    4. Z-Wave Adapter
    Z-Wave Adapter
    • Lenny.CB
      Lenny.CB Most Active last edited by
      @versteckt:
      Hallo, hab in GitHub eine neue main.js hochgeladen.
      Bitte nur diese austauschen und neustarten, ansonsten müsstest du alles nochmals installieren.
      LG Christian `
      getan… jetzt keine "roten" Log-Eiträge mehr...
      is es egal welche node-Version ich habe? zurzeit ist 0.12.6 installiert...
       Zeit
      Nachricht
      zwave-0	2016-03-25 19:34:30	warn	Object 'zwave.0.NODE9.ready' not found for stateChange
      zwave-0	2016-03-25 19:34:30	warn	Object 'zwave.0.NODE8.ready' not found for stateChange
      zwave-0	2016-03-25 19:34:30	warn	Object 'zwave.0.NODE7.ready' not found for stateChange
      zwave-0	2016-03-25 19:34:30	warn	Object 'zwave.0.NODE6.ready' not found for stateChange
      zwave-0	2016-03-25 19:34:30	warn	Object 'zwave.0.NODE5.ready' not found for stateChange
      zwave-0	2016-03-25 19:34:30	warn	Object 'zwave.0.NODE4.ready' not found for stateChange
      zwave-0	2016-03-25 19:34:28	info	Scan completed
      zwave-0	2016-03-25 19:34:28	info	node ready nodeid:9 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0301","productid":"0x1001","type":"Motor Contro
      zwave-0	2016-03-25 19:34:28	info	node ready nodeid:8 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor Contro
      zwave-0	2016-03-25 19:34:28	info	node ready nodeid:7 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor Contro
      zwave-0	2016-03-25 19:34:28	info	node ready nodeid:6 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0301","productid":"0x1001","type":"Motor Contro
      zwave-0	2016-03-25 19:34:28	info	node ready nodeid:5 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGWPE Wall Plug","producttype":"0x0600","productid":"0x1000","type":"Binary Switch","name":"","loc":"
      zwave-0	2016-03-25 19:34:28	info	node ready nodeid:4 nodeinfo:{"manufacturer":"FIBARO System","manufacturerid":"0x010f","product":"FGRM222 Roller Shutter Controller 2","producttype":"0x0302","productid":"0x1000","type":"Motor Contro
      zwave-0	2016-03-25 19:34:27	info	node9: timeout, currently not implemented
      zwave-0	2016-03-25 19:34:17	info	node9: timeout, currently not implemented
      zwave-0	2016-03-25 19:34:05	info	node ready nodeid:1 nodeinfo:{"manufacturer":"Aeotec","manufacturerid":"0x0086","product":"Z-Stick Gen5","producttype":"0x0001","productid":"0x005a","type":"Static PC Controller","name":"","loc":""}
      zwave-0	2016-03-25 19:33:59	info	node9: nop, currently not implemented
      zwave-0	2016-03-25 19:33:59	info	node8: nop, currently not implemented
      zwave-0	2016-03-25 19:33:59	info	node7: nop, currently not implemented
      zwave-0	2016-03-25 19:33:59	info	node6: nop, currently not implemented
      zwave-0	2016-03-25 19:33:59	info	node5: nop, currently not implemented
      zwave-0	2016-03-25 19:33:59	info	node4: nop, currently not implemented
      zwave-0	2016-03-25 19:33:59	info	nodeid 9 is now available, but maybe not ready
      zwave-0	2016-03-25 19:33:59	info	nodeid 8 is now available, but maybe not ready
      zwave-0	2016-03-25 19:33:59	info	nodeid 7 is now available, but maybe not ready
      zwave-0	2016-03-25 19:33:58	info	nodeid 6 is now available, but maybe not ready
      zwave-0	2016-03-25 19:33:58	info	nodeid 5 is now available, but maybe not ready
      zwave-0	2016-03-25 19:33:58	info	nodeid 4 is now available, but maybe not ready
      zwave-0	2016-03-25 19:33:58	info	nodeid 1 is now available, but maybe not ready
      zwave-0	2016-03-25 19:33:58	info	driver ready: homeid = f331c5f6
      zwave-0	2016-03-25 19:33:58	info	scanning homeid=0xf331c5f6...
