    4. Test Adapter mihome-vacuum v2.0.x
      Kueppert @dirkhe last edited by
      @dirkhe nur die Einträge aus dem log, die mit dem Adapter zu tun haben? Oder einfach einen Auszug von heute als Dateianhang?
        @dirkhe hab noch was gefunden, das ggf. weiterhilft:
        2020-03-27 12:06:16.826 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:16 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8822e208-397d-ca1f-0000-01711babce13","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:19.839 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:19 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"5b505204-c47a-87cb-0000-01711babdafa","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:23.153 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:06:23.300 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:23 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"68e38ade-5a0d-cfb2-0000-01711babe751","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:26.325 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:26 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8649174a-c919-a08e-0000-01711babf304","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:29.371 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:29 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"ec138f99-5fef-ac1a-0000-01711babff18","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:30.137 - info: unifi.0 (2203) Starting UniFi-Controller query
        2020-03-27 12:06:30.138 - info: unifi.0 (2203) update_interval = 60
        2020-03-27 12:06:30.138 - info: unifi.0 (2203) controller = 192.168.178.71:8443
        2020-03-27 12:06:30.434 - info: unifi.0 (2203) getSitesStats: default
        2020-03-27 12:06:30.453 - info: unifi.0 (2203) getSiteSysinfo: 1
        2020-03-27 12:06:30.472 - info: unifi.0 (2203) getClientDevices: 22
        2020-03-27 12:06:30.684 - info: unifi.0 (2203) getAccessDevices: 1
        2020-03-27 12:06:32.426 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:32 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"349d92a7-bf60-22a9-0000-01711bac0b51","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:35.736 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:35 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"a7f090d2-a1ff-3817-0000-01711bac180b","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:39.023 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:38 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"33042f81-515d-efc9-0000-01711bac25fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:42.113 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:41 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f930393c-6d79-c7ad-0000-01711bac31af","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:43.153 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:06:45.389 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:45 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f549b8fd-cb30-333c-0000-01711bac3e3a","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:48.626 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:48 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"afe7d6f9-52ff-75ff-0000-01711bac4a6d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:48.631 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
        2020-03-27 12:06:52.019 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:51 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"01962472-7526-84f1-0000-01711bac58cd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:55.014 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:54 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"addcf6aa-172a-d7c0-0000-01711bac637c","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:06:58.346 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:58 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"37bc4ae2-30bf-d082-0000-01711bac701f","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:07:01.341 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:01 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"b9a60d2c-943f-7a23-0000-01711bac7c21","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:07:03.155 - info: mihome-vacuum.0 (780) Disconnect
        2020-03-27 12:07:04.595 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:04 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"0f1c5fc0-fe2c-85b2-0000-01711bac89fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:07:07.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:07 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"67576ec9-5750-92b1-0000-01711bac9560","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:07:10.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:10 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"03737cb1-32cb-595c-0000-01711baca111","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:07:14.189 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:14 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8a047e9d-2efe-578c-0000-01711bacae2d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:07:17.174 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:17 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2a63601a-70f8-7946-0000-01711bacbaa4","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
        2020-03-27 12:07:23.156 - info: mihome-vacuum.0 (780) Disconnect
          dirkhe Developer last edited by
          Eigentlich reichen die Zeilen vorher vom Adapter. Wenn aber davor andere Sachen auch verrückt spielen oder da eine Menge los war, ist das vlt auch sinnvoll. Man kann an dem Log nicht erkennen, wo das ganze aufgetreten ist
            Hyperbit @Kueppert last edited by
            @Kueppert läuft das bei dir auf einem Raspberry?
            Ich lese da Out of Memory und interpretiere da hinein das der Prozess dann abgeschossen wurde (ist aber nur ein schneller Blick auf die deinen Logauszug vom Handy aus).
            Lg
              dirkhe Developer @Kueppert last edited by
              @Kueppert hier ist er gar nicht mit dem robbi verbunden. Irgendwann müsste dann auch noch ein Connect kommen.
                @dirkhe hab nochmal mehr logging über einen längeren Zeitraum hier angefügt:
                2020-03-27 11:35:22.125 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:35:25.829 - info: nut.0 (579) Start NUT update
                2020-03-27 11:35:25.842 - info: nut.0 (579) All Nut values set
                2020-03-27 11:35:26.171 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:35:34.549 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:35:42.176 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:35:46.727 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:35:54.377 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:36:06.046 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:36:12.678 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:36:12.679 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:36:12.679 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:36:12.946 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:36:12.963 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:36:12.979 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:36:13.132 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:36:13.348 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:36:17.454 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:36:42.170 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:36:48.611 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                2020-03-27 11:36:54.786 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:37:05.891 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:37:11.345 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:37:13.197 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:37:13.198 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:37:13.198 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:37:13.492 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:37:13.506 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:37:13.520 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:37:13.633 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:37:14.833 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:37:25.149 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:37:34.711 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:37:39.452 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:37:42.708 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:37:46.689 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:37:50.176 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:37:53.559 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:37:57.080 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:38:04.140 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:38:07.533 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:38:10.774 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:38:13.712 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:38:13.712 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:38:13.712 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:38:13.957 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:38:13.961 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:38:13.971 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:38:13.985 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:38:14.106 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:38:20.958 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:38:25.256 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:38:35.222 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:38:38.625 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:38:41.670 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:38:55.343 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:38:58.593 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:39:02.020 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:39:05.311 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:39:08.707 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:39:11.964 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:39:14.181 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:39:14.182 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:39:14.182 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:39:14.435 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:39:14.459 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:39:14.482 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:39:14.695 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:39:18.782 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:39:24.201 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:39:27.647 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:39:31.150 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:39:34.295 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:39:38.334 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:39:41.816 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:39:45.382 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:39:48.586 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:39:51.843 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:39:58.839 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:40:02.025 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:40:08.908 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:40:12.409 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:40:14.788 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:40:14.789 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:40:14.789 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:40:15.055 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:40:15.084 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:40:15.108 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:40:15.298 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:40:15.801 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:40:22.858 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:40:25.831 - info: nut.0 (579) Start NUT update
                2020-03-27 11:40:25.845 - info: nut.0 (579) All Nut values set
                2020-03-27 11:40:26.137 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:40:29.554 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:40:36.245 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:40:50.405 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                2020-03-27 11:40:52.555 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                2020-03-27 11:40:52.989 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:40:56.217 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:40:59.538 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:41:09.693 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:41:12.973 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:41:15.444 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:41:15.444 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:41:15.444 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:41:15.713 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:41:15.733 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:41:15.751 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:41:15.918 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:41:19.465 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:41:47.585 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:41:48.614 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                2020-03-27 11:41:51.106 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:41:54.358 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:42:01.150 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:42:11.353 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:42:15.881 - warn: sonoff.0 (636) Client "Sonoff-S10-Wohnzimmer" not connected
                2020-03-27 11:42:16.056 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:42:16.056 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:42:16.056 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:42:16.323 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:42:16.362 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:42:16.389 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:42:16.636 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:42:18.361 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:42:38.243 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:42:45.019 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:42:55.433 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:42:58.594 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:43:05.420 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:43:11.802 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:43:16.732 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:43:16.733 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:43:16.733 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:43:17.032 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:43:17.058 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:43:17.078 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:43:17.249 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:43:35.351 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:43:42.064 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:44:02.001 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:44:05.570 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:44:12.313 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:44:17.329 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:44:17.329 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:44:17.329 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:44:17.577 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:44:17.591 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:44:17.606 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:44:17.743 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:44:18.857 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:44:22.494 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:44:29.048 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:44:32.361 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:44:42.700 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:44:49.464 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:44:52.764 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:44:56.369 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:44:59.952 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:45:00.022 - info: host.ioBroker2 instance system.adapter.daswetter.0 started with pid 11811
                2020-03-27 11:45:01.781 - info: daswetter.0 (11811) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.0
                2020-03-27 11:45:02.610 - info: daswetter.0 (11811) Terminated (NO_ERROR): Without reason
                2020-03-27 11:45:03.120 - info: host.ioBroker2 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                2020-03-27 11:45:03.539 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:45:06.746 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:45:13.481 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:45:17.084 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:45:17.844 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:45:17.845 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:45:17.845 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:45:18.080 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:45:18.100 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:45:18.116 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:45:18.251 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:45:20.666 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:45:24.057 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:45:25.833 - info: nut.0 (579) Start NUT update
                2020-03-27 11:45:25.852 - info: nut.0 (579) All Nut values set
                2020-03-27 11:45:30.813 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:45:34.324 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:45:37.919 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:45:44.784 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:45:48.191 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:45:51.802 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:45:55.321 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:45:58.884 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:46:02.372 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:46:08.897 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:46:12.532 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:46:18.340 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:46:18.341 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:46:18.341 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:46:18.633 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:46:18.655 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:46:18.672 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:46:18.862 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:46:19.486 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:46:23.016 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:46:30.061 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:46:34.097 - info: info.0 (855) Popup news was read...
