:56:07.566	debug	(25108) sendMsg[1] >>> {"id":60,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:56:05.461	debug	(25108) 25386
                      mihome-vacuum.0	2020-03-23 12:56:04.795	debug	(25108) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1820,"state":5,"battery":90,"clean_time":41,"clean_area":1227500,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":60,"dnd_enabled":0}],"
                      mihome-vacuum.0	2020-03-23 12:56:04.789	debug	(25108) sendMsg[1] >>> {"id":59,"method":"get_status"}
                      mihome-vacuum.0	2020-03-23 12:56:04.173	debug	(25108) update_Map got new time:1584964557
                      mihome-vacuum.0	2020-03-23 12:56:04.173	debug	(25108) update_Map got new expires:1584966369
                      mihome-vacuum.0	2020-03-23 12:56:04.172	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/10?Expires=1584966369000&GalaxyAccessKeyId=5271733786445&Signature=LYQx8/knaEakQH4E6C3MOeK9yCw=
                      mihome-vacuum.0	2020-03-23 12:55:57.393	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:55:57.393	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F11"],"id":58}
                      mihome-vacuum.0	2020-03-23 12:55:57.386	debug	(25108) update_Map need new mapurl
                      mihome-vacuum.0	2020-03-23 12:55:57.386	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:55:57.386	debug	(25108) sendMsg[1] >>> {"id":58,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:55:55.342	debug	(25108) 25439
                      mihome-vacuum.0	2020-03-23 12:55:53.786	debug	(25108) update_Map got new time:1584964552
                      mihome-vacuum.0	2020-03-23 12:55:53.785	debug	(25108) update_Map got new expires:1584966359
                      mihome-vacuum.0	2020-03-23 12:55:53.785	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/9?Expires=1584966359000&GalaxyAccessKeyId=5271733786445&Signature=JFqxC7osOBZiDVhkuB4+PUvupFA=
                      mihome-vacuum.0	2020-03-23 12:55:52.599	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:55:52.591	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F10"],"id":57}
                      mihome-vacuum.0	2020-03-23 12:55:52.577	debug	(25108) update_Map need new mapurl
                      mihome-vacuum.0	2020-03-23 12:55:52.576	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:55:52.576	debug	(25108) sendMsg[1] >>> {"id":57,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:55:50.522	debug	(25108) 25577
                      mihome-vacuum.0	2020-03-23 12:55:48.933	debug	(25108) update_Map got new time:1584964548
                      mihome-vacuum.0	2020-03-23 12:55:48.932	debug	(25108) update_Map got new expires:1584966354
                      mihome-vacuum.0	2020-03-23 12:55:48.930	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/8?Expires=1584966354000&GalaxyAccessKeyId=5271733786445&Signature=jNp5BLEYGtfq+lCJI0gVV2errPE=
                      mihome-vacuum.0	2020-03-23 12:55:48.020	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:55:48.019	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F9"],"id":56}
                      mihome-vacuum.0	2020-03-23 12:55:48.013	debug	(25108) update_Map need new mapurl
                      mihome-vacuum.0	2020-03-23 12:55:48.013	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:55:48.013	debug	(25108) sendMsg[1] >>> {"id":56,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:55:45.963	debug	(25108) 25606
                      mihome-vacuum.0	2020-03-23 12:55:44.794	debug	(25108) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1819,"state":5,"battery":90,"clean_time":18,"clean_area":190000,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":60,"dnd_enabled":0}],"i
                      mihome-vacuum.0	2020-03-23 12:55:44.793	debug	(25108) Receive <<< {"partner_id":"","id":55,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.4_004007","ap":{"ssid":"Mueller","bssid":"DC:39:6F:4E:09:86","rssi":-53},"netif":{"localIp
                      mihome-vacuum.0	2020-03-23 12:55:44.787	debug	(25108) Next WiFi check: 23.03 12:56
                      mihome-vacuum.0	2020-03-23 12:55:44.786	debug	(25108) sendMsg[1] >>> {"id":55,"method":"miIO.info"}
                      mihome-vacuum.0	2020-03-23 12:55:44.786	debug	(25108) sendMsg[1] >>> {"id":54,"method":"get_status"}
                      mihome-vacuum.0	2020-03-23 12:55:44.724	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:55:44.723	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F8"],"id":53}
                      mihome-vacuum.0	2020-03-23 12:55:44.716	debug	(25108) update_Map use old mapurl
                      mihome-vacuum.0	2020-03-23 12:55:44.716	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:55:44.716	debug	(25108) sendMsg[1] >>> {"id":53,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:55:42.689	debug	(25108) 25712
                      mihome-vacuum.0	2020-03-23 12:55:40.987	debug	(25108) update_Map got new time:1584964540
                      mihome-vacuum.0	2020-03-23 12:55:40.987	debug	(25108) update_Map got new expires:1584966346
                      mihome-vacuum.0	2020-03-23 12:55:40.987	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/2?Expires=1584966346000&GalaxyAccessKeyId=5271733786445&Signature=5eXnZvps6rzehwbiYWPwaSz3uK8=
                      mihome-vacuum.0	2020-03-23 12:55:40.455	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:55:40.454	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F3"],"id":52}
                      mihome-vacuum.0	2020-03-23 12:55:40.448	debug	(25108) update_Map need new mapurl
                      mihome-vacuum.0	2020-03-23 12:55:40.447	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:55:40.447	debug	(25108) sendMsg[1] >>> {"id":52,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:55:37.165	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:55:37.165	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F2"],"id":51}
                      mihome-vacuum.0	2020-03-23 12:55:37.134	debug	(25108) update_Map use old mapurl
                      mihome-vacuum.0	2020-03-23 12:55:37.134	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:55:37.133	debug	(25108) sendMsg[1] >>> {"id":51,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:55:35.120	error	(25108) Error: IndexSizeError: The source width is 0.
