    4. Test Adapter mihome-vacuum v2.0.x
    • Meistertr
      Meistertr Developer @bahnuhr last edited by
      @bahnuhr kannst du mal einen debug log posten mit dem fehler am besten von adapterstart an
      • bahnuhr
        bahnuhr Forum Testing Most Active @Meistertr last edited by bahnuhr
        @Meistertr sagte in Test Adapter mihome-vacuum v2.0.x:
        Wie erwartet 😉 ; jetzt kam nur ein kleiner Fehler.
        mihome-vacuum.0	2020-03-23 12:56:35.711	debug	(25108) 27094
        mihome-vacuum.0	2020-03-23 12:56:34.139	debug	(25108) update_Map got new time:1584964593
        mihome-vacuum.0	2020-03-23 12:56:34.139	debug	(25108) update_Map got new expires:1584966399
        mihome-vacuum.0	2020-03-23 12:56:34.139	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/17?Expires=1584966399000&GalaxyAccessKeyId=5271733786445&Signature=t2EP7FNPlPmKgnc2jlc407uJZ2E=
        mihome-vacuum.0	2020-03-23 12:56:33.196	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:56:33.196	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F18"],"id":67}
        mihome-vacuum.0	2020-03-23 12:56:33.190	debug	(25108) update_Map need new mapurl
        mihome-vacuum.0	2020-03-23 12:56:33.190	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:56:33.190	debug	(25108) sendMsg[1] >>> {"id":67,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:56:31.113	debug	(25108) 26149
        mihome-vacuum.0	2020-03-23 12:56:29.566	debug	(25108) update_Map got new time:1584964588
        mihome-vacuum.0	2020-03-23 12:56:29.566	debug	(25108) update_Map got new expires:1584966395
        mihome-vacuum.0	2020-03-23 12:56:29.565	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/16?Expires=1584966395000&GalaxyAccessKeyId=5271733786445&Signature=3Iqpx2YmoEn9MA3bqASRW9cgPf4=
        mihome-vacuum.0	2020-03-23 12:56:28.803	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:56:28.803	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F17"],"id":66}
        mihome-vacuum.0	2020-03-23 12:56:28.797	debug	(25108) update_Map need new mapurl
        mihome-vacuum.0	2020-03-23 12:56:28.796	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:56:28.796	debug	(25108) sendMsg[1] >>> {"id":66,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:56:26.696	debug	(25108) 25622
        mihome-vacuum.0	2020-03-23 12:56:25.466	debug	(25108) update_Map got new time:1584964584
        mihome-vacuum.0	2020-03-23 12:56:25.466	debug	(25108) update_Map got new expires:1584966391
        mihome-vacuum.0	2020-03-23 12:56:25.465	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/15?Expires=1584966391000&GalaxyAccessKeyId=5271733786445&Signature=XFvjvvLFtcF6P8DirOSWl2yOZnY=
        mihome-vacuum.0	2020-03-23 12:56:24.756	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:56:24.755	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F16"],"id":65}
        mihome-vacuum.0	2020-03-23 12:56:24.746	debug	(25108) update_Map need new mapurl
        mihome-vacuum.0	2020-03-23 12:56:24.746	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:56:24.746	debug	(25108) sendMsg[1] >>> {"id":65,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:56:24.357	debug	(25108) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1821,"state":5,"battery":90,"clean_time":52,"clean_area":1650000,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":60,"dnd_enabled":0}],"
        mihome-vacuum.0	2020-03-23 12:56:24.349	debug	(25108) sendMsg[1] >>> {"id":64,"method":"get_status"}
        mihome-vacuum.0	2020-03-23 12:56:22.504	debug	(25108) 25287
        mihome-vacuum.0	2020-03-23 12:56:21.257	debug	(25108) update_Map got new time:1584964580
        mihome-vacuum.0	2020-03-23 12:56:21.257	debug	(25108) update_Map got new expires:1584966386
        mihome-vacuum.0	2020-03-23 12:56:21.257	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/14?Expires=1584966386000&GalaxyAccessKeyId=5271733786445&Signature=EUwOC9FaM2PA7UdbOxIlrSFMtgM=
        mihome-vacuum.0	2020-03-23 12:56:20.541	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:56:20.540	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F15"],"id":63}
        mihome-vacuum.0	2020-03-23 12:56:20.523	debug	(25108) update_Map need new mapurl
        mihome-vacuum.0	2020-03-23 12:56:20.523	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:56:20.522	debug	(25108) sendMsg[1] >>> {"id":63,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:56:18.480	debug	(25108) 25298
        mihome-vacuum.0	2020-03-23 12:56:17.232	debug	(25108) update_Map got new time:1584964576
        mihome-vacuum.0	2020-03-23 12:56:17.232	debug	(25108) update_Map got new expires:1584966382
        mihome-vacuum.0	2020-03-23 12:56:17.232	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/13?Expires=1584966382000&GalaxyAccessKeyId=5271733786445&Signature=rU6CEL9ad98+soIz8aj1vIHtNI0=
        mihome-vacuum.0	2020-03-23 12:56:16.779	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:56:16.779	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F14"],"id":62}
        mihome-vacuum.0	2020-03-23 12:56:16.349	debug	(25108) update_Map need new mapurl
        mihome-vacuum.0	2020-03-23 12:56:16.349	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:56:16.349	debug	(25108) sendMsg[1] >>> {"id":62,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:56:14.253	debug	(25108) 25384
        mihome-vacuum.0	2020-03-23 12:56:12.979	debug	(25108) update_Map got new time:1584964571
        mihome-vacuum.0	2020-03-23 12:56:12.978	debug	(25108) update_Map got new expires:1584966378
        mihome-vacuum.0	2020-03-23 12:56:12.978	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/12?Expires=1584966378000&GalaxyAccessKeyId=5271733786445&Signature=1Dwo2TkxTrZzxbzxQZi8JcS8wLU=
        mihome-vacuum.0	2020-03-23 12:56:11.625	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:56:11.625	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F13"],"id":61}
        mihome-vacuum.0	2020-03-23 12:56:11.618	debug	(25108) update_Map need new mapurl
        mihome-vacuum.0	2020-03-23 12:56:11.618	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:56:11.618	debug	(25108) sendMsg[1] >>> {"id":61,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:56:09.575	debug	(25108) 25476
        mihome-vacuum.0	2020-03-23 12:56:08.315	debug	(25108) update_Map got new time:1584964567
        mihome-vacuum.0	2020-03-23 12:56:08.314	debug	(25108) update_Map got new expires:1584966373
        mihome-vacuum.0	2020-03-23 12:56:08.314	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/11?Expires=1584966373000&GalaxyAccessKeyId=5271733786445&Signature=tjYniLMErl39ZV7YoJCllXEXKzk=
        mihome-vacuum.0	2020-03-23 12:56:07.581	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:56:07.580	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F12"],"id":60}
        mihome-vacuum.0	2020-03-23 12:56:07.567	debug	(25108) update_Map need new mapurl
        mihome-vacuum.0	2020-03-23 12:56:07.567	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:56:07.566	debug	(25108) sendMsg[1] >>> {"id":60,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:56:05.461	debug	(25108) 25386
        mihome-vacuum.0	2020-03-23 12:56:04.795	debug	(25108) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1820,"state":5,"battery":90,"clean_time":41,"clean_area":1227500,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":60,"dnd_enabled":0}],"
        mihome-vacuum.0	2020-03-23 12:56:04.789	debug	(25108) sendMsg[1] >>> {"id":59,"method":"get_status"}
        mihome-vacuum.0	2020-03-23 12:56:04.173	debug	(25108) update_Map got new time:1584964557
        mihome-vacuum.0	2020-03-23 12:56:04.173	debug	(25108) update_Map got new expires:1584966369
        mihome-vacuum.0	2020-03-23 12:56:04.172	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/10?Expires=1584966369000&GalaxyAccessKeyId=5271733786445&Signature=LYQx8/knaEakQH4E6C3MOeK9yCw=
        mihome-vacuum.0	2020-03-23 12:55:57.393	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:55:57.393	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F11"],"id":58}
        mihome-vacuum.0	2020-03-23 12:55:57.386	debug	(25108) update_Map need new mapurl
        mihome-vacuum.0	2020-03-23 12:55:57.386	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:55:57.386	debug	(25108) sendMsg[1] >>> {"id":58,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:55:55.342	debug	(25108) 25439
        mihome-vacuum.0	2020-03-23 12:55:53.786	debug	(25108) update_Map got new time:1584964552
        mihome-vacuum.0	2020-03-23 12:55:53.785	debug	(25108) update_Map got new expires:1584966359
        mihome-vacuum.0	2020-03-23 12:55:53.785	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/9?Expires=1584966359000&GalaxyAccessKeyId=5271733786445&Signature=JFqxC7osOBZiDVhkuB4+PUvupFA=
        mihome-vacuum.0	2020-03-23 12:55:52.599	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:55:52.591	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F10"],"id":57}
        mihome-vacuum.0	2020-03-23 12:55:52.577	debug	(25108) update_Map need new mapurl
        mihome-vacuum.0	2020-03-23 12:55:52.576	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:55:52.576	debug	(25108) sendMsg[1] >>> {"id":57,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:55:50.522	debug	(25108) 25577
        mihome-vacuum.0	2020-03-23 12:55:48.933	debug	(25108) update_Map got new time:1584964548
        mihome-vacuum.0	2020-03-23 12:55:48.932	debug	(25108) update_Map got new expires:1584966354
        mihome-vacuum.0	2020-03-23 12:55:48.930	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/8?Expires=1584966354000&GalaxyAccessKeyId=5271733786445&Signature=jNp5BLEYGtfq+lCJI0gVV2errPE=
        mihome-vacuum.0	2020-03-23 12:55:48.020	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:55:48.019	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F9"],"id":56}
        mihome-vacuum.0	2020-03-23 12:55:48.013	debug	(25108) update_Map need new mapurl
        mihome-vacuum.0	2020-03-23 12:55:48.013	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:55:48.013	debug	(25108) sendMsg[1] >>> {"id":56,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:55:45.963	debug	(25108) 25606
        mihome-vacuum.0	2020-03-23 12:55:44.794	debug	(25108) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1819,"state":5,"battery":90,"clean_time":18,"clean_area":190000,"error_code":0,"map_present":1,"in_cleaning":1,"fan_power":60,"dnd_enabled":0}],"i
        mihome-vacuum.0	2020-03-23 12:55:44.793	debug	(25108) Receive <<< {"partner_id":"","id":55,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.4_004007","ap":{"ssid":"Mueller","bssid":"DC:39:6F:4E:09:86","rssi":-53},"netif":{"localIp
        mihome-vacuum.0	2020-03-23 12:55:44.787	debug	(25108) Next WiFi check: 23.03 12:56
        mihome-vacuum.0	2020-03-23 12:55:44.786	debug	(25108) sendMsg[1] >>> {"id":55,"method":"miIO.info"}
        mihome-vacuum.0	2020-03-23 12:55:44.786	debug	(25108) sendMsg[1] >>> {"id":54,"method":"get_status"}
        mihome-vacuum.0	2020-03-23 12:55:44.724	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:55:44.723	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F8"],"id":53}
        mihome-vacuum.0	2020-03-23 12:55:44.716	debug	(25108) update_Map use old mapurl
        mihome-vacuum.0	2020-03-23 12:55:44.716	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:55:44.716	debug	(25108) sendMsg[1] >>> {"id":53,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:55:42.689	debug	(25108) 25712
        mihome-vacuum.0	2020-03-23 12:55:40.987	debug	(25108) update_Map got new time:1584964540
        mihome-vacuum.0	2020-03-23 12:55:40.987	debug	(25108) update_Map got new expires:1584966346
        mihome-vacuum.0	2020-03-23 12:55:40.987	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/2?Expires=1584966346000&GalaxyAccessKeyId=5271733786445&Signature=5eXnZvps6rzehwbiYWPwaSz3uK8=
        mihome-vacuum.0	2020-03-23 12:55:40.455	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:55:40.454	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F3"],"id":52}
        mihome-vacuum.0	2020-03-23 12:55:40.448	debug	(25108) update_Map need new mapurl
        mihome-vacuum.0	2020-03-23 12:55:40.447	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:55:40.447	debug	(25108) sendMsg[1] >>> {"id":52,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:55:37.165	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:55:37.165	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F2"],"id":51}
        mihome-vacuum.0	2020-03-23 12:55:37.134	debug	(25108) update_Map use old mapurl
        mihome-vacuum.0	2020-03-23 12:55:37.134	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:55:37.133	debug	(25108) sendMsg[1] >>> {"id":51,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:55:35.120	error	(25108) Error: IndexSizeError: The source width is 0.