                2020-03-27 11:46:37.139 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:46:40.494 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:46:43.695 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:46:47.796 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                2020-03-27 11:46:48.617 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                2020-03-27 11:46:49.998 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                2020-03-27 11:46:50.524 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:46:53.865 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:46:57.326 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:47:00.643 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:47:08.240 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:47:15.347 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:47:19.006 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:47:19.007 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:47:19.007 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:47:19.293 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:47:19.316 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:47:19.335 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:47:19.488 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:47:22.019 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:47:28.878 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:47:35.391 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:47:40.287 - info: web-speedy.0 (2583) Execute timer with : 1800000 Currently running : false
                2020-03-27 11:47:40.288 - info: web-speedy.0 (2583) Run test on on Best Server found
                2020-03-27 11:47:40.292 - info: web-speedy.0 (2583) The speed test has been started and will take at maximum 30 seconds for a single test run
                2020-03-27 11:47:42.062 - info: web-speedy.0 (2583) Closest server found, running test
                2020-03-27 11:47:56.668 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:48:00.376 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:48:07.741 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:48:19.569 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:48:19.570 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:48:19.570 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:48:19.837 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:48:19.852 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:48:19.870 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:48:20.037 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:48:41.515 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:48:44.973 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:48:46.231 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.download_Mb, Alias=false
                2020-03-27 11:48:46.233 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.upload_Mb, Alias=false
                2020-03-27 11:48:46.267 - info: web-speedy.0 (2583) The speed test has been completed successfully.
                2020-03-27 11:48:55.771 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:48:59.039 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:49:06.111 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:49:09.562 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:49:12.898 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:49:16.380 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:49:20.187 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:49:20.188 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:49:20.188 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:49:20.438 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:49:20.461 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:49:20.485 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:49:20.639 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:49:26.764 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:49:47.270 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:49:50.761 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:50:08.038 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:50:15.685 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:50:20.725 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:50:20.726 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:50:20.726 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:50:21.037 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:50:21.059 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:50:21.071 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:50:21.177 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:50:22.688 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:50:25.834 - info: nut.0 (579) Start NUT update
                2020-03-27 11:50:25.854 - info: nut.0 (579) All Nut values set
                2020-03-27 11:50:57.626 - info: javascript.0 (459) script.js.common.Sonstiges.XiaomiVacuum-Map: iQontrol Staubsauger Datei geschrieben
                2020-03-27 11:51:21.298 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:51:21.298 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:51:21.298 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:51:21.565 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:51:21.582 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:51:21.609 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 11:51:21.849 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:51:22.830 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:51:42.831 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:51:48.621 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                2020-03-27 11:52:02.833 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:52:21.967 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:52:21.968 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:52:21.968 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:52:22.242 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:52:22.270 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:52:22.291 - info: unifi.0 (2203) getClientDevices: 22
                2020-03-27 11:52:22.501 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:52:22.834 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:52:42.835 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:52:47.306 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                2020-03-27 11:52:49.619 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                2020-03-27 11:53:02.837 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:53:22.645 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:53:22.646 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:53:22.646 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:53:22.839 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:53:22.902 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:53:22.916 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:53:22.931 - info: unifi.0 (2203) getClientDevices: 22
                2020-03-27 11:53:23.107 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:53:42.839 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:54:02.841 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:54:22.842 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:54:23.220 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:54:23.220 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:54:23.220 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:54:23.468 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:54:23.498 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:54:23.516 - info: unifi.0 (2203) getClientDevices: 22
                2020-03-27 11:54:23.660 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:54:42.843 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:55:02.843 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:55:22.844 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:55:23.758 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:55:23.759 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:55:23.759 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:55:24.018 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:55:24.038 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:55:24.056 - info: unifi.0 (2203) getClientDevices: 22
                2020-03-27 11:55:24.195 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:55:25.835 - info: nut.0 (579) Start NUT update
                2020-03-27 11:55:25.848 - info: nut.0 (579) All Nut values set
                2020-03-27 11:55:42.846 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:56:02.846 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:56:22.848 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:56:24.290 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:56:24.290 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:56:24.291 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:56:24.550 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:56:24.582 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:56:24.611 - info: unifi.0 (2203) getClientDevices: 22
                2020-03-27 11:56:24.744 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:56:42.849 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:56:48.623 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                2020-03-27 11:57:02.851 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:57:22.852 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:57:24.830 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:57:24.831 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:57:24.831 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:57:25.151 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:57:25.175 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:57:25.216 - info: unifi.0 (2203) getClientDevices: 22
                2020-03-27 11:57:25.375 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:57:42.852 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:58:02.854 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:58:22.855 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:58:25.493 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:58:25.494 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:58:25.494 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:58:25.797 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:58:25.816 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:58:25.842 - info: unifi.0 (2203) getClientDevices: 22
                2020-03-27 11:58:26.091 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:58:43.077 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:58:47.481 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                2020-03-27 11:58:49.626 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                2020-03-27 11:59:03.079 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:59:23.079 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 11:59:26.196 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 11:59:26.196 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 11:59:26.196 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 11:59:26.439 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 11:59:26.459 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 11:59:26.497 - info: unifi.0 (2203) getClientDevices: 22
                2020-03-27 11:59:26.634 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 11:59:43.081 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:00:00.023 - info: host.ioBroker2 instance system.adapter.daswetter.0 started with pid 29088
                2020-03-27 12:00:01.676 - info: daswetter.0 (29088) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.0
                2020-03-27 12:00:02.358 - info: daswetter.0 (29088) Terminated (NO_ERROR): Without reason
                2020-03-27 12:00:02.868 - info: host.ioBroker2 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                2020-03-27 12:00:03.125 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:00:04.040 - info: host.ioBroker2 instance system.adapter.ical.0 started with pid 29255
                2020-03-27 12:00:14.339 - info: host.ioBroker2 instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                2020-03-27 12:00:23.126 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:00:25.836 - info: nut.0 (579) Start NUT update
                2020-03-27 12:00:25.848 - info: nut.0 (579) All Nut values set
                2020-03-27 12:00:26.716 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:00:26.716 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:00:26.716 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:00:27.029 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:00:27.046 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:00:27.068 - info: unifi.0 (2203) getClientDevices: 22
                2020-03-27 12:00:27.207 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:00:43.127 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:01:03.128 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:01:23.130 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:01:27.323 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:01:27.323 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:01:27.324 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:01:27.619 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:01:27.640 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:01:27.667 - info: unifi.0 (2203) getClientDevices: 22
                2020-03-27 12:01:27.822 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:01:43.130 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:01:48.627 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                2020-03-27 12:02:03.136 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:02:23.137 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:02:27.898 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:02:27.898 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:02:27.898 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:02:28.239 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:02:28.254 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:02:28.269 - info: unifi.0 (2203) getClientDevices: 22
                2020-03-27 12:02:28.387 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:02:43.138 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:02:48.401 - info: javascript.0 (459) script.js.common.Sonstiges.TürenFenster-TextSkript: TürenFenster_getriggert