                      mihome-vacuum.0	2020-03-23 12:55:33.895	debug	(25108) update_Map got new time:1584964533
                      mihome-vacuum.0	2020-03-23 12:55:33.895	debug	(25108) update_Map got new expires:1584966339
                      mihome-vacuum.0	2020-03-23 12:55:33.894	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/3?Expires=1584966339000&GalaxyAccessKeyId=5271733786445&Signature=ey30yZF12A0fddnWcBvV/vOVOxM=
                      mihome-vacuum.0	2020-03-23 12:55:33.007	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:55:33.007	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F1"],"id":50}
                      mihome-vacuum.0	2020-03-23 12:55:33.000	debug	(25108) update_Map need new mapurl
                      mihome-vacuum.0	2020-03-23 12:55:33.000	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:55:33.000	debug	(25108) sendMsg[1] >>> {"id":50,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:55:30.941	debug	(25108) 25503
                      mihome-vacuum.0	2020-03-23 12:55:30.646	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:55:30.646	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F3"],"id":49}
                      mihome-vacuum.0	2020-03-23 12:55:30.642	debug	(25108) 1. Mappointer_nomap___retry
                      mihome-vacuum.0	2020-03-23 12:55:30.641	debug	(25108) sendMsg[1] >>> {"id":49,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:55:30.140	debug	(25108) Receive <<< {"result":["retry"],"id":48}
                      mihome-vacuum.0	2020-03-23 12:55:30.135	debug	(25108) 0. Mappointer_nomap___retry
                      mihome-vacuum.0	2020-03-23 12:55:30.134	debug	(25108) sendMsg[1] >>> {"id":48,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:55:29.633	debug	(25108) Receive <<< {"result":["retry"],"id":47}
                      mihome-vacuum.0	2020-03-23 12:55:29.626	debug	(25108) update_Map use old mapurl
                      mihome-vacuum.0	2020-03-23 12:55:29.626	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:55:29.625	debug	(25108) sendMsg[1] >>> {"id":47,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:55:27.573	debug	(25108) 25503
                      mihome-vacuum.0	2020-03-23 12:55:26.335	debug	(25108) update_Map got new time:1584964524
                      mihome-vacuum.0	2020-03-23 12:55:26.335	debug	(25108) update_Map got new expires:1584966331
                      mihome-vacuum.0	2020-03-23 12:55:26.335	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/1?Expires=1584966331000&GalaxyAccessKeyId=5271733786445&Signature=848skiBJVBAd8F1A5U5DTnKCjck=
                      mihome-vacuum.0	2020-03-23 12:55:24.985	debug	(25108) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":46}
                      mihome-vacuum.0	2020-03-23 12:55:24.978	debug	(25108) sendMsg[1] >>> {"id":46,"method":"get_carpet_mode"}
                      mihome-vacuum.0	2020-03-23 12:55:24.786	debug	(25108) Receive <<< {"result":[90],"id":45}
                      mihome-vacuum.0	2020-03-23 12:55:24.777	debug	(25108) update_Map need new mapurl
                      mihome-vacuum.0	2020-03-23 12:55:24.777	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:55:24.776	debug	(25108) sendMsg[1] >>> {"id":45,"method":"get_sound_volume"}
                      mihome-vacuum.0	2020-03-23 12:55:24.776	debug	(25108) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1818,"state":5,"battery":90,"clean_time":896,"clean_area":13962500,"error_code":0,"map_present":0,"in_cleaning":1,"fan_power":60,"dnd_enabled":0}]
                      mihome-vacuum.0	2020-03-23 12:55:24.769	debug	(25108) sendMsg[1] >>> {"id":44,"method":"get_status"}
                      mihome-vacuum.0	2020-03-23 12:55:23.774	debug	(25108) stateChange mihome-vacuum.0.control.start {"val":false,"ack":false,"ts":1584964523865,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1584964523865}
                      mihome-vacuum.0	2020-03-23 12:55:22.771	debug	(25108) Receive <<< {"result":["ok"],"id":43}
                      mihome-vacuum.0	2020-03-23 12:55:22.764	debug	(25108) sendMsg[1] >>> {"id":43,"method":"app_start"}
                      mihome-vacuum.0	2020-03-23 12:55:22.763	info	(25108) trigger cleaning all
                      mihome-vacuum.0	2020-03-23 12:55:22.761	debug	(25108) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                      mihome-vacuum.0	2020-03-23 12:55:22.760	debug	(25108) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1584964522854,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1584964522854}
                      mihome-vacuum.0	2020-03-23 12:55:05.653	debug	(25108) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1816,"state":8,"battery":90,"clean_time":896,"clean_area":13962500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}]
                      mihome-vacuum.0	2020-03-23 12:55:05.646	debug	(25108) sendMsg[1] >>> {"id":42,"method":"get_status"}
                      mihome-vacuum.0	2020-03-23 12:54:48.751	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:54:48.750	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F1"],"id":41}