        mihome-vacuum.0	2020-03-23 12:55:33.895	debug	(25108) update_Map got new time:1584964533
        mihome-vacuum.0	2020-03-23 12:55:33.895	debug	(25108) update_Map got new expires:1584966339
        mihome-vacuum.0	2020-03-23 12:55:33.894	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/3?Expires=1584966339000&GalaxyAccessKeyId=5271733786445&Signature=ey30yZF12A0fddnWcBvV/vOVOxM=
        mihome-vacuum.0	2020-03-23 12:55:33.007	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:55:33.007	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F1"],"id":50}
        mihome-vacuum.0	2020-03-23 12:55:33.000	debug	(25108) update_Map need new mapurl
        mihome-vacuum.0	2020-03-23 12:55:33.000	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:55:33.000	debug	(25108) sendMsg[1] >>> {"id":50,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:55:30.941	debug	(25108) 25503
        mihome-vacuum.0	2020-03-23 12:55:30.646	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:55:30.646	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F3"],"id":49}
        mihome-vacuum.0	2020-03-23 12:55:30.642	debug	(25108) 1. Mappointer_nomap___retry
        mihome-vacuum.0	2020-03-23 12:55:30.641	debug	(25108) sendMsg[1] >>> {"id":49,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:55:30.140	debug	(25108) Receive <<< {"result":["retry"],"id":48}
        mihome-vacuum.0	2020-03-23 12:55:30.135	debug	(25108) 0. Mappointer_nomap___retry
        mihome-vacuum.0	2020-03-23 12:55:30.134	debug	(25108) sendMsg[1] >>> {"id":48,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:55:29.633	debug	(25108) Receive <<< {"result":["retry"],"id":47}
        mihome-vacuum.0	2020-03-23 12:55:29.626	debug	(25108) update_Map use old mapurl
        mihome-vacuum.0	2020-03-23 12:55:29.626	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:55:29.625	debug	(25108) sendMsg[1] >>> {"id":47,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:55:27.573	debug	(25108) 25503
        mihome-vacuum.0	2020-03-23 12:55:26.335	debug	(25108) update_Map got new time:1584964524
        mihome-vacuum.0	2020-03-23 12:55:26.335	debug	(25108) update_Map got new expires:1584966331
        mihome-vacuum.0	2020-03-23 12:55:26.335	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/1?Expires=1584966331000&GalaxyAccessKeyId=5271733786445&Signature=848skiBJVBAd8F1A5U5DTnKCjck=
        mihome-vacuum.0	2020-03-23 12:55:24.985	debug	(25108) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":46}
        mihome-vacuum.0	2020-03-23 12:55:24.978	debug	(25108) sendMsg[1] >>> {"id":46,"method":"get_carpet_mode"}
        mihome-vacuum.0	2020-03-23 12:55:24.786	debug	(25108) Receive <<< {"result":[90],"id":45}
        mihome-vacuum.0	2020-03-23 12:55:24.777	debug	(25108) update_Map need new mapurl
        mihome-vacuum.0	2020-03-23 12:55:24.777	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:55:24.776	debug	(25108) sendMsg[1] >>> {"id":45,"method":"get_sound_volume"}
        mihome-vacuum.0	2020-03-23 12:55:24.776	debug	(25108) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1818,"state":5,"battery":90,"clean_time":896,"clean_area":13962500,"error_code":0,"map_present":0,"in_cleaning":1,"fan_power":60,"dnd_enabled":0}]
        mihome-vacuum.0	2020-03-23 12:55:24.769	debug	(25108) sendMsg[1] >>> {"id":44,"method":"get_status"}
        mihome-vacuum.0	2020-03-23 12:55:23.774	debug	(25108) stateChange mihome-vacuum.0.control.start {"val":false,"ack":false,"ts":1584964523865,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1584964523865}
        mihome-vacuum.0	2020-03-23 12:55:22.771	debug	(25108) Receive <<< {"result":["ok"],"id":43}
        mihome-vacuum.0	2020-03-23 12:55:22.764	debug	(25108) sendMsg[1] >>> {"id":43,"method":"app_start"}
        mihome-vacuum.0	2020-03-23 12:55:22.763	info	(25108) trigger cleaning all
        mihome-vacuum.0	2020-03-23 12:55:22.761	debug	(25108) sendTo "startVacuuming" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-03-23 12:55:22.760	debug	(25108) stateChange mihome-vacuum.0.control.start {"val":true,"ack":false,"ts":1584964522854,"q":0,"from":"system.adapter.web.0","user":"system.user.admin","lc":1584964522854}
        mihome-vacuum.0	2020-03-23 12:55:05.653	debug	(25108) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1816,"state":8,"battery":90,"clean_time":896,"clean_area":13962500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}]
        mihome-vacuum.0	2020-03-23 12:55:05.646	debug	(25108) sendMsg[1] >>> {"id":42,"method":"get_status"}
        mihome-vacuum.0	2020-03-23 12:54:48.751	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:54:48.750	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F1"],"id":41}
        mihome-vacuum.0	2020-03-23 12:54:48.746	debug	(25108) sendMsg[1] >>> {"id":41,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:54:47.257	debug	(25108) Receive <<< {"result":[3807893,54657357500,1588,[1584959723,1584954900,1584953434,1584951226,1584950091,1584947492,1584864593,1584791981,1584781226,1584720065,1584717908,1584714391,1584698558
        mihome-vacuum.0	2020-03-23 12:54:47.247	debug	(25108) sendMsg[1] >>> {"id":40,"method":"get_clean_summary"}
        mihome-vacuum.0	2020-03-23 12:54:46.742	debug	(25108) Receive <<< {"result":[{"main_brush_work_time":183065,"side_brush_work_time":613021,"filter_work_time":183065,"sensor_dirty_time":79593}],"id":39}
        mihome-vacuum.0	2020-03-23 12:54:46.737	debug	(25108) sendMsg[1] >>> {"id":39,"method":"get_consumable"}
        mihome-vacuum.0	2020-03-23 12:54:46.735	debug	(25108) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1815,"state":8,"battery":90,"clean_time":896,"clean_area":13962500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}
        mihome-vacuum.0	2020-03-23 12:54:45.642	debug	(25108) sendMsg[1] >>> {"id":38,"method":"get_status"}
        mihome-vacuum.0	2020-03-23 12:54:36.714	debug	(25108) 25503
        mihome-vacuum.0	2020-03-23 12:54:34.467	debug	(25108) update_Map got new time:1584964471
        mihome-vacuum.0	2020-03-23 12:54:34.467	debug	(25108) update_Map got new expires:1584966279
        mihome-vacuum.0	2020-03-23 12:54:34.467	debug	(25108) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/55356075/0?Expires=1584966279000&GalaxyAccessKeyId=5271733786445&Signature=jz+7hQGOaYEERurJDZ2ob3fe8ag=
        mihome-vacuum.0	2020-03-23 12:54:31.710	debug	(25108) update_Map need new mapurl
        mihome-vacuum.0	2020-03-23 12:54:31.710	debug	(25108) update_Map Mimap enabled
        mihome-vacuum.0	2020-03-23 12:54:31.709	debug	(25108) Mappointer_updated
        mihome-vacuum.0	2020-03-23 12:54:31.709	debug	(25108) Receive <<< {"result":["roboroommap%2F55356075%2F0"],"id":37}
        mihome-vacuum.0	2020-03-23 12:54:31.705	debug	(25108) 8. Mappointer_nomap___retry
        mihome-vacuum.0	2020-03-23 12:54:31.704	debug	(25108) sendMsg[1] >>> {"id":37,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:54:31.188	debug	(25108) Receive <<< {"result":["retry"],"id":36}
        mihome-vacuum.0	2020-03-23 12:54:31.182	debug	(25108) 7. Mappointer_nomap___retry
        mihome-vacuum.0	2020-03-23 12:54:31.182	debug	(25108) sendMsg[1] >>> {"id":36,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:54:30.679	debug	(25108) Receive <<< {"result":["retry"],"id":35}
        mihome-vacuum.0	2020-03-23 12:54:30.674	debug	(25108) CLEAN_LOGGING[{"Datum":"23.3","Start":"11:35","Saugzeit":"15 min","Fläche":"13.96 m²","Error":0,"Ende":true},{"Datum":"23.3","Start":"10:15","Saugzeit":"14 min","Fläche":"7.8 m²","Error":0,"E
        mihome-vacuum.0	2020-03-23 12:54:30.673	debug	(25108) 6. Mappointer_nomap___retry
        mihome-vacuum.0	2020-03-23 12:54:30.672	debug	(25108) sendMsg[1] >>> {"id":35,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:54:30.470	debug	(25108) Receive <<< {"result":[[1584432079,1584435588,3509,54180000,0,1]],"id":34}
        mihome-vacuum.0	2020-03-23 12:54:30.463	debug	(25108) sendMsg[1] >>> {"id":34,"method":"get_clean_record","params":[1584432079]}
        mihome-vacuum.0	2020-03-23 12:54:30.269	debug	(25108) Receive <<< {"result":[[1584435782,1584435979,197,1927500,0,1]],"id":33}
        mihome-vacuum.0	2020-03-23 12:54:30.261	debug	(25108) sendMsg[1] >>> {"id":33,"method":"get_clean_record","params":[1584435782]}
        mihome-vacuum.0	2020-03-23 12:54:30.160	debug	(25108) Receive <<< {"result":["retry"],"id":32}
        mihome-vacuum.0	2020-03-23 12:54:30.154	debug	(25108) 5. Mappointer_nomap___retry
        mihome-vacuum.0	2020-03-23 12:54:30.153	debug	(25108) sendMsg[1] >>> {"id":32,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:54:30.058	debug	(25108) Receive <<< {"result":[[1584437279,1584438376,1097,9885000,0,1]],"id":31}
        mihome-vacuum.0	2020-03-23 12:54:30.047	debug	(25108) sendMsg[1] >>> {"id":31,"method":"get_clean_record","params":[1584437279]}
        mihome-vacuum.0	2020-03-23 12:54:29.844	debug	(25108) Receive <<< {"result":[[1584440510,1584441254,744,9045000,0,1]],"id":30}
