    4. Nach Updates folgende Fehler
      bz7i last edited by
      Guten Morgen,
      ich hatte gestern mein ioBroker seit längerer Zeit endlich mal wieder geupdatet.
      Jetzt bin Ich Heute morgen aufgesanden und ioBroker hatte sich verabschiedet 😢
      In der Log habe Ich folgende Einträge und weiß damit aber nichts anzufangen.
      hm-rega-0	2016-03-27 01:42:38	error	post request error: socket hang up
      uncaught	2016-03-27 01:22:36	error	exception: spawn ENOMEM
      host-RaspberryPi2B	2016-03-27 01:22:06	info	Restart adapter system.adapter.ping.0 because enabled
      host-RaspberryPi2B	2016-03-27 01:22:06	error	instance system.adapter.ping.0 terminated with code 6 (uncaught exception)
      Error:	2016-03-27 01:22:04	error	at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
      Error:	2016-03-27 01:22:04	error	at wrapper [as _onTimeout] (timers.js:252:14)
      Error:	2016-03-27 01:22:04	error	at pingAll (/opt/iobroker/node_modules/iobroker.ping/main.js:93:11)
      Error:	2016-03-27 01:22:04	error	at Array.forEach (native)
      Error:	2016-03-27 01:22:04	error	at /opt/iobroker/node_modules/iobroker.ping/main.js:103:26
      Error:	2016-03-27 01:22:04	error	at Object.probe (/opt/iobroker/node_modules/iobroker.ping/node_modules/ping/lib/ping-promise.js:65:17)
      Error:	2016-03-27 01:22:04	error	at Object.exports.spawn (child_process.js:715:9)
      Error:	2016-03-27 01:22:04	error	at ChildProcess.spawn (child_process.js:927:11)
      Error:	2016-03-27 01:22:04	error	at errnoException (child_process.js:980:11)
      Error:	2016-03-27 01:22:04	error	spawn ENOMEM
      uncaught	2016-03-27 01:22:04	error	exception: spawn ENOMEM
      ping-0	2016-03-27 01:14:08	warn	Reconnection to DB.
      hm-rpc-1	2016-03-27 01:14:04	warn	Reconnection to DB.
      web-0	2016-03-27 01:14:04	warn	Reconnection to DB.
      node-red-0	2016-03-27 01:14:04	warn	Reconnection to DB.
      hm-rpc-0	2016-03-27 01:14:03	warn	Reconnection to DB.
      admin-0	2016-03-27 01:14:03	warn	Reconnection to DB.
      web-0	2016-03-27 01:14:03	warn	Reconnection to DB.
      history-0	2016-03-27 01:14:03	warn	Reconnection to DB.
      hm-rega-0	2016-03-27 01:14:03	warn	Reconnection to DB.
      pushover-0	2016-03-27 01:14:03	warn	Reconnection to DB.
      hm-rpc-0	2016-03-27 00:10:43	info	setValue ["LEQ1019190:1","INHIBIT",true] BOOL
      Oder hat das was mit der Zeitumstellung zu tun ?
      Mich beunruhigt das schon, weil wenn Ich jetzt nicht da gewesen wäre, wäre meine Freundin ganz schön verzweifelt.
      Die Rollladen waren alle unten und durch aktivierter Alarmanlage alle gespeert.
      Hat da einer Rat ?
      • wendy2702
        wendy2702 last edited by
        Mein iobroker läuft auch nicht mehr.
        Habe aber keine updates gemacht und denke/befürchte es liegt an der Zeitumstellung
        • wendy2702
          Also bei mir scheint es an der Zeitumstellung gelegen zu haben.
          Konnte iobroker mit "iobroker start" wieder zum leben erwecken.
          Gruß und Frohe Ostern
            Hallo nochmal,
            ich hatte heute Mittag schon geantwortet, aber irgendwo ist der post verschollen:
            @bz7i:
            du hast da einen Error drin:
            = Error NO MEMory
            Ich denke, dass es das RAM betrifft (sonst wäre es meiner Meinung nach ENOSPC)
            Da wird wohl ein Reboot helfen.
            Rainer
              bz7i last edited by
              Hi Homoran,
              laufen tut die Kiste schon wieder. Da hat ein Reboot geholfen, das ist richtig.
              Aber was kann Ich denn tun, das es nicht wieder passiert ?
              Gruß Sebastian
