    4. [GELÖST] Flot und Rickshaw Adapter - Installation schlägt fehl
      GerdSo last edited by
      ich schaffe es nicht die beiden Adapter zu installieren.
      iobroker	2016-03-27 16:44:09	info	exit 25
      iobroker	2016-03-27 16:44:09	info	Cannot install iobroker.flot: 4294963228
      iobroker	2016-03-27 16:44:09	info	npm ERR! C:\WINDOWS\system32\npm-debug.log
      iobroker	2016-03-27 16:44:09	info	npm ERR! Please include the following file with any support request:
      iobroker	2016-03-27 16:44:09	info	eisdir a package you are trying to install.
      iobroker	2016-03-27 16:44:09	info	ERR!
      iobroker	2016-03-27 16:44:09	info	and is related to npm not being able to find a package.json innpm
      iobroker	2016-03-27 16:44:09	info	eisdir This is most likely not a problem with npm itselfnpm
      iobroker	2016-03-27 16:44:09	info	ERR! eisdir EISDIR: illegal operation on a directory, read
      iobroker	2016-03-27 16:44:09	info	syscall read
      iobroker	2016-03-27 16:44:09	info	-4068npm
      iobroker	2016-03-27 16:44:09	info	errno
      iobroker	2016-03-27 16:44:09	info	EISDIR
      iobroker	2016-03-27 16:44:09	info	code
      iobroker	2016-03-27 16:44:09	info	ERR! npm v3.7.3
      iobroker	2016-03-27 16:44:09	info	ERR! node v5.9.0
      iobroker	2016-03-27 16:44:09	info	"C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "--production" "--prefix" "C:/Program Files/ioBroker/node_modules/iobroker.flot"
      iobroker	2016-03-27 16:44:09	info	argv
      iobroker	2016-03-27 16:44:09	info	ERR! Windows_NT 10.0.10586
      iobroker	2016-03-27 16:44:09	info	addLocal Could not install C:\WINDOWS\system32
      iobroker	2016-03-27 16:44:06	info	npm install --production --prefix "C:/Program Files/ioBroker/node_modules/iobroker.flot" (System call)
      iobroker	2016-03-27 16:44:06	info	host.DauerlaufLaptop install adapter flot
      iobroker	2016-03-27 16:44:05	info	add flot
      Andere Adapter lassen sich problemlos installieren.
      "npm cache clean" habe ich schon durchgeführt, führte aber nicht zum Erfolg
      Jemand eine Idee, was bei mir falsch läuft?
      Folgende Adapter sind installiert und sind aktiv (außer email.0 und fritzbox.0)
      • Instanz Titel Zeitplanung
      admin.0 ioBroker Admin
      dwd.0 DWD */5 * * * *
      email.0 Email Adapter
      fritzbox.0 fritzbox Adapter
      history.0 history
      hm-rega.0 HomeMatic ReGaHSS
      hm-rpc.0 HomeMatic RPC
      hmm.0 Homematic Manager
      ical.0 iCal Adapter 0 */6 * * *
      javascript.0 Javascript/Coffescript Script Engine
      simple-api.0 simpleAPI Adapter
      socketio.0 socket.io Adapter
      vis.0 iobroker Visualisation
      web.0 ioBroker simple web Adapter
      yr.0 yr.no */5 * * * *
      • derAuge
        derAuge last edited by
        Hallo GerdSo,
        willkommen im Forum
        Habe die Installation des Adapters gerade mal auf einem RPi2 getestet. Da läuft es durch
        Hast du dein System schon einmal neu gestartet?
        Jürgen
          Wenn ich das aber richtig sehe ist es hier eine WIN10 Installation.
          Angemeckert wird sowohl die nodejs version mit 5.9.0 und die wohl dazugehörige npm-Version von 3.7.3
          Kann dazu mal ein Windows USer etwas sagen - ich kann das leider nicht.
          Rainer
            mehrfach neu gestartet, inkl. Rechnerneustart. Richtig, ist ein Win10 System.
            Alle Installationen sind aktuell, d.h. ioBroker etc. ist aktuell, node.js und npm aktuelle Version. Dachte vorher, dass es daran liegt und habe alles aktualisiert.
            Ergänzung: Mit diesen Versionen läßt sich z.B. der vCard-Adapter problemlos installieren
            Viele Grüße Gerd.
            • Bluefox
              Bluefox last edited by
              Das ist Rechtenproblem. In der neuen Installation habe ich iobroker aus Programm Files verschoben .
              Ich empfehle dir aus der Konsole mit admin rechten, das Kommando ausführen:
              cd C:/Program Files/ioBroker/
              npm install iobroker.flot
              iobroker add flot
                @Bluefox:
                iobroker add flot `
                Hab es probiert, schlägt trotzdem fehl, davor wurde wie vorgeschlagen npm install iobroker.flot ausgeführt, alles mit admin-Rechten:
                C:\Program Files\ioBroker>iobroker add flot
                C:\Program Files\ioBroker>node node_modules/iobroker.js-controller/iobroker.js add flot
                npm ERR! addLocal Could not install C:\Program Files\ioBroker
                npm ERR! Windows_NT 10.0.10586
                npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\Kerstin\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "install" "--production" "--prefix" "C:/Program Files/ioBroker/node_modules/iobroker.flot"
                npm ERR! node v5.9.0
                npm ERR! npm  v3.8.5
                npm ERR! code EISDIR
                npm ERR! errno -4068
                npm ERR! syscall read
                npm ERR! eisdir EISDIR: illegal operation on a directory, read
                npm ERR! eisdir This is most likely not a problem with npm itself
                npm ERR! eisdir and is related to npm not being able to find a package.json in
                npm ERR! eisdir a package you are trying to install.
                npm ERR!     C:\Program Files\ioBroker\npm-debug.log
                  Lösung gefunden. Nachdem Aufruf von
                  npm -g install npm@latest-2
                  funktioniert es und ich konnte flot und auch rickshaw installieren. Jetzt ist npm=2.2.2