        mihome-vacuum.0	2020-03-23 12:54:29.836	debug	(25108) sendMsg[1] >>> {"id":30,"method":"get_clean_record","params":[1584440510]}
        mihome-vacuum.0	2020-03-23 12:54:29.676	debug	(25108) Receive <<< {"result":[[1584522471,1584526290,3819,56207500,0,1]],"id":29}
        mihome-vacuum.0	2020-03-23 12:54:29.645	debug	(25108) Receive <<< {"result":["retry"],"id":28}
        mihome-vacuum.0	2020-03-23 12:54:29.636	debug	(25108) sendMsg[1] >>> {"id":29,"method":"get_clean_record","params":[1584522471]}
        mihome-vacuum.0	2020-03-23 12:54:29.480	debug	(25108) 4. Mappointer_nomap___retry
        mihome-vacuum.0	2020-03-23 12:54:29.479	debug	(25108) sendMsg[1] >>> {"id":28,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:54:29.443	debug	(25108) Receive <<< {"result":[[1584607817,1584611387,3570,53177500,0,1]],"id":27}
        mihome-vacuum.0	2020-03-23 12:54:29.434	debug	(25108) sendMsg[1] >>> {"id":27,"method":"get_clean_record","params":[1584607817]}
        mihome-vacuum.0	2020-03-23 12:54:29.407	debug	(25108) Xiaomi Cloud: Login successful
        mihome-vacuum.0	2020-03-23 12:54:29.239	debug	(25108) Receive <<< {"result":[[1584696124,1584698496,2372,37152500,0,1]],"id":26}
        mihome-vacuum.0	2020-03-23 12:54:29.233	debug	(25108) sendMsg[1] >>> {"id":26,"method":"get_clean_record","params":[1584696124]}
        mihome-vacuum.0	2020-03-23 12:54:29.046	debug	(25108) Receive <<< {"result":[[1584698558,1584698607,2,0,0,0]],"id":25}
        mihome-vacuum.0	2020-03-23 12:54:29.032	debug	(25108) sendMsg[1] >>> {"id":25,"method":"get_clean_record","params":[1584698558]}
        mihome-vacuum.0	2020-03-23 12:54:28.978	debug	(25108) Receive <<< {"result":["retry"],"id":24}
        mihome-vacuum.0	2020-03-23 12:54:28.972	debug	(25108) 3. Mappointer_nomap___retry
        mihome-vacuum.0	2020-03-23 12:54:28.972	debug	(25108) sendMsg[1] >>> {"id":24,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:54:28.836	debug	(25108) Receive <<< {"result":[[1584714391,1584716484,2093,29517500,0,1]],"id":23}
        mihome-vacuum.0	2020-03-23 12:54:28.828	debug	(25108) sendMsg[1] >>> {"id":23,"method":"get_clean_record","params":[1584714391]}
        mihome-vacuum.0	2020-03-23 12:54:28.631	debug	(25108) Receive <<< {"result":[[1584717908,1584718769,861,7745000,0,1]],"id":22}
        mihome-vacuum.0	2020-03-23 12:54:28.626	debug	(25108) sendMsg[1] >>> {"id":22,"method":"get_clean_record","params":[1584717908]}
        mihome-vacuum.0	2020-03-23 12:54:28.470	debug	(25108) Receive <<< {"result":["retry"],"id":21}
        mihome-vacuum.0	2020-03-23 12:54:28.465	debug	(25108) 2. Mappointer_nomap___retry
        mihome-vacuum.0	2020-03-23 12:54:28.465	debug	(25108) sendMsg[1] >>> {"id":21,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:54:28.429	debug	(25108) Receive <<< {"result":[[1584720065,1584720067,2,0,0,0]],"id":20}
        mihome-vacuum.0	2020-03-23 12:54:28.424	debug	(25108) sendMsg[1] >>> {"id":20,"method":"get_clean_record","params":[1584720065]}
        mihome-vacuum.0	2020-03-23 12:54:28.229	debug	(25108) Receive <<< {"result":[[1584781226,1584784989,3763,54167500,0,1]],"id":19}
        mihome-vacuum.0	2020-03-23 12:54:28.222	debug	(25108) sendMsg[1] >>> {"id":19,"method":"get_clean_record","params":[1584781226]}
        mihome-vacuum.0	2020-03-23 12:54:27.972	debug	(25108) Receive <<< {"result":[[1584791981,1584793011,960,11062500,0,0]],"id":18}
        mihome-vacuum.0	2020-03-23 12:54:27.964	debug	(25108) Receive <<< {"result":["retry"],"id":17}
        mihome-vacuum.0	2020-03-23 12:54:27.964	debug	(25108) sendMsg[1] >>> {"id":18,"method":"get_clean_record","params":[1584791981]}
        mihome-vacuum.0	2020-03-23 12:54:27.957	debug	(25108) 1. Mappointer_nomap___retry
        mihome-vacuum.0	2020-03-23 12:54:27.957	debug	(25108) sendMsg[1] >>> {"id":17,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:54:27.770	debug	(25108) Receive <<< {"result":[[1584864593,1584868121,3528,54155000,0,1]],"id":16}
        mihome-vacuum.0	2020-03-23 12:54:27.764	debug	(25108) sendMsg[1] >>> {"id":16,"method":"get_clean_record","params":[1584864593]}
        mihome-vacuum.0	2020-03-23 12:54:27.569	debug	(25108) Receive <<< {"result":[[1584947492,1584949533,2041,27837500,0,1]],"id":15}
        mihome-vacuum.0	2020-03-23 12:54:27.562	debug	(25108) sendMsg[1] >>> {"id":15,"method":"get_clean_record","params":[1584947492]}
        mihome-vacuum.0	2020-03-23 12:54:27.457	debug	(25108) Receive <<< {"result":["retry"],"id":14}
        mihome-vacuum.0	2020-03-23 12:54:27.451	debug	(25108) 0. Mappointer_nomap___retry
        mihome-vacuum.0	2020-03-23 12:54:27.451	debug	(25108) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:54:27.367	debug	(25108) Receive <<< {"result":[[1584950091,1584950616,525,4770000,0,1]],"id":13}
        mihome-vacuum.0	2020-03-23 12:54:27.361	debug	(25108) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1584950091]}
        mihome-vacuum.0	2020-03-23 12:54:27.167	debug	(25108) Receive <<< {"result":[[1584951226,1584952166,940,10002500,0,1]],"id":12}
        mihome-vacuum.0	2020-03-23 12:54:27.160	debug	(25108) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1584951226]}
        mihome-vacuum.0	2020-03-23 12:54:26.966	debug	(25108) Receive <<< {"result":[[1584953434,1584954052,618,9067500,0,1]],"id":11}
        mihome-vacuum.0	2020-03-23 12:54:26.958	debug	(25108) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1584953434]}
        mihome-vacuum.0	2020-03-23 12:54:26.950	debug	(25108) Receive <<< {"result":["retry"],"id":10}
        mihome-vacuum.0	2020-03-23 12:54:26.944	debug	(25108) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
        mihome-vacuum.0	2020-03-23 12:54:26.763	debug	(25108) Receive <<< {"result":[[1584954900,1584955757,857,7797500,0,1]],"id":9}
        mihome-vacuum.0	2020-03-23 12:54:26.757	debug	(25108) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1584954900]}
        mihome-vacuum.0	2020-03-23 12:54:26.752	debug	(25108) Receive <<< {"result":"unknown_method","id":8}
        mihome-vacuum.0	2020-03-23 12:54:26.751	info	(25108) create state for carpet_mode
        mihome-vacuum.0	2020-03-23 12:54:26.751	debug	(25108) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":7}
        mihome-vacuum.0	2020-03-23 12:54:26.745	debug	(25108) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
        mihome-vacuum.0	2020-03-23 12:54:26.744	debug	(25108) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
        mihome-vacuum.0	2020-03-23 12:54:26.563	debug	(25108) Receive <<< {"result":[[1584959723,1584960619,896,13962500,0,1]],"id":6}
        mihome-vacuum.0	2020-03-23 12:54:26.556	debug	(25108) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1584959723]}
        mihome-vacuum.0	2020-03-23 12:54:26.555	debug	(25108) Receive <<< {"result":[3807893,54657357500,1588,[1584959723,1584954900,1584953434,1584951226,1584950091,1584947492,1584864593,1584791981,1584781226,1584720065,1584717908,1584714391,1584698558
        mihome-vacuum.0	2020-03-23 12:54:26.544	debug	(25108) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
        mihome-vacuum.0	2020-03-23 12:54:26.351	debug	(25108) Receive <<< {"result":[{"main_brush_work_time":183065,"side_brush_work_time":613021,"filter_work_time":183065,"sensor_dirty_time":79593}],"id":4}
        mihome-vacuum.0	2020-03-23 12:54:26.344	debug	(25108) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
        mihome-vacuum.0	2020-03-23 12:54:26.176	info	(25108) set nächster Timer: Nicht verfügbar
        mihome-vacuum.0	2020-03-23 12:54:26.153	debug	(25108) Receive <<< {"result":[90],"id":3}
        mihome-vacuum.0	2020-03-23 12:54:26.146	debug	(25108) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
        mihome-vacuum.0	2020-03-23 12:54:25.951	debug	(25108) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.4_004007","ap":{"ssid":"Mueller","bssid":"DC:39:6F:4E:09:86","rssi":-53},"netif":{"localIp
        mihome-vacuum.0	2020-03-23 12:54:25.946	debug	(25108) Next WiFi check: 23.03 12:55
        mihome-vacuum.0	2020-03-23 12:54:25.945	debug	(25108) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
        mihome-vacuum.0	2020-03-23 12:54:25.744	info	(25108) Connected
        mihome-vacuum.0	2020-03-23 12:54:25.741	debug	(25108) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-03-23 12:54:25.740	debug	(25108) Receive <<< {"result":[{"msg_ver":8,"msg_seq":1814,"state":8,"battery":90,"clean_time":896,"clean_area":13962500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":60,"dnd_enabled":0}
        mihome-vacuum.0	2020-03-23 12:54:25.732	debug	(25108) sendMsg[1] >>> {"id":1,"method":"get_status"}
        mihome-vacuum.0	2020-03-23 12:54:25.690	debug	(25108) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
        mihome-vacuum.0	2020-03-23 12:54:25.690	info	(25108) connecting, this can take up to 10 minutes ...
