    4. Test Adapter mihome-vacuum v2.0.x
      Kueppert last edited by
      Hi zusammen,
      ich hatte gerade nachdem mein Saugi fertig war mit saugen, eine 100% CPU-Auslastung. Ich hatte folgendes im Log:
      host.ioBroker2	2020-03-27 12:22:38.108	info	Restart adapter system.adapter.mihome-vacuum.0 because enabled
      host.ioBroker2	2020-03-27 12:22:38.108	info	instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
      host.ioBroker2	2020-03-27 12:22:38.107	warn	instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
      host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[13]: 17: 0x1de16585a2e1
      host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[13]: 16: 0x9193fb [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[12]: 15: 0x9c4c33 node::StringBytes::Write(v8::Isolate*, char*, unsigned long, v8::Local<v8::Value>, node::encoding, int*) [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[11]: 14: 0xb2a2a1 v8::String::Value::Value(v8::Isolate*, v8::Local<v8::Value>) [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[10]: 13: 0xafd334 v8::internal::String::Flatten(v8::internal::Handle<v8::internal::String>, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[9]: 12: 0x101ce9d v8::internal::String::SlowFlatten(v8::internal::Handle<v8::internal::ConsString>, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[8]: 11: 0xed342a v8::internal::Factory::NewRawOneByteString(int, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[7]: 10: 0xecbbb5 [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[6]: 9: 0xf038d1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.107	error	Caught by controller[5]: 8: 0xf00c64 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[4]: 7: 0xf00332 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[3]: 6: 0xef4258 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[2]: 5: 0xef4152 [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 4: 0xafff44 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 3: 0xaffd0e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 2: 0x8f9d5c [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.106	error	Caught by controller[1]: 1: 0x8f9d10 node::Abort() [io.mihome-vacuum.0]
      host.ioBroker2	2020-03-27 12:22:38.105	error	Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
      Ist das erste Mal aufgetreten heute O.o
      D H 2 Replies Last reply Reply Quote 0
        dirkhe Developer @Kueppert last edited by
        @Kueppert könntest du noch ein bisschen mehr Log Posten, bevor das passiert ist?
        K 2 Replies Last reply Reply Quote 0
          Kueppert @dirkhe last edited by
          @dirkhe nur die Einträge aus dem log, die mit dem Adapter zu tun haben? Oder einfach einen Auszug von heute als Dateianhang?
            @dirkhe hab noch was gefunden, das ggf. weiterhilft:
            2020-03-27 12:06:16.826 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:16 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8822e208-397d-ca1f-0000-01711babce13","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:06:19.839 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:19 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"5b505204-c47a-87cb-0000-01711babdafa","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:06:23.153 - info: mihome-vacuum.0 (780) Disconnect
            2020-03-27 12:06:23.300 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:23 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"68e38ade-5a0d-cfb2-0000-01711babe751","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:06:26.325 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:26 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8649174a-c919-a08e-0000-01711babf304","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:06:29.371 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:29 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"ec138f99-5fef-ac1a-0000-01711babff18","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:06:30.137 - info: unifi.0 (2203) Starting UniFi-Controller query
            2020-03-27 12:06:30.138 - info: unifi.0 (2203) update_interval = 60
            2020-03-27 12:06:30.138 - info: unifi.0 (2203) controller = 192.168.178.71:8443
            2020-03-27 12:06:30.434 - info: unifi.0 (2203) getSitesStats: default
            2020-03-27 12:06:30.453 - info: unifi.0 (2203) getSiteSysinfo: 1
            2020-03-27 12:06:30.472 - info: unifi.0 (2203) getClientDevices: 22
            2020-03-27 12:06:30.684 - info: unifi.0 (2203) getAccessDevices: 1
            2020-03-27 12:06:32.426 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:32 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"349d92a7-bf60-22a9-0000-01711bac0b51","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:06:35.736 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:35 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"a7f090d2-a1ff-3817-0000-01711bac180b","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:06:39.023 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:38 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"33042f81-515d-efc9-0000-01711bac25fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:06:42.113 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:41 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f930393c-6d79-c7ad-0000-01711bac31af","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:06:43.153 - info: mihome-vacuum.0 (780) Disconnect
            2020-03-27 12:06:45.389 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:45 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f549b8fd-cb30-333c-0000-01711bac3e3a","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:06:48.626 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:48 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"afe7d6f9-52ff-75ff-0000-01711bac4a6d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:06:48.631 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
            2020-03-27 12:06:52.019 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:51 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"01962472-7526-84f1-0000-01711bac58cd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:06:55.014 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:54 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"addcf6aa-172a-d7c0-0000-01711bac637c","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:06:58.346 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:58 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"37bc4ae2-30bf-d082-0000-01711bac701f","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:07:01.341 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:01 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"b9a60d2c-943f-7a23-0000-01711bac7c21","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:07:03.155 - info: mihome-vacuum.0 (780) Disconnect
            2020-03-27 12:07:04.595 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:04 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"0f1c5fc0-fe2c-85b2-0000-01711bac89fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:07:07.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:07 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"67576ec9-5750-92b1-0000-01711bac9560","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:07:10.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:10 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"03737cb1-32cb-595c-0000-01711baca111","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:07:14.189 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:14 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8a047e9d-2efe-578c-0000-01711bacae2d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:07:17.174 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:17 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2a63601a-70f8-7946-0000-01711bacbaa4","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
            2020-03-27 12:07:23.156 - info: mihome-vacuum.0 (780) Disconnect
              dirkhe Developer last edited by
              Eigentlich reichen die Zeilen vorher vom Adapter. Wenn aber davor andere Sachen auch verrückt spielen oder da eine Menge los war, ist das vlt auch sinnvoll. Man kann an dem Log nicht erkennen, wo das ganze aufgetreten ist
                Hyperbit @Kueppert last edited by
                @Kueppert läuft das bei dir auf einem Raspberry?
                Ich lese da Out of Memory und interpretiere da hinein das der Prozess dann abgeschossen wurde (ist aber nur ein schneller Blick auf die deinen Logauszug vom Handy aus).
                Lg
                  @Kueppert hier ist er gar nicht mit dem robbi verbunden. Irgendwann müsste dann auch noch ein Connect kommen.
                    @dirkhe hab nochmal mehr logging über einen längeren Zeitraum hier angefügt:
                    2020-03-27 11:35:22.125 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:35:25.829 - info: nut.0 (579) Start NUT update
                    2020-03-27 11:35:25.842 - info: nut.0 (579) All Nut values set
                    2020-03-27 11:35:26.171 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:35:34.549 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:35:42.176 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:35:46.727 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:35:54.377 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:36:06.046 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:36:12.678 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:36:12.679 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:36:12.679 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:36:12.946 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:36:12.963 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:36:12.979 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:36:13.132 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:36:13.348 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:36:17.454 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:36:42.170 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:36:48.611 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                    2020-03-27 11:36:54.786 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:37:05.891 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:37:11.345 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:37:13.197 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:37:13.198 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:37:13.198 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:37:13.492 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:37:13.506 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:37:13.520 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:37:13.633 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:37:14.833 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:37:25.149 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:37:34.711 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:37:39.452 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:37:42.708 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:37:46.689 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:37:50.176 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:37:53.559 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:37:57.080 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:38:04.140 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:38:07.533 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:38:10.774 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:38:13.712 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:38:13.712 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:38:13.712 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:38:13.957 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:38:13.961 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:38:13.971 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:38:13.985 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:38:14.106 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:38:20.958 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:38:25.256 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:38:35.222 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:38:38.625 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:38:41.670 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:38:55.343 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:38:58.593 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:39:02.020 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:39:05.311 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:39:08.707 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:39:11.964 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:39:14.181 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:39:14.182 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:39:14.182 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:39:14.435 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:39:14.459 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:39:14.482 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:39:14.695 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:39:18.782 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:39:24.201 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:39:27.647 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:39:31.150 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:39:34.295 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:39:38.334 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:39:41.816 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:39:45.382 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:39:48.586 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:39:51.843 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:39:58.839 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:40:02.025 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:40:08.908 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:40:12.409 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:40:14.788 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:40:14.789 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:40:14.789 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:40:15.055 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:40:15.084 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:40:15.108 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:40:15.298 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:40:15.801 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:40:22.858 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:40:25.831 - info: nut.0 (579) Start NUT update
                    2020-03-27 11:40:25.845 - info: nut.0 (579) All Nut values set
                    2020-03-27 11:40:26.137 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:40:29.554 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:40:36.245 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:40:50.405 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                    2020-03-27 11:40:52.555 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                    2020-03-27 11:40:52.989 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:40:56.217 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:40:59.538 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:41:09.693 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:41:12.973 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:41:15.444 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:41:15.444 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:41:15.444 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:41:15.713 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:41:15.733 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:41:15.751 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:41:15.918 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:41:19.465 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:41:47.585 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:41:48.614 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                    2020-03-27 11:41:51.106 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:41:54.358 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:42:01.150 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:42:11.353 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:42:15.881 - warn: sonoff.0 (636) Client "Sonoff-S10-Wohnzimmer" not connected
                    2020-03-27 11:42:16.056 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:42:16.056 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:42:16.056 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:42:16.323 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:42:16.362 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:42:16.389 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:42:16.636 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:42:18.361 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:42:38.243 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:42:45.019 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:42:55.433 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:42:58.594 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:43:05.420 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:43:11.802 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:43:16.732 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:43:16.733 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:43:16.733 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:43:17.032 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:43:17.058 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:43:17.078 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:43:17.249 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:43:35.351 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:43:42.064 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:44:02.001 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:44:05.570 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:44:12.313 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:44:17.329 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:44:17.329 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:44:17.329 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:44:17.577 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:44:17.591 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:44:17.606 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:44:17.743 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:44:18.857 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:44:22.494 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:44:29.048 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:44:32.361 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:44:42.700 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:44:49.464 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:44:52.764 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:44:56.369 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:44:59.952 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:45:00.022 - info: host.ioBroker2 instance system.adapter.daswetter.0 started with pid 11811
                    2020-03-27 11:45:01.781 - info: daswetter.0 (11811) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.0
                    2020-03-27 11:45:02.610 - info: daswetter.0 (11811) Terminated (NO_ERROR): Without reason
                    2020-03-27 11:45:03.120 - info: host.ioBroker2 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                    2020-03-27 11:45:03.539 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:45:06.746 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:45:13.481 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:45:17.084 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:45:17.844 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:45:17.845 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:45:17.845 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:45:18.080 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:45:18.100 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:45:18.116 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:45:18.251 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:45:20.666 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:45:24.057 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:45:25.833 - info: nut.0 (579) Start NUT update
                    2020-03-27 11:45:25.852 - info: nut.0 (579) All Nut values set
                    2020-03-27 11:45:30.813 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:45:34.324 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:45:37.919 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:45:44.784 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:45:48.191 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:45:51.802 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:45:55.321 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:45:58.884 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:46:02.372 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:46:08.897 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:46:12.532 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:46:18.340 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:46:18.341 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:46:18.341 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:46:18.633 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:46:18.655 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:46:18.672 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:46:18.862 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:46:19.486 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:46:23.016 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:46:30.061 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:46:34.097 - info: info.0 (855) Popup news was read...