                2020-03-27 12:03:03.139 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:03:23.141 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:03:28.462 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:03:28.463 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:03:28.463 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:03:28.758 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:03:28.775 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:03:28.790 - info: unifi.0 (2203) getClientDevices: 22
                2020-03-27 12:03:28.962 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:03:43.142 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:04:03.143 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:04:23.144 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:04:29.045 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:04:29.045 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:04:29.045 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:04:29.312 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:04:29.326 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:04:29.339 - info: unifi.0 (2203) getClientDevices: 22
                2020-03-27 12:04:29.464 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:04:43.145 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:04:51.465 - info: javascript.0 (459) script.js.common.Sonstiges.TürenFenster-TextSkript: TürenFenster_getriggert
                2020-03-27 12:05:03.147 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:05:23.149 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:05:25.837 - info: nut.0 (579) Start NUT update
                2020-03-27 12:05:25.851 - info: nut.0 (579) All Nut values set
                2020-03-27 12:05:29.557 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:05:29.557 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:05:29.557 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:05:29.873 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:05:29.886 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:05:29.905 - info: unifi.0 (2203) getClientDevices: 22
                2020-03-27 12:05:30.022 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:05:43.151 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:06:03.151 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:06:16.826 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:16 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8822e208-397d-ca1f-0000-01711babce13","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:06:19.839 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:19 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"5b505204-c47a-87cb-0000-01711babdafa","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:06:23.153 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:06:23.300 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:23 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"68e38ade-5a0d-cfb2-0000-01711babe751","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:06:26.325 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:26 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8649174a-c919-a08e-0000-01711babf304","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:06:29.371 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:29 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"ec138f99-5fef-ac1a-0000-01711babff18","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:06:30.137 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:06:30.138 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:06:30.138 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:06:30.434 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:06:30.453 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:06:30.472 - info: unifi.0 (2203) getClientDevices: 22
                2020-03-27 12:06:30.684 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:06:32.426 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:32 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"349d92a7-bf60-22a9-0000-01711bac0b51","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:06:35.736 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:35 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"a7f090d2-a1ff-3817-0000-01711bac180b","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:06:39.023 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:38 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"33042f81-515d-efc9-0000-01711bac25fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:06:42.113 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:41 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f930393c-6d79-c7ad-0000-01711bac31af","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:06:43.153 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:06:45.389 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:45 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"f549b8fd-cb30-333c-0000-01711bac3e3a","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:06:48.626 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:48 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"afe7d6f9-52ff-75ff-0000-01711bac4a6d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:06:48.631 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                2020-03-27 12:06:52.019 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:51 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"01962472-7526-84f1-0000-01711bac58cd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:06:55.014 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:54 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"addcf6aa-172a-d7c0-0000-01711bac637c","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:06:58.346 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:06:58 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"37bc4ae2-30bf-d082-0000-01711bac701f","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:07:01.341 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:01 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"b9a60d2c-943f-7a23-0000-01711bac7c21","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:07:03.155 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:07:04.595 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:04 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"0f1c5fc0-fe2c-85b2-0000-01711bac89fd","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:07:07.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:07 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"67576ec9-5750-92b1-0000-01711bac9560","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:07:10.845 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:10 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"03737cb1-32cb-595c-0000-01711baca111","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:07:14.189 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:14 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"8a047e9d-2efe-578c-0000-01711bacae2d","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:07:17.174 - error: mihome-vacuum.0 (780) no map found on server___{"statusCode":403,"headers":{"server":"nginx","date":"Fri, 27 Mar 2020 11:07:17 GMT","content-length":"122","connection":"close","x-xiaomi-request-id":"2a63601a-70f8-7946-0000-01711bacbaa4","access-control-allow-origin":"*"},"request":{"uri":{"protocol":"https:","slashes":true,"auth":null,"host":"cnbj2.fds.api.xiaomi.com","port":443,"hostname":"cnbj2.fds.api.xiaomi.com","hash":null,"search":"?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","query":"Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","pathname":"/robomap/roboroommap/82487762/7","path":"/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs=","href":"https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/7?Expires=1585307176000&GalaxyAccessKeyId=5271733786445&Signature=O/rJtkhhKIQGz73JDbnDcWZYxUs="},"method":"GET","headers":{}}}
                2020-03-27 12:07:23.156 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:07:30.808 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:07:30.808 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:07:30.809 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:07:31.071 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:07:31.090 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:07:31.114 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:07:31.278 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:08:31.361 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:08:31.362 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:08:31.362 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:08:31.689 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:08:31.706 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:08:31.724 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:08:31.886 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:09:31.986 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:09:31.987 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:09:31.987 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:09:32.323 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:09:32.341 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:09:32.358 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:09:32.498 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:10:25.838 - info: nut.0 (579) Start NUT update
                2020-03-27 12:10:25.851 - info: nut.0 (579) All Nut values set
                2020-03-27 12:10:32.591 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:10:32.591 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:10:32.591 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:10:32.877 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:10:32.898 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:10:32.914 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:10:33.041 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:10:47.363 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                2020-03-27 12:10:49.501 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                2020-03-27 12:11:33.116 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:11:33.116 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:11:33.116 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:11:33.434 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:11:33.456 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:11:33.486 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:11:33.626 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:11:48.633 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                2020-03-27 12:12:33.713 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:12:33.713 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:12:33.713 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:12:34.034 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:12:34.049 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:12:34.067 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:12:34.186 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:12:59.391 - info: web.0 (519) ==>Connected system.user.admin from ::ffff:192.168.178.54
                2020-03-27 12:13:01.572 - info: web.0 (519) <==Disconnect system.user.admin from ::ffff:192.168.178.54 vis.0
                2020-03-27 12:13:34.264 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:13:34.264 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:13:34.264 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:13:34.591 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:13:34.606 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:13:34.620 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:13:34.749 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:14:34.825 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:14:34.826 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:14:34.826 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:14:35.119 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:14:35.147 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:14:35.170 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:14:35.371 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:15:00.026 - info: host.ioBroker2 instance system.adapter.daswetter.0 started with pid 14507
                2020-03-27 12:15:01.858 - info: daswetter.0 (14507) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v10.16.0
                2020-03-27 12:15:02.856 - info: daswetter.0 (14507) Terminated (NO_ERROR): Without reason
                2020-03-27 12:15:03.366 - info: host.ioBroker2 instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
                2020-03-27 12:15:25.840 - info: nut.0 (579) Start NUT update
                2020-03-27 12:15:25.853 - info: nut.0 (579) All Nut values set
                2020-03-27 12:15:35.479 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:15:35.480 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:15:35.480 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:15:35.754 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:15:35.770 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:15:35.788 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:15:35.950 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:16:34.114 - info: info.0 (855) Popup news was read...
                2020-03-27 12:16:36.046 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:16:36.046 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:16:36.047 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:16:36.292 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:16:36.318 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:16:36.337 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:16:36.473 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:16:48.635 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                2020-03-27 12:17:36.548 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:17:36.548 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:17:36.549 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:17:36.790 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:17:36.806 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:17:36.824 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:17:36.953 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:17:40.294 - info: web-speedy.0 (2583) Execute timer with : 1800000 Currently running : false