        mihome-vacuum.0	2020-03-23 12:54:25.689	warn	(25108) Time difference between Mihome Vacuum and ioBroker: 3 sec
        mihome-vacuum.0	2020-03-23 12:54:25.689	debug	(25108) Receive <<< Helo <<< 2131002000000000034caaab5e78a374ffffffffffffffffffffffffffffffff
        mihome-vacuum.0	2020-03-23 12:54:25.669	info	(25108) New generation or new fw(3.5.4,004007) detected, create new states goto and zoneclean
        mihome-vacuum.0	2020-03-23 12:54:25.646	debug	(25108) server started on 0.0.0.0:53421
        mihome-vacuum.0	2020-03-23 12:54:25.637	info	(25108) Cloud control disabled
        mihome-vacuum.0	2020-03-23 12:54:25.636	info	(25108) Expert mode disabled, states deleted
        mihome-vacuum.0	2020-03-23 12:54:25.631	debug	(25108) Xiaomi Cloud: Logging in
        mihome-vacuum.0	2020-03-23 12:54:25.630	debug	(25108) load Map creator... true
        mihome-vacuum.0	2020-03-23 12:54:25.195	info	(25108) starting. Version 2.0.9-RC07 in C:/ioBroker/node_modules/iobroker.mihome-vacuum, node: v10.18.0
          root_ last edited by
          Hatte den IndexSizeError auch. Bei mir ist auch die Xiaomi cloud map aktiv.
            Hyperbit last edited by
            Meister ich Gratuiliere!
            ich bin gerade von Valetudo auf Valetudo RE umgestiegen. Hier hat der Mapper nicht mehr funktioniert und somit hatte ich im IO Broker keine Karte.
            Ich habe es einfach nicht hinbekommen, das der VALETUDO-Mapper (von ValetudoRE) trotz gefüllten MQTT Topic ein Bild generierte.
            Und da entdecke ich deine 2.0.x Version des mihome-vacuum adapter.
            Ich bin verliebt!! Einfach Token und IP rein und gut ist. Schon habe ich die Karten ohne extra Valetudo-Mapper!!
            DU BIST DER BESTE!
            • V
              Vocaris @dirkhe last edited by
              @dirkhe Hei, welche Readme?
              Habe das gleiche Problem.
              Inder Adapterinfo steht folgendes:
              Error at installation
              if your installation runs in error. The canvas package could not be install
              npm ERR! canvas@2.6.1 install: node-pre-gyp install --fallback-to-build npm ERR! Exit status 1
              Please install canvas and the libs manually with:
              sudo apt-get install build-essential libcairo2-dev libpango1.0-dev libjpeg-dev libgif-dev librsvg2-dev
              sudo npm install canvas --unsafe-perm=true
              Wenn ich aber auf der Konsole den ersten Befehl ausführe kommt:
              s müssen 19,1 MB an Archiven heruntergeladen werden.
              Nach dieser Operation werden 69,7 MB Plattenplatz zusätzlich benutzt.
              Möchten Sie fortfahren? [J/n]
              Egal ob ich J oder j drücke. Danach komtm immer Abbruch und ich stehe wieder im Prompt.
                arteck Developer Most Active @Vocaris last edited by
                @Vocaris dann drück y
                • bahnuhr
                  Heute wieder ein paar errors.
                  Vielleicht hilfts bei der Analyse.
                  mihome-vacuum.0	2020-03-25 10:26:38.115	warn	(34164) Could not receive Mappointer, giving up
                  mihome-vacuum.0	2020-03-25 10:26:31.710	info	(34164) Connected
                  mihome-vacuum.0	2020-03-25 10:26:31.683	info	(34164) connecting, this can take up to 10 minutes ...
                  mihome-vacuum.0	2020-03-25 10:26:31.682	warn	(34164) Time difference between Mihome Vacuum and ioBroker: 33 sec
                  mihome-vacuum.0	2020-03-25 10:26:31.673	info	(34164) Disconnected due last Restponse of 10:24:13.434
                  mihome-vacuum.0	2020-03-25 10:25:07.843	warn	(34164) no answer received after after 3 times -> pause miIO.info try again in one hour
                  mihome-vacuum.0	2020-03-25 09:37:29.006	warn	(34164) Could not receive Mappointer, giving up
                  mihome-vacuum.0	2020-03-25 09:37:22.687	info	(34164) Connected
                  mihome-vacuum.0	2020-03-25 09:37:22.679	info	(34164) connecting, this can take up to 10 minutes ...
                  mihome-vacuum.0	2020-03-25 09:37:22.678	warn	(34164) Time difference between Mihome Vacuum and ioBroker: 1 sec
                  mihome-vacuum.0	2020-03-25 09:37:22.641	info	(34164) Disconnected due last Restponse of 09:35:04.852
                  mihome-vacuum.0	2020-03-25 09:36:18.221	warn	(34164) no answer received after after 3 times -> pause miIO.info try again in one hour
                  mihome-vacuum.0	2020-03-25 09:27:49.636	info	(34164) Connected
                  mihome-vacuum.0	2020-03-25 09:27:49.193	info	(34164) connecting, this can take up to 10 minutes ...
                  mihome-vacuum.0	2020-03-25 09:27:49.193	warn	(34164) Time difference between Mihome Vacuum and ioBroker: 33 sec
                  mihome-vacuum.0	2020-03-25 09:27:49.190	info	(34164) Disconnected due last Restponse of 09:25:30.115
                  mihome-vacuum.0	2020-03-25 09:20:47.531	warn	(34164) no answer received after after 3 times -> pause miIO.info try again in one hour
                  mihome-vacuum.0	2020-03-25 09:10:22.253	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:10:44 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"590c9079-d95c-f
                  mihome-vacuum.0	2020-03-25 09:10:15.076	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:10:37 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"38fed30a-d23f-9
                  mihome-vacuum.0	2020-03-25 09:09:08.793	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:09:30 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"db9d3cf8-fc19-0
                  mihome-vacuum.0	2020-03-25 09:09:01.969	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:09:23 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"994e4c75-c90d-5
                  mihome-vacuum.0	2020-03-25 09:06:24.493	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:44 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"963ada9d-8c92-f
                  mihome-vacuum.0	2020-03-25 09:06:17.722	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:37 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2bae5056-c3b3-3
                  mihome-vacuum.0	2020-03-25 09:06:14.200	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:33 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"5e1f15e8-bddf-3
                  mihome-vacuum.0	2020-03-25 09:06:11.005	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:30 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"21973af7-c50d-0
                  mihome-vacuum.0	2020-03-25 09:06:07.798	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:27 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"d0f1ec26-f964-b
                  mihome-vacuum.0	2020-03-25 09:06:04.588	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:24 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"78388881-77c9-0
                  mihome-vacuum.0	2020-03-25 09:06:01.042	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:20 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"9fabd49b-2b3c-b
                  mihome-vacuum.0	2020-03-25 09:05:57.851	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:17 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"65f480c9-d31f-6
                  mihome-vacuum.0	2020-03-25 09:05:54.638	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:14 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"41196374-457c-6
                  mihome-vacuum.0	2020-03-25 09:05:51.065	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:10 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"3655b6ed-b2ba-3
                  mihome-vacuum.0	2020-03-25 09:05:47.757	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:07 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"dc6eb8cc-798c-1
                  mihome-vacuum.0	2020-03-25 09:05:44.195	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:03 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"ba9f3cbc-142f-2
                  mihome-vacuum.0	2020-03-25 09:05:40.636	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:06:00 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8664a1e0-34c4-1
                  mihome-vacuum.0	2020-03-25 09:05:37.442	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:05:57 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"306e88a7-6192-1
                  mihome-vacuum.0	2020-03-25 09:04:28.968	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:04:47 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"0204c5b0-06f9-c
                  mihome-vacuum.0	2020-03-25 09:04:25.391	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:04:43 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"eb24cacf-6a57-a
                  mihome-vacuum.0	2020-03-25 09:04:22.135	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:04:40 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f3d100dc-4f57-d
                  mihome-vacuum.0	2020-03-25 09:04:18.818	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:04:37 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"b98c0d3a-9aec-c
                  mihome-vacuum.0	2020-03-25 09:04:15.622	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:04:33 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"36f1185c-d96c-6
                  mihome-vacuum.0	2020-03-25 09:04:12.277	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:04:30 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"45674737-ff41-d
                  mihome-vacuum.0	2020-03-25 09:04:08.713	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:04:27 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"4bae4140-2f0d-a
                  mihome-vacuum.0	2020-03-25 09:03:02.574	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:03:20 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2481a7b3-3e7b-b
                  mihome-vacuum.0	2020-03-25 09:02:59.140	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:03:16 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"98e81887-04e2-0
                  mihome-vacuum.0	2020-03-25 09:02:55.557	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 08:03:13 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"a5d832bf-c2f6-e
                  mihome-vacuum.0	2020-03-25 08:46:11.816	info	(34164) trigger cleaning all
                  mihome-vacuum.0	2020-03-25 08:37:47.405	error	(34164) Error: connect ETIMEDOUT 47.74.174.56:443
                  mihome-vacuum.0	2020-03-25 08:37:04.636	info	(34164) Connected
                  mihome-vacuum.0	2020-03-25 08:37:04.627	info	(34164) connecting, this can take up to 10 minutes ...