                    2020-03-27 11:46:37.139 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:46:40.494 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:46:43.695 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:46:47.796 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                    2020-03-27 11:46:48.617 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                    2020-03-27 11:46:49.998 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                    2020-03-27 11:46:50.524 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:46:53.865 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:46:57.326 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:47:00.643 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:47:08.240 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:47:15.347 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:47:19.006 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:47:19.007 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:47:19.007 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:47:19.293 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:47:19.316 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:47:19.335 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:47:19.488 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:47:22.019 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:47:28.878 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:47:35.391 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:47:40.287 - info: web-speedy.0 (2583) Execute timer with : 1800000 Currently running : false
                    2020-03-27 11:47:40.288 - info: web-speedy.0 (2583) Run test on on Best Server found
                    2020-03-27 11:47:40.292 - info: web-speedy.0 (2583) The speed test has been started and will take at maximum 30 seconds for a single test run
                    2020-03-27 11:47:42.062 - info: web-speedy.0 (2583) Closest server found, running test
                    2020-03-27 11:47:56.668 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:48:00.376 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:48:07.741 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:48:19.569 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:48:19.570 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:48:19.570 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:48:19.837 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:48:19.852 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:48:19.870 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:48:20.037 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:48:41.515 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:48:44.973 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:48:46.231 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.download_Mb, Alias=false
                    2020-03-27 11:48:46.233 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.upload_Mb, Alias=false
                    2020-03-27 11:48:46.267 - info: web-speedy.0 (2583) The speed test has been completed successfully.
                    2020-03-27 11:48:55.771 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:48:59.039 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:49:06.111 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:49:09.562 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:49:12.898 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:49:16.380 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:49:20.187 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:49:20.188 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:49:20.188 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:49:20.438 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:49:20.461 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:49:20.485 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:49:20.639 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:49:26.764 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:49:47.270 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:49:50.761 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:50:08.038 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:50:15.685 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:50:20.725 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:50:20.726 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:50:20.726 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:50:21.037 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:50:21.059 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:50:21.071 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:50:21.177 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:50:22.688 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:50:25.834 - info: nut.0 (579) Start NUT update
                    2020-03-27 11:50:25.854 - info: nut.0 (579) All Nut values set
                    2020-03-27 11:50:57.626 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                    2020-03-27 11:51:21.298 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:51:21.298 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:51:21.298 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:51:21.565 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:51:21.582 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:51:21.609 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 11:51:21.849 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:51:22.830 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:51:42.831 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:51:48.621 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                    2020-03-27 11:52:02.833 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:52:21.967 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:52:21.968 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:52:21.968 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:52:22.242 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:52:22.270 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:52:22.291 - info: unifi.0 (2203) getClientDevices: 22
                    2020-03-27 11:52:22.501 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:52:22.834 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:52:42.835 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:52:47.306 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                    2020-03-27 11:52:49.619 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                    2020-03-27 11:53:02.837 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:53:22.645 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:53:22.646 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:53:22.646 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:53:22.839 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:53:22.902 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:53:22.916 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:53:22.931 - info: unifi.0 (2203) getClientDevices: 22
                    2020-03-27 11:53:23.107 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:53:42.839 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:54:02.841 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:54:22.842 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:54:23.220 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:54:23.220 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:54:23.220 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:54:23.468 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:54:23.498 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:54:23.516 - info: unifi.0 (2203) getClientDevices: 22
                    2020-03-27 11:54:23.660 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:54:42.843 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:55:02.843 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:55:22.844 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:55:23.758 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:55:23.759 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:55:23.759 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:55:24.018 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:55:24.038 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:55:24.056 - info: unifi.0 (2203) getClientDevices: 22
                    2020-03-27 11:55:24.195 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:55:25.835 - info: nut.0 (579) Start NUT update
                    2020-03-27 11:55:25.848 - info: nut.0 (579) All Nut values set
                    2020-03-27 11:55:42.846 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:56:02.846 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:56:22.848 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:56:24.290 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:56:24.290 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:56:24.291 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:56:24.550 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:56:24.582 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:56:24.611 - info: unifi.0 (2203) getClientDevices: 22
                    2020-03-27 11:56:24.744 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:56:42.849 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:56:48.623 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                    2020-03-27 11:57:02.851 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:57:22.852 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:57:24.830 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:57:24.831 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:57:24.831 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:57:25.151 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:57:25.175 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:57:25.216 - info: unifi.0 (2203) getClientDevices: 22
                    2020-03-27 11:57:25.375 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:57:42.852 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:58:02.854 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:58:22.855 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:58:25.493 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:58:25.494 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:58:25.494 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:58:25.797 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:58:25.816 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:58:25.842 - info: unifi.0 (2203) getClientDevices: 22
                    2020-03-27 11:58:26.091 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:58:43.077 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:58:47.481 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                    2020-03-27 11:58:49.626 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                    2020-03-27 11:59:03.079 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:59:23.079 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 11:59:26.196 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 11:59:26.196 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 11:59:26.196 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 11:59:26.439 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 11:59:26.459 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 11:59:26.497 - info: unifi.0 (2203) getClientDevices: 22
                    2020-03-27 11:59:26.634 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 11:59:43.081 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:00:00.023 - info: host.ioBroker2 instance system.adapter.daswetter.0 started with pid 29088
                    2020-03-27 12:00:01.676 - info: daswetter.0 (29088) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.0
                    2020-03-27 12:00:02.358 - info: daswetter.0 (29088) Terminated (NO_ERROR): Without reason
                    2020-03-27 12:00:02.868 - info: host.ioBroker2 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                    2020-03-27 12:00:03.125 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:00:04.040 - info: host.ioBroker2 instance system.adapter.ical.0 started with pid 29255
                    2020-03-27 12:00:14.339 - info: host.ioBroker2 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                    2020-03-27 12:00:23.126 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:00:25.836 - info: nut.0 (579) Start NUT update
                    2020-03-27 12:00:25.848 - info: nut.0 (579) All Nut values set
                    2020-03-27 12:00:26.716 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:00:26.716 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:00:26.716 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:00:27.029 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:00:27.046 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:00:27.068 - info: unifi.0 (2203) getClientDevices: 22
                    2020-03-27 12:00:27.207 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:00:43.127 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:01:03.128 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:01:23.130 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:01:27.323 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:01:27.323 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:01:27.324 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:01:27.619 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:01:27.640 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:01:27.667 - info: unifi.0 (2203) getClientDevices: 22
                    2020-03-27 12:01:27.822 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:01:43.130 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:01:48.627 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                    2020-03-27 12:02:03.136 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:02:23.137 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:02:27.898 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:02:27.898 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:02:27.898 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:02:28.239 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:02:28.254 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:02:28.269 - info: unifi.0 (2203) getClientDevices: 22
                    2020-03-27 12:02:28.387 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:02:43.138 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:02:48.401 - info: javascript.0 (459) script.js.common.Sonstiges.TürenFenster-TextSkript: TürenFenster_getriggert