                2020-03-27 12:17:40.295 - info: web-speedy.0 (2583) Run test on on Best Server found
                2020-03-27 12:17:40.299 - info: web-speedy.0 (2583) The speed test has been started and will take at maximum 30 seconds for a single test run
                2020-03-27 12:17:42.155 - info: web-speedy.0 (2583) Closest server found, running test
                2020-03-27 12:18:37.039 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:18:37.040 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:18:37.040 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:18:37.300 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:18:37.317 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:18:37.331 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:18:37.481 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:18:44.897 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.download_Mb, Alias=false
                2020-03-27 12:18:44.901 - info: sql.0 (746) enabled logging of web-speedy.0.Results.speeds.upload_Mb, Alias=false
                2020-03-27 12:18:44.924 - info: web-speedy.0 (2583) The speed test has been completed successfully.
                2020-03-27 12:19:03.197 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:19:03.205 - info: mihome-vacuum.0 (780) Connected
                2020-03-27 12:19:37.593 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:19:37.594 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:19:37.594 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:19:37.931 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:19:37.963 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:19:37.994 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:19:38.324 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:20:25.841 - info: nut.0 (579) Start NUT update
                2020-03-27 12:20:25.869 - info: nut.0 (579) All Nut values set
                2020-03-27 12:20:27.984 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:20:38.626 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:20:38.627 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:20:38.627 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:20:38.929 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:20:38.949 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:20:38.967 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:20:39.175 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:20:49.946 - info: mihome-vacuum.0 (780) Disconnect
                2020-03-27 12:21:39.360 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:21:39.381 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:21:39.381 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:21:39.862 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:21:39.886 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:21:39.910 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:21:40.081 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:21:48.651 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                2020-03-27 12:22:38.105 - error: host.ioBroker2 Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 1: 0x8f9d10 node::Abort() [io.mihome-vacuum.0]
                2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 2: 0x8f9d5c [io.mihome-vacuum.0]
                2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 3: 0xaffd0e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[1]: 4: 0xafff44 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[2]: 5: 0xef4152 [io.mihome-vacuum.0]
                2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[3]: 6: 0xef4258 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.mihome-vacuum.0]
                2020-03-27 12:22:38.106 - error: host.ioBroker2 Caught by controller[4]: 7: 0xf00332 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[5]: 8: 0xf00c64 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[6]: 9: 0xf038d1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.mihome-vacuum.0]
                2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[7]: 10: 0xecbbb5 [io.mihome-vacuum.0]
                2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[8]: 11: 0xed342a v8::internal::Factory::NewRawOneByteString(int, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[9]: 12: 0x101ce9d v8::internal::String::SlowFlatten(v8::internal::Handle, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[10]: 13: 0xafd334 v8::internal::String::Flatten(v8::internal::Handle, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[11]: 14: 0xb2a2a1 v8::String::Value::Value(v8::Isolate*, v8::Local) [io.mihome-vacuum.0]
                2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[12]: 15: 0x9c4c33 node::StringBytes::Write(v8::Isolate*, char*, unsigned long, v8::Local, node::encoding, int*) [io.mihome-vacuum.0]
                2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[13]: 16: 0x9193fb [io.mihome-vacuum.0]
                2020-03-27 12:22:38.107 - error: host.ioBroker2 Caught by controller[13]: 17: 0x1de16585a2e1
                2020-03-27 12:22:38.107 - warn: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                2020-03-27 12:22:38.108 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                2020-03-27 12:22:38.108 - info: host.ioBroker2 Restart adapter system.adapter.mihome-vacuum.0 because enabled
                2020-03-27 12:22:40.300 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:22:40.301 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:22:40.301 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:22:40.568 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:22:40.588 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:22:40.607 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:22:40.872 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:23:08.163 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 started with pid 23991
                2020-03-27 12:23:11.961 - info: mihome-vacuum.0 (23991) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
                2020-03-27 12:23:12.083 - info: mihome-vacuum.0 (23991) Expert mode disabled, states deleted
                2020-03-27 12:23:12.084 - info: mihome-vacuum.0 (23991) Create state clean_home for controlling by cloud adapter
                2020-03-27 12:23:12.100 - info: mihome-vacuum.0 (23991) Disconnect
                2020-03-27 12:23:12.147 - info: mihome-vacuum.0 (23991) New generation or new fw detected, create new states goto and zoneclean
                2020-03-27 12:23:12.183 - info: mihome-vacuum.0 (23991) Connected
                2020-03-27 12:23:12.652 - info: mihome-vacuum.0 (23991) set nächster Timer: Nicht verfügbar
                2020-03-27 12:23:15.110 - info: mihome-vacuum.0 (23991) create state for carpet_mode
                2020-03-27 12:23:41.038 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:23:41.039 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:23:41.039 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:23:41.299 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:23:41.319 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:23:41.347 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:23:41.566 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:24:41.033 - info: mihome-vacuum.0 (23991) Disconnect
                2020-03-27 12:24:41.677 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:24:41.677 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:24:41.677 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:24:41.944 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:24:41.987 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:24:42.025 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:24:42.222 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:25:03.902 - error: host.ioBroker2 Caught by controller[0]: FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 1: 0x8f9d10 node::Abort() [io.mihome-vacuum.0]
                2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 2: 0x8f9d5c [io.mihome-vacuum.0]
                2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 3: 0xaffd0e v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 4: 0xafff44 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [io.mihome-vacuum.0]
                2020-03-27 12:25:03.903 - error: host.ioBroker2 Caught by controller[1]: 5: 0xef4152 [io.mihome-vacuum.0]
                2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 6: 0xef4258 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [io.mihome-vacuum.0]
                2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 7: 0xf00332 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 8: 0xf00c64 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [io.mihome-vacuum.0]
                2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 9: 0xf038d1 v8::internal::Heap::AllocateRawWithRetryOrFail(int, v8::internal::AllocationSpace, v8::internal::AllocationAlignment) [io.mihome-vacuum.0]
                2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 10: 0xecbbb5 [io.mihome-vacuum.0]
                2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 11: 0xed342a v8::internal::Factory::NewRawOneByteString(int, v8::internal::PretenureFlag) [io.mihome-vacuum.0]
                2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 12: 0x1203785 v8::internal::IncrementalStringBuilder::Extend() [io.mihome-vacuum.0]
                2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 13: 0xfc74f2 v8::internal::JsonStringifier::SerializeString(v8::internal::Handle) [io.mihome-vacuum.0]
                2020-03-27 12:25:03.904 - error: host.ioBroker2 Caught by controller[2]: 14: 0xfc7d9b v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_(v8::internal::Handle, bool, v8::internal::Handle) [io.mihome-vacuum.0]
                2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[2]: 15: 0xfccead v8::internal::JsonStringifier::Result v8::internal::JsonStringifier::Serialize_(v8::internal::Handle, bool, v8::internal::Handle) [io.mihome-vacuum.0]
                2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[2]: 16: 0xfcdc09 v8::internal::JsonStringifier::Stringify(v8::internal::Handle, v8::internal::Handle, v8::internal::Handle) [io.mihome-vacuum.0]
                2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[3]: 17: 0xbd46d1 v8::internal::Builtin_JsonStringify(int, v8::internal::Object**, v8::internal::Isolate*) [io.mihome-vacuum.0]
                2020-03-27 12:25:03.905 - error: host.ioBroker2 Caught by controller[3]: 18: 0xbcdda65bf7d
                2020-03-27 12:25:03.905 - warn: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated due to SIGABRT
                2020-03-27 12:25:03.905 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 terminated with code NaN ()
                2020-03-27 12:25:03.905 - info: host.ioBroker2 Restart adapter system.adapter.mihome-vacuum.0 because enabled
                2020-03-27 12:25:25.848 - info: nut.0 (579) Start NUT update
                2020-03-27 12:25:25.949 - info: nut.0 (579) All Nut values set
                2020-03-27 12:25:33.930 - info: host.ioBroker2 instance system.adapter.mihome-vacuum.0 started with pid 26894
                2020-03-27 12:25:37.015 - info: mihome-vacuum.0 (26894) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
                2020-03-27 12:25:37.080 - info: mihome-vacuum.0 (26894) Expert mode disabled, states deleted
                2020-03-27 12:25:37.081 - info: mihome-vacuum.0 (26894) Create state clean_home for controlling by cloud adapter
                2020-03-27 12:25:37.093 - info: mihome-vacuum.0 (26894) Disconnect
                2020-03-27 12:25:37.132 - info: mihome-vacuum.0 (26894) New generation or new fw detected, create new states goto and zoneclean
                2020-03-27 12:25:37.160 - info: mihome-vacuum.0 (26894) Connected
                2020-03-27 12:25:37.617 - info: mihome-vacuum.0 (26894) set nächster Timer: Nicht verfügbar
                2020-03-27 12:25:42.445 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:25:42.446 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:25:42.446 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:25:42.750 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:25:42.772 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:25:42.789 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:25:42.985 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:25:52.169 - warn: mihome-vacuum.0 (26894) no answer received after after 3 times -> pause miIO.info from request parameters, try again in one hour
                2020-03-27 12:26:17.096 - info: mihome-vacuum.0 (26894) Disconnect
                2020-03-27 12:26:17.101 - info: mihome-vacuum.0 (26894) Connected
                2020-03-27 12:26:43.100 - info: unifi.0 (2203) Starting UniFi-Controller query
                2020-03-27 12:26:43.101 - info: unifi.0 (2203) update_interval = 60
                2020-03-27 12:26:43.101 - info: unifi.0 (2203) controller = 192.168.178.71:8443
                2020-03-27 12:26:43.383 - info: unifi.0 (2203) getSitesStats: default
                2020-03-27 12:26:43.396 - info: unifi.0 (2203) getSiteSysinfo: 1
                2020-03-27 12:26:43.410 - info: unifi.0 (2203) getClientDevices: 23
                2020-03-27 12:26:43.557 - info: unifi.0 (2203) getAccessDevices: 1
                2020-03-27 12:26:48.940 - info: tankerkoenig.0 (1238) Reading data from tankerkoenig ...
                2020-03-27 12:26:57.098 - info: mihome-vacuum.0 (26894) Disconnect
                2020-03-27 12:26:57.107 - info: mihome-vacuum.0 (26894) Connected
                2020-03-27 12:27:37.102 - info: mihome-vacuum.0 (26894) Disconnect
                2020-03-27 12:27:37.157 - info: mihome-vacuum.0 (26894) Connected
                Ein Memory-Problem sollte ich eigentlich nicht haben mit 3,5 GB
                  dirkhe Developer @Kueppert last edited by
                  @Kueppert das kommt ja regelmäßig. Was mich wundert ist, dass er ständig disconnected. Kannst du mal die aktuelle Version installieren, bitte? Dann mal auf Debug stellen. Das sieht aus wie eine recursion, aber aktuell weiß ich gar nicht, wo das sein könnte. Allerdings bin ich beim abrufen der Karte auch nicht so tief im Code.
                    Kueppert @dirkhe last edited by Kueppert
                    @dirkhe habe jetzt 2.0.9 drauf via Katze und Adapter steht auf Debug. Ich warte mal was ab...ggf muss ich den Saugi auch mal starten, damit was passiert 😉 Danke dir schon mal für die Unterstützung.