      zwave-0	2016-03-25 19:33:58	info	connected: homeid = 1.4.0
      zwave-0	2016-03-25 19:33:56	info	starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.zwave
      host-iobroker	2016-03-25 19:33:52	info	instance system.adapter.zwave.0 started with pid 2462
      host-iobroker	2016-03-25 19:33:52	info	object change system.adapter.zwave.0
      edit: die FIBAROS lassen sich über VIS ansteuern… 🙂
      • V
        versteckt last edited by
        Hallo, na das Log sieht ja schon mal gut aus.
        Ich arbeite mit 4.x habe aber auch mit 0.12 angefangen, sollte ansich kein Problem sein.
        Seit letztens sollte auch die 0.10er funktionieren, aber die ist offiziell nicht supported damit.
        Bitte ausgiebig testen und mir Bescheid geben.
        LG Christian
        • V
          Achja, die "warn" und "info" Einträge sind im Moment nur noch zur Lesbarkeit drinnen, sind aber nicht
          als Fehlereinträge zusehen.
          • Lenny.CB
            @versteckt:
            LG Christian `
            jo, wie immer, Danke für die schnelle Hilfe…!
            Was hast du denn für ein BS? Wheezy, Jessie???
            Ich hatte in den lestzen Tagen echt viel probiert...
            Banana pro mit Jessie mit Node 4.4.0 --> nur Installationsfehler
            Banana pro mit Wheezy mit Node 4.4.0 --> nur Installationsfehler
            Banana pro mit Wheezy mit Node 0.10* --> Installation klappt auch ohne "-unsafe -perm" Zeugs
            Banana pro mit Wheezy mit Node 0.12* --> Installation klappt auch ohne "-unsafe -perm" Zeugs
            Dachte mir, "musste doch mal das System aktualisieren" bums, Ende...
            "never touch a running system!" ist wohl doch was dran an dem Spruch... :lol:
            • AlCalzone
              @versteckt:
              .) Statusmeldung des Adapters wie "alle Nodes fertig geladen", "Treiber/Controller fertig initialisiert"
              -> erledigt `
              Der Knaller, wird gleich ausprobiert!
              @versteckt:
              .) aktivieren/deaktivieren des inclusion/exclusion Modus der zwave-Platine
              -> Siehe hierzu https://github.com/OpenZWave/node-openz … ME-mgmt.md
              -> ...If your OZW version is 1.3 or greater, then there's a whole bunch of new calls, which effectively replace the old BeginControllerCommand. There's also no CancelControllerCommand thus you can't cancel any pending commands (they simply timeout)... `
              Der Link ist mir bekannt. Ich hatte eine Weile damit gespielt, selbst per Skript eine eigene Instanz des Treibers zu initialisieren, das hat mir aber üblicherweise nur den RasPi aufgehängt oder die ioBroker-Prozesse abgeschossen.
              Habe mir mal die neue main.js angeschaut. Sehe ich das richtig, dass ich nur den State "zwave.0.GLOBAL_ACTION" überschreiben muss, um die von mir gewünschte Funktionalität zu erreichen?
              Viele Grüße und danke für die superschnelle Reaktion!
              • V
                Hallo, ja, kannst du normal überschreiben.
                Hab es noch nicht dokumentiert, aber grundsätzlich ist es möglich die Funktionen per Javascript Adapter auszuführen.
                Du musst nur die richtigen Parameter übergeben.
                Falls es nicht funktioniert, muss ich noch was anpassen.
                LG Christian
                • AlCalzone
                  Hab es gerade mal ausprobiert, die .ready-States werden korrekt gesetzt.