                    2020-03-27 12:03:03.139 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:03:23.141 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:03:28.462 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:03:28.463 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:03:28.463 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:03:28.758 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:03:28.775 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:03:28.790 - info: unifi.0 (2203) getClientDevices: 22
                    2020-03-27 12:03:28.962 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:03:43.142 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:04:03.143 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:04:23.144 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:04:29.045 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:04:29.045 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:04:29.045 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:04:29.312 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:04:29.326 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:04:29.339 - info: unifi.0 (2203) getClientDevices: 22
                    2020-03-27 12:04:29.464 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:04:43.145 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:04:51.465 - info: javascript.0 (459) script.js.common.Sonstiges.TürenFenster-TextSkript: TürenFenster_getriggert
                    2020-03-27 12:05:03.147 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:05:23.149 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:05:25.837 - info: nut.0 (579) Start NUT update
                    2020-03-27 12:05:25.851 - info: nut.0 (579) All Nut values set
                    2020-03-27 12:05:29.557 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:05:29.557 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:05:29.557 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:05:29.873 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:05:29.886 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:05:29.905 - info: unifi.0 (2203) getClientDevices: 22
                    2020-03-27 12:05:30.022 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:05:43.151 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:06:03.151 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:06:16.826 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:16 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8822e208-397d-ca1f-0000-01711babce13","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:06:19.839 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:19 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"5b505204-c47a-87cb-0000-01711babdafa","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:06:23.153 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:06:23.300 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:23 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"68e38ade-5a0d-cfb2-0000-01711babe751","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:06:26.325 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:26 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8649174a-c919-a08e-0000-01711babf304","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:06:29.371 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:29 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"ec138f99-5fef-ac1a-0000-01711babff18","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:06:30.137 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:06:30.138 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:06:30.138 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:06:30.434 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:06:30.453 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:06:30.472 - info: unifi.0 (2203) getClientDevices: 22
                    2020-03-27 12:06:30.684 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:06:32.426 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:32 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"349d92a7-bf60-22a9-0000-01711bac0b51","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:06:35.736 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:35 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"a7f090d2-a1ff-3817-0000-01711bac180b","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:06:39.023 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:38 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"33042f81-515d-efc9-0000-01711bac25fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:06:42.113 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:41 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f930393c-6d79-c7ad-0000-01711bac31af","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:06:43.153 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:06:45.389 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:45 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f549b8fd-cb30-333c-0000-01711bac3e3a","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:06:48.626 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:48 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"afe7d6f9-52ff-75ff-0000-01711bac4a6d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:06:48.631 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                    2020-03-27 12:06:52.019 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:51 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"01962472-7526-84f1-0000-01711bac58cd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:06:55.014 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:54 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"addcf6aa-172a-d7c0-0000-01711bac637c","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:06:58.346 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:58 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"37bc4ae2-30bf-d082-0000-01711bac701f","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:07:01.341 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:01 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"b9a60d2c-943f-7a23-0000-01711bac7c21","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:07:03.155 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:07:04.595 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:04 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"0f1c5fc0-fe2c-85b2-0000-01711bac89fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:07:07.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:07 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"67576ec9-5750-92b1-0000-01711bac9560","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:07:10.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:10 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"03737cb1-32cb-595c-0000-01711baca111","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:07:14.189 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:14 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8a047e9d-2efe-578c-0000-01711bacae2d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:07:17.174 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:17 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2a63601a-70f8-7946-0000-01711bacbaa4","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                    2020-03-27 12:07:23.156 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:07:30.808 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:07:30.808 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:07:30.809 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:07:31.071 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:07:31.090 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:07:31.114 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:07:31.278 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:08:31.361 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:08:31.362 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:08:31.362 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:08:31.689 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:08:31.706 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:08:31.724 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:08:31.886 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:09:31.986 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:09:31.987 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:09:31.987 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:09:32.323 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:09:32.341 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:09:32.358 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:09:32.498 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:10:25.838 - info: nut.0 (579) Start NUT update
                    2020-03-27 12:10:25.851 - info: nut.0 (579) All Nut values set
                    2020-03-27 12:10:32.591 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:10:32.591 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:10:32.591 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:10:32.877 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:10:32.898 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:10:32.914 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:10:33.041 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:10:47.363 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                    2020-03-27 12:10:49.501 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                    2020-03-27 12:11:33.116 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:11:33.116 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:11:33.116 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:11:33.434 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:11:33.456 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:11:33.486 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:11:33.626 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:11:48.633 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                    2020-03-27 12:12:33.713 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:12:33.713 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:12:33.713 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:12:34.034 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:12:34.049 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:12:34.067 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:12:34.186 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:12:59.391 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                    2020-03-27 12:13:01.572 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                    2020-03-27 12:13:34.264 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:13:34.264 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:13:34.264 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:13:34.591 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:13:34.606 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:13:34.620 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:13:34.749 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:14:34.825 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:14:34.826 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:14:34.826 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:14:35.119 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:14:35.147 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:14:35.170 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:14:35.371 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:15:00.026 - info: host.ioBroker2 instance system.adapter.daswetter.0 started with pid 14507
                    2020-03-27 12:15:01.858 - info: daswetter.0 (14507) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.0
                    2020-03-27 12:15:02.856 - info: daswetter.0 (14507) Terminated (NO_ERROR): Without reason
                    2020-03-27 12:15:03.366 - info: host.ioBroker2 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                    2020-03-27 12:15:25.840 - info: nut.0 (579) Start NUT update
                    2020-03-27 12:15:25.853 - info: nut.0 (579) All Nut values set
                    2020-03-27 12:15:35.479 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:15:35.480 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:15:35.480 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:15:35.754 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:15:35.770 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:15:35.788 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:15:35.950 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:16:34.114 - info: info.0 (855) Popup news was read...
                    2020-03-27 12:16:36.046 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:16:36.046 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:16:36.047 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:16:36.292 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:16:36.318 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:16:36.337 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:16:36.473 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:16:48.635 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                    2020-03-27 12:17:36.548 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:17:36.548 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:17:36.549 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:17:36.790 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:17:36.806 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:17:36.824 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:17:36.953 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:17:40.294 - info: web-speedy.0 (2583) Execute timer with : 1800000 Currently running : false
                    2020-03-27 12:17:40.295 - info: web-speedy.0 (2583) Run test on on Best Server found
                    2020-03-27 12:17:40.299 - info: web-speedy.0 (2583) The speed test has been started and will take at maximum 30 seconds for a single test run
                    2020-03-27 12:17:42.155 - info: web-speedy.0 (2583) Closest server found, running test
                    2020-03-27 12:18:37.039 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:18:37.040 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:18:37.040 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:18:37.300 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:18:37.317 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:18:37.331 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:18:37.481 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:18:44.897 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.download_Mb, Alias=false
                    2020-03-27 12:18:44.901 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.upload_Mb, Alias=false
                    2020-03-27 12:18:44.924 - info: web-speedy.0 (2583) The speed test has been completed successfully.