                  mihome-vacuum.0	2020-03-25 08:37:04.627	warn	(34164) Time difference between Mihome Vacuum and ioBroker: 1 sec
                  mihome-vacuum.0	2020-03-25 08:37:04.623	info	(34164) Disconnected due last Restponse of 08:35:00.812
                  mihome-vacuum.0	2020-03-25 08:36:00.291	warn	(34164) no answer received after after 3 times -> pause miIO.info try again in one hour
                  mihome-vacuum.0	2020-03-25 08:35:02.024	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:35:39 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"4bc70e3d-cac8-9
                  mihome-vacuum.0	2020-03-25 08:33:42.848	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:34:19 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"309925a6-965c-9
                  mihome-vacuum.0	2020-03-25 08:33:39.288	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:34:16 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"6b93c8bf-81ec-d
                  mihome-vacuum.0	2020-03-25 08:33:36.102	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:34:13 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"fa26c485-08a3-6
                  mihome-vacuum.0	2020-03-25 08:33:32.908	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:34:10 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2a967c41-854b-5
                  mihome-vacuum.0	2020-03-25 08:33:29.688	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:34:06 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"1fdeadb5-8064-8
                  mihome-vacuum.0	2020-03-25 08:33:26.377	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:34:03 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"84bfba44-eb98-7
                  mihome-vacuum.0	2020-03-25 08:33:23.157	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:34:00 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8b4d4804-9e0b-c
                  mihome-vacuum.0	2020-03-25 08:33:19.919	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:57 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"6276bae3-07c3-3
                  mihome-vacuum.0	2020-03-25 08:33:16.670	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:53 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"94b2a90b-62a7-2
                  mihome-vacuum.0	2020-03-25 08:33:13.445	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:50 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"aa5fdc8f-ebea-3
                  mihome-vacuum.0	2020-03-25 08:33:09.762	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:46 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"40ba9e50-dd3e-9
                  mihome-vacuum.0	2020-03-25 08:33:06.508	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:43 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"d0f24378-1c70-b
                  mihome-vacuum.0	2020-03-25 08:33:02.954	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:40 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"662842d1-5071-3
                  mihome-vacuum.0	2020-03-25 08:33:00.377	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:36 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"768c3a81-f5e1-6
                  mihome-vacuum.0	2020-03-25 08:32:56.820	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:33 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"1e198f0c-d506-5
                  mihome-vacuum.0	2020-03-25 08:32:52.791	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:33:29 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"027b29e8-1098-1
                  mihome-vacuum.0	2020-03-25 08:31:48.106	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:32:23 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"d3343497-8d0e-3
                  mihome-vacuum.0	2020-03-25 08:31:44.558	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:32:20 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"a8dc487f-37b9-5
                  mihome-vacuum.0	2020-03-25 08:31:37.349	error	(34164) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Wed, 25 Mar 2020 07:32:13 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"ef543389-c089-b
                  mihome-vacuum.0	2020-03-25 08:26:12.269	info	(34164) Connected
                  mihome-vacuum.0	2020-03-25 08:26:12.260	info	(34164) connecting, this can take up to 10 minutes ...
                  mihome-vacuum.0	2020-03-25 08:26:12.260	warn	(34164) Time difference between Mihome Vacuum and ioBroker: 33 sec
                  mihome-vacuum.0	2020-03-25 08:26:12.255	info	(34164) Disconnected due last Restponse of 08:24:03.128
                  mihome-vacuum.0	2020-03-25 08:25:07.806	warn	(34164) no answer received after after 3 times -> pause miIO.info try again in one hour
                  mihome-vacuum.0	2020-03-25 08:17:55.983	info	(34164) trigger cleaning all
                  mihome-vacuum.0	2020-03-25 08:01:51.888	error	(34164) Error: IndexSizeError: The source width is 0.
                  mihome-vacuum.0	2020-03-25 08:01:32.411	info	(34164) trigger cleaning all
                  mihome-vacuum.0	2020-03-25 07:37:49.522	warn	(34164) Could not receive Mappointer, giving up
                  mihome-vacuum.0	2020-03-25 07:37:43.170	info	(34164) Connected
                  mihome-vacuum.0	2020-03-25 07:37:43.162	info	(34164) connecting, this can take up to 10 minutes ...
                  mihome-vacuum.0	2020-03-25 07:37:43.162	warn	(34164) Time difference between Mihome Vacuum and ioBroker: 1 sec
                  mihome-vacuum.0	2020-03-25 07:37:43.158	info	(34164) Disconnected due last Restponse of 07:35:26.448
                  mihome-vacuum.0	2020-03-25 07:36:38.883	warn	(34164) no answer received after after 3 times -> pause miIO.info try again in one hour
                  mfg
                  Dieter
                  K Meistertr 2 Replies Last reply Reply Quote 0
                    K_o_bold @bahnuhr last edited by K_o_bold
                    @bahnuhr , @dirkhe , @Meistertr ,
                    den gleichen Error habe ich auch immer wieder. --> no map found
                    • Meistertr
                      @bahnuhr in der version von git gibt es die fehler nciht mehr
                      • bahnuhr
                        habe von git installiert.
                        Ist aber immer noch die 2.0.9
                        richtig?
                          schdief last edited by
                          Hi, ich habe gerade meinen Xiaomi mit Valetudo geflasht und versuche die Karte in mein Vis einzubinden. Lieder kriege ich nur eine Fehlermeldung:
                          mihome-vacuum.0	2020-03-26 16:43:51.868	warn	(20737) Could not receive Mappointer, giving up
                          Die states unter .map bleiben auch alle leer. Was mache ich hier falsch?
                          Danke!
                            Kueppert last edited by
                            Hi zusammen,
                            ich hatte gerade nachdem mein Saugi fertig war mit saugen, eine 100% CPU-Auslastung. Ich hatte folgendes im Log:
                            host.ioBroker2	2020-03-27 12:22:38.108	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
                            host.ioBroker2	2020-03-27 12:22:38.108	info	instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                            host.ioBroker2	2020-03-27 12:22:38.107	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                            host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[13]: 17: 0x1de16585a2e1
                            host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[13]: 16: 0x9193fb [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[12]: 15: 0x9c4c33 node::StringBytes::Write(v8::Isolate*, char*, unsigned long, v8::Local<v8::Value>, node::encoding, int*) [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[11]: 14: 0xb2a2a1 v8::String::Value::Value(v8::Isolate*, v8::Local<v8::Value>) [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[10]: 13: 0xafd334 v8::internal::String::Flatten(v8::internal::Handle<v8::internal::String>, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[9]: 12: 0x101ce9d v8::internal::String::SlowFlatten(v8::internal::Handle<v8::internal::ConsString>, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[8]: 11: 0xed342a v8::internal::Factory::NewRawOneByteString(int, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[7]: 10: 0xecbbb5 [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[6]: 9: 0xf038d1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[5]: 8: 0xf00c64 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[4]: 7: 0xf00332 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[3]: 6: 0xef4258 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[2]: 5: 0xef4152 [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 4: 0xafff44 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 3: 0xaffd0e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 2: 0x8f9d5c [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 1: 0x8f9d10 node::Abort() [io.mihome-vacuum.0]
                            host.ioBroker2	2020-03-27 12:22:38.105	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                            Ist das erste Mal aufgetreten heute O.o
                            D H 2 Replies Last reply Reply Quote 0
                              dirkhe Developer @Kueppert last edited by
                              @Kueppert könntest du noch ein bisschen mehr Log Posten, bevor das passiert ist?
                              K 2 Replies Last reply Reply Quote 0
                                Kueppert @dirkhe last edited by
                                @dirkhe nur die Einträge aus dem log, die mit dem Adapter zu tun haben? Oder einfach einen Auszug von heute als Dateianhang?
