    4. IOBroker Anbindung an einen Kostal Plenticore
    • StrathCole
      StrathCole last edited by
      Okay, lag an was anderem. Habe einen Fix ins Git geladen.
        tp1de last edited by
        @StrathCole sagte in IOBroker Anbindung an einen Kostal Plenticore:
        Geht nicht - Adapter startet alle 30 Sekunden neu
        StrathCole 1 Reply Last reply Reply Quote 0
        • StrathCole
          StrathCole @tp1de last edited by
          @tom57 Mit derselben Meldung?
            tp1de @StrathCole last edited by
            Nein .....
            host.iob	2020-03-25 17:51:40.192	info	Restart adapter system.adapter.plenticore.0 because enabled
            host.iob	2020-03-25 17:51:40.191	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
            host.iob	2020-03-25 17:51:39.597	info	instance system.adapter.plenticore.0 started with pid 1909
            host.iob	2020-03-25 17:51:09.547	info	Restart adapter system.adapter.plenticore.0 because enabled
            host.iob	2020-03-25 17:51:09.546	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
            host.iob	2020-03-25 17:51:08.971	info	instance system.adapter.plenticore.0 started with pid 1862
            host.iob	2020-03-25 17:50:38.923	info	Restart adapter system.adapter.plenticore.0 because enabled
            host.iob	2020-03-25 17:50:38.922	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
            host.iob	2020-03-25 17:50:38.373	info	instance system.adapter.plenticore.0 started with pid 1847
            host.iob	2020-03-25 17:50:08.347	info	Restart adapter system.adapter.plenticore.0 because enabled
            host.iob	2020-03-25 17:50:08.347	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
            host.iob	2020-03-25 17:50:07.797	info	instance system.adapter.plenticore.0 started with pid 1831
            host.iob	2020-03-25 17:49:37.773	info	Restart adapter system.adapter.plenticore.0 because enabled
            host.iob	2020-03-25 17:49:37.773	error	instance system.adapter.plenticore.0 terminated with code 156 (156)
            • StrathCole
              @tom57 Hast du ihn mal manuell komplett angehalten und neu gestartet?
                Nein hatte nur neu gestartet ....
                Jetzt habe ich Ihn angehalten ... etwas gewartet ... und neu gestartet.
                Jetzt habe ich keine Neustarts mehr.
                Wo ist der Unterschied mit Anhalten zum Neustarten ?
                StrathCole Diginix 2 Replies Last reply Reply Quote 0
                • StrathCole
                  @tom57 sagte in IOBroker Anbindung an einen Kostal Plenticore:
                  Das weiß ich nicht. Ich habe das aber auch manchmal bei Adaptern, die ich aktualisiere, dass ioBroker sie nicht korrekt neu startet und ich dann einmal manuell beenden muss.
                    Ok, wieder was gelernt 😊
                    • Diginix
                      Diginix @tp1de last edited by
                      In einem solchen Fall läuft dann noch ein Zombiprozess.
                      Wenn du den Adapter stoppst und in der Kommandozeile:
                      ps auxww | grep plenticore
                      ausführst, siehst du ihn. Mit diesem Kommando kann man ihn killen:
                      sudo kill -9 $(pidof io.plenticore.0)
                      • StrathCole
                        StrathCole last edited by StrathCole
                        Ich habe jetzt die aktuelle Version 2.1.0 ins Git und ins NPM repository geladen. Damit sollte sie morgen auch im "latest" von ioBroker auftauchen. Einzige Neuerung seit dem letzten Git-Upload ist das einstellbare minimum MinSoC.
                        Zudem habe ich die README auf den neuesten Stand gebracht und auch die Vorhersage etwas erläutert.
                        Nun habe ich auch noch eine deutsche Übersetzung der README eingepflegt.
                        • Bostil
                          Bostil last edited by
                          Jungs, ganz doof gefragt: Bekomme auch bald eine PV-Anlage mit einem Kostal Plenticore plus 8.5 - aber was wird noch benötigt, um die PV-Daten letztlich über iobroker auslesen zu lassen? Blicke hier noch nicht durch ....