                  Die Fernsteuerung des Adapters funktioniert über das Setzen des States leider nicht, da ein State im "javascript.0"-Namespace erstellt wird, was im zwave-Adapter im falschen Codepfad landet. Außerdem ist der Wert des States "null" und nicht das Objekt, das ich übergebe:
                  var stateName = "zwave.0.GLOBAL_ACTION";
                  var newState = {action: "remove_device"};
                  createState(stateName, newState, true);
                  Im Prinzip möchte ich vom Skripting-Adapter aus in diesen Codepfad eingreifen:
                  https://github.com/husky-koglhof/ioBrok … in.js#L173
                  Edit: hab gerade deine Antwort gesehen, wie stelle ich das an, per JS die Funktionen auszuführen?
                  • V
                    Ich schreib dir das morgen zusammen, heute bin ich schon weg vom Rechner.
                    LG Christian
                    • V
                      Guten Morgen!
                      Meine Mädels sind alle schon unterwegs, darum gibt es um die Uhrzeit schon ein Update:
                      In GitHub ist nun die Version 0.3.0 integriert.
                      Damit ist es nun möglich, direkt über Javascript / VIS / etc. eine Aktion an den zWave Adapter zu übermitteln.
                      Beispiel Javascript:
                      // Only for Documentation, all valid actions
                      var actions = ['reset', 'assign_return_route', 'delete_all_return_routes', 'create_primary', 'replace_failed_node', 'transfer_primary',
                                      'replication_send', 'add_button', 'remove_button', 'add_device', 'remove_device', 'receive_config', 'refresh_node', 'remove_failed_node',
                                      'has_node_failed', 'request_node_neighbor_update', 'assign_return_route', 'delete_all_return_routes', 'send_node_information',
                                      'request_network_update', 'refresh_device', 'healNetwork', 'updatenode', 'association', 'naming'];
                      // Nodeid is always needed, get it from e.g. input from vis
                      var nodeid = 10;
                      // Action is always needed, get it from e.g. listbox from vis
                      var action = 'naming';
                      // ButtonID is only needed for action = adddButton, removeButton
                      var buttonid = 1;
                      // Name and Location are needed only needed for action = naming
                      var deviceName = 'New Name of Device';
                      var deviceLocation = 'New Location of Device';
                      // Heal and Count are needed only needed for action = healNetwork
                      var heal = true;
                      var count = 5;
                      // Group and Nodes are needed only needed for action = association
                      var group = 'GROUP NAME FROM ASSOCIATIONS';
                      var nodes = [1,2,3];
                      buildAction(action, nodeid, undefined, undefined, deviceName, deviceLocation, undefined, undefined);
                      // Build correct Action
                      function buildAction(executeAction, nodeid, heal, count, device_name, device_location, groupid, nodes) {
                          switch (executeAction) {
                              case 'association':
                                  submitAction(executeAction, nodeid, undefined, undefined, undefined, undefined, undefined, groupid, nodes);
                                  break;
                              case 'updatenode':
                                  submitAction(executeAction, nodeid);
                                  break;
                              case 'heal':
                                  submitAction(executeAction, nodeid, undefined, undefined, undefined, heal, count);
                                  break;
                              case 'add_device':
                                  submitAction(executeAction);
                                  break;
                              case 'remove_device':
                                  break;
                              case 'receive_config':
                                  break;
                              case 'refresh_node':
                                  break;
                              case 'remove_failed_node':
                                  break;
                              case 'has_node_failed':
                                  break;
                              case 'request_node_neighbor_update':
                                  break;
                              case 'send_node_information':
                                  break;
                              case 'request_network_update':
                                  break;
                              case 'refresh_device':
                                  break;
                              case 'naming':
                                  submitAction(executeAction, nodeid, undefined, device_name, device_location);
                                  break;
                              case 'reset':
                                  break;
                              case 'assign_return_route':
                                  break;
                              case 'delete_all_return_routes':
                                  break;
                              case 'create_primary':
                                  break;
                              case 'replace_failed_node':
                                  break;
                              case 'transfer_primary':
                                  break;
                              case 'replication_send':
                                  break;
                              case 'add_button':
                                  submitAction(executeAction, nodeid, buttonid);
                                  break;
                              case 'remove_button':
                                  break;
                              default:
                                  break;
                      // Submit Action back to zWave Adapter
                      function submitAction(action, nodeid, buttonid, name, location, heal, count, group, nodes) {
                          if (nodeid !== undefined) {
                              if (buttonid !== undefined) {
                                  setState('zwave.0.NODE' + nodeid + ".GLOBAL_ACTION", {
                                      val: {nodeid: nodeid, action: action, buttonid: buttonid},
                                      ack: true});
                              } else if (name !== undefined && location !== undefined) {
                                      val: {nodeid: nodeid, action: action, name: name, location: location},
                                      ack: true
                              } else if (heal !== undefined) {
                                  setState('zwave.0.GLOBAL_ACTION', {
                                      val: {nodeid: nodeid, action: action, heal: heal, count: count},
                                      ack: true
                              } else if (group !== undefined) {
                                      val: {nodeid: nodeid, action: action, group: group, target_nodeid: nodes},
                                      ack: true
                              } else {
                                      val: {nodeid: nodeid, action: action},
                                      ack: true
                          } else {
                                  val: {action:action},
                                  ack: true
                      In diesem Beispiel wird der Name und die Location des Node 10 verändert.
