    4. Test Adapter VW Connect für VW, ID, Audi, Seat, Skoda
      tombox @tf last edited by
      @tf bei dem 406 wäre gut zu wissen was in debug vorher und nachher angezeigt
        tf @tombox last edited by
        @tombox Im "info" modus das Folgende:
        vw-connect.0 2020-03-15 21:50:12.778 error (6729) 406
        vw-connect.0 2020-03-15 21:50:08.700 info (6729) starting. Version 0.0.11 in /opt/iobroker/node_modules/iobroker.vw-connect, node: v10.19.0
        Im "debug" Modus wie in meiner vorletzten Mail:
        vw-connect.0 2020-03-15 21:16:52.321 debug (6455) 400
        vw-connect.0 2020-03-15 21:16:52.319 debug (6455) error while getting https://msg.volkswagen.de/fs-car/bs/rs/v1/$type/$country/vehicles/$vin/status
        vw-connect.0 2020-03-15 21:16:52.318 debug (6455) 502
        vw-connect.0 2020-03-15 21:16:51.973 debug (6455) {"CurrentVehicleDataResponse":{"requestId":"57619337","vin":"TMBxxxx"}}
        vw-connect.0 2020-03-15 21:16:51.072 error (6455) 406
        vw-connect.0 2020-03-15 21:16:50.785 debug (6455) {"userVehicles":{"vehicle":["TMBxxxxxx"]}}
        vw-connect.0 2020-03-15 21:16:50.502 debug (6455) {"firstName":"xx","lastName":"xx","salutation":"SALUTATION:MR","dateOfBirth":"xx","nickname":"xx","businessIdentifierType":"BUSINESS_IDENTIFIER_TYPE:MBB_ID","businessIdentifier
        vw-connect.0 2020-03-15 21:16:50.269 debug (6455) getData
        vw-connect.0 2020-03-15 21:16:50.267 debug (6455) Login successful
        vw-connect.0 2020-03-15 21:16:49.531 debug (6455) Error: Invalid protocol: skodaconnect:
        vw-connect.0 2020-03-15 21:16:48.792 debug (6455) {"date":"Sun, 15 Mar 2020 20:16:48 GMT","content-length":"0","connection":"close","cache-control":"no-cache, no-store, max-age=0, must-revalidate","content-language":"en","expires":"0","locatio
        vw-connect.0 2020-03-15 21:16:48.791 debug (6455) ""
        vw-connect.0 2020-03-15 21:16:48.396 debug (6455) parsePasswordForm
        vw-connect.0 2020-03-15 21:16:47.923 debug (6455) parseEmailForm
        • Wszene
          Wszene @opossum last edited by
          @opossum
          Hallo opossum,
          ich bin jetzt auch im Besitz eines Fahrzeugs welches die Funktion hat.
          Darf ich dich mal Fragen ob du mir evtl. zur Anregung und zur Funktionserkennung deine Vis zur verfügung stellen kannst.
          Ich wäre dir sehr Dankbar.
          Marcel
            fuchs1978 last edited by
            Wir es in absehbarer Zeit auch die Unterstützung für Seat Connect geben? Die App und Webseite sind jetzt ja online.
              tombox @fuchs1978 last edited by
              @fuchs1978 bräuchte ich kurzzeitig Zugang zu einem Account um das aufzunehmen
                fuchs1978 @tombox last edited by
                @tombox said in Test Adapter VW Connect v0.0.x:
                Ich habe leider noch kein Auto, daher kann ich nicht helfen 😭
                • Wszene
                  Wszene last edited by
                  Ich habe im Log immer folgende Fehler
                  vw-connect.0	2020-03-25 21:50:25.707	error	(1740) 400
                  vw-connect.0	2020-03-25 21:50:25.706	error	(1740) Failing to refresh token.
                  Hat jemand eine Idee wie ich diese wegbekomme?
                  Danke im Voraus
                  Marcel
                    tombox @Wszene last edited by
                    @Wszene sollte nicht passieren du kannst den Adapter mal im debug setzen und mir den log im den Fehler herum per PN zusenden bzw sagen wie oft es passiert. unter Instanzen Experten Modus einstellen und dann log Level auf debug setzen.
