    4. [neuer Adapter] smartgarden adapter for Gardena smart system
    • dslraser
      dslraser Forum Testing Most Active @jpgorganizer last edited by
      @jpgorganizer
      bei mir nicht.
      kannst Du schon mal das Update zur Verfügung stellen ? Ich habe Zeit ind könnte testen.
      jpgorganizer 1 Reply Last reply Reply Quote 0
      • jpgorganizer
        jpgorganizer @dslraser last edited by
        @dslraser ich habe ihn online auf github ... kannst ja testen und Info geben.
        Bitte beachte die Relesase Notes:
        0.4.0
        • (jpgorganizer)
          • NOTE: with this version an additional dependency is necessary at runtime. If it does not get installed together with the installation of this adapter, please install seperately with npm install https://github.com/jpgorganizer/ioBroker.utils
          • NOTE: you must delete all states of the adapter instance to install this release and please check your application carefully for necessary adjustments regarding type/role changes (see below)
          • data types of (nearly) all datapoints adjusted for compliance with ioBroker guidance:
            • states now have special ioBroker type and role instead of former string/text where applicable, e.g. number/value.battery for batteryLevel_value (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/3)
          • datapoint activity_value_i replaced by activity_mowing_i with type/role boolean/indicator.working: true means mowing, false means not mowing
          • possibility to pre-define states integrated, see new switch PreDefine States in adapter/instance configuration (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/2)
          • states are readonly now; except states for commands (Issue https://github.com/jpgorganizer/ioBroker.smartgarden/issues/4)
          • input field for useTestVariable in adapter/instance configuration switched to a checkbox (former: text); please check your settings
          • error in command stop_all_valves_i in VALVE_SET fixed
        jpgorganizer
        • jpgorganizer
          hab gerade geprüft : ich kann den Adapter nicht installieren - liegt an der Auflösung einer Abhängigkeit - ich bin dran und melde mich
          StrathCole 1 Reply Last reply Reply Quote 0
          • StrathCole
            StrathCole @jpgorganizer last edited by
            @jpgorganizer Ja, für die Abhängigkeiten muss die Lib erst npm publish durchlaufen haben.
            • jpgorganizer
              jpgorganizer @StrathCole last edited by
              @StrathCole ja, schon gesehen, aber ich wollte npm eigentlich erst mal vermeiden 😞 werde es für die Lib aber wohl trotzdem schon machen müssen.
              • StrathCole
                @jpgorganizer Ja, hatte ich auch gemerkt, als ich etwas in ein Lib ausgelagert habe. Etwas umständlich. Beim publish musst du auch beachten, dass du npm publish --access public machst, weil du sonst für private Projekte was Kostenpflichtiges brauchst. Habe ich ne Weile gebraucht, das zu finden. Bei den Adaptern ging es ohne.
                • jpgorganizer
                  @dslraser
                  @StrathCole
                  so, wieder Feuer frei - Abhängigkeit der Lib kann nun aufgelöst werden.
                  die aktuelle Version ist nun die 0.4.1
                  weiterhin die Notes von der 0.4.0 beachten
                  0.4.1
                  • (jpgorganizer)
                    • Dependency get's resolved now
                  0.4.0
                  • (jpgorganizer)
                    • NOTE: with this version an additional dependency is necessary at runtime. If it does not get installed together with the installation of this adapter, please install seperately with npm install https://github.com/jpgorganizer/ioBroker.utils or npm i @jpgorganizer/utils
                  jpgorganizer
                  dslraser 1 Reply Last reply Reply Quote 2
                  • jpgorganizer
                    @StrathCole sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                    @jpgorganizer Möchtest du grundsätzlich auch Pull Requests bekommen oder lieber erst mal alles allein bauen, wenn wir Ideen haben?
                    eigentlich wäre es mir lieber, wenn ich Dinge selbst einbaue. Ggfs. komme ich gerne drauf zurück. Danke für's Angebot.
                    Ideen am besten hier diskutieren oder gleich als Issue in github anlegen. Je nachdem, wie genau die Idee schon vorliegt.
                    jpgorganizer
                      muckel last edited by
                      Super Adapter! Danke.
