    4. JavaScript
    5. Fenster Script: Liste der offenen Fenster
      HeliosFan @v522533 last edited by
      @v522533
      https://forum.iobroker.net/topic/27743/offene-fenster-in-telegram-e-mail-iqontrol-vis
        paul53 @v522533 last edited by paul53
        @v522533 sagte:
        Auflistung, welche Fenster offen sind.
        Versuche es mal so:
        function countOpenWindowsDoors() {
            var openWindows = 0;
            var openDoors = 0;
            var listWindows = [];
            var listDoors = [];
            // Fenster
            var windows = getObject("enum.functions.windowstatus").common.members;
            for(let i = 0; i < windows.length; i++) {
                var Status = getState(windows[i]).val;
                if ( Status ) {
                    openWindows++;
                    listWindows.push(getObject(windows[i]).common.name);
            // Türen
            var doors = getObject("enum.functions.doorstatus").common.members;
            for(let i = 0; i < doors.length; i++) {
                var Status = getState(doors[i]).val;
                if ( Status ) {
                    openDoors++;
                    listDoors.push(getObject(doors[i]).common.name);
            var openWindowsText = "Kein Fenster geöffnet";
            var openDoorsText = "Keine Tür geöffnet";
            if(listWindows.length) openWindowsText = 'Offene Fenster: ' + listWindows.join(', ');
            if(listDoors.length) openDoorsText = 'Offene Türen: ' + listDoors.join(', ');
            setState('Datenpunkte.0.StatusWindowOpenText', openWindowsText, true);
            setState('Datenpunkte.0.StatusDoorOpenText', openDoorsText, true);
            setState('Datenpunkte.0.StatusWindowOpen', openWindows, true );
            setState('Datenpunkte.0.StatusDoorOpen', openDoors, true );
        $('state(functions=windowstatus)').on(function(obj) {
            countOpenWindowsDoors();
        $('state(functions=doorstatus)').on(function(obj) {
        v522533 2 Replies Last reply Reply Quote 0
        • v522533
          v522533 @paul53 last edited by v522533
          danke wird heute abend direkt getestet
          • v522533
            funktioniert leider nicht:
            javascript.0	2020-03-25 17:27:26.985	error	(19305) at processImmediate (timers.js:658:5)
            javascript.0	2020-03-25 17:27:26.985	error	(19305) at tryOnImmediate (timers.js:676:5)
            javascript.0	2020-03-25 17:27:26.985	error	(19305) at runCallback (timers.js:705:18)
            javascript.0	2020-03-25 17:27:26.985	error	(19305) at Immediate.setImmediate (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4851:37)
            javascript.0	2020-03-25 17:27:26.985	error	(19305) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:439:25)
            javascript.0	2020-03-25 17:27:26.984	error	(19305) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1101:38)
            javascript.0	2020-03-25 17:27:26.984	error	(19305) at Object.<anonymous> (script.js.common.Sonstiges.Fenster:37:5)
            javascript.0	2020-03-25 17:27:26.984	error	(19305) at countOpenWindowsDoors (script.js.common.Sonstiges.Fenster:13:58)
            javascript.0	2020-03-25 17:27:26.984	error	(19305) Error in callback: TypeError: Cannot read property 'name' of undefined
              @v522533 sagte:
              Sorry, mein Fehler: Klammer falsch gesetzt. Richtig:
              und
              v522533 1 Reply Last reply Reply Quote 0
              • v522533
                jetzt gehts vielen dank. Eine letzte Frage: Ist es möglich aus der erzeugten liste bestimmte Worte auszublenden. Speziell geht es darum, dass die Zigbee Sensoren automatisch zum Datenpunkt immer "is open" dazu schreiben. Das würde ich gerne weg haben.
                  @v522533 sagte:
                  Die Namen kann man im Tab "Objekte" editieren.
                  • v522533
                    ja aber jedes mal wenn der wert geändert wird, wird wieder mit "is open" überschrieben
                      @v522533 sagte:
                      Bei Wertänderung ? Das kann nicht sein.
                      • v522533
                        doch auf 2 systemen mehrmals versucht.
                          @v522533 sagte:
                          Wie sehen die Namen jetzt aus (habe kein Zigbee) ?
                          • v522533
                            möchtest du mal mit anydesk schauen?
                              @v522533 sagte:
                              Poste hier einen Screen shot (Tab "Objekte").
