    4. Test Coronavirus Statistics for ioBroker
    • sissiwup
      sissiwup @sissiwup last edited by sissiwup
      @sissiwup
      Folgende Fehler kommen im SQL-Adapter:
      2020-03-30 13:21:16.896  - error: sql.0 (12224) Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(8155, 1585567275882, Thüringen, 1, 27, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Thüringen' in 'field list'
      2020-03-30 13:21:17.083  - error: sql.0 (12224) Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(8982, 1585567276037, Berlin, 1, 27, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Berlin' in 'field list'
      2020-03-30 13:21:17.215  - error: sql.0 (12224) Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(8988, 1585567276186, Berlin, 1, 27, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Berlin' in 'field list'
      2020-03-30 13:21:17.350  - error: sql.0 (12224) Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(8993, 1585567276332, Berlin, 1, 27, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Berlin' in 'field list'
      2020-03-30 13:21:17.562  - error: sql.0 (12224) Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(9000, 1585567276518, Berlin, 1, 27, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Berlin' in 'field list'
      2020-03-30 13:21:17.642  - info: coronavirus-statistics.0 (24338) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-03-30 13:21:17.706  - error: sql.0 (12224) Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(9007, 1585567276675, Berlin, 1, 27, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Berlin' in 'field list'
      2020-03-30 13:21:17.834  - error: sql.0 (12224) Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(9011, 1585567276815, Berlin, 1, 27, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Berlin' in 'field list'
      2020-03-30 13:21:17.916  - error: sql.0 (12224) Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(9019, 1585567276878, Berlin, 1, 27, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Berlin' in 'field list'
      2020-03-30 13:21:17.949  - error: sql.0 (12224) Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(9023, 1585567276934, Berlin, 1, 27, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Berlin' in 'field list'
      2020-03-30 13:21:18.096  - error: sql.0 (12224) Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(9029, 1585567277057, Berlin, 1, 27, 0);: Error: ER_BAD_FIELD_ERROR: Unknown column 'Berlin' in 'field list'
      Also so ca. 600 Zeilen
      9011 ist z.B. coronavirus-statistics.0.Germany.Stadt.Berlin_Lichtenberg.BL
      Ich habe Bundesland aus der Historie genommen. Dann gibt es keinen Fehler.
        SaiBot1981 last edited by
        @Dutchman irgendwie stimmt da was nicht mit den Meldungen für Deutschland. Stand: 13:24 Uhr "0" neue Fälle und "0" neue Verstorbene.
        Ist das so richtig?
        Chaot sissiwup 2 Replies Last reply Reply Quote 0
        • Chaot
          Chaot @SaiBot1981 last edited by
          @TiboTake Deutschland ist vermutlich eingeschlafen.
          Auch auf anderen Seiten bisher keine aktuellen Zahle von heute.
          • sissiwup
            sissiwup @SaiBot1981 last edited by
            @TiboTake sagte in Test Coronavirus Statistics for ioBroker:
            Ist das so richtig?
            Die Bundesländer scheinen zu stimmen. Deutschland liegt aber total daneben.
            Weder Cases noch sonstiges stimmen ...
            sissiwup 1 Reply Last reply Reply Quote 0
            • sissiwup
              @sissiwup sagte in Test Coronavirus Statistics for ioBroker:
              Ist das so richtig?
              jetzt kommen Werte, dafür sind alle Historie-Einstellungen weg. Scheinbar sind die Werte neu angelegt worden.
                crunchip Forum Testing Most Active last edited by crunchip
                für die, die es verwenden, habe die Ansicht Tageswerte für Deutschland und Global angepasst
                für Deutschland
                 "datasource": "InfluxDB-corona",
                 "aliasColors": {
                   "Genesen": "dark-green",
                   "Kritisch": "dark-purple",
                   "Sterbefälle": "dark-red",
                   "aktiv": "dark-orange",
                   "infiziert": "dark-blue"
                 "bars": true,
                 "dashLength": 10,
                 "dashes": false,
                 "fill": 1,
                 "fillGradient": 0,
                 "gridPos": {
                   "h": 6,
                   "w": 12,
                   "x": 0,
                   "y": 13
                 "hiddenSeries": false,
                 "id": 26,
                 "legend": {
                   "avg": false,
                   "current": true,
                   "hideEmpty": false,
                   "hideZero": false,
                   "max": false,
                   "min": false,
                   "show": true,
                   "total": false,
                   "values": true
                 "lines": false,
                 "linewidth": 1,
                 "nullPointMode": "null",
                 "options": {
                   "dataLinks": []
                 "percentage": false,
                 "pointradius": 2,
                 "points": false,
                 "renderer": "flot",
                 "seriesOverrides": [
                     "alias": "Sterbefälle"
                     "alias": "Kritisch"
                     "alias": "aktiv"
                     "alias": "infiziert"
                     "alias": "Genesen"
                 "spaceLength": 10,
                 "stack": true,
                 "steppedLine": false,
                 "targets": [
                     "alias": "Kritisch",
                     "groupBy": [
                         "params": [
                           "$__interval"
                         "type": "time"
                         "params": [
                           "null"
                         "type": "fill"
                     "orderByTime": "ASC",
                     "policy": "default",
                     "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.critical\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
                     "rawQuery": true,
                     "refId": "D",
                     "resultFormat": "time_series",
                     "select": [
                           "params": [
                             "value"
                           "type": "field"
                           "params": [],
                           "type": "mean"
                     "tags": []
                     "alias": "infiziert",
                     "groupBy": [
                         "params": [
                           "$__interval"
                         "type": "time"
                         "params": [
                           "null"
                         "type": "fill"
                     "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.cases\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
                     "rawQuery": true,
                     "refId": "A",
