    4. [HowTo] ioBroker Restore unter Linux durchführen
      martin last edited by
      Das hier kommt auch ständig:
      host.iobroker	2020-02-20 08:38:36.535	error	Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
      host.iobroker	2020-02-20 08:38:36.535	error	Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
      host.iobroker	2020-02-20 08:38:36.535	error	Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
      host.iobroker	2020-02-20 08:38:36.535	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      host.iobroker	2020-02-20 08:38:36.535	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      host.iobroker	2020-02-20 08:38:36.535	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
      host.iobroker	2020-02-20 08:38:36.535	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      host.iobroker	2020-02-20 08:38:36.534	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
      host.iobroker	2020-02-20 08:38:36.534	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.tr-064/tr-064.js:16:20)
      host.iobroker	2020-02-20 08:38:36.531	error	Caught by controller[0]: at Object.exports.Adapter (/opt/iobroker/node_modules/soef/soef.js:1383:23)
      host.iobroker	2020-02-20 08:38:36.530	error	Caught by controller[0]: TypeError: fns.adapter is not a function
      host.iobroker	2020-02-20 08:38:36.530	error	Caught by controller[0]: ^
      host.iobroker	2020-02-20 08:38:36.530	error	Caught by controller[0]: fns.adapter = fns.adapter(options);
      host.iobroker	2020-02-20 08:38:36.529	error	Caught by controller[0]: /opt/iobroker/node_modules/soef/soef.js:1383
        apollon77 @martin last edited by apollon77
        @martin Bitte auf dem Latest repo die 3.1.4 vom tr-064 Adapter installieren
          @martin Hier hattest DU scheinbar eine GitHub version von mqtt drauf die es nie auf npm gibt, also kann er es nicht nachinstallieren.
          Am besten installiere die aktuellste Verison vom Adapter
            martin @apollon77 last edited by
            @apollon77 said in [HowTo] ioBroker Restore unter Linux durchführen:
            Okay. Sind die Einstellungen dann alle noch da?
              @martin ja klar
                Babu242 last edited by
                Einen schönen gute Tag
                Ich habe den Iobroker auf einem Windowsrechner laufen
                das lief auch schon seit 6–7 Monaten einwandfrei,
                leider ist jetzt das System abgestürzt und ich bekomme das back up nicht hin.
                Das Back-up habe ich mit backitup erstellt mit einem NAS und mit ftp darauf zugegriffen.
                Das Hatte auch alles gut funktioniert.
                Ich habe das Backup aufspielen wollen das hat nicht funktioniert.
                Mittlerweile habe ich den iobroker und auch den Rechner neu aufgesetzt nix geht.
                Hier der die das Log
                Backitup Restore.pdf
                Sobald das abgelaufen ist, komme ich nicht mehr auf die Oberfläche
                ich habe jedes Mal mehrere stunden gewartet.
                leider ohne Erfolg.
                Vielleicht weis jemand Hilfe Danke
                bleibt Gesund
                • simatec
                  simatec Developer Most Active @Babu242 last edited by
                  @Babu242
                  Was gibt der Befehl iobroker list instances und iobroker status aus?
                    @simatec
                    Hallo erstmal und danke das du mir hilfst
                    Hier die Screenshots
                    LG Babu
                    • simatec
                      @Babu242 Läuft da eventuell noch eine Installation von iobroker?
                      Führe mal iobroker stop und iobroker host this
                      Danach dann ein reboot ...
                        @simatec
                        Die zwei Sachen habe ich gemacht
                        vor und nach einem reboot
                        sieht gleich aus
                        • simatec
                          eventuell kann hier noch @Stabilostick zu Windows etwas sagen ...
                            Eine kurze frage
                            kann das stabilostick jetzt schon sehen oder schreibe ich ihn an
                            Und danke erstmal für deine Unterstützung
                            LG Babu
                              skokarl last edited by
                              @simatec
                              Backupit läuft wirklich super, Probleme die ich immer mal wieder hatte waren meist
                              selbstgemachte. Danke für den Adapter.
                              Aber eine Frage brennt mir noch unter den Nägeln.
                              Ich habe eine TestVM die nicht immer unbedingt auf dem neuesten Stand ist.
                              Kann ich eine funktionierende IOBroker Installation mit einem neueren Backup überschreiben ?
                              Funktioniert das ?
                              Also einfach Restore mit einem neueren Backup machen ?
                              • simatec
                                simatec Developer Most Active @skokarl last edited by
                                @skokarl
                                Das geht ohne Probleme ...
                                  bokelogan last edited by
                                  wie kann ich denn die Skripte JS uns Blocky sichern, wenn ich kein Backup gemacht habe und ioBroker nicht mehr startet.
                                  Ich kann nur noch mit einem anderen Linux System auf die SD-Karte zugreifen.
                                  Viele Grüße
                                  • simatec
                                    simatec Developer Most Active @bokelogan last edited by
                                    @bokelogan
                                    Den Ordner iobroker-data kopieren ...
                                      shigi76 last edited by shigi76
                                      ich habe ein komplettes Backup mit backitup übers web eingespielt. Hat super geklappt. Nun schmeißt mir der backitup Adapter aber am laufenden Band Fehlrmeldungen ins LOG (Siehe Anhang). Auch geht die Instanz immer mal von grün auf rot und dann wieder zu grün.
                                      Was kann da der Grund sein?
                                      Danke für eventuelle Hilfen!
                                      Glasfaser simatec 2 Replies Last reply Reply Quote 0
                                      • Glasfaser
                                        Glasfaser @shigi76 last edited by
                                        @shigi76
                                        Starte mal dein System neu !
                                        • simatec
                                          simatec Developer Most Active @shigi76 last edited by
                                          @shigi76
                                          Ein komplett Backup gibt es nicht mehr
                                            Danke bis hierhin!
                                            Neu gestartet habe ich schon öfter mal, Fehlermeldungen bleiben.
                                            "Ein komplett Backup gibt es nicht mehr":
                                            Heißt das, dass die Fehlermeldungen im LOG so hingenommen werden müssen und ich nichts falsch mache oder gibt es dieses Komplettbackup nur bei mir nicht mehr? 🤷‍♂️
                                            S J 2 Replies Last reply Reply Quote 0
                                            backitup how-to restore restore backup
                                            76
                                            513
                                            130810