                                  @dirkhe hab noch was gefunden, das ggf. weiterhilft:
                                  2020-03-27 12:06:16.826 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:16 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8822e208-397d-ca1f-0000-01711babce13","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:06:19.839 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:19 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"5b505204-c47a-87cb-0000-01711babdafa","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:06:23.153 - info: mihome-vacuum.0 (780) Disconnect
                                  2020-03-27 12:06:23.300 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:23 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"68e38ade-5a0d-cfb2-0000-01711babe751","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:06:26.325 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:26 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8649174a-c919-a08e-0000-01711babf304","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:06:29.371 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:29 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"ec138f99-5fef-ac1a-0000-01711babff18","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:06:30.137 - info: unifi.0 (2203) Starting UniFi-Controller query
                                  2020-03-27 12:06:30.138 - info: unifi.0 (2203) update_interval = 60
                                  2020-03-27 12:06:30.138 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                  2020-03-27 12:06:30.434 - info: unifi.0 (2203) getSitesStats: default
                                  2020-03-27 12:06:30.453 - info: unifi.0 (2203) getSiteSysinfo: 1
                                  2020-03-27 12:06:30.472 - info: unifi.0 (2203) getClientDevices: 22
                                  2020-03-27 12:06:30.684 - info: unifi.0 (2203) getAccessDevices: 1
                                  2020-03-27 12:06:32.426 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:32 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"349d92a7-bf60-22a9-0000-01711bac0b51","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:06:35.736 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:35 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"a7f090d2-a1ff-3817-0000-01711bac180b","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:06:39.023 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:38 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"33042f81-515d-efc9-0000-01711bac25fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:06:42.113 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:41 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f930393c-6d79-c7ad-0000-01711bac31af","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:06:43.153 - info: mihome-vacuum.0 (780) Disconnect
                                  2020-03-27 12:06:45.389 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:45 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f549b8fd-cb30-333c-0000-01711bac3e3a","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:06:48.626 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:48 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"afe7d6f9-52ff-75ff-0000-01711bac4a6d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:06:48.631 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                                  2020-03-27 12:06:52.019 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:51 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"01962472-7526-84f1-0000-01711bac58cd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:06:55.014 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:54 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"addcf6aa-172a-d7c0-0000-01711bac637c","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:06:58.346 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:58 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"37bc4ae2-30bf-d082-0000-01711bac701f","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:07:01.341 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:01 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"b9a60d2c-943f-7a23-0000-01711bac7c21","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:07:03.155 - info: mihome-vacuum.0 (780) Disconnect
                                  2020-03-27 12:07:04.595 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:04 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"0f1c5fc0-fe2c-85b2-0000-01711bac89fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:07:07.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:07 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"67576ec9-5750-92b1-0000-01711bac9560","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:07:10.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:10 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"03737cb1-32cb-595c-0000-01711baca111","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:07:14.189 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:14 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8a047e9d-2efe-578c-0000-01711bacae2d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:07:17.174 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:17 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2a63601a-70f8-7946-0000-01711bacbaa4","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                  2020-03-27 12:07:23.156 - info: mihome-vacuum.0 (780) Disconnect
                                    dirkhe Developer last edited by
                                    Eigentlich reichen die Zeilen vorher vom Adapter. Wenn aber davor andere Sachen auch verrückt spielen oder da eine Menge los war, ist das vlt auch sinnvoll. Man kann an dem Log nicht erkennen, wo das ganze aufgetreten ist
                                      Hyperbit @Kueppert last edited by
                                      @Kueppert läuft das bei dir auf einem Raspberry?
                                      Ich lese da Out of Memory und interpretiere da hinein das der Prozess dann abgeschossen wurde (ist aber nur ein schneller Blick auf die deinen Logauszug vom Handy aus).
                                      Lg
                                        @Kueppert hier ist er gar nicht mit dem robbi verbunden. Irgendwann müsste dann auch noch ein Connect kommen.
                                          @dirkhe hab nochmal mehr logging über einen längeren Zeitraum hier angefügt:
                                          2020-03-27 11:35:22.125 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:35:25.829 - info: nut.0 (579) Start NUT update
                                          2020-03-27 11:35:25.842 - info: nut.0 (579) All Nut values set
                                          2020-03-27 11:35:26.171 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:35:34.549 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:35:42.176 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:35:46.727 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:35:54.377 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:36:06.046 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:36:12.678 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:36:12.679 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:36:12.679 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:36:12.946 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:36:12.963 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:36:12.979 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:36:13.132 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:36:13.348 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:36:17.454 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:36:42.170 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:36:48.611 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                                          2020-03-27 11:36:54.786 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:37:05.891 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:37:11.345 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:37:13.197 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:37:13.198 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:37:13.198 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:37:13.492 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:37:13.506 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:37:13.520 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:37:13.633 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:37:14.833 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:37:25.149 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:37:34.711 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:37:39.452 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:37:42.708 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:37:46.689 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:37:50.176 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:37:53.559 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:37:57.080 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:38:04.140 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:38:07.533 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:38:10.774 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:38:13.712 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:38:13.712 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:38:13.712 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:38:13.957 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:38:13.961 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:38:13.971 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:38:13.985 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:38:14.106 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:38:20.958 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:38:25.256 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:38:35.222 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:38:38.625 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:38:41.670 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:38:55.343 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:38:58.593 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:39:02.020 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:39:05.311 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:39:08.707 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:39:11.964 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:39:14.181 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:39:14.182 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:39:14.182 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:39:14.435 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:39:14.459 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:39:14.482 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:39:14.695 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:39:18.782 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:39:24.201 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:39:27.647 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:39:31.150 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:39:34.295 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:39:38.334 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:39:41.816 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:39:45.382 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:39:48.586 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:39:51.843 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:39:58.839 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:40:02.025 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:40:08.908 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:40:12.409 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:40:14.788 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:40:14.789 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:40:14.789 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:40:15.055 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:40:15.084 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:40:15.108 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:40:15.298 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:40:15.801 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:40:22.858 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:40:25.831 - info: nut.0 (579) Start NUT update
                                          2020-03-27 11:40:25.845 - info: nut.0 (579) All Nut values set
                                          2020-03-27 11:40:26.137 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:40:29.554 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:40:36.245 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:40:50.405 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                                          2020-03-27 11:40:52.555 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                                          2020-03-27 11:40:52.989 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:40:56.217 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:40:59.538 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:41:09.693 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:41:12.973 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:41:15.444 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:41:15.444 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:41:15.444 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:41:15.713 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:41:15.733 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:41:15.751 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:41:15.918 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:41:19.465 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:41:47.585 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:41:48.614 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                                          2020-03-27 11:41:51.106 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:41:54.358 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:42:01.150 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:42:11.353 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:42:15.881 - warn: sonoff.0 (636) Client "Sonoff-S10-Wohnzimmer" not connected
                                          2020-03-27 11:42:16.056 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:42:16.056 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:42:16.056 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:42:16.323 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:42:16.362 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:42:16.389 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:42:16.636 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:42:18.361 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:42:38.243 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:42:45.019 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:42:55.433 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:42:58.594 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:43:05.420 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:43:11.802 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:43:16.732 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:43:16.733 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:43:16.733 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:43:17.032 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:43:17.058 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:43:17.078 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:43:17.249 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:43:35.351 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:43:42.064 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:44:02.001 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:44:05.570 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:44:12.313 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:44:17.329 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:44:17.329 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:44:17.329 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:44:17.577 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:44:17.591 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:44:17.606 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:44:17.743 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:44:18.857 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:44:22.494 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:44:29.048 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:44:32.361 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:44:42.700 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:44:49.464 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:44:52.764 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:44:56.369 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:44:59.952 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:45:00.022 - info: host.ioBroker2 instance system.adapter.daswetter.0 started with pid 11811
                                          2020-03-27 11:45:01.781 - info: daswetter.0 (11811) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.0
                                          2020-03-27 11:45:02.610 - info: daswetter.0 (11811) Terminated (NO_ERROR): Without reason
                                          2020-03-27 11:45:03.120 - info: host.ioBroker2 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                          2020-03-27 11:45:03.539 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:45:06.746 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:45:13.481 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:45:17.084 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:45:17.844 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:45:17.845 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:45:17.845 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:45:18.080 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:45:18.100 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:45:18.116 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:45:18.251 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:45:20.666 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:45:24.057 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:45:25.833 - info: nut.0 (579) Start NUT update
                                          2020-03-27 11:45:25.852 - info: nut.0 (579) All Nut values set
                                          2020-03-27 11:45:30.813 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:45:34.324 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:45:37.919 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:45:44.784 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:45:48.191 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:45:51.802 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:45:55.321 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:45:58.884 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:46:02.372 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:46:08.897 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:46:12.532 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:46:18.340 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:46:18.341 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:46:18.341 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:46:18.633 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:46:18.655 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:46:18.672 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:46:18.862 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:46:19.486 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:46:23.016 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:46:30.061 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:46:34.097 - info: info.0 (855) Popup news was read...
                                          2020-03-27 11:46:37.139 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:46:40.494 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:46:43.695 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:46:47.796 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                                          2020-03-27 11:46:48.617 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                                          2020-03-27 11:46:49.998 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                                          2020-03-27 11:46:50.524 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:46:53.865 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:46:57.326 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:47:00.643 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:47:08.240 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:47:15.347 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:47:19.006 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:47:19.007 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:47:19.007 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:47:19.293 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:47:19.316 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:47:19.335 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:47:19.488 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:47:22.019 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:47:28.878 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:47:35.391 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:47:40.287 - info: web-speedy.0 (2583) Execute timer with : 1800000 Currently running : false
                                          2020-03-27 11:47:40.288 - info: web-speedy.0 (2583) Run test on on Best Server found
                                          2020-03-27 11:47:40.292 - info: web-speedy.0 (2583) The speed test has been started and will take at maximum 30 seconds for a single test run
                                          2020-03-27 11:47:42.062 - info: web-speedy.0 (2583) Closest server found, running test
                                          2020-03-27 11:47:56.668 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:48:00.376 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:48:07.741 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:48:19.569 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:48:19.570 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:48:19.570 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:48:19.837 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:48:19.852 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:48:19.870 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:48:20.037 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:48:41.515 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:48:44.973 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:48:46.231 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.download_Mb, Alias=false
                                          2020-03-27 11:48:46.233 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.upload_Mb, Alias=false
                                          2020-03-27 11:48:46.267 - info: web-speedy.0 (2583) The speed test has been completed successfully.