                      mihome-vacuum.0	2020-03-23 12:54:48.746	debug	(25108) sendMsg[1] >>> {"id":41,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:54:47.257	debug	(25108) Receive <<< {"result":[3807893,54657357500,1588,[1584959723,1584954900,1584953434,1584951226,1584950091,1584947492,1584864593,1584791981,1584781226,1584720065,1584717908,1584714391,1584698558
                      mihome-vacuum.0	2020-03-23 12:54:47.247	debug	(25108) sendMsg[1] >>> {"id":40,"method":"get_clean_summary"}
                      mihome-vacuum.0	2020-03-23 12:54:46.742	debug	(25108) Receive <<< {"result":[{"main_brush_work_time":183065,"side_brush_work_time":613021,"filter_work_time":183065,"sensor_dirty_time":79593}],"id":39}
                      mihome-vacuum.0	2020-03-23 12:54:46.737	debug	(25108) sendMsg[1] >>> {"id":39,"method":"get_consumable"}
                      mihome-vacuum.0	2020-03-23 12:54:46.735	debug	(25108) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1815,"state":8,"battery":90,"clean_time":896,"clean_area":13962500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}
                      mihome-vacuum.0	2020-03-23 12:54:45.642	debug	(25108) sendMsg[1] >>> {"id":38,"method":"get_status"}
                      mihome-vacuum.0	2020-03-23 12:54:36.714	debug	(25108) 25503
                      mihome-vacuum.0	2020-03-23 12:54:34.467	debug	(25108) update_Map got new time:1584964471
                      mihome-vacuum.0	2020-03-23 12:54:34.467	debug	(25108) update_Map got new expires:1584966279
                      mihome-vacuum.0	2020-03-23 12:54:34.467	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/0?Expires=1584966279000&GalaxyAccessKeyId=5271733786445&Signature=jz+7hQGOaYEERurJDZ2ob3fe8ag=
                      mihome-vacuum.0	2020-03-23 12:54:31.710	debug	(25108) update_Map need new mapurl
                      mihome-vacuum.0	2020-03-23 12:54:31.710	debug	(25108) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-23 12:54:31.709	debug	(25108) Mappointer_updated
                      mihome-vacuum.0	2020-03-23 12:54:31.709	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F0"],"id":37}
                      mihome-vacuum.0	2020-03-23 12:54:31.705	debug	(25108) 8. Mappointer_nomap___retry
                      mihome-vacuum.0	2020-03-23 12:54:31.704	debug	(25108) sendMsg[1] >>> {"id":37,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:54:31.188	debug	(25108) Receive <<< {"result":["retry"],"id":36}
                      mihome-vacuum.0	2020-03-23 12:54:31.182	debug	(25108) 7. Mappointer_nomap___retry
                      mihome-vacuum.0	2020-03-23 12:54:31.182	debug	(25108) sendMsg[1] >>> {"id":36,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:54:30.679	debug	(25108) Receive <<< {"result":["retry"],"id":35}
                      mihome-vacuum.0	2020-03-23 12:54:30.674	debug	(25108) CLEAN_LOGGING[{"Datum":"23.3","Start":"11:35","Saugzeit":"15 min","Fläche":"13.96 m²","Error":0,"Ende":true},{"Datum":"23.3","Start":"10:15","Saugzeit":"14 min","Fläche":"7.8 m²","Error":0,"E
                      mihome-vacuum.0	2020-03-23 12:54:30.673	debug	(25108) 6. Mappointer_nomap___retry
                      mihome-vacuum.0	2020-03-23 12:54:30.672	debug	(25108) sendMsg[1] >>> {"id":35,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:54:30.470	debug	(25108) Receive <<< {"result":[[1584432079,1584435588,3509,54180000,0,1]],"id":34}
                      mihome-vacuum.0	2020-03-23 12:54:30.463	debug	(25108) sendMsg[1] >>> {"id":34,"method":"get_clean_record","params":[1584432079]}
                      mihome-vacuum.0	2020-03-23 12:54:30.269	debug	(25108) Receive <<< {"result":[[1584435782,1584435979,197,1927500,0,1]],"id":33}
                      mihome-vacuum.0	2020-03-23 12:54:30.261	debug	(25108) sendMsg[1] >>> {"id":33,"method":"get_clean_record","params":[1584435782]}
                      mihome-vacuum.0	2020-03-23 12:54:30.160	debug	(25108) Receive <<< {"result":["retry"],"id":32}
                      mihome-vacuum.0	2020-03-23 12:54:30.154	debug	(25108) 5. Mappointer_nomap___retry
                      mihome-vacuum.0	2020-03-23 12:54:30.153	debug	(25108) sendMsg[1] >>> {"id":32,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:54:30.058	debug	(25108) Receive <<< {"result":[[1584437279,1584438376,1097,9885000,0,1]],"id":31}
                      mihome-vacuum.0	2020-03-23 12:54:30.047	debug	(25108) sendMsg[1] >>> {"id":31,"method":"get_clean_record","params":[1584437279]}
                      mihome-vacuum.0	2020-03-23 12:54:29.844	debug	(25108) Receive <<< {"result":[[1584440510,1584441254,744,9045000,0,1]],"id":30}
                      mihome-vacuum.0	2020-03-23 12:54:29.836	debug	(25108) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1584440510]}
                      mihome-vacuum.0	2020-03-23 12:54:29.676	debug	(25108) Receive <<< {"result":[[1584522471,1584526290,3819,56207500,0,1]],"id":29}
                      mihome-vacuum.0	2020-03-23 12:54:29.645	debug	(25108) Receive <<< {"result":["retry"],"id":28}
                      mihome-vacuum.0	2020-03-23 12:54:29.636	debug	(25108) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1584522471]}