                    2020-03-27 12:19:03.197 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:19:03.205 - info: mihome-vacuum.0 (780) Connected
                    2020-03-27 12:19:37.593 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:19:37.594 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:19:37.594 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:19:37.931 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:19:37.963 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:19:37.994 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:19:38.324 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:20:25.841 - info: nut.0 (579) Start NUT update
                    2020-03-27 12:20:25.869 - info: nut.0 (579) All Nut values set
                    2020-03-27 12:20:27.984 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:20:38.626 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:20:38.627 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:20:38.627 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:20:38.929 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:20:38.949 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:20:38.967 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:20:39.175 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:20:49.946 - info: mihome-vacuum.0 (780) Disconnect
                    2020-03-27 12:21:39.360 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:21:39.381 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:21:39.381 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:21:39.862 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:21:39.886 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:21:39.910 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:21:40.081 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:21:48.651 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                    2020-03-27 12:22:38.105 - error: host.ioBroker2 Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                    2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 1: 0x8f9d10 node::Abort() [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 2: 0x8f9d5c [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 3: 0xaffd0e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 4: 0xafff44 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[2]: 5: 0xef4152 [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[3]: 6: 0xef4258 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[4]: 7: 0xf00332 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[5]: 8: 0xf00c64 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[6]: 9: 0xf038d1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[7]: 10: 0xecbbb5 [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[8]: 11: 0xed342a v8::internal::Factory::NewRawOneByteString(int, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[9]: 12: 0x101ce9d v8::internal::String::SlowFlatten(v8::internal::Handle, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[10]: 13: 0xafd334 v8::internal::String::Flatten(v8::internal::Handle, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[11]: 14: 0xb2a2a1 v8::String::Value::Value(v8::Isolate*, v8::Local) [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[12]: 15: 0x9c4c33 node::StringBytes::Write(v8::Isolate*, char*, unsigned long, v8::Local, node::encoding, int*) [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[13]: 16: 0x9193fb [io.mihome-vacuum.0]
                    2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[13]: 17: 0x1de16585a2e1
                    2020-03-27 12:22:38.107 - warn: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                    2020-03-27 12:22:38.108 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                    2020-03-27 12:22:38.108 - info: host.ioBroker2 Restart adapter system.adapter.mihome-vacuum.0 because enabled
                    2020-03-27 12:22:40.300 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:22:40.301 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:22:40.301 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:22:40.568 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:22:40.588 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:22:40.607 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:22:40.872 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:23:08.163 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 started with pid 23991
                    2020-03-27 12:23:11.961 - info: mihome-vacuum.0 (23991) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
                    2020-03-27 12:23:12.083 - info: mihome-vacuum.0 (23991) Expert mode disabled, states deleted
                    2020-03-27 12:23:12.084 - info: mihome-vacuum.0 (23991) Create state clean_home for controlling by cloud adapter
                    2020-03-27 12:23:12.100 - info: mihome-vacuum.0 (23991) Disconnect
                    2020-03-27 12:23:12.147 - info: mihome-vacuum.0 (23991) New generation or new fw detected, create new states goto and zoneclean
                    2020-03-27 12:23:12.183 - info: mihome-vacuum.0 (23991) Connected
                    2020-03-27 12:23:12.652 - info: mihome-vacuum.0 (23991) set nächster Timer: Nicht verfügbar
                    2020-03-27 12:23:15.110 - info: mihome-vacuum.0 (23991) create state for carpet_mode
                    2020-03-27 12:23:41.038 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:23:41.039 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:23:41.039 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:23:41.299 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:23:41.319 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:23:41.347 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:23:41.566 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:24:41.033 - info: mihome-vacuum.0 (23991) Disconnect
                    2020-03-27 12:24:41.677 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:24:41.677 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:24:41.677 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:24:41.944 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:24:41.987 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:24:42.025 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:24:42.222 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:25:03.902 - error: host.ioBroker2 Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                    2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 1: 0x8f9d10 node::Abort() [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 2: 0x8f9d5c [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 3: 0xaffd0e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 4: 0xafff44 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 5: 0xef4152 [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 6: 0xef4258 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 7: 0xf00332 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 8: 0xf00c64 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 9: 0xf038d1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 10: 0xecbbb5 [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 11: 0xed342a v8::internal::Factory::NewRawOneByteString(int, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 12: 0x1203785 v8::internal::IncrementalStringBuilder::Extend() [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 13: 0xfc74f2 v8::internal::JsonStringifier::SerializeString(v8::internal::Handle) [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 14: 0xfc7d9b v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_(v8::internal::Handle, bool, v8::internal::Handle) [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[2]: 15: 0xfccead v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_(v8::internal::Handle, bool, v8::internal::Handle) [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[2]: 16: 0xfcdc09 v8::internal::JsonStringifier::Stringify(v8::internal::Handle, v8::internal::Handle, v8::internal::Handle) [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[3]: 17: 0xbd46d1 v8::internal::Builtin_JsonStringify(int, v8::internal::Object**, v8::internal::Isolate*) [io.mihome-vacuum.0]
                    2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[3]: 18: 0xbcdda65bf7d
                    2020-03-27 12:25:03.905 - warn: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                    2020-03-27 12:25:03.905 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                    2020-03-27 12:25:03.905 - info: host.ioBroker2 Restart adapter system.adapter.mihome-vacuum.0 because enabled
                    2020-03-27 12:25:25.848 - info: nut.0 (579) Start NUT update
                    2020-03-27 12:25:25.949 - info: nut.0 (579) All Nut values set
                    2020-03-27 12:25:33.930 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 started with pid 26894
                    2020-03-27 12:25:37.015 - info: mihome-vacuum.0 (26894) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
                    2020-03-27 12:25:37.080 - info: mihome-vacuum.0 (26894) Expert mode disabled, states deleted
                    2020-03-27 12:25:37.081 - info: mihome-vacuum.0 (26894) Create state clean_home for controlling by cloud adapter
                    2020-03-27 12:25:37.093 - info: mihome-vacuum.0 (26894) Disconnect
                    2020-03-27 12:25:37.132 - info: mihome-vacuum.0 (26894) New generation or new fw detected, create new states goto and zoneclean
                    2020-03-27 12:25:37.160 - info: mihome-vacuum.0 (26894) Connected
                    2020-03-27 12:25:37.617 - info: mihome-vacuum.0 (26894) set nächster Timer: Nicht verfügbar
                    2020-03-27 12:25:42.445 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:25:42.446 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:25:42.446 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:25:42.750 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:25:42.772 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:25:42.789 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:25:42.985 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:25:52.169 - warn: mihome-vacuum.0 (26894) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
                    2020-03-27 12:26:17.096 - info: mihome-vacuum.0 (26894) Disconnect
                    2020-03-27 12:26:17.101 - info: mihome-vacuum.0 (26894) Connected
                    2020-03-27 12:26:43.100 - info: unifi.0 (2203) Starting UniFi-Controller query
                    2020-03-27 12:26:43.101 - info: unifi.0 (2203) update_interval = 60
                    2020-03-27 12:26:43.101 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                    2020-03-27 12:26:43.383 - info: unifi.0 (2203) getSitesStats: default
                    2020-03-27 12:26:43.396 - info: unifi.0 (2203) getSiteSysinfo: 1
                    2020-03-27 12:26:43.410 - info: unifi.0 (2203) getClientDevices: 23
                    2020-03-27 12:26:43.557 - info: unifi.0 (2203) getAccessDevices: 1
                    2020-03-27 12:26:48.940 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                    2020-03-27 12:26:57.098 - info: mihome-vacuum.0 (26894) Disconnect
                    2020-03-27 12:26:57.107 - info: mihome-vacuum.0 (26894) Connected
                    2020-03-27 12:27:37.102 - info: mihome-vacuum.0 (26894) Disconnect
                    2020-03-27 12:27:37.157 - info: mihome-vacuum.0 (26894) Connected
                    Ein Memory-Problem sollte ich eigentlich nicht haben mit 3,5 GB
                      dirkhe Developer @Kueppert last edited by
                      @Kueppert das kommt ja regelmäßig. Was mich wundert ist, dass er ständig disconnected. Kannst du mal die aktuelle Version installieren, bitte? Dann mal auf Debug stellen. Das sieht aus wie eine recursion, aber aktuell weiß ich gar nicht, wo das sein könnte. Allerdings bin ich beim abrufen der Karte auch nicht so tief im Code.
                        Kueppert @dirkhe last edited by Kueppert
                        @dirkhe habe jetzt 2.0.9 drauf via Katze und Adapter steht auf Debug. Ich warte mal was ab...ggf muss ich den Saugi auch mal starten, damit was passiert 😉 Danke dir schon mal für die Unterstützung.