                                          2020-03-27 11:48:55.771 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:48:59.039 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:49:06.111 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:49:09.562 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:49:12.898 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:49:16.380 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:49:20.187 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:49:20.188 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:49:20.188 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:49:20.438 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:49:20.461 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:49:20.485 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:49:20.639 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:49:26.764 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:49:47.270 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:49:50.761 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:50:08.038 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:50:15.685 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:50:20.725 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:50:20.726 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:50:20.726 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:50:21.037 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:50:21.059 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:50:21.071 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:50:21.177 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:50:22.688 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:50:25.834 - info: nut.0 (579) Start NUT update
                                          2020-03-27 11:50:25.854 - info: nut.0 (579) All Nut values set
                                          2020-03-27 11:50:57.626 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                                          2020-03-27 11:51:21.298 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:51:21.298 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:51:21.298 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:51:21.565 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:51:21.582 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:51:21.609 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 11:51:21.849 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:51:22.830 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:51:42.831 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:51:48.621 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                                          2020-03-27 11:52:02.833 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:52:21.967 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:52:21.968 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:52:21.968 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:52:22.242 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:52:22.270 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:52:22.291 - info: unifi.0 (2203) getClientDevices: 22
                                          2020-03-27 11:52:22.501 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:52:22.834 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:52:42.835 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:52:47.306 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                                          2020-03-27 11:52:49.619 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                                          2020-03-27 11:53:02.837 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:53:22.645 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:53:22.646 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:53:22.646 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:53:22.839 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:53:22.902 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:53:22.916 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:53:22.931 - info: unifi.0 (2203) getClientDevices: 22
                                          2020-03-27 11:53:23.107 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:53:42.839 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:54:02.841 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:54:22.842 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:54:23.220 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:54:23.220 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:54:23.220 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:54:23.468 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:54:23.498 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:54:23.516 - info: unifi.0 (2203) getClientDevices: 22
                                          2020-03-27 11:54:23.660 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:54:42.843 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:55:02.843 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:55:22.844 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:55:23.758 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:55:23.759 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:55:23.759 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:55:24.018 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:55:24.038 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:55:24.056 - info: unifi.0 (2203) getClientDevices: 22
                                          2020-03-27 11:55:24.195 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:55:25.835 - info: nut.0 (579) Start NUT update
                                          2020-03-27 11:55:25.848 - info: nut.0 (579) All Nut values set
                                          2020-03-27 11:55:42.846 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:56:02.846 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:56:22.848 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:56:24.290 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:56:24.290 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:56:24.291 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:56:24.550 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:56:24.582 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:56:24.611 - info: unifi.0 (2203) getClientDevices: 22
                                          2020-03-27 11:56:24.744 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:56:42.849 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:56:48.623 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                                          2020-03-27 11:57:02.851 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:57:22.852 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:57:24.830 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:57:24.831 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:57:24.831 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:57:25.151 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:57:25.175 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:57:25.216 - info: unifi.0 (2203) getClientDevices: 22
                                          2020-03-27 11:57:25.375 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:57:42.852 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:58:02.854 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:58:22.855 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:58:25.493 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:58:25.494 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:58:25.494 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:58:25.797 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:58:25.816 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:58:25.842 - info: unifi.0 (2203) getClientDevices: 22
                                          2020-03-27 11:58:26.091 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:58:43.077 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:58:47.481 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                                          2020-03-27 11:58:49.626 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                                          2020-03-27 11:59:03.079 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:59:23.079 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 11:59:26.196 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 11:59:26.196 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 11:59:26.196 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 11:59:26.439 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 11:59:26.459 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 11:59:26.497 - info: unifi.0 (2203) getClientDevices: 22
                                          2020-03-27 11:59:26.634 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 11:59:43.081 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:00:00.023 - info: host.ioBroker2 instance system.adapter.daswetter.0 started with pid 29088
                                          2020-03-27 12:00:01.676 - info: daswetter.0 (29088) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.0
                                          2020-03-27 12:00:02.358 - info: daswetter.0 (29088) Terminated (NO_ERROR): Without reason
                                          2020-03-27 12:00:02.868 - info: host.ioBroker2 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                          2020-03-27 12:00:03.125 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:00:04.040 - info: host.ioBroker2 instance system.adapter.ical.0 started with pid 29255
                                          2020-03-27 12:00:14.339 - info: host.ioBroker2 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                                          2020-03-27 12:00:23.126 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:00:25.836 - info: nut.0 (579) Start NUT update
                                          2020-03-27 12:00:25.848 - info: nut.0 (579) All Nut values set
                                          2020-03-27 12:00:26.716 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:00:26.716 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:00:26.716 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:00:27.029 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:00:27.046 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:00:27.068 - info: unifi.0 (2203) getClientDevices: 22
                                          2020-03-27 12:00:27.207 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:00:43.127 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:01:03.128 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:01:23.130 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:01:27.323 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:01:27.323 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:01:27.324 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:01:27.619 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:01:27.640 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:01:27.667 - info: unifi.0 (2203) getClientDevices: 22
                                          2020-03-27 12:01:27.822 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:01:43.130 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:01:48.627 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                                          2020-03-27 12:02:03.136 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:02:23.137 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:02:27.898 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:02:27.898 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:02:27.898 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:02:28.239 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:02:28.254 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:02:28.269 - info: unifi.0 (2203) getClientDevices: 22
                                          2020-03-27 12:02:28.387 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:02:43.138 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:02:48.401 - info: javascript.0 (459) script.js.common.Sonstiges.TürenFenster-TextSkript: TürenFenster_getriggert
                                          2020-03-27 12:03:03.139 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:03:23.141 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:03:28.462 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:03:28.463 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:03:28.463 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:03:28.758 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:03:28.775 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:03:28.790 - info: unifi.0 (2203) getClientDevices: 22
                                          2020-03-27 12:03:28.962 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:03:43.142 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:04:03.143 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:04:23.144 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:04:29.045 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:04:29.045 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:04:29.045 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:04:29.312 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:04:29.326 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:04:29.339 - info: unifi.0 (2203) getClientDevices: 22
                                          2020-03-27 12:04:29.464 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:04:43.145 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:04:51.465 - info: javascript.0 (459) script.js.common.Sonstiges.TürenFenster-TextSkript: TürenFenster_getriggert
                                          2020-03-27 12:05:03.147 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:05:23.149 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:05:25.837 - info: nut.0 (579) Start NUT update
                                          2020-03-27 12:05:25.851 - info: nut.0 (579) All Nut values set
                                          2020-03-27 12:05:29.557 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:05:29.557 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:05:29.557 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:05:29.873 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:05:29.886 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:05:29.905 - info: unifi.0 (2203) getClientDevices: 22
                                          2020-03-27 12:05:30.022 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:05:43.151 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:06:03.151 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:06:16.826 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:16 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8822e208-397d-ca1f-0000-01711babce13","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:06:19.839 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:19 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"5b505204-c47a-87cb-0000-01711babdafa","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:06:23.153 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:06:23.300 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:23 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"68e38ade-5a0d-cfb2-0000-01711babe751","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:06:26.325 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:26 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8649174a-c919-a08e-0000-01711babf304","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:06:29.371 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:29 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"ec138f99-5fef-ac1a-0000-01711babff18","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:06:30.137 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:06:30.138 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:06:30.138 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:06:30.434 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:06:30.453 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:06:30.472 - info: unifi.0 (2203) getClientDevices: 22
                                          2020-03-27 12:06:30.684 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:06:32.426 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:32 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"349d92a7-bf60-22a9-0000-01711bac0b51","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:06:35.736 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:35 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"a7f090d2-a1ff-3817-0000-01711bac180b","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:06:39.023 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:38 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"33042f81-515d-efc9-0000-01711bac25fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:06:42.113 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:41 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f930393c-6d79-c7ad-0000-01711bac31af","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:06:43.153 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:06:45.389 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:45 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f549b8fd-cb30-333c-0000-01711bac3e3a","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:06:48.626 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:48 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"afe7d6f9-52ff-75ff-0000-01711bac4a6d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:06:48.631 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                                          2020-03-27 12:06:52.019 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:51 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"01962472-7526-84f1-0000-01711bac58cd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:06:55.014 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:54 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"addcf6aa-172a-d7c0-0000-01711bac637c","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:06:58.346 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:58 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"37bc4ae2-30bf-d082-0000-01711bac701f","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:07:01.341 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:01 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"b9a60d2c-943f-7a23-0000-01711bac7c21","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:07:03.155 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:07:04.595 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:04 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"0f1c5fc0-fe2c-85b2-0000-01711bac89fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:07:07.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:07 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"67576ec9-5750-92b1-0000-01711bac9560","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:07:10.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:10 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"03737cb1-32cb-595c-0000-01711baca111","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:07:14.189 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:14 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8a047e9d-2efe-578c-0000-01711bacae2d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:07:17.174 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:17 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2a63601a-70f8-7946-0000-01711bacbaa4","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                                          2020-03-27 12:07:23.156 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:07:30.808 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:07:30.808 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:07:30.809 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:07:31.071 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:07:31.090 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:07:31.114 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:07:31.278 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:08:31.361 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:08:31.362 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:08:31.362 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:08:31.689 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:08:31.706 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:08:31.724 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:08:31.886 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:09:31.986 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:09:31.987 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:09:31.987 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:09:32.323 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:09:32.341 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:09:32.358 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:09:32.498 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:10:25.838 - info: nut.0 (579) Start NUT update
                                          2020-03-27 12:10:25.851 - info: nut.0 (579) All Nut values set
                                          2020-03-27 12:10:32.591 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:10:32.591 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:10:32.591 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:10:32.877 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:10:32.898 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:10:32.914 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:10:33.041 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:10:47.363 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                                          2020-03-27 12:10:49.501 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                                          2020-03-27 12:11:33.116 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:11:33.116 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:11:33.116 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:11:33.434 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:11:33.456 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:11:33.486 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:11:33.626 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:11:48.633 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                                          2020-03-27 12:12:33.713 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:12:33.713 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:12:33.713 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:12:34.034 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:12:34.049 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:12:34.067 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:12:34.186 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:12:59.391 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                                          2020-03-27 12:13:01.572 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                                          2020-03-27 12:13:34.264 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:13:34.264 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:13:34.264 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:13:34.591 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:13:34.606 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:13:34.620 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:13:34.749 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:14:34.825 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:14:34.826 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:14:34.826 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:14:35.119 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:14:35.147 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:14:35.170 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:14:35.371 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:15:00.026 - info: host.ioBroker2 instance system.adapter.daswetter.0 started with pid 14507
                                          2020-03-27 12:15:01.858 - info: daswetter.0 (14507) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.0
                                          2020-03-27 12:15:02.856 - info: daswetter.0 (14507) Terminated (NO_ERROR): Without reason
                                          2020-03-27 12:15:03.366 - info: host.ioBroker2 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                                          2020-03-27 12:15:25.840 - info: nut.0 (579) Start NUT update
                                          2020-03-27 12:15:25.853 - info: nut.0 (579) All Nut values set
                                          2020-03-27 12:15:35.479 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:15:35.480 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:15:35.480 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:15:35.754 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:15:35.770 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:15:35.788 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:15:35.950 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:16:34.114 - info: info.0 (855) Popup news was read...
