    4. Test Coronavirus Statistics for ioBroker
    • CKMartens
      CKMartens @Guest last edited by
      @Yetiberg Schon passiert, aber trotzdem:
      coronavirus-statistics.0	2020-03-28 10:05:35.514	warn	(4302) Libyan_Arab_Jamahiriya not found in lib! Must be added to the country name translator.
      coronavirus-statistics.0	2020-03-28 10:05:35.493	warn	(4302) MS_Zaandam not found in lib! Must be added to the country name translator.
      coronavirus-statistics.0	2020-03-28 10:05:35.464	warn	(4302) Holy_See_(Vatican_City_State) not found in lib! Must be added to the country name translator.
      coronavirus-statistics.0	2020-03-28 10:05:35.448	warn	(4302) Syrian_Arab_Republic not found in lib! Must be added to the country name translator.
      coronavirus-statistics.0	2020-03-28 10:05:35.097	warn	(4302) Tanzania,_United_Republic_of not found in lib! Must be added to the country name translator.
      coronavirus-statistics.0	2020-03-28 10:05:35.034	warn	(4302) Congo,_the_Democratic_Republic_of_the not found in lib! Must be added to the country name translator.
      coronavirus-statistics.0	2020-03-28 10:05:34.734	warn	(4302) Palestinian_Territory,_Occupied not found in lib! Must be added to the country name translator.
      coronavirus-statistics.0	2020-03-28 10:05:34.716	warn	(4302) Coast_D'Ivoire not found in lib! Must be added to the country name translator.
      coronavirus-statistics.0	2020-03-28 10:05:34.653	warn	(4302) Moldova,_Republic_of not found in lib! Must be added to the country name translator.
      coronavirus-statistics.0	2020-03-28 10:05:34.633	warn	(4302) Bosnia not found in lib! Must be added to the country name translator.
      coronavirus-statistics.0	2020-03-28 10:05:29.272	info	(4302) user defined country translation added: Bosnia -> Bosnien und Herzegowina
      coronavirus-statistics.0	2020-03-28 10:05:29.272	info	(4302) user defined country translation added: Moldova,_Republic_of -> Moldawien
      coronavirus-statistics.0	2020-03-28 10:05:29.272	info	(4302) user defined country translation added: Venezuela,_Bolivarian_Republic_of -> Venezuela
      coronavirus-statistics.0	2020-03-28 10:05:29.272	info	(4302) user defined country translation added: Coast_D'Ivoire -> Elfenbeinküste
      coronavirus-statistics.0	2020-03-28 10:05:29.272	info	(4302) user defined country translation added: Palestinian_Territory,_Occupied -> Palästinensische Autonomiegebiete
      coronavirus-statistics.0	2020-03-28 10:05:29.272	info	(4302) user defined country translation added: Congo,_the_Democratic_Republic_of_the -> Demokratische Republik Kongo
      coronavirus-statistics.0	2020-03-28 10:05:29.272	info	(4302) user defined country translation added: Tanzania,_United_Republic_of -> Tansania
      coronavirus-statistics.0	2020-03-28 10:05:29.272	info	(4302) user defined country translation added: Lao_People's_Democratic_Republic -> Laos
      coronavirus-statistics.0	2020-03-28 10:05:29.271	info	(4302) user defined country translation added: Syrian_Arab_Republic -> Syrien
      coronavirus-statistics.0	2020-03-28 10:05:29.271	info	(4302) user defined country translation added: Holy_See_(Vatican_City_State) -> Vatikanstadt
      coronavirus-statistics.0	2020-03-28 10:05:29.271	info	(4302) user defined country translation added: MS_Zaandam -> MS Zaandam
      coronavirus-statistics.0	2020-03-28 10:05:29.271	info	(4302) user defined country translation added: Libyan_Arab_Jamahiriya -> Libyeb
      coronavirus-statistics.0	2020-03-28 10:05:22.036	info	(4302) starting. Version 0.4.8 in /opt/iobroker/node_modules/iobroker.coronavirus-statistics, node: v10.19.0
      I Dutchman 2 Replies Last reply Reply Quote 0
      • I
        intruder7 @CKMartens last edited by
        @Dutchman Halli Hallo, ist es möglich in die States nur dann zu schreiben wenn sich der Wert vom ursprünglichen unterscheidet? Hintergrund: ich logge mit dem SQL Adapter die Werte mt und es werden ganz viele gleiche Werte geschrieben obwohl ich Aufzeichnung nur bei Änderung aktiviert habe.