                          Danke euch!
                          • StrathCole
                            StrathCole @Bostil last edited by StrathCole
                            @Bostil Der Plenticore muss einfach im selben Netzwerk sein, sodass der ioBroker ihn erreichen kann. Sinnvoll wird es dann auch erst, wenn er mit einem SEM gekoppelt ist.
                            • Bostil
                              Danke @StrathCole - hieße, der Plenticore bringt fast alles mit, um ihn im iobroker zumindest sichtbar zu machen. Der Plenticore wird einfach per LAN am Router angeschlossen, und ab da an ist es Konfigurationsarbeit? Danke dir.
                              • StrathCole
                                @Bostil Im Grunde ist das richtig, ja.
                                Bostil 1 Reply Last reply Reply Quote 1
                                • Diginix
                                  Diginix last edited by Diginix
                                  @StrathCole Habe heute erst die Logzeile entdeckt:
                                  Invalid minimum MinSoC value set. Valid values are from 5 to 100 and lower than maximum MinSoC. Resetting to default (5).
                                  Und darauf hin in der Instanz versucht 5% als minMinSOC zu speichern. Wird aber immer mit einem Fehlerdialog quittiert, dass der Wert zw. 5 und 100 und kleiner maxMinSOC sein soll. maxMinSOC ist 20.
                                  Erst ab minmin 40 und daher maxmin >40 lässt sich der Dialog speichern.
                                  StrathCole 2 Replies Last reply Reply Quote 0
                                  • StrathCole
                                    StrathCole @Diginix last edited by
                                    @Diginix Komisch. Schau ich mir noch mal an.
                                    • StrathCole
                                      @Diginix Danke für den Hinweis. Problem ist behoben.
                                      Diginix 1 Reply Last reply Reply Quote 1
                                      • Diginix
                                        Diginix @StrathCole last edited by
                                        @StrathCole Funktioniert
                                        • StrathCole
                                          Gestern und heute hat die "intelligente" Batteriesteuerung zum ersten Mal richtig funktioniert. Allerdings ist sie selbst dann nicht optimal. Warum?
                                          Korrekterweise hat die Steuerung erst spät mit der Batterieladung begonnen (gegen 11 Uhr) und dann auch nur in einer geringen Leistung, sodass gerade keine Leistung der PV verloren ging. Nun kommt das große Aber. Die Batterie wurde in der Nacht bis auf das MinSoC entladen, also 5%. Nun hat die Steuerung aber selbst da morgens nichts in die Batterie gepackt (erwartet hätte ich eine Ladung auf mind. 8-10%, es wurde aber alles eingespeist). Das führte dazu, dass ich ein Verbrauchspeak hatte (10kW), das die PV-Leistung nicht decken konnte, aber die Batterie ebensowenig, weil sie ja schon auf MinSoC war. Ergo: 1kWh Netzbezug.
                                          Unter intelligent verstehe ich wirklich was anderes *seufz
                                          • Diginix
                                            Die Anlage bei mir gehört meinen Eltern und die meinten sie hätten keine 70% Deckelung, sondern lösen die Einspeisung über die Steuererklärung. Dann ist die intelligente Regelung für uns doch unwichtig oder? Im Netz lese ich dass es ohne Begrenzung keine Einspeisung gibt. Habe das aber noch nicht ganz durchblickt.
                                            Oder ist es genau diese Abflachung hier:
                                            Bisher dachte ich die 5500 Watt sind ohnehin mein Maximum, der WR heißt ja auch Plenticore 5.5. Im letzten Sommer wurden die 5500 W auch nie überschritten weil durch die höheren Temp. der Wirkungsgrad geringer war. Nur jetzt bei winterlichten Temp. und voller Sonne habe ich die 7000 W mal angekratzt.
                                            Viel mehr noch stört mich aktuell das nächtliche Nachladen aus dem Netz wenn die 5% SOC unterschritten werden.
                                            StrathCole T 2 Replies Last reply Reply Quote 0
                                            1.4k
                                            1302
                                            443729