                      mihome-vacuum.0	2020-03-23 12:54:29.480	debug	(25108) 4. Mappointer_nomap___retry
                      mihome-vacuum.0	2020-03-23 12:54:29.479	debug	(25108) sendMsg[1] >>> {"id":28,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:54:29.443	debug	(25108) Receive <<< {"result":[[1584607817,1584611387,3570,53177500,0,1]],"id":27}
                      mihome-vacuum.0	2020-03-23 12:54:29.434	debug	(25108) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1584607817]}
                      mihome-vacuum.0	2020-03-23 12:54:29.407	debug	(25108) Xiaomi Cloud: Login successful
                      mihome-vacuum.0	2020-03-23 12:54:29.239	debug	(25108) Receive <<< {"result":[[1584696124,1584698496,2372,37152500,0,1]],"id":26}
                      mihome-vacuum.0	2020-03-23 12:54:29.233	debug	(25108) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1584696124]}
                      mihome-vacuum.0	2020-03-23 12:54:29.046	debug	(25108) Receive <<< {"result":[[1584698558,1584698607,2,0,0,0]],"id":25}
                      mihome-vacuum.0	2020-03-23 12:54:29.032	debug	(25108) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1584698558]}
                      mihome-vacuum.0	2020-03-23 12:54:28.978	debug	(25108) Receive <<< {"result":["retry"],"id":24}
                      mihome-vacuum.0	2020-03-23 12:54:28.972	debug	(25108) 3. Mappointer_nomap___retry
                      mihome-vacuum.0	2020-03-23 12:54:28.972	debug	(25108) sendMsg[1] >>> {"id":24,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:54:28.836	debug	(25108) Receive <<< {"result":[[1584714391,1584716484,2093,29517500,0,1]],"id":23}
                      mihome-vacuum.0	2020-03-23 12:54:28.828	debug	(25108) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1584714391]}
                      mihome-vacuum.0	2020-03-23 12:54:28.631	debug	(25108) Receive <<< {"result":[[1584717908,1584718769,861,7745000,0,1]],"id":22}
                      mihome-vacuum.0	2020-03-23 12:54:28.626	debug	(25108) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1584717908]}
                      mihome-vacuum.0	2020-03-23 12:54:28.470	debug	(25108) Receive <<< {"result":["retry"],"id":21}
                      mihome-vacuum.0	2020-03-23 12:54:28.465	debug	(25108) 2. Mappointer_nomap___retry
                      mihome-vacuum.0	2020-03-23 12:54:28.465	debug	(25108) sendMsg[1] >>> {"id":21,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:54:28.429	debug	(25108) Receive <<< {"result":[[1584720065,1584720067,2,0,0,0]],"id":20}
                      mihome-vacuum.0	2020-03-23 12:54:28.424	debug	(25108) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1584720065]}
                      mihome-vacuum.0	2020-03-23 12:54:28.229	debug	(25108) Receive <<< {"result":[[1584781226,1584784989,3763,54167500,0,1]],"id":19}
                      mihome-vacuum.0	2020-03-23 12:54:28.222	debug	(25108) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1584781226]}
                      mihome-vacuum.0	2020-03-23 12:54:27.972	debug	(25108) Receive <<< {"result":[[1584791981,1584793011,960,11062500,0,0]],"id":18}
                      mihome-vacuum.0	2020-03-23 12:54:27.964	debug	(25108) Receive <<< {"result":["retry"],"id":17}
                      mihome-vacuum.0	2020-03-23 12:54:27.964	debug	(25108) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1584791981]}
                      mihome-vacuum.0	2020-03-23 12:54:27.957	debug	(25108) 1. Mappointer_nomap___retry
                      mihome-vacuum.0	2020-03-23 12:54:27.957	debug	(25108) sendMsg[1] >>> {"id":17,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:54:27.770	debug	(25108) Receive <<< {"result":[[1584864593,1584868121,3528,54155000,0,1]],"id":16}
                      mihome-vacuum.0	2020-03-23 12:54:27.764	debug	(25108) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1584864593]}
                      mihome-vacuum.0	2020-03-23 12:54:27.569	debug	(25108) Receive <<< {"result":[[1584947492,1584949533,2041,27837500,0,1]],"id":15}
                      mihome-vacuum.0	2020-03-23 12:54:27.562	debug	(25108) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1584947492]}
                      mihome-vacuum.0	2020-03-23 12:54:27.457	debug	(25108) Receive <<< {"result":["retry"],"id":14}
                      mihome-vacuum.0	2020-03-23 12:54:27.451	debug	(25108) 0. Mappointer_nomap___retry
                      mihome-vacuum.0	2020-03-23 12:54:27.451	debug	(25108) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:54:27.367	debug	(25108) Receive <<< {"result":[[1584950091,1584950616,525,4770000,0,1]],"id":13}
                      mihome-vacuum.0	2020-03-23 12:54:27.361	debug	(25108) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1584950091]}
                      mihome-vacuum.0	2020-03-23 12:54:27.167	debug	(25108) Receive <<< {"result":[[1584951226,1584952166,940,10002500,0,1]],"id":12}
                      mihome-vacuum.0	2020-03-23 12:54:27.160	debug	(25108) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1584951226]}
                      mihome-vacuum.0	2020-03-23 12:54:26.966	debug	(25108) Receive <<< {"result":[[1584953434,1584954052,618,9067500,0,1]],"id":11}