                      Feedback: Sensor gibt keine der Messdaten an den Adapter. Bodenfeuchte, Temperatur, Helligkeit
                      • jpgorganizer
                        jpgorganizer @muckel last edited by jpgorganizer
                        @muckel sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                        sowas ähnliches hat @dslraser auch schon gesagt. Ich habe keinen sensor, deshalb bin ich auf eurer Mitarbeit angewiesen.
                        Bitte macht mal in der Instance Konfig den Loglevel auf 3 und startet dann den Adaper und lasst mir mal den gesamten Log zukommen.
                        jpgorganizer
                        • dslraser
                          @jpgorganizer sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                          ich mache jetzt schon eine ganze Weile rum, aber ich bekomme den Adapter nicht mehr grün.
                          undefined2020-03-31 17:14:50.156 - info: host.iobroker "system.adapter.smartgarden.0" disabled
                          2020-03-31 17:14:50.156 - info: host.iobroker stopInstance system.adapter.smartgarden.0 (force=false, process=true)
                          2020-03-31 17:14:50.160 - info: smartgarden.0 (906) Got terminate signal TERMINATE_YOURSELF
                          2020-03-31 17:14:50.162 - info: smartgarden.0 (906) terminating
                          2020-03-31 17:14:50.162 - info: smartgarden.0 (906) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                          2020-03-31 17:14:50.157 - info: host.iobroker stopInstance system.adapter.smartgarden.0 send kill signal
                          2020-03-31 17:14:50.687 - info: host.iobroker instance system.adapter.smartgarden.0 terminated with code 156 (156)
                          2020-03-31 17:14:52.239 - info: host.iobroker "system.adapter.smartgarden.0" enabled
                          2020-03-31 17:14:52.259 - info: host.iobroker instance system.adapter.smartgarden.0 started with pid 921
                          2020-03-31 17:14:53.979 - info: smartgarden.0 (921) starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v10.19.0
                          2020-03-31 17:14:54.016 - info: smartgarden.0 (921) sgSetState: info.revision Main: 2010 / API: 2010
                          2020-03-31 17:14:54.018 - info: smartgarden.0 (921) Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
                          2020-03-31 17:14:54.336 - info: smartgarden.0 (921) Connection: successful: response.statusCode / statusMessage=200 / OK
                          2020-03-31 17:14:54.337 - info: smartgarden.0 (921) sgSetState: info.connection true
                          2020-03-31 17:14:54.339 - info: smartgarden.0 (921) get_locations ...
                          2020-03-31 17:14:54.486 - error: smartgarden.0 (921) Error: getlocations: no data
                          • jpgorganizer
                            @dslraser sagte in [neuer Adapter] smartgarden adapter for Gardena smart system:
                            Der Fehler kommt, nach dem Einloggen und wenn er dann keine Geräte von der Schnittstelle gemeldet bekommt.
                            Prüfe nochmals die Gardena Account Daten und auch den API-Key. Hast du vielleicht zwei Gardena Accounts? 1x mit und 1x ohne Geräte?
                            jpgorganizer
                            • dslraser
                              alles schon mehrfach geprüft. Und nein, ich habe nur einen Account. Im Browser kann ich mich genau mit diesen Daten anmelden. ApI-Key passt auch.
                              • dslraser
                                @jpgorganizer
                                Ich habe jetzt den API-Key gelöscht und neu erstellt. Damit wird der Adapter nun wieder grün.
                                • jpgorganizer
                                  @jpgorganizer
                                  das muss man nicht verstehen ??? würde ich aber gerne
                                  Das müssen wir beobachten, ob sowas öfter vorkommt. Danke für die Rückmeldung.
                                  jpgorganizer
                                  dslraser jpgorganizer 2 Replies Last reply Reply Quote 0
                                  • dslraser
                                    @jpgorganizer
                                    So, mein Blockly brauchte ich kaum ändern, läuft mit der 0.4.1 immer noch (nur den Stop aller Ventile habe ich im Blockly geändert. Der DP .stop_all_valves_i mit STOP_UNTIL_NEXT_TASK funktioniert nun 👍 )
                                    Bis auf die Sensordaten ist alles okay. Da warte ich mal noch etwas ab, da diese Daten nicht ständig übertragen werden. Im Moment ist es leer.