                     "select": [
                           "params": [
                             "value"
                           "type": "field"
                           "params": [],
                           "type": "mean"
                     "tags": []
                     "alias": "aktiv",
                     "groupBy": [
                         "params": [
                           "$__interval"
                         "type": "time"
                         "params": [
                           "null"
                         "type": "fill"
                     "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.active\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
                     "rawQuery": true,
                     "refId": "B",
                     "select": [
                           "params": [
                             "value"
                           "type": "field"
                           "params": [],
                           "type": "mean"
                     "tags": []
                     "alias": "Sterbefälle",
                     "groupBy": [
                         "params": [
                           "$__interval"
                         "type": "time"
                         "params": [
                           "null"
                         "type": "fill"
                     "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.deaths\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
                     "rawQuery": true,
                     "refId": "C",
                     "select": [
                           "params": [
                             "value"
                           "type": "field"
                           "params": [],
                           "type": "mean"
                     "tags": []
                     "alias": "Genesen",
                     "groupBy": [
                         "params": [
                           "$__interval"
                         "type": "time"
                         "params": [
                           "null"
                         "type": "fill"
                     "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.Germany.recovered\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
                     "rawQuery": true,
                     "refId": "E",
                     "select": [
                           "params": [
                             "value"
                           "type": "field"
                           "params": [],
                           "type": "mean"
                     "tags": []
                 "thresholds": [],
                 "timeFrom": "7d",
                 "timeRegions": [],
                 "timeShift": null,
                 "title": "Tageswerte Deutschland",
                 "tooltip": {
                   "shared": true,
                   "sort": 0,
                   "value_type": "individual"
                 "transparent": true,
                 "type": "graph",
                 "xaxis": {
                   "buckets": null,
                   "mode": "time",
                   "name": null,
                   "show": true,
                   "values": []
                 "yaxes": [
                     "format": "short",
                     "label": null,
                     "logBase": 1,
                     "max": null,
                     "min": null,
                     "show": true
                     "format": "short",
                     "label": null,
                     "logBase": 1,
                     "max": null,
                     "min": null,
                     "show": true
                 "yaxis": {
                   "align": false,
                   "alignLevel": null
                für Global
                 "aliasColors": {
                 "bars": true,
                 "dashLength": 10,
                 "dashes": false,
                 "fill": 1,
                 "fillGradient": 0,
                 "gridPos": {
                   "h": 6,
                   "w": 12,
                   "x": 0,
                   "y": 19
                 "id": 27,
                 "legend": {
                   "avg": false,
                   "current": true,
                   "hideEmpty": false,
                   "hideZero": false,
                   "max": false,
                   "min": false,
                   "show": true,
                   "total": false,
                   "values": true,
                   "alignAsTable": false
                 "lines": false,
                 "linewidth": 1,
                 "options": {
                   "dataLinks": []
                 "pointradius": 2,
                 "points": false,
                 "renderer": "flot",
                     "alias": "Kritisch"
                     "alias": "aktiv"
                     "alias": "Genesen"
                 "spaceLength": 10,
                 "stack": true,
                 "targets": [
                     "groupBy": [
                         "params": [
                           "$__interval"
                         "type": "time"
                         "params": [
                           "null"
                         "type": "fill"
                     "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.critical\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
                     "rawQuery": true,
                     "refId": "D",
                     "select": [
                           "params": [
                             "value"
                           "type": "field"
                           "params": [],
                           "type": "mean"
                     "tags": []
                     "groupBy": [
                         "params": [
                           "$__interval"
                         "type": "time"
                         "params": [
                           "null"
                         "type": "fill"
                     "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.cases\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
                     "rawQuery": true,
                     "refId": "A",
                     "select": [
                           "params": [
                             "value"
                           "type": "field"
                           "params": [],
                           "type": "mean"
                     "tags": []
                     "alias": "aktiv",
                     "groupBy": [
                         "params": [
                           "$__interval"
                         "type": "time"
                         "params": [
                           "null"
                         "type": "fill"
                     "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.active\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
                     "rawQuery": true,
                     "refId": "B",
                     "select": [
                           "params": [
                             "value"
