    4. Test/Support für Adapter rssfeed und vis-2-widgets-rssfeed
    • O
      Oli @OliverIO last edited by
      @OliverIO
      er bringt komischerweise auch keine Fehler
      rssfeed.0	2020-03-26 12:34:31.807	info	(25410) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.rssfeed, node: v10.19.0
      rssfeed.0	2020-03-26 12:34:30.321	debug	(25410) statesDB connected
      rssfeed.0	2020-03-26 12:34:30.320	debug	(25410) States connected to redis: 127.0.0.1:9000
      rssfeed.0	2020-03-26 12:34:30.290	debug	(25410) States create System PubSub Client
      rssfeed.0	2020-03-26 12:34:30.288	debug	(25410) States create User PubSub Client
      rssfeed.0	2020-03-26 12:34:30.252	debug	(25410) Redis States: Use Redis connection: 127.0.0.1:9000
      rssfeed.0	2020-03-26 12:34:30.249	debug	(25410) objectDB connected
      rssfeed.0	2020-03-26 12:34:30.239	debug	(25410) Objects connected to redis: 127.0.0.1:9001
      rssfeed.0	2020-03-26 12:34:30.210	debug	(25410) Objects client initialize lua scripts
      rssfeed.0	2020-03-26 12:34:30.209	debug	(25410) Objects create User PubSub Client
      rssfeed.0	2020-03-26 12:34:30.207	debug	(25410) Objects create System PubSub Client
      rssfeed.0	2020-03-26 12:34:30.169	debug	(25410) Objects client ready ... initialize now
      rssfeed.0	2020-03-26 12:34:30.108	debug	(25410) Redis Objects: Use Redis connection: 127.0.0.1:9001
      rssfeed.0	2020-03-26 12:34:26.055	info	(25164) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      rssfeed.0	2020-03-26 12:34:26.053	info	(25164) terminating
      rssfeed.0	2020-03-26 12:34:26.052	info	(25164) cleaned everything up...
      rssfeed.0	2020-03-26 12:34:26.051	debug	(25164) deleteObservers
      rssfeed.0	2020-03-26 12:34:26.051	debug	(25164) closeConnections
      rssfeed.0	2020-03-26 12:34:26.049	info	(25164) Got terminate signal TERMINATE_YOURSELF
      rssfeed.0	2020-03-26 12:34:20.091	debug	(25164) system.adapter.admin.0: logging false
      rssfeed.0	2020-03-26 12:34:01.353	info	(25164) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.rssfeed, node: v10.19.0
      rssfeed.0	2020-03-26 12:33:59.910	debug	(25164) statesDB connected
      rssfeed.0	2020-03-26 12:33:59.909	debug	(25164) States connected to redis: 127.0.0.1:9000
      rssfeed.0	2020-03-26 12:33:59.879	debug	(25164) States create System PubSub Client
      rssfeed.0	2020-03-26 12:33:59.876	debug	(25164) States create User PubSub Client
      rssfeed.0	2020-03-26 12:33:59.859	debug	(25164) Redis States: Use Redis connection: 127.0.0.1:9000
      rssfeed.0	2020-03-26 12:33:59.856	debug	(25164) objectDB connected
      rssfeed.0	2020-03-26 12:33:59.847	debug	(25164) Objects connected to redis: 127.0.0.1:9001
      rssfeed.0	2020-03-26 12:33:59.819	debug	(25164) Objects client initialize lua scripts
      rssfeed.0	2020-03-26 12:33:59.818	debug	(25164) Objects create User PubSub Client
      rssfeed.0	2020-03-26 12:33:59.817	debug	(25164) Objects create System PubSub Client
      rssfeed.0	2020-03-26 12:33:59.811	debug	(25164) Objects client ready ... initialize now
      rssfeed.0	2020-03-26 12:33:59.757	debug	(25164) Redis Objects: Use Redis connection: 127.0.0.1:9001
      rssfeed.0	2020-03-26 12:33:55.708	info	(24576) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      rssfeed.0	2020-03-26 12:33:55.706	info	(24576) terminating
      rssfeed.0	2020-03-26 12:33:55.705	info	(24576) cleaned everything up...
      rssfeed.0	2020-03-26 12:33:55.702	info	(24576) Got terminate signal TERMINATE_YOURSELF
      rssfeed.0	2020-03-26 12:32:44.984	info	(24576) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.rssfeed, node: v10.19.0
      rssfeed.0	2020-03-26 12:32:40.019	info	(24212) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      rssfeed.0	2020-03-26 12:32:40.017	info	(24212) terminating
      rssfeed.0	2020-03-26 12:32:40.016	info	(24212) cleaned everything up...