                    Erster Auszug:
                    mihome-vacuum.0	2020-03-27 14:53:24.911	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:53:24.910	debug	(29151) no answer for undefined(id:25) received, giving up
                    mihome-vacuum.0	2020-03-27 14:53:19.910	debug	(29151) sendMsg[3] >>> {"id":25,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:53:14.909	debug	(29151) sendMsg[2] >>> {"id":25,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:53:09.909	debug	(29151) sendMsg[1] >>> {"id":25,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:53:09.906	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:53:09.906	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:53:09.906	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0545ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:53:04.950	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:53:04.949	debug	(29151) no answer for undefined(id:24) received, giving up
                    mihome-vacuum.0	2020-03-27 14:52:59.949	debug	(29151) sendMsg[3] >>> {"id":24,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:52:54.948	debug	(29151) sendMsg[2] >>> {"id":24,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:52:49.947	debug	(29151) sendMsg[1] >>> {"id":24,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:52:49.914	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:52:49.914	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:52:49.913	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0531ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:52:44.927	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:52:44.927	debug	(29151) no answer for undefined(id:23) received, giving up
                    mihome-vacuum.0	2020-03-27 14:52:39.925	debug	(29151) sendMsg[3] >>> {"id":23,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:52:34.906	debug	(29151) sendMsg[2] >>> {"id":23,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:52:29.905	debug	(29151) sendMsg[1] >>> {"id":23,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:52:29.903	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:52:29.903	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:52:29.902	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e051dffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:52:24.914	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:52:24.914	debug	(29151) no answer for undefined(id:22) received, giving up
                    mihome-vacuum.0	2020-03-27 14:52:19.913	debug	(29151) sendMsg[3] >>> {"id":22,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:52:14.911	debug	(29151) sendMsg[2] >>> {"id":22,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:52:09.910	debug	(29151) sendMsg[1] >>> {"id":22,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:52:09.902	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:52:09.901	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:52:09.901	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0509ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:52:04.907	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:52:04.906	debug	(29151) no answer for undefined(id:21) received, giving up
                    mihome-vacuum.0	2020-03-27 14:51:59.905	debug	(29151) sendMsg[3] >>> {"id":21,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:51:54.904	debug	(29151) sendMsg[2] >>> {"id":21,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:51:49.904	debug	(29151) sendMsg[1] >>> {"id":21,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:51:49.901	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:51:49.900	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:51:49.900	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e04f5ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:51:44.905	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:51:44.905	debug	(29151) no answer for undefined(id:20) received, giving up
                    mihome-vacuum.0	2020-03-27 14:51:39.903	debug	(29151) sendMsg[3] >>> {"id":20,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:51:34.902	debug	(29151) sendMsg[2] >>> {"id":20,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:51:29.901	debug	(29151) sendMsg[1] >>> {"id":20,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:51:29.900	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:51:29.899	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:51:29.899	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e04e1ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:51:24.904	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:51:24.904	debug	(29151) no answer for undefined(id:19) received, giving up
                    mihome-vacuum.0	2020-03-27 14:51:19.903	debug	(29151) sendMsg[3] >>> {"id":19,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:51:14.901	debug	(29151) sendMsg[2] >>> {"id":19,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:51:09.900	debug	(29151) sendMsg[1] >>> {"id":19,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:51:09.898	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:51:09.898	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:51:09.897	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e04cdffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:51:04.919	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:51:04.918	debug	(29151) no answer for undefined(id:18) received, giving up
                    mihome-vacuum.0	2020-03-27 14:50:59.917	debug	(29151) sendMsg[3] >>> {"id":18,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:50:54.915	debug	(29151) sendMsg[2] >>> {"id":18,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:50:49.914	debug	(29151) sendMsg[1] >>> {"id":18,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:50:49.898	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:50:49.898	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:50:49.898	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e04b9ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:50:44.903	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:50:44.903	debug	(29151) no answer for undefined(id:17) received, giving up
                    mihome-vacuum.0	2020-03-27 14:50:39.901	debug	(29151) sendMsg[3] >>> {"id":17,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:50:34.900	debug	(29151) sendMsg[2] >>> {"id":17,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:50:29.899	debug	(29151) sendMsg[1] >>> {"id":17,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:50:29.896	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:50:29.896	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:50:29.896	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e04a5ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:50:24.904	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:50:24.904	debug	(29151) no answer for undefined(id:16) received, giving up
                    mihome-vacuum.0	2020-03-27 14:50:19.904	debug	(29151) sendMsg[3] >>> {"id":16,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:50:14.902	debug	(29151) sendMsg[2] >>> {"id":16,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:50:09.900	debug	(29151) sendMsg[1] >>> {"id":16,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:50:09.895	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:50:09.894	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:50:09.894	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0491ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:50:04.903	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:50:04.903	debug	(29151) no answer for undefined(id:15) received, giving up
                    mihome-vacuum.0	2020-03-27 14:49:59.901	debug	(29151) sendMsg[3] >>> {"id":15,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:49:54.900	debug	(29151) sendMsg[2] >>> {"id":15,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:49:49.900	debug	(29151) sendMsg[1] >>> {"id":15,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:49:49.894	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:49:49.894	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:49:49.893	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e047dffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:49:44.900	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:49:44.899	debug	(29151) no answer for undefined(id:14) received, giving up
                    mihome-vacuum.0	2020-03-27 14:49:39.898	debug	(29151) sendMsg[3] >>> {"id":14,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:49:34.897	debug	(29151) sendMsg[2] >>> {"id":14,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:49:29.896	debug	(29151) sendMsg[1] >>> {"id":14,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:49:29.893	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:49:29.893	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:49:29.892	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0469ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:49:24.898	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:49:24.898	debug	(29151) no answer for undefined(id:13) received, giving up
                    mihome-vacuum.0	2020-03-27 14:49:19.898	debug	(29151) sendMsg[3] >>> {"id":13,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:49:14.896	debug	(29151) sendMsg[2] >>> {"id":13,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:49:09.894	debug	(29151) sendMsg[1] >>> {"id":13,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:49:09.891	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:49:09.890	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:49:09.890	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0455ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:49:04.911	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:49:04.911	debug	(29151) no answer for undefined(id:12) received, giving up
                    mihome-vacuum.0	2020-03-27 14:48:59.909	debug	(29151) sendMsg[3] >>> {"id":12,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:48:54.907	debug	(29151) sendMsg[2] >>> {"id":12,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:48:49.906	debug	(29151) sendMsg[1] >>> {"id":12,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:48:49.891	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:48:49.891	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:48:49.890	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0441ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:48:44.902	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:48:44.902	debug	(29151) no answer for undefined(id:11) received, giving up
                    mihome-vacuum.0	2020-03-27 14:48:39.900	debug	(29151) sendMsg[3] >>> {"id":11,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:48:34.899	debug	(29151) sendMsg[2] >>> {"id":11,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:48:29.897	debug	(29151) sendMsg[1] >>> {"id":11,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:48:29.891	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:48:29.891	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:48:29.890	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e042dffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:48:24.938	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:48:24.938	debug	(29151) no answer for undefined(id:10) received, giving up