                      Wenn man den Befehl "buildAction(…)" dementsprechend anders parametrisiert, dann natürlich auch andere Actions.
                      Man kann aber auch direkt in die Variable zwave.0.NODE<id>.GLOBAL_ACTION z.B.
                      {"val":{"nodeid":10,"action":"naming","name":"New Name of Device","location":"New Location of Device"}}
                      reinschreiben.
                      Ich bin grade am überlegen, ob ich mir damit nicht selbst ein vis Widget baue...
                      LG Christian</id>
                      • AlCalzone
                        Funktioniert einwandfrei!
                        Gibt es eigentlich eine Möglichkeit, den Adapter zu updaten ohne jedesmal openzwave neu zu kompilieren?
                        Okay, habe gerade nen kleinen Bug gefunden. Bei re-initialisieren des Adapters werden die GLOBAL_ACTION und ready states der einzelnen Nodes nicht gelöscht.
                        • V
                          Hallo, ja ist im Plan für die nächste Version.
                          Im Moment waren einfach immer Fehler drinnen, welche tlw. durch eine neue openzwave Version
                          behoben wurden.
                          • V
                            Hallo, ist in GitHub jetzt drinnen.
                            Es wurde die preinstall.js dementsprechend angepasst.
                            Wenn die beiden Dateien
                            /usr/local/lib/libopenzwave.so und
                            /usr/local/etc/openzwave/manufacturer_specific.xml
                            existieren, wird keine erneute openzwave Installation durchgeführt.
                            • Lenny.CB
                              Hallo Christian,
                              die Version 0.3.0 ist jetzt auch bei mir drauf.
                              Installation lief ohne Fehler durch. Habe jetzt auch keine Fehler mehr im Log.
                              Nur eins wundert mich etwas. Was hat die zwave-Instanz mit der mit der rpc-Instanz zu tun?
                              Im Log habe ich Warnhinweise:
                              zwave.0	2016-03-27 10:36:32	warn	zwave.0 Object 'hm-rpc.1.CUX1200014.1.HUMIDITY' not found for stateChange
                              zwave-0	2016-03-27 10:36:30	warn	Object 'hm-rpc.1.CUX1200032.1.HUM_MAX_24H' not found for stateChange
                              Das betrifft meine CuxD-Geräte die offensichtlich durch den rpc-Adapter falsch erkannt werden. (es fehlen sämtliche Humidity-Kanäle)
                              Das war mal in einer früheren rpc-Version anders.
                              Grüße, Lenny
                              • V
                                Ist nur ein Logeintrag, weil alles State Changes überwacht werden.
                                Klarer Fall von, das muss noch raus.