                      mihome-vacuum.0	2020-03-23 12:54:26.958	debug	(25108) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1584953434]}
                      mihome-vacuum.0	2020-03-23 12:54:26.950	debug	(25108) Receive <<< {"result":["retry"],"id":10}
                      mihome-vacuum.0	2020-03-23 12:54:26.944	debug	(25108) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-23 12:54:26.763	debug	(25108) Receive <<< {"result":[[1584954900,1584955757,857,7797500,0,1]],"id":9}
                      mihome-vacuum.0	2020-03-23 12:54:26.757	debug	(25108) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1584954900]}
                      mihome-vacuum.0	2020-03-23 12:54:26.752	debug	(25108) Receive <<< {"result":"unknown_method","id":8}
                      mihome-vacuum.0	2020-03-23 12:54:26.751	info	(25108) create state for carpet_mode
                      mihome-vacuum.0	2020-03-23 12:54:26.751	debug	(25108) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":7}
                      mihome-vacuum.0	2020-03-23 12:54:26.745	debug	(25108) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
                      mihome-vacuum.0	2020-03-23 12:54:26.744	debug	(25108) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
                      mihome-vacuum.0	2020-03-23 12:54:26.563	debug	(25108) Receive <<< {"result":[[1584959723,1584960619,896,13962500,0,1]],"id":6}
                      mihome-vacuum.0	2020-03-23 12:54:26.556	debug	(25108) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1584959723]}
                      mihome-vacuum.0	2020-03-23 12:54:26.555	debug	(25108) Receive <<< {"result":[3807893,54657357500,1588,[1584959723,1584954900,1584953434,1584951226,1584950091,1584947492,1584864593,1584791981,1584781226,1584720065,1584717908,1584714391,1584698558
                      mihome-vacuum.0	2020-03-23 12:54:26.544	debug	(25108) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
                      mihome-vacuum.0	2020-03-23 12:54:26.351	debug	(25108) Receive <<< {"result":[{"main_brush_work_time":183065,"side_brush_work_time":613021,"filter_work_time":183065,"sensor_dirty_time":79593}],"id":4}
                      mihome-vacuum.0	2020-03-23 12:54:26.344	debug	(25108) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
                      mihome-vacuum.0	2020-03-23 12:54:26.176	info	(25108) set nächster Timer: Nicht verfügbar
                      mihome-vacuum.0	2020-03-23 12:54:26.153	debug	(25108) Receive <<< {"result":[90],"id":3}
                      mihome-vacuum.0	2020-03-23 12:54:26.146	debug	(25108) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
                      mihome-vacuum.0	2020-03-23 12:54:25.951	debug	(25108) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.4_004007","ap":{"ssid":"Mueller","bssid":"DC:39:6F:4E:09:86","rssi":-53},"netif":{"localIp
                      mihome-vacuum.0	2020-03-23 12:54:25.946	debug	(25108) Next WiFi check: 23.03 12:55
                      mihome-vacuum.0	2020-03-23 12:54:25.945	debug	(25108) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
                      mihome-vacuum.0	2020-03-23 12:54:25.744	info	(25108) Connected
                      mihome-vacuum.0	2020-03-23 12:54:25.741	debug	(25108) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                      mihome-vacuum.0	2020-03-23 12:54:25.740	debug	(25108) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1814,"state":8,"battery":90,"clean_time":896,"clean_area":13962500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}
                      mihome-vacuum.0	2020-03-23 12:54:25.732	debug	(25108) sendMsg[1] >>> {"id":1,"method":"get_status"}
                      mihome-vacuum.0	2020-03-23 12:54:25.690	debug	(25108) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                      mihome-vacuum.0	2020-03-23 12:54:25.690	info	(25108) connecting, this can take up to 10 minutes ...
                      mihome-vacuum.0	2020-03-23 12:54:25.689	warn	(25108) Time difference between Mihome Vacuum and ioBroker: 3 sec
                      mihome-vacuum.0	2020-03-23 12:54:25.689	debug	(25108) Receive <<< Helo <<< 2131002000000000034caaab5e78a374ffffffffffffffffffffffffffffffff
                      mihome-vacuum.0	2020-03-23 12:54:25.669	info	(25108) New generation or new fw(3.5.4,004007) detected, create new states goto and zoneclean
                      mihome-vacuum.0	2020-03-23 12:54:25.646	debug	(25108) server started on 0.0.0.0:53421
                      mihome-vacuum.0	2020-03-23 12:54:25.637	info	(25108) Cloud control disabled
                      mihome-vacuum.0	2020-03-23 12:54:25.636	info	(25108) Expert mode disabled, states deleted
                      mihome-vacuum.0	2020-03-23 12:54:25.631	debug	(25108) Xiaomi Cloud: Logging in
                      mihome-vacuum.0	2020-03-23 12:54:25.630	debug	(25108) load Map creator... true
                      mihome-vacuum.0	2020-03-23 12:54:25.195	info	(25108) starting. Version 2.0.9-RC07 in C:/ioBroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
                        root_ last edited by
                        Hatte den IndexSizeError auch. Bei mir ist auch die Xiaomi cloud map aktiv.