                    mihome-vacuum.0	2020-03-27 14:48:19.937	debug	(29151) sendMsg[3] >>> {"id":10,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:48:14.935	debug	(29151) sendMsg[2] >>> {"id":10,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:48:09.934	debug	(29151) sendMsg[1] >>> {"id":10,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:48:09.888	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:48:09.888	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:48:09.887	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0419ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:48:04.906	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:48:04.905	debug	(29151) no answer for undefined(id:9) received, giving up
                    mihome-vacuum.0	2020-03-27 14:47:59.904	debug	(29151) sendMsg[3] >>> {"id":9,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:47:54.902	debug	(29151) sendMsg[2] >>> {"id":9,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:47:49.901	debug	(29151) sendMsg[1] >>> {"id":9,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:47:49.888	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:47:49.888	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:47:49.887	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0405ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:47:44.898	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:47:44.897	debug	(29151) no answer for undefined(id:8) received, giving up
                    mihome-vacuum.0	2020-03-27 14:47:39.895	debug	(29151) sendMsg[3] >>> {"id":8,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:47:34.894	debug	(29151) sendMsg[2] >>> {"id":8,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:47:29.892	debug	(29151) sendMsg[1] >>> {"id":8,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:47:29.887	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:47:29.887	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:47:29.887	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e03f1ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:47:24.899	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:47:24.898	debug	(29151) no answer for undefined(id:7) received, giving up
                    mihome-vacuum.0	2020-03-27 14:47:19.897	debug	(29151) sendMsg[3] >>> {"id":7,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:47:14.895	debug	(29151) sendMsg[2] >>> {"id":7,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:47:09.893	debug	(29151) sendMsg[1] >>> {"id":7,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:47:09.886	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:47:09.886	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:47:09.886	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e03ddffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:47:04.905	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:47:04.905	debug	(29151) no answer for undefined(id:6) received, giving up
                    mihome-vacuum.0	2020-03-27 14:46:59.903	debug	(29151) sendMsg[3] >>> {"id":6,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:46:54.901	debug	(29151) sendMsg[2] >>> {"id":6,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:46:49.899	debug	(29151) sendMsg[1] >>> {"id":6,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:46:49.886	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:46:49.886	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:46:49.886	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e03c9ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:46:44.892	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:46:44.892	debug	(29151) no answer for undefined(id:5) received, giving up
                    mihome-vacuum.0	2020-03-27 14:46:39.890	debug	(29151) sendMsg[3] >>> {"id":5,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:46:34.889	debug	(29151) sendMsg[2] >>> {"id":5,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:46:29.887	debug	(29151) sendMsg[1] >>> {"id":5,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:46:29.884	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:46:29.883	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:46:29.883	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e03b5ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:46:24.891	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:46:24.890	debug	(29151) no answer for undefined(id:4) received, giving up
                    mihome-vacuum.0	2020-03-27 14:46:23.350	debug	(29151) system.adapter.admin.0: logging true
                    mihome-vacuum.0	2020-03-27 14:45:49.893	debug	(29151) sendMsg[1] >>> {"id":3,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:45:49.885	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:45:49.884	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:45:49.884	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e038dffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:45:39.890	debug	(29151) sendMsg[3] >>> {"id":2,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:45:34.889	debug	(29151) sendMsg[2] >>> {"id":2,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:45:29.888	debug	(29151) sendMsg[1] >>> {"id":2,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:45:29.883	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:45:29.883	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:45:29.882	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0379ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:45:24.978	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:45:24.978	debug	(29151) no answer for undefined(id:1) received, giving up
                    mihome-vacuum.0	2020-03-27 14:45:19.977	debug	(29151) sendMsg[3] >>> {"id":1,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:45:14.976	debug	(29151) sendMsg[2] >>> {"id":1,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:45:12.042	debug	(29151) Xiaomi Cloud: Login successful
                    mihome-vacuum.0	2020-03-27 14:45:10.409	info	(29151) set nächster Timer: Nicht verfügbar
                    mihome-vacuum.0	2020-03-27 14:45:09.974	debug	(29151) sendMsg[1] >>> {"id":1,"method":"get_status"}
                    mihome-vacuum.0	2020-03-27 14:45:09.956	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                    mihome-vacuum.0	2020-03-27 14:45:09.955	info	(29151) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:45:09.954	debug	(29151) Receive <<< Helo <<< 213100200000000004eaa9d25e7e0365ffffffffffffffffffffffffffffffff
                    mihome-vacuum.0	2020-03-27 14:45:09.948	info	(29151) New generation or new fw(3.5.4,004004) detected, create new states goto and zoneclean
                    mihome-vacuum.0	2020-03-27 14:45:09.885	debug	(29151) server started on 0.0.0.0:53421
                    mihome-vacuum.0	2020-03-27 14:45:09.863	info	(29151) Create state clean_home for controlling by cloud adapter
                    mihome-vacuum.0	2020-03-27 14:45:09.861	info	(29151) Expert mode disabled, states deleted
                    mihome-vacuum.0	2020-03-27 14:45:09.848	debug	(29151) Xiaomi Cloud: Logging in
                    mihome-vacuum.0	2020-03-27 14:45:09.847	debug	(29151) load Map creator... true
                    mihome-vacuum.0	2020-03-27 14:45:09.776	info	(29151) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
                    mihome-vacuum.0	2020-03-27 14:45:04.283	info	(28505) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    mihome-vacuum.0	2020-03-27 14:45:04.281	info	(28505) terminating
                    mihome-vacuum.0	2020-03-27 14:45:04.280	info	(28505) Got terminate signal TERMINATE_YOURSELF
                    mihome-vacuum.0	2020-03-27 14:44:43.305	info	(28505) create state for carpet_mode
                    mihome-vacuum.0	2020-03-27 14:44:42.775	info	(28505) set nächster Timer: Nicht verfügbar
                    mihome-vacuum.0	2020-03-27 14:44:42.287	info	(28505) Connected
                    mihome-vacuum.0	2020-03-27 14:44:42.246	info	(28505) connecting, this can take up to 10 minutes ...
                    mihome-vacuum.0	2020-03-27 14:44:42.224	info	(28505) New generation or new fw(3.5.4,004004) detected, create new states goto and zoneclean
                    mihome-vacuum.0	2020-03-27 14:44:42.179	info	(28505) Create state clean_home for controlling by cloud adapter
                    mihome-vacuum.0	2020-03-27 14:44:42.178	info	(28505) Expert mode disabled, states deleted
                    mihome-vacuum.0	2020-03-27 14:44:42.092	info	(28505) starting. Version 2.0.9-RC07 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.16.0
                    mihome-vacuum.0	2020-03-27 14:44:34.501	info	(26894) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                    mihome-vacuum.0	2020-03-27 14:44:34.500	info	(26894) terminating
                    mihome-vacuum.0	2020-03-27 14:44:34.499	info	(26894) Got terminate signal TERMINATE_YOURSELF
                      Kueppert @Kueppert last edited by
                      @dirkhe dann habe ich gerade mal die MiHome-App geöffnet und den Staubi angeklickt, da passiert was im Log:
                      mihome-vacuum.0	2020-03-27 14:56:51.929	debug	(29151) Mappointer_updated
                      mihome-vacuum.0	2020-03-27 14:56:51.928	debug	(29151) Receive <<< {"result":["roboroommap%2F82487762%2F6"],"id":70}
                      mihome-vacuum.0	2020-03-27 14:56:51.923	debug	(29151) sendMsg[1] >>> {"id":70,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-27 14:56:50.431	debug	(29151) Receive <<< {"result":[268569,4074617500,145,[1585305280,1583161415,1582365313,1582274907,1581673021,1580981012,1580463233,1580371947,1579857633,1579250658,1578393704,1577711651,1577701268,157
                      mihome-vacuum.0	2020-03-27 14:56:50.423	debug	(29151) sendMsg[1] >>> {"id":69,"method":"get_clean_summary"}
                      mihome-vacuum.0	2020-03-27 14:56:49.932	debug	(29151) Receive <<< {"result":[{"main_brush_work_time":268569,"side_brush_work_time":268569,"filter_work_time":268569,"sensor_dirty_time":22220}],"id":68}
                      mihome-vacuum.0	2020-03-27 14:56:49.922	debug	(29151) sendMsg[1] >>> {"id":68,"method":"get_consumable"}
                      mihome-vacuum.0	2020-03-27 14:56:49.918	debug	(29151) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2055,"state":8,"battery":100,"clean_time":1882,"clean_area":33882500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":0
                      mihome-vacuum.0	2020-03-27 14:56:49.912	debug	(29151) sendMsg[1] >>> {"id":67,"method":"get_status"}
                      mihome-vacuum.0	2020-03-27 14:56:37.022	debug	(29151) 25604
                      mihome-vacuum.0	2020-03-27 14:56:35.580	debug	(29151) update_Map got new time:1585317393
                      mihome-vacuum.0	2020-03-27 14:56:35.580	debug	(29151) update_Map got new expires:1585319195
                      mihome-vacuum.0	2020-03-27 14:56:35.579	debug	(29151) update_Map got new url:https://cnbj2.fds.api.xiaomi.com/robomap/roboroommap/82487762/3?Expires=1585319195000&GalaxyAccessKeyId=5271733786445&Signature=7rSJ64eWNT8XkG/3l6kHPHiGBtE=