      rssfeed.0	2020-03-26 12:32:40.013	info	(24212) Got terminate signal TERMINATE_YOURSELF
      rssfeed.0	2020-03-26 12:31:51.811	info	(24212) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.rssfeed, node: v10.19.0
      rssfeed.0	2020-03-26 12:31:46.949	info	(20931) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      rssfeed.0	2020-03-26 12:31:46.948	info	(20931) terminating
      rssfeed.0	2020-03-26 12:31:46.947	info	(20931) cleaned everything up...
      rssfeed.0	2020-03-26 12:31:46.944	info	(20931) Got terminate signal TERMINATE_YOURSELF
      rssfeed.0	2020-03-26 12:24:50.823	info	(20931) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.rssfeed, node: v10.19.0
      rssfeed.0	2020-03-26 12:24:46.101	info	(16404) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
      rssfeed.0	2020-03-26 12:24:46.100	info	(16404) terminating
      rssfeed.0	2020-03-26 12:24:46.098	info	(16404) cleaned everything up...
      rssfeed.0	2020-03-26 12:24:46.095	info	(16404) Got terminate signal TERMINATE_YOURSELF
      • OliverIO
        OliverIO @Oli last edited by
        @Oli
        hast du beendet? oder beendet er sich immer wieder selbst.
        schalte mal bei den instanzen im expertenmodus von info auf debug.
        Bei sigi234 hat die Aktualisierung einwandfrei geklappt
        Alternativ auch den adapter komplett entfernen (nicht nur die instanz) und neu installieren
        • O
          @OliverIO
          habe jetzt alles deinstalliert und neu installiert, gleiches Ergebnis, hier der Log:
          ssfeed.0	2020-03-26 13:57:25.457	debug	(31282) system.adapter.admin.0: logging true
          rssfeed.0	2020-03-26 13:57:21.369	info	(31282) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.rssfeed, node: v10.19.0
          rssfeed.0	2020-03-26 13:57:20.517	debug	(31282) statesDB connected
          rssfeed.0	2020-03-26 13:57:20.516	debug	(31282) States connected to redis: 127.0.0.1:9000
          rssfeed.0	2020-03-26 13:57:20.473	debug	(31282) States create System PubSub Client
          rssfeed.0	2020-03-26 13:57:20.467	debug	(31282) States create User PubSub Client
          rssfeed.0	2020-03-26 13:57:19.966	debug	(31282) Redis States: Use Redis connection: 127.0.0.1:9000
          rssfeed.0	2020-03-26 13:57:19.962	debug	(31282) objectDB connected
          rssfeed.0	2020-03-26 13:57:19.954	debug	(31282) Objects connected to redis: 127.0.0.1:9001
          rssfeed.0	2020-03-26 13:57:19.927	debug	(31282) Objects client initialize lua scripts
          rssfeed.0	2020-03-26 13:57:19.926	debug	(31282) Objects create User PubSub Client
          rssfeed.0	2020-03-26 13:57:19.925	debug	(31282) Objects create System PubSub Client
          rssfeed.0	2020-03-26 13:57:19.919	debug	(31282) Objects client ready ... initialize now
          rssfeed.0	2020-03-26 13:57:19.868	debug	(31282) Redis Objects: Use Redis connection: 127.0.0.1:9001
          rssfeed.0	2020-03-26 13:57:16.525	debug	(31214) got articles #: 40 from Tagesschau
          rssfeed.0	2020-03-26 13:57:15.771	info	(31214) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          rssfeed.0	2020-03-26 13:57:15.770	info	(31214) terminating
          rssfeed.0	2020-03-26 13:57:15.769	info	(31214) cleaned everything up...
          rssfeed.0	2020-03-26 13:57:15.768	debug	(31214) deleteObservers
          rssfeed.0	2020-03-26 13:57:15.768	debug	(31214) closeConnections
          rssfeed.0	2020-03-26 13:57:15.766	info	(31214) Got terminate signal TERMINATE_YOURSELF
          rssfeed.0	2020-03-26 13:57:15.644	debug	(31214) request: http://www.tagesschau.de/xml/rss2
          rssfeed.0	2020-03-26 13:57:15.602	info	(31214) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.rssfeed, node: v10.19.0
          rssfeed.0	2020-03-26 13:57:13.763	debug	(31214) statesDB connected
          rssfeed.0	2020-03-26 13:57:13.762	debug	(31214) States connected to redis: 127.0.0.1:9000
          rssfeed.0	2020-03-26 13:57:13.711	debug	(31214) States create System PubSub Client
          rssfeed.0	2020-03-26 13:57:13.709	debug	(31214) States create User PubSub Client
          rssfeed.0	2020-03-26 13:57:13.692	debug	(31214) Redis States: Use Redis connection: 127.0.0.1:9000
          rssfeed.0	2020-03-26 13:57:13.688	debug	(31214) objectDB connected
          rssfeed.0	2020-03-26 13:57:13.679	debug	(31214) Objects connected to redis: 127.0.0.1:9001
          rssfeed.0	2020-03-26 13:57:13.651	debug	(31214) Objects client initialize lua scripts
          rssfeed.0	2020-03-26 13:57:13.650	debug	(31214) Objects create User PubSub Client
          rssfeed.0	2020-03-26 13:57:13.648	debug	(31214) Objects create System PubSub Client
          rssfeed.0	2020-03-26 13:57:13.642	debug	(31214) Objects client ready ... initialize now
          rssfeed.0	2020-03-26 13:57:13.591	debug	(31214) Redis Objects: Use Redis connection: 127.0.0.1:9001
          rssfeed.0	2020-03-26 13:57:09.512	info	(30604) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          rssfeed.0	2020-03-26 13:57:09.511	info	(30604) terminating
          rssfeed.0	2020-03-26 13:57:09.510	info	(30604) cleaned everything up...