                    Wszene 1 Reply Last reply Reply Quote 0
                    • Wszene
                      Wszene @tombox last edited by
                      @tombox
                      Ich finde leider nicht wo ich das debugen einschalten kann
                        @Wszene Auf das rote Symbol klicken und dann unter log level einstellen
                        • Wszene
                          Wszene @tombox last edited by Wszene
                          @tombox
                          OK habe ich gefunden
                          Werde dir heute Abend das Log zukommen lassen
                          EDIT:
                          Log via PN
                            @Wszene Bitte lösche den Log und schicke mir logs nur per pn
                            ich brauch den log wenn der 400 error mit dem refresh token kommt
                              Bourne @opossum last edited by
                              @opossum wie hast du es bei den Türen umgesetzt, das statt 1, 2 oder 3 dann z.B. geschlossen, offen oder verriegelt ausgegeben wird?
                              • opossum
                                Hallo, @Bourne ,
                                anbei mal dazu ein Screenshot:
                                  Bourne @opossum last edited by Bourne
                                  @opossum ok, danke, hab es mal so übernommen. mein Problem ist jetzt, dass der Text nicht angezeigt wird 😞
                                  Edit: Text wird jetzt angezeigt, ohne das ich was geändert habe, komisch.
                                    @opossum said in Test Adapter VW Connect v0.0.x:
                                    Hallo, @Bourne ,
                                    Nun habe ich ein weiteres Problem mit der Map-Anzeige.
                                    Bekomme immer die Fehlermeldung im widget:
                                    "Google Maps kann auf dieser Seite nicht richtig geladen werden."
                                    Habe Api-Schlüssel erstellt und eingetragen wo es erforderlich ist.
                                    Muss ich jetzt noch irgendwas anderes bei google oder im iobroker einstellen?
                                    • cvidal
                                      Hi, ich habe vorhin mein System auf NodeJS 12 geupdatet, leider läuft der Adapter damit noch nicht.
                                      Ist es in nächster Zeit geplant das der Adapter mit NodeJS 12 läuft oder sollte ich erst wieder auf Version 10 gehen?
                                      Folgendes sagt mein Log:
                                      host.IoBroker	2020-04-14 14:15:58.343	info	Restart adapter system.adapter.vw-connect.0 because enabled
                                      host.IoBroker	2020-04-14 14:15:58.343	error	instance system.adapter.vw-connect.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      host.IoBroker	2020-04-14 14:15:58.343	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
                                      host.IoBroker	2020-04-14 14:15:58.343	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                                      host.IoBroker	2020-04-14 14:15:58.343	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
                                      host.IoBroker	2020-04-14 14:15:58.342	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1156:30)
                                      host.IoBroker	2020-04-14 14:15:58.342	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/canvas/lib/bindings.js:3:18)
                                      host.IoBroker	2020-04-14 14:15:58.342	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                                      host.IoBroker	2020-04-14 14:15:58.342	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1042:19)
                                      host.IoBroker	2020-04-14 14:15:58.342	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:899:14)
                                      host.IoBroker	2020-04-14 14:15:58.342	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:1000:32)
                                      host.IoBroker	2020-04-14 14:15:58.342	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1206:18)
                                      host.IoBroker	2020-04-14 14:15:58.341	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                      host.IoBroker	2020-04-14 14:15:58.341	error	Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                      host.IoBroker	2020-04-14 14:15:58.341	error	Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                      host.IoBroker	2020-04-14 14:15:58.341	error	Caught by controller[0]: was compiled against a different Node.js version using
                                      host.IoBroker	2020-04-14 14:15:58.341	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/canvas/build/Release/canvas.node'
                                      host.IoBroker	2020-04-14 14:15:58.341	error	Caught by controller[0]: ^
                                      host.IoBroker	2020-04-14 14:15:58.340	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                                      host.IoBroker	2020-04-14 14:15:58.340	error	Caught by controller[0]: internal/modules/cjs/loader.js:1206
                                      host.IoBroker	2020-04-14 14:15:57.905	info	instance system.adapter.vw-connect.0 started with pid 18419
                                      host.IoBroker	2020-04-14 14:15:57.883	info	"system.adapter.vw-connect.0" enabled
                                        tombox @cvidal last edited by
                                        @cvidal Hast du auch rebuild ausgeführt? es scheint so als müsste etwas neugebaut werden für den Adapter. Neuinstallation könnte vielleicht auch schon helfen?