                              • v522533
                                  @v522533
                                  Ersetze Zeile 13 durch
                                              let id = windows[i].substring(0, windows[i].lastIndexOf('.')); // Device ID
                                              listWindows.push(getObject(id).common.name); // Device Name
                                  Analog für die Türen (Zeile 24).
                                  • v522533
                                    geht fast. jetzt is das "is open" weg, allerdings sagt er mir dass mein fenster offen is wenn ich die tür auf mache. funktion ist aber richtig zugeordnet. so sieht mein script jetzut aus:
                                        var openDoors = 0;
                                        var listDoors = [];
                                        // Fenster
                                            if ( Status ) {
                                                openWindows++;
                                        // Türen
                                            if ( Status ) {
                                                openDoors++;
                                                listDoors.push(getObject(id).common.name); // Device Name
                                        setState('javascript.0.StatusWindowOpenText', openWindowsText, true);
                                        setState('javascript.0.StatusDoorOpenText', openDoorsText, true);
                                        setState('javascript.0.StatusWindowOpen', openWindows, true );
                                        setState('javascript.0.StatusDoorOpen', openDoors, true );
                                      @v522533 sagte:
                                      Zeile 24 richtig:
                                                  let id = doors[i].substring(0, doors[i].lastIndexOf('.')); // Device ID
                                      v522533 1 Reply Last reply Reply Quote 1
                                      • v522533
                                        perfekt. vielen vielen dank
                                          Hansi1234 last edited by Hansi1234
                                          Hi @v522533 und @paul53
                                          Bin zufällig auf diesen Beitrag gestoßen und wollte eben das gleiche machen. Allerdings erhalte ich diesen Fehler. Die Adapter habe ich bereits neu gestartet.
                                          javascript.0	2020-03-26 11:17:40.773	info	(2684) script.js.Visualisierung.StatusTuerFenster: registered 18 subscriptions and 3 schedules
                                          javascript.0	2020-03-26 11:17:40.772	warn	(2684) at script.js.Visualisierung.StatusTuerFenster:93:1
                                          javascript.0	2020-03-26 11:17:40.772	warn	(2684) at countOpenWindowsDoors (script.js.Visualisierung.StatusTuerFenster:71:5)
                                          javascript.0	2020-03-26 11:17:40.772	warn	(2684) at setState (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.javascript\lib\sandbox.js:1404:20)
                                          javascript.0	2020-03-26 11:17:40.772	warn	(2684) State "javascript.0.StatusDoorOpen" not found
                                          javascript.0	2020-03-26 11:17:40.771	warn	(2684) at countOpenWindowsDoors (script.js.Visualisierung.StatusTuerFenster:69:5)
                                          javascript.0	2020-03-26 11:17:40.771	warn	(2684) at setState (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.javascript\lib\sandbox.js:1404:20)
                                          javascript.0	2020-03-26 11:17:40.771	warn	(2684) State "javascript.0.StatusWindowOpen" not found
                                          javascript.0	2020-03-26 11:17:40.771	warn	(2684) at script.js.Visualisierung.StatusTuerFenster:93:1
                                          javascript.0	2020-03-26 11:17:40.771	warn	(2684) at countOpenWindowsDoors (script.js.Visualisierung.StatusTuerFenster:67:5)
                                          javascript.0	2020-03-26 11:17:40.770	warn	(2684) at setState (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.javascript\lib\sandbox.js:1404:20)
                                          javascript.0	2020-03-26 11:17:40.770	warn	(2684) State "javascript.0.StatusDoorOpenText" not found
                                          javascript.0	2020-03-26 11:17:40.770	warn	(2684) at script.js.Visualisierung.StatusTuerFenster:93:1
                                          javascript.0	2020-03-26 11:17:40.770	warn	(2684) at countOpenWindowsDoors (script.js.Visualisierung.StatusTuerFenster:65:5)
                                          javascript.0	2020-03-26 11:17:40.769	warn	(2684) at setState (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.javascript\lib\sandbox.js:1404:20)
                                          javascript.0	2020-03-26 11:17:40.768	warn	(2684) State "javascript.0.StatusWindowOpenText" not found
                                          javascript.0	2020-03-26 11:17:40.285	info	(2684) Start javascript script.js.Visualisierung.StatusTuerFenster
                                            paul53 @Hansi1234 last edited by paul53
                                            @Hansi1234 sagte:
                                            Sagt das nicht genug aus ?
                                            Wieso hat das Script mind. 93 Zeilen ?
                                            56
                                            5960