                                      muckel @jpgorganizer last edited by
                                      @jpgorganizer
                                      Hier der gewünschte log
                                      smartgarden.0	2020-03-31 18:08:15.797	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.rfLinkState_value ONLINE
                                      smartgarden.0	2020-03-31 18:08:15.796	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.modelType_value GARDENA smart Irrigation Control
                                      smartgarden.0	2020-03-31 18:08:15.796	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.serial_value 00001393
                                      smartgarden.0	2020-03-31 18:08:15.796	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.rfLinkLevel_timestamp 2020-03-31T15:30:10.995+0000
                                      smartgarden.0	2020-03-31 18:08:15.795	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.rfLinkLevel_value 60
                                      smartgarden.0	2020-03-31 18:08:15.795	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.batteryState_value NO_BATTERY
                                      smartgarden.0	2020-03-31 18:08:15.794	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_COMMON_7332.name_value Bewässerungsteuerung Garten
                                      smartgarden.0	2020-03-31 18:08:15.794	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_COMMON_d2bf229d-d6a9-46d1-98ea-10f3379c7332
                                      smartgarden.0	2020-03-31 18:08:15.791	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.lastErrorCode_timestamp 2019-08-31T05:50:16.873+0000
                                      smartgarden.0	2020-03-31 18:08:15.791	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.lastErrorCode_value NO_MESSAGE
                                      smartgarden.0	2020-03-31 18:08:15.790	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.state_timestamp 2019-08-31T05:50:21.319+0000
                                      smartgarden.0	2020-03-31 18:08:15.790	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.state_value UNAVAILABLE
                                      smartgarden.0	2020-03-31 18:08:15.790	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.activity_timestamp 2019-08-31T05:50:16.781+0000
                                      smartgarden.0	2020-03-31 18:08:15.789	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.duration_value null
                                      smartgarden.0	2020-03-31 18:08:15.789	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.duration_timestamp
                                      smartgarden.0	2020-03-31 18:08:15.788	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.duration_leftover_i null
                                      smartgarden.0	2020-03-31 18:08:15.788	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.activity_value CLOSED
                                      smartgarden.0	2020-03-31 18:08:15.788	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:6.name_value Valve 6
                                      smartgarden.0	2020-03-31 18:08:15.787	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A6
                                      smartgarden.0	2020-03-31 18:08:15.786	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.lastErrorCode_timestamp 2019-08-31T05:50:16.863+0000
                                      smartgarden.0	2020-03-31 18:08:15.785	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.lastErrorCode_value NO_MESSAGE
                                      smartgarden.0	2020-03-31 18:08:15.785	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.state_timestamp 2019-08-31T05:50:21.319+0000
                                      smartgarden.0	2020-03-31 18:08:15.784	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.state_value UNAVAILABLE
                                      smartgarden.0	2020-03-31 18:08:15.784	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.activity_timestamp 2019-08-31T05:50:16.765+0000
                                      smartgarden.0	2020-03-31 18:08:15.783	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.duration_value null
                                      smartgarden.0	2020-03-31 18:08:15.783	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.duration_timestamp
                                      smartgarden.0	2020-03-31 18:08:15.783	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.duration_leftover_i null
                                      smartgarden.0	2020-03-31 18:08:15.782	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.activity_value CLOSED
                                      smartgarden.0	2020-03-31 18:08:15.782	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:5.name_value Valve 5
                                      smartgarden.0	2020-03-31 18:08:15.781	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A5
                                      smartgarden.0	2020-03-31 18:08:15.778	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.lastErrorCode_timestamp 2019-08-31T05:50:16.855+0000
                                      smartgarden.0	2020-03-31 18:08:15.776	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.lastErrorCode_value NO_MESSAGE