                          Hyperbit last edited by
                          Meister ich Gratuiliere!
                          ich bin gerade von Valetudo auf Valetudo RE umgestiegen. Hier hat der Mapper nicht mehr funktioniert und somit hatte ich im IO Broker keine Karte.
                          Ich habe es einfach nicht hinbekommen, das der VALETUDO-Mapper (von ValetudoRE) trotz gefüllten MQTT Topic ein Bild generierte.
                          Und da entdecke ich deine 2.0.x Version des mihome-vacuum adapter.
                          Ich bin verliebt!! Einfach Token und IP rein und gut ist. Schon habe ich die Karten ohne extra Valetudo-Mapper!!
                          DU BIST DER BESTE!
                          • V
                            Vocaris @dirkhe last edited by
                            @dirkhe Hei, welche Readme?
                            Habe das gleiche Problem.
                            Inder Adapterinfo steht folgendes:
                            Error at installation
                            if your installation runs in error. The canvas package could not be install
                            npm ERR! canvas@2.6.1 install: node-pre-gyp install --fallback-to-build npm ERR! Exit status 1
                            Please install canvas and the libs manually with:
                            sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
                            sudo npm install canvas --unsafe-perm=true
                            Wenn ich aber auf der Konsole den ersten Befehl ausführe kommt:
                            s müssen 19,1 MB an Archiven heruntergeladen werden.
                            Nach dieser Operation werden 69,7 MB Plattenplatz zusätzlich benutzt.
                            Möchten Sie fortfahren? [J/n]
                            Egal ob ich J oder j drücke. Danach komtm immer Abbruch und ich stehe wieder im Prompt.
                              arteck Developer Most Active @Vocaris last edited by
                              @Vocaris dann drück y
                              • bahnuhr
                                Heute wieder ein paar errors.
                                Vielleicht hilfts bei der Analyse.
                                mihome-vacuum.0	2020-03-25 10:26:38.115	warn	(34164) Could not receive Mappointer, giving up
                                mihome-vacuum.0	2020-03-25 10:26:31.710	info	(34164) Connected
                                mihome-vacuum.0	2020-03-25 10:26:31.683	info	(34164) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-03-25 10:26:31.682	warn	(34164) Time difference between Mihome Vacuum and ioBroker: 33 sec
                                mihome-vacuum.0	2020-03-25 10:26:31.673	info	(34164) Disconnected due last Restponse of 10:24:13.434
                                mihome-vacuum.0	2020-03-25 10:25:07.843	warn	(34164) no answer received after after 3 times -> pause miIO.info try again in one hour
                                mihome-vacuum.0	2020-03-25 09:37:29.006	warn	(34164) Could not receive Mappointer, giving up
                                mihome-vacuum.0	2020-03-25 09:37:22.687	info	(34164) Connected
                                mihome-vacuum.0	2020-03-25 09:37:22.679	info	(34164) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-03-25 09:37:22.678	warn	(34164) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                mihome-vacuum.0	2020-03-25 09:37:22.641	info	(34164) Disconnected due last Restponse of 09:35:04.852
                                mihome-vacuum.0	2020-03-25 09:36:18.221	warn	(34164) no answer received after after 3 times -> pause miIO.info try again in one hour
                                mihome-vacuum.0	2020-03-25 09:27:49.636	info	(34164) Connected
                                mihome-vacuum.0	2020-03-25 09:27:49.193	info	(34164) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-03-25 09:27:49.193	warn	(34164) Time difference between Mihome Vacuum and ioBroker: 33 sec
                                mihome-vacuum.0	2020-03-25 09:27:49.190	info	(34164) Disconnected due last Restponse of 09:25:30.115
                                mihome-vacuum.0	2020-03-25 09:20:47.531	warn	(34164) no answer received after after 3 times -> pause miIO.info try again in one hour
                                mihome-vacuum.0	2020-03-25 09:10:22.253	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:10:44 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"590c9079-d95c-f
                                mihome-vacuum.0	2020-03-25 09:10:15.076	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:10:37 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"38fed30a-d23f-9
                                mihome-vacuum.0	2020-03-25 09:09:08.793	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:09:30 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"db9d3cf8-fc19-0
                                mihome-vacuum.0	2020-03-25 09:09:01.969	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:09:23 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"994e4c75-c90d-5
                                mihome-vacuum.0	2020-03-25 09:06:24.493	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:44 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"963ada9d-8c92-f
                                mihome-vacuum.0	2020-03-25 09:06:17.722	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:37 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2bae5056-c3b3-3
                                mihome-vacuum.0	2020-03-25 09:06:14.200	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:33 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"5e1f15e8-bddf-3
                                mihome-vacuum.0	2020-03-25 09:06:11.005	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:30 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"21973af7-c50d-0
                                mihome-vacuum.0	2020-03-25 09:06:07.798	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:27 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"d0f1ec26-f964-b
                                mihome-vacuum.0	2020-03-25 09:06:04.588	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:24 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"78388881-77c9-0
                                mihome-vacuum.0	2020-03-25 09:06:01.042	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:20 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"9fabd49b-2b3c-b
                                mihome-vacuum.0	2020-03-25 09:05:57.851	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:17 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"65f480c9-d31f-6
                                mihome-vacuum.0	2020-03-25 09:05:54.638	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:14 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"41196374-457c-6
                                mihome-vacuum.0	2020-03-25 09:05:51.065	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:10 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"3655b6ed-b2ba-3
                                mihome-vacuum.0	2020-03-25 09:05:47.757	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:07 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"dc6eb8cc-798c-1
                                mihome-vacuum.0	2020-03-25 09:05:44.195	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:03 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"ba9f3cbc-142f-2
                                mihome-vacuum.0	2020-03-25 09:05:40.636	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:00 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8664a1e0-34c4-1
                                mihome-vacuum.0	2020-03-25 09:05:37.442	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:05:57 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"306e88a7-6192-1