                        Erster Auszug:
                        mihome-vacuum.0	2020-03-27 14:53:24.911	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:53:24.910	debug	(29151) no answer for undefined(id:25) received, giving up
                        mihome-vacuum.0	2020-03-27 14:53:19.910	debug	(29151) sendMsg[3] >>> {"id":25,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:53:14.909	debug	(29151) sendMsg[2] >>> {"id":25,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:53:09.909	debug	(29151) sendMsg[1] >>> {"id":25,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:53:09.906	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:53:09.906	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:53:09.906	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0545ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:53:04.950	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:53:04.949	debug	(29151) no answer for undefined(id:24) received, giving up
                        mihome-vacuum.0	2020-03-27 14:52:59.949	debug	(29151) sendMsg[3] >>> {"id":24,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:52:54.948	debug	(29151) sendMsg[2] >>> {"id":24,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:52:49.947	debug	(29151) sendMsg[1] >>> {"id":24,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:52:49.914	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:52:49.914	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:52:49.913	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0531ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:52:44.927	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:52:44.927	debug	(29151) no answer for undefined(id:23) received, giving up
                        mihome-vacuum.0	2020-03-27 14:52:39.925	debug	(29151) sendMsg[3] >>> {"id":23,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:52:34.906	debug	(29151) sendMsg[2] >>> {"id":23,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:52:29.905	debug	(29151) sendMsg[1] >>> {"id":23,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:52:29.903	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:52:29.903	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:52:29.902	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e051dffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:52:24.914	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:52:24.914	debug	(29151) no answer for undefined(id:22) received, giving up
                        mihome-vacuum.0	2020-03-27 14:52:19.913	debug	(29151) sendMsg[3] >>> {"id":22,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:52:14.911	debug	(29151) sendMsg[2] >>> {"id":22,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:52:09.910	debug	(29151) sendMsg[1] >>> {"id":22,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:52:09.902	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:52:09.901	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:52:09.901	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0509ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:52:04.907	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:52:04.906	debug	(29151) no answer for undefined(id:21) received, giving up
                        mihome-vacuum.0	2020-03-27 14:51:59.905	debug	(29151) sendMsg[3] >>> {"id":21,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:51:54.904	debug	(29151) sendMsg[2] >>> {"id":21,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:51:49.904	debug	(29151) sendMsg[1] >>> {"id":21,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:51:49.901	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:51:49.900	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:51:49.900	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e04f5ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:51:44.905	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:51:44.905	debug	(29151) no answer for undefined(id:20) received, giving up
                        mihome-vacuum.0	2020-03-27 14:51:39.903	debug	(29151) sendMsg[3] >>> {"id":20,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:51:34.902	debug	(29151) sendMsg[2] >>> {"id":20,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:51:29.901	debug	(29151) sendMsg[1] >>> {"id":20,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:51:29.900	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:51:29.899	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:51:29.899	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e04e1ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:51:24.904	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:51:24.904	debug	(29151) no answer for undefined(id:19) received, giving up
                        mihome-vacuum.0	2020-03-27 14:51:19.903	debug	(29151) sendMsg[3] >>> {"id":19,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:51:14.901	debug	(29151) sendMsg[2] >>> {"id":19,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:51:09.900	debug	(29151) sendMsg[1] >>> {"id":19,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:51:09.898	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:51:09.898	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:51:09.897	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e04cdffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:51:04.919	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:51:04.918	debug	(29151) no answer for undefined(id:18) received, giving up
                        mihome-vacuum.0	2020-03-27 14:50:59.917	debug	(29151) sendMsg[3] >>> {"id":18,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:50:54.915	debug	(29151) sendMsg[2] >>> {"id":18,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:50:49.914	debug	(29151) sendMsg[1] >>> {"id":18,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:50:49.898	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:50:49.898	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:50:49.898	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e04b9ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:50:44.903	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:50:44.903	debug	(29151) no answer for undefined(id:17) received, giving up
                        mihome-vacuum.0	2020-03-27 14:50:39.901	debug	(29151) sendMsg[3] >>> {"id":17,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:50:34.900	debug	(29151) sendMsg[2] >>> {"id":17,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:50:29.899	debug	(29151) sendMsg[1] >>> {"id":17,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:50:29.896	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:50:29.896	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:50:29.896	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e04a5ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:50:24.904	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:50:24.904	debug	(29151) no answer for undefined(id:16) received, giving up
                        mihome-vacuum.0	2020-03-27 14:50:19.904	debug	(29151) sendMsg[3] >>> {"id":16,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:50:14.902	debug	(29151) sendMsg[2] >>> {"id":16,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:50:09.900	debug	(29151) sendMsg[1] >>> {"id":16,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:50:09.895	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:50:09.894	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:50:09.894	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0491ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:50:04.903	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:50:04.903	debug	(29151) no answer for undefined(id:15) received, giving up
                        mihome-vacuum.0	2020-03-27 14:49:59.901	debug	(29151) sendMsg[3] >>> {"id":15,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:49:54.900	debug	(29151) sendMsg[2] >>> {"id":15,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:49:49.900	debug	(29151) sendMsg[1] >>> {"id":15,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:49:49.894	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:49:49.894	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:49:49.893	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e047dffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:49:44.900	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:49:44.899	debug	(29151) no answer for undefined(id:14) received, giving up
                        mihome-vacuum.0	2020-03-27 14:49:39.898	debug	(29151) sendMsg[3] >>> {"id":14,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:49:34.897	debug	(29151) sendMsg[2] >>> {"id":14,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:49:29.896	debug	(29151) sendMsg[1] >>> {"id":14,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:49:29.893	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:49:29.893	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:49:29.892	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0469ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:49:24.898	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:49:24.898	debug	(29151) no answer for undefined(id:13) received, giving up
                        mihome-vacuum.0	2020-03-27 14:49:19.898	debug	(29151) sendMsg[3] >>> {"id":13,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:49:14.896	debug	(29151) sendMsg[2] >>> {"id":13,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:49:09.894	debug	(29151) sendMsg[1] >>> {"id":13,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:49:09.891	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:49:09.890	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:49:09.890	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0455ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:49:04.911	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:49:04.911	debug	(29151) no answer for undefined(id:12) received, giving up
                        mihome-vacuum.0	2020-03-27 14:48:59.909	debug	(29151) sendMsg[3] >>> {"id":12,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:48:54.907	debug	(29151) sendMsg[2] >>> {"id":12,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:48:49.906	debug	(29151) sendMsg[1] >>> {"id":12,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:48:49.891	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:48:49.891	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:48:49.890	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0441ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:48:44.902	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:48:44.902	debug	(29151) no answer for undefined(id:11) received, giving up
                        mihome-vacuum.0	2020-03-27 14:48:39.900	debug	(29151) sendMsg[3] >>> {"id":11,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:48:34.899	debug	(29151) sendMsg[2] >>> {"id":11,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:48:29.897	debug	(29151) sendMsg[1] >>> {"id":11,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:48:29.891	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:48:29.891	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:48:29.890	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e042dffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:48:24.938	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:48:24.938	debug	(29151) no answer for undefined(id:10) received, giving up