                                      smartgarden.0	2020-03-31 18:08:15.775	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.state_timestamp 2019-08-31T05:50:21.319+0000
                                      smartgarden.0	2020-03-31 18:08:15.775	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.state_value OK
                                      smartgarden.0	2020-03-31 18:08:15.774	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.activity_timestamp 2019-10-20T03:59:57.087+0000
                                      smartgarden.0	2020-03-31 18:08:15.774	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.duration_value null
                                      smartgarden.0	2020-03-31 18:08:15.773	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.duration_timestamp
                                      smartgarden.0	2020-03-31 18:08:15.773	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.duration_leftover_i null
                                      smartgarden.0	2020-03-31 18:08:15.772	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.activity_value CLOSED
                                      smartgarden.0	2020-03-31 18:08:15.772	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:4.name_value Rasensprenger
                                      smartgarden.0	2020-03-31 18:08:15.771	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A4
                                      smartgarden.0	2020-03-31 18:08:15.770	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.lastErrorCode_timestamp 2019-08-31T05:50:16.847+0000
                                      smartgarden.0	2020-03-31 18:08:15.769	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.lastErrorCode_value NO_MESSAGE
                                      smartgarden.0	2020-03-31 18:08:15.769	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.state_timestamp 2019-08-31T05:50:21.319+0000
                                      smartgarden.0	2020-03-31 18:08:15.768	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.state_value OK
                                      smartgarden.0	2020-03-31 18:08:15.768	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.activity_timestamp 2019-10-20T04:59:57.085+0000
                                      smartgarden.0	2020-03-31 18:08:15.767	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.duration_value null
                                      smartgarden.0	2020-03-31 18:08:15.767	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.duration_timestamp
                                      smartgarden.0	2020-03-31 18:08:15.767	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.duration_leftover_i null
                                      smartgarden.0	2020-03-31 18:08:15.766	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.activity_value CLOSED
                                      smartgarden.0	2020-03-31 18:08:15.766	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:3.name_value Böschung und Hochbeet
                                      smartgarden.0	2020-03-31 18:08:15.765	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A3
                                      smartgarden.0	2020-03-31 18:08:15.762	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.lastErrorCode_timestamp 2019-08-31T05:50:16.840+0000
                                      smartgarden.0	2020-03-31 18:08:15.761	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.lastErrorCode_value NO_MESSAGE
                                      smartgarden.0	2020-03-31 18:08:15.761	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.state_timestamp 2019-08-31T05:50:21.319+0000
                                      smartgarden.0	2020-03-31 18:08:15.760	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.state_value OK
                                      smartgarden.0	2020-03-31 18:08:15.760	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.activity_timestamp 2019-10-20T04:29:57.132+0000
                                      smartgarden.0	2020-03-31 18:08:15.759	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.duration_value null
                                      smartgarden.0	2020-03-31 18:08:15.759	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.duration_timestamp
                                      smartgarden.0	2020-03-31 18:08:15.758	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.duration_leftover_i null
                                      smartgarden.0	2020-03-31 18:08:15.758	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.activity_value CLOSED
                                      smartgarden.0	2020-03-31 18:08:15.757	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:2.name_value Zaun- und Kiwibeet
                                      smartgarden.0	2020-03-31 18:08:15.756	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A2
                                      smartgarden.0	2020-03-31 18:08:15.715	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.lastErrorCode_timestamp 2019-08-31T05:50:16.833+0000
                                      smartgarden.0	2020-03-31 18:08:15.714	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.lastErrorCode_value NO_MESSAGE
                                      smartgarden.0	2020-03-31 18:08:15.714	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.state_timestamp 2019-08-31T05:50:21.319+0000
                                      smartgarden.0	2020-03-31 18:08:15.713	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.state_value OK
