    4. Beta-Test Android App ioGo 2.1.x
      e-s @Guest last edited by
      @nis
      Mache ich morgen, auf welchem debug Level?
        A Former User @e-s last edited by
        @e-s am besten wäre Verbose
          e-s @Guest last edited by e-s
          @nis
          Wenn man die Geräte alle mal in Ruhe lässt, dann scheint es doch zu funktionieren...
          Also könnte meine Ungeduld Schuld sein.
          Das Fire will aber wirklich nicht, um verbose Log passiert aber kaum was
          23:02:53:373 D/StateFirebaseServiceImp - 61: Service created
          23:02:53:425 D/EnumFirebaseServiceImpl - 54: Service created
          23:02:53:681 I/FirebaseService - 205: DeviceFirebaseServiceImpl successfully connected
          23:02:53:688 I/DeviceFirebaseServiceIm - 73: buffer is empty
          23:02:53:692 I/FirebaseService - 205: StateFirebaseServiceImpl successfully connected
          23:02:53:734 I/FirebaseService - 205: EnumFirebaseServiceImpl successfully connected
          23:02:58:358 D/HostFirebaseServiceImpl - 60: Service created
          23:02:58:369 D/InstanceFirebaseService - 60: Service created
          23:02:58:376 D/AdapterFirebaseServiceI - 54: Service created
          23:02:58:555 I/FirebaseService - 205: HostFirebaseServiceImpl successfully connected
          23:02:58:559 I/FirebaseService - 205: InstanceFirebaseServiceImpl successfully connected
          23:02:58:567 I/FirebaseService - 205: AdapterFirebaseServiceImpl successfully connected
          23:03:03:503 I/DeviceFirebaseServiceIm - 87: send device FireHD8
          23:03:03:504 I/HostFirebaseServiceImpl - 70: start syncing
          23:03:03:508 I/InstanceFirebaseService - 70: start syncing
          23:03:03:509 I/AdapterFirebaseServiceI - 77: start syncing
          23:03:03:582 I/EnumFirebaseServiceImpl - 77: start syncing
          23:03:03:647 I/StateFirebaseServiceImp - 91: start syncing
          23:03:03:863 I/EnumFirebaseServiceImpl - 123: no differences found
          23:03:03:868 I/StateFirebaseServiceImp - 150: no differences found
          23:03:03:872 I/AdapterFirebaseServiceI - 109: 0 differences found
          23:03:03:877 D/AdapterFirebaseServiceI - 119: system.adapter.icons-material-png found only local
          23:03:03:881 I/HostFirebaseServiceImpl - 133: no differences found
          23:03:03:884 I/InstanceFirebaseService - 137: no differences found
          23:03:09:841 I/DeviceFirebaseServiceIm - 87: send device FireHD8
          23:03:14:983 I/DeviceFirebaseServiceIm - 87: send device FireHD8
          23:03:19:029 I/DeviceFirebaseServiceIm - 87: send device FireHD8
          23:06:01:721 I/DeviceFirebaseServiceIm - 87: send device FireHD8
          23:06:21:891 I/DeviceFirebaseServiceIm - 87: send device FireHD8
          23:06:48:552 I/DeviceFirebaseServiceIm - 87: send device FireHD8
          23:07:36:881 I/DeviceFirebaseServiceIm - 87: send device FireHD8
          Werde es weiter beobachten, aber bisher bleibt die 0 stehen.
          Neustart hat auch nicht geholfen.
            @e-s es könte an der doch schon recht alten Android Version liegen, da muss ich mal recherchieren ob man da was zu findet an Inkompabilitäten...
              @e-s sagte in Beta-Test Android App ioGo 2.1.x:
              Ist es theoretisch möglich eine Pushnachricht mit verfallszeit zu senden, also push kommt auf handy an und wird nach Zeit x wieder von selbst gelöscht aus der Infobar auch wenn nicht weggedrückt oder gesehen?
              In der nächsten Version kann man einstellen, dass Pushnachrichten nach x Sekunden entfernt werden sollen. Die Nachrichten sind dann trotzdem noch in der Messageliste der App nachzusehen.
              E ? 2 Replies Last reply Reply Quote 1
                @nis
                Hab dir ne Mail gesendet...