        Liebe Grüße
        C Dutchman 2 Replies Last reply Reply Quote 0
          CruziX @intruder7 last edited by
          @intruder7 setz doch in die Sql Einstellungen ein delta
          • Dutchman
            Dutchman Developer Most Active Administrators @intruder7 last edited by
            @intruder7 sagte in Test Coronavirus Statistics for ioBroker:
            Liebe Grüße
            bitte issue erstellen
            ich probiere das Thema hier so gut wie moeglich zu folgen aber programmier Sachen übersehe das bitte per git dan kan ich auch regieren/status melden
            • Dutchman
              Dutchman Developer Most Active Administrators @CKMartens last edited by
              @CKMartens sagte in Test Coronavirus Statistics for ioBroker:
              es ist ein major update unterwegs womit dies geloest ist gimme me some time today 🙂
              • Dutchman
                Dutchman Developer Most Active Administrators last edited by Dutchman
                So Leute nach 2 Tagen intensief API durchnehmen und Zusammenarbeit kan ich endlich rufen
                MAJOR UPDATE 0.4.9 ==> READY for testing !!!
                Warum Major : Da wir die Laender Namen jetzt anders einlesen, kan es passieren das states fuer euch neue Namen bekommen (Deutschland hat sich nicht geaendert)
                Wen ihr die letzte tage ab und zu mal von git gezogen habt, kan es sein das ihr einige datapunkte an falschen stellen habt, ich empfehle dan : Loeschen und adapter neu erstellen lassen
                Sollte sich Datenpunkte geaendert haben die ihr fuer logging braucht, empfehle ich die alias function ODER daten übertragen in die neuen stellen
                An den Datenpunkten fuer :
                • Laender
                • Bundeslanders
                • Staedte
                • Kreise
                Wird's sich ab JETZT nichts mehr ändern da wir die ISO normen verwenden.
                Ich bedanke mich an alle die mitgeholfen haben, soviel zusammenarbeite und Hilfe (auch wens nur so klein aussieht) habe ich bis jetzt noch nicht erlebt bei anderen adapter.
                Da sieht man, die situation bringt auch zusammen !
                sigi234 sissiwup 2 Replies Last reply Reply Quote 5
                • Nashra
                  Nashra Most Active Forum Testing last edited by Nashra
                  Hallo @Dutchman, vielen Dank für deine Arbeit sowie auch an alle die dabei geholfen haben. 👍
                  Danke!
                  • I
                    intruder7 @CruziX last edited by
                    @CruziX
                    Wae auch mein erster Gedanke, hat aber nicht geholfen
                      sigi234 Forum Testing Most Active @Dutchman last edited by
                      @Dutchman
                      Läuft einwandfrei und viel schneller! 👍
                      • harrym
                        harrym last edited by
                        @Dutchman
                        TOP! und wie @sigi234 schon angemerkt hat .... echt viel schneller.
                          hab auch ein bisschen weitergebastelt, Gesamtes Dashboard auf drei Bilder verteilt.
                          4f0a2b3a-5215-48c0-b0fd-0dd0d531d9d3-image.png a4396439-5673-4983-a300-4e6dfa849f27-image.png 815cae42-0f9e-40f2-bfdf-0a4f8d3b4a9e-image.png
                          harrym sigi234 2 Replies Last reply Reply Quote 3
                          • harrym
                            harrym @crunchip last edited by
                            @crunchip haben will 👍 👍 👍 👍 😊 BITTE
                              sigi234 Forum Testing Most Active @crunchip last edited by sigi234
                              @crunchip
                              Geile Sache, da kann ich meine einpacken. 😀
                              Ist aber Grafana?
                                crunchip Forum Testing Most Active @harrym last edited by
                                @harrym gerne
                                Covid-19Dash.txt
                                harrym H 2 Replies Last reply Reply Quote 3
                                • harrym
                                  @crunchip DANKE 😉
                                    crunchip Forum Testing Most Active @sigi234 last edited by
                                    @sigi234 Danke sigi,
                                    jawohl, finde Grafana irgendwie genial, man kann natürlich auch alles direkt in Vis machen, dennoch hat Grafana so seine Vorzüge.
                                    harrym 1 Reply Last reply Reply Quote 0
                                    • harrym
                                      @crunchip sehe ich auch so .... aber biste da mal alles aus grafana rauskitzeln kannst (so wie du) haste ne steile lernkurve notwendig.
                                        @harrym tztz, der Schein trügt, hab davon eigentlich kaum einen Plan, steh da noch voll am Anfang, aber genau so ein Objekt, ist für mich grad schön zum üben.
                                        • Chaot
                                          Chaot @crunchip last edited by
                                          @crunchip Kannst du mich mal Schlau machen? Was ist Grafana?
                                            A Former User last edited by
                                            Grafana
                                            Chaot 1 Reply Last reply Reply Quote -1
                                            adapter installation adapterentwicklung testen
                                            120
                                            1177
                                            305668