                                Gesendet von meinem iPhone mit Tapatalk
                                • ruhr70
                                  ruhr70 last edited by
                                  Jetzt habe ich die letzten Stunden mit dem ZWave Adapter verbracht… Die Installation ist ein steiniger Weg 😉
                                  Ist... es ist noch nicht vorbei 😉
                                  Pi 3
                                  Z-WAVE USB-Stick ZMEEUZB1 (ZME_UZB1)
                                  Z-Wave Adapter 0.3.0
                                  Fibaro Motion Sensor
                                  Fibaro Wall Plug
                                  Die Installation lief nicht auf Anhieb. Ich bekomme hie nicht mehr alles zusammen. Es war aber mehrmals Installation/Deinstallation angesagt. Beim letzte funktionierenden Versuch musste der Adapter ein zweites Mal gestartet werden, damit er läuft.
                                  Aktueller Staus:
                                  Adapter ist installiert und beendet sich erst einmal nciht mehr selbst (SIGTERM oder davor mit dem 103()).
                                  Geräte sind erkannt. Der Motion Sensor sowohl auf der extra Admin Seite, als auch in den ioBroker Objekten. Der Wall-Plug nur in den ioBroker Objekten.
                                  Dann diverse Versuche, Statusänderungen zue rehalten (kommen keine), dafür aber folgende Fehlermeldung im Log:
                                  host-rasp31 2016-04-17 19:19:53 info instance system.adapter.zwave.0 terminated with code 6 (uncaught exception)
                                  zwave-0 2016-04-17 19:19:51 info node4: nop, currently not implemented
                                  TypeError: 2016-04-17 19:19:51 error at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:323:16)
                                  TypeError: 2016-04-17 19:19:51 error at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
                                  TypeError: 2016-04-17 19:19:51 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
                                  TypeError: 2016-04-17 19:19:51 error at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                  TypeError: 2016-04-17 19:19:51 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
                                  TypeError: 2016-04-17 19:19:51 error at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
                                  TypeError: 2016-04-17 19:19:51 error at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                                  TypeError: 2016-04-17 19:19:51 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
                                  TypeError: 2016-04-17 19:19:51 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
                                  TypeError: 2016-04-17 19:19:51 error at Socket. (/opt/iobroker/node_modules/iobroker.zwave/main.js:308:76)
                                  TypeError: 2016-04-17 19:19:51 error Cannot read property 'split' of undefined
                                  uncaught 2016-04-17 19:19:51 error exception: Cannot read property 'split' of undefined
                                  zwave-0 2016-04-17 19:19:51 error Add Associaton for 3: 3
                                  zwave-0 2016-04-17 19:19:51 error Remove Associaton for 3: 1
                                  zwave-0 2016-04-17 19:17:58 warn Object 'web.0.connected' not found for stateChange
                                  zwave-0 2016-04-17 19:17:57 warn Object 'web.0.connected' not found for stateChange
                                  history-1 2016-04-17 19:16:44 info starting. Version 0.2.1 in /opt/iobroker/node_modules/iobroker.history
                                  iobroker 2016-04-17 19:16:43 info exit 0
                                  iobroker 2016-04-17 19:16:43 info host.rasp31 object system.adapter.history.1 created
                                  host-rasp31 2016-04-17 19:16:43 info instance system.adapter.history.1 started with pid 5621
                                  host-rasp31 2016-04-17 19:16:43 info object change system.adapter.history.1
                                  iobroker 2016-04-17 19:16:43 info host.rasp31 object system.adapter.history.1.alive created
                                  iobroker 2016-04-17 19:16:43 info host.rasp31 object system.adapter.history.1.connected created
                                  iobroker 2016-04-17 19:16:43 info host.rasp31 object system.adapter.history.1.memHeapUsed created
                                  iobroker 2016-04-17 19:16:43 info host.rasp31 object system.adapter.history.1.memHeapTotal created
                                  iobroker 2016-04-17 19:16:43 info host.rasp31 object system.adapter.history.1.memRss created
                                  iobroker 2016-04-17 19:16:43 info host.rasp31 object system.adapter.history.1.uptime created
                                  iobroker 2016-04-17 19:16:43 info host.rasp31 create instance history