                        mihome-vacuum.0	2020-03-27 14:48:19.937	debug	(29151) sendMsg[3] >>> {"id":10,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:48:14.935	debug	(29151) sendMsg[2] >>> {"id":10,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:48:09.934	debug	(29151) sendMsg[1] >>> {"id":10,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:48:09.888	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:48:09.888	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:48:09.887	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0419ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:48:04.906	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:48:04.905	debug	(29151) no answer for undefined(id:9) received, giving up
                        mihome-vacuum.0	2020-03-27 14:47:59.904	debug	(29151) sendMsg[3] >>> {"id":9,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:47:54.902	debug	(29151) sendMsg[2] >>> {"id":9,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:47:49.901	debug	(29151) sendMsg[1] >>> {"id":9,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:47:49.888	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:47:49.888	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:47:49.887	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0405ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:47:44.898	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:47:44.897	debug	(29151) no answer for undefined(id:8) received, giving up
                        mihome-vacuum.0	2020-03-27 14:47:39.895	debug	(29151) sendMsg[3] >>> {"id":8,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:47:34.894	debug	(29151) sendMsg[2] >>> {"id":8,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:47:29.892	debug	(29151) sendMsg[1] >>> {"id":8,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:47:29.887	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:47:29.887	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:47:29.887	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e03f1ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:47:24.899	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:47:24.898	debug	(29151) no answer for undefined(id:7) received, giving up
                        mihome-vacuum.0	2020-03-27 14:47:19.897	debug	(29151) sendMsg[3] >>> {"id":7,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:47:14.895	debug	(29151) sendMsg[2] >>> {"id":7,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:47:09.893	debug	(29151) sendMsg[1] >>> {"id":7,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:47:09.886	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:47:09.886	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:47:09.886	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e03ddffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:47:04.905	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:47:04.905	debug	(29151) no answer for undefined(id:6) received, giving up
                        mihome-vacuum.0	2020-03-27 14:46:59.903	debug	(29151) sendMsg[3] >>> {"id":6,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:46:54.901	debug	(29151) sendMsg[2] >>> {"id":6,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:46:49.899	debug	(29151) sendMsg[1] >>> {"id":6,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:46:49.886	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:46:49.886	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:46:49.886	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e03c9ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:46:44.892	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:46:44.892	debug	(29151) no answer for undefined(id:5) received, giving up
                        mihome-vacuum.0	2020-03-27 14:46:39.890	debug	(29151) sendMsg[3] >>> {"id":5,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:46:34.889	debug	(29151) sendMsg[2] >>> {"id":5,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:46:29.887	debug	(29151) sendMsg[1] >>> {"id":5,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:46:29.884	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:46:29.883	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:46:29.883	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e03b5ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:46:24.891	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:46:24.890	debug	(29151) no answer for undefined(id:4) received, giving up
                        mihome-vacuum.0	2020-03-27 14:46:23.350	debug	(29151) system.adapter.admin.0: logging true
                        mihome-vacuum.0	2020-03-27 14:45:49.893	debug	(29151) sendMsg[1] >>> {"id":3,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:45:49.885	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:45:49.884	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:45:49.884	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e038dffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:45:39.890	debug	(29151) sendMsg[3] >>> {"id":2,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:45:34.889	debug	(29151) sendMsg[2] >>> {"id":2,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:45:29.888	debug	(29151) sendMsg[1] >>> {"id":2,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:45:29.883	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:45:29.883	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:45:29.882	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0379ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:45:24.978	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:45:24.978	debug	(29151) no answer for undefined(id:1) received, giving up
                        mihome-vacuum.0	2020-03-27 14:45:19.977	debug	(29151) sendMsg[3] >>> {"id":1,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:45:14.976	debug	(29151) sendMsg[2] >>> {"id":1,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:45:12.042	debug	(29151) Xiaomi Cloud: Login successful
                        mihome-vacuum.0	2020-03-27 14:45:10.409	info	(29151) set nächster Timer: Nicht verfügbar
                        mihome-vacuum.0	2020-03-27 14:45:09.974	debug	(29151) sendMsg[1] >>> {"id":1,"method":"get_status"}
                        mihome-vacuum.0	2020-03-27 14:45:09.956	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                        mihome-vacuum.0	2020-03-27 14:45:09.955	info	(29151) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:45:09.954	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0365ffffffffffffffffffffffffffffffff
                        mihome-vacuum.0	2020-03-27 14:45:09.948	info	(29151) New generation or new fw(3.5.4,004004) detected, create new states goto and zoneclean
                        mihome-vacuum.0	2020-03-27 14:45:09.885	debug	(29151) server started on 0.0.0.0:53421
                        mihome-vacuum.0	2020-03-27 14:45:09.863	info	(29151) Create state clean_home for controlling by cloud adapter
                        mihome-vacuum.0	2020-03-27 14:45:09.861	info	(29151) Expert mode disabled, states deleted
                        mihome-vacuum.0	2020-03-27 14:45:09.848	debug	(29151) Xiaomi Cloud: Logging in
                        mihome-vacuum.0	2020-03-27 14:45:09.847	debug	(29151) load Map creator... true
                        mihome-vacuum.0	2020-03-27 14:45:09.776	info	(29151) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
                        mihome-vacuum.0	2020-03-27 14:45:04.283	info	(28505) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        mihome-vacuum.0	2020-03-27 14:45:04.281	info	(28505) terminating
                        mihome-vacuum.0	2020-03-27 14:45:04.280	info	(28505) Got terminate signal TERMINATE_YOURSELF
                        mihome-vacuum.0	2020-03-27 14:44:43.305	info	(28505) create state for carpet_mode
                        mihome-vacuum.0	2020-03-27 14:44:42.775	info	(28505) set nächster Timer: Nicht verfügbar
                        mihome-vacuum.0	2020-03-27 14:44:42.287	info	(28505) Connected
                        mihome-vacuum.0	2020-03-27 14:44:42.246	info	(28505) connecting, this can take up to 10 minutes ...
                        mihome-vacuum.0	2020-03-27 14:44:42.224	info	(28505) New generation or new fw(3.5.4,004004) detected, create new states goto and zoneclean
                        mihome-vacuum.0	2020-03-27 14:44:42.179	info	(28505) Create state clean_home for controlling by cloud adapter
                        mihome-vacuum.0	2020-03-27 14:44:42.178	info	(28505) Expert mode disabled, states deleted
                        mihome-vacuum.0	2020-03-27 14:44:42.092	info	(28505) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
                        mihome-vacuum.0	2020-03-27 14:44:34.501	info	(26894) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        mihome-vacuum.0	2020-03-27 14:44:34.500	info	(26894) terminating
                        mihome-vacuum.0	2020-03-27 14:44:34.499	info	(26894) Got terminate signal TERMINATE_YOURSELF
                          Kueppert @Kueppert last edited by
                          @dirkhe dann habe ich gerade mal die MiHome-App geöffnet und den Staubi angeklickt, da passiert was im Log:
                          mihome-vacuum.0	2020-03-27 14:56:51.929	debug	(29151) Mappointer_updated
                          mihome-vacuum.0	2020-03-27 14:56:51.928	debug	(29151) Receive <<< {"result":["roboroommap%2F82487762%2F6"],"id":70}
                          mihome-vacuum.0	2020-03-27 14:56:51.923	debug	(29151) sendMsg[1] >>> {"id":70,"method":"get_map_v1"}
                          mihome-vacuum.0	2020-03-27 14:56:50.431	debug	(29151) Receive <<< {"result":[268569,4074617500,145,[1585305280,1583161415,1582365313,1582274907,1581673021,1580981012,1580463233,1580371947,1579857633,1579250658,1578393704,1577711651,1577701268,157
                          mihome-vacuum.0	2020-03-27 14:56:50.423	debug	(29151) sendMsg[1] >>> {"id":69,"method":"get_clean_summary"}
                          mihome-vacuum.0	2020-03-27 14:56:49.932	debug	(29151) Receive <<< {"result":[{"main_brush_work_time":268569,"side_brush_work_time":268569,"filter_work_time":268569,"sensor_dirty_time":22220}],"id":68}
                          mihome-vacuum.0	2020-03-27 14:56:49.922	debug	(29151) sendMsg[1] >>> {"id":68,"method":"get_consumable"}
                          mihome-vacuum.0	2020-03-27 14:56:49.918	debug	(29151) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2055,"state":8,"battery":100,"clean_time":1882,"clean_area":33882500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":0
                          mihome-vacuum.0	2020-03-27 14:56:49.912	debug	(29151) sendMsg[1] >>> {"id":67,"method":"get_status"}
                          mihome-vacuum.0	2020-03-27 14:56:37.022	debug	(29151) 25604
                          mihome-vacuum.0	2020-03-27 14:56:35.580	debug	(29151) update_Map got new time:1585317393
                          mihome-vacuum.0	2020-03-27 14:56:35.580	debug	(29151) update_Map got new expires:1585319195
                          mihome-vacuum.0	2020-03-27 14:56:35.579	debug	(29151) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/3?Expires=1585319195000&GalaxyAccessKeyId=5271733786445&Signature=7rSJ64eWNT8XkG/3l6kHPHiGBtE=