                                mihome-vacuum.0	2020-03-25 09:04:28.968	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:04:47 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"0204c5b0-06f9-c
                                mihome-vacuum.0	2020-03-25 09:04:25.391	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:04:43 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"eb24cacf-6a57-a
                                mihome-vacuum.0	2020-03-25 09:04:22.135	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:04:40 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f3d100dc-4f57-d
                                mihome-vacuum.0	2020-03-25 09:04:18.818	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:04:37 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"b98c0d3a-9aec-c
                                mihome-vacuum.0	2020-03-25 09:04:15.622	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:04:33 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"36f1185c-d96c-6
                                mihome-vacuum.0	2020-03-25 09:04:12.277	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:04:30 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"45674737-ff41-d
                                mihome-vacuum.0	2020-03-25 09:04:08.713	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:04:27 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"4bae4140-2f0d-a
                                mihome-vacuum.0	2020-03-25 09:03:02.574	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:03:20 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2481a7b3-3e7b-b
                                mihome-vacuum.0	2020-03-25 09:02:59.140	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:03:16 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"98e81887-04e2-0
                                mihome-vacuum.0	2020-03-25 09:02:55.557	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:03:13 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"a5d832bf-c2f6-e
                                mihome-vacuum.0	2020-03-25 08:46:11.816	info	(34164) trigger cleaning all
                                mihome-vacuum.0	2020-03-25 08:37:47.405	error	(34164) Error: connect ETIMEDOUT 47.74.174.56:443
                                mihome-vacuum.0	2020-03-25 08:37:04.636	info	(34164) Connected
                                mihome-vacuum.0	2020-03-25 08:37:04.627	info	(34164) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-03-25 08:37:04.627	warn	(34164) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                mihome-vacuum.0	2020-03-25 08:37:04.623	info	(34164) Disconnected due last Restponse of 08:35:00.812
                                mihome-vacuum.0	2020-03-25 08:36:00.291	warn	(34164) no answer received after after 3 times -> pause miIO.info try again in one hour
                                mihome-vacuum.0	2020-03-25 08:35:02.024	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:35:39 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"4bc70e3d-cac8-9
                                mihome-vacuum.0	2020-03-25 08:33:42.848	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:34:19 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"309925a6-965c-9
                                mihome-vacuum.0	2020-03-25 08:33:39.288	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:34:16 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"6b93c8bf-81ec-d
                                mihome-vacuum.0	2020-03-25 08:33:36.102	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:34:13 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"fa26c485-08a3-6
                                mihome-vacuum.0	2020-03-25 08:33:32.908	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:34:10 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2a967c41-854b-5
                                mihome-vacuum.0	2020-03-25 08:33:29.688	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:34:06 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"1fdeadb5-8064-8
                                mihome-vacuum.0	2020-03-25 08:33:26.377	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:34:03 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"84bfba44-eb98-7
                                mihome-vacuum.0	2020-03-25 08:33:23.157	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:34:00 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8b4d4804-9e0b-c
                                mihome-vacuum.0	2020-03-25 08:33:19.919	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:57 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"6276bae3-07c3-3
                                mihome-vacuum.0	2020-03-25 08:33:16.670	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:53 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"94b2a90b-62a7-2
                                mihome-vacuum.0	2020-03-25 08:33:13.445	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:50 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"aa5fdc8f-ebea-3
                                mihome-vacuum.0	2020-03-25 08:33:09.762	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:46 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"40ba9e50-dd3e-9
                                mihome-vacuum.0	2020-03-25 08:33:06.508	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:43 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"d0f24378-1c70-b
                                mihome-vacuum.0	2020-03-25 08:33:02.954	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:40 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"662842d1-5071-3
                                mihome-vacuum.0	2020-03-25 08:33:00.377	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:36 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"768c3a81-f5e1-6
                                mihome-vacuum.0	2020-03-25 08:32:56.820	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:33 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"1e198f0c-d506-5
                                mihome-vacuum.0	2020-03-25 08:32:52.791	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:29 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"027b29e8-1098-1
                                mihome-vacuum.0	2020-03-25 08:31:48.106	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:32:23 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"d3343497-8d0e-3
                                mihome-vacuum.0	2020-03-25 08:31:44.558	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:32:20 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"a8dc487f-37b9-5
                                mihome-vacuum.0	2020-03-25 08:31:37.349	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:32:13 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"ef543389-c089-b
                                mihome-vacuum.0	2020-03-25 08:26:12.269	info	(34164) Connected
                                mihome-vacuum.0	2020-03-25 08:26:12.260	info	(34164) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-03-25 08:26:12.260	warn	(34164) Time difference between Mihome Vacuum and ioBroker: 33 sec
                                mihome-vacuum.0	2020-03-25 08:26:12.255	info	(34164) Disconnected due last Restponse of 08:24:03.128
                                mihome-vacuum.0	2020-03-25 08:25:07.806	warn	(34164) no answer received after after 3 times -> pause miIO.info try again in one hour
                                mihome-vacuum.0	2020-03-25 08:17:55.983	info	(34164) trigger cleaning all
                                mihome-vacuum.0	2020-03-25 08:01:51.888	error	(34164) Error: IndexSizeError: The source width is 0.