                                      smartgarden.0	2020-03-31 18:08:15.713	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.activity_timestamp 2019-10-20T02:59:57.008+0000
                                      smartgarden.0	2020-03-31 18:08:15.712	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.duration_value null
                                      smartgarden.0	2020-03-31 18:08:15.712	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.duration_timestamp
                                      smartgarden.0	2020-03-31 18:08:15.711	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.duration_leftover_i null
                                      smartgarden.0	2020-03-31 18:08:15.710	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.activity_value CLOSED
                                      smartgarden.0	2020-03-31 18:08:15.710	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_32:1.name_value Himbeerbeet
                                      smartgarden.0	2020-03-31 18:08:15.709	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_d2bf229d-d6a9-46d1-98ea-10f3379c7332%3A1
                                      smartgarden.0	2020-03-31 18:08:15.647	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_SET_7332.lastErrorCode_timestamp 2020-02-11T19:57:25.833+0000
                                      smartgarden.0	2020-03-31 18:08:15.647	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_SET_7332.lastErrorCode_value NO_MESSAGE
                                      smartgarden.0	2020-03-31 18:08:15.646	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_SET_7332.state_timestamp 2020-02-11T19:57:25.833+0000
                                      smartgarden.0	2020-03-31 18:08:15.646	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_SET_7332.stop_all_valves_i null
                                      smartgarden.0	2020-03-31 18:08:15.645	info	(11408) sgSetState: sg.0.L_504a.D_7332.S_VALVE_SET_7332.state_value OK
                                      smartgarden.0	2020-03-31 18:08:15.645	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_d2bf229d-d6a9-46d1-98ea-10f3379c7332.SERVICE_VALVE_SET_d2bf229d-d6a9-46d1-98ea-10f3379c7332
                                      smartgarden.0	2020-03-31 18:08:15.642	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.rfLinkState_value ONLINE
                                      smartgarden.0	2020-03-31 18:08:15.642	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.modelType_value GARDENA smart Sensor
                                      smartgarden.0	2020-03-31 18:08:15.641	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.serial_value 00003256
                                      smartgarden.0	2020-03-31 18:08:15.641	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.rfLinkLevel_timestamp 2020-03-31T15:43:17.925+0000
                                      smartgarden.0	2020-03-31 18:08:15.640	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.rfLinkLevel_value 30
                                      smartgarden.0	2020-03-31 18:08:15.640	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.batteryState_timestamp 2020-03-30T21:10:41.910+0000
                                      smartgarden.0	2020-03-31 18:08:15.639	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.batteryState_value OK
                                      smartgarden.0	2020-03-31 18:08:15.639	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.batteryLevel_timestamp 2020-03-30T21:10:41.910+0000
                                      smartgarden.0	2020-03-31 18:08:15.638	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.batteryLevel_value 95
                                      smartgarden.0	2020-03-31 18:08:15.638	info	(11408) sgSetState: sg.0.L_504a.D_c63b.S_COMMON_c63b.name_value Sensor
                                      smartgarden.0	2020-03-31 18:08:15.637	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_c5a76528-97d2-4816-9c90-9589f0fac63b.SERVICE_COMMON_c5a76528-97d2-4816-9c90-9589f0fac63b
                                      smartgarden.0	2020-03-31 18:08:15.636	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.rfLinkState_value ONLINE
                                      smartgarden.0	2020-03-31 18:08:15.636	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.modelType_value GARDENA smart Mower
                                      smartgarden.0	2020-03-31 18:08:15.635	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.serial_value 00008016
                                      smartgarden.0	2020-03-31 18:08:15.635	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.rfLinkLevel_timestamp 2020-03-30T21:12:42.678+0000
                                      smartgarden.0	2020-03-31 18:08:15.634	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.rfLinkLevel_value 70
                                      smartgarden.0	2020-03-31 18:08:15.634	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.batteryState_timestamp 2020-03-30T22:00:42.625+0000
                                      smartgarden.0	2020-03-31 18:08:15.633	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.batteryState_value OK
                                      smartgarden.0	2020-03-31 18:08:15.633	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.batteryLevel_timestamp 2020-03-30T22:00:42.625+0000