          rssfeed.0	2020-03-26 13:57:09.509	debug	(30604) deleteObservers
          rssfeed.0	2020-03-26 13:57:09.509	debug	(30604) closeConnections
          rssfeed.0	2020-03-26 13:57:09.507	info	(30604) Got terminate signal TERMINATE_YOURSELF
          rssfeed.0	2020-03-26 13:56:22.800	debug	(30604) system.adapter.admin.0: logging false
          rssfeed.0	2020-03-26 13:55:54.640	info	(30604) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.rssfeed, node: v10.19.0
          rssfeed.0	2020-03-26 13:55:53.905	debug	(30604) statesDB connected
          rssfeed.0	2020-03-26 13:55:53.904	debug	(30604) States connected to redis: 127.0.0.1:9000
          rssfeed.0	2020-03-26 13:55:53.876	debug	(30604) States create System PubSub Client
          rssfeed.0	2020-03-26 13:55:53.873	debug	(30604) States create User PubSub Client
          rssfeed.0	2020-03-26 13:55:53.856	debug	(30604) Redis States: Use Redis connection: 127.0.0.1:9000
          rssfeed.0	2020-03-26 13:55:53.852	debug	(30604) objectDB connected
          rssfeed.0	2020-03-26 13:55:53.844	debug	(30604) Objects connected to redis: 127.0.0.1:9001
          rssfeed.0	2020-03-26 13:55:53.817	debug	(30604) Objects client initialize lua scripts
          rssfeed.0	2020-03-26 13:55:53.816	debug	(30604) Objects create User PubSub Client
          rssfeed.0	2020-03-26 13:55:53.814	debug	(30604) Objects create System PubSub Client
          rssfeed.0	2020-03-26 13:55:53.791	debug	(30604) Objects client ready ... initialize now
          rssfeed.0	2020-03-26 13:55:53.726	debug	(30604) Redis Objects: Use Redis connection: 127.0.0.1:9001
          rssfeed.0	2020-03-26 13:55:49.683	info	(30272) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          rssfeed.0	2020-03-26 13:55:49.682	info	(30272) terminating
          rssfeed.0	2020-03-26 13:55:49.681	info	(30272) cleaned everything up...
          rssfeed.0	2020-03-26 13:55:49.678	info	(30272) Got terminate signal TERMINATE_YOURSELF
          rssfeed.0	2020-03-26 13:55:18.002	info	(30272) starting. Version 0.0.14 in /opt/iobroker/node_modules/iobroker.rssfeed, node: v10.19.0
          • OliverIO
            @Oli
            du hattes da nicht den force Knopf gedrückt?
            Im log finde ich nur 'Debugmeldungen von iobroker, die mit rssfeed zu tun haben,
            aber kein code von mir wurde da aufgerufen.
            Habe versucht das bei mir nachzustellen, und tatsächlich scheint es da ein Problem zu geben.
            Ich schau da mal heute Abend.
            • OliverIO
              Neue Version 0.0.15
              • Ein sehr lästiger Fehler, für den ich sehr tief in den iobroker-code hineinkriechen musste ist nun endlich behoben. Die Datenpunkte werden werden wieder abgerufen.
              • Mit loglevel debug gibt der Adapter nun sehr viel Informationen zum Ablauf aus.
              Da ich Änderungen an der Adapterkonfiguration vornehmen musste, wäre es gut, wenn die Instanz komplett deinstalliert wird und dann neu installiert wird.
              Zum Test hilft es auch die Datenpunkte der feeds unter rssfeed.0 zu löschen
              Über eine Nachricht ob es funktioniert würde ich mich freuen
              • O
                @OliverIO
                habe gerade die neue Version getestet,
                Datenpunkte werden leider immer noch nicht angelegt.