                                          2020-03-27 12:16:36.046 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:16:36.046 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:16:36.047 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:16:36.292 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:16:36.318 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:16:36.337 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:16:36.473 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:16:48.635 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                                          2020-03-27 12:17:36.548 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:17:36.548 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:17:36.549 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:17:36.790 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:17:36.806 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:17:36.824 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:17:36.953 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:17:40.294 - info: web-speedy.0 (2583) Execute timer with : 1800000 Currently running : false
                                          2020-03-27 12:17:40.295 - info: web-speedy.0 (2583) Run test on on Best Server found
                                          2020-03-27 12:17:40.299 - info: web-speedy.0 (2583) The speed test has been started and will take at maximum 30 seconds for a single test run
                                          2020-03-27 12:17:42.155 - info: web-speedy.0 (2583) Closest server found, running test
                                          2020-03-27 12:18:37.039 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:18:37.040 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:18:37.040 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:18:37.300 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:18:37.317 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:18:37.331 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:18:37.481 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:18:44.897 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.download_Mb, Alias=false
                                          2020-03-27 12:18:44.901 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.upload_Mb, Alias=false
                                          2020-03-27 12:18:44.924 - info: web-speedy.0 (2583) The speed test has been completed successfully.
                                          2020-03-27 12:19:03.197 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:19:03.205 - info: mihome-vacuum.0 (780) Connected
                                          2020-03-27 12:19:37.593 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:19:37.594 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:19:37.594 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:19:37.931 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:19:37.963 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:19:37.994 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:19:38.324 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:20:25.841 - info: nut.0 (579) Start NUT update
                                          2020-03-27 12:20:25.869 - info: nut.0 (579) All Nut values set
                                          2020-03-27 12:20:27.984 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:20:38.626 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:20:38.627 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:20:38.627 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:20:38.929 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:20:38.949 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:20:38.967 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:20:39.175 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:20:49.946 - info: mihome-vacuum.0 (780) Disconnect
                                          2020-03-27 12:21:39.360 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:21:39.381 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:21:39.381 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:21:39.862 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:21:39.886 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:21:39.910 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:21:40.081 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:21:48.651 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                                          2020-03-27 12:22:38.105 - error: host.ioBroker2 Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                                          2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 1: 0x8f9d10 node::Abort() [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 2: 0x8f9d5c [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 3: 0xaffd0e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 4: 0xafff44 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[2]: 5: 0xef4152 [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[3]: 6: 0xef4258 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[4]: 7: 0xf00332 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[5]: 8: 0xf00c64 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[6]: 9: 0xf038d1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[7]: 10: 0xecbbb5 [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[8]: 11: 0xed342a v8::internal::Factory::NewRawOneByteString(int, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[9]: 12: 0x101ce9d v8::internal::String::SlowFlatten(v8::internal::Handle, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[10]: 13: 0xafd334 v8::internal::String::Flatten(v8::internal::Handle, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[11]: 14: 0xb2a2a1 v8::String::Value::Value(v8::Isolate*, v8::Local) [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[12]: 15: 0x9c4c33 node::StringBytes::Write(v8::Isolate*, char*, unsigned long, v8::Local, node::encoding, int*) [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[13]: 16: 0x9193fb [io.mihome-vacuum.0]
                                          2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[13]: 17: 0x1de16585a2e1
                                          2020-03-27 12:22:38.107 - warn: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                                          2020-03-27 12:22:38.108 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                                          2020-03-27 12:22:38.108 - info: host.ioBroker2 Restart adapter system.adapter.mihome-vacuum.0 because enabled
                                          2020-03-27 12:22:40.300 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:22:40.301 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:22:40.301 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:22:40.568 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:22:40.588 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:22:40.607 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:22:40.872 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:23:08.163 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 started with pid 23991
                                          2020-03-27 12:23:11.961 - info: mihome-vacuum.0 (23991) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
                                          2020-03-27 12:23:12.083 - info: mihome-vacuum.0 (23991) Expert mode disabled, states deleted
                                          2020-03-27 12:23:12.084 - info: mihome-vacuum.0 (23991) Create state clean_home for controlling by cloud adapter
                                          2020-03-27 12:23:12.100 - info: mihome-vacuum.0 (23991) Disconnect
                                          2020-03-27 12:23:12.147 - info: mihome-vacuum.0 (23991) New generation or new fw detected, create new states goto and zoneclean
                                          2020-03-27 12:23:12.183 - info: mihome-vacuum.0 (23991) Connected
                                          2020-03-27 12:23:12.652 - info: mihome-vacuum.0 (23991) set nächster Timer: Nicht verfügbar
                                          2020-03-27 12:23:15.110 - info: mihome-vacuum.0 (23991) create state for carpet_mode
                                          2020-03-27 12:23:41.038 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:23:41.039 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:23:41.039 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:23:41.299 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:23:41.319 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:23:41.347 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:23:41.566 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:24:41.033 - info: mihome-vacuum.0 (23991) Disconnect
                                          2020-03-27 12:24:41.677 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:24:41.677 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:24:41.677 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:24:41.944 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:24:41.987 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:24:42.025 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:24:42.222 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:25:03.902 - error: host.ioBroker2 Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                                          2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 1: 0x8f9d10 node::Abort() [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 2: 0x8f9d5c [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 3: 0xaffd0e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 4: 0xafff44 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 5: 0xef4152 [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 6: 0xef4258 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 7: 0xf00332 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 8: 0xf00c64 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 9: 0xf038d1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 10: 0xecbbb5 [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 11: 0xed342a v8::internal::Factory::NewRawOneByteString(int, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 12: 0x1203785 v8::internal::IncrementalStringBuilder::Extend() [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 13: 0xfc74f2 v8::internal::JsonStringifier::SerializeString(v8::internal::Handle) [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 14: 0xfc7d9b v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_(v8::internal::Handle, bool, v8::internal::Handle) [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[2]: 15: 0xfccead v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_(v8::internal::Handle, bool, v8::internal::Handle) [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[2]: 16: 0xfcdc09 v8::internal::JsonStringifier::Stringify(v8::internal::Handle, v8::internal::Handle, v8::internal::Handle) [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[3]: 17: 0xbd46d1 v8::internal::Builtin_JsonStringify(int, v8::internal::Object**, v8::internal::Isolate*) [io.mihome-vacuum.0]
                                          2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[3]: 18: 0xbcdda65bf7d
                                          2020-03-27 12:25:03.905 - warn: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                                          2020-03-27 12:25:03.905 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                                          2020-03-27 12:25:03.905 - info: host.ioBroker2 Restart adapter system.adapter.mihome-vacuum.0 because enabled
                                          2020-03-27 12:25:25.848 - info: nut.0 (579) Start NUT update
                                          2020-03-27 12:25:25.949 - info: nut.0 (579) All Nut values set
                                          2020-03-27 12:25:33.930 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 started with pid 26894
                                          2020-03-27 12:25:37.015 - info: mihome-vacuum.0 (26894) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
                                          2020-03-27 12:25:37.080 - info: mihome-vacuum.0 (26894) Expert mode disabled, states deleted
                                          2020-03-27 12:25:37.081 - info: mihome-vacuum.0 (26894) Create state clean_home for controlling by cloud adapter
                                          2020-03-27 12:25:37.093 - info: mihome-vacuum.0 (26894) Disconnect
                                          2020-03-27 12:25:37.132 - info: mihome-vacuum.0 (26894) New generation or new fw detected, create new states goto and zoneclean
                                          2020-03-27 12:25:37.160 - info: mihome-vacuum.0 (26894) Connected
                                          2020-03-27 12:25:37.617 - info: mihome-vacuum.0 (26894) set nächster Timer: Nicht verfügbar
                                          2020-03-27 12:25:42.445 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:25:42.446 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:25:42.446 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:25:42.750 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:25:42.772 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:25:42.789 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:25:42.985 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:25:52.169 - warn: mihome-vacuum.0 (26894) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
                                          2020-03-27 12:26:17.096 - info: mihome-vacuum.0 (26894) Disconnect
                                          2020-03-27 12:26:17.101 - info: mihome-vacuum.0 (26894) Connected
                                          2020-03-27 12:26:43.100 - info: unifi.0 (2203) Starting UniFi-Controller query
                                          2020-03-27 12:26:43.101 - info: unifi.0 (2203) update_interval = 60
                                          2020-03-27 12:26:43.101 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                                          2020-03-27 12:26:43.383 - info: unifi.0 (2203) getSitesStats: default
                                          2020-03-27 12:26:43.396 - info: unifi.0 (2203) getSiteSysinfo: 1
                                          2020-03-27 12:26:43.410 - info: unifi.0 (2203) getClientDevices: 23
                                          2020-03-27 12:26:43.557 - info: unifi.0 (2203) getAccessDevices: 1
                                          2020-03-27 12:26:48.940 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                                          2020-03-27 12:26:57.098 - info: mihome-vacuum.0 (26894) Disconnect
                                          2020-03-27 12:26:57.107 - info: mihome-vacuum.0 (26894) Connected
                                          2020-03-27 12:27:37.102 - info: mihome-vacuum.0 (26894) Disconnect
                                          2020-03-27 12:27:37.157 - info: mihome-vacuum.0 (26894) Connected
                                          Ein Memory-Problem sollte ich eigentlich nicht haben mit 3,5 GB
                                            dirkhe Developer @Kueppert last edited by
                                            @Kueppert das kommt ja regelmäßig. Was mich wundert ist, dass er ständig disconnected. Kannst du mal die aktuelle Version installieren, bitte? Dann mal auf Debug stellen. Das sieht aus wie eine recursion, aber aktuell weiß ich gar nicht, wo das sein könnte. Allerdings bin ich beim abrufen der Karte auch nicht so tief im Code.
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            493867