                          mihome-vacuum.0	2020-03-27 14:56:34.765	debug	(29151) CLEAN_LOGGING[{"Datum":"27.3","Start":"11:34","Saugzeit":"31 min","Fläche":"33.88 m²","Error":0,"Ende":true},{"Datum":"2.3","Start":"16:03","Saugzeit":"1 min","Fläche":"1.27 m²","Error":0,"End
                          mihome-vacuum.0	2020-03-27 14:56:34.569	debug	(29151) Receive <<< {"result":[[1570894237,1570896347,1961,33425000,0,1]],"id":66}
                          mihome-vacuum.0	2020-03-27 14:56:34.563	debug	(29151) sendMsg[1] >>> {"id":66,"method":"get_clean_record","params":[1570894237]}
                          mihome-vacuum.0	2020-03-27 14:56:34.367	debug	(29151) Receive <<< {"result":[[1571385380,1571387768,2388,35787500,0,1]],"id":65}
                          mihome-vacuum.0	2020-03-27 14:56:34.361	debug	(29151) sendMsg[1] >>> {"id":65,"method":"get_clean_record","params":[1571385380]}
                          mihome-vacuum.0	2020-03-27 14:56:34.166	debug	(29151) Receive <<< {"result":[[1572341803,1572343814,2011,33695000,0,1]],"id":64}
                          mihome-vacuum.0	2020-03-27 14:56:34.160	debug	(29151) sendMsg[1] >>> {"id":64,"method":"get_clean_record","params":[1572341803]}
                          mihome-vacuum.0	2020-03-27 14:56:33.964	debug	(29151) Receive <<< {"result":[[1573114531,1573116539,2008,33780000,0,1]],"id":63}
                          mihome-vacuum.0	2020-03-27 14:56:33.959	debug	(29151) sendMsg[1] >>> {"id":63,"method":"get_clean_record","params":[1573114531]}
                          mihome-vacuum.0	2020-03-27 14:56:33.764	debug	(29151) Receive <<< {"result":[[1573808322,1573810637,2315,35065000,0,1]],"id":62}
                          mihome-vacuum.0	2020-03-27 14:56:33.757	debug	(29151) sendMsg[1] >>> {"id":62,"method":"get_clean_record","params":[1573808322]}
                          mihome-vacuum.0	2020-03-27 14:56:33.561	debug	(29151) Receive <<< {"result":[[1576490060,1576492145,2085,33827500,0,1]],"id":61}
                          mihome-vacuum.0	2020-03-27 14:56:33.556	debug	(29151) sendMsg[1] >>> {"id":61,"method":"get_clean_record","params":[1576490060]}
                          mihome-vacuum.0	2020-03-27 14:56:33.361	debug	(29151) Receive <<< {"result":[[1577088558,1577089956,1398,19932500,0,1]],"id":60}
                          mihome-vacuum.0	2020-03-27 14:56:33.355	debug	(29151) sendMsg[1] >>> {"id":60,"method":"get_clean_record","params":[1577088558]}
                          mihome-vacuum.0	2020-03-27 14:56:33.168	debug	(29151) update_Map need new mapurl
                          mihome-vacuum.0	2020-03-27 14:56:33.168	debug	(29151) update_Map Mimap enabled
                          mihome-vacuum.0	2020-03-27 14:56:33.167	debug	(29151) Mappointer_updated
                          mihome-vacuum.0	2020-03-27 14:56:33.167	debug	(29151) Receive <<< {"result":["roboroommap%2F82487762%2F3"],"id":59}
                          mihome-vacuum.0	2020-03-27 14:56:33.162	debug	(29151) Receive <<< {"result":[[1577701268,1577701837,569,5437500,0,1]],"id":58}
                          mihome-vacuum.0	2020-03-27 14:56:33.161	debug	(29151) 3. Mappointer_nomap___retry
                          mihome-vacuum.0	2020-03-27 14:56:33.161	debug	(29151) sendMsg[1] >>> {"id":59,"method":"get_map_v1"}
                          mihome-vacuum.0	2020-03-27 14:56:33.154	debug	(29151) sendMsg[1] >>> {"id":58,"method":"get_clean_record","params":[1577701268]}
                          mihome-vacuum.0	2020-03-27 14:56:32.960	debug	(29151) Receive <<< {"result":[[1577711651,1577712390,739,13485000,0,1]],"id":57}
                          mihome-vacuum.0	2020-03-27 14:56:32.953	debug	(29151) sendMsg[1] >>> {"id":57,"method":"get_clean_record","params":[1577711651]}
                          mihome-vacuum.0	2020-03-27 14:56:32.759	debug	(29151) Receive <<< {"result":[[1578393704,1578395855,2151,33467500,0,1]],"id":56}
                          mihome-vacuum.0	2020-03-27 14:56:32.751	debug	(29151) sendMsg[1] >>> {"id":56,"method":"get_clean_record","params":[1578393704]}
                          mihome-vacuum.0	2020-03-27 14:56:32.660	debug	(29151) Receive <<< {"result":["retry"],"id":55}
                          mihome-vacuum.0	2020-03-27 14:56:32.654	debug	(29151) 2. Mappointer_nomap___retry
                          mihome-vacuum.0	2020-03-27 14:56:32.654	debug	(29151) sendMsg[1] >>> {"id":55,"method":"get_map_v1"}
                          mihome-vacuum.0	2020-03-27 14:56:32.555	debug	(29151) Receive <<< {"result":[[1579250658,1579253070,2412,36095000,0,1]],"id":54}
                          mihome-vacuum.0	2020-03-27 14:56:32.549	debug	(29151) sendMsg[1] >>> {"id":54,"method":"get_clean_record","params":[1579250658]}
                          mihome-vacuum.0	2020-03-27 14:56:32.355	debug	(29151) Receive <<< {"result":[[1579857633,1579859588,1955,33762500,0,1]],"id":53}
                          mihome-vacuum.0	2020-03-27 14:56:32.348	debug	(29151) sendMsg[1] >>> {"id":53,"method":"get_clean_record","params":[1579857633]}
                          mihome-vacuum.0	2020-03-27 14:56:32.154	debug	(29151) Receive <<< {"result":[[1580371947,1580373899,1952,33397500,0,1]],"id":52}
                          mihome-vacuum.0	2020-03-27 14:56:32.153	debug	(29151) Receive <<< {"result":["retry"],"id":51}
                          mihome-vacuum.0	2020-03-27 14:56:32.147	debug	(29151) sendMsg[1] >>> {"id":52,"method":"get_clean_record","params":[1580371947]}
                          mihome-vacuum.0	2020-03-27 14:56:32.144	debug	(29151) 1. Mappointer_nomap___retry
                          mihome-vacuum.0	2020-03-27 14:56:32.144	debug	(29151) sendMsg[1] >>> {"id":51,"method":"get_map_v1"}
                          mihome-vacuum.0	2020-03-27 14:56:31.951	debug	(29151) Receive <<< {"result":[[1580463233,1580468445,2521,36215000,0,1]],"id":50}
                          mihome-vacuum.0	2020-03-27 14:56:31.945	debug	(29151) sendMsg[1] >>> {"id":50,"method":"get_clean_record","params":[1580463233]}
                          mihome-vacuum.0	2020-03-27 14:56:31.750	debug	(29151) Receive <<< {"result":[[1580981012,1580983420,2408,36150000,0,1]],"id":49}
                          mihome-vacuum.0	2020-03-27 14:56:31.744	debug	(29151) sendMsg[1] >>> {"id":49,"method":"get_clean_record","params":[1580981012]}
                          mihome-vacuum.0	2020-03-27 14:56:31.643	debug	(29151) Receive <<< {"result":["retry"],"id":48}
                          mihome-vacuum.0	2020-03-27 14:56:31.638	debug	(29151) 0. Mappointer_nomap___retry
                          mihome-vacuum.0	2020-03-27 14:56:31.638	debug	(29151) sendMsg[1] >>> {"id":48,"method":"get_map_v1"}
                          mihome-vacuum.0	2020-03-27 14:56:31.549	debug	(29151) Receive <<< {"result":[[1581673021,1581675073,2052,33732500,0,1]],"id":47}
                          mihome-vacuum.0	2020-03-27 14:56:31.543	debug	(29151) sendMsg[1] >>> {"id":47,"method":"get_clean_record","params":[1581673021]}
                          mihome-vacuum.0	2020-03-27 14:56:31.349	debug	(29151) Receive <<< {"result":[[1582274907,1582276815,1908,33457500,0,1]],"id":46}
                          mihome-vacuum.0	2020-03-27 14:56:31.342	debug	(29151) sendMsg[1] >>> {"id":46,"method":"get_clean_record","params":[1582274907]}
                          mihome-vacuum.0	2020-03-27 14:56:31.147	debug	(29151) Receive <<< {"result":[[1582365313,1582367499,2186,38605000,0,1]],"id":45}
                          mihome-vacuum.0	2020-03-27 14:56:31.141	debug	(29151) sendMsg[1] >>> {"id":45,"method":"get_clean_record","params":[1582365313]}
                          mihome-vacuum.0	2020-03-27 14:56:31.136	debug	(29151) Receive <<< {"result":["retry"],"id":44}
                          mihome-vacuum.0	2020-03-27 14:56:31.129	debug	(29151) sendMsg[1] >>> {"id":44,"method":"get_map_v1"}
                          mihome-vacuum.0	2020-03-27 14:56:30.946	debug	(29151) Receive <<< {"result":[[1583161415,1583161534,54,1272500,0,0]],"id":43}
                          mihome-vacuum.0	2020-03-27 14:56:30.940	debug	(29151) sendMsg[1] >>> {"id":43,"method":"get_clean_record","params":[1583161415]}
                          mihome-vacuum.0	2020-03-27 14:56:30.936	debug	(29151) Receive <<< {"result":"unknown_method","id":42}
                          mihome-vacuum.0	2020-03-27 14:56:30.935	info	(29151) create state for carpet_mode
                          mihome-vacuum.0	2020-03-27 14:56:30.935	debug	(29151) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":41}
                          mihome-vacuum.0	2020-03-27 14:56:30.929	debug	(29151) sendMsg[1] >>> {"id":42,"method":"get_room_mapping"}
                          mihome-vacuum.0	2020-03-27 14:56:30.928	debug	(29151) sendMsg[1] >>> {"id":41,"method":"get_carpet_mode"}
                          mihome-vacuum.0	2020-03-27 14:56:30.746	debug	(29151) Receive <<< {"result":[[1585305280,1585307162,1882,33882500,0,1]],"id":40}
                          mihome-vacuum.0	2020-03-27 14:56:30.739	debug	(29151) sendMsg[1] >>> {"id":40,"method":"get_clean_record","params":[1585305280]}
                          mihome-vacuum.0	2020-03-27 14:56:30.737	debug	(29151) Receive <<< {"result":[268569,4074617500,145,[1585305280,1583161415,1582365313,1582274907,1581673021,1580981012,1580463233,1580371947,1579857633,1579250658,1578393704,1577711651,1577701268,157
                          mihome-vacuum.0	2020-03-27 14:56:30.728	debug	(29151) sendMsg[1] >>> {"id":39,"method":"get_clean_summary"}
                          mihome-vacuum.0	2020-03-27 14:56:30.533	debug	(29151) Receive <<< {"result":[{"main_brush_work_time":268569,"side_brush_work_time":268569,"filter_work_time":268569,"sensor_dirty_time":22220}],"id":38}
                          mihome-vacuum.0	2020-03-27 14:56:30.528	debug	(29151) sendMsg[1] >>> {"id":38,"method":"get_consumable"}
                          mihome-vacuum.0	2020-03-27 14:56:30.333	debug	(29151) Receive <<< {"result":[30],"id":37}
                          mihome-vacuum.0	2020-03-27 14:56:30.328	debug	(29151) sendMsg[1] >>> {"id":37,"method":"get_sound_volume"}
                          mihome-vacuum.0	2020-03-27 14:56:30.133	debug	(29151) Receive <<< {"partner_id":"","id":36,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.4_004004","ap":{"ssid":"Unifi_EG","bssid":"18:E8:29:94:F0:F8","rssi":-38},"netif":{"localI
                          mihome-vacuum.0	2020-03-27 14:56:30.130	debug	(29151) Next WiFi check: 27.03 14:57
                          mihome-vacuum.0	2020-03-27 14:56:30.129	debug	(29151) sendMsg[1] >>> {"id":36,"method":"miIO.info"}
                          mihome-vacuum.0	2020-03-27 14:56:29.927	info	(29151) Connected
                          mihome-vacuum.0	2020-03-27 14:56:29.924	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                          mihome-vacuum.0	2020-03-27 14:56:29.922	debug	(29151) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2042,"state":8,"battery":100,"clean_time":1882,"clean_area":33882500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":0
                          mihome-vacuum.0	2020-03-27 14:56:29.917	debug	(29151) sendMsg[1] >>> {"id":35,"method":"get_status"}
                          mihome-vacuum.0	2020-03-27 14:56:29.914	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                          mihome-vacuum.0	2020-03-27 14:56:29.914	info	(29151) connecting, this can take up to 10 minutes ...