                                      smartgarden.0	2020-03-31 18:08:15.632	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.batteryLevel_value 100
                                      smartgarden.0	2020-03-31 18:08:15.632	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_COMMON_b6a2.name_value Tussi
                                      smartgarden.0	2020-03-31 18:08:15.631	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_7044cd9e-41d2-4466-886e-d8786903b6a2.SERVICE_COMMON_7044cd9e-41d2-4466-886e-d8786903b6a2
                                      smartgarden.0	2020-03-31 18:08:15.628	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.operatingHours_value 1159
                                      smartgarden.0	2020-03-31 18:08:15.627	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.activity_timestamp 2020-03-31T15:16:56.719+0000
                                      smartgarden.0	2020-03-31 18:08:15.627	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.activity_control_i null
                                      smartgarden.0	2020-03-31 18:08:15.626	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.activity_mowing_i false
                                      smartgarden.0	2020-03-31 18:08:15.626	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.activity_value PARKED_PARK_SELECTED
                                      smartgarden.0	2020-03-31 18:08:15.625	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.state_timestamp 2020-03-31T15:16:56.719+0000
                                      smartgarden.0	2020-03-31 18:08:15.624	info	(11408) sgSetState: sg.0.L_504a.D_b6a2.S_MOWER_b6a2.state_value OK
                                      smartgarden.0	2020-03-31 18:08:15.624	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_7044cd9e-41d2-4466-886e-d8786903b6a2.SERVICE_MOWER_7044cd9e-41d2-4466-886e-d8786903b6a2
                                      smartgarden.0	2020-03-31 18:08:15.607	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.rfLinkState_value ONLINE
                                      smartgarden.0	2020-03-31 18:08:15.606	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.modelType_value GARDENA smart Water Control
                                      smartgarden.0	2020-03-31 18:08:15.606	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.serial_value 00031728
                                      smartgarden.0	2020-03-31 18:08:15.605	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.rfLinkLevel_timestamp 2020-03-31T15:59:51.659+0000
                                      smartgarden.0	2020-03-31 18:08:15.605	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.rfLinkLevel_value 70
                                      smartgarden.0	2020-03-31 18:08:15.604	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.batteryState_timestamp 2020-03-31T15:59:51.602+0000
                                      smartgarden.0	2020-03-31 18:08:15.604	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.batteryState_value OUT_OF_OPERATION
                                      smartgarden.0	2020-03-31 18:08:15.603	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.batteryLevel_timestamp 2020-03-31T15:59:51.636+0000
                                      smartgarden.0	2020-03-31 18:08:15.603	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.batteryLevel_value 0
                                      smartgarden.0	2020-03-31 18:08:15.602	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_COMMON_9a5d.name_value Blumenbeet Straße
                                      smartgarden.0	2020-03-31 18:08:15.601	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_2512c1ce-5226-414b-8ea3-b61fe40c9a5d.SERVICE_COMMON_2512c1ce-5226-414b-8ea3-b61fe40c9a5d
                                      smartgarden.0	2020-03-31 18:08:15.555	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.state_value OK
                                      smartgarden.0	2020-03-31 18:08:15.555	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.activity_timestamp 2020-03-30T22:59:59.184+0000
                                      smartgarden.0	2020-03-31 18:08:15.554	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.duration_value null
                                      smartgarden.0	2020-03-31 18:08:15.554	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.duration_timestamp
                                      smartgarden.0	2020-03-31 18:08:15.553	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.duration_leftover_i null
                                      smartgarden.0	2020-03-31 18:08:15.553	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.activity_value CLOSED
                                      smartgarden.0	2020-03-31 18:08:15.552	info	(11408) sgSetState: sg.0.L_504a.D_9a5d.S_VALVE_9a5d.name_value Blumenbeet Straße
                                      smartgarden.0	2020-03-31 18:08:15.551	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_2512c1ce-5226-414b-8ea3-b61fe40c9a5d.SERVICE_VALVE_2512c1ce-5226-414b-8ea3-b61fe40c9a5d
                                      smartgarden.0	2020-03-31 18:08:15.549	info	(11408) setServiceStates: smartgarden.0.LOCATION_5a66f03f-74db-4fa0-9e61-38bbded6504a.DEVICE_2512c1ce-5226-414b-8ea3-b61fe40c9a5d.SERVICE_VALVE_SET_2512c1ce-5226-414b-8ea3-b61fe40c9a5d%3Awc
                                      smartgarden.0	2020-03-31 18:08:15.465	info	(11408) parseMessage: COMMON found