                                mihome-vacuum.0	2020-03-25 08:01:32.411	info	(34164) trigger cleaning all
                                mihome-vacuum.0	2020-03-25 07:37:49.522	warn	(34164) Could not receive Mappointer, giving up
                                mihome-vacuum.0	2020-03-25 07:37:43.170	info	(34164) Connected
                                mihome-vacuum.0	2020-03-25 07:37:43.162	info	(34164) connecting, this can take up to 10 minutes ...
                                mihome-vacuum.0	2020-03-25 07:37:43.162	warn	(34164) Time difference between Mihome Vacuum and ioBroker: 1 sec
                                mihome-vacuum.0	2020-03-25 07:37:43.158	info	(34164) Disconnected due last Restponse of 07:35:26.448
                                mihome-vacuum.0	2020-03-25 07:36:38.883	warn	(34164) no answer received after after 3 times -> pause miIO.info try again in one hour
                                mfg
                                Dieter
                                K Meistertr 2 Replies Last reply Reply Quote 0
                                  K_o_bold @bahnuhr last edited by K_o_bold
                                  @bahnuhr , @dirkhe , @Meistertr ,
                                  den gleichen Error habe ich auch immer wieder. --> no map found
                                  • Meistertr
                                    @bahnuhr in der version von git gibt es die fehler nciht mehr
                                    • bahnuhr
                                      habe von git installiert.
                                      Ist aber immer noch die 2.0.9
                                      richtig?
                                        schdief last edited by
                                        Hi, ich habe gerade meinen Xiaomi mit Valetudo geflasht und versuche die Karte in mein Vis einzubinden. Lieder kriege ich nur eine Fehlermeldung:
                                        mihome-vacuum.0	2020-03-26 16:43:51.868	warn	(20737) Could not receive Mappointer, giving up
                                        Die states unter .map bleiben auch alle leer. Was mache ich hier falsch?
                                        Danke!
                                          Kueppert last edited by
                                          Hi zusammen,
                                          ich hatte gerade nachdem mein Saugi fertig war mit saugen, eine 100% CPU-Auslastung. Ich hatte folgendes im Log:
                                          host.ioBroker2	2020-03-27 12:22:38.108	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
                                          host.ioBroker2	2020-03-27 12:22:38.108	info	instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                                          host.ioBroker2	2020-03-27 12:22:38.107	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                                          host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[13]: 17: 0x1de16585a2e1
                                          host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[13]: 16: 0x9193fb [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[12]: 15: 0x9c4c33 node::StringBytes::Write(v8::Isolate*, char*, unsigned long, v8::Local<v8::Value>, node::encoding, int*) [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[11]: 14: 0xb2a2a1 v8::String::Value::Value(v8::Isolate*, v8::Local<v8::Value>) [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[10]: 13: 0xafd334 v8::internal::String::Flatten(v8::internal::Handle<v8::internal::String>, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[9]: 12: 0x101ce9d v8::internal::String::SlowFlatten(v8::internal::Handle<v8::internal::ConsString>, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[8]: 11: 0xed342a v8::internal::Factory::NewRawOneByteString(int, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[7]: 10: 0xecbbb5 [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[6]: 9: 0xf038d1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[5]: 8: 0xf00c64 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[4]: 7: 0xf00332 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[3]: 6: 0xef4258 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[2]: 5: 0xef4152 [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 4: 0xafff44 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 3: 0xaffd0e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 2: 0x8f9d5c [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 1: 0x8f9d10 node::Abort() [io.mihome-vacuum.0]
                                          host.ioBroker2	2020-03-27 12:22:38.105	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                                          Ist das erste Mal aufgetreten heute O.o
                                          D H 2 Replies Last reply Reply Quote 0
                                            dirkhe Developer @Kueppert last edited by
                                            @Kueppert könntest du noch ein bisschen mehr Log Posten, bevor das passiert ist?
                                            K 2 Replies Last reply Reply Quote 0
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            493922