                  A Former User @Guest last edited by
                  @nis Version 2.1.8 kommt gerade als Beta online:
                  (Feature) Automatisches Löschen von Pushbenarichtigungen
                  E Neuschwansteini 2 Replies Last reply Reply Quote 1
                    @nis
                    Habs gerade installiert aber noch nicht getestet. Geht das nur global oder wäre es auch möglich durch prio Wahl beim senden zu unterscheiden ob Nachrichten existent in der statusleiste bleiben oder nicht?
                    Edit: klappt einwandfrei, nur möchte ich nicht alle Nachrichten sofort wieder weg haben.
                    Edit2: hab mal auf dem fireHD eine akku app installiert, die kann prinzipiell den akkustand auslesen. Du kannst ja alternativ mal eine Beta bauen die den akkustand in der app selbst anzeigt um dem Fehler eingrenzen zu können.
                    ? 2 Replies Last reply Reply Quote 0
                      Geht aktuell nur global. Aber genau dafür ist ja die Beta Version auch da, einfach mal zum Ausprobieren.
                      Ich finde die Idee gut, dass Nachrichten mit hoher Prio nicht automatisch gelöscht werden.
                      Für Normale Nachrichten zieht dann der globale Timeout und zusätzlich kann ich auch noch einen individuellen Timeout als Payload der Nachricht selber einbauen. Dann kann man auch jede einzelne Nachricht individuell löschen lassen.
                        Ich würde das lieber erstmal über die Logs versuchen zu analysieren. Dazu bin ich gerade dabei die App mit weiteren sinnvollen Logging zu versehen.
                        • Neuschwansteini
                          Neuschwansteini @Guest last edited by
                          @nis Hi, könnte man das automatische löschen auch in Minuten eingeben? Hab da jetzt 86400 stehen... 🙈
                          E ? 2 Replies Last reply Reply Quote 0
                            e-s @Neuschwansteini last edited by
                            @ilovegym
                              A Former User @Neuschwansteini last edited by
                              @ilovegym sagte in Beta-Test Android App ioGo 2.1.x:
                              ich versuche mal in der nächsten Version den folgenden Input zu ermöglichen:
                              • "30" = 30 Sekunden
                              • "30s" = 30 Sekunden
                              • "10m" = 10 Minuten
                              • "12h" = 12 Stunden
                              • "2d" = 2 Tage
                              ? 1 Reply Last reply Reply Quote 2
                                @nis und da ist auch schon die neue Version 2.1.9 (als Beta) mit "smarter" Zeitangabe beim Löschen von Pushnachrichten...
                                Folgendes ist möglich als Eingabe:
                                "30s" = 30 Sekunden
                                "10m" = 10 Minuten
                                "12h" = 12 Stunden
                                "2d" = 2 Tage
                                E crunchip 2 Replies Last reply Reply Quote 0
                                  @nis
                                  konntest du dir meine Mail von gestern ansehen?
                                    @e-s ja, habe ich gesehen. Ich kann es aber nicht nachstellen. Wenn ich das Passwort falsch eingebe kommt bei Information "iogo - account unknown". Wenn ich dann das richtige Passwort eingebe, steht dort sofort wieder "iogo -connected"
                                      @nis
                                      ist ja auch nicht so wichtig, schon komisch das es nur mit 2 verschiedene Geräten passiert ist.
                                      Viel wichtiger wäre mir im Moment sowieso der Akkuwert und noch wichtiger die json Tabelle😊
                                        @e-s hattest du mir schonmal wegen dem Akkuthema ein Log der App geschickt? Ich habe eine Vermutung woran es liegt und könnte das mit dem Log überprüfen.
                                        Tabellen wird vermutlich noch etwas länger dauern, ist nicht so einfach aus einem beliebigen JsonArray eine hübsche Tabelle zu zaubern
                                          @nis
                                          das log von gestern ist auch von dem Gerät was kein Akkuwert anzeigt. Solltest du darin auch finden, aber ich sehe da nix.
                                          Die Tabelle muss nicht schön, aber wäre klasse wenn ich schon mal sehen könnte ob es überhaupt funktioniert, dann könnte ich weiter basteln in meinen Ideen.
                                            @e-s Das Log beinhaltet nur 3 Minuten nachdem erfolgreichen Anmelden, das ist etwas zuwenig um das Akkuproblem zu finden.
                                            31.7k
                                            79.8k
                                            android beta geofence iogo test
                                            10
                                            272
                                            24007