                      mihome-vacuum.0	2020-03-27 14:56:34.765	debug	(29151) CLEAN_LOGGING[{"Datum":"27.3","Start":"11:34","Saugzeit":"31 min","Fläche":"33.88 m²","Error":0,"Ende":true},{"Datum":"2.3","Start":"16:03","Saugzeit":"1 min","Fläche":"1.27 m²","Error":0,"End
                      mihome-vacuum.0	2020-03-27 14:56:34.569	debug	(29151) Receive <<< {"result":[[1570894237,1570896347,1961,33425000,0,1]],"id":66}
                      mihome-vacuum.0	2020-03-27 14:56:34.563	debug	(29151) sendMsg[1] >>> {"id":66,"method":"get_clean_record","params":[1570894237]}
                      mihome-vacuum.0	2020-03-27 14:56:34.367	debug	(29151) Receive <<< {"result":[[1571385380,1571387768,2388,35787500,0,1]],"id":65}
                      mihome-vacuum.0	2020-03-27 14:56:34.361	debug	(29151) sendMsg[1] >>> {"id":65,"method":"get_clean_record","params":[1571385380]}
                      mihome-vacuum.0	2020-03-27 14:56:34.166	debug	(29151) Receive <<< {"result":[[1572341803,1572343814,2011,33695000,0,1]],"id":64}
                      mihome-vacuum.0	2020-03-27 14:56:34.160	debug	(29151) sendMsg[1] >>> {"id":64,"method":"get_clean_record","params":[1572341803]}
                      mihome-vacuum.0	2020-03-27 14:56:33.964	debug	(29151) Receive <<< {"result":[[1573114531,1573116539,2008,33780000,0,1]],"id":63}
                      mihome-vacuum.0	2020-03-27 14:56:33.959	debug	(29151) sendMsg[1] >>> {"id":63,"method":"get_clean_record","params":[1573114531]}
                      mihome-vacuum.0	2020-03-27 14:56:33.764	debug	(29151) Receive <<< {"result":[[1573808322,1573810637,2315,35065000,0,1]],"id":62}
                      mihome-vacuum.0	2020-03-27 14:56:33.757	debug	(29151) sendMsg[1] >>> {"id":62,"method":"get_clean_record","params":[1573808322]}
                      mihome-vacuum.0	2020-03-27 14:56:33.561	debug	(29151) Receive <<< {"result":[[1576490060,1576492145,2085,33827500,0,1]],"id":61}
                      mihome-vacuum.0	2020-03-27 14:56:33.556	debug	(29151) sendMsg[1] >>> {"id":61,"method":"get_clean_record","params":[1576490060]}
                      mihome-vacuum.0	2020-03-27 14:56:33.361	debug	(29151) Receive <<< {"result":[[1577088558,1577089956,1398,19932500,0,1]],"id":60}
                      mihome-vacuum.0	2020-03-27 14:56:33.355	debug	(29151) sendMsg[1] >>> {"id":60,"method":"get_clean_record","params":[1577088558]}
                      mihome-vacuum.0	2020-03-27 14:56:33.168	debug	(29151) update_Map need new mapurl
                      mihome-vacuum.0	2020-03-27 14:56:33.168	debug	(29151) update_Map Mimap enabled
                      mihome-vacuum.0	2020-03-27 14:56:33.167	debug	(29151) Mappointer_updated
                      mihome-vacuum.0	2020-03-27 14:56:33.167	debug	(29151) Receive <<< {"result":["roboroommap%2F82487762%2F3"],"id":59}
                      mihome-vacuum.0	2020-03-27 14:56:33.162	debug	(29151) Receive <<< {"result":[[1577701268,1577701837,569,5437500,0,1]],"id":58}
                      mihome-vacuum.0	2020-03-27 14:56:33.161	debug	(29151) 3. Mappointer_nomap___retry
                      mihome-vacuum.0	2020-03-27 14:56:33.161	debug	(29151) sendMsg[1] >>> {"id":59,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-27 14:56:33.154	debug	(29151) sendMsg[1] >>> {"id":58,"method":"get_clean_record","params":[1577701268]}
                      mihome-vacuum.0	2020-03-27 14:56:32.960	debug	(29151) Receive <<< {"result":[[1577711651,1577712390,739,13485000,0,1]],"id":57}
                      mihome-vacuum.0	2020-03-27 14:56:32.953	debug	(29151) sendMsg[1] >>> {"id":57,"method":"get_clean_record","params":[1577711651]}
                      mihome-vacuum.0	2020-03-27 14:56:32.759	debug	(29151) Receive <<< {"result":[[1578393704,1578395855,2151,33467500,0,1]],"id":56}
                      mihome-vacuum.0	2020-03-27 14:56:32.751	debug	(29151) sendMsg[1] >>> {"id":56,"method":"get_clean_record","params":[1578393704]}
                      mihome-vacuum.0	2020-03-27 14:56:32.660	debug	(29151) Receive <<< {"result":["retry"],"id":55}
                      mihome-vacuum.0	2020-03-27 14:56:32.654	debug	(29151) 2. Mappointer_nomap___retry
                      mihome-vacuum.0	2020-03-27 14:56:32.654	debug	(29151) sendMsg[1] >>> {"id":55,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-27 14:56:32.555	debug	(29151) Receive <<< {"result":[[1579250658,1579253070,2412,36095000,0,1]],"id":54}
                      mihome-vacuum.0	2020-03-27 14:56:32.549	debug	(29151) sendMsg[1] >>> {"id":54,"method":"get_clean_record","params":[1579250658]}
                      mihome-vacuum.0	2020-03-27 14:56:32.355	debug	(29151) Receive <<< {"result":[[1579857633,1579859588,1955,33762500,0,1]],"id":53}
                      mihome-vacuum.0	2020-03-27 14:56:32.348	debug	(29151) sendMsg[1] >>> {"id":53,"method":"get_clean_record","params":[1579857633]}
                      mihome-vacuum.0	2020-03-27 14:56:32.154	debug	(29151) Receive <<< {"result":[[1580371947,1580373899,1952,33397500,0,1]],"id":52}
                      mihome-vacuum.0	2020-03-27 14:56:32.153	debug	(29151) Receive <<< {"result":["retry"],"id":51}
                      mihome-vacuum.0	2020-03-27 14:56:32.147	debug	(29151) sendMsg[1] >>> {"id":52,"method":"get_clean_record","params":[1580371947]}
                      mihome-vacuum.0	2020-03-27 14:56:32.144	debug	(29151) 1. Mappointer_nomap___retry
                      mihome-vacuum.0	2020-03-27 14:56:32.144	debug	(29151) sendMsg[1] >>> {"id":51,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-27 14:56:31.951	debug	(29151) Receive <<< {"result":[[1580463233,1580468445,2521,36215000,0,1]],"id":50}
                      mihome-vacuum.0	2020-03-27 14:56:31.945	debug	(29151) sendMsg[1] >>> {"id":50,"method":"get_clean_record","params":[1580463233]}
                      mihome-vacuum.0	2020-03-27 14:56:31.750	debug	(29151) Receive <<< {"result":[[1580981012,1580983420,2408,36150000,0,1]],"id":49}
                      mihome-vacuum.0	2020-03-27 14:56:31.744	debug	(29151) sendMsg[1] >>> {"id":49,"method":"get_clean_record","params":[1580981012]}
                      mihome-vacuum.0	2020-03-27 14:56:31.643	debug	(29151) Receive <<< {"result":["retry"],"id":48}
                      mihome-vacuum.0	2020-03-27 14:56:31.638	debug	(29151) 0. Mappointer_nomap___retry
                      mihome-vacuum.0	2020-03-27 14:56:31.638	debug	(29151) sendMsg[1] >>> {"id":48,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-27 14:56:31.549	debug	(29151) Receive <<< {"result":[[1581673021,1581675073,2052,33732500,0,1]],"id":47}
                      mihome-vacuum.0	2020-03-27 14:56:31.543	debug	(29151) sendMsg[1] >>> {"id":47,"method":"get_clean_record","params":[1581673021]}
                      mihome-vacuum.0	2020-03-27 14:56:31.349	debug	(29151) Receive <<< {"result":[[1582274907,1582276815,1908,33457500,0,1]],"id":46}
                      mihome-vacuum.0	2020-03-27 14:56:31.342	debug	(29151) sendMsg[1] >>> {"id":46,"method":"get_clean_record","params":[1582274907]}
                      mihome-vacuum.0	2020-03-27 14:56:31.147	debug	(29151) Receive <<< {"result":[[1582365313,1582367499,2186,38605000,0,1]],"id":45}
                      mihome-vacuum.0	2020-03-27 14:56:31.141	debug	(29151) sendMsg[1] >>> {"id":45,"method":"get_clean_record","params":[1582365313]}
                      mihome-vacuum.0	2020-03-27 14:56:31.136	debug	(29151) Receive <<< {"result":["retry"],"id":44}
                      mihome-vacuum.0	2020-03-27 14:56:31.129	debug	(29151) sendMsg[1] >>> {"id":44,"method":"get_map_v1"}
                      mihome-vacuum.0	2020-03-27 14:56:30.946	debug	(29151) Receive <<< {"result":[[1583161415,1583161534,54,1272500,0,0]],"id":43}
                      mihome-vacuum.0	2020-03-27 14:56:30.940	debug	(29151) sendMsg[1] >>> {"id":43,"method":"get_clean_record","params":[1583161415]}
                      mihome-vacuum.0	2020-03-27 14:56:30.936	debug	(29151) Receive <<< {"result":"unknown_method","id":42}
                      mihome-vacuum.0	2020-03-27 14:56:30.935	info	(29151) create state for carpet_mode
                      mihome-vacuum.0	2020-03-27 14:56:30.935	debug	(29151) Receive <<< {"result":[{"enable":0,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":41}
                      mihome-vacuum.0	2020-03-27 14:56:30.929	debug	(29151) sendMsg[1] >>> {"id":42,"method":"get_room_mapping"}
                      mihome-vacuum.0	2020-03-27 14:56:30.928	debug	(29151) sendMsg[1] >>> {"id":41,"method":"get_carpet_mode"}
                      mihome-vacuum.0	2020-03-27 14:56:30.746	debug	(29151) Receive <<< {"result":[[1585305280,1585307162,1882,33882500,0,1]],"id":40}
                      mihome-vacuum.0	2020-03-27 14:56:30.739	debug	(29151) sendMsg[1] >>> {"id":40,"method":"get_clean_record","params":[1585305280]}
                      mihome-vacuum.0	2020-03-27 14:56:30.737	debug	(29151) Receive <<< {"result":[268569,4074617500,145,[1585305280,1583161415,1582365313,1582274907,1581673021,1580981012,1580463233,1580371947,1579857633,1579250658,1578393704,1577711651,1577701268,157
                      mihome-vacuum.0	2020-03-27 14:56:30.728	debug	(29151) sendMsg[1] >>> {"id":39,"method":"get_clean_summary"}
                      mihome-vacuum.0	2020-03-27 14:56:30.533	debug	(29151) Receive <<< {"result":[{"main_brush_work_time":268569,"side_brush_work_time":268569,"filter_work_time":268569,"sensor_dirty_time":22220}],"id":38}
                      mihome-vacuum.0	2020-03-27 14:56:30.528	debug	(29151) sendMsg[1] >>> {"id":38,"method":"get_consumable"}
                      mihome-vacuum.0	2020-03-27 14:56:30.333	debug	(29151) Receive <<< {"result":[30],"id":37}
                      mihome-vacuum.0	2020-03-27 14:56:30.328	debug	(29151) sendMsg[1] >>> {"id":37,"method":"get_sound_volume"}
                      mihome-vacuum.0	2020-03-27 14:56:30.133	debug	(29151) Receive <<< {"partner_id":"","id":36,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.4_004004","ap":{"ssid":"Unifi_EG","bssid":"18:E8:29:94:F0:F8","rssi":-38},"netif":{"localI
                      mihome-vacuum.0	2020-03-27 14:56:30.130	debug	(29151) Next WiFi check: 27.03 14:57
                      mihome-vacuum.0	2020-03-27 14:56:30.129	debug	(29151) sendMsg[1] >>> {"id":36,"method":"miIO.info"}
                      mihome-vacuum.0	2020-03-27 14:56:29.927	info	(29151) Connected
                      mihome-vacuum.0	2020-03-27 14:56:29.924	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                      mihome-vacuum.0	2020-03-27 14:56:29.922	debug	(29151) Receive <<< {"result":[{"msg_ver":8,"msg_seq":2042,"state":8,"battery":100,"clean_time":1882,"clean_area":33882500,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":77,"dnd_enabled":0
                      mihome-vacuum.0	2020-03-27 14:56:29.917	debug	(29151) sendMsg[1] >>> {"id":35,"method":"get_status"}
                      mihome-vacuum.0	2020-03-27 14:56:29.914	debug	(29151) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                      mihome-vacuum.0	2020-03-27 14:56:29.914	info	(29151) connecting, this can take up to 10 minutes ...