                           "type": "field"
                           "params": [],
                           "type": "mean"
                     "tags": []
                     "groupBy": [
                         "params": [
                           "$__interval"
                         "type": "time"
                         "params": [
                           "null"
                         "type": "fill"
                     "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.deaths\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
                     "rawQuery": true,
                     "refId": "C",
                     "select": [
                           "params": [
                             "value"
                           "type": "field"
                           "params": [],
                           "type": "mean"
                     "tags": []
                     "alias": "Genesen",
                     "groupBy": [
                         "params": [
                           "$__interval"
                         "type": "time"
                         "params": [
                           "null"
                         "type": "fill"
                     "query": "SELECT non_negative_difference(last(cumulative_sum))FROM (\nSELECT cumulative_sum(non_negative_difference(last(\"value\"))) FROM \"coronavirus-statistics.0.global_continents.World_Sum.recovered\" WHERE $timeFilter GROUP BY time(1d)\n) WHERE $timeFilter GROUP BY time(1d) tz('Europe/Berlin')",
                     "rawQuery": true,
                     "refId": "E",
                     "select": [
                           "params": [
                             "value"
                           "type": "field"
                           "params": [],
                           "type": "mean"
                     "tags": []
                 "thresholds": [],
                 "timeFrom": "7d",
                 "timeRegions": [],
                 "timeShift": null,
                 "title": "Tageswerte Global",
                 "tooltip": {
                   "shared": true,
                   "sort": 0,
                 "type": "graph",
                 "xaxis": {
                   "buckets": null,
                   "mode": "time",
                   "name": null,
                   "show": true,
                   "values": []
                 "yaxes": [
                     "format": "short",
                     "label": null,
                     "logBase": 1,
                     "max": null,
                     "min": null,
                     "show": true
                     "format": "short",
                     "label": null,
                     "logBase": 1,
                     "max": null,
                     "min": null,
                     "show": true
                 "yaxis": {
                   "align": false,
                   "alignLevel": null
                H Chaot 4 Replies Last reply Reply Quote 0
                  Hicki @crunchip last edited by
                  @crunchip Ist das für ioBroker?
                    crunchip Forum Testing Most Active @Hicki last edited by
                    @Hicki ist für´s Grafana Dashboard
                      @crunchip Schade sieht gut aus
                        @Hicki HIER siehst du es ganz, dafür ist aber Grafana und InfluxDB nötig
                          @crunchip sagte in Test Coronavirus Statistics for ioBroker:
                          ist der Hammer - große Klasse
                          Ist es sehr Umfangreich beides zu installieren?
                          Knallochse 1 Reply Last reply Reply Quote 0
                          • Knallochse
                            Knallochse @Hicki last edited by
                            @Hicki hatten wir gestern schonmal. Bitte neues Thema erstellen, wenn dein Anliegen nicht direkt mit dem Adapter zu tun hat
                              Hicki @Knallochse last edited by
                              @Knallochse Entschuldigung
                              • Dutchman
                                Dutchman Developer Most Active Administrators @sissiwup last edited by
                                Warum sind die Deutsch? Und warum ist germany nicht Deutschland?
                                Die Parameter wurden nicht übernommen, d.h. z.B. alle Kreise waren bei mir ausgewählt, das ist wieder weg.
                                Änderungen in der Struktur sind natürlich tödlich für Historien etc.
                                wie auch im changelog erwähnt haben sich leider die datenpunkte während der Beta fase geändert, das diese jetzt iso conform sind werde diese sich nach offizieller PROD version nicht mehr ändern.
                                Sorry, eine der Nachteile von beta test aber so sind die Datenstrukturen deutlicher.
                                • S0NIC
                                  S0NIC @Chaot last edited by
                                  @Chaot Propaganda
                                  harrym Chaot 2 Replies Last reply Reply Quote 0
                                  • harrym
                                    harrym @S0NIC last edited by
                                    @S0NIC "der chinesische virus" .... Propaganda ala Trump?
                                    sry .... de Daten werden nur geliefert .... und nicht von uns erhoben.
                                    • Chaot
                                      Chaot @S0NIC last edited by
                                      @S0NIC Habe ich heute auch gelesen. Stand denke ich im Spiegel. Die Chinesen zählen Fälle bei denen der Virus nachgewiesen ist, aber keine Symptome vorhanden sind nicht in die Statistik 👎
                                      • Dutchman
                                        Dutchman Developer Most Active Administrators @Chaot last edited by
                                        @Chaot sagte in Test Coronavirus Statistics for ioBroker:
                                        Lol.... Achja ist alles was
                                        So Leute 0.4.9 reif für stable ?
                                        Knallochse sigi234 2 Replies Last reply Reply Quote 1
                                        • Knallochse
                                          Knallochse @Dutchman last edited by
                                          @Dutchman
                                          Ich konnte keine Fehler durch den Adapter ausmachen, und für die Zahlen die ausgegeben werden bist du nicht verantwortlich 😁
                                            sigi234 Forum Testing Most Active @Dutchman last edited by
                                            @Dutchman sagte in Test Coronavirus Statistics for ioBroker:
                                            Jupp
                                            81.1k
                                            adapter installation adapterentwicklung testen
                                            120
                                            1177
                                            330392