                                  iobroker 2016-04-17 19:16:41 info add history
                                  zwave-0 2016-04-17 18:39:27 warn Object 'web.0.connected' not found for stateChange
                                  zwave-0 2016-04-17 18:39:26 warn Object 'web.0.connected' not found for stateChange
                                  zwave-0 2016-04-17 18:38:44 warn Object 'web.0.connected' not found for stateChange
                                  zwave-0 2016-04-17 18:38:43 warn Object 'web.0.connected' not found for stateChange
                                  zwave-0 2016-04-17 18:35:55 warn Object 'web.0.connected' not found for stateChange
                                  zwave-0 2016-04-17 18:35:53 warn Object 'web.0.connected' not found for stateChange
                                  zwave-0 2016-04-17 18:35:01 warn Object 'web.0.connected' not found for stateChange
                                  zwave-0 2016-04-17 18:35:00 warn Object 'web.0.connected' not found for stateChange
                                  host-rasp31 2016-04-17 18:34:06 warn instance system.adapter.zwave.0 already running with pid 3472
                                  zwave-0 2016-04-17 18:33:56 info node2: node dead (Undead Undead Undead), currently not implemented
                                  zwave-0 2016-04-17 18:33:56 info Scan completed
                                  Es wurden ein Haufen Datenpunkte angelegt. Gefüllt wird allerdings keiner.
                                  Dann gibt es beim Adapter 4 Nodes:
                                  1- USB Stick
                                  2 - ?
                                  3 - Motion Sensor
                                  4 - Wall Plug
                                  ioBroker/Zustände zeigt bei dem Motion Sensor Werte an. Für den Wall-Plug (Node 4) kommen keine Werte.
                                  Die Meldungen nach dem Neustart des Adapters, da er nach der Fehlermeldung oben beendet wurde:
                                  zwave-0	2016-04-17 19:39:08	info	node4: timeout, currently not implemented
                                  zwave-0	2016-04-17 19:38:58	info	node2: timeout, currently not implemented
                                  zwave-0	2016-04-17 19:38:52	info	node2: node dead (Undead Undead Undead), currently not implemented
                                  sql-0	2016-04-17 19:38:52	info	sendTo "getHistory" to system.adapter.admin.0 from system.adapter.sql.0: {"step":null,"error":null}
                                  sql-0	2016-04-17 19:38:52	info	No Data
                                  admin-0	2016-04-17 19:38:52	info	sendTo "getHistory" to system.adapter.sql.0 from system.adapter.admin.0: {"id":"zwave.0.NODE3.SENSOR_MULTILEVEL.Temperature_1","options":{"end":1460914742,"count":50,"instance":"sql.0","from":true,"a
                                  zwave-0	2016-04-17 19:38:48	info	nodeid 2 is now available, but maybe not ready
                                  zwave-0	2016-04-17 19:38:39	info	node4: timeout, currently not implemented
                                  zwave-0	2016-04-17 19:38:29	info	node4: timeout, currently not implemented
                                  zwave-0	2016-04-17 19:38:19	info	node4: timeout, currently not implemented
                                  zwave-0	2016-04-17 19:38:09	info	node4: timeout, currently not implemented
                                  zwave-0	2016-04-17 19:37:59	info	node4: timeout, currently not implemented
                                  zwave-0	2016-04-17 19:37:49	info	nodeid 4 is now available, but maybe not ready
                                  zwave-0	2016-04-17 19:37:45	info	node4: timeout, currently not implemented
                                  zwave-0	2016-04-17 19:37:35	info	node4: timeout, currently not implemented
                                  zwave-0	2016-04-17 19:37:25	info	node4: timeout, currently not implemented
                                  zwave-0	2016-04-17 19:37:15	info	node2: nop, currently not implemented
                                  zwave-0	2016-04-17 19:37:11	info	node ready nodeid:1 nodeinfo:{"manufacturer":"Z-Wave.Me","manufacturerid":"0x0115","product":"ZME_UZB1 USB Stick","producttype":"0x0400","productid":"0x0001","type":"Static PC Controller","name":"ras
                                  zwave-0	2016-04-17 19:37:11	info	node3: node sleep, currently not implemented
                                  zwave-0	2016-04-17 19:37:11	info	node3: nop, currently not implemented
                                  zwave-0	2016-04-17 19:37:07	info	node2: nop, currently not implemented
                                  zwave-0	2016-04-17 19:37:03	info	nodeid 3 is now available, but maybe not ready
                                  zwave-0	2016-04-17 19:37:03	info	nodeid 1 is now available, but maybe not ready
                                  zwave-0	2016-04-17 19:37:02	info	driver ready: homeid = c0c36bea
                                  zwave-0	2016-04-17 19:37:02	info	scanning homeid=0xc0c36bea...