                        @Kueppert jetzt bist du on Track ..
                        Kannst den debuglevel wieder runter setzten. Wir wissen zwar jetzt immer noch nicht, wo die rekursion ist.
                          root_ last edited by
                          Hab einen Mi home Vacuum und bekomme mit der 2.0.9 die Zonenreinigung nicht mehr hin.
                          Hat bis jetzt immer funktioniert. Hab einen neuen Raum mit den Koordinaten angelegt. Das hat auch funktioniert. Bekomme aber folgende Meldung wenn ich die Reinigung starte:
                          mihome-vacuum.0	2020-03-28 16:36:49.032	error	(100061) [24159,24383,28759,25933,1] ->mihome-vacuum.0.rooms.manual_24159_24383_28759_25933
                          mihome-vacuum.0	2020-03-28 16:36:49.001	info	(100061) trigger cleaning zone [24159,24383,28759,25933,1]
                            dirkhe Developer @root_ last edited by
                            @root_ kannst du mal den loglevel auf debug stellen und nochmal probieren, bitte
                            • Jan Fiedler
                              Jan Fiedler last edited by
                              Gibt es eine Möglichkeit die Raumkoordinaten auszulesen, ohne Valetudo zu installieren?
                              ? D 2 Replies Last reply Reply Quote 0
                                A Former User @Jan Fiedler last edited by
                                @Jan-Fiedler sagte in Test Adapter mihome-vacuum v2.0.x:
                                mit der Flole-App ( Android ), auf Zonenreinigung gehen, Zone markieren, dann auf Reinigen und den Finger drauflassen, bis "Zone wurde in die Zwischenablage kopiert" erscheint.
                                Dann c+p wohin. Damit geht die "Raumreinigung" mit allen Modellen, die noch auf der alten Firmware sind.
                                Jan Fiedler 1 Reply Last reply Reply Quote 0
                                • Elektroniker86
                                  Elektroniker86 last edited by
                                  Ich habe eben versucht den Adapter über die Katze /Githublink zu installieren, allerdings nicht erfolgreich.
                                  obroker host.IoBroker-Pi4 Cannot install https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/tarball/c2dcd9c10ccd505e22854e3bd4f7323a1b752dd3
                                  Muss ich vorher den alten Adapter deinstallieren vielleicht?
                                  Ich habe zwei Instanzen des alten Adapters pausiert und dann versucht zu installieren.
                                    root_ @dirkhe last edited by
                                    @dirkhe said in Test Adapter mihome-vacuum v2.0.x:
                                    mihome-vacuum.0	2020-03-29 16:23:06.651	debug	(92536) Receive <<< {"result":[1846515,23124062500,707,[]],"id":13}
                                    mihome-vacuum.0	2020-03-29 16:23:06.644	debug	(92536) sendMsg[1] >>> {"id":13,"method":"get_clean_summary"}
                                    mihome-vacuum.0	2020-03-29 16:23:06.150	debug	(92536) Receive <<< {"result":[{"main_brush_work_time":484190,"side_brush_work_time":484190,"filter_work_time":291118,"sensor_dirty_time":48205}],"id":12}
                                    mihome-vacuum.0	2020-03-29 16:23:06.140	debug	(92536) sendMsg[1] >>> {"id":12,"method":"get_consumable"}
                                    mihome-vacuum.0	2020-03-29 16:23:06.135	debug	(92536) Receive <<< {"result":[{"msg_ver":8,"msg_seq":203,"state":8,"battery":100,"clean_time":0,"clean_area":0,"error_code":0,"map_present":1,"in_cleaning":0,"fan_power":90,"dnd_enabled":0}],"id":11
                                    mihome-vacuum.0	2020-03-29 16:23:06.125	debug	(92536) sendMsg[1] >>> {"id":11,"method":"get_status"}
                                    mihome-vacuum.0	2020-03-29 16:23:04.192	error	(92536) [24159,24383,28759,25933,1] ->mihome-vacuum.0.rooms.manual_24159_24383_28759_25933
                                    mihome-vacuum.0	2020-03-29 16:23:04.145	debug	(92536) Receive <<< {"result":["ok"],"id":10}
                                    mihome-vacuum.0	2020-03-29 16:23:04.133	debug	(92536) sendMsg[1] >>> {"id":10,"method":"set_custom_mode","params":[90]}
                                    mihome-vacuum.0	2020-03-29 16:23:04.132	debug	(92536) stateChange mihome-vacuum.0.control.fan_power {"val":90,"ack":false,"ts":1585491784127,"q":0,"from":"system.adapter.mihome-vacuum.0","user":"system.user.admin","lc":1541688856539}
                                    mihome-vacuum.0	2020-03-29 16:23:04.123	info	(92536) trigger cleaning zone [24159,24383,28759,25933,1]
                                    mihome-vacuum.0	2020-03-29 16:23:04.115	debug	(92536) sendTo "cleanZone" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
                                      @root_ welche Version hast du genau, das sieht man, wenn man den adapter startet. Ich habe die ganze zeit gesucht und ich kann aktuell nicht mal die Stelle finden, wo diese Fehlermeldung geschrieben wird. Bitte nochmal die aktuelle Version rc07 installieren. Funktioniert das denn, wenn du die Koordinaten über sendCustomcommand eingibst?
                                        mihome-vacuum.0	2020-03-29 17:04:53.496	info	(45717) connecting, This can take up to 5 minutes ...
                                        mihome-vacuum.0	2020-03-29 17:04:53.494	debug	(45717) Receive <<< Helo <<< 213100200000000004e9e7315e80b915ffffffffffffffffffffffffffffffff
                                        mihome-vacuum.0	2020-03-29 17:04:53.460	info	(45717) New generation or new fw(3.5.4,004007) detected, create new states goto and zoneclean
                                        mihome-vacuum.0	2020-03-29 17:04:53.397	debug	(45717) server started on 0.0.0.0:53421
                                        mihome-vacuum.0	2020-03-29 17:04:53.386	info	(45717) Disconnect
                                        mihome-vacuum.0	2020-03-29 17:04:53.373	info	(45717) Create state clean_home for controlling by cloud adapter
                                        mihome-vacuum.0	2020-03-29 17:04:53.372	info	(45717) Expert mode enabled, states created
                                        mihome-vacuum.0	2020-03-29 17:04:53.353	debug	(45717) Xiaomi Cloud: Logging in
                                        mihome-vacuum.0	2020-03-29 17:04:53.350	debug	(45717) load Map creator... true
                                        mihome-vacuum.0	2020-03-29 17:04:53.263	info	(45717) starting. Version 2.0.9 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v10.19.0
                                        host.raspberry	2020-03-29 17:04:48.816	info	instance system.adapter.mihome-vacuum.0 started with pid 45717
                                        Hab gerade noch mal über git upgedatet aber von RC07 steht bei mir nix
                                          @root_ wenn man in der Package.json schaut, sollte da 2.0.9 rc07. Installiere bitte mal via url https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum, aber eigentlich sollte das das gleiche sein. Bin gerade ratlos
                                          • Jan Fiedler
                                            Jan Fiedler @Guest last edited by
                                            @ilovegym Das geht leider mit den neuen Karten nicht mehr...Kann man die Räume evtl mehrfach per multipleRoomClean durchlaufen lassen?
                                            map mihome-vacuum roborock xiaomi
                                            144
                                            1474
                                            493935