                                        cvidal 1 Reply Last reply Reply Quote 0
                                        • cvidal
                                          cvidal Forum Testing @tombox last edited by
                                          @tombox Neuinstallation hilft hier nicht bei npm rebuild bekomme ich Errors mit denen ich nicht weiterkomme.
                                          root@IoBroker:/home/christian# cd /opt/iobroker
                                          root@IoBroker:/opt/iobroker# npm rebuild
                                          iobroker.js-controller@2.2.9 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                          node lib/preinstallCheck.js
                                          NPM version: 6.14.4
                                          iobroker.js-controller@2.2.9 install /opt/iobroker/node_modules/iobroker.js-controller
                                          node iobroker.js setup first
                                          acme-v2@1.8.6 postinstall /opt/iobroker/node_modules/acme-v2
                                          node scripts/postinstall
                                          Greenlock and ACME.js v3 are on the way!
                                          Watch for updates at https://indiegogo.com/at/greenlock
                                          authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
                                          node-gyp rebuild
                                          make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
                                          CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
                                          ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
                                          ../authenticate_pam.cc:107:87: warning: ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value*)’ is deprecated [-Wdeprecated-declarations]
                                          keCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
                                          In file included from ../authenticate_pam.cc:23:0:
                                          ../../nan/nan.h:1024:46: note: declared here
                                          NAN_DEPRECATED inline v8::Localv8::Value MakeCallback(
                                          ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
                                          ../authenticate_pam.cc:147:83: warning: ‘v8::Localv8::Value v8::Object::Get(v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declaration ]
                                          al<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
                                          In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8-internal.h:14:0,
                                          from /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:27,
                                          from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:67,
                                          from ../../nan/nan.h:54,
                                          /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:3553:51: note: declared here
                                          V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
                                          /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
                                          declarator attribute((deprecated(message)))
                                          ../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
                                          serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
                                          In file included from /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:67:0,
                                          /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2878:7: note: candidate: int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const
                                          int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
                                          /home/iobroker/.cache/node-gyp/12.16.2/include/node/v8.h:2878:7: note: no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
                                          ../authenticate_pam.cc:152:69: warning: ‘v8::Localv8::Value v8::Object::Get(v8::Localv8::Value)’ is deprecated: Use maybe version [-Wdeprecated-declaration ]
                                          res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
                                          ../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
                                          remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
                                          ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
                                          username->WriteUtf8(m->username, sizeof(m->username) - 1);
                                          ../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], long unsigned int)’
                                          password->WriteUtf8(m->password, sizeof(m->password) - 1);
                                          ../authenticate_pam.cc: At global scope:
                                          ../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void
                                          void init(Handle<Object> exports) {
                                          ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
                                          ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
                                          ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
                                          In file included from ../../nan/nan.h:54:0,
                                          ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope
                                          NODE_MODULE(authenticate_pam, init);
                                          /home/iobroker/.cache/node-gyp/12.16.2/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’
                                          (node::addon_register_func) (regfunc),
                                          ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
                                          authenticate_pam.target.mk:111: die Regel für Ziel „Release/obj.target/authenticate_pam/authenticate_pam.o“ scheiterte
                                          make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
                                          make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
                                          gyp ERR! build error
                                          gyp ERR! stack Error: make failed with exit code: 2
                                          gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
                                          gyp ERR! stack at ChildProcess.emit (events.js:310:20)
                                          gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
                                          gyp ERR! System Linux 4.9.0-11-amd64
                                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                          gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
                                          gyp ERR! node -v v12.16.2
                                          gyp ERR! node-gyp -v v5.1.0
                                          gyp ERR! not ok
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! errno 1
                                          npm ERR! authenticate-pam@1.0.2 install: node-gyp rebuild
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the authenticate-pam@1.0.2 install script.
                                          npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                                          npm ERR! /home/iobroker/.npm/_logs/2020-04-14T20_19_29_910Z-debug.log
                                          • Wszene
                                            Hallo Zusammen,
                                            Ich bekomme seid dem 24.04 keine Daten mehr
                                            Das heist in der App wird alles aktualisiert aber im ioBroker nicht
                                            Marcel
                                            1.0k
                                            audi id.3 myaudi seat skoda skoda connect volkswagen vw id we connect wecharge
                                            399
                                            3091
                                            1603700