                Bostil 1 Reply Last reply Reply Quote 0
                • Bostil
                  Bostil @Oli last edited by Bostil
                  @Oli Hatte gerade auch beim Testen das Problem. Lag wohl daran, dass ich als Name erneut "Tagesschau" gewählt habe. Hab den Eintrag nun als Tagesschau2 angelegt und nun erstellt er wieder einen Datenpunkt und ruft Nachrichten ab.
                  Tolle Arbeit @OliverIO Macht sich prima ...
                  O S 2 Replies Last reply Reply Quote 1
                  • O
                    Oli @Bostil last edited by
                    @Bostil
                    genau das war es, danke!!
                    • OliverIO
                      @Oli @Bostil
                      Eigentlich sollte man keine 2 Einträge mit dem gleichen Namen anlegen können.
                      Das werd ich verbessern
                        sigi234 Forum Testing Most Active @OliverIO last edited by sigi234
                        @OliverIO
                        Hallo, ist es möglich die Schriftfarbe bei item.title in Abhängigkeit vom Text zu ändern? bindings?
                        Also item.title = Das Wort Türöffnung kommt vor = dann Farbe GELB
                        = Das Wort Brand kommt vor = dann Farbe ROT
                        = Das Wort Technischer Einsatz kommt vor = dann Farbe BLAU
                        = Das Wort Sturm kommt vor = dann Farbe GRÜN
                        Derzeitiges Template:
                        <h4><meta.title style="color:#a9a7a7"><%- meta.title %></h4>
                        <img src="<%- meta.image.url %>">
                        <% articles.forEach(function(item){ %>
                        <p><item.pubdate style="color:Orange">Veröffentlichungsdatum: <%- vis.formatDate(item.pubdate, "TT.MM.JJJJ SS:mm")%> Uhr</p>
                        <h3><item.title style="color:lime"><%- item.title %></h3>
                        <p><%- item.description %></p>
                        <div style="clear:both;" />
                          skokarl @Bostil last edited by skokarl
                          @Bostil
                          möchtest Du mal das Hintergrund Bild hier spendieren ?, sieht klasse aus.
                          @OliverIO mal wieder eine super Umsetzung von Dir, geil.... so was habe ich auch schon lange gesucht
                            skokarl last edited by
                            Wie macht ihr das mit der Laufschrift ?
                            Ich möchte nur den Einzeiler, und das als Laufschrift.
                              sigi234 Forum Testing Most Active @skokarl last edited by
                              @skokarl
                              maxarticles
                                skokarl @sigi234 last edited by skokarl
                                @sigi234
                                nee Sigi,.....falsches Widget 🤕
                                Danke Dir !
                                @OliverIO
                                ich liebe Deine Adapter .....😇
                                  skokarl last edited by skokarl
                                  wenn jemand den n-tv rss gefunden hat .......
                                  der hier bringt nur ein xml file
                                  	https://www.n-tv.de/rss
                                  • O
                                    @OliverIO
                                    echt ein super Adapter, schade dass man das ganze nur einmal liken kann.
                                    Hallo an alle.
                                    die templates sind noch nicht ganz meine Freunde, vielleicht kann mir ja von euch jemand helfen.
                                    Ich versuche mich gerade an folgenden rss-feed:
                                    https://www.hoerzu.de/rss/tipp/spielfilm/
                                    Nun möchte ich folgendes realisieren:
                                    1. Oben Anzeige der Sendezeit
                                    2. Ein Bild der Sendung anzeigen lassen
                                    3. Den eingefügten Link aktive schalten
                                    Ist das möglich und wenn ja, wie?
                                    OliverIO SBorg 2 Replies Last reply Reply Quote 1
                                      Ash2k last edited by
                                      super spannender Adapter, habe ich mir schon lange gewünscht 🙂
                                      Ich möchte das gerne als Newsticker nutzen, daher dachte ich das Widget Marquee ist das Richtige für mich. Jedoch wenn ich die rss_oid auswähle passiert in der View anschließend nichts, es ist einfach nichts zu sehen.
                                      Vermutlich hab ich nur irgendwas übersehen aber vielleicht kann mir jemand auf die Sprünge helfen?
                                      S OliverIO 2 Replies Last reply Reply Quote 0
                                        skokarl @Ash2k last edited by skokarl
                                        @Ash2k
                                        siehst du in einem anderen Widget was ? ( rss feed widget )
                                          Ash2k @skokarl last edited by
                                          @skokarl ja im "normalen" Feed Widget mit dem Template aus dem Eingangsbeitrag hier erscheint was.
                                          • OliverIO
                                            OliverIO @Ash2k last edited by
                                            @Ash2k
                                            habs gerade ausprobiert. funktioniert, hab nur festgestellt, das das widget das falsche bildchen hat, aber das ist für dier funktion irrelevant
                                            adapter atom feed iobroker.rssfeed rdf rss vis widget
                                            34
                                            690
                                            144584