                                  zwave-0	2016-04-17 19:37:02	info	node255: timeout, currently not implemented
                                  zwave-0	2016-04-17 19:37:01	info	connected: homeid = 1.4.0
                                  zwave-0	2016-04-17 19:37:01	info	found: zwave.0.NODE3.GLOBAL_ACTION
                                  zwave-0	2016-04-17 19:37:01	info	found: zwave.0.NODE3.ready
                                  zwave-0	2016-04-17 19:37:01	info	found: zwave.0.NODE1.GLOBAL_ACTION
                                  zwave-0	2016-04-17 19:37:01	info	found: zwave.0.NODE1.ready
                                  zwave-0	2016-04-17 19:37:00	info	starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.zwave
                                  host-rasp31	2016-04-17 19:36:59	info	instance system.adapter.zwave.0 started with pid 6639
                                  host-rasp31	2016-04-17 19:36:59	info	object change system.adapter.zwave.0
                                  host-rasp31	2016-04-17 19:36:56	info	object change system.adapter.zwave.0
                                  Wenn ich irgendwie unterstützen kann (Daten liefern, usw.) gerne. Muss nur wissen, was benötigt wird.
                                  VG,
                                  Michael
                                  • ruhr70
                                    Ergänzend:
                                    Node 4.2.1
                                    npm 2.14.17
                                    zwave-0	2016-04-17 20:32:55	info	node3: node sleep, currently not implemented
                                    zwave-0	2016-04-17 20:32:51	info	node3: timeout, currently not implemented
                                    zwave-0	2016-04-17 20:32:41	info	node3: node awake, currently not implemented
                                    • AlCalzone
                                      Ich habe heute versucht, ein Fibaro FGS-222 Relais per ioBroker.zwave zu schalten. Nachdem sich die Installation schwierig gestaltet hat (Neustart notwendig, um das Relais richtig anzuzeigen), scheint jetzt auch die Verknüpfung nicht ordentlich zu sein.
                                      Bei manuellem Schalten am Relais wird der State in ioBroker korrekt aktualisiert. Die andere Richtung will aber nicht. Setzen des States in ioBroker schaltet das Relais weder an noch aus. Es passiert einfach nichts. Ideen woran das liegen könnte?
                                        Was sagt das log?
                                        ggf. z-Waveadapter auf debug schalten.
                                        Rainer
                                        • AlCalzone
                                          Im Log erscheint überhaupt nichts. Beim Filter-Dropdown ist "debug" vorausgewählt oder was meinst du mit "zwave auf debug stellen"?
                                          So siehts im Ereignis-Tab aus:
                                          ~~![](</s><URL url=)http://i.imgur.com/p900Fn5.png" />
                                          Die gelb hinterlegten Einträge tauchen auf, wenn ich das Relais von Hand betätigte, die anderen beiden Einträge waren je 1 Versuch per "Objekte"-tab und per Skript das Teil anzuschalten – ist aber nichts passiert.~~
                                            @AlCalzone:
                                            Beim Filter-Dropdown ist "debug" vorausgewählt oder was meinst du mit "zwave auf debug stellen"? `
                                            Dann würde er debug ausgaben zeigen wenn er denn welche hätte 😉
                                            Also im Reiter Instanzen links oben den admin mode über das Männchen-Icon aktivieren, dann in der dann rechts erscheinenden Spalte Log Stufe den Loglevel von Info auf debug schalten.
                                            Rainer
                                            110
                                            28908