                                      smartgarden.0	2020-03-31 18:08:15.464	info	(11408) parseMessage: VALVE found
                                      smartgarden.0	2020-03-31 18:08:15.463	info	(11408) parseMessage: VALVE found
                                      smartgarden.0	2020-03-31 18:08:15.462	info	(11408) parseMessage: VALVE found
                                      smartgarden.0	2020-03-31 18:08:15.461	info	(11408) parseMessage: VALVE found
                                      smartgarden.0	2020-03-31 18:08:15.460	info	(11408) parseMessage: VALVE found
                                      smartgarden.0	2020-03-31 18:08:15.420	info	(11408) parseMessage: VALVE_SET found
                                      smartgarden.0	2020-03-31 18:08:15.419	info	(11408) parseMessage: COMMON found
                                      smartgarden.0	2020-03-31 18:08:15.419	info	(11408) parseMessage: Unknown message found
                                      smartgarden.0	2020-03-31 18:08:15.418	info	(11408) parseMessage: COMMON found
                                      smartgarden.0	2020-03-31 18:08:15.417	info	(11408) parseMessage: MOWER found
                                      smartgarden.0	2020-03-31 18:08:15.416	info	(11408) parseMessage: COMMON found
                                      smartgarden.0	2020-03-31 18:08:15.413	info	(11408) parseMessage: VALVE found
                                      smartgarden.0	2020-03-31 18:08:15.411	info	(11408) parseMessage: VALVE_SET found
                                      smartgarden.0	2020-03-31 18:08:15.409	info	(11408) parseMessage: DEVICE found
                                      smartgarden.0	2020-03-31 18:08:15.408	info	(11408) parseMessage: DEVICE found
                                      smartgarden.0	2020-03-31 18:08:15.406	info	(11408) parseMessage: DEVICE found
                                      smartgarden.0	2020-03-31 18:08:15.404	info	(11408) parseMessage: DEVICE found
                                      smartgarden.0	2020-03-31 18:08:15.400	info	(11408) sgSetState: L_504a.name My Garden
                                      smartgarden.0	2020-03-31 18:08:15.400	info	(11408) parseMessage: LOCATION found
                                      smartgarden.0	2020-03-31 18:08:13.220	info	(11408) on_open: ### connected ###
                                      smartgarden.0	2020-03-31 18:08:12.332	info	(11408) get_websocket ...
                                      smartgarden.0	2020-03-31 18:08:12.330	info	(11408) get_locations: successful / response.statusMessage: OK
                                      smartgarden.0	2020-03-31 18:08:11.768	info	(11408) get_locations ...
                                      smartgarden.0	2020-03-31 18:08:11.766	info	(11408) sgSetState: info.connection true
                                      smartgarden.0	2020-03-31 18:08:11.765	info	(11408) Connection: successful: response.statusCode / statusMessage=200 / OK
                                      smartgarden.0	2020-03-31 18:08:11.230	info	(11408) Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev
                                      smartgarden.0	2020-03-31 18:08:11.229	info	(11408) sgSetState: info.revision Main: 2010 / API: 2010
                                      smartgarden.0	2020-03-31 18:08:11.209	info	(11408) starting. Version 0.4.1 in /opt/iobroker/node_modules/iobroker.smartgarden, node: v10.16.0
                                      host.SmartHome	2020-03-31 18:08:09.927	info	instance system.adapter.smartgarden.0 started with pid 11408
                                      host.SmartHome	2020-03-31 18:08:09.905	info	"system.adapter.smartgarden.0" enabled
                                      host.SmartHome	2020-03-31 18:08:05.075	info	instance system.adapter.smartgarden.0 terminated with code 156 (156)
                                      smartgarden.0	2020-03-31 18:08:04.553	info	(1661) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                      smartgarden.0	2020-03-31 18:08:04.553	info	(1661) terminating
                                      smartgarden.0	2020-03-31 18:08:04.552	info	(1661) Got terminate signal TERMINATE_YOURSELF
                                        muckel @dslraser last edited by
                                        @jpgorganizer
                                        Bei mir werden auch die Datenpunkte nicht angelegt, bei @dslraser schon.
                                        • jpgorganizer
                                          @muckel
                                          schau mal bei den Datenpunkten unter
                                          kannst du da mal einen Screenshot machen, was da so dabei ist. Und ist unter dem Device noch ein anderer Service (SERVICE_xxxxx)?
                                          VG
                                          jpgorganizer
                                            muckel @jpgorganizer last edited by muckel
                                            @jpgorganizer
                                            nein, der screenshot ist alles was da ist vom Sensor.
                                            mehr gibt es nicht.
                                            gardena smart system smartgarden
                                            108
                                            1080
                                            283297