                            @Kueppert jetzt bist du on Track ..
                            Kannst den debuglevel wieder runter setzten. Wir wissen zwar jetzt immer noch nicht, wo die rekursion ist.
                              root_ last edited by
                              Hab einen Mi home Vacuum und bekomme mit der 2.0.9 die Zonenreinigung nicht mehr hin.
                              Hat bis jetzt immer funktioniert. Hab einen neuen Raum mit den Koordinaten angelegt. Das hat auch funktioniert. Bekomme aber folgende Meldung wenn ich die Reinigung starte:
                              mihome-vacuum.0	2020-03-28 16:36:49.032	error	(100061) [24159,24383,28759,25933,1] ->mihome-vacuum.0.rooms.manual_24159_24383_28759_25933
                              mihome-vacuum.0	2020-03-28 16:36:49.001	info	(100061) trigger cleaning zone [24159,24383,28759,25933,1]
                                dirkhe Developer @root_ last edited by
                                @root_ kannst du mal den loglevel auf debug stellen und nochmal probieren, bitte
                                • Jan Fiedler
                                  Jan Fiedler last edited by
                                  Gibt es eine Möglichkeit die Raumkoordinaten auszulesen, ohne Valetudo zu installieren?
                                  ? D 2 Replies Last reply Reply Quote 0
                                    A Former User @Jan Fiedler last edited by
                                    @Jan-Fiedler sagte in Test Adapter mihome-vacuum v2.0.x:
                                    mit der Flole-App ( Android ), auf Zonenreinigung gehen, Zone markieren, dann auf Reinigen und den Finger drauflassen, bis "Zone wurde in die Zwischenablage kopiert" erscheint.
                                    Dann c+p wohin. Damit geht die "Raumreinigung" mit allen Modellen, die noch auf der alten Firmware sind.
                                    Jan Fiedler 1 Reply Last reply Reply Quote 0
                                    • Elektroniker86
                                      Elektroniker86 last edited by
                                      Ich habe eben versucht den Adapter über die Katze /Githublink zu installieren, allerdings nicht erfolgreich.
                                      obroker host.IoBroker-Pi4 Cannot install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/c2dcd9c10ccd505e22854e3bd4f7323a1b752dd3
                                      Muss ich vorher den alten Adapter deinstallieren vielleicht?
                                      Ich habe zwei Instanzen des alten Adapters pausiert und dann versucht zu installieren.
                                        root_ @dirkhe last edited by
                                        @dirkhe said in Test Adapter mihome-vacuum v2.0.x:
                                        mihome-vacuum.0	2020-03-29 16:23:06.651	debug	(92536) Receive <<< {"result":[1846515,23124062500,707,[]],"id":13}
                                        mihome-vacuum.0	2020-03-29 16:23:06.644	debug	(92536) sendMsg[1] >>> {"id":13,"method":"get_clean_summary"}
                                        mihome-vacuum.0	2020-03-29 16:23:06.150	debug	(92536) Receive <<< {"result":[{"main_brush_work_time":484190,"side_brush_work_time":484190,"filter_work_time":291118,"sensor_dirty_time":48205}],"id":12}
                                        mihome-vacuum.0	2020-03-29 16:23:06.140	debug	(92536) sendMsg[1] >>> {"id":12,"method":"get_consumable"}
                                        mihome-vacuum.0	2020-03-29 16:23:06.135	debug	(92536) Receive <<< {"result":[{"msg_ver":8,"msg_seq":203,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":90,"dnd_enabled":0}],"id":11
                                        mihome-vacuum.0	2020-03-29 16:23:06.125	debug	(92536) sendMsg[1] >>> {"id":11,"method":"get_status"}
                                        mihome-vacuum.0	2020-03-29 16:23:04.192	error	(92536) [24159,24383,28759,25933,1] ->mihome-vacuum.0.rooms.manual_24159_24383_28759_25933
                                        mihome-vacuum.0	2020-03-29 16:23:04.145	debug	(92536) Receive <<< {"result":["ok"],"id":10}
                                        mihome-vacuum.0	2020-03-29 16:23:04.133	debug	(92536) sendMsg[1] >>> {"id":10,"method":"set_custom_mode","params":[90]}
                                        mihome-vacuum.0	2020-03-29 16:23:04.132	debug	(92536) stateChange mihome-vacuum.0.control.fan_power {"val":90,"ack":false,"ts":1585491784127,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1541688856539}
                                        mihome-vacuum.0	2020-03-29 16:23:04.123	info	(92536) trigger cleaning zone [24159,24383,28759,25933,1]
                                        mihome-vacuum.0	2020-03-29 16:23:04.115	debug	(92536) sendTo "cleanZone" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                          @root_ welche Version hast du genau, das sieht man, wenn man den adapter startet. Ich habe die ganze zeit gesucht und ich kann aktuell nicht mal die Stelle finden, wo diese Fehlermeldung geschrieben wird. Bitte nochmal die aktuelle Version rc07 installieren. Funktioniert das denn, wenn du die Koordinaten über sendCustomcommand eingibst?
                                            mihome-vacuum.0	2020-03-29 17:04:53.496	info	(45717) connecting, This can take up to 5 minutes ...
                                            mihome-vacuum.0	2020-03-29 17:04:53.494	debug	(45717) Receive <<< Helo <<< 213100200000000004e9e7315e80b915ffffffffffffffffffffffffffffffff
                                            mihome-vacuum.0	2020-03-29 17:04:53.460	info	(45717) New generation or new fw(3.5.4,004007) detected, create new states goto and zoneclean
                                            mihome-vacuum.0	2020-03-29 17:04:53.397	debug	(45717) server started on 0.0.0.0:53421
                                            mihome-vacuum.0	2020-03-29 17:04:53.386	info	(45717) Disconnect
                                            mihome-vacuum.0	2020-03-29 17:04:53.373	info	(45717) Create state clean_home for controlling by cloud adapter
                                            mihome-vacuum.0	2020-03-29 17:04:53.372	info	(45717) Expert mode enabled, states created
                                            mihome-vacuum.0	2020-03-29 17:04:53.353	debug	(45717) Xiaomi Cloud: Logging in
                                            mihome-vacuum.0	2020-03-29 17:04:53.350	debug	(45717) load Map creator... true
                                            mihome-vacuum.0	2020-03-29 17:04:53.263	info	(45717) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                                            host.raspberry	2020-03-29 17:04:48.816	info	instance system.adapter.mihome-vacuum.0 started with pid 45717
                                            Hab gerade noch mal über git upgedatet aber von RC07 steht bei mir nix
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            493935
